[Swift-commit] cog r3806
    swift at ci.uchicago.edu
    Fri Oct  4 17:45:04 CDT 2013
r3806 | hategan | 2013-10-04 17:44:58 -0500 (Fri, 04 Oct 2013) | 1 line
don't allow positional arguments to be passed as keyword arguments and detect this at compile-time
Index: modules/karajan/src/org/globus/cog/karajan/analyzer/Scope.java
--- modules/karajan/src/org/globus/cog/karajan/analyzer/Scope.java	(revision 3805)
+++ modules/karajan/src/org/globus/cog/karajan/analyzer/Scope.java	(working copy)
@@ -536,7 +536,7 @@
 			addVar(v, index++);
 		for (Param o :  optional) {
-            Var v = new ParamWrapperVar.Positional(o);
+            Var v = new ParamWrapperVar.UDFOptional(o);
             addVar(v, index++);
 		return first;
Index: modules/karajan/src/org/globus/cog/karajan/analyzer/ParamWrapperVar.java
--- modules/karajan/src/org/globus/cog/karajan/analyzer/ParamWrapperVar.java	(revision 3805)
+++ modules/karajan/src/org/globus/cog/karajan/analyzer/ParamWrapperVar.java	(working copy)
@@ -44,8 +44,24 @@
 			super.setIndex(index);
 			param.setIndex(index);
+		@Override
+		public boolean isSettableByName() {
+			return false;
+	public static class UDFOptional extends Positional {
+		public UDFOptional(Param p) {
+		    super(p);
+		@Override
+			return true;
 	public static class Optional extends ParamWrapperVar {
 		private IndexRange ir;
Index: modules/karajan/src/org/globus/cog/karajan/analyzer/Var.java
--- modules/karajan/src/org/globus/cog/karajan/analyzer/Var.java	(revision 3805)
+++ modules/karajan/src/org/globus/cog/karajan/analyzer/Var.java	(working copy)
@@ -59,6 +59,10 @@
 		this.canBeNull = canBeNull;
+		return true;
 	@Override
 	public String toString() {
 		if (getValue() == null) {
Index: modules/karajan/src/org/globus/cog/karajan/compiled/nodes/InternalFunction.java
--- modules/karajan/src/org/globus/cog/karajan/compiled/nodes/InternalFunction.java	(revision 3805)
+++ modules/karajan/src/org/globus/cog/karajan/compiled/nodes/InternalFunction.java	(working copy)
@@ -20,7 +20,6 @@
 import k.rt.ExecutionException;
 import k.rt.FutureObject;
 import k.rt.FutureValue;
-import k.rt.IllegalExtraArgumentException;
 import k.rt.Stack;
 import k.thr.LWThread;
 import k.thr.Yield;
@@ -29,7 +28,6 @@
 import org.globus.cog.karajan.analyzer.ArgRef;
 import org.globus.cog.karajan.analyzer.ChannelRef;
 import org.globus.cog.karajan.analyzer.CompilationException;
-import org.globus.cog.karajan.analyzer.CompilerSettings;
 import org.globus.cog.karajan.analyzer.IntrospectionHelper;
 import org.globus.cog.karajan.analyzer.Param;
 import org.globus.cog.karajan.analyzer.ParamWrapperVar;
Index: modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Named.java
--- modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Named.java	(revision 3805)
+++ modules/karajan/src/org/globus/cog/karajan/compiled/nodes/functions/Named.java	(working copy)
@@ -39,7 +39,9 @@
 	@Override
 	public Node compileBody(WrapperNode w, Scope argScope, Scope scope) throws CompilationException {
 		Var vret = scope.parent.lookupParam(name, this);
+		if (!vret.isSettableByName()) {
+			throw new CompilationException(this, "Cannot pass positional argument '" + name + "' by name");
 		if (value.isStatic()) {
 			vret.setValue(value.getValue());
@@ -63,4 +65,15 @@
 			ret.setValue(stack, value.getValue(stack));
+	@Override
+	public String getTextualName() {
+		if (name == null) {
+			return super.getTextualName();
+		else {
+			return name + "=";
\ No newline at end of file
Index: modules/karajan/src/org/globus/cog/karajan/compiled/nodes/user/UserDefinedFunction.java
--- modules/karajan/src/org/globus/cog/karajan/compiled/nodes/user/UserDefinedFunction.java	(revision 3805)
+++ modules/karajan/src/org/globus/cog/karajan/compiled/nodes/user/UserDefinedFunction.java	(working copy)
@@ -106,7 +106,7 @@
 	@Override
 	public Node compileChildren(WrapperNode w, Scope scope) throws CompilationException {
 		List<Param> params = getParams(w, scope);
 		compileOptionalParamValues(params, scope);
 		sig = new Signature(params);
Index: modules/karajan/resources/sys.k
--- modules/karajan/resources/sys.k	(revision 3805)
+++ modules/karajan/resources/sys.k	(working copy)
@@ -1,153 +1,153 @@
 namespace(sys) {
     export(parallel, def("org.globus.cog.karajan.compiled.nodes.Parallel"))
-	export(uparallel, def(classname="org.globus.cog.karajan.compiled.nodes.UParallel"))
-	export(unsynchronized, def(classname="org.globus.cog.karajan.compiled.nodes.UnsynchronizedNode"))
-	export(race, def(classname="org.globus.cog.karajan.compiled.nodes.Race"))
-	export(try, def(classname="org.globus.cog.karajan.compiled.nodes.Try"))
