[Swift-commit] cog r3664
swift at ci.uchicago.edu swift at ci.uchicago.edu
Tue May 21 14:25:05 CDT 2013
r3664 | hategan | 2013-05-21 14:21:51 -0500 (Tue, 21 May 2013) | 1 line
change file copy buffer size for local provider staging from 1kB to 32kB
Index: modules/provider-local/src/org/globus/cog/abstraction/impl/execution/local/JobSubmissionTaskHandler.java
--- modules/provider-local/src/org/globus/cog/abstraction/impl/execution/local/JobSubmissionTaskHandler.java	(revision 3663)
+++ modules/provider-local/src/org/globus/cog/abstraction/impl/execution/local/JobSubmissionTaskHandler.java	(working copy)
@@ -63,7 +63,7 @@
     private static final int STDOUT = 0;
     private static final int STDERR = 1;
-    public static final int BUFFER_SIZE = 1024;
+    public static final int BUFFER_SIZE = 32768;
     private Process process;
     private volatile boolean killed;
