[Swift-commit] cog r3602
swift at ci.uchicago.edu
Sat Feb 9 00:55:11 CST 2013
r3602 | hategan | 2013-02-09 00:50:09 -0600 (Sat, 09 Feb 2013) | 1 line
added ability to override user home for remote coaster services
Index: modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java (revision 3601)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java (working copy)
@@ -54,7 +54,6 @@
import org.globus.cog.karajan.workflow.service.channels.KarajanChannel;
import org.globus.cog.karajan.workflow.service.commands.Command;
import org.globus.cog.karajan.workflow.service.commands.Command.Callback;
-import org.globus.common.CoGProperties;
import org.ietf.jgss.GSSCredential;
public class ServiceManager implements StatusListener {
@@ -64,6 +63,7 @@
public static final String BOOTSTRAP_JAR = "coaster-bootstrap.jar";
public static final String TASK_ATTR_ID = "coaster:serviceid";
+ public static final String ATTR_USER_HOME_OVERRIDE = "userHomeOverride";
private static ServiceManager defaultManager;
@@ -108,8 +108,12 @@
return th;
+ public String reserveService(Service service, String bootHandlerProvider) throws TaskSubmissionException {
+ return reserveService(service, bootHandlerProvider, null);
- public String reserveService(Service service, String bootHandlerProvider) throws TaskSubmissionException {
+ public String reserveService(Service service, String bootHandlerProvider, String userHomeOverride) throws TaskSubmissionException {
ServiceContact contact = service.getServiceContact();
if (logger.isDebugEnabled()) {
logger.debug("Reserving service " + contact);
@@ -121,7 +125,7 @@
if (url == null) {
url =
startService(service, getBootHandler(bootHandlerProvider),
- bootHandlerProvider);
+ bootHandlerProvider, userHomeOverride);
increaseUsageCount(contact);
return url;
@@ -133,7 +137,12 @@
public String reserveService(Task task, String bootHandlerProvider)
- return reserveService(getService(task), bootHandlerProvider);
+ String userHomeOverride = null;
+ if (task.getType() == Task.JOB_SUBMISSION) {
+ JobSpecification spec = (JobSpecification) task.getSpecification();
+ userHomeOverride = (String) spec.getAttribute(ATTR_USER_HOME_OVERRIDE);
+ return reserveService(getService(task), bootHandlerProvider, userHomeOverride);
private Service getService(Task task) {
@@ -159,13 +168,13 @@
// private static final String[] STRING_ARRAY = new String[0];
- protected String startService(Service service, TaskHandler bootHandler,
- String bootHandlerProvider) throws Exception {
+ protected String startService(final Service service, TaskHandler bootHandler,
+ String bootHandlerProvider, String userHomeOverride) throws Exception {
SecurityContext sc = service.getSecurityContext();
try {
startLocalService();
- final Task t = buildTask(service);
+ final Task t = buildTask(service, userHomeOverride);
t.addStatusListener(this);
@@ -188,7 +197,8 @@
t.setAttribute(TASK_ATTR_ID, id);
new Thread(new Runnable() {
public void run() {
- CoasterService.main(new String[] { ls, id, "-local" });
+ CoasterService.main(new String[] { ls, id, "-local", "-shared.dir",
+ (String) service.getAttribute(ATTR_USER_HOME_OVERRIDE) });
}).start();
@@ -286,7 +296,7 @@
return task.getService(0).getSecurityContext();
- private Task buildTask(Service service) throws TaskSubmissionException {
+ private Task buildTask(Service service, String userHomeOverride) throws TaskSubmissionException {
try {
Task t = new TaskImpl();
t.setType(Task.JOB_SUBMISSION);
@@ -297,7 +307,8 @@
js.addArgument(loadBootstrapScript(new String[] { getBootstrapServiceURL(),
getLocalServiceURL(), getMD5(BOOTSTRAP_JAR), getMD5(Bootstrap.BOOTSTRAP_LIST),
- id, service.getServiceContact().getHost() }));
+ id, service.getServiceContact().getHost(),
+ userHomeOverride }));
js.setDelegation(Delegation.FULL_DELEGATION);
js.setStdOutputLocation(FileLocation.MEMORY);
js.setStdErrorLocation(FileLocation.MEMORY);
Index: modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/bootstrap/Bootstrap.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/bootstrap/Bootstrap.java (revision 3601)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/bootstrap/Bootstrap.java (working copy)
@@ -187,6 +187,8 @@
addDebuggingOptions(args);
args.add("-Xmx256M");
args.add("-Dtcp.channel.log.io.performance=true");
+ //pass user home override to service
+ args.add("-Duser.home=" + System.getProperty("user.home"));
//args.add("-agentlib:hprof=file=c.hprof");
addProperties(args);
args.add("-cp");
Index: modules/provider-coaster/resources/bootstrap.sh
--- modules/provider-coaster/resources/bootstrap.sh (revision 3601)
+++ modules/provider-coaster/resources/bootstrap.sh (working copy)
@@ -3,9 +3,10 @@
EMD5=$3
ID=$5
H=$6
-L=$7
+HO=$7
B="coaster-bootstrap"
error() {
echo $1
echo $1 >>$L
@@ -54,8 +55,12 @@
eval "$@"
+if [ "$HO" == "" ]; then
+ HO=$HOME
+fi
if [ "$L" == "" ]; then
- L=~/$B-$ID.log
+ L=$HO/$B-$ID.log
fi
detectPaths
DJ=`mktemp /tmp/bootstrap.XXXXXX`
@@ -88,9 +93,10 @@
if [ "$AAMD5" != "$EMD5" ]; then
error "Bootstrap jar checksum failed: $EMD5 != $AAMD5"
fi
echo "JAVA=$JAVA" >>$L
if [ -x $JAVA ]; then
- CMD="$WR $JAVA -Djava=\"$JAVA\" -DGLOBUS_TCP_PORT_RANGE=\"$GLOBUS_TCP_PORT_RANGE\" -DX509_USER_PROXY=\"$X509_USER_PROXY\" -DX509_CERT_DIR=\"$X509_CERT_DIR\" -DGLOBUS_HOSTNAME=\"$H\" -jar $DJ $BS $LS $ID"
+ CMD="$WR $JAVA -Djava=\"$JAVA\" -DGLOBUS_TCP_PORT_RANGE=\"$GLOBUS_TCP_PORT_RANGE\" -DX509_USER_PROXY=\"$X509_USER_PROXY\" -DX509_CERT_DIR=\"$X509_CERT_DIR\" -DGLOBUS_HOSTNAME=\"$H\" -Duser.home=\"$HO\" -jar $DJ $BS $LS $ID"
echo $CMD >>$L
eval $CMD >>$L
EC=$?
More information about the Swift-commit
