[Swift-commit] r6498 - branches/release-0.94/docs/userguide
davidk at ci.uchicago.edu
Thu May 2 15:59:01 CDT 2013
Author: davidk
Date: 2013-05-02 15:59:01 -0500 (Thu, 02 May 2013)
New Revision: 6498
Modified:
branches/release-0.94/docs/userguide/app_procedures
Log:
Fix capitalization for documentation of @extractInt, @toInt, and @toFloat
Modified: branches/release-0.94/docs/userguide/app_procedures
--- branches/release-0.94/docs/userguide/app_procedures 2013-05-02 15:49:38 UTC (rev 6497)
+++ branches/release-0.94/docs/userguide/app_procedures 2013-05-02 20:59:01 UTC (rev 6498)
@@ -292,9 +292,9 @@
Swift trace: hello
- at extractint
+ at extractInt
- at extractint(file) will read the specified file, parse an integer from
+ at extractInt(file) will read the specified file, parse an integer from
the file contents and return that integer.
@@ -406,15 +406,15 @@
parallel).
- at toint
+ at toInt
- at toint(input) will parse its input string into an integer. This can be
+ at toInt(input) will parse its input string into an integer. This can be
used with @arg to pass input parameters to a Swift script as
integers.
- at tofloat
+ at toFloat
- at tofloat(input) will parse its input string into a floating point number. This can be
+ at toFloat(input) will parse its input string into a floating point number. This can be
floating point numbers.
More information about the Swift-commit
