[Swift-commit] r6242 - branches/faster/resources
hategan at ci.uchicago.edu
Fri Feb 8 22:36:01 CST 2013
Author: hategan
Date: 2013-02-08 22:36:01 -0600 (Fri, 08 Feb 2013)
New Revision: 6242
Modified:
branches/faster/resources/Karajan-no-provenance.stg
branches/faster/resources/Karajan.stg
Log:
fixed various issues in code generation
Modified: branches/faster/resources/Karajan-no-provenance.stg
--- branches/faster/resources/Karajan-no-provenance.stg 2013-02-07 20:20:42 UTC (rev 6241)
+++ branches/faster/resources/Karajan-no-provenance.stg 2013-02-09 04:36:01 UTC (rev 6242)
@@ -11,4 +11,8 @@
range(from, to, step, datatype) ::= <<swift:range($from$, $to$$if(step)$, step = $step$$endif$)>>
+slicearray(parent, memberchild, datatype) ::= <<
+ swift:sliceArray($parent$, "$memberchild$", "$datatype$")
cs() ::= << >>
Modified: branches/faster/resources/Karajan.stg
--- branches/faster/resources/Karajan.stg 2013-02-07 20:20:42 UTC (rev 6241)
+++ branches/faster/resources/Karajan.stg 2013-02-09 04:36:01 UTC (rev 6242)
@@ -19,8 +19,8 @@
$endif$
$constants;separator="\n"$
+$declarations;separator="\n"$
$procedures;separator="\n"$
-$declarations;separator="\n"$
$if(statements)$
restartLog() {
@@ -33,6 +33,7 @@
$endif$
$cleanups:swift_cleandataset();separator="\n"$
swift:cleanDataset(shutdown=true)
@@ -78,7 +79,7 @@
compound(outputs, inputs, declarations, statements, config, name, initWaitCounts, cleanups) ::= <<
-unitStart("COMPOUND", name="$name$", outputs="$outputs:list();separator=","$")
+swift:unitStart("COMPOUND", name="$name$", outputs="$outputs:list();separator=","$")
$if(initWaitCounts)$
$initWaitCounts;separator="\n"$
$endif$
@@ -90,7 +91,7 @@
$outputs:swift_closedataset();separator="\n"$
-unitEnd("COMPOUND", name="$name$")
+swift:unitEnd("COMPOUND", name="$name$")
proc_args(args) ::= <<
@@ -110,7 +111,7 @@
swift_execute(outputs,inputs,attributes,application,name,line) ::= <<
-unitStart("PROCEDURE", name="$name$", line="$line$", outputs="$outputs:list();separator=","$")
+swift:unitStart("PROCEDURE", name="$name$", line="$line$", outputs="$outputs:list();separator=","$")
swift:execute(
$attributes$
swift:tr("$application.exec$")
@@ -119,7 +120,7 @@
$swift_arguments(attributes=application.attributes,arguments=application.arguments, stdin=application.stdin,stdout=application.stdout,stderr=application.stderr)$
-unitEnd("PROCEDURE", name="$name$", line="$line$")
+swift:unitEnd("PROCEDURE", name="$name$", line="$line$")
log_param(dir) ::= <<
@@ -165,7 +166,7 @@
swift_attributes(entries) ::= <<
swift:attributes(
- map(
+ map:map(
$entries;separator="\n"$
@@ -197,7 +198,7 @@
iterate(declarations,statements,cond,var,cleanups,trace,line) ::= <<
sys:while($var$, 0) {
- if (vdl:getFieldValue($cond$)) {
+ if (swift:getFieldValue($cond$)) {
$sub_comp(declarations=declarations, statements=statements, cleanups=cleanups)$
next($var$ + 1)
@@ -205,21 +206,22 @@
foreach(var, in, indexVar, indexVarType, declarations, statements, line, refs, selfClose, cleanups, trace) ::= <<
-swift:tParallelFor(\$, _traceline="$line$"$if(indexVar)$, _kvar="$indexVar$"$endif$, _vvar="$var$"$if(selfClose)$, selfClose="true"$endif$$if(refs)$, refs="$refs;separator=" "$"$endif$,
+swift:tParallelFor(\$, _traceline="$line$"$if(indexVar)$, _kvar="$indexVar$"$endif$, _vvar="$var$"$if(selfClose)$, selfClose=true$endif$$if(refs)$, refs="$refs;separator=" "$"$endif$,
$! The iterator !$
getArrayIterator($in$)) {
(\$\$, $var$) := each(\$)
$if(indexVar)$
- $indexVar$ := swift:new($indexVarType$, \$\$)
+ $indexVar$ := swift:new("$indexVarType$", value=\$\$)
$endif$
- unitStart("FOREACH_IT", line="$line$")
+ swift:unitStart("FOREACH_IT", line="$line$")
$if(statements)$
$parallel(statements=statements)$
$endif$
- unitEnd("FOREACH_IT", line="$line$")
+ swift:unitEnd("FOREACH_IT", line="$line$")
@@ -229,32 +231,35 @@
callInternal(func, outputs, inputs, line, serialize) ::= <<
sequential(
- unitStart("INTERNALPROC", name="$func$", outputs="$outputs:list();separator=","$")
+ swift:unitStart("INTERNALPROC", name="$func$", outputs="$outputs:list();separator=","$")
$func$(
$if(!serialize)$parallel($endif$
$outputs:callInternal_log_output();separator="\n"$
$inputs:callInternal_log_input();separator="\n"$
