[Swift-commit] r7136 - trunk/libexec
hategan at ci.uchicago.edu
Fri Oct 4 17:46:09 CDT 2013
Author: hategan
Date: 2013-10-04 17:46:09 -0500 (Fri, 04 Oct 2013)
New Revision: 7136
Modified:
trunk/libexec/swift-int-staging.k
trunk/libexec/swift-int.k
trunk/libexec/swift.k
Log:
removed positionals passed as keyword arguments
Modified: trunk/libexec/swift-int-staging.k
--- trunk/libexec/swift-int-staging.k 2013-10-04 22:45:30 UTC (rev 7135)
+++ trunk/libexec/swift-int-staging.k 2013-10-04 22:46:09 UTC (rev 7136)
@@ -66,7 +66,7 @@
ddir := initDDir()
uid := UID()
- jobdir := substring(uid, from=0, to=1)
+ jobdir := substring(uid, 0, to=1)
jobid := "{tr}-{uid}"
log(LOG:DEBUG, "THREAD_ASSOCIATION jobid={jobid} thread=", currentThread(), " host={rhost} replicationGroup={replicationGroup}")
Modified: trunk/libexec/swift-int.k
--- trunk/libexec/swift-int.k 2013-10-04 22:45:30 UTC (rev 7135)
+++ trunk/libexec/swift-int.k 2013-10-04 22:46:09 UTC (rev 7136)
@@ -34,7 +34,7 @@
checkErrorFile := function(rhost, wfdir, jobid, jobdir) {
if (file:exists("{wfdir}/status/{jobdir}/{jobid}-error", host=rhost)) {
log(LOG:INFO, "FAILURE jobid={jobid} - Failure file found")
- task:transfer(srchost=rhost, srcdir="{wfdir}/status/{jobdir}", srcfile="{jobid}-error")
+ task:transfer("{jobid}-error", srchost=rhost, srcdir="{wfdir}/status/{jobdir}")
error := parallel(
file:remove("{wfdir}/status/{jobdir}/{jobid}-error", host=rhost)
sequential(
@@ -77,8 +77,8 @@
sharedDir := dircat(wfdir, "shared")
dir:make(sharedDir, host = rhost)
- transfer(srcdir="{SWIFT:HOME}/libexec/", srcfile=siteProfile(rhost, "swift:wrapperScript"), destdir=sharedDir, desthost=rhost)
- transfer(srcdir="{SWIFT:HOME}/libexec/", srcfile="_swiftseq", destdir=sharedDir, desthost=rhost)
+ transfer(siteProfile(rhost, "swift:wrapperScript"), srcdir="{SWIFT:HOME}/libexec/", destdir=sharedDir, desthost=rhost)
+ transfer("_swiftseq", srcdir="{SWIFT:HOME}/libexec/", destdir=sharedDir, desthost=rhost)
dir:make(dircat(wfdir, "kickstart"), host=rhost)
statusMode := configProperty("status.mode",host=rhost)
@@ -143,26 +143,19 @@
log(LOG:DEBUG, "cdmfile {cdmfile}")
if (cdmfile != "" & cdm:get("GATHER_DIR") != "UNSET") {
log(LOG:INFO, "submitting cdm_cleanup.sh to {dir}")
- task:transfer(srcfile="cdm_cleanup.sh",
+ task:transfer("cdm_cleanup.sh",
srcdir="{SWIFT:HOME}/libexec",
desthost=host, destdir=dir)
- task:transfer(srcfile="cdm_lib.sh",
+ task:transfer("cdm_lib.sh",
log(LOG:INFO, "execute: cdm_cleanup.sh")
- task:execute(
- executable="/bin/bash",
- arguments=list("{dir}/cdm_cleanup.sh",
- cdm:get("GATHER_DIR"), cdm:get("GATHER_TARGET"), UID())
+ task:execute("/bin/bash", list("{dir}/cdm_cleanup.sh", cdm:get("GATHER_DIR"), cdm:get("GATHER_TARGET"), UID())
host=host, batch=true, TCProfile(host))
if (swift:configProperty("sitedir.keep") == "false") {
- task:execute(
- siteProfile(host, "swift:cleanupCommand"),
- arguments=list(
- siteProfile(host, "swift:cleanupCommandOptions"),
- dir
+ task:execute(siteProfile(host, "swift:cleanupCommand"),
+ list(siteProfile(host, "swift:cleanupCommandOptions"), dir)
log(LOG:INFO, "END dir={dir} host={host}")
@@ -188,7 +181,7 @@
dir:make(destdir, host=host, provider=provider)
- task:transfer(srcprovider=provider, srchost=srchost, srcfile=filename, srcdir=srcdir, desthost=host, destdir=destdir)
+ task:transfer(filename, srcprovider=provider, srchost=srchost, srcdir=srcdir, desthost=host, destdir=destdir)
log(LOG:INFO, "END jobid={jobid}")
@@ -202,19 +195,18 @@
"policy={policy}")
if (policy == "DEFAULT") {
restartOnError(2) {
- task:transfer(srcprovider=provider, srchost=srchost, srcfile=srcfile,
+ task:transfer(srcfile, srcprovider=provider, srchost=srchost,
srcdir=srcdir, desthost=desthost, destdir=destdir,
transferParams(srchost, desthost, provider))
else if (policy == "BROADCAST") {
log(LOG:DEBUG, "FILE_STAGE_IN_BROADCAST file={srcfile} policy={policy}")
- cdm:broadcast(srcfile=srcfile, srcdir=srcdir)
+ cdm:broadcast(srcfile, srcdir)
else if (policy == "EXTERNAL") {
