[Swift-commit] r6213 - trunk/src/org/griphyn/vdl/karajan
hategan at ci.uchicago.edu
Sat Feb 2 03:02:25 CST 2013
Author: hategan
Date: 2013-02-02 03:02:23 -0600 (Sat, 02 Feb 2013)
New Revision: 6213
Modified:
trunk/src/org/griphyn/vdl/karajan/WaitingThreadsMonitor.java
Log:
stacks are not guaranteed to be the same in the same sequential scope (though the frames are), so don't assume that's the case because it leads to 'waiting threads' that are never removed from the monitor
Modified: trunk/src/org/griphyn/vdl/karajan/WaitingThreadsMonitor.java
--- trunk/src/org/griphyn/vdl/karajan/WaitingThreadsMonitor.java 2013-02-02 08:23:02 UTC (rev 6212)
+++ trunk/src/org/griphyn/vdl/karajan/WaitingThreadsMonitor.java 2013-02-02 09:02:23 UTC (rev 6213)
@@ -24,48 +24,95 @@
import java.util.List;
import java.util.Map;
+import org.globus.cog.karajan.stack.VariableNotFoundException;
import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.util.ThreadingContext;
import org.griphyn.vdl.mapping.DSHandle;
public class WaitingThreadsMonitor {
- private static Map<VariableStack, DSHandle> threads = new HashMap<VariableStack, DSHandle>();
- private static Map<VariableStack, List<DSHandle>> outputs = new HashMap<VariableStack, List<DSHandle>>();;
+ private static class StackTCPair {
+ public final VariableStack stack;
+ public final ThreadingContext tc;
+ public StackTCPair(VariableStack stack) {
+ this.stack = stack;
+ try {
+ this.tc = ThreadingContext.get(stack);
+ catch (VariableNotFoundException e) {
+ throw new RuntimeException("Cannot get thread id", e);
+ @Override
+ public int hashCode() {
+ return tc.hashCode();
+ @Override
+ public boolean equals(Object obj) {
+ if (obj instanceof StackTCPair) {
+ return ((StackTCPair) obj).tc == tc;
+ else {
+ return false;
+ @Override
+ public String toString() {
+ return tc.toString();
+ private static Map<StackTCPair, DSHandle> threads = new HashMap<StackTCPair, DSHandle>();
+ private static Map<StackTCPair, List<DSHandle>> outputs = new HashMap<StackTCPair, List<DSHandle>>();;
public static void addThread(VariableStack stack, DSHandle waitingOn) {
if (stack != null) {
synchronized(threads) {
- threads.put(stack, waitingOn);
+ threads.put(new StackTCPair(stack), waitingOn);
public static void removeThread(VariableStack stack) {
- synchronized(threads) {
- threads.remove(stack);
+ if (stack != null) {
+ synchronized(threads) {
+ threads.remove(new StackTCPair(stack));
public static Map<VariableStack, DSHandle> getAllThreads() {
- return new HashMap<VariableStack, DSHandle>(threads);
+ Map<VariableStack, DSHandle> m = new HashMap<VariableStack, DSHandle>();
+ for (Map.Entry<StackTCPair, DSHandle> e : threads.entrySet()) {
+ m.put(e.getKey().stack, e.getValue());
+ return m;
public static void addOutput(VariableStack stack, List<DSHandle> outputs) {
synchronized(WaitingThreadsMonitor.outputs) {
- WaitingThreadsMonitor.outputs.put(stack, outputs);
+ WaitingThreadsMonitor.outputs.put(new StackTCPair(stack), outputs);
public static void removeOutput(VariableStack stack) {
synchronized(outputs) {
- outputs.remove(stack);
+ outputs.remove(new StackTCPair(stack));
public static Map<VariableStack, List<DSHandle>> getOutputs() {
- return new HashMap<VariableStack, List<DSHandle>>(outputs);
+ Map<VariableStack, List<DSHandle>> m = new HashMap<VariableStack, List<DSHandle>>();
+ for (Map.Entry<StackTCPair, List<DSHandle>> e : outputs.entrySet()) {
+ return m;
More information about the Swift-commit
