[Swift-commit] r6908 - in trunk/tests/stress: . IO IO/bagOnodes	IO/beagle IO/multiple IO/uc3
    yadunandb at ci.uchicago.edu
    Wed Aug 21 11:40:29 CDT 2013
Author: yadunandb
Date: 2013-08-21 11:40:28 -0500 (Wed, 21 Aug 2013)
New Revision: 6908
Added:
   trunk/tests/stress/IO/
   trunk/tests/stress/IO/bagOnodes/
   trunk/tests/stress/IO/bagOnodes/run
   trunk/tests/stress/IO/bagOnodes/sites.template.xml
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.check.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.setup.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.source.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.swift
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.timeout
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.check.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.setup.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.source.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.swift
   trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.timeout
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.check.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.setup.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.source.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.swift
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.timeout
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.check.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.setup.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.source.sh
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.swift
   trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.timeout
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.check.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.setup.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.source.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.swift
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.timeout
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.check.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.setup.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.source.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.swift
   trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.timeout
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.args
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.check.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.setup.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.source.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.swift
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.timeout
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.check.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.setup.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.source.sh
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.swift
   trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.timeout
   trunk/tests/stress/IO/bagOnodes/swift.properties
   trunk/tests/stress/IO/bagOnodes/t.sh
   trunk/tests/stress/IO/bagOnodes/tc.template.data
   trunk/tests/stress/IO/bagOnodes/temp.sh
   trunk/tests/stress/IO/bagOnodes/title.txt
   trunk/tests/stress/IO/bagOnodes/wrapper.sh
   trunk/tests/stress/IO/bagOnodes/z_stats.clean.sh
   trunk/tests/stress/IO/bagOnodes/z_stats.swift
   trunk/tests/stress/IO/beagle/
   trunk/tests/stress/IO/beagle/run
   trunk/tests/stress/IO/beagle/sites.template.xml
   trunk/tests/stress/IO/beagle/stage_from_remote1x1.check.sh
   trunk/tests/stress/IO/beagle/stage_from_remote1x1.setup.sh
   trunk/tests/stress/IO/beagle/stage_from_remote1x1.source.sh
   trunk/tests/stress/IO/beagle/stage_from_remote1x1.swift
   trunk/tests/stress/IO/beagle/stage_from_remote1x1.timeout
   trunk/tests/stress/IO/beagle/stage_from_remote1x2.check.sh
   trunk/tests/stress/IO/beagle/stage_from_remote1x2.setup.sh
   trunk/tests/stress/IO/beagle/stage_from_remote1x2.source.sh
   trunk/tests/stress/IO/beagle/stage_from_remote1x2.swift
   trunk/tests/stress/IO/beagle/stage_from_remote1x2.timeout
   trunk/tests/stress/IO/beagle/stage_from_remoteNx1.check.sh
   trunk/tests/stress/IO/beagle/stage_from_remoteNx1.setup.sh
   trunk/tests/stress/IO/beagle/stage_from_remoteNx1.source.sh
   trunk/tests/stress/IO/beagle/stage_from_remoteNx1.swift
   trunk/tests/stress/IO/beagle/stage_from_remoteNx1.timeout
   trunk/tests/stress/IO/beagle/stage_from_remoteNx2.check.sh
   trunk/tests/stress/IO/beagle/stage_from_remoteNx2.setup.sh
   trunk/tests/stress/IO/beagle/stage_from_remoteNx2.source.sh
   trunk/tests/stress/IO/beagle/stage_from_remoteNx2.swift
   trunk/tests/stress/IO/beagle/stage_from_remoteNx2.timeout
   trunk/tests/stress/IO/beagle/stage_to_remote1x1.args
   trunk/tests/stress/IO/beagle/stage_to_remote1x1.check.sh
   trunk/tests/stress/IO/beagle/stage_to_remote1x1.setup.sh
   trunk/tests/stress/IO/beagle/stage_to_remote1x1.source.sh
   trunk/tests/stress/IO/beagle/stage_to_remote1x1.swift
   trunk/tests/stress/IO/beagle/stage_to_remote1x1.timeout
   trunk/tests/stress/IO/beagle/stage_to_remote1x2.check.sh
   trunk/tests/stress/IO/beagle/stage_to_remote1x2.setup.sh
   trunk/tests/stress/IO/beagle/stage_to_remote1x2.source.sh
   trunk/tests/stress/IO/beagle/stage_to_remote1x2.swift
   trunk/tests/stress/IO/beagle/stage_to_remote1x2.timeout
   trunk/tests/stress/IO/beagle/stage_to_remoteNx1.args
   trunk/tests/stress/IO/beagle/stage_to_remoteNx1.check.sh
   trunk/tests/stress/IO/beagle/stage_to_remoteNx1.setup.sh
   trunk/tests/stress/IO/beagle/stage_to_remoteNx1.source.sh
   trunk/tests/stress/IO/beagle/stage_to_remoteNx1.swift
   trunk/tests/stress/IO/beagle/stage_to_remoteNx1.timeout
   trunk/tests/stress/IO/beagle/stage_to_remoteNx2.check.sh
   trunk/tests/stress/IO/beagle/stage_to_remoteNx2.setup.sh
   trunk/tests/stress/IO/beagle/stage_to_remoteNx2.source.sh
   trunk/tests/stress/IO/beagle/stage_to_remoteNx2.swift
   trunk/tests/stress/IO/beagle/stage_to_remoteNx2.timeout
   trunk/tests/stress/IO/beagle/swift.properties
   trunk/tests/stress/IO/beagle/tc.template.data
   trunk/tests/stress/IO/beagle/temp.sh
   trunk/tests/stress/IO/beagle/title.txt
   trunk/tests/stress/IO/beagle/wrapper.sh
   trunk/tests/stress/IO/beagle/z_stats.clean.sh
   trunk/tests/stress/IO/beagle/z_stats.swift
   trunk/tests/stress/IO/multiple/
   trunk/tests/stress/IO/multiple/run
   trunk/tests/stress/IO/multiple/sites.template.xml
   trunk/tests/stress/IO/multiple/sites.template.xml.beagle
   trunk/tests/stress/IO/multiple/stage_from_remote1x1.check.sh
   trunk/tests/stress/IO/multiple/stage_from_remote1x1.setup.sh
   trunk/tests/stress/IO/multiple/stage_from_remote1x1.swift
   trunk/tests/stress/IO/multiple/stage_from_remote1x1.timeout
   trunk/tests/stress/IO/multiple/stage_from_remote1x2.check.sh
   trunk/tests/stress/IO/multiple/stage_from_remote1x2.setup.sh
   trunk/tests/stress/IO/multiple/stage_from_remote1x2.swift
   trunk/tests/stress/IO/multiple/stage_from_remote1x2.timeout
   trunk/tests/stress/IO/multiple/stage_from_remoteNx1.check.sh
   trunk/tests/stress/IO/multiple/stage_from_remoteNx1.setup.sh
   trunk/tests/stress/IO/multiple/stage_from_remoteNx1.swift
   trunk/tests/stress/IO/multiple/stage_from_remoteNx1.timeout
   trunk/tests/stress/IO/multiple/stage_from_remoteNx2.check.sh
   trunk/tests/stress/IO/multiple/stage_from_remoteNx2.setup.sh
   trunk/tests/stress/IO/multiple/stage_from_remoteNx2.swift
   trunk/tests/stress/IO/multiple/stage_from_remoteNx2.timeout
   trunk/tests/stress/IO/multiple/stage_to_remote1x1.args
   trunk/tests/stress/IO/multiple/stage_to_remote1x1.check.sh
   trunk/tests/stress/IO/multiple/stage_to_remote1x1.setup.sh
   trunk/tests/stress/IO/multiple/stage_to_remote1x1.source.sh