-	export(catch, def(classname="org.globus.cog.karajan.compiled.nodes.Catch"))
-	export(maybe, def(classname="org.globus.cog.karajan.compiled.nodes.Maybe"))
-	export(exclusive, def(classname="org.globus.cog.karajan.compiled.nodes.Exclusive"))
-	export(cache, def(classname="org.globus.cog.karajan.compiled.nodes.CacheNode"))
+	export(uparallel, def("org.globus.cog.karajan.compiled.nodes.UParallel"))
+	export(unsynchronized, def("org.globus.cog.karajan.compiled.nodes.UnsynchronizedNode"))
+	export(race, def("org.globus.cog.karajan.compiled.nodes.Race"))
+	export(try, def("org.globus.cog.karajan.compiled.nodes.Try"))
+	export(catch, def("org.globus.cog.karajan.compiled.nodes.Catch"))
+	export(maybe, def("org.globus.cog.karajan.compiled.nodes.Maybe"))
+	export(exclusive, def("org.globus.cog.karajan.compiled.nodes.Exclusive"))
+	export(cache, def("org.globus.cog.karajan.compiled.nodes.CacheNode"))
-	export(future, def(classname="org.globus.cog.karajan.compiled.nodes.FutureNode"))
-	export(futureChannel, def(classname="org.globus.cog.karajan.compiled.nodes.FutureChannelNode"))
+	export(future, def("org.globus.cog.karajan.compiled.nodes.FutureNode"))
+	export(futureChannel, def("org.globus.cog.karajan.compiled.nodes.FutureChannelNode"))
-	export(echo, def(classname="org.globus.cog.karajan.compiled.nodes.Echo"))
-	export(print, def(classname="org.globus.cog.karajan.compiled.nodes.Print"))
+	export(echo, def("org.globus.cog.karajan.compiled.nodes.Echo"))
+	export(print, def("org.globus.cog.karajan.compiled.nodes.Print"))
-    export(for, def(classname="org.globus.cog.karajan.compiled.nodes.For"))
-    export(parallelFor, def(classname="org.globus.cog.karajan.compiled.nodes.ParallelFor"))
-	export(uParallelFor, def(classname="org.globus.cog.karajan.compiled.nodes.UParallelFor"))
-	export(each, def(classname="org.globus.cog.karajan.compiled.nodes.Each"))
+    export(for, def("org.globus.cog.karajan.compiled.nodes.For"))
+    export(parallelFor, def("org.globus.cog.karajan.compiled.nodes.ParallelFor"))
+	export(uParallelFor, def("org.globus.cog.karajan.compiled.nodes.UParallelFor"))
+	export(each, def("org.globus.cog.karajan.compiled.nodes.Each"))
-    export(restartOnError, def(classname="org.globus.cog.karajan.compiled.nodes.RestartOnErrorNode"))
-    export(throw, def(classname="org.globus.cog.karajan.compiled.nodes.Throw"))
-	export(exception, def(classname="org.globus.cog.karajan.compiled.nodes.functions.KException"))
+    export(restartOnError, def("org.globus.cog.karajan.compiled.nodes.RestartOnErrorNode"))
+    export(throw, def("org.globus.cog.karajan.compiled.nodes.Throw"))
+	export(exception, def("org.globus.cog.karajan.compiled.nodes.functions.KException"))
 	namespace(channel) {
-		export(new, def(classname="org.globus.cog.karajan.compiled.nodes.ChannelNew"))
-		export(from, def(classname="org.globus.cog.karajan.compiled.nodes.ChannelFrom"))
-		export(to, def(classname="org.globus.cog.karajan.compiled.nodes.ChannelTo"))
-		export(fork, def(classname="org.globus.cog.karajan.compiled.nodes.ChannelFork"))
-		export(close, def(classname="org.globus.cog.karajan.compiled.nodes.ChannelClose"))
+		export(new, def("org.globus.cog.karajan.compiled.nodes.ChannelNew"))
+		export(from, def("org.globus.cog.karajan.compiled.nodes.ChannelFrom"))
+		export(to, def("org.globus.cog.karajan.compiled.nodes.ChannelTo"))
+		export(fork, def("org.globus.cog.karajan.compiled.nodes.ChannelFork"))
+		export(close, def("org.globus.cog.karajan.compiled.nodes.ChannelClose"))
-    export(formatNumber, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$FormatNumber"))
-    export(formatDate, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$FormatDate"))
-    export(contains, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$FileContains"))
-	export(file:contains, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$FileContains"))
-    export(UID, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$UID"))
-    export(readFile, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$FileRead"))
-	export(file:read, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$FileRead"))
-	export(property, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Property"))
-	export(getenv, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$GetEnv"))
-	export(outputStream, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$OutputStream"))
-	export(closeStream, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$CloseStream"))
+    export(formatNumber, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$FormatNumber"))
+    export(formatDate, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$FormatDate"))
