[Swift-commit] r6252 - branches/faster/src/org/griphyn/vdl/karajan
hategan at ci.uchicago.edu
Fri Feb 8 23:29:51 CST 2013
Author: hategan
Date: 2013-02-08 23:29:51 -0600 (Fri, 08 Feb 2013)
New Revision: 6252
Modified:
branches/faster/src/org/griphyn/vdl/karajan/Loader.java
Log:
use .swiftx for intermediate code and fix cache id
Modified: branches/faster/src/org/griphyn/vdl/karajan/Loader.java
--- branches/faster/src/org/griphyn/vdl/karajan/Loader.java 2013-02-09 05:28:44 UTC (rev 6251)
+++ branches/faster/src/org/griphyn/vdl/karajan/Loader.java 2013-02-09 05:29:51 UTC (rev 6252)
@@ -47,7 +47,6 @@
import org.apache.log4j.FileAppender;
import org.apache.log4j.Level;
import org.apache.log4j.Logger;
-import org.globus.cog.abstraction.impl.execution.fake.JobSubmissionTaskHandler;
import org.globus.cog.karajan.compiled.nodes.Main;
import org.globus.cog.karajan.compiled.nodes.grid.AbstractGridNode;
import org.globus.cog.karajan.parser.WrapperNode;
@@ -217,7 +216,7 @@
ec.start(context);
ec.waitFor();
long end = System.currentTimeMillis();
- System.out.println(JobSubmissionTaskHandler.jobsRun + " jobs, " + JobSubmissionTaskHandler.jobsRun * 1000 / (end - start) + " j/s");
+ //System.out.println(JobSubmissionTaskHandler.jobsRun + " jobs, " + JobSubmissionTaskHandler.jobsRun * 1000 / (end - start) + " j/s");
if (ec.isFailed()) {
runerror = true;
@@ -287,7 +286,7 @@
File swiftscript = new File(project);
debugText("SWIFTSCRIPT", swiftscript);
String projectBase = project.substring(0, project.lastIndexOf('.'));
- File xml = new File(projectBase + ".xml");
+ File xml = new File(projectBase + ".swiftx");
File kml = new File(projectBase + ".kml");
loadBuildVersion(provenanceEnabled);
@@ -309,7 +308,8 @@
recompile = true;
else {
- String prefix = "<!-- CACHE ID ";
+ firstLine = firstLine.trim();
+ String prefix = "// CACHE ID ";
int offset = firstLine.indexOf(prefix);
if (offset < 0) {
// no build version in the KML
@@ -318,9 +318,7 @@
recompile = true;
else {
- String cut = firstLine.substring(offset + prefix.length());
- int endOffset = cut.indexOf(" -->");
- String kmlversion = cut.substring(0, endOffset);
+ String kmlversion = firstLine.substring(offset + prefix.length());
logger.debug("kmlversion is >" + kmlversion + "<");
logger.debug("build version is >" + buildVersion + "<");
if (!(kmlversion.equals(buildVersion))) {
More information about the Swift-commit