$if(!serialize)$)$endif$
- unitEnd("INTERNALPROC", name="$func$")
+ swift:unitEnd("INTERNALPROC", name="$func$")
callInternal_log_input() ::= <<
sequential(
- parameterLog("input", "TODO_name_or_pos", vdl:getDatasetProvenanceID($it$))
+ swift:parameterLog("input", "TODO_name_or_pos", vdl:getDatasetProvenanceID($it$))
$it$
callInternal_log_output() ::= <<
sequential(
- parameterLog("output", "TODO_name_or_pos", vdl:getDatasetProvenanceID($it$))
+ swift:parameterLog("output", "TODO_name_or_pos", vdl:getDatasetProvenanceID($it$))
$it$
callUserDefined(func, outputs, inputs, line, serialize, partialClose) ::= <<
+$if(partialClose)$
+sequential(
+$endif$
$func$(
$outputs;separator=", "$
@@ -263,6 +268,7 @@
$if(partialClose)$
$partialClose$
$endif$
@@ -297,7 +303,7 @@
variable_log() ::= <<
- parameterLog("intermediate", "$name$", swift:getDatasetProvenanceID($name$))
+ swift:parameterLog("intermediate", "$name$", swift:getDatasetProvenanceID($name$))
swift_mapping(mapping, file) ::= <<
@@ -313,39 +319,45 @@
assign(var, value, line, partialClose) ::= <<
+$if(partialClose)$
+sequential(
+$endif$
swift:setFieldValue($if(line)$_traceline="$line$"$endif$
$var$
$value$
$if(partialClose)$
-$partialClose$
+$partialClose$)
$endif$
append(array, value, partialClose) ::= <<
+$if(partialClose)$
+sequential(
+$endif$
swift:appendArray(
$array$
$value$
$if(partialClose)$
-$partialClose$
+$partialClose$)
$endif$
callexpr(call, datatype, prefix) ::= <<
sequential(
- tmp := swift:new("$datatype$", dbgname="swift#callintermediate",
+ swift#callintermediate := swift:new("$datatype$", dbgname="swift#callintermediate",
swift:mapping("concurrent_mapper",
swift:parameter("prefix", "_callintermediate-$prefix$")
$call$
- tmp
array(elements, datatype) ::= <<
-swift:createarray(
+swift:createArray(
list(
$elements;separator="\n"$
@@ -356,21 +368,24 @@
sequential(
tmp := swift:range($from$, $to$$if(step)$, step = $step$$endif$)
tmp
- $range_log()$
+ $range_log(from=from, to=to, step=step, out=tmp)$
-range_log() ::= <<
+range_log(from, to, step, out) ::= <<
+ swift:log(INFO, str:concat("ARRAYRANGE thread=", currentThread(), " array=", getDatasetProvenanceId($out$),
+ " from=", getDatasetProvenanceId($from$), "to=", getDatasetProvenanceId($to$)
+ $if(step)$", step=", getDatasetProvenanceId($step$)$else$, "step=none"$endif$))
if(condition,vthen,velse,line,trace) ::= <<
if (swift:getFieldValue($condition$)) {
- unitStart("CONDITION_BLOCK")
+ swift:unitStart("CONDITION_BLOCK")
$vthen$
$if(velse)$
else {
$velse$
$endif$
@@ -394,7 +409,7 @@
if (swift:getFieldValue(swiftop:eq(swc, $case.value$))) {
$sub_comp(declarations=case.declarations, statements=case.statements)$
- else
+ $if(rest(cases))$else$else$$if(sdefault)$else$endif$$endif$
$if(sdefault)$
@@ -419,19 +434,20 @@
partialclose(var, count) ::= <<
-partialCloseDataset($var$$if(count)$, count=$count$$endif$)
+swift:partialCloseDataset($var$$if(count)$, count=$count$$endif$)
setWaitCount(name, waitCount) ::= <<
-setWaitCount($name$$if(waitCount)$, count=$waitCount$$endif$)
+swift:setWaitCount($name$$if(waitCount)$, count=$waitCount$$endif$)
unitStart(type, outputs) ::= <<
- unitStart("$type$", outputs="$outputs$")
+swift:unitStart("$type$", outputs="$outputs$")
unitEnd(type) ::= <<
- unitEnd("$type$")
+ swift:unitEnd("$type$")
operator ::= [
@@ -472,22 +488,24 @@
extractarrayelement(parent, arraychild, datatype) ::= <<
-swift:getfieldsubscript($parent$, $arraychild$)
+swift:getFieldSubscript($parent$, $arraychild$)
extractstructelement(parent, memberchild, datatype) ::= <<
-getfield($parent$, $memberchild$)
+getField($parent$, "$memberchild$")
sequential(
- slice := swift:sliceArray($parent$, $memberchild$, $datatype$)
- logSliceArray($memberchild$, $parent$)
+ slice := swift:sliceArray($parent$, "$memberchild$", "$datatype$")
+ $logSliceArray(memberchild=memberchild, array=parent, slice=slice)$
slice
-logSliceArray(memberchild, array) ::= <<
+logSliceArray(memberchild, array, slice) ::= <<
+ swift:log(DEBUG, str:concat("SLICEARRAY thread=", currentThread(), " slice=", swift:getDatasetProvenanceID($slice$),
+ " member=$member$ array=", swift:getDatasetProvenanceID($array$))
More information about the Swift-commit
