[Swift-commit] r6318 - in SwiftApps/modis: . bin conf tutorial
davidk at ci.uchicago.edu
Thu Feb 28 10:55:05 CST 2013
Author: davidk
Date: 2013-02-28 10:55:05 -0600 (Thu, 28 Feb 2013)
New Revision: 6318
Added:
SwiftApps/modis/bin/assemble.sh
SwiftApps/modis/bin/gray.rgb
SwiftApps/modis/bin/rgb_adjust_color.pl
SwiftApps/modis/bin/rgb_downscale.pl
SwiftApps/modis/bin/rgb_draw_rectangle.pl
SwiftApps/modis/bin/rgb_histogram.pl
SwiftApps/modis/tutorial/modis06.swift
Removed:
SwiftApps/modis/bin/adjust_color.pl
SwiftApps/modis/bin/assemble.sh.orig
SwiftApps/modis/bin/assemble.sh.v2
SwiftApps/modis/bin/assemble2.sh
SwiftApps/modis/bin/draw_rectangle.pl
SwiftApps/modis/bin/erasewater.sh
SwiftApps/modis/bin/getlanduse.pl
SwiftApps/modis/bin/gray.png
SwiftApps/modis/bin/setborder.sh
Modified:
SwiftApps/modis/bin/colormodis.sh
SwiftApps/modis/bin/getlanduse.sh
SwiftApps/modis/bin/markmap.sh
SwiftApps/modis/conf/beagle-ssh.cf
SwiftApps/modis/conf/beagle.cf
SwiftApps/modis/conf/fusion.cf
SwiftApps/modis/conf/local-coasters.cf
SwiftApps/modis/conf/local.cf
SwiftApps/modis/conf/midway.cf
SwiftApps/modis/conf/raven.cf
SwiftApps/modis/demo
SwiftApps/modis/tutorial/modis05.swift
Log:
Starting work towards the assembly step
Added rgb_downscale.pl to resample an image
Some clean up
Deleted: SwiftApps/modis/bin/adjust_color.pl
--- SwiftApps/modis/bin/adjust_color.pl 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/adjust_color.pl 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,35 +0,0 @@
-#!/usr/bin/perl
-# Usage: adjust_color.pl input.rgb table.txt output.rgb
-my ($input_filename, $translation_table, $output_filename) = @ARGV;
-open(FILE_INPUT, "$input_filename") || die "Unable to open $input_filename!";
-open(FILE_OUTPUT, ">$output_filename") || die "Unable to create $output_filename";
-# Read translation table into a hash
-my %tr_table = ();
-open(TRANSLATION_TABLE, "$translation_table") || die "Unable to open $translation_table";
-while(<TRANSLATION_TABLE>) {
- my ($from, $to) = split;
- $tr_table{$from} = $to;
-# Read data
-$/ = \3;
-while(<FILE_INPUT>) {
- my $hex = sprintf ("#%2.2X%2.2X%2.2X", unpack('C3', $_));
- if(defined($tr_table{$hex})) {
- my $new_value = $tr_table{$hex};
- print FILE_OUTPUT pack('C3',
- hex(substr($new_value,1,2)),
- hex(substr($new_value,3,2)),
- hex(substr($new_value,5,2))
- else { print FILE_OUTPUT $_; }
-close(FILE_INPUT);
-close(FILE_OUTPUT);
Deleted: SwiftApps/modis/bin/assemble.sh
--- SwiftApps/modis/bin/assemble.sh 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/assemble.sh 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,13 +0,0 @@
-output=$1
-shift
-inputs=$(ls -1 $*)
-labels=""
-for f in $inputs; do
- labels="$labels -label $(echo $f | sed -e 's/^.*\(h..v..\).*/\1/') $f"
-done
-echo doing:
-echo montage $labels -font Courier-Regular $inputs $output
-montage $labels -font Courier-Regular $output
Copied: SwiftApps/modis/bin/assemble.sh (from rev 6307, SwiftApps/modis/bin/assemble2.sh)
--- SwiftApps/modis/bin/assemble.sh (rev 0)
@@ -0,0 +1,68 @@
+#!/bin/bash
+output=$(cd $(dirname $1); echo $PWD/$(basename $1)) # Full pathname of output file
+selected=$(cd $(dirname $2); echo $PWD/$(basename $2)) # Full pathname of input text file "selected"
+indir=$(cd $(dirname $3); echo $PWD/$(basename $3)) # Full pathname of image input dir
+webdir=$4
+echo output=$output
+echo selected=$selected
+echo indir=$indir
+echo webdir=$webdir
+if [ ! -d $webdir ]; then
+ mkdir -p $webdir
+ if [ $? -ne 0 ]; then
+ echo Unable to create $webdir, quitting
+ exit 1
+ fi
+fi
+tmpdir=$( eval mktemp -d $PWD/modis.assemble.XXXX )
+bindir=$(cd $(dirname $0); pwd)
+graytile=$bindir/gray.rgb
+# input files are expected to start with hNNvNN.