+    export(contains, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$FileContains"))
+	export(file:contains, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$FileContains"))
+    export(UID, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$UID"))
+    export(readFile, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$FileRead"))
+	export(file:read, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$FileRead"))
+	export(property, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Property"))
+	export(getenv, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$GetEnv"))
+	export(outputStream, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$OutputStream"))
+	export(closeStream, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$CloseStream"))
 	export(contextAttribute, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$ContextAttribute"))
-	export(discard, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Discard"))
-	export(range, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Range"))
-	export(filter, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Filter"))
-	export(sort, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Sort"))
+	export(discard, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Discard"))
+	export(range, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Range"))
+	export(filter, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Filter"))
+	export(sort, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Sort"))
-	export(dot, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Dot"))
-	export(cross, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Cross"))
-	export(unique, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Unique"))
+	export(dot, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Dot"))
+	export(cross, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Cross"))
+	export(unique, def("org.globus.cog.karajan.compiled.nodes.functions.Unique"))
 	namespace(str) {
-		export(strip, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Strip"))
-		export(split, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Split"))
-		export(matches, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Matches"))
-		export(chr, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Chr"))
-		export(substring, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$SubString"))
-		export(quote, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Quote"))
+		export(strip, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Strip"))
+		export(split, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Split"))
+		export(matches, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Matches"))
+		export(chr, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Chr"))
+		export(substring, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$SubString"))
+		export(quote, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Quote"))
 		export(number, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$ParseNumber"))
-	export(time, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Time"))
-	export(once, def(classname="org.globus.cog.karajan.compiled.nodes.Once"))
+	export(time, def("org.globus.cog.karajan.compiled.nodes.functions.Time"))
+	export(once, def("org.globus.cog.karajan.compiled.nodes.Once"))
-	export(wait, def(classname="org.globus.cog.karajan.compiled.nodes.WaitNode"))
-	export(executeFile, def(classname="org.globus.cog.karajan.compiled.nodes.ExecuteFile"))
-	export(file:execute, def(classname="org.globus.cog.karajan.compiled.nodes.ExecuteFile"))
-	export(file:write, def(classname="org.globus.cog.karajan.compiled.nodes.FileWrite"))
+	export(wait, def("org.globus.cog.karajan.compiled.nodes.WaitNode"))
+	export(executeFile, def("org.globus.cog.karajan.compiled.nodes.ExecuteFile"))
+	export(file:execute, def("org.globus.cog.karajan.compiled.nodes.ExecuteFile"))
+	export(file:write, def("org.globus.cog.karajan.compiled.nodes.FileWrite"))
-	export(CBFFunction, def(classname="org.globus.cog.karajan.compiled.nodes.user.CBFFunction"))
-	export(apply, def(classname="org.globus.cog.karajan.compiled.nodes.Apply"))
+	export(CBFFunction, def("org.globus.cog.karajan.compiled.nodes.user.CBFFunction"))
+	export(apply, def("org.globus.cog.karajan.compiled.nodes.Apply"))
-	export(if, def(classname="org.globus.cog.karajan.compiled.nodes.If"))
-	export(while, def(classname="org.globus.cog.karajan.compiled.nodes.While"))
-	export(next, def(classname="org.globus.cog.karajan.compiled.nodes.Next"))
+	export(if, def("org.globus.cog.karajan.compiled.nodes.If"))