   trunk/tests/stress/IO/multiple/stage_to_remote1x1.swift
   trunk/tests/stress/IO/multiple/stage_to_remote1x1.timeout
   trunk/tests/stress/IO/multiple/stage_to_remote1x2.check.sh
   trunk/tests/stress/IO/multiple/stage_to_remote1x2.setup.sh
   trunk/tests/stress/IO/multiple/stage_to_remote1x2.source.sh
   trunk/tests/stress/IO/multiple/stage_to_remote1x2.swift
   trunk/tests/stress/IO/multiple/stage_to_remote1x2.timeout
   trunk/tests/stress/IO/multiple/stage_to_remoteNx1.args
   trunk/tests/stress/IO/multiple/stage_to_remoteNx1.check.sh
   trunk/tests/stress/IO/multiple/stage_to_remoteNx1.setup.sh
   trunk/tests/stress/IO/multiple/stage_to_remoteNx1.source.sh
   trunk/tests/stress/IO/multiple/stage_to_remoteNx1.swift
   trunk/tests/stress/IO/multiple/stage_to_remoteNx1.timeout
   trunk/tests/stress/IO/multiple/stage_to_remoteNx2.check.sh
   trunk/tests/stress/IO/multiple/stage_to_remoteNx2.setup.sh
   trunk/tests/stress/IO/multiple/stage_to_remoteNx2.source.sh
   trunk/tests/stress/IO/multiple/stage_to_remoteNx2.swift
   trunk/tests/stress/IO/multiple/stage_to_remoteNx2.timeout
   trunk/tests/stress/IO/multiple/swift.properties
   trunk/tests/stress/IO/multiple/tc.template.data
   trunk/tests/stress/IO/multiple/temp.sh
   trunk/tests/stress/IO/multiple/title.txt
   trunk/tests/stress/IO/multiple/wrapper.sh
   trunk/tests/stress/IO/multiple/z_stats.clean.sh
   trunk/tests/stress/IO/multiple/z_stats.swift
   trunk/tests/stress/IO/uc3/
   trunk/tests/stress/IO/uc3/run
   trunk/tests/stress/IO/uc3/script.args
   trunk/tests/stress/IO/uc3/script.check.sh
   trunk/tests/stress/IO/uc3/script.setup.sh
   trunk/tests/stress/IO/uc3/sites.backup.xml
   trunk/tests/stress/IO/uc3/sites.template.xml
   trunk/tests/stress/IO/uc3/stage_from_remote.check.sh
   trunk/tests/stress/IO/uc3/stage_from_remote.setup.sh
   trunk/tests/stress/IO/uc3/stage_from_remote.source.sh
   trunk/tests/stress/IO/uc3/stage_from_remote.swift
   trunk/tests/stress/IO/uc3/stage_from_remote.timeout
   trunk/tests/stress/IO/uc3/stage_from_remote1x1.check.sh
   trunk/tests/stress/IO/uc3/stage_from_remote1x1.setup.sh
   trunk/tests/stress/IO/uc3/stage_from_remote1x1.source.sh
   trunk/tests/stress/IO/uc3/stage_from_remote1x1.swift
   trunk/tests/stress/IO/uc3/stage_from_remote1x1.timeout
   trunk/tests/stress/IO/uc3/stage_from_remote1x2.check.sh
   trunk/tests/stress/IO/uc3/stage_from_remote1x2.setup.sh
   trunk/tests/stress/IO/uc3/stage_from_remote1x2.source.sh
   trunk/tests/stress/IO/uc3/stage_from_remote1x2.swift
   trunk/tests/stress/IO/uc3/stage_from_remote1x2.timeout
   trunk/tests/stress/IO/uc3/stage_from_remoteNx1.check.sh
   trunk/tests/stress/IO/uc3/stage_from_remoteNx1.setup.sh
   trunk/tests/stress/IO/uc3/stage_from_remoteNx1.source.sh
   trunk/tests/stress/IO/uc3/stage_from_remoteNx1.swift
   trunk/tests/stress/IO/uc3/stage_from_remoteNx1.timeout
   trunk/tests/stress/IO/uc3/stage_from_remoteNx2.check.sh
   trunk/tests/stress/IO/uc3/stage_from_remoteNx2.setup.sh
   trunk/tests/stress/IO/uc3/stage_from_remoteNx2.source.sh
   trunk/tests/stress/IO/uc3/stage_from_remoteNx2.swift
   trunk/tests/stress/IO/uc3/stage_from_remoteNx2.timeout
   trunk/tests/stress/IO/uc3/stage_to_remote1x1.args
   trunk/tests/stress/IO/uc3/stage_to_remote1x1.check.sh
   trunk/tests/stress/IO/uc3/stage_to_remote1x1.setup.sh
   trunk/tests/stress/IO/uc3/stage_to_remote1x1.source.sh
   trunk/tests/stress/IO/uc3/stage_to_remote1x1.swift
   trunk/tests/stress/IO/uc3/stage_to_remote1x1.timeout
   trunk/tests/stress/IO/uc3/stage_to_remote1x2.check.sh
   trunk/tests/stress/IO/uc3/stage_to_remote1x2.setup.sh
   trunk/tests/stress/IO/uc3/stage_to_remote1x2.source.sh
   trunk/tests/stress/IO/uc3/stage_to_remote1x2.swift
   trunk/tests/stress/IO/uc3/stage_to_remote1x2.timeout
   trunk/tests/stress/IO/uc3/stage_to_remoteNx1.check.sh
   trunk/tests/stress/IO/uc3/stage_to_remoteNx1.setup.sh
   trunk/tests/stress/IO/uc3/stage_to_remoteNx1.source.sh
   trunk/tests/stress/IO/uc3/stage_to_remoteNx1.swift
   trunk/tests/stress/IO/uc3/stage_to_remoteNx1.timeout
   trunk/tests/stress/IO/uc3/stage_to_remoteNx2.check.sh
   trunk/tests/stress/IO/uc3/stage_to_remoteNx2.setup.sh
   trunk/tests/stress/IO/uc3/stage_to_remoteNx2.source.sh
   trunk/tests/stress/IO/uc3/stage_to_remoteNx2.swift
   trunk/tests/stress/IO/uc3/stage_to_remoteNx2.timeout
   trunk/tests/stress/IO/uc3/swift.properties
   trunk/tests/stress/IO/uc3/tc.template.data
   trunk/tests/stress/IO/uc3/temp.sh
   trunk/tests/stress/IO/uc3/title.txt
   trunk/tests/stress/IO/uc3/wrapper.sh
   trunk/tests/stress/IO/uc3/z_stats.clean.sh
   trunk/tests/stress/IO/uc3/z_stats.swift
Log:
Committing IO stress tests
Added: trunk/tests/stress/IO/bagOnodes/run
--- trunk/tests/stress/IO/bagOnodes/run	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/run	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,22 @@
+#! /bin/sh
+set -x
+export STRESS="S1"
+#./stage_to_remote.setup.sh
+#ARGS=`cat stage_to_remote.args`
+#swift -config swift.properties -sites.file sites.template.xml -tc.file tc.template.data stage_to_remote.swift $ARGS
+#./stage_to_remote1.setup.sh
+#ARGS=`cat stage_to_remote1.args`
+#swift -config swift.properties -sites.file sites.template.xml -tc.file tc.template.data stage_to_remote1.swift $ARGS
+#./stage_from_remote.setup.sh
+#ARGS=`cat stage_from_remote.args`
+#swift -config swift.properties -sites.file sites.template.xml -tc.file tc.template.data stage_from_remote.swift $ARGS
+./stage_to_remoteNx1.setup.sh
+ARGS=`cat stage_to_remoteNx1.args`
+swift -config swift.properties -sites.file sites.template.xml -tc.file tc.template.data stage_to_remoteNx1.swift $ARGS
Property changes on: trunk/tests/stress/IO/bagOnodes/run
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/stress/IO/bagOnodes/sites.template.xml
--- trunk/tests/stress/IO/bagOnodes/sites.template.xml	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/sites.template.xml	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,123 @@
+<config>
+  <pool handle="crank">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="crank.mcs.anl.gov"/>
+    <profile namespace="globus" key="jobsPerNode">8</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="globus" key="maxtime">3600</profile>
+    <profile namespace="globus" key="maxWalltime">00:05:00</profile>
+    <profile namespace="karajan" key="jobThrottle">0.0799</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <workdirectory>/sandbox/{env.USER}/swiftwork</workdirectory>
+  </pool>
+  <pool handle="churn">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="churn.mcs.anl.gov"/>
+  </pool>
+  <pool handle="crush">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="crush.mcs.anl.gov"/>
+  </pool>
+  <pool handle="grind">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="grind.mcs.anl.gov"/>
+  </pool>
+  <pool handle="steamroller">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="steamroller.mcs.anl.gov"/>
+  </pool>
+  <pool handle="stomp">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="stomp.mcs.anl.gov"/>
+  </pool>
+  <pool handle="thrash">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="thrash.mcs.anl.gov"/>
+  </pool>
+  <pool handle="thwomp">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="thwomp.mcs.anl.gov"/>
+  </pool>
+  <pool handle="trounce">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="trounce.mcs.anl.gov"/>
+  </pool>
+  <pool handle="vanquish">
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="vanquish.mcs.anl.gov"/>
+  </pool>
+</config>
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.check.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+rm -rf "dummy" *.out &> /dev/null
+if [ "$KILL_JAVA" == "true" ];
+then
+    echo "Killing Java.."
+    for dead in `ps axf -u $USER | grep HeapDumpOnOutOfMemoryError | grep -o ^[0-9]*`
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.check.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.setup.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+ARGS_FILE=${0%.setup.sh}.args
+MCS_USERNAME=$MCS_USERNAME
+case $STRESS in
+    "S1")
+        SIZE=10
+        LOOPS=0
+    "S2")
+        SIZE=15
+        LOOPS=0
+        SIZE=10
+        LOOPS=0
+esac
+echo "-loops=$LOOPS -size=$SIZE " > $ARGS_FILE
+cat <<'EOF' > filemaker.sh
+#!/bin/bash
+echo "From filemaker.sh $1 $2 on Host:$HOSTNAME"
+MAXSIZE=$1
+OUT=$2
+dd if=/dev/zero of=$OUT bs=1024 count=0 seek=$((1024*MAXSIZE))
+EOF
+if [[ -z $MCS_USERNAME ]]
+then
+    echo "Remote username not provided. Skipping sites configs"
+else
+    ls *xml
+    cat sites.xml  | sed "s/{env.USER}/$MCS_USERNAME/" > tmp && mv tmp sites.xml
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.setup.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.source.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+if [ "midway001" == "midway001" ]
+then
+   export GLOBUS_HOSTNAME=swift.rcc.uchicago.edu
+   export GLOBUS_TCP_PORT_RANGE=50000,51000
+fi;
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.source.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.swift
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
+file script  <"filemaker.sh">;
+app (file out, file log) remote_driver (file run, int size)
+    bash @run size @out stdout=@filename(log);
+file driver_out[] <simple_mapper; prefix="driver", suffix=".out">;
+file driver_log[] <simple_mapper; prefix="driver", suffix=".log">;
+int filesize = @toInt(@arg("size","10"));
+int loop = @toInt(@arg("loops","0"));
+foreach item,i in [0:loop] {
+        (driver_out[i], driver_log[i]) = remote_driver(script, filesize);
\ No newline at end of file
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.timeout
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.check.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+    killall -u $USER java -9
+fi
+IN=`grep "PerformanceDiagnosticInputStream\ \[IN\]" $BASE*log | tail -n 1`
+MEM=`grep "PerformanceDiagnosticInputStream\ \[MEM\]" $BASE*log`
+OUT=`grep "PerformanceDiagnosticOutputStream\ \[OUT\]" $BASE*log | tail -n 1`
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.check.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.setup.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=100
+        LOOPS=0
+    "S2")
+        SIZE=150
+        LOOPS=0
+        SIZE=100
+        LOOPS=0
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.setup.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.source.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.source.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.swift
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.timeout
--- trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remote1x2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.check.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.check.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.setup.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=20
+        LOOPS=10
+    "S2")
+        SIZE=30
+        LOOPS=20
+        SIZE=20
+        LOOPS=10
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.setup.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.source.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.source.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.swift
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.timeout
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.check.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.check.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.setup.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=20
+        LOOPS=50
+    "S2")
+        SIZE=50
+        LOOPS=50
+        SIZE=20
+        LOOPS=50
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.setup.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.source.sh
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.source.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.swift
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.timeout
--- trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_from_remoteNx2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.check.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.check.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.setup.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,56 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=50
+        LOOPS=0
+    "S2")
+        FILES=100
+        LOOPS=0
+        FILES=50
+        LOOPS=0
+esac
+dd if=/dev/zero of=dummy bs=1024 count=0 seek=$((1024*FILES))
+echo "-loops=$LOOPS" > $ARGS_FILE
+cat <<'EOF' > wrapper.sh
+#!/bin/bash
+ARG1=$1
+ls | grep "$1" &> /dev/null
+if [ $? == 0 ]
+then
+    echo "Hey this is wrapper and the $1 exists as a file";
+    ls -lah;
+else
+    echo "Doinks! the file we need isn't here";
+    ls -lah
+fi
+cat $ARG1 > $ARG1.test
+if [ $? == 0 ]
+then
+    echo "The cat worked! ";
+else
+    echo "The cat failed ";
+fi
+rm $ARG1 $ARG1.test
+echo "Residual files cleaned up"
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.setup.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.source.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.source.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.swift
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
+file package <"dummy">;
+file script  <"wrapper.sh">;
+app (file out, file err) remote_driver (file run, file tar)
+    bash @run @filename(tar) stdout=@filename(out) stderr=@filename(err);
+file driver_err[] <simple_mapper; prefix="driver", suffix=".err">;
+        (driver_out[i], driver_err[i]) = remote_driver(script, package);
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.timeout
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.check.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.check.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.setup.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+	FILES=100
+	LOOPS=0
+    "S2")
+	FILES=500
+	LOOPS=0
+        FILES=100
+        LOOPS=0
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.setup.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.source.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.source.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.swift
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.timeout
--- trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remote1x2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.args
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.args	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.args	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+-loops=10
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.check.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.check.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.setup.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=10
+        LOOPS=10
+    "S2")
+        FILES=10
+        LOOPS=50
+        FILES=10
+        LOOPS=10
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.setup.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.source.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.source.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.swift
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
+    bash @run @tar stdout=@out stderr=@err;
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.timeout
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+1200