+# we reverse this to form the final image
+cd $indir
+for h in {0..35}; do
+ h=$( printf %02d $h );
+ for v in {0..17}; do
+ v=$( printf %02d $v );
+ hv=h${h}v${v}
+ vh=v${v}h${h}
+ # Use graytile if the expected section is not found
+ if [ ! -f $indir/$hv.color.rgb ]; then
+ echo $indir/$hv.color.rgb does not exist
+ cp $graytile $tmpdir
+ mv $tmpdir/gray.rgb $tmpdir/$vh.rgb
+ # Otherwise, downscale input images
+ #elif grep $hv $selected >&/dev/null; then
+ # convert $hv.png -resize 290x290 $tmpdir/t.png
+ # convert $tmp/t.png -bordercolor red -border 5x5 $tmpdir/$vh.png
+ else
+ $bindir/rgb_downscale.pl $indir/$hv.color.rgb 2400 2400 8 $tmpdir/$vh.rgb
+ fi
+ done
+done
+#montage -tile 36x18 -geometry +0+0 $tmpdir/v*png $tmpdir/bigmap.png
+#cp $tmp/bigmap.png $output
+exit 0
+inputs=$(ls -1 $*)
+labels=""
+for f in $inputs; do
+ labels="$labels -label $(echo $f | sed -e 's/^.*\(h..v..\).*/\1/') $f"
+done
+montage $labels -font Courier-Regular $output
Deleted: SwiftApps/modis/bin/assemble.sh.orig
--- SwiftApps/modis/bin/assemble.sh.orig 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/assemble.sh.orig 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,4 +0,0 @@
-output=$1
-shift
-inputs=$(ls -1 $*)
-montage -label '%f' -font Courier-Regular $inputs $output
\ No newline at end of file
Deleted: SwiftApps/modis/bin/assemble.sh.v2
--- SwiftApps/modis/bin/assemble.sh.v2 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/assemble.sh.v2 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,10 +0,0 @@
-output=$1
-shift
-inputs=$(ls -1 $*)
-labels=""
-done
-montage $label -font Courier-Regular $inputs $output
Deleted: SwiftApps/modis/bin/assemble2.sh
--- SwiftApps/modis/bin/assemble2.sh 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/assemble2.sh 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,69 +0,0 @@
-#!/bin/bash
-output=$(cd $(dirname $1); echo $(pwd)/$(basename $1)) # get full pathname of output file
-selected=$(cd $(dirname $2); echo $(pwd)/$(basename $2)) # get full pathname of input file "selected"
-indir=$(cd $(dirname $3); pwd) # get full pathname of input dir "geos"
-webdir=$4
-if [ ! -d $webdir ]; then
- mkdir -p $webdir
- if [ $? -ne 0 ]; then
- echo Unable to create $webdir, quitting
- exit 1
- fi
-fi
-tmpdir=$PWD/$( basename $( mktemp -d modis.assemble.XXXX ) )
-ls -ld $tmpdir
-bindir=$(cd $(dirname $0); pwd)
-graytile=$bindir/gray.png
-# input files are expected to start with hNNvNN.
