[Swift-commit] cog r3579
swift at ci.uchicago.edu
Sat Feb 2 02:45:09 CST 2013
r3579 | hategan | 2013-02-02 02:43:47 -0600 (Sat, 02 Feb 2013) | 1 line
removed unused debug stuff
Index: modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AllocateHost.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AllocateHost.java (revision 3578)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AllocateHost.java (working copy)
@@ -41,8 +41,6 @@
this.setQuotedArgs(true);
- private static Map<Task, Long> stimes = Collections.synchronizedMap(new HashMap<Task, Long>());
protected void partialArgumentsEvaluated(VariableStack stack) throws ExecutionException {
Object constraints = A_CONSTRAINTS.getValue(stack);
try {
@@ -63,7 +61,6 @@
Contact contact = s.allocateContact(constraints);
t.setVirtualContact(contact);
s.addJobStatusListener(this, t);
- stimes.put(t, System.currentTimeMillis());
s.enqueue(t, new Contact[] { contact });
More information about the Swift-commit
