[Swift-commit] r6297 - in trunk/docs: merged/userguide userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Wed Feb 20 11:28:17 CST 2013
Author: ketan
Date: 2013-02-20 11:28:17 -0600 (Wed, 20 Feb 2013)
New Revision: 6297
Modified:
   trunk/docs/merged/userguide/coasters
   trunk/docs/userguide/app_procedures
Log:
adding toString and camelcase to functions
Modified: trunk/docs/merged/userguide/coasters
--- trunk/docs/merged/userguide/coasters	2013-02-20 03:04:04 UTC (rev 6296)
+++ trunk/docs/merged/userguide/coasters	2013-02-20 17:28:17 UTC (rev 6297)
@@ -145,8 +145,8 @@
 |jobThrottle |the number of concurrent jobs allowed on a site
-For Advanced Users
+Advanced User-Guide
 //Coasters for advanced users. Getting your hands dirty.
@@ -158,29 +158,9 @@
 Coasters configurations
-//Manual
-//Todo
-//Passive
-//Todo
-//Persistent
-//Todo
-//Summary of Differences Between different Coaster types
-//A tabular representations of highlights of different coaster setups
-//Data Management
-Coaster providers: local, ssh, pbs
+Coaster providers
 Settings and examples for different coaster providers mechanisms.
Modified: trunk/docs/userguide/app_procedures
--- trunk/docs/userguide/app_procedures	2013-02-20 03:04:04 UTC (rev 6296)
+++ trunk/docs/userguide/app_procedures	2013-02-20 17:28:17 UTC (rev 6297)
@@ -292,9 +292,9 @@
 Swift trace: hello
- at extractint
+ at extractInt
- at extractint(file) will read the specified file, parse an integer from
+ at extractInt(file) will read the specified file, parse an integer from
 the file contents and return that integer.
@@ -406,18 +406,24 @@
 parallel).
- at toint
+ at toInt
- at toint(input) will parse its input string into an integer. This can be
+ at toInt(input) will parse its input string into an integer. This can be
 used with @arg to pass input parameters to a Swift script as
 integers.
- at tofloat
- at tofloat(input) will parse its input string into a floating point number. This can be
+ at toFloat
+ at toFloat(input) will parse its input string into a floating point number. This can be
 floating point numbers.
+ at toString
+ at toString(input) will parse its input into a string. This can be
+used with @arg to pass input parameters to a Swift script as
+strings.
 @length
 @length(array) will return the length of an array in Swift. This function will wait for all elements in the array to be written before returning the length.
