[Swift-commit] r7140 - in SwiftApps/tryswift: . config
davidk at ci.uchicago.edu
Sun Oct 6 21:22:49 CDT 2013
Author: davidk
Date: 2013-10-06 21:22:49 -0500 (Sun, 06 Oct 2013)
New Revision: 7140
Added:
SwiftApps/tryswift/pushTo.sh
Modified:
SwiftApps/tryswift/config/sites.xml
SwiftApps/tryswift/config/tc.data
SwiftApps/tryswift/getfiles.php
SwiftApps/tryswift/index.php
SwiftApps/tryswift/tryswift.php
Log:
Changes to configuration for running on swiftvm1
Modified: SwiftApps/tryswift/config/sites.xml
--- SwiftApps/tryswift/config/sites.xml 2013-10-07 01:15:08 UTC (rev 7139)
+++ SwiftApps/tryswift/config/sites.xml 2013-10-07 02:22:49 UTC (rev 7140)
@@ -1,9 +1,10 @@
-<config>
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
<pool handle="local">
<execution provider="local" url="none"/>
<profile namespace="karajan" key="jobThrottle">0</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<filesystem provider="local"/>
- <workdirectory>/home/davidk/work</workdirectory>
+ <workdirectory>/home/tryswift/swiftwork</workdirectory>
</pool>
</config>
Modified: SwiftApps/tryswift/config/tc.data
--- SwiftApps/tryswift/config/tc.data 2013-10-07 01:15:08 UTC (rev 7139)
+++ SwiftApps/tryswift/config/tc.data 2013-10-07 02:22:49 UTC (rev 7140)
@@ -5,5 +5,5 @@
local paste /usr/bin/paste
local wc /usr/bin/wc
local sleep /bin/sleep
-local simulate /home/davidk/tryswift/bin/simulate.sh
-local stats /home/davidk/tryswift/bin/stats.sh
+local simulate /home/tryswift/tryswift/bin/simulate.sh
+local stats /home/tryswift/tryswift/bin/stats.sh
Modified: SwiftApps/tryswift/getfiles.php
--- SwiftApps/tryswift/getfiles.php 2013-10-07 01:15:08 UTC (rev 7139)
+++ SwiftApps/tryswift/getfiles.php 2013-10-07 02:22:49 UTC (rev 7140)
@@ -1,8 +1,7 @@
<?PHP
$dir = $_POST['dir'];
-$web_directory = "/home/davidk/tryswift";
-$cmd = "PATH=/usr/bin:/bin:\$PATH /home/tryswift/swift-0.94.1-RC2/bin/swift -sites.file sites.xml -tc.file tc.data script.swift";
+$web_directory = "/home/tryswift/tryswift";
chdir("$web_directory/$dir");
system("$web_directory/waitswift.sh");
@@ -30,7 +29,7 @@
substr($file, -7) != ".swiftx" &&
substr($file, -4) != ".log"
- print "<div class=\"span2\"><a href=\"$dir/$file\" target=\"_new\">$file</a> [" . filesize($file) . " bytes]</div>\n";
+ print "<div class=\"span2\"><a href=\"$dir/$file\" target=\"_blank\">$file</a> [" . filesize($file) . " bytes]</div>\n";
Modified: SwiftApps/tryswift/index.php
--- SwiftApps/tryswift/index.php 2013-10-07 01:15:08 UTC (rev 7139)
+++ SwiftApps/tryswift/index.php 2013-10-07 02:22:49 UTC (rev 7140)
@@ -8,13 +8,6 @@
<body>
<div class="container-fluid">
- <div class="row-fluid">
- <div id="header" class="span12">
- <h2>Try Swift</h2>
- </div>
- </div>
<!-- Script navigation -->
Added: SwiftApps/tryswift/pushTo.sh
--- SwiftApps/tryswift/pushTo.sh (rev 0)
+++ SwiftApps/tryswift/pushTo.sh 2013-10-07 02:22:49 UTC (rev 7140)
@@ -0,0 +1,17 @@
+#!/bin/bash
+src="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
+dst=$1
+if [ -z "$dst" ]; then
+ echo Usage: pushTo.sh destination
+ exit 1
+fi
+if [ ! -d "$dst" ]; then
+ echo Directory $dst does not exist
+ exit 1
+fi
+echo Copying from $src to $dst
+rsync -r --exclude=.svn --exclude=pushTo.sh $src/* $dst
Property changes on: SwiftApps/tryswift/pushTo.sh
___________________________________________________________________
Added: svn:executable
Modified: SwiftApps/tryswift/tryswift.php
--- SwiftApps/tryswift/tryswift.php 2013-10-07 01:15:08 UTC (rev 7139)
+++ SwiftApps/tryswift/tryswift.php 2013-10-07 02:22:49 UTC (rev 7140)
@@ -6,8 +6,8 @@
$source = $_POST['source'];
- $web_directory = "/home/davidk/tryswift";
- $swift_cmd = "PATH=/usr/bin:/bin:\$PATH nohup /home/davidk/swift-0.94/cog/modules/swift/dist/swift-svn/bin/swift -sites.file sites.xml -tc.file tc.data -config cf script.swift";
+ $web_directory = "/home/tryswift/tryswift";
+ $swift_cmd = "nohup /home/tryswift/swift-trunk/cog/modules/swift/dist/swift-svn/bin/swift -sites.file sites.xml -tc.file tc.data -config cf script.swift";
# Create directory structure
$unique = uniqid();
More information about the Swift-commit
