[Swift-commit] r6512 - branches/release-0.94/libexec
davidk at ci.uchicago.edu
Mon May 20 01:00:24 CDT 2013
Author: davidk
Date: 2013-05-20 01:00:24 -0500 (Mon, 20 May 2013)
New Revision: 6512
Modified:
branches/release-0.94/libexec/_swiftwrap.wrapperstaging
Log:
Update to _swiftwrap.wrapperstaging to work with direct:// and stage:// (symlinks and dd)
Modified: branches/release-0.94/libexec/_swiftwrap.wrapperstaging
--- branches/release-0.94/libexec/_swiftwrap.wrapperstaging 2013-05-20 00:35:10 UTC (rev 6511)
+++ branches/release-0.94/libexec/_swiftwrap.wrapperstaging 2013-05-20 06:00:24 UTC (rev 6512)
@@ -56,10 +56,12 @@
localPath() {
- # remove protocol://
- PATH="${1#*://}"
- # remove leading "/" if present
- PATH="${PATH#/}"
+ # remove protocol://
+ PATH="${1#*://}"
+ # Remove hostname
+ PATH="${PATH#*/}"
+ # remove leading "/" if present
+ PATH="${PATH#/}"
log "Transformed $1 to $PATH"
echo $PATH
@@ -80,13 +82,29 @@
case $SRC in
file://*)
- SRC=${SRC#file://}
+ SRC=${SRC#file://*/}
log "Copying $SRC to $DST"
if [ ! -f $SRC ]; then
fail 254 "Cannot stage in $SRC. File not found."
fi
- cp $SRC $DST 2>&1 >& "$INFO"
+ ln -s $SRC $DST 2>&1 >& "$INFO"
+ stage://*)
+ SRC=${SRC#stage://}
+ log "Copying $SRC to $DST"
+ if [ ! -f $SRC ]; then
+ fail 254 "Cannot stage in $SRC. File not found."
+ fi
+ dd if=$SRC of=$DST bs=10M 2>&1 >& "$INFO"
+ direct://*)
+ SRC=${SRC#direct://}
+ log "Linking $SRC to $DST"
+ fail 245 "Cannot stage in $SRC. File not found."
+ fi
http://*)
log "Fetching $SRC using wget"
wget $SRC -O $DST 2>&1 >& "$INFO"
@@ -121,7 +139,7 @@
DIR=`dirname $DST`
mkdir -p $DIR
fail 254 "Cannot handle protocol ${DST%%://*}"
@@ -269,7 +287,6 @@
COMMANDLINE=$@
PARAMFILE=
openinfo "wrapper.log"
More information about the Swift-commit
