[Swift-commit] r6114 - in SwiftApps/SciColSim: . params
wilde at ci.uchicago.edu
Tue Jan 1 16:42:53 CST 2013
Author: wilde
Date: 2013-01-01 16:42:52 -0600 (Tue, 01 Jan 2013)
New Revision: 6114
Modified:
SwiftApps/SciColSim/Makefile
SwiftApps/SciColSim/TODO
SwiftApps/SciColSim/annealing.swift
SwiftApps/SciColSim/optimizer.cpp
SwiftApps/SciColSim/params/ARtest03
SwiftApps/SciColSim/testopt.py
Log:
annealing.swift: do indivudual target_innovation annealing loops iteratively instead of in parallel. Will make parallel an option in a future rev (code is still there). Removed unused unmapped file which was causing a spurious warning '(input) no files'; Makefile: addded targets for non-OpenMP optimizer. optimizer.cpp: return 3*max_loss when ration exceeds max_loss; added some debug traces.
Modified: SwiftApps/SciColSim/Makefile
--- SwiftApps/SciColSim/Makefile 2012-12-30 19:55:18 UTC (rev 6113)
+++ SwiftApps/SciColSim/Makefile 2013-01-01 22:42:52 UTC (rev 6114)
@@ -2,14 +2,13 @@
ifeq ($(UNAME), Linux)
-all: openmp-optimizer graphsim openmptest
+all: optimizer openmp-optimizer graphsim openmptest
openmp-optimizer: optimizer.cpp
- g++ -DP_OPENMP -static -O -fopenmp -I boost_1_47_0 -o openmp-optimizer optimizer.cpp
-# g++ -static -O -I boost_1_47_0 -o openmp-optimizer optimizer.cpp
+ g++ -DP_OPENMP -static -O2 -fopenmp -I boost_1_47_0 -o openmp-optimizer optimizer.cpp
-#t: t.cpp
-# g++ -DP_OPENMP -static -O -fopenmp -I boost_1_47_0 -o t t.cpp
+optimizer: optimizer.cpp
+ g++ -static -O2 -I boost_1_47_0 -o optimizer optimizer.cpp
graphsim: graphsim.cpp
g++ -DP_OPENMP -static -pg -O2 -fopenmp -I boost_1_47_0 -o graphsim graphsim.cpp
@@ -24,11 +23,14 @@
ifeq ($(UNAME), Darwin)
-all: openmp-optimizer dispatch-optimizer orig-optimizer graphsim openmptest
+all: optimizer openmp-optimizer dispatch-optimizer orig-optimizer graphsim openmptest
g++ -DP_OPENMP -fopenmp -I boost_1_47_0 -o openmp-optimizer optimizer.cpp
+ g++ -I boost_1_47_0 -o optimizer optimizer.cpp
g++ -DP_OPENMP -fopenmp -I boost_1_47_0 -g -o graphsim graphsim.cpp
Modified: SwiftApps/SciColSim/TODO
--- SwiftApps/SciColSim/TODO 2012-12-30 19:55:18 UTC (rev 6113)
+++ SwiftApps/SciColSim/TODO 2013-01-01 22:42:52 UTC (rev 6114)
@@ -1,5 +1,49 @@
+--- 2012.1231
+Check running times under actual OPENMP & Node settings. Running 24X?
+Reduce mem to 24X
+Why large neg expos? Eg:
+multi_annealing: AR: 3487.405033 +- 23.971373
+multi_loss: returning: ci=1 cj=0 r.loss=3487.405033 r.sdev=23.971373
+Progress: time: Mon, 31 Dec 2012 06:14:55 +0000 Checking status:1 Finished successfully:841
+multi_loss: returning: ci=0 cj=0 r.loss=3427.572341 r.sdev=24.738546
+multi_annealing: AR: initial: 3427.572341 +- 24.738546
+multi_annealing: AR: 0.9889519936665272 vs 1.0174100270514812E-13
+math/min: result=1.0174100270514812E-13
+multi_annealing: AR: 1,0 1 Did not accept: 1.8783001222853395 (0)
+multi_annealing: AR: 1.8783001222853395 0.0 0.0 0.0 0.0
+multi_loss appCalls=420
+multi_annealing: AR: -0.15939764554651975 1
+[0.0,-0.15939764554651975,0.0,0.0,0.0]
+Why 2X jobs in first wave????
+Run 1000X x 5 TIs first? (parallel run)
+Add select: ser or par
+Need 100 Ann cycles?
