[Swift-commit] r6289 - trunk/tests
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Feb 18 14:28:51 CST 2013
Author: ketan
Date: 2013-02-18 14:28:51 -0600 (Mon, 18 Feb 2013)
New Revision: 6289
Modified:
   trunk/tests/README
Log:
minor fix
Modified: trunk/tests/README
--- trunk/tests/README	2013-02-18 15:28:01 UTC (rev 6288)
+++ trunk/tests/README	2013-02-18 20:28:51 UTC (rev 6289)
@@ -1,6 +1,6 @@
 USAGENOTES contains instructions on how to operate the test suite.
 It is an asciidoc document, in order to properly build it run the following command:
-$ asciidoc -a toc USAGENOTES
+$ asciidoc -a toc USAGENOTES.txt
 It will generate an HTML file called USAGENOTES.
 Warning:
