[Swift-commit] r6507 - trunk/docs/designs
davidk at ci.uchicago.edu
Wed May 15 11:44:29 CDT 2013
Author: davidk
Date: 2013-05-15 11:44:28 -0500 (Wed, 15 May 2013)
New Revision: 6507
Modified:
trunk/docs/designs/swiftwrap.txt
Log:
Some info on relative vs. absolute paths and how they are handled
Modified: trunk/docs/designs/swiftwrap.txt
--- trunk/docs/designs/swiftwrap.txt 2013-05-14 16:58:46 UTC (rev 6506)
+++ trunk/docs/designs/swiftwrap.txt 2013-05-15 16:44:28 UTC (rev 6507)
@@ -6,7 +6,7 @@
|Argument | Description
| -a | Command line arguments passed to app
-| -d | DIRS?
+| -d | List of directories to create
| -e | App to execute
| -err | Where to write stderr
| -i | Set stdin
@@ -21,10 +21,60 @@
| -wt | Wrapper log always transfer, true/false
-Enabling wrapper staging
+Swift properties related to wrapper staging
+[options="header"]
+|Setting | Description
+| use.wrapper.staging | If set to true, enable wrapper staging. Defaults to false.
+| wrapper.staging.local.server | Swift passes a URL prefix to swiftwrap.wrapperstaging that determines how to access local files. This setting determines what the prefix is (for example, file://).
+Protocols
+Below is a list of protocols supported by _swiftwrap.wrapperstaging and a brief explanation of how they are implemented.
+http://
+HTTP is implemented in _swiftwrap.wrapperstaging via the wget command.
+file://
+TODO: How to set different modes of file staging?
+gsiftp://
+GSIFTP files will be transferred using the globus-url-copy command.
+Examples of how swiftwrap is called
+Using absolute pathnames
+In this example, Swift tries to map the file below using an absolute path
-use.wrapper.staging=true
-wrapper.staging.local.server=file://
+file data <"/home/davidkelly999/staging/dd-absolute/data.txt">;
+._swiftwrap.wrapperstaging arguments
+| -if | file://localhost//home/davidkelly999/staging/dd-absolute/data.txt
+| -of | catsn.0001.out
+| -urlprefix | file:///home/davidkelly999/staging/dd-absolute
+| -d | \__root__/home/davidkelly999/staging/dd-absolute\|.
+| -a | \__root__/home/davidkelly999/staging/dd-absolute/data.txt
+Using relative pathnames
+Here is an example using relative pathnames in Swift.
+file data <"data.txt">;
+| -if | file://localhost/data.txt
+| -urlprefix | file:///home/davidkelly999/staging/dd-relative
+| -d | \|.
+| -a | data.txt
More information about the Swift-commit
