[Swift-commit] r6303 - trunk/docs/userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Feb 21 19:36:09 CST 2013
Author: ketan
Date: 2013-02-21 19:36:08 -0600 (Thu, 21 Feb 2013)
New Revision: 6303
Modified:
   trunk/docs/userguide/configuration_properties
   trunk/docs/userguide/kickstart
   trunk/docs/userguide/profiles
Log:
cleanup and format
Modified: trunk/docs/userguide/configuration_properties
--- trunk/docs/userguide/configuration_properties	2013-02-21 18:53:23 UTC (rev 6302)
+++ trunk/docs/userguide/configuration_properties	2013-02-22 01:36:08 UTC (rev 6303)
@@ -416,6 +416,13 @@
     directory. In such cases, relative mode must be used. (since Swift
     0.9)
+use.wrapper.staging
+    Valid values: true, false
+    Default value: false
+    Determines if the Swift wrapper should do file staging.
 wrapper.parameter.mode
     Controls how Swift will supply parameters to the remote wrapper
Modified: trunk/docs/userguide/kickstart
--- trunk/docs/userguide/kickstart	2013-02-21 18:53:23 UTC (rev 6302)
+++ trunk/docs/userguide/kickstart	2013-02-22 01:36:08 UTC (rev 6303)
@@ -27,5 +27,5 @@
 </pool>
-There are various kickstat.* properties, which have sensible default
+There are various kickstart.* properties, which have sensible default
 values. These are documented in the properties section.
Modified: trunk/docs/userguide/profiles
--- trunk/docs/userguide/profiles	2013-02-21 18:53:23 UTC (rev 6302)
+++ trunk/docs/userguide/profiles	2013-02-22 01:36:08 UTC (rev 6303)
@@ -39,35 +39,47 @@
 swift namespace
-storagesize limits the amount of space that will be used on the remote
-site for temporary files. When more than that amount of space is used,
-the remote temporary file cache will be cleared using the algorithm
-specified in the caching.algorithm property.
-wrapperInterpreter - The wrapper interpreter indicates the command
-(executable) to be used to run the Swift wrapper script. The default is
-"/bin/bash" on Unix sites and "cscript.exe" on Windows sites.
+storagesize
-wrapperInterpreterOptions - Allows specifying additional options to the
-executable used to run the Swift wrapper. The defaults are no options on
-Unix sites and "Nologo" on Windows sites.
+    limits the amount of space that will be used on the remote site for temporary
+    files. When more than that amount of space is used, the remote temporary file
+    cache will be cleared using the algorithm specified in the caching.algorithm
+    property.
-wrapperScript - Specifies the name of the wrapper script to be used on a
-site. The defaults are "_swiftwrap" on Unix sites and "_swiftwrap.vbs"
-on Windows sites. If you specify a custom wrapper script, it must be
-present in the "libexec" directory of the Swift installation.
+wrapperInterpreter
-cleanupCommand Indicates the command to be run at the end of a Swift
-run to clean up the run directories on a remote site. Defaults are
-"/bin/rm" on Unix sites and "cmd.exe" on Windows sites
+    The wrapper interpreter indicates the command (executable) to be used to run
+    the Swift wrapper script. The default is "/bin/bash" on Unix sites and
+    "cscript.exe" on Windows sites.
-cleanupCommandOptions Specifies the options to be passed to the
-cleanup command above. The options are passed in the argument list to
-the cleanup command. After the options, the last argument is the
-directory to be deleted. The default on Unix sites is "-rf". The default
-on Windows sites is ["/C", "del", "/Q"].
+wrapperInterpreterOptions
+    Allows specifying additional options to the executable used to run the Swift
+    wrapper. The defaults are no options on Unix sites and "Nologo" on Windows
+    sites.
+wrapperScript
+    Specifies the name of the wrapper script to be used on a site. The defaults are
+    "_swiftwrap" on Unix sites and "_swiftwrap.vbs" on Windows sites. If you
+    specify a custom wrapper script, it must be present in the "libexec" directory
+    of the Swift installation.
+cleanupCommand
+    Indicates the command to be run at the end of a Swift run to clean up the run
+    directories on a remote site. Defaults are "/bin/rm" on Unix sites and
+    "cmd.exe" on Windows sites
+cleanupCommandOptions
+    Specifies the options to be passed to the cleanup command above. The options
+    are passed in the argument list to the cleanup command.  After the options, the
+    last argument is the directory to be deleted. The default on Unix sites is
+    "-rf". The default on Windows sites is ["/C", "del", "/Q"].
 Globus namespace
 maxwalltime specifies a walltime limit for each job, in minutes.
@@ -80,29 +92,28 @@
 Example:
-localhost	echo	/bin/echo	INSTALLED	INTEL32::LINUX	GLOBUS::maxwalltime="00:20:00"
+localhost echo /bin/echo INSTALLED INTEL32::LINUX GLOBUS::maxwalltime="00:20:00"
-When replication is enabled (see replication), then
-walltime will also be enforced at the Swift client side: when a job has
-been active for more than twice the maxwalltime, Swift will kill the job
-and regard it as failed.
+When replication is enabled (see replication), then walltime will also be
+enforced at the Swift client side: when a job has been active for more than
+twice the maxwalltime, Swift will kill the job and regard it as failed.
-When clustering is used, maxwalltime will be used to select which jobs
-will be clustered together. More information on this is available in the
-clustering section.
+When clustering is used, maxwalltime will be used to select which jobs will be
+clustered together. More information on this is available in the clustering
+section.
-When coasters as used, maxwalltime influences the default coaster
-worker maxwalltime, and which jobs will be sent to which workers. More
-information on this is available in the coasters section.
+When coasters as used, maxwalltime influences the default coaster worker
+maxwalltime, and which jobs will be sent to which workers. More information on
+this is available in the coasters section.
-queue is used by the PBS, GRAM2 and GRAM4 providers. This profile
-entry specifies which queue jobs will be submitted to. The valid queue
-names are site-specific.
+queue is used by the PBS, GRAM2 and GRAM4 providers. This profile entry
+specifies which queue jobs will be submitted to. The valid queue names are
+site-specific.
-host_types specifies the types of host that are permissible for a job
-to run on. The valid values are site-specific. This profile entry is
-used by the GRAM2 and GRAM4 providers.
+host_types specifies the types of host that are permissible for a job to run
+on. The valid values are site-specific. This profile entry is used by the GRAM2
+and GRAM4 providers.
 condor_requirements allows a requirements string to be specified when
 Condor is used as an LRM behind GRAM2. Example:
@@ -111,113 +122,144 @@
 <profile namespace="globus" key="condor_requirements">Arch == "X86_64" || Arch="INTEL"</profile>
-slots When using coasters, this parameter specifies the
-maximum number of jobs/blocks that the coaster scheduler will have
-running at any given time. The default is 20.
+slots
-jobsPerNode - This parameter determines how many coaster workers are
-started one each compute node. The default value is 1.
+    When using coasters, this parameter specifies the maximum number of jobs/blocks
+    that the coaster scheduler will have running at any given time. The default is
+    20.
-nodeGranularity - When allocating a coaster worker block, this parameter
-restricts the number of nodes in a block to a multiple of this value.
-The total number of workers will then be a multiple of workersPerNode *
-nodeGranularity. The default value is 1.
+jobsPerNode
-allocationStepSize - Each time the coaster block scheduler computes a
-schedule, it will attempt to allocate a number of slots from the number
-of available slots (limited using the above slots profile). This
-parameter specifies the maximum fraction of slots that are allocated in
-one schedule. Default is 0.1.
+    This parameter determines how many coaster workers are started one each compute
+    node. The default value is 1.
-lowOverallocation - Overallocation is a function of the walltime of a
-job which determines how long (time-wise) a worker job will be. For
-example, if a number of 10s jobs are submitted to the coaster service,
-and the overallocation for 10s jobs is 10, the coaster scheduler will
-attempt to start worker jobs that have a walltime of 100s. The
-overallocation is controlled by manipulating the end-points of an
-overallocation function. The low endpoint, specified by this parameter,
-is the overallocation for a 1s job. The high endpoint is the
-overallocation for a (theoretical) job of infinite length. The
-overallocation for job sizes in the [1s, +inf) interval is determined
-using an exponential decay function: overallocation(walltime) = walltime
-* (lowOverallocation - highOverallocation) * exp(-walltime *
-overallocationDecayFactor) + highOverallocation The default value of
-lowOverallocation is 10.