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.check.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.check.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.setup.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=50
+        LOOPS=50
+    "S2")
+        FILES=100
+        LOOPS=100
+        FILES=50
+        LOOPS=50
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.setup.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.source.sh
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.source.sh
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.swift
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.timeout
--- trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/stage_to_remoteNx2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+1200
Added: trunk/tests/stress/IO/bagOnodes/swift.properties
--- trunk/tests/stress/IO/bagOnodes/swift.properties	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/swift.properties	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+use.provider.staging=true
+use.wrapper.staging=false
+wrapperlog.always.transfer=true
+execution.retries=0
+lazy.errors=false
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+tcp.port.range=50000,51000
Added: trunk/tests/stress/IO/bagOnodes/t.sh
--- trunk/tests/stress/IO/bagOnodes/t.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/t.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,13 @@
+#!/bin/bash
+arr=(crank chrun crush grind steamroller stomp thrash thwomp trounce vanquish);
+for item in ${arr[*]}
+do
+    echo "Host $item.mcs.anl.gov"
+    echo "    Hostname $item.mcs.anl.gov"
+    echo "    User yadunand"
+    echo "    ProxyCommand ssh -A yadunand at login.mcs.anl.gov nc %h %p 2> /dev/null"
+    echo "    ForwardAgent yes"
+    echo
+done
Property changes on: trunk/tests/stress/IO/bagOnodes/t.sh
Added: trunk/tests/stress/IO/bagOnodes/tc.template.data
--- trunk/tests/stress/IO/bagOnodes/tc.template.data	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/tc.template.data	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,10 @@
+crank  bash /bin/bash null null null
+churn  bash /bin/bash null null null
+crush  bash /bin/bash null null null
+grind  bash /bin/bash null null null
+steamroller bash /bin/bash null null null
+stomp  bash /bin/bash null null null
+thrash bash /bin/bash null null null
+thwomp bash /bin/bash null null null
+trounce bash /bin/bash null null null
+vanquish bash /bin/bash null null null
Added: trunk/tests/stress/IO/bagOnodes/temp.sh
--- trunk/tests/stress/IO/bagOnodes/temp.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/temp.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,16 @@
+#!/bin/bash
+for i in `ls *setup.sh`
+do
+    BASE=${i%.setup.sh};
+    echo $BASE
+    echo "Source file : $BASE.source.sh"
+    cat <<'EOF' > $BASE.check.sh
+#!/bin/bash
+echo "Cleaning up"
+rm -rf "dummy" driver*.out &> /dev/null
+EOF
+done;
Property changes on: trunk/tests/stress/IO/bagOnodes/temp.sh
Added: trunk/tests/stress/IO/bagOnodes/title.txt
--- trunk/tests/stress/IO/bagOnodes/title.txt	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/title.txt	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+IO stress testing at a bag of 10 nodes at MCS, ANL
Added: trunk/tests/stress/IO/bagOnodes/wrapper.sh
--- trunk/tests/stress/IO/bagOnodes/wrapper.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/wrapper.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,21 @@
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
Property changes on: trunk/tests/stress/IO/bagOnodes/wrapper.sh
Added: trunk/tests/stress/IO/bagOnodes/z_stats.clean.sh
--- trunk/tests/stress/IO/bagOnodes/z_stats.clean.sh	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/z_stats.clean.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,24 @@
+#!/bin/bash
+HOME=$PWD
+echo "Current test : $HOME"
+TESTS_HOME=$(dirname $HOME)
+echo "Tests home : $TESTS_HOME"
+ps -u $USER
+echo "Clearing all java instances"
+ps -u $USER | grep java
+if [ "$?" == "0" ]
+then
+fi
+echo "Collecting stats"
+for test_case in `ls $TESTS_HOME | grep stage`
+do
+    echo "$test_case"
+    cat $TESTS_HOME/$test_case/*check.stdout
+    echo
+done
Property changes on: trunk/tests/stress/IO/bagOnodes/z_stats.clean.sh
Added: trunk/tests/stress/IO/bagOnodes/z_stats.swift
--- trunk/tests/stress/IO/bagOnodes/z_stats.swift	                        (rev 0)
+++ trunk/tests/stress/IO/bagOnodes/z_stats.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+type file;
Added: trunk/tests/stress/IO/beagle/run
--- trunk/tests/stress/IO/beagle/run	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/run	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,22 @@
+#! /bin/sh
+set -x
+export STRESS="S1"
+export COG_OPTS=-Dtcp.channel.log.io.performance=true
+./stage_to_remote1x1.setup.sh
+ARGS=`cat stage_to_remote1x1.args`
+swift -config swift.properties -sites.file sites.template.xml -tc.file tc.template.data stage_to_remote1x1.swift $ARGS
Property changes on: trunk/tests/stress/IO/beagle/run
Added: trunk/tests/stress/IO/beagle/sites.template.xml
--- trunk/tests/stress/IO/beagle/sites.template.xml	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/sites.template.xml	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,20 @@
+<config>
+  <pool handle="beagle">
+    <execution provider="coaster" jobmanager="ssh-cl:pbs" url="login4.beagle.ci.uchicago.edu"/>
+    <profile namespace="globus" key="jobsPerNode">24</profile>
+    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
+    <profile namespace="globus" key="maxtime">3700</profile>
+    <profile namespace="globus" key="maxWalltime">01:00:00</profile>
+    <profile namespace="globus" key="userHomeOverride">/lustre/beagle/{env.USER}/swiftwork</profile>
+    <profile namespace="globus" key="slots">20</profile>
+    <profile namespace="globus" key="maxnodes">10</profile>
+    <profile namespace="globus" key="nodeGranularity">1</profile>
+    <profile namespace="karajan" key="jobThrottle">4.80</profile>
+    <profile namespace="karajan" key="workerLoggingLevel">trace</profile>
+    <!-- <workdirectory>/lustre/beagle/yadunandb/swiftwork</workdirectory> -->
+    <workdirectory>/tmp/{env.USER}/swiftwork</workdirectory>
+  </pool>
+</config>
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x1.check.sh
--- trunk/tests/stress/IO/beagle/stage_from_remote1x1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remote1x1.check.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x1.setup.sh
--- trunk/tests/stress/IO/beagle/stage_from_remote1x1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+BEAGLE_USERNAME=$BEAGLE_USERNAME
+case $STRESS in
+    "S1")
+        SIZE=10
+        LOOPS=0
+    "S2")
+        SIZE=15
+        LOOPS=0
+        SIZE=10
+        LOOPS=0
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+if [[ -z $BEAGLE_USERNAME ]]
+then
+else
+    ls *xml
+    cat sites.xml  | sed "s/{env.USER}/$BEAGLE_USERNAME/" > tmp && mv tmp sites.xml
+fi
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remote1x1.setup.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x1.source.sh
--- trunk/tests/stress/IO/beagle/stage_from_remote1x1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,10 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remote1x1.source.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x1.swift
--- trunk/tests/stress/IO/beagle/stage_from_remote1x1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x1.timeout
--- trunk/tests/stress/IO/beagle/stage_from_remote1x1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x2.check.sh
--- trunk/tests/stress/IO/beagle/stage_from_remote1x2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remote1x2.check.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x2.setup.sh
