[Swift-commit] r6301 - trunk/docs/siteguide
ketan at ci.uchicago.edu
Thu Feb 21 11:05:23 CST 2013
Author: ketan
Date: 2013-02-21 11:05:23 -0600 (Thu, 21 Feb 2013)
New Revision: 6301
Modified:
trunk/docs/siteguide/beagle
trunk/docs/siteguide/stampede
Log:
Formatting
Modified: trunk/docs/siteguide/beagle
--- trunk/docs/siteguide/beagle 2013-02-21 16:47:51 UTC (rev 6300)
+++ trunk/docs/siteguide/beagle 2013-02-21 17:05:23 UTC (rev 6301)
@@ -107,7 +107,8 @@
pbs cat /bin/cat null null null
-More about config and tc file options can be found in the swift userguide here: http://www.ci.uchicago.edu/swift/wwwdev/guides/release-0.93/userguide/userguide.html#_swift_configuration_properties.
+More about config and tc file options can be found in the swift userguide here:
+http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html#_swift_configuration_properties
*step 6.* Run the example using following commandline:
Modified: trunk/docs/siteguide/stampede
--- trunk/docs/siteguide/stampede 2013-02-21 16:47:51 UTC (rev 6300)
+++ trunk/docs/siteguide/stampede 2013-02-21 17:05:23 UTC (rev 6301)
@@ -1,17 +1,19 @@
Stampede
-Stampede is a 10 petaflop supercomputer available as part of XSEDE resources. It employs a batch-oriented
-computational model where-in a SLURM schedular accepts user's jobs and queues
-them in the queueing system for execution. The computational model requires
-a user to prepare the submit files, track job submissions, chackpointing,
-managing input/output data and handling exceptional conditions manually.
+Stampede is a 10 petaflop supercomputer available as part of XSEDE resources.
+It employs a batch-oriented computational model where-in a SLURM schedular
+accepts user's jobs and queues them in the queueing system for execution. The
+computational model requires a user to prepare the submit files, track job
+submissions, chackpointing, managing input/output data and handling exceptional
+conditions manually.
Running Swift under Stampede can accomplish the above tasks with least manual
user intervention. In the following sections, we discuss more about specifics of
running Swift on Stampede. A more detailed information about Swift and its
workings can be found on Swift documentation page here:
http://www.ci.uchicago.edu/swift/wwwdev/docs/index.php
More information on Stampede can be found on XSEDE Stampede website here:
https://www.xsede.org/stampede
@@ -31,10 +33,12 @@
Follow the steps outlined below to get started with Swift on Stampede:
-*step 1.* Install Swift using one of the installation methods documented on Swift home: http://www.ci.uchicago.edu/swift/downloads/index.php, if installing from source, java can be loaded on Stampede using +module load jdk32+ and apache ant could be downloaded from here: http://ant.apache.org
+*step 1.* Install Swift using one of the installation methods documented on Swift home: http://www.ci.uchicago.edu/swift/downloads/index.php,
+if installing from source, java can be loaded on Stampede using +module load jdk32+ and apache ant could be downloaded from here: http://ant.apache.org
*step 2.* Create and change to a directory where your Swift related work will
-stay. (say, +mkdir swift-work+, followed by, +cd swift-work+)
+stay. (say, +mkdir swift-work+, followed by, +cd swift-work+)
*step 3.* To get started with a simple example running the Linux +/bin/cat+ command to read an
input file +data.txt+ and write it to an output file, start with writing a simple Swift source script as follows:
@@ -80,7 +84,7 @@
<profile namespace="globus" key="queue">development</profile>
<!-- for mail notification -->
- <profile namespace="globus" key="slurm.mail-user">myemail at dept.org</profile>
+ <profile namespace="globus" key="slurm.mail-user">me at dept.org</profile>
<profile namespace="globus" key="slurm.mail-type">ALL</profile>
<filesystem provider="local"/>
@@ -108,7 +112,8 @@
stampede cat /bin/cat null null null
-More about config and tc file options can be found in the Swift userguide here: http://www.ci.uchicago.edu/swift/wwwdev/guides/release-0.93/userguide/userguide.html#_swift_configuration_properties.
+More about config and tc file options can be found in the Swift userguide here:
+http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html#_swift_configuration_properties.
@@ -122,7 +127,8 @@
*step 7.* Swift will show a status message as "done" after the job has completed its run in the queue. Check the output in the generated +outdir+ directory (+ls outdir+)
-login3$ swift -sites.file sites.stampede.xml -config cf -tc.file tc catsn.swiftSwift trunk swift-r6290 cog-r3609
+login3$ swift -sites.file sites.stampede.xml -config cf -tc.file tc catsn.swift
+Swift trunk swift-r6290 cog-r3609
RunID: 20130221-1030-faapk389
Progress: time: Thu, 21 Feb 2013 10:30:21 -0600
@@ -153,3 +159,9 @@
$ squeue -u `whoami`
+The output will give an indication of the status of jobs. See the slurm manual for more information on job management commands:
+$ man slurm
More information about the Swift-commit
