[Swift-commit] r6250 - branches/faster/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu
Fri Feb 8 23:27:53 CST 2013
Author: hategan
Date: 2013-02-08 23:27:53 -0600 (Fri, 08 Feb 2013)
New Revision: 6250
Modified:
branches/faster/src/org/griphyn/vdl/karajan/lib/Stagein.java
branches/faster/src/org/griphyn/vdl/karajan/lib/Stageout.java
Log:
negation operator got lost in translation
Modified: branches/faster/src/org/griphyn/vdl/karajan/lib/Stagein.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/Stagein.java 2013-02-09 05:26:59 UTC (rev 6249)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/Stagein.java 2013-02-09 05:27:53 UTC (rev 6250)
@@ -22,6 +22,7 @@
import java.util.Collection;
+import k.rt.ConditionalYield;
import k.rt.ExecutionException;
import k.rt.Stack;
import k.thr.LWThread;
@@ -36,7 +37,6 @@
import org.globus.cog.karajan.compiled.nodes.Node;
import org.globus.cog.karajan.futures.FutureFault;
import org.globus.cog.karajan.parser.WrapperNode;
-import org.griphyn.vdl.engine.Karajan;
import org.griphyn.vdl.mapping.AbstractDataNode;
import org.griphyn.vdl.mapping.DependentException;
import org.griphyn.vdl.mapping.MappingDependentException;
@@ -62,7 +62,7 @@
public Node compile(WrapperNode w, Scope scope)
throws CompilationException {
Node def = getParent().getParent();
- procName = Karajan.demangle(def.getTextualName());
+ procName = def.getTextualName();
tracer = Tracer.getTracer(def, "APPCALL");
return super.compile(w, scope);
@@ -70,7 +70,7 @@
@Override
public Object function(Stack stack) {
AbstractDataNode var = this.var.getValue(stack);
- if (var.isPrimitive()) {
+ if (!var.isPrimitive()) {
boolean deperr = false;
boolean mdeperr = false;
try {
@@ -90,7 +90,7 @@
stagein.add(filename(var.getField(p))[0]);
- catch (FutureFault f) {
+ catch (ConditionalYield f) {
if (tracer.isEnabled()) {
tracer.trace(LWThread.currentThread(), procName + " WAIT " + Tracer.getFutureName(f.getFuture()));
Modified: branches/faster/src/org/griphyn/vdl/karajan/lib/Stageout.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/Stageout.java 2013-02-09 05:26:59 UTC (rev 6249)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/Stageout.java 2013-02-09 05:27:53 UTC (rev 6250)
@@ -73,7 +73,7 @@
var.waitFor(this);
try {
retPaths(cr_stageout.get(stack), var);
if (var.isRestartable()) {
More information about the Swift-commit
