[Swift-commit] r6263 - trunk/docs/userguide
ketan at ci.uchicago.edu
Tue Feb 12 21:56:56 CST 2013
Author: ketan
Date: 2013-02-12 21:56:56 -0600 (Tue, 12 Feb 2013)
New Revision: 6263
Modified:
trunk/docs/userguide/app_procedures
Log:
minor fixes
Modified: trunk/docs/userguide/app_procedures
--- trunk/docs/userguide/app_procedures 2013-02-12 22:50:33 UTC (rev 6262)
+++ trunk/docs/userguide/app_procedures 2013-02-13 03:56:56 UTC (rev 6263)
@@ -91,9 +91,10 @@
procedure call must exist. Files will be mapped in the same way as
for input files.
- (? Is it defined that output subdirectories will be precreated
- before execution or should app executables expect to make them?
- That's probably determined by the present behaviour of wrapper.sh)
+ * The output subdirectories will be precreated
+ before execution by Swift if defined within a Swift script such as the
+ location attribute of a mapper. App executables expect to make them if
+ they are referred to in the wrapper scripts.
* Output produced by running the application executable on some
inputs should be the same no matter how many times, when or where
@@ -104,19 +105,19 @@
Things to not assume:
- * anything about the path of the application workspace directory
+ * Anything about the path of the application workspace directory
- * that either the application workspace directory will be deleted or
+ * That either the application workspace directory will be deleted or
will continue to exist or will remain unmodified after execution
has finished
- * that files can be passed(?def) between application procedure
+ * That files can be passed between application procedure
invocations through any mechanism except through files known to
Swift through the mapping mechanism (there is some exception here
for external datasets - there are a separate set of assertions
that hold for external datasets)
- * that application executables will run on any particular site of
+ * That application executables will run on any particular site of
those available, or than any combination of applications will run
on the same or different sites.
More information about the Swift-commit