log(LOG:DEBUG, "FILE_STAGE_IN_EXTERNAL file={srcfile} policy={policy}")
- cdm:external(srcfile=srcfile, srcdir=srcdir,
- desthost=desthost, destdir=destdir)
+ cdm:external(srcfile, srcdir, desthost, destdir)
else {
log(LOG:DEBUG, "FILE_STAGE_IN_SKIP file={srcfile} policy={policy}")
@@ -233,15 +225,15 @@
libexec := "{SWIFT:HOME}/libexec"
if (cdmfile != "") {
- doStageinFile(provider="file", srchost="localhost", srcfile=basename(cdmfile),
- srcdir=swift:dirname(cdmfile), desthost=host, destdir=dir,
- size=file:size(cdmfile), policy="DEFAULT")
- doStageinFile(provider="file", srchost="localhost", srcfile="cdm.pl",
- srcdir=libexec, desthost=host, destdir=dir,
- size=file:size("{libexec}/cdm.pl}"), policy="DEFAULT")
- doStageinFile(provider="file", srchost="localhost", srcfile="cdm_lib.sh",
- size=file:size("{libexec}/cdm_lib.sh}"), policy="DEFAULT")
+ doStageinFile("file", "localhost", basename(cdmfile),
+ swift:dirname(cdmfile), host, dir,
+ file:size(cdmfile), "DEFAULT")
+ doStageinFile("file", "localhost", "cdm.pl",
+ libexec, host, dir,
+ file:size("{libexec}/cdm.pl}"), "DEFAULT")
+ doStageinFile("file", "localhost", "cdm_lib.sh",
+ file:size("{libexec}/cdm_lib.sh}"), "DEFAULT")
parallelFor(file, files) {
@@ -252,11 +244,11 @@
filename := basename(file)
size := file:size("{srcdir}/{filename}", host=srchost, provider=provider)
- policy := cdm:query(query=file)
+ policy := cdm:query(file)
log(LOG:DEBUG, "CDM: {file} : {policy}")
- doStageinFile(provider=provider, srchost=srchost, srcfile=filename,
- srcdir=srcdir, desthost=host, destdir=destdir, size=size, policy=policy)
+ doStageinFile(provider, srchost, filename,
+ srcdir, host, destdir, size, policy)
log(LOG:INFO, "END jobid={jobid} - Staging in finished")
@@ -267,7 +259,7 @@
done := list(
parallelFor(pv, stageouts) {
(path, var) := each(pv)
- file := absFileName(getField(var, path = path))
+ file := absFileName(getField(var, path))
provider := provider(file)
dhost := hostname(file)
rdir := dircat(dir, reldirname(file))
@@ -280,11 +272,11 @@
"destdir={ldir} desthost={dhost} provider={provider}")
//make sure we do have the directory on the client side
dir:make(ldir, host=dhost, provider=provider)
if ((policy == "DEFAULT") | (policy == "BROADCAST")) {
restartOnError(2) {
- task:transfer(srchost=host, srcfile=bname,srcdir=rdir,
+ task:transfer(bname, srchost=host, srcdir=rdir,
destdir=ldir, desthost=dhost, destprovider=provider,
transferParams(host, dhost, provider))
@@ -317,7 +309,7 @@
(name, file) := each(f)
destfile := concat("{jobid}-", basename(file))
try {
- task:transfer(srchost=rhost, srcdir=tmpdir, srcfile=file, destfile=destfile)
+ task:transfer(file, srchost=rhost, srcdir=tmpdir, destfile=destfile)
"\n {name}: "
strip(file:read(destfile))
@@ -334,7 +326,7 @@
recfile := "{jobid}-info"
srcdir := dircat("{wfdir}/info/", jobdir)
try {
- task:transfer(srchost=rhost, srcdir=srcdir, srcfile=recfile, destdir="{SWIFT:SCRIPT_NAME}-{SWIFT:RUN_ID}.d/")
+ task:transfer(recfile, srchost=rhost, srcdir=srcdir, destdir="{SWIFT:SCRIPT_NAME}-{SWIFT:RUN_ID}.d/")
else catch (exception) {
maybe(file:remove(recfile))
@@ -379,7 +371,7 @@
uid := UID()
Modified: trunk/libexec/swift.k
--- trunk/libexec/swift.k 2013-10-04 22:45:30 UTC (rev 7135)
+++ trunk/libexec/swift.k 2013-10-04 22:46:09 UTC (rev 7136)
@@ -236,7 +236,7 @@
setDatasetValues(stageout)
- mark(restartout, err=false, mapping=false)
+ mark(restartout, false, mapping=false)
log(LOG:INFO, "END_SUCCESS thread=", currentThread(), " tr={tr}")
setProgress(progress, "Finished successfully")
@@ -251,8 +251,8 @@
to(errors, exception)
log(LOG:INFO, exception)
echo(exception)
- mark(restartout, err=true, mapping=false)
- graphStuff(tr, stagein, stageout, err=true, maybe(args=arguments))
+ mark(restartout, true, mapping=false)
+ graphStuff(tr, stagein, stageout, true, maybe(args=arguments))
@@ -272,8 +272,8 @@
- mark(restartout, err=true, mapping=merr)
+ mark(restartout, true, mapping=merr)
More information about the Swift-commit