+Check calcs in sumloss.sh
+get more resource telemetry (MEM, etc)
+Debug 0.94
+Try Swift/T
+Improve/reduce staging?
--- Questions and Open Issues ---
When sampling the graph, we compress the node ids. Is this OK?
Modified: SwiftApps/SciColSim/annealing.swift
--- SwiftApps/SciColSim/annealing.swift 2012-12-30 19:55:18 UTC (rev 6113)
+++ SwiftApps/SciColSim/annealing.swift 2013-01-01 22:42:52 UTC (rev 6114)
@@ -68,7 +68,7 @@
int annealing_cycles)
int cycle = 10; // const
- int NEVOPARAMS = 5; // const - 5 params, alpha 1,m through delta, does not include target_innovation
+ int NEVOPARAMS = 5; // const - 5 params: alpha_i, alpha_m, beta, gamma, delta
float rejection[][]; // [i][j] where i is cycle and j is evolve-parameter (alpha_i, alpha_m, beta, gamma, delta)
float trejection[][];
@@ -229,7 +229,7 @@
tracef("%q\n", x);
file rfile[];
- file ofile[]; // FIXME: to obtain timings and otehr stats
+ //file ofile[]; // FIXME: to obtain timings and otehr stats
tracef( "multi_loss: entered: ci=%i cj=%i target_innov=%f evolve_reruns=%i x=%q\n",ci, cj, target_innov,evolve_reruns,x );
@@ -268,6 +268,47 @@
// s = readStat(statsfile); FIXME: to obtain timings and other stats
+optimizer_serial_sweep() // Implements logic of python driver script
+ int minrange = @toint(@arg("minrange", "58"));
+ int maxrange = @toint(@arg("maxrange", "59"));
+ int rangeinc = @toint(@arg("rangeinc", "50"));
+ // FIXME: add provision for random priming and random param values when x[i] == -100 (see optimizer.cpp main())
+ int nreps = @toint(@arg("nreps", "1"));
+//file bestfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".best_opt_some")>;
+//file maxfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".max_dist")>;
+# foreach target_innov in [minrange:maxrange:rangeinc] {
+ iterate i {
+ int target_innov = minrange + (i*rangeinc);
+ foreach rep in [1:nreps] {
+ string some_out_filename = @strcat( "best.T", @strcat(target_innov), ".R", @strcat(rep), ".txt" );
+ file outfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".out")>;
+ file lossfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".loss_data")>;
+ (outfile,lossfile) = multi_annealing(some_out_filename,
+ @tofloat(@arg("tstart", "2.0")),
+ @tofloat(@arg("tend", "0.01")),
+ @tofloat(@arg("trejection", "0.3")),
+ @toint(@arg("evoreruns", "100")),
+ @tofloat(@arg("startingjump", "2.3")),
+ [ @tofloat(@arg("alphai", "0.0")),
+ @tofloat(@arg("alpham", "0.0")),
+ @tofloat(@arg("beta", "4.0")),
+ @tofloat(@arg("gamma", "50.0")),
+ @tofloat(@arg("delta", "-1.0"))
+ @tofloat(target_innov),
+ @toint(@arg("annealingcycles", "50")) );
+ } until(target_innov >= (maxrange-rangeinc));
optimizer_sweep() // Implements logic of python driver script
@@ -309,7 +350,7 @@
main()
- optimizer_sweep();
+ optimizer_serial_sweep();
main();
Modified: SwiftApps/SciColSim/optimizer.cpp
--- SwiftApps/SciColSim/optimizer.cpp 2012-12-30 19:55:18 UTC (rev 6113)
+++ SwiftApps/SciColSim/optimizer.cpp 2013-01-01 22:42:52 UTC (rev 6114)
@@ -694,8 +694,8 @@
std::vector<int> d(num_edges(Full_g));
edge_descriptor s;
boost::graph_traits<graph_t>::vertex_descriptor u, v;
+ cout << "reset_world: start id=" << id << endl;
for (int i=0; i<N_nodes-1; i++){
for (int j=i+1; j<N_nodes; j++){
if (Final[i][j] > 0. && Tried[i][j] > 0){
@@ -723,6 +723,7 @@
Tried[i][j]=0.;
+ cout << "reset_world: end id=" << id << endl;
@@ -1004,7 +1005,8 @@
void evolve_to_target_and_save(int istart, int iend, double* storage, int* counters){
- double ALOT=100000000000.;