--- trunk/tests/stress/IO/beagle/stage_from_remote1x2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=100
+        LOOPS=0
+    "S2")
+        SIZE=150
+        LOOPS=0
+        SIZE=100
+        LOOPS=0
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remote1x2.setup.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x2.source.sh
--- trunk/tests/stress/IO/beagle/stage_from_remote1x2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remote1x2.source.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x2.swift
--- trunk/tests/stress/IO/beagle/stage_from_remote1x2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/beagle/stage_from_remote1x2.timeout
--- trunk/tests/stress/IO/beagle/stage_from_remote1x2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remote1x2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx1.check.sh
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remoteNx1.check.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx1.setup.sh
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=20
+        LOOPS=10
+    "S2")
+        SIZE=30
+        LOOPS=20
+        SIZE=20
+        LOOPS=10
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remoteNx1.setup.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx1.source.sh
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remoteNx1.source.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx1.swift
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx1.timeout
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx2.check.sh
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remoteNx2.check.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx2.setup.sh
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=20
+        LOOPS=50
+    "S2")
+        SIZE=50
+        LOOPS=50
+        SIZE=20
+        LOOPS=50
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remoteNx2.setup.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx2.source.sh
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/beagle/stage_from_remoteNx2.source.sh
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx2.swift
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/beagle/stage_from_remoteNx2.timeout
--- trunk/tests/stress/IO/beagle/stage_from_remoteNx2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_from_remoteNx2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x1.args
--- trunk/tests/stress/IO/beagle/stage_to_remote1x1.args	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x1.args	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+-loops=0
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x1.check.sh
--- trunk/tests/stress/IO/beagle/stage_to_remote1x1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remote1x1.check.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x1.setup.sh
--- trunk/tests/stress/IO/beagle/stage_to_remote1x1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,56 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=50
+        LOOPS=0
+    "S2")
+        FILES=100
+        LOOPS=0
+        FILES=50
+        LOOPS=0
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remote1x1.setup.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x1.source.sh
--- trunk/tests/stress/IO/beagle/stage_to_remote1x1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remote1x1.source.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x1.swift
--- trunk/tests/stress/IO/beagle/stage_to_remote1x1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x1.timeout
--- trunk/tests/stress/IO/beagle/stage_to_remote1x1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x2.check.sh
--- trunk/tests/stress/IO/beagle/stage_to_remote1x2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remote1x2.check.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x2.setup.sh
--- trunk/tests/stress/IO/beagle/stage_to_remote1x2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+	FILES=100
+	LOOPS=0
+    "S2")
+	FILES=500
+	LOOPS=0
+        FILES=100
+        LOOPS=0
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remote1x2.setup.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x2.source.sh
--- trunk/tests/stress/IO/beagle/stage_to_remote1x2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remote1x2.source.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x2.swift
--- trunk/tests/stress/IO/beagle/stage_to_remote1x2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/beagle/stage_to_remote1x2.timeout
--- trunk/tests/stress/IO/beagle/stage_to_remote1x2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remote1x2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.args
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx1.args	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx1.args	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+-loops=10
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.check.sh
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.check.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.setup.sh
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=10
+        LOOPS=10
+    "S2")
+        FILES=10
+        LOOPS=50
+        FILES=10
+        LOOPS=10
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.setup.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.source.sh
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.source.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.swift
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx1.timeout
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+1200
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx2.check.sh
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remoteNx2.check.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx2.setup.sh
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=50
+        LOOPS=50
+    "S2")
+        FILES=100
+        LOOPS=100
+        FILES=50
+        LOOPS=50
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remoteNx2.setup.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx2.source.sh
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/beagle/stage_to_remoteNx2.source.sh
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx2.swift
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/beagle/stage_to_remoteNx2.timeout
--- trunk/tests/stress/IO/beagle/stage_to_remoteNx2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/stage_to_remoteNx2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+1200
Added: trunk/tests/stress/IO/beagle/swift.properties
--- trunk/tests/stress/IO/beagle/swift.properties	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/swift.properties	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+lazy.errors=false
+sitedir.keep=true
Added: trunk/tests/stress/IO/beagle/tc.template.data
--- trunk/tests/stress/IO/beagle/tc.template.data	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/tc.template.data	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,2 @@
+local  perl /usr/bin/perl null null null
+beagle bash /bin/bash null null null
Added: trunk/tests/stress/IO/beagle/temp.sh
--- trunk/tests/stress/IO/beagle/temp.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/temp.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,31 @@
+#!/bin/bash
+do
+    echo $BASE
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
+EOF
+done;
Property changes on: trunk/tests/stress/IO/beagle/temp.sh
Added: trunk/tests/stress/IO/beagle/title.txt
--- trunk/tests/stress/IO/beagle/title.txt	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/title.txt	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,3 @@
+IO stress testing.