+nodeGranularity
-highOverallocation - The high overallocation endpoint (as described
-above). Default: 1
+    When allocating a coaster worker block, this parameter restricts the number of
+    nodes in a block to a multiple of this value.  The total number of workers will
+    then be a multiple of workersPerNode * nodeGranularity. The default value is 1.
-overallocationDecayFactor - The decay factor for the overallocation
-curve. Default 0.001 (1e-3).
+allocationStepSize
-spread - When a large number of jobs is submitted to the a coaster
-service, the work is divided into blocks. This parameter allows a rough
-control of the relative sizes of those blocks. A value of 0 indicates
-that all work should be divided equally between the blocks (and blocks
-will therefore have equal sizes). A value of 1 indicates the largest
-possible spread. The existence of the spread parameter is based on the
-assumption that smaller overall jobs will generally spend less time in
-the queue than larger jobs. By submitting blocks of different sizes,
-submitted jobs may be finished quicker by smaller blocks. Default: 0.9.
+    Each time the coaster block scheduler computes a schedule, it will attempt to
+    allocate a number of slots from the number of available slots (limited using
+    the above slots profile). This parameter specifies the maximum fraction of
+    slots that are allocated in one schedule. Default is 0.1.
-reserve - Reserve time is a time in the allocation of a worker that sits
-at the end of the worker time and is useable only for critical
-operations. For example, a job will not be submitted to a worker if it
-overlaps its reserve time, but a job that (due to inaccurate walltime
-specification) runs into the reserve time will not be killed (note that
-once the worker exceeds its walltime, the queuing system will kill the
-job anyway). Default 10 (s).
+lowOverallocation
-maxnodes - Determines the maximum number of nodes that can be allocated
-in one coaster block. Default: unlimited.
+    Overallocation is a function of the walltime of a job which determines how
+    long (time-wise) a worker job will be. For example, if a number of 10s jobs
+    are submitted to the coaster service, and the overallocation for 10s jobs
+    is 10, the coaster scheduler will attempt to start worker jobs that have a
+    walltime of 100s. The overallocation is controlled by manipulating the
+    end-points of an overallocation function. The low endpoint, specified by
+    this parameter, is the overallocation for a 1s job. The high endpoint is
+    the overallocation for a (theoretical) job of infinite length. The
+    overallocation for job sizes in the [1s, +inf) interval is determined using
+    an exponential decay function:
+    overallocation(walltime) = walltime * (lowOverallocation -
+    highOverallocation) * exp(-walltime * overallocationDecayFactor) +
-maxtime - Indicates the maximum walltime, in seconds, that a coaster
-block can have.
-Default: unlimited.
+    The default value of lowOverallocation is 10.
-remoteMonitorEnabled - If set to "true", the client side will get a
-Swing window showing, graphically, the state of the coaster scheduler
-(blocks, jobs, etc.). Default: false
+highOverallocation
-internalhostname - If the head node has multiple network interfaces,
-only one of which is visible from the worker nodes. The choice of
-which interface is the one that worker nodes can connect to is a
-matter of the particular cluster. This must be set in the your
-sites file to clarify to the workers which exact interface on the
-head node they are to try to connect to.
+    The high overallocation endpoint (as described above). Default: 1
+overallocationDecayFactor
+    The decay factor for the overallocation curve. Default 0.001 (1e-3).
+spread
+    When a large number of jobs is submitted to coaster service, the work is
+    divided into blocks. This parameter allows a rough control of the relative
+    sizes of those blocks. A value of 0 indicates that all work should be divided
+    equally between the blocks (and blocks will therefore have equal sizes). A
+    value of 1 indicates the largest possible spread. The existence of the spread
+    parameter is based on the assumption that smaller overall jobs will generally
+    spend less time in the queue than larger jobs. By submitting blocks of
+    different sizes, submitted jobs may be finished quicker by smaller blocks.