-# we reverse this to form the final image
-cd $indir
-for h in {0..35}; do
- h=$( printf %02d $h );
- for v in {0..17}; do
- v=$( printf %02d $v );
- hv=h${h}v${v}
- vh=v${v}h${h}
- if [ ! -f $hv*png ]; then
- cp $graytile $tmpdir/$vh.png
- elif grep $hv $selected >&/dev/null; then
- echo "adding border to $hv"
- # add red border
- convert $hv*png -resize 290x290 $tmp/t.png
- convert $tmp/t.png -bordercolor red -border 5x5 $tmp/$vh.png
- else
- cp $hv*png $tmp/$vh.png
- fi
- done
-done
-montage -tile 36x18 -geometry +0+0 $tmp/v*png $tmp/bigmap.png
-convert $tmp/bigmap.png -resize 20% $tmp/map.png
-cp $tmp/map.png $output
-cp $tmp/bigmap.png $output
-if [ -d "$webdir" ]; then
- cp $tmp/map.png $webdir
-fi
-exit 0
-inputs=$(ls -1 $*)
-labels=""
-done
Modified: SwiftApps/modis/bin/colormodis.sh
--- SwiftApps/modis/bin/colormodis.sh 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/colormodis.sh 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,9 +1,9 @@
+#!/bin/bash
# Return a new modis files with the 0-16 pixel values changed to
# colors that reflect the land use of that region. (See legend)
# usage: colormodis.sh original.rgb recolored.rgb
infile=$1
outfile=$2
@@ -32,4 +32,4 @@
#101010 #949494
EOF
-$BINDIR/adjust_color.pl $infile translate.txt $outfile
+$BINDIR/rgb_adjust_color.pl $infile translate.txt $outfile
Deleted: SwiftApps/modis/bin/draw_rectangle.pl
--- SwiftApps/modis/bin/draw_rectangle.pl 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/draw_rectangle.pl 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,37 +0,0 @@
-#!/usr/bin/perl
-# Draw a rectangle on an RGB file
-# Usage: draw_rectangle.pl infile.rgb xmin ymin xmax ymax outfile.rgb
-my ($input_filename, $xres, $yres, $xmin, $ymin, $xmax, $ymax, $output_filename) = @ARGV;
-# Read data three bytes at a time (RGB)
-$/ = \3;
-my $x=0, $y=0;
- (my $red, my $green, my $blue) = unpack('C3', $_);
- #print "$red $green $blue\n";
- # Left and right of rectangle, 2 pixels wide
- if ( $x == $xmin || $x == $xmin+1 || $x == $xmax || $x == $xmax-1 ) {
- if ( $y <= $ymax && $y >= $ymin ) {
- $red="255"; $blue="0"; $green="0"; }
- # Top and bottom, 2 pixels high
- if ( $y == $ymin || $y == $ymin-1 || $y == $ymax || $y == $ymax-1 ) {
- if ( $x <= $xmax && $x >= $xmin ) {
- print FILE_OUTPUT pack('C3', $red, $green, $blue);
- if($x == $xres-1) { $x = 0; $y++; }
- else { $x++; }
-close(FILE_INPUT);
Deleted: SwiftApps/modis/bin/erasewater.sh
--- SwiftApps/modis/bin/erasewater.sh 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/erasewater.sh 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,78 +0,0 @@
-# Return a new modis files with the 0-16 pixel values changed to
-# colors that reflect the land use of that region. (See legend)
-# usage: colormodis.sh modis.tif recolored.tif
-infile=$1
-outfile=$2
-tmp=`mktemp /tmp/modis.$USER.XXXXXX`
-mv $tmp $tmp.tif
-tmp=$tmp.tif
-tmp=$2
-map=`mktemp /tmp/colormap.$USER.XXXXXX`
-# Create color set
- cat |
- sed -e 's/ c.=/ /g' -e 's/[^0-9 ]//g' |
- awk '{printf("#%02x%02x%02x #%02x%02x%02x\n",$1,$2,$3,255,255,255)}') >$map <<EOF
- <Entry c1="32" c2="65" c3="179" c4="255"/>
-EOF
-cp $infile $tmp
-# output logged to stdout/error is ignored by swift for this app()
-while read mval color ; do
- echo color $mval is $color
- echo convert $tmp "-fill" "$color" "-opaque" "$mval" $tmp
- convert $tmp "-fill" "$color" "-opaque" "$mval" $tmp
-done <$map
-exit
-#cp $tmp $outfile
-convert -thumbnail 300x300 $tmp $outfile
-# rm $tmp $map # Keep these for debugging, for now.
