[Swift-commit] r6136 - trunk/bin
davidk at ci.uchicago.edu
Mon Jan 7 11:20:43 CST 2013
Author: davidk
Date: 2013-01-07 11:20:43 -0600 (Mon, 07 Jan 2013)
New Revision: 6136
Modified:
trunk/bin/swiftrun
Log:
Start of a bash based swiftrun
Modified: trunk/bin/swiftrun
--- trunk/bin/swiftrun 2013-01-07 04:24:06 UTC (rev 6135)
+++ trunk/bin/swiftrun 2013-01-07 17:20:43 UTC (rev 6136)
@@ -1,230 +1,54 @@
-#!/usr/bin/perl -w
+#!/bin/bash
-use strict;
-use FindBin qw($Bin);
-use lib "$FindBin::Bin/../lib/perl";
-use Cwd;
-use Cwd qw(abs_path);
-use File::Copy;
-use File::Path;
-use Getopt::Long qw(:config permute pass_through);
-use File::Which qw(which where);
-use XML::Simple;
-use Pod::Usage;
-use SwiftConfig;
-# Command line processing
-my @option_sites; # Site name to execute upon
-my $option_script; # Script name to run
-my @option_inputs; # Name of data to include with execution
-my @option_groups; # Name of group/groups to run script on
-my $option_certificate; # Use a default certificate instead of your own
-GetOptions(
- 'site|sites=s{,}' => \@option_sites,
- 'script=s' => \$option_script,
- 'input|inputs=s{,}' => \@option_inputs,
- 'help|man|h' => sub { pod2usage(-verbose => 2); },
- 'group|groups=s{,}' => \@option_groups,
- 'certificate' => \$option_certificate,
-# Check arguments
-initialize_swiftconfig();
-if(!$option_script || (!@option_sites && !@option_groups)) {
- print "Incorrect usage. Try swiftrun -help\n";
- exit;
+# Verify an argument is not null
+verify_not_null()
+ argname=$1; shift
+ if [ _$1 != _ ]; then
+ return 0;
+ else
+ echo $0: value for $argname can not be null
+ exit 1
+ fi
+# Parse command line arguments
+args=""
+script=""
+while [ $# -gt 0 ]
+do
+ case "$1" in
+ -site|-sites|-s) SITES=$2; verify_not_null sites $SITES; shift ;;
+ *) if [ -z "$args" ]; then script="$1"
+ else args+="$1"
+ fi ;;
+ esac
+ shift
+done
# Create run directory
-my $script_filename = strip_directory($option_script);
-my $dotswift_directory = "$ENV{'HOME'}/.swift";
-my @run_directories = <run.????>;
-if(!@run_directories) {
- $run_directories[0] = "run.0000";
-my ($run_number) = $run_directories[-1] =~ m{(\d+)};
-$run_number++;
-my $run_directory = getcwd() . "/" . sprintf "run.%04s", $run_number;
-create_directory($run_directory);
+rundir=$( echo run??? | sed -e 's/^.*run//' | awk '{ printf("run%03d\n", $1+1)}' )
+mkdir $rundir
-# Copy over needed files
-copy_file( "$option_script", "$run_directory" );
+# Create sites.xml
+IFS=","
+echo "<config>" > $rundir/sites.xml
+for site in $SITES
+do
+ gensites -l $site >> $rundir/sites.xml
+done
+echo "</config>" >> $rundir/sites.xml
-# Determine list of sites. Store each swiftconfig directory we need in @sites
-my @sites = ();
+# tc.data
+if [ -f "tc.data" ]; then
+ cp tc.data $rundir
+fi
-# Check for -sites all
-foreach my $option_site (@option_sites) {
- if(lc($option_site) eq 'all') {
- @sites = glob("$dotswift_directory/sites/*");
+# Swift script
+if [ -f "$script" ]; then
+ cp $script $rundir
+fi
-# Everything else specified by -sites
- next;
- if(-d "$dotswift_directory/sites/$option_site") {
- push(@sites, "$dotswift_directory/sites/$option_site");
- else {
- die "Unable to find configuration for $option_site\n";
-# Groups
-foreach my $group(@option_groups) {
- open(GROUPFILE, "$dotswift_directory/groups/$group.group")
- || die "Unable to open file for $group\n";
- while(<GROUPFILE>) {
- chomp($_);
- push(@sites, "$dotswift_directory/sites/$_");
- close(GROUPFILE);
-# Create configuration files for run
-my @sites_xml;
-my @apps_data;
-foreach my $site (@sites) {
- if ( !-d "$site" ) {
- die "Unable to find configuration for $site\n";
- # Sites.xml
- if ( !-e "$site/sites.xml" ) {
