[Swift-commit] r6131 - SwiftApps/SciColSim
wilde at ci.uchicago.edu
Fri Jan 4 14:01:38 CST 2013
Author: wilde
Date: 2013-01-04 14:01:38 -0600 (Fri, 04 Jan 2013)
New Revision: 6131
Modified:
SwiftApps/SciColSim/testopt.py
Log:
Adjust time command for Mac OS X differences.
Modified: SwiftApps/SciColSim/testopt.py
--- SwiftApps/SciColSim/testopt.py 2013-01-04 01:16:18 UTC (rev 6130)
+++ SwiftApps/SciColSim/testopt.py 2013-01-04 20:01:38 UTC (rev 6131)
@@ -144,7 +144,7 @@
incrTarget = 134
optimizerRepeats = 1
evolveReruns = 1
- evolveReruns = 240
+ evolveReruns = 20
annealingSteps = 1
alpha_i = "0.0"
@@ -166,8 +166,8 @@
gamma = "0.0"
delta = "0.0"
+ NWorkers = "2"
openmp = ""
- NWorkers = "24"
openmp = "OMP_NUM_THREADS=" + NWorkers
operation = "m" # n=normal, m=manual (runs 1 multi_loss call)
@@ -186,12 +186,17 @@
operation = ""
seed = ""
+if sys.platform == "darwin":
+ timecmd = "/usr/bin/time "
+else:
+ timecmd = "/usr/bin/time -v "
# Run the test
for target in range(startTarget,endTarget,incrTarget):
for i in range(optimizerRepeats):
args = "rm -f bestdb.txt; " + \
- openmp + " " + "/usr/bin/time -v " + app + " " + alpha_i + " " + alpha_m + " " + beta + " " + gamma + " " + delta + " " + str(target) + " 40000 20 " + str(evolveReruns) + \
+ openmp + " " + timecmd + app + " " + alpha_i + " " + alpha_m + " " + beta + " " + gamma + " " + delta + " " + str(target) + " 40000 20 " + str(evolveReruns) + \
" 2 " + verboseLevel + " 2. 0.01 " + str(annealingSteps) + " 0.3 2.3 0 0 0 0 0 " + operation + " " + NWorkers + " " + seed \
# + " >& out.T"+str(target)+".i"+str(i) + "; #mv bestdb.txt best.T" + str(target) + ".i" + str(i)
print("\n**** Calling optimizer: "+args+"\n")
More information about the Swift-commit