-cat >/dev/null <<END # PIXELVALUES
- 0 water
- 1 evergreen needleleaf forest
- 2 evergreen broadleaf forest
- 3 deciduous needleleaf forest
- 4 deciduous broadleaf forest
- 5 mixed forests
- 6 closed shrubland
- 7 open shrublands
- 8 woody savannas
- 9 savannas
- 10 grasslands
- 11 permanent wetlands
- 12 croplands
- 13 urban and built-up
- 14 cropland/natural vegetation mosaic
- 15 snow and ice
- 16 barren or sparsely vegetated
- 254 unclassified
-0 <Entry c1="32" c2="65" c3="179" c4="255"/>
-1 <Entry c1="0" c2="106" c3="15" c4="255"/>
-2 <Entry c1="0" c2="124" c3="37" c4="255"/>
-3 <Entry c1="0" c2="162" c3="91" c4="255"/>
-4 <Entry c1="0" c2="161" c3="37" c4="255"/>
-5 <Entry c1="6" c2="146" c3="40" c4="255"/>
-6 <Entry c1="158" c2="150" c3="104" c4="255"/>
-7 <Entry c1="193" c2="196" c3="143" c4="255"/>
-8 <Entry c1="133" c2="170" c3="91" c4="255"/>
-9 <Entry c1="177" c2="183" c3="65" c4="255"/>
-10 <Entry c1="164" c2="208" c3="126" c4="255"/>
-11 <Entry c1="115" c2="171" c3="174" c4="255"/>
-12 <Entry c1="204" c2="210" c3="83" c4="255"/>
-13 <Entry c1="217" c2="0" c3="0" c4="255"/>
-14 <Entry c1="157" c2="227" c3="110" c4="255"/>
-15 <Entry c1="182" c2="181" c3="194" c4="255"/>
-16 <Entry c1="148" c2="148" c3="148" c4="255"/>
-EOF
Deleted: SwiftApps/modis/bin/getlanduse.pl
--- SwiftApps/modis/bin/getlanduse.pl 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/getlanduse.pl 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,23 +0,0 @@
-#!/usr/bin/perl -w
-# Input to this program should be a raw, greyscale RGB file
-# Usage: getlanduse.pl myfile.rgb
-my $image_filename = shift;
-open(IMAGEFILE, "$image_filename") || die "Unable to open $image_filename!\n";
-binmode IMAGEFILE;
-my @pixelcount;
-foreach my $count (0..255) { $pixelcount[$count] = 0; }
-# Read values, three bytes at a time
-$/ = \3;
-foreach(<IMAGEFILE>) {
- $pixelcount[unpack('C', $_)]++;
-close(IMAGEFILE);
- if($pixelcount[$count] == 0) { next; }
- printf("%d %d %02x\n", $pixelcount[$count], $count, $count);
Modified: SwiftApps/modis/bin/getlanduse.sh
--- SwiftApps/modis/bin/getlanduse.sh 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/getlanduse.sh 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1,4 +1,4 @@
#!/bin/bash
BINDIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
-$BINDIR/getlanduse.pl $1 | sort -rn
+$BINDIR/rgb_histogram.pl $1 | sort -rn
Deleted: SwiftApps/modis/bin/gray.png
(Binary files differ)
Added: SwiftApps/modis/bin/gray.rgb
Property changes on: SwiftApps/modis/bin/gray.rgb
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: SwiftApps/modis/bin/markmap.sh
--- SwiftApps/modis/bin/markmap.sh 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/markmap.sh 2013-02-28 16:55:05 UTC (rev 6318)
@@ -14,7 +14,7 @@
hv=$(echo $f | sed -e 's,^.*/,,' -e 's/\..*//')
h=$(echo $hv | sed -e 's/h//' -e 's/v..//' -e 's/^0//')
v=$(echo $hv | sed -e 's/h..//' -e 's/v//' -e 's/^0//')
- $BINDIR/draw_rectangle.pl $outmap.step $xres $yres $(( $h * 20 )) $(( $v * 20 )) $(( $h * 20 + 20 )) $(( $v * 20 + 20)) $outmap.tmp
+ $BINDIR/rgb_draw_rectangle.pl $outmap.step $xres $yres $(( $h * 20 )) $(( $v * 20 )) $(( $h * 20 + 20 )) $(( $v * 20 + 20)) $outmap.tmp
mv $outmap.tmp $outmap.step
done
