[Swift-commit] r6220 - trunk/docs/userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sun Feb 3 14:49:41 CST 2013
Author: ketan
Date: 2013-02-03 14:49:41 -0600 (Sun, 03 Feb 2013)
New Revision: 6220
Modified:
   trunk/docs/userguide/log-processing
Log:
organize logs section and add a subsection, may be need a debug section
Modified: trunk/docs/userguide/log-processing
--- trunk/docs/userguide/log-processing	2013-02-03 15:40:12 UTC (rev 6219)
+++ trunk/docs/userguide/log-processing	2013-02-03 20:49:41 UTC (rev 6220)
@@ -5,7 +5,6 @@
 To properly generate log plots, you must enable VDL/Karajan logging.
 TODO:How?
 You should check the scripts that you intend to use to determine
 what log lines they require and ensure that you are generating
 those lines via log4j.properties
@@ -18,6 +17,28 @@
 TODO: Does it work for coasters-based runs only?
+Meaning and interpretation of Swift log messages
+A Swift log file is typically a text file with the name of the Swift run and
+its timestamp in the filename and an extension ".log". In addition, a ".rlog"
+file is Swift's resume log which is used by Swift when a run is resumed using
+the "-resume" option. The .rlog file is only for Swift's internal purpose and
+not to be interpreted by the user.
+Each line in the log file is typically made up of three parts. The first part
+is the timestamp, the second is the type of log message and the third is the
+message itself. The types of log messages follows the java log4j standard types
+of TRACE, DEBUG, INFO, WARN, ERROR and FATAL. This section lists the various
+Swift log messages and explains the meaning and likely interpretation of those
+messages. Please note that the list is not comprehensive at this time. Also
+note that we will ignore the timestamps here.
+. _DEBUG Loader arguments: [-sites.file, sites.xml, -config, cf, -tc.file, tc, postproc-gridftp.swift]_
+. _DEBUG Loader Max heap: 5592449024_
+. _DEBUG textfiles BEGIN_
+. _DEBUG Loader kmlversion is_
 Normalize event times in the log to the run start time
