[Swift-commit] r6312 - branches/release-0.94/docs/userguide
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Feb 23 15:09:56 CST 2013
Author: hategan
Date: 2013-02-23 15:09:56 -0600 (Sat, 23 Feb 2013)
New Revision: 6312
Modified:
   branches/release-0.94/docs/userguide/language
Log:
added section about associative arrays
Modified: branches/release-0.94/docs/userguide/language
--- branches/release-0.94/docs/userguide/language	2013-02-23 19:18:20 UTC (rev 6311)
+++ branches/release-0.94/docs/userguide/language	2013-02-23 21:09:56 UTC (rev 6312)
@@ -182,6 +182,64 @@
 some initial condition, and then repeatedly run the simulate
 procedure, using each execution's outputs as input to the next step.
+Associative Arrays
+By default, array keys are integers. However, other primitive types are also
+allowed as array keys. The syntax for declaring an array with a key type different
+than the default is:
+<valueType>[<keyType>] array;
+For example, the following code declares and assigns items to an array with string
+keys and float values:
+float[string] a;
+a["one"] = 0.2;
+a["two"] = 0.4;
+In addition to primitive types, a special type named *auto* can be used to
+declare an array for which an additional *append* operation is available:
+int[auto] array;
+foreach i in [1:100] {
+  append(array, i * 2);
+foreach v in array {
+  trace(v);
+Items in an array with *auto* keys cannot be accessed directly using a primitive
+type. The following example results in a compile-time error:
+int[auto] array;
+array[0] = 1;
+However, it is possible to use *auto* key values from one array to access another:
+int[auto] a;
+int[auto] b;
+append(a, 1);
+append(a, 2);
+foreach v, k in a {
+  b[k] = a[k] * 2;
 Ordering of execution
 Non-array variables are single-assignment, which means that they must