Copied: SwiftApps/modis/bin/rgb_adjust_color.pl (from rev 6311, SwiftApps/modis/bin/adjust_color.pl)
--- SwiftApps/modis/bin/rgb_adjust_color.pl (rev 0)
+++ SwiftApps/modis/bin/rgb_adjust_color.pl 2013-02-28 16:55:05 UTC (rev 6318)
@@ -0,0 +1,35 @@
+#!/usr/bin/perl
+# Usage: rgb_adjust_color.pl input.rgb table.txt output.rgb
+my ($input_filename, $translation_table, $output_filename) = @ARGV;
+open(FILE_INPUT, "$input_filename") || die "Unable to open $input_filename!";
+open(FILE_OUTPUT, ">$output_filename") || die "Unable to create $output_filename";
+# Read translation table into a hash
+my %tr_table = ();
+open(TRANSLATION_TABLE, "$translation_table") || die "Unable to open $translation_table";
+while(<TRANSLATION_TABLE>) {
+ my ($from, $to) = split;
+ $tr_table{$from} = $to;
+# Read data
+$/ = \3;
+while(<FILE_INPUT>) {
+ my $hex = sprintf ("#%2.2X%2.2X%2.2X", unpack('C3', $_));
+ if(defined($tr_table{$hex})) {
+ my $new_value = $tr_table{$hex};
+ print FILE_OUTPUT pack('C3',
+ hex(substr($new_value,1,2)),
+ hex(substr($new_value,3,2)),
+ hex(substr($new_value,5,2))
+ else { print FILE_OUTPUT $_; }
+close(FILE_INPUT);
+close(FILE_OUTPUT);
Added: SwiftApps/modis/bin/rgb_downscale.pl
--- SwiftApps/modis/bin/rgb_downscale.pl (rev 0)
+++ SwiftApps/modis/bin/rgb_downscale.pl 2013-02-28 16:55:05 UTC (rev 6318)
@@ -0,0 +1,43 @@
+#!/usr/bin/perl
+# Downscale an rgb image
+# Usage: rgb_downscale.pl input.rgb xres yres scalefactor output.rgb
+sub array_avg {
+ my $result=0;
+ foreach(@_){ $result += $_; }
+ return int($result/@_);
+my ($input_filename, $xres, $yres, $scalefactor, $output_filename) = @ARGV;
+open(FILE_OUTPUT, ">$output_filename") || die "Unable to write to $output_filename!";
+local $/;
+my @values = unpack('C*', <FILE_INPUT>);
+close(FILE_INPUT);
+my $x=0, $y=0;
+while($y < $yres) {
+ my (@reds, @greens, @blues) = ();
+ foreach my $yloc ($y..$y+($scalefactor-1)) {
+ foreach my $xloc ($x..$x+($scalefactor-1)) {
+ my $index = ($yloc * $xres + $xloc) * 3;
+ push(@reds, $values[$index]);
+ push(@greens, $values[$index+1]);
+ push(@blues, $values[$index+2]);
+ my $red = &array_avg(@reds);
+ my $green = &array_avg(@greens);
+ my $blue = &array_avg(@blues);
+ print FILE_OUTPUT pack('C3', $red, $green, $blue);
+ if( ($x+$scalefactor) >= $xres ) { $x = 0; $y += $scalefactor; }
+ else { $x += $scalefactor; }
+close(FILE_INPUT);
Property changes on: SwiftApps/modis/bin/rgb_downscale.pl
Added: svn:executable
Copied: SwiftApps/modis/bin/rgb_draw_rectangle.pl (from rev 6308, SwiftApps/modis/bin/draw_rectangle.pl)
--- SwiftApps/modis/bin/rgb_draw_rectangle.pl (rev 0)
+++ SwiftApps/modis/bin/rgb_draw_rectangle.pl 2013-02-28 16:55:05 UTC (rev 6318)
@@ -0,0 +1,36 @@
+#!/usr/bin/perl
+# Draw a rectangle on an RGB file
+# Usage: draw_rectangle.pl infile.rgb xmin ymin xmax ymax outfile.rgb
+my ($input_filename, $xres, $yres, $xmin, $ymin, $xmax, $ymax, $output_filename) = @ARGV;
+# Read data three bytes at a time (RGB)
+$/ = \3;
+my $x=0, $y=0;
+ (my $red, my $green, my $blue) = unpack('C3', $_);
+ # Left and right of rectangle, 2 pixels wide
+ if ( $x == $xmin || $x == $xmin+1 || $x == $xmax || $x == $xmax-1 ) {
+ if ( $y <= $ymax && $y >= $ymin ) {
+ $red="255"; $blue="0"; $green="0"; }
+ # Top and bottom, 2 pixels high
+ if ( $y == $ymin || $y == $ymin-1 || $y == $ymax || $y == $ymax-1 ) {