+Local site : ANY
+Remote site: Beagle
Added: trunk/tests/stress/IO/beagle/wrapper.sh
--- trunk/tests/stress/IO/beagle/wrapper.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/wrapper.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,21 @@
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
Property changes on: trunk/tests/stress/IO/beagle/wrapper.sh
Added: trunk/tests/stress/IO/beagle/z_stats.clean.sh
--- trunk/tests/stress/IO/beagle/z_stats.clean.sh	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/z_stats.clean.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,24 @@
+#!/bin/bash
+HOME=$PWD
+ps -u $USER
+if [ "$?" == "0" ]
+then
+fi
+do
+    echo "$test_case"
+    echo
+done
Property changes on: trunk/tests/stress/IO/beagle/z_stats.clean.sh
Added: trunk/tests/stress/IO/beagle/z_stats.swift
--- trunk/tests/stress/IO/beagle/z_stats.swift	                        (rev 0)
+++ trunk/tests/stress/IO/beagle/z_stats.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+type file;
Added: trunk/tests/stress/IO/multiple/run
--- trunk/tests/stress/IO/multiple/run	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/run	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,22 @@
+#! /bin/sh
+set -x
+export STRESS="S1"
Property changes on: trunk/tests/stress/IO/multiple/run
Added: trunk/tests/stress/IO/multiple/sites.template.xml
--- trunk/tests/stress/IO/multiple/sites.template.xml	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/sites.template.xml	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,70 @@
+<config>
+  <pool handle="uc3">
+    <execution provider="coaster" url="uc3-sub.uchicago.edu" jobmanager="ssh-cl:condor"/>
+    <profile namespace="karajan" key="jobThrottle">10.00</profile>
+    <profile namespace="globus"  key="jobsPerNode">1</profile>
+    <profile namespace="globus"  key="slots">1000</profile>
+    <profile namespace="globus"  key="maxNodes">1</profile>
+    <profile namespace="globus"  key="condor.+AccountingGroup">"group_friends.{uc3.USER}"</profile>
+    <profile namespace="globus"  key="jobType">nonshared</profile>
+    <!-- <profile namespace="globus"  key="condor.+Requirements">isUndefined(GLIDECLIENT_Name) == FALSE</profile> -->
+    <workdirectory>.</workdirectory>
+  </pool>
+    <!-- <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile> -->
+    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24;pbs.resource_list=advres=wilde.1768</profile>
+    <profile namespace="globus" key="userHomeOverride">/lustre/beagle/{beagle.USER}/swiftwork</profile>
+    <profile namespace="globus" key="slots">5</profile>
+    <profile namespace="globus" key="maxnodes">1</profile>
+    <workdirectory>/tmp/{beagle.USER}/swiftwork</workdirectory>
+  </pool>
+  <pool handle="sandyb">
+    <execution provider="coaster" jobmanager="local:slurm"/>
+    <profile namespace="globus" key="queue">sandyb</profile>
+    <profile namespace="globus" key="jobsPerNode">16</profile>
+    <profile namespace="globus" key="maxTime">3600</profile>
+    <profile namespace="globus" key="slots">4</profile>
+    <profile namespace="karajan" key="jobThrottle">.64</profile>
+    <workdirectory>/tmp/{mid.USER}</workdirectory>
+  </pool>
+  <pool handle="westmere">
+    <profile namespace="globus" key="queue">westmere</profile>
+    <profile namespace="globus" key="jobsPerNode">12</profile>
+    <profile namespace="karajan" key="jobThrottle">.48</profile>
+  </pool>
+</config>
Added: trunk/tests/stress/IO/multiple/sites.template.xml.beagle
--- trunk/tests/stress/IO/multiple/sites.template.xml.beagle	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/sites.template.xml.beagle	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,20 @@
+<config>
+    <execution provider="coaster" jobmanager="ssh-cl:local" url="login4.beagle.ci.uchicago.edu"/>
+    <profile namespace="globus" key="userHomeOverride">/lustre/beagle/yadunandb/swiftwork</profile>
+    <workdirectory>/tmp/yadunandb/swiftwork</workdirectory>
+  </pool>
+</config>
Added: trunk/tests/stress/IO/multiple/stage_from_remote1x1.check.sh
--- trunk/tests/stress/IO/multiple/stage_from_remote1x1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remote1x1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/multiple/stage_from_remote1x1.check.sh
Added: trunk/tests/stress/IO/multiple/stage_from_remote1x1.setup.sh
--- trunk/tests/stress/IO/multiple/stage_from_remote1x1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remote1x1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,60 @@
+#!/bin/bash
+#OVERRIDE_GLOBUS_HOST swift.rcc.uchicago.edu
+#OVERRIDE_GLOBUS_TCP_PORT_RANGE 50000,51000
+if [[ -z $MIDWAY_USERNAME ]]
+then
+else
+    ls *xml
+    cat sites.xml  | sed "s/{mid.USER}/$MIDWAY_USERNAME/" > tmp && mv tmp\
+ sites.xml
+fi
+if [[ -z $UC3_USERNAME ]]
+then
+else
+    ls *xml
+    cat sites.xml  | sed "s/{uc3.USER}/$UC3_USERNAME/" > tmp && mv tmp si\
+tes.xml
+fi
+then
+else
+    ls *xml
+    cat sites.xml  | sed "s/{beagle.USER}/$BEAGLE_USERNAME/" > tmp && mv \
+tmp sites.xml
+fi
+case $STRESS in
+    "S1")
+        SIZE=10
+        LOOPS=0
+    "S2")
+        SIZE=15
+        LOOPS=0
+        SIZE=10
+        LOOPS=0
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
Property changes on: trunk/tests/stress/IO/multiple/stage_from_remote1x1.setup.sh
Added: trunk/tests/stress/IO/multiple/stage_from_remote1x1.swift
--- trunk/tests/stress/IO/multiple/stage_from_remote1x1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remote1x1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/multiple/stage_from_remote1x1.timeout
--- trunk/tests/stress/IO/multiple/stage_from_remote1x1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remote1x1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/multiple/stage_from_remote1x2.check.sh
--- trunk/tests/stress/IO/multiple/stage_from_remote1x2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remote1x2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/multiple/stage_from_remote1x2.check.sh
Added: trunk/tests/stress/IO/multiple/stage_from_remote1x2.setup.sh
--- trunk/tests/stress/IO/multiple/stage_from_remote1x2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remote1x2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,60 @@
+#!/bin/bash
+then
+else
+    ls *xml
+ sites.xml
+fi
+then
+else
+    ls *xml
+tes.xml
+fi
+then
+else
+    ls *xml
+tmp sites.xml
+fi
+case $STRESS in
+    "S1")
+        SIZE=100
+        LOOPS=0
+    "S2")
+        SIZE=150
+        LOOPS=0
+        SIZE=100
+        LOOPS=0
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
Property changes on: trunk/tests/stress/IO/multiple/stage_from_remote1x2.setup.sh
Added: trunk/tests/stress/IO/multiple/stage_from_remote1x2.swift
--- trunk/tests/stress/IO/multiple/stage_from_remote1x2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remote1x2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/multiple/stage_from_remote1x2.timeout
--- trunk/tests/stress/IO/multiple/stage_from_remote1x2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remote1x2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/multiple/stage_from_remoteNx1.check.sh
--- trunk/tests/stress/IO/multiple/stage_from_remoteNx1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remoteNx1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/multiple/stage_from_remoteNx1.check.sh