- die "Unable to find sites.xml for $site\n";
- open(CURRENT_SITE, "$site/sites.xml")
- || die "Unable to open $site/sites.xml";
- push(@sites_xml, <CURRENT_SITE>);
- close(CURRENT_SITE);
- # Properties
- if( -e "$site/swift.properties") {
- copy_file( "$site/swift.properties", "$run_directory");
- # Applications
- if(-e "$site/apps") {
- open(APPFILE, "$site/apps") || die "Unable to open $site/apps";
- while(<APPFILE>) {
- chomp($_);
- if(-e "$dotswift_directory/apps/$_.apps") {
- open(APPDATA, "$dotswift_directory/apps/$_.apps")
- || die "Unable to open $dotswift_directory/apps/$_.apps";
- my @temp_app_data = <APPDATA>;
- close(APPDATA);
- foreach(@temp_app_data) {
- my $simple_site_name = strip_directory($site);
- s/SWIFTCONFIGURATION/$simple_site_name/ig;
- push(@apps_data, @temp_app_data);
-# Save configuration information
-open(TC, ">>$run_directory/tc.data")
- || die "Unable to write to $run_directory/tc.data\n";
-print TC @apps_data;
-close(TC);
-open( SITEFILE, ">$run_directory/sites.xml" )
- || die "Unable to open $run_directory/sites.xml for writing\n";
-print SITEFILE "<config>\n at sites_xml</config>\n";
-close(SITEFILE);
-# Link input data
-foreach my $input_file (@option_inputs) {
- # Check for relative path
- my $first_char = substr $input_file, 0, 1;
- if( $first_char ne '/') {
- $input_file = getcwd() . "/$input_file";
- if ( !-e $input_file ) {
- die "Unable to find requested input file: $input_file\n";
- my $new_path = "$run_directory/" . strip_directory($input_file);
- symlink $input_file, $new_path
- || die "Unable to create symlink to $new_path\n";
-# Handle certificates if needed
-if($option_certificate) {
- $ENV{'X509_CERT_DIR'} = "$FindBin::Bin/../etc/certificate";
- $ENV{'X509_CADIR'} = "$FindBin::Bin/../etc/certificate";
- $ENV{'X509_USER_PROXY'} = "$FindBin::Bin/../etc/certificate/x509up_swift";
-# Run swift
-chdir("$run_directory") || die "Unable to chdir to $run_directory\n";
-print "Executing script $option_script\n";
-print "Check $run_directory for output and debugging information\n";
-my $system_command =
- 'swift '
- . "-sites.file $run_directory/sites.xml "
- . "-tc.file $run_directory/tc.data "
- . "$option_script ";
-if(-e "$run_directory/swift.properties") {
- $system_command .= "-config $run_directory/swift.properties ";
-# Add unknown options
-foreach my $unknown_argument (@ARGV) {
- $system_command .= "$unknown_argument ";
-# Execute
-system($system_command);
-my $sec = (time - $^T);
-my $hours = ($sec/(60*60))%24;
-my $mins = ($sec/60)%60;
-my $secs = $sec%60;
-my $datestring = sprintf("%dh:%dm:%ds", $hours, $mins, $secs);
-print "Script $option_script finished in $datestring\n";
-__END__
-=head1 NAME
-swiftrun - Run swift using configurations generated by swiftconfig
-=head1 SYNOPSIS
-swiftrun [B<-option> value]
-=head1 OVERVIEW
-The swiftrun program allows you to execute swift using configurations
-generated by swiftconfig.
-=head1 DESCRIPTION
-General operations:
- -site <site1 site2> Execute swift on given sitename(s)
- -script file.swift Specify the swift script to run
- -input <file1 file2> Link to data required for execution
- -groups <group1 group2> Run script on a site grouping
-=head1 EXAMPLES
-Run a script on a single site
- swiftrun -site local -script my.script
-Run a script on multiple sites
- swiftrun -site host1 host2 -script my.script
-Run a script on all available configurations
- swiftrun -site all -script my.script
-Link multiple files
- swiftrun -site local -script my.script -input /foo/file* /foo2/file*
-=cut
+# Run
+cd $rundir
+time swift -sites.file sites.xml -tc.file tc.data $script $args 2>&1 | tee swift.out
More information about the Swift-commit