+	export(while, def("org.globus.cog.karajan.compiled.nodes.While"))
+	export(next, def("org.globus.cog.karajan.compiled.nodes.Next"))
 	namespace(math) {
-		export(sum, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Sum"))
-		export(sqrt, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Sqrt"))
-		export(equalsNumeric, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$EqualsNumeric"))
-		export(min, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Min"))
-		export(max, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Max"))
-		export(floor, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Floor"))
-		export(round, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Round"))
-		export(ln, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Ln"))
-		export(exp, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Exp"))
-		export(random, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Random"))
-		export(sin, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Sin"))
-		export(cos, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Cos"))
-		export(tan, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Tan"))
-		export(asin, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$ASin"))
-		export(acos, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$ACos"))
-		export(atan, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$ATan"))
-		export(sinh, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Sinh"))
-		export(cosh, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Cosh"))
-		export(tanh, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Tanh"))
-		export(pow, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Pow"))
+		export(sum, def("org.globus.cog.karajan.compiled.nodes.functions.Sum"))
+		export(sqrt, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Sqrt"))
+		export(equalsNumeric, def("org.globus.cog.karajan.compiled.nodes.functions.Math$EqualsNumeric"))
+		export(min, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Min"))
+		export(max, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Max"))
+		export(floor, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Floor"))
+		export(round, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Round"))
+		export(ln, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Ln"))
+		export(exp, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Exp"))
+		export(random, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Random"))
+		export(sin, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Sin"))
+		export(cos, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Cos"))
+		export(tan, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Tan"))
+		export(asin, def("org.globus.cog.karajan.compiled.nodes.functions.Math$ASin"))
+		export(acos, def("org.globus.cog.karajan.compiled.nodes.functions.Math$ACos"))
+		export(atan, def("org.globus.cog.karajan.compiled.nodes.functions.Math$ATan"))
+		export(sinh, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Sinh"))
+		export(cosh, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Cosh"))
+		export(tanh, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Tanh"))
+		export(pow, def("org.globus.cog.karajan.compiled.nodes.functions.Math$Pow"))
-	export(equals, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Equals"))
+	export(equals, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Equals"))
 	namespace(list) {
-		export(append, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$Append"))
-		export(list, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$Cons"))
-		export(prepend, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$Prepend"))
-		export(join, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$Join"))
-		export(size, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$Size"))
-		export(last, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$Last"))
-		export(first, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$First"))
-		export(butLast, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$ButLast"))
-		export(butFirst, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$ButFirst"))
-		export(isEmpty, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$IsEmpty"))
-		export(get, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$Get"))
-		export(isList, def(classname="org.globus.cog.karajan.compiled.nodes.functions.List$IsList"))
+		export(append, def("org.globus.cog.karajan.compiled.nodes.functions.List$Append"))
+		export(list, def("org.globus.cog.karajan.compiled.nodes.functions.List$Cons"))
+		export(prepend, def("org.globus.cog.karajan.compiled.nodes.functions.List$Prepend"))
