[Swift-commit] r6233 - trunk/docs/cookbook
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Feb 4 08:44:44 CST 2013
Author: ketan
Date: 2013-02-04 08:44:42 -0600 (Mon, 04 Feb 2013)
New Revision: 6233
Modified:
   trunk/docs/cookbook/swift_basics
Log:
polishing cookbook
Modified: trunk/docs/cookbook/swift_basics
--- trunk/docs/cookbook/swift_basics	2013-02-04 14:29:39 UTC (rev 6232)
+++ trunk/docs/cookbook/swift_basics	2013-02-04 14:44:42 UTC (rev 6233)
@@ -12,10 +12,10 @@
 .Check your Java
 Swift is a Java application. Make sure you are running Java version 5 or higher. You
-can make sure you have Java in your $PATH (or $HOME/.soft file depending upon
+can make sure you have Java in your $PATH (or file such as $HOME/.soft depending upon
 your environment)
-Following are the possible ways to detect and run Java:
+Following are some possible ways to detect and run Java:
 $ grep java $HOME/.soft
@@ -32,10 +32,12 @@
 Setting up to run Swift
 This is simple. We will be using a pre-compiled version of Swift that can be
-downloaded from link:http://www.ci.uchicago.edu/swift/downloads/index.php[here]. Download and untar the latest precompiled version as follows:
+downloaded from
+link:http://www.ci.uchicago.edu/swift/downloads/index.php[here]. Download and
+untar the latest precompiled version as follows:
-$ tar xf swift-0.92.1.tar.gz
+$ tar zxf swift-0.92.1.tar.gz
 Environment Setup
@@ -99,7 +101,7 @@
 The _profiles_ field should be set to null if no profile entries are to be
 specified, or should contain the profile entries separated by semicolons.
-Setting swift configuration
+Setting Swift configuration
 Many configuration properties could be set using the Swift configuration file.
 We will not cover them all in this section. see
@@ -201,16 +203,16 @@
 What if Swift hangs
-Owing to its highly multithreaded architecture it is often the case that the
+Owing to its multi-threaded architecture it is often the case that the
 underlying java virtual machine gets into deadlock situations or Swift hangs
-because of other complications in its threaded operations. Under such
-situations, Swift _hang-checker_ chips in and resolves the situation.
+because of other complications in its operations. Under such
+situations, Swift _hang-checker_ chips in and gives indication of the situation.
 . how to use the information to identify and correct the deadlock.
 . How close to the Swift source code can we make the hang-checker messages, so that the user can relate it to Swift functions, expressions, and ideally source code lines?
-. The current Hang Checker output is actually *very* nice and useful already:
+. The Hang Checker output is nice and useful:
 Registered futures:
@@ -224,7 +226,7 @@
 Resuming a stopped or crashed Swift Run
-I had a .rlog file from a Swift run that ran out of time. I kicked it off
+I had a .rlog file from a Swift run that ran out of time. I resumed the run
 using the -resume flag described in section 16.2 of the Swift User Guide and
 it picked up where it left off. Then I killed it because I wanted to make
 changes to my sites file.
@@ -250,8 +252,8 @@
 [nbest at login2 files]$ pwd
 /home/nbest/bigdata/files
-~wilde/swift/src/stable/cog/modules/swift/dist/swift-svn/bin/swift \
-> -tc.file tc -sites.file pbs.xml ~/scripts/mcd12q1.swift -resume
+~wilde/swift/src/stable/cog/modules/swift/dist/swift-svn/bin/swift -resume \
+> -tc.file tc -sites.file pbs.xml ~/scripts/mcd12q1.swift
 > mcd12q1-20100310-1326-ptxe1x1d.0.rlog
 Swift svn swift-r3255 (swift modified locally) cog-r2723 (cog modified
 locally)
@@ -274,13 +276,6 @@
 in previous run:2558
-From Neil: A comment about that section of the user guide: It says "In order
-to restart from a restart log file, the -resume logfile argument can be used
-after the SwiftScript? program file name." and then puts the -resume logfile
-argument before the script file name. I'm sure the order doesn't matter but
-the contradiction is confusing.
 Notes to add (from Mike):
 - explain what aspects of a Swift script make it restartable, and which