Added: trunk/tests/stress/IO/multiple/stage_from_remoteNx1.setup.sh
--- trunk/tests/stress/IO/multiple/stage_from_remoteNx1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remoteNx1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,59 @@
+#!/bin/bash
+then
+else
+    ls *xml
+ sites.xml
+fi
+then
+else
+    ls *xml
+tes.xml
+fi
+then
+else
+    ls *xml
+tmp sites.xml
+fi
+case $STRESS in
+    "S1")
+        SIZE=20
+        LOOPS=10
+    "S2")
+        SIZE=30
+        LOOPS=20
+        SIZE=20
+        LOOPS=10
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
Property changes on: trunk/tests/stress/IO/multiple/stage_from_remoteNx1.setup.sh
Added: trunk/tests/stress/IO/multiple/stage_from_remoteNx1.swift
--- trunk/tests/stress/IO/multiple/stage_from_remoteNx1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remoteNx1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/multiple/stage_from_remoteNx1.timeout
--- trunk/tests/stress/IO/multiple/stage_from_remoteNx1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remoteNx1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/multiple/stage_from_remoteNx2.check.sh
--- trunk/tests/stress/IO/multiple/stage_from_remoteNx2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remoteNx2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/multiple/stage_from_remoteNx2.check.sh
Added: trunk/tests/stress/IO/multiple/stage_from_remoteNx2.setup.sh
--- trunk/tests/stress/IO/multiple/stage_from_remoteNx2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remoteNx2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,59 @@
+#!/bin/bash
+then
+else
+    ls *xml
+ sites.xml
+fi
+then
+else
+    ls *xml
+tes.xml
+fi
+then
+else
+    ls *xml
+tmp sites.xml
+fi
+case $STRESS in
+    "S1")
+        SIZE=20
+        LOOPS=50
+    "S2")
+        SIZE=50
+        LOOPS=50
+        SIZE=20
+        LOOPS=50
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
Property changes on: trunk/tests/stress/IO/multiple/stage_from_remoteNx2.setup.sh
Added: trunk/tests/stress/IO/multiple/stage_from_remoteNx2.swift
--- trunk/tests/stress/IO/multiple/stage_from_remoteNx2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remoteNx2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/multiple/stage_from_remoteNx2.timeout
--- trunk/tests/stress/IO/multiple/stage_from_remoteNx2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_from_remoteNx2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x1.args
--- trunk/tests/stress/IO/multiple/stage_to_remote1x1.args	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x1.args	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+-loops=0
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x1.check.sh
--- trunk/tests/stress/IO/multiple/stage_to_remote1x1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remote1x1.check.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x1.setup.sh
--- trunk/tests/stress/IO/multiple/stage_to_remote1x1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,72 @@
+#!/bin/bash
+then
+else
+    ls *xml
+ sites.xml
+fi
+then
+else
+    ls *xml
+tes.xml
+fi
+then
+else
+    ls *xml
+tmp sites.xml
+fi
+case $STRESS in
+    "S1")
+	FILES=50
+        LOOPS=0
+    "S2")
+	FILES=100
+        LOOPS=0
+        FILES=50
+        LOOPS=0
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remote1x1.setup.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x1.source.sh
--- trunk/tests/stress/IO/multiple/stage_to_remote1x1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remote1x1.source.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x1.swift
--- trunk/tests/stress/IO/multiple/stage_to_remote1x1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x1.timeout
--- trunk/tests/stress/IO/multiple/stage_to_remote1x1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x2.check.sh
--- trunk/tests/stress/IO/multiple/stage_to_remote1x2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remote1x2.check.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x2.setup.sh
--- trunk/tests/stress/IO/multiple/stage_to_remote1x2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,71 @@
+#!/bin/bash
+then
+else
+    ls *xml
+ sites.xml
+fi
+then
+else
+    ls *xml
+tes.xml
+fi
+then
+else
+    ls *xml
+tmp sites.xml
+fi
+case $STRESS in
+    "S1")
+	FILES=100
+        LOOPS=0
+    "S2")
+	FILES=500
+        LOOPS=0
+        FILES=100
+        LOOPS=0
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remote1x2.setup.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x2.source.sh
--- trunk/tests/stress/IO/multiple/stage_to_remote1x2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remote1x2.source.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x2.swift
--- trunk/tests/stress/IO/multiple/stage_to_remote1x2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/multiple/stage_to_remote1x2.timeout
--- trunk/tests/stress/IO/multiple/stage_to_remote1x2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remote1x2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.args
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx1.args	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx1.args	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+-loops=10
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.check.sh
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.check.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.setup.sh
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,74 @@
+#!/bin/bash
+then
+else
+    ls *xml
+ sites.xml
+fi
+then
+else
+    ls *xml
+tes.xml
+fi
+then
+else
+    ls *xml
+tmp sites.xml
+fi
+case $STRESS in
+    "S1")
+        FILES=10
+        LOOPS=10
+    "S2")
+        FILES=10
+        LOOPS=50
+        FILES=10
+        LOOPS=10
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.setup.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.source.sh
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.source.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.swift
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx1.timeout
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+1200
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx2.check.sh
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remoteNx2.check.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx2.setup.sh
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,74 @@
+#!/bin/bash
+then
+else
+    ls *xml
+ sites.xml
+fi
+then
+else
+    ls *xml
+tes.xml
+fi
+then
+else
+    ls *xml
+tmp sites.xml
+fi
+case $STRESS in
+    "S1")
+        FILES=50
+        LOOPS=50
+    "S2")
+        FILES=100
+        LOOPS=100
+        FILES=50
+        LOOPS=50
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remoteNx2.setup.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx2.source.sh
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/multiple/stage_to_remoteNx2.source.sh
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx2.swift
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/multiple/stage_to_remoteNx2.timeout
--- trunk/tests/stress/IO/multiple/stage_to_remoteNx2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/stage_to_remoteNx2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+1200