+		export(join, def("org.globus.cog.karajan.compiled.nodes.functions.List$Join"))
+		export(size, def("org.globus.cog.karajan.compiled.nodes.functions.List$Size"))
+		export(last, def("org.globus.cog.karajan.compiled.nodes.functions.List$Last"))
+		export(first, def("org.globus.cog.karajan.compiled.nodes.functions.List$First"))
+		export(butLast, def("org.globus.cog.karajan.compiled.nodes.functions.List$ButLast"))
+		export(butFirst, def("org.globus.cog.karajan.compiled.nodes.functions.List$ButFirst"))
+		export(isEmpty, def("org.globus.cog.karajan.compiled.nodes.functions.List$IsEmpty"))
+		export(get, def("org.globus.cog.karajan.compiled.nodes.functions.List$Get"))
+		export(isList, def("org.globus.cog.karajan.compiled.nodes.functions.List$IsList"))
 	namespace(map) {
-		export(map, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Map$Cons"))
-		export(put, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Map$Put"))
-		export(delete, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Map$Delete"))
-		export(get, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Map$Get"))
-		export(entry, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Map$EntryCons"))
-		export(size, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Map$Size"))
-		export(contains, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Map$Contains"))
+		export(map, def("org.globus.cog.karajan.compiled.nodes.functions.Map$Cons"))
+		export(put, def("org.globus.cog.karajan.compiled.nodes.functions.Map$Put"))
+		export(delete, def("org.globus.cog.karajan.compiled.nodes.functions.Map$Delete"))
+		export(get, def("org.globus.cog.karajan.compiled.nodes.functions.Map$Get"))
+		export(entry, def("org.globus.cog.karajan.compiled.nodes.functions.Map$EntryCons"))
+		export(size, def("org.globus.cog.karajan.compiled.nodes.functions.Map$Size"))
+		export(contains, def("org.globus.cog.karajan.compiled.nodes.functions.Map$Contains"))
-	export(stats, def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Stats"))
+	export(stats, def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Stats"))
-	export('&', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Logic$And"))
-	export('|', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Logic$Or"))
-	export('!', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Logic$Not"))
+	export('&', def("org.globus.cog.karajan.compiled.nodes.functions.Logic$And"))
+	export('|', def("org.globus.cog.karajan.compiled.nodes.functions.Logic$Or"))
+	export('!', def("org.globus.cog.karajan.compiled.nodes.functions.Logic$Not"))
 	namespace(math) {
-		export('+', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Sum"))
-		export('*', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Product"))
-		export('-', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Difference"))
-		export('neg', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Neg"))
-		export('/', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Quotient"))
-		export('%', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$Remainder"))
-		export('>', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$GreaterThan"))
-		export('<', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$LessThan"))
-		export('>=', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$GreaterOrEqual"))
-		export('<=', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Math$LessOrEqual"))
+		export('+', def("org.globus.cog.karajan.compiled.nodes.functions.Math$Sum"))
+		export('*', def("org.globus.cog.karajan.compiled.nodes.functions.Math$Product"))
+		export('-', def("org.globus.cog.karajan.compiled.nodes.functions.Math$Difference"))
+		export('neg', def("org.globus.cog.karajan.compiled.nodes.functions.Math$Neg"))
+		export('/', def("org.globus.cog.karajan.compiled.nodes.functions.Math$Quotient"))
+		export('%', def("org.globus.cog.karajan.compiled.nodes.functions.Math$Remainder"))
+		export('>', def("org.globus.cog.karajan.compiled.nodes.functions.Math$GreaterThan"))
+		export('<', def("org.globus.cog.karajan.compiled.nodes.functions.Math$LessThan"))
+		export('>=', def("org.globus.cog.karajan.compiled.nodes.functions.Math$GreaterOrEqual"))
+		export('<=', def("org.globus.cog.karajan.compiled.nodes.functions.Math$LessOrEqual"))
-	export('==', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$Equals"))
-	export('!=', def(classname="org.globus.cog.karajan.compiled.nodes.functions.Misc$NotEquals"))
+	export('==', def("org.globus.cog.karajan.compiled.nodes.functions.Misc$Equals"))
+	export('!=', def("org.globus.cog.karajan.compiled.nodes.functions.Misc$NotEquals"))
More information about the Swift-commit
