[Swift-commit] r7406 - branches/release-0.95/bin
davidk at ci.uchicago.edu
Wed Dec 11 10:04:40 CST 2013
Author: davidk
Date: 2013-12-11 10:04:40 -0600 (Wed, 11 Dec 2013)
New Revision: 7406
Modified:
branches/release-0.95/bin/swiftrun
Log:
Properties flag
New jobmanager format
Modified: branches/release-0.95/bin/swiftrun
--- branches/release-0.95/bin/swiftrun 2013-12-11 16:01:58 UTC (rev 7405)
+++ branches/release-0.95/bin/swiftrun 2013-12-11 16:04:40 UTC (rev 7406)
@@ -18,6 +18,7 @@
my $option_siteslist; # Value of -sites option, comma separated
my $option_config; # Value of -config option
my $option_listconfig; # List configuration files used, values, then exit
+my $option_properties; # Use a swift.properties specified in the command line
my $option_help; # Print help
my $option_version; # Print version number
my @sites; # List of sites from -sites in array
@@ -25,7 +26,6 @@
my @new_swift_args; # New command line arguments
my @original_swift_args; # Original arguments
# List of xml shortcuts
my %xml_aliases = (
'allocationstepsize' => 'globus.allocationstepsize',
@@ -146,7 +146,37 @@
# Make sure to handle special cases that are not in the namespace=x, key=y, format
- if ( $namespace eq "provider" ) { return "<execution provider=\"" . $property . "\" jobmanager=\"" . $value . "\"/>\n"; }
+ if ( $namespace eq "jobmanager" && defined($value)) {
+ my $ccount = ($value =~ s/:/:/g);
+ my $jobmanager = "";
+ my $jobmanagerURL = "";
+ # With no separators, assume local
+ if( $ccount == 0 ) {
+ $jobmanager = "local:$value";
+ # With one separator, use ssh-cl and assume hostname:type
+ elsif ( $ccount == 1) {
+ (my $first, my $second) = split(':', $value);
+ $jobmanager = "ssh-cl:$second";
+ $jobmanagerURL = "$first";
+ # Other, in the format of proto:host:jobMgr
+ elsif ( $ccount == 2) {
+ (my $first, my $second, my $third) = split(':', $value);
+ $jobmanager="$first:$third";
+ $jobmanagerURL = "$second";
+ if ( defined($jobmanagerURL) && length($jobmanagerURL) > 0) {
+ return "<execution provider=\"coaster\" jobmanager=\"" . $jobmanager . "\" url=\"" . $jobmanagerURL . "\"/>\n";
+ } else {
+ return "<execution provider=\"coaster\" jobmanager=\"" . $jobmanager . "\"/>\n";
elsif ( $namespace eq "workdirectory" ) { return "<workdirectory>$value</workdirectory>\n"; }
elsif ( $namespace eq "workdir" ) { return "<workdirectory>$value</workdirectory>\n"; }
elsif ( $namespace eq "taskdir" ) { return "<scratch>$value</scratch>\n"; }
@@ -253,7 +283,9 @@
sub swiftquit {
print STDERR $_[0] . "\n";
print " --SWIFTRUNQUIT ";
- rmtree $run_directory || die "Failed to remove $run_directory: $!\n";
+ if (defined($run_directory) && -d "$run_directory") {
+ rmtree $run_directory || die "Failed to remove $run_directory: $!\n";
exit 1;
@@ -303,13 +335,14 @@
@original_swift_args = @ARGV;
GetOptionsFromArray(
\@original_swift_args,
- 'config=s' => \$option_config,
- 'help' => \$option_help,
- 'listconfig' => \$option_listconfig,
- 'site|sites=s' => \$option_siteslist,
- 'sitesfile=s' => \$option_sitesfile,
- 'tcfile=s' => \$option_tcfile,
- 'version' => \$option_version,
+ 'config=s' => \$option_config,
+ 'help' => \$option_help,
+ 'listconfig' => \$option_listconfig,
+ 'property|properties=s' => \$option_properties,
+ 'site|sites=s' => \$option_siteslist,
+ 'sitesfile=s' => \$option_sitesfile,
+ 'tcfile=s' => \$option_tcfile,
+ 'version' => \$option_version,
# Set @sites array from comma separated list of sites
@@ -318,7 +351,7 @@
# Verify Swift is found in PATH
-my $swift_etc_directory = dirname(dirname(`which swift`)) . "/etc";
+my $swift_etc_directory = dirname(dirname($0)) . "/etc";
if( ! -d $swift_etc_directory ) { &swiftquit("Unable to find a valid Swift installation"); }
# Set the search order for properties
@@ -326,6 +359,12 @@
&add_property_file("$ENV{SWIFT_SITE_CONF}/swift.properties") if defined($ENV{SWIFT_SITE_CONF});
&add_property_file("$ENV{HOME}/.swift/swift.properties");
&add_property_file("swift.properties");
+if(defined($option_properties)) {
+ if(! -f $option_properties) {
+ swiftquit("Unable to find properties file $option_properties");
+ &add_property_file($option_properties);
# Set property values
foreach my $property_file(@property_files) {
@@ -413,10 +452,10 @@
$arg =~ s/tcfile/tc.file/g;
-# Make sure -sites isn't in the arguments we send back to swift
+# Make sure swiftrun arguments aren't sent back to swift
while( @ARGV ) {
my $option = shift;
- if ( $option eq "-site" || $option eq "-sites" ) { shift; }
+ if ( $option eq "-site" || $option eq "-sites" || $option eq "-properties" || $option eq "-property") { shift; }
else { push( @new_swift_args, $option ); }
More information about the Swift-commit