+ //double ALOT=100000000000.;
+ double ALOT= 3.0 * max_loss; // Per Andrey, 2012.12.29
double ratio = 0.0;
int check = 0;
@@ -1012,6 +1014,7 @@
reset_world();
for (int k = istart; k < iend; k++){
+ cout << "evolve_ttas: k=" << k << endl;
for(int i=0; i< N_epochs && current_novelty < TargetNovelty; i++){
Modified: SwiftApps/SciColSim/params/ARtest03
--- SwiftApps/SciColSim/params/ARtest03 2012-12-30 19:55:18 UTC (rev 6113)
+++ SwiftApps/SciColSim/params/ARtest03 2013-01-01 22:42:52 UTC (rev 6114)
@@ -4,11 +4,11 @@
target_innovation_increment 50 # increment target innovation by this amount
annealing_repeats 1 # times to repeate the entire optimization process for each target_innovation
-annealing_cycles 10 # times to perform the simulated annealing loop for all non-fixed parameters
+annealing_cycles 30 # times to perform the simulated annealing loop for all non-fixed parameters
-evolve_reruns 32 # times to perform evolve_to_target_and_save() (objective function - is batched)
-nworkers 16 # number of parallel threads (cores) to use per invocation of C++ optimizer
-reruns_per_opt_invocation 16 # reruns_per_opt_invocation mod nworkers must == 0 !!! <=== NOTE WELL !!!
+evolve_reruns 48 # times to perform evolve_to_target_and_save() (objective function - is batched)
+nworkers 24 # number of parallel threads (cores) to use per invocation of C++ optimizer
+reruns_per_opt_invocation 24 # reruns_per_opt_invocation mod nworkers must == 0 !!! <=== NOTE WELL !!!
alpha_i 0.0 # 5 evolve() parameters: must be decimal values !!!
alpha_m 0.0 # alpha_i and alpha_m are fixed for now
Modified: SwiftApps/SciColSim/testopt.py
--- SwiftApps/SciColSim/testopt.py 2012-12-30 19:55:18 UTC (rev 6113)
+++ SwiftApps/SciColSim/testopt.py 2013-01-01 22:42:52 UTC (rev 6114)
@@ -10,7 +10,7 @@
app = "./openmp-optimizer"; # For Mac or Linux: Using OpenMP (Default)
#paramset="default"
-paramset="mw2"
+paramset="mw3"
verboseLevel = "1"
print("Running with parameter set " + paramset + "\n\n");
@@ -131,6 +131,26 @@
verboseLevel = "1"
+elif paramset == "mw3": # Timing TEST PARAMETERS by Mike
+ startTarget = 135
+ endTarget = 136
+ incrTarget = 135
+ optimizerRepeats = 1
+ evolveReruns = 1
+ evolveReruns = 2
+ annealingSteps = 1
+ NWorkers = "1"
+ openmp = "OMP_NUM_THREADS=" + NWorkers
+ openmp = ""
+ operation = "m" # n=normal, m=manual (runs 1 multi_loss call)
+ seed = "123456"
+ app = "./graphsim"
+ app = "./openmp-optimizer"
+ app = "./optimizer"
+ verboseLevel = "99"
# Ensure we dont pass new parameters to original optimizer versions
# (but they would be ignored)
@@ -144,9 +164,9 @@
for target in range(startTarget,endTarget,incrTarget):
for i in range(optimizerRepeats):
args = "rm -f bestdb.txt; " + \
- openmp + " " + app + " 0 0 0 0 0 " + str(target) + " 40000 20 " + str(evolveReruns) + \
- " 2 " + verboseLevel + " 2. 0.01 " + str(annealingSteps) + " 0.3 2.3 0 0 0 0 0 " + operation + " " + NWorkers + " " + seed + \
- " >& out.T"+str(target)+".i"+str(i) + "; #mv bestdb.txt best.T" + str(target) + ".i" + str(i)
+ openmp + " " + "/usr/bin/time -v " + app + " 0 -0.673572334121749 -2.0320313590203978 0 0 " + str(target) + " 40000 20 " + str(evolveReruns) + \
+ " 2 " + verboseLevel + " 2. 0.01 " + str(annealingSteps) + " 0.3 2.3 0 0 0 0 0 " + operation + " " + NWorkers + " " + seed \
+ # + " >& out.T"+str(target)+".i"+str(i) + "; #mv bestdb.txt best.T" + str(target) + ".i" + str(i)
print("\n**** Calling optimizer: "+args+"\n")
os.system(args);
More information about the Swift-commit
