[Swift-commit] r6408 - trunk/docs/siteguide
    ketan at ci.uchicago.edu
    Wed Mar 27 15:06:41 CDT 2013
Author: ketan
Date: 2013-03-27 15:06:41 -0500 (Wed, 27 Mar 2013)
New Revision: 6408
Modified:
   trunk/docs/siteguide/intrepid
Log:
update
Modified: trunk/docs/siteguide/intrepid
--- trunk/docs/siteguide/intrepid	2013-03-26 18:47:50 UTC (rev 6407)
+++ trunk/docs/siteguide/intrepid	2013-03-27 20:06:41 UTC (rev 6408)
@@ -154,7 +154,7 @@
 Manually Editing tc.data
-Below is the tc.data file used by Swift's test suite for running on PADS.
+Below is the tc.data file used by Swift's test suite.
 include::../../tests/providers/intrepid/tc.template.data[]
@@ -183,8 +183,7 @@
 You should see several new files being created, called catsn.0001.out,
 catsn.0002.out, etc. Each of these files should contain the contents of what
-you placed into data.txt. If this happens, your job has run successfully on
-PADS!
+you placed into data.txt. If this happens, your job has run successfully!
 More Help
More information about the Swift-commit