+ if ( $x <= $xmax && $x >= $xmin ) {
+ if($x == $xres-1) { $x = 0; $y++; }
+ else { $x++; }
+close(FILE_INPUT);
Copied: SwiftApps/modis/bin/rgb_histogram.pl (from rev 6307, SwiftApps/modis/bin/getlanduse.pl)
--- SwiftApps/modis/bin/rgb_histogram.pl (rev 0)
+++ SwiftApps/modis/bin/rgb_histogram.pl 2013-02-28 16:55:05 UTC (rev 6318)
@@ -0,0 +1,23 @@
+#!/usr/bin/perl -w
+# Input to this program should be a raw, greyscale RGB file
+# Usage: rgb_histogram.pl myfile.rgb
+my $image_filename = shift;
+open(IMAGEFILE, "$image_filename") || die "Unable to open $image_filename!\n";
+binmode IMAGEFILE;
+my @pixelcount;
+foreach my $count (0..255) { $pixelcount[$count] = 0; }
+# Read values, three bytes at a time
+$/ = \3;
+foreach(<IMAGEFILE>) {
+ $pixelcount[unpack('C', $_)]++;
+close(IMAGEFILE);
+ if($pixelcount[$count] == 0) { next; }
+ printf("%d %d %02x\n", $pixelcount[$count], $count, $count);
Deleted: SwiftApps/modis/bin/setborder.sh
--- SwiftApps/modis/bin/setborder.sh 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/bin/setborder.sh 2013-02-28 16:55:05 UTC (rev 6318)
@@ -1 +0,0 @@
-convert $1 -bordercolor red -border 20 $2
Modified: SwiftApps/modis/conf/beagle-ssh.cf
--- SwiftApps/modis/conf/beagle-ssh.cf 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/conf/beagle-ssh.cf 2013-02-28 16:55:05 UTC (rev 6318)
@@ -10,6 +10,6 @@
#app getlanduse=/lustre/beagle/davidk/modis/bin/getlanduse.sh
#app analyzelanduse=/lustre/beagle/davidk/modis/bin/analyzelanduse.sh
#app colormodis=/lustre/beagle/davidk/modis/bin/colormodis.sh
-#app assemble=/lustre/beagle/davidk/modis/bin/assemble2.sh
+#app assemble=/lustre/beagle/davidk/modis/bin/assemble.sh
#app markmap=/lustre/beagle/davidk/modis/bin/markmap.sh
#app echo=/bin/echo
Modified: SwiftApps/modis/conf/beagle.cf
--- SwiftApps/modis/conf/beagle.cf 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/conf/beagle.cf 2013-02-28 16:55:05 UTC (rev 6318)
@@ -10,6 +10,6 @@
#app getlanduse=$PWD/../bin/getlanduse.sh
#app analyzelanduse=$PWD/../bin/analyzelanduse.sh
#app colormodis=$PWD/../bin/colormodis.sh
-#app assemble=$PWD/../bin/assemble2.sh
+#app assemble=$PWD/../bin/assemble.sh
#app markmap=$PWD/../bin/markmap.sh
#app echo=/bin/echo
Modified: SwiftApps/modis/conf/fusion.cf
--- SwiftApps/modis/conf/fusion.cf 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/conf/fusion.cf 2013-02-28 16:55:05 UTC (rev 6318)
@@ -9,6 +9,6 @@
#app echo=/bin/echo
Modified: SwiftApps/modis/conf/local-coasters.cf
--- SwiftApps/modis/conf/local-coasters.cf 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/conf/local-coasters.cf 2013-02-28 16:55:05 UTC (rev 6318)
@@ -10,6 +10,6 @@
#app echo=/bin/echo
Modified: SwiftApps/modis/conf/local.cf
--- SwiftApps/modis/conf/local.cf 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/conf/local.cf 2013-02-28 16:55:05 UTC (rev 6318)
@@ -10,6 +10,6 @@
#app echo=/bin/echo
Modified: SwiftApps/modis/conf/midway.cf
--- SwiftApps/modis/conf/midway.cf 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/conf/midway.cf 2013-02-28 16:55:05 UTC (rev 6318)
@@ -11,6 +11,6 @@
#app echo=/bin/echo
Modified: SwiftApps/modis/conf/raven.cf
--- SwiftApps/modis/conf/raven.cf 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/conf/raven.cf 2013-02-28 16:55:05 UTC (rev 6318)