+    Default: 0.9.
+reserve
+    Reserve time is a time in the allocation of a worker that sits
+    at the end of the worker time and is useable only for critical
+    operations. For example, a job will not be submitted to a worker if it
+    overlaps its reserve time, but a job that (due to inaccurate walltime
+    specification) runs into the reserve time will not be killed (note that
+    once the worker exceeds its walltime, the queuing system will kill the
+    job anyway). Default 10 (s).
+maxnodes
+    Determines the maximum number of nodes that can be allocated
+    in one coaster block. Default: unlimited.
+maxtime
+    Indicates the maximum walltime, in seconds, that a coaster
+    block can have.
+    Default: unlimited.
+remoteMonitorEnabled
+    If set to "true", the client side will get a Swing window showing, graphically,
+    the state of the coaster scheduler (blocks, jobs, etc.). Default: false
+internalhostname
+    If the head node has multiple network interfaces,
+    only one of which is visible from the worker nodes. The choice of
+    which interface is the one that worker nodes can connect to is a
+    matter of the particular cluster. This must be set in the your
+    sites file to clarify to the workers which exact interface on the
+    head node they are to try to connect to.
 env namespace
 Profile keys set in the env namespace will be set in the unix
 environment of the executed job. Some environment variables influence
 the worker-side behaviour of Swift:
-PATHPREFIX - set in env namespace profiles. This path is prefixed onto
-the start of the PATH when jobs are executed. It can be more useful
-than setting the PATH environment variable directly, because setting
-PATH will cause the execution site's default path to be lost.
+PATHPREFIX
-SWIFT_JOBDIR_PATH - set in env namespace profiles. If set, then Swift
-will use the path specified here as a worker-node local temporary
-directory to copy input files to before running a job. If unset, Swift
-will keep input files on the site-shared filesystem. In some cases,
-copying to a worker-node local directory can be much faster than having
-applications access the site-shared filesystem directly.
+    set in env namespace profiles. This path is prefixed onto the start of the
+    PATH when jobs are executed. It can be more useful than setting the PATH
+    environment variable directly, because setting PATH will cause the
+    execution site's default path to be lost.
-SWIFT_EXTRA_INFO - set in env namespace profiles. If set, then Swift
-will execute the command specified in SWIFT_EXTRA_INFO on execution
-sites immediately before each application execution, and will record the
-stdout of that command in the wrapper info log file for that job. This
-is intended to allow software version and other arbitrary information
-about the remote site to be gathered and returned to the submit side.
-(since Swift 0.9)
+SWIFT_JOBDIR_PATH
-SWIFT_GEN_SCRIPTS - set in the env namespace profiles. This variable
-just needs to be set, it doesn't matter what it is set to. If set, then Swift
-will keep the script that was used to execute the job in the job directory.
-The script will be called run.sh and will have the command line that Swift
-tried to execute with.
+    set in env namespace profiles. If set, then Swift will use the path
+    specified here as a worker-node local temporary directory to copy input
+    files to before running a job. If unset, Swift will keep input files on the
+    site-shared filesystem. In some cases, copying to a worker-node local
+    directory can be much faster than having applications access the
+    site-shared filesystem directly.
+SWIFT_EXTRA_INFO
+    set in env namespace profiles. If set, then Swift will execute the command
+    specified in SWIFT_EXTRA_INFO on execution sites immediately before each
+    application execution, and will record the stdout of that command in the
+    wrapper info log file for that job. This is intended to allow software
+    version and other arbitrary information about the remote site to be
+    gathered and returned to the submit side.  (since Swift 0.9)
+SWIFT_GEN_SCRIPTS
+    set in the env namespace profiles. This variable just needs to be set, it
+    doesn't matter what it is set to. If set, then Swift will keep the script
+    that was used to execute the job in the job directory.  The script will be
+    called run.sh and will have the command line that Swift tried to execute
+    with.
 === Dynamic profiles
 To set a profile setting based on the value of a Swift variable, you
