[Swift-commit] r6236 - in trunk/docs: . cookbook utils
ketan at ci.uchicago.edu
Tue Feb 5 09:43:43 CST 2013
Author: ketan
Date: 2013-02-05 09:43:43 -0600 (Tue, 05 Feb 2013)
New Revision: 6236
Modified:
trunk/docs/build_docs.sh
trunk/docs/cookbook/debugging
trunk/docs/utils/gensites.txt
Log:
build script mods for mac
Modified: trunk/docs/build_docs.sh
--- trunk/docs/build_docs.sh 2013-02-05 15:10:54 UTC (rev 6235)
+++ trunk/docs/build_docs.sh 2013-02-05 15:43:43 UTC (rev 6236)
@@ -57,8 +57,14 @@
chmod $CHMOD_DIRECTORY_MODE $INSTALLATION_DIRECTORY > /dev/null 2>&1
fi
+unamestr=`\uname`
+if [[ "$unamestr" == 'Linux' ]]; then
+ pushd $(dirname $(readlink -f $0)) > /dev/null 2>&1
+else
+ pushd $(dirname $(greadlink -f $0)) > /dev/null 2>&1
+fi
# Gather version information
-pushd $(dirname $(readlink -f $0)) > /dev/null 2>&1
pushd .. > /dev/null 2>&1
VERSION=`svn info |grep URL|awk -F / '{print $NF}'`
popd > /dev/null 2>&1
Modified: trunk/docs/cookbook/debugging
--- trunk/docs/cookbook/debugging 2013-02-05 15:10:54 UTC (rev 6235)
+++ trunk/docs/cookbook/debugging 2013-02-05 15:43:43 UTC (rev 6236)
@@ -1,17 +1,23 @@
Debugging Swift
-Swift errors are logged in several places:
+Swift errors are logged in several places. In case of errors, following places
+should be inspected for clues:
. All text from standard output and standard error produced by running the
swift command
. The .log file from this run. It will be named script.uniqueID.log
where "script" is the name of your *.swift script source file, and
uniqueID is a long unique id which starts with the date and time you ran the
swift command.
. $HOME/.globus/coasters directory on remote machines on which you are
running coasters
. $HOME/.globus/scripts directory on the host on which you run the Swift
command, when swift is submitting to a local scheduler (Condor, PBS, SGE,
Cobalt)
. $HOME/.globus/??? on remote systems that you access via Globus
Modified: trunk/docs/utils/gensites.txt
--- trunk/docs/utils/gensites.txt 2013-02-05 15:10:54 UTC (rev 6235)
+++ trunk/docs/utils/gensites.txt 2013-02-05 15:43:43 UTC (rev 6236)
@@ -51,18 +51,11 @@
Running this command will print some information about the template and give
-you an idea of what settings you will need to specify. You should see
-something like this:
+you an idea of what settings you will need to specify.
-Description: Template for Intrepid. More information about this system can be found at http://www.alcf.anl.gov/support/gettingstarted/index.php
-Required Tokens: host work project queue
+The required tokens are required to properly use the templates. These are
+placeholder values you will need to specify in the following steps.
-The required tokens are required to properly use the templates. These are placeholder
-values you will need to specify in the
-following steps.
Providing Site Specific Values
More information about the Swift-commit