@@ -10,6 +10,6 @@
#app echo=/bin/echo
Modified: SwiftApps/modis/demo
--- SwiftApps/modis/demo 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/demo 2013-02-28 16:55:05 UTC (rev 6318)
@@ -65,7 +65,13 @@
# Select script
echo
prompt="Pick an option:"
-options=("Tutorial 1" "Tutorial 2" "Tutorial 3" "Tutorial 4")
+options=(
+ "Tutorial 1 - Analyze landuse for a single image"
+ "Tutorial 2 - Analyze landuse for 317 images"
+ "Tutorial 3 - Create text files summarizing results"
+ "Tutorial 4 - Highlight top areas on a map"
+ "Tutorial 5 - Create colored images"
echo "Select script"
PS3="$prompt "
@@ -75,6 +81,7 @@
2 ) run tutorial/modis02.swift; break;;
3 ) run tutorial/modis03.swift; break;;
4 ) run tutorial/modis04.swift; break;;
+ 5 ) run tutorial/modis05.swift; break;;
$(( ${#options[@]}+1 )) ) echo "Goodbye!"; break;;
*) echo "Invalid option. Try another one.";continue;;
esac
Modified: SwiftApps/modis/tutorial/modis05.swift
--- SwiftApps/modis/tutorial/modis05.swift 2013-02-28 02:36:11 UTC (rev 6317)
+++ SwiftApps/modis/tutorial/modis05.swift 2013-02-28 16:55:05 UTC (rev 6318)
@@ -48,7 +48,7 @@
gridmap = markMap(topSelected);
# Create multi-color images for all tiles
-imagefile colorImage[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("landuse/\\1.color.png")>;
+imagefile colorImage[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("colorImages/\\1.color.rgb")>;
foreach g, i in geos {
colorImage[i] = colorModis(g);
Added: SwiftApps/modis/tutorial/modis06.swift
--- SwiftApps/modis/tutorial/modis06.swift (rev 0)
+++ SwiftApps/modis/tutorial/modis06.swift 2013-02-28 16:55:05 UTC (rev 6318)
@@ -0,0 +1,59 @@
+type file;
+type imagefile;
+type landuse;
+app (landuse output) getLandUse (imagefile input)
+ getlanduse @filename(input) stdout=@filename(output);
+app (file output, file tilelist) analyzeLandUse (landuse input[], string usetype, int maxnum)
+ analyzelanduse @output @tilelist usetype maxnum @input;
+app (imagefile grid) markMap (file tilelist)
+ markmap @tilelist @grid;
+app (imagefile output) colorModis (imagefile input)
+ colormodis @input @output;
+# Constants and command line arguments
+int nFiles = @toInt(@arg("nfiles", "1000"));
+int nSelect = @toInt(@arg("nselect", "10"));
+string landType = @arg("landtype", "urban");
+string MODISdir = @arg("modisdir", "../data/modis/2002");
+# Input Dataset
+imagefile geos[] <ext; exec="../bin/modis.mapper", location=MODISdir, suffix=".rgb", n=nFiles>;
+# Compute the land use summary of each MODIS tile
+landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("landuse/\\1.landuse.byfreq")>;
+foreach g,i in geos {
+ land[i] = getLandUse(g);
+# Find the top N tiles (by total area of selected landuse types)
+file topSelected <"topselected.txt">;
+file selectedTiles <"selectedtiles.txt">;
+(topSelected, selectedTiles) = analyzeLandUse(land, landType, nSelect);
+# Mark the top N tiles on a sinusoidal gridded map
+imagefile gridmap <"gridmap.png">;
+gridmap = markMap(topSelected);
+# Create multi-color images for all tiles
+foreach g, i in geos {
+ colorImage[i] = colorModis(g);
+# Assemble a montage of the top selected areas
+imagefile montage<"map.png">;
+assemble(selectedTiles,colorImage,webDir);
More information about the Swift-commit
