[Swift-commit] r6517 - in branches/faster: etc src/org/griphyn/vdl/karajan src/org/griphyn/vdl/util
hategan at ci.uchicago.edu
Fri May 24 18:56:24 CDT 2013
Author: hategan
Date: 2013-05-24 18:56:24 -0500 (Fri, 24 May 2013)
New Revision: 6517
Added:
branches/faster/src/org/griphyn/vdl/util/LazyFileAppender.java
Modified:
branches/faster/etc/log4j.properties
branches/faster/src/org/griphyn/vdl/karajan/Loader.java
Log:
bye bye swift.log
Modified: branches/faster/etc/log4j.properties
--- branches/faster/etc/log4j.properties 2013-05-24 23:16:26 UTC (rev 6516)
+++ branches/faster/etc/log4j.properties 2013-05-24 23:56:24 UTC (rev 6517)
@@ -6,7 +6,7 @@
log4j.appender.CONSOLE.Threshold=INFO
log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
-log4j.appender.FILE=org.apache.log4j.FileAppender
+log4j.appender.FILE=org.griphyn.vdl.util.LazyFileAppender
log4j.appender.FILE.File=swift.log
log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
Modified: branches/faster/src/org/griphyn/vdl/karajan/Loader.java
--- branches/faster/src/org/griphyn/vdl/karajan/Loader.java 2013-05-24 23:16:26 UTC (rev 6516)
+++ branches/faster/src/org/griphyn/vdl/karajan/Loader.java 2013-05-24 23:56:24 UTC (rev 6517)
@@ -65,6 +65,7 @@
import org.griphyn.vdl.toolkit.VDLt2VDLx;
import org.griphyn.vdl.toolkit.VDLt2VDLx.IncorrectInvocationException;
import org.griphyn.vdl.toolkit.VDLt2VDLx.ParsingException;
+import org.griphyn.vdl.util.LazyFileAppender;
import org.griphyn.vdl.util.VDL2Config;
import org.griphyn.vdl.util.VDL2ConfigProperties;
import org.griphyn.vdl.util.VDL2ConfigProperties.PropInfo;
@@ -96,9 +97,6 @@
public static String buildVersion;
public static void main(String[] argv) {
- if (logger.isDebugEnabled()) {
- logger.debug("Swift started");
ArgumentParser ap = buildArgumentParser();
String project = null;
try {
@@ -557,6 +555,9 @@
else {
fa.setFile(f.getAbsolutePath());
+ if (fa instanceof LazyFileAppender) {
+ ((LazyFileAppender) fa).fileNameConfigured();
fa.activateOptions();
Level level = Level.WARN;
Added: branches/faster/src/org/griphyn/vdl/util/LazyFileAppender.java
--- branches/faster/src/org/griphyn/vdl/util/LazyFileAppender.java (rev 0)
+++ branches/faster/src/org/griphyn/vdl/util/LazyFileAppender.java 2013-05-24 23:56:24 UTC (rev 6517)
@@ -0,0 +1,95 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on May 24, 2013
+package org.griphyn.vdl.util;
+import java.io.BufferedWriter;
+import java.io.File;
+import java.io.FileNotFoundException;
+import java.io.FileOutputStream;
+import java.io.IOException;
+import java.io.Writer;
+import org.apache.log4j.FileAppender;
+import org.apache.log4j.helpers.LogLog;
+public class LazyFileAppender extends FileAppender {
+ * Override FileAppender.setFile to avoid creating an empty log file before
+ * the code has a chance to customize the file name.
+ public synchronized void setFile(String fileName, boolean append, boolean bufferedIO, int bufferSize)
+ throws IOException {
+ LogLog.debug("setFile called: " + fileName + ", " + append);
+ // set a stdout writer just in case
+ reset();
+ Writer fw = createWriter(System.out);
+ this.setQWForFiles(fw);
+ this.fileName = fileName;
+ this.fileAppend = append;
+ this.bufferedIO = bufferedIO;
+ this.bufferSize = bufferSize;
+ LogLog.debug("setFile ended");
+ * Calling this method will signal this class that the log file name
+ * has been configured and that the file can now be opened.
+ * @throws IOException
+ public void fileNameConfigured() throws IOException {
+ LogLog.debug("fileNameConfigured called");
+ // It does not make sense to have immediate flush and bufferedIO.
+ if (this.bufferedIO) {
+ setImmediateFlush(false);
+ // Save file name since reset() sets it to null
+ String fileName = this.fileName;
+ reset();
+ FileOutputStream ostream = null;
+ try {
+ // attempt to create file
+ ostream = new FileOutputStream(this.fileName, this.fileAppend);
+ catch (FileNotFoundException ex) {
+ // if parent directory does not exist then
+ // attempt to create it and try to create file
+ // see bug 9150
+ String parentName = new File(this.fileName).getParent();
+ if (parentName != null) {
+ File parentDir = new File(parentName);
+ if (!parentDir.exists() && parentDir.mkdirs()) {
+ else {
+ throw ex;
+ else {
+ throw ex;
+ Writer fw = createWriter(ostream);
+ fw = new BufferedWriter(fw, this.bufferSize);
+ writeHeader();
+ LogLog.debug("fileNameConfigured ended");
More information about the Swift-commit