Added: trunk/tests/stress/IO/multiple/swift.properties
--- trunk/tests/stress/IO/multiple/swift.properties	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/swift.properties	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+lazy.errors=false
+sitedir.keep=true
Added: trunk/tests/stress/IO/multiple/tc.template.data
--- trunk/tests/stress/IO/multiple/tc.template.data	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/tc.template.data	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,2 @@
Added: trunk/tests/stress/IO/multiple/temp.sh
--- trunk/tests/stress/IO/multiple/temp.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/temp.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,16 @@
+#!/bin/bash
+do
+    echo $BASE
+#!/bin/bash
+echo "Cleaning up"
+EOF
+done;
Property changes on: trunk/tests/stress/IO/multiple/temp.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/stress/IO/multiple/title.txt
--- trunk/tests/stress/IO/multiple/title.txt	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/title.txt	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+IO stress testing on multiple remote sites: Beagle | UC3 | Midway
Added: trunk/tests/stress/IO/multiple/wrapper.sh
--- trunk/tests/stress/IO/multiple/wrapper.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/wrapper.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,21 @@
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
Property changes on: trunk/tests/stress/IO/multiple/wrapper.sh
Added: trunk/tests/stress/IO/multiple/z_stats.clean.sh
--- trunk/tests/stress/IO/multiple/z_stats.clean.sh	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/z_stats.clean.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,24 @@
+#!/bin/bash
+HOME=$PWD
+ps -u $USER
+if [ "$?" == "0" ]
+then
+fi
+do
+    echo "$test_case"
+    echo
+done
Property changes on: trunk/tests/stress/IO/multiple/z_stats.clean.sh
Added: trunk/tests/stress/IO/multiple/z_stats.swift
--- trunk/tests/stress/IO/multiple/z_stats.swift	                        (rev 0)
+++ trunk/tests/stress/IO/multiple/z_stats.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+type file;
Added: trunk/tests/stress/IO/uc3/run
--- trunk/tests/stress/IO/uc3/run	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/run	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,11 @@
+#! /bin/sh
+set -x
+export STRESS="S1"
+export GLOBUS_HOSTNAME=swift.rcc.uchicago.edu
+. stage_to_remote1x1.source.sh
+swift -config cf -sites.file sites.template.xml -tc.file tc.template.data stage_to_remote1x1.swift $ARGS
Property changes on: trunk/tests/stress/IO/uc3/run
Added: trunk/tests/stress/IO/uc3/script.args
--- trunk/tests/stress/IO/uc3/script.args	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/script.args	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+-loops=10
Added: trunk/tests/stress/IO/uc3/script.check.sh
--- trunk/tests/stress/IO/uc3/script.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/script.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,4 @@
+#!/bin/bash
+echo "Cleaning up"
Property changes on: trunk/tests/stress/IO/uc3/script.check.sh
Added: trunk/tests/stress/IO/uc3/script.setup.sh
--- trunk/tests/stress/IO/uc3/script.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/script.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,28 @@
+#!/bin/bash
+ARGS_FILE=script.args
+case $STRESS in
+    "S1")
+        FILES=10
+        LOOPS=10
+    "S2")
+        FILES=100
+        LOOPS=10
+    "S3")
+        FILES=200
+        LOOPS=20
+    "S4")
+        FILES=300
+        LOOPS=10
+        FILES=10
+        LOOPS=10
+esac
Property changes on: trunk/tests/stress/IO/uc3/script.setup.sh
Added: trunk/tests/stress/IO/uc3/sites.backup.xml
--- trunk/tests/stress/IO/uc3/sites.backup.xml	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/sites.backup.xml	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+<config>
+    <execution provider="coaster" url="uc3-sub.uchicago.edu" jobmanager="local:condor"/>
+    <profile namespace="karajan" key="jobThrottle">.99</profile>
+    <profile namespace="karajan" key="initialScore">1000</profile>
+    <profile namespace="globus"  key="maxWalltime">3600</profile>
+    <profile namespace="globus"  key="nodeGranularity">10</profile>
+    <profile namespace="globus"  key="highOverAllocation">100</profile>
+    <profile namespace="globus"  key="lowOverAllocation">100</profile>
+    <profile namespace="globus"  key="slots">1</profile>
+    <profile namespace="globus" key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile>
+    <profile namespace="globus"  key="maxNodes">10</profile>
+    <profile namespace="globus"  key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
+    <filesystem provider="local" url="none" />
+    <workdirectory>/tmp/workdir</workdirectory>
+  </pool>
+</config>
\ No newline at end of file
Added: trunk/tests/stress/IO/uc3/sites.template.xml
--- trunk/tests/stress/IO/uc3/sites.template.xml	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/sites.template.xml	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+<config>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <profile namespace="globus"  key="maxtime">3600</profile>
+    <profile namespace="globus"  key="maxWalltime">00:30:00</profile>
+  </pool>
+</config>
Added: trunk/tests/stress/IO/uc3/stage_from_remote.check.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,4 @@
+#!/bin/bash
+echo "Cleaning up"
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote.check.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote.setup.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,13 @@
+#!/bin/bash
+echo "-loops=10 -size=10 -Dtcp.channel.log.io.performance=true" > stage_from_remote.args
+cat <<'EOF' > filemaker.sh
+#!/bin/bash
+echo "From filemaker.sh $1 $2 on Host:$HOSTNAME"
+MAXSIZE=$1
+OUT=$2
+dd if=/dev/zero of=$OUT bs=1024 count=0 seek=$((1024*MAXSIZE))
+EOF
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote.source.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,7 @@
+#!/bin/bash
+if [ "midway001" == "midway001" ]
+then
+   export GLOBUS_HOSTNAME=swift.rcc.uchicago.edu
+   export GLOBUS_TCP_PORT_RANGE=50000,51000
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote.source.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote.swift
--- trunk/tests/stress/IO/uc3/stage_from_remote.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
+file script  <"filemaker.sh">;
+app (file out, file log) remote_driver (file run, int size)
+    bash @run size @out stdout=@filename(log);
+file driver_out[] <simple_mapper; prefix="driver", suffix=".out">;
+file driver_log[] <simple_mapper; prefix="driver", suffix=".log">;
+int filesize = @toInt(@arg("size","10"));
+int loop = @toInt(@arg("loops","0"));
+foreach item,i in [0:loop] {
+        (driver_out[i], driver_log[i]) = remote_driver(script, filesize);
Added: trunk/tests/stress/IO/uc3/stage_from_remote.timeout
--- trunk/tests/stress/IO/uc3/stage_from_remote.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x1.check.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote1x1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+rm -rf "dummy" *.out &> /dev/null
+if [ "$KILL_JAVA" == "true" ];
+then
+    echo "Killing Java.."
+    for dead in `ps axf -u $USER | grep HeapDumpOnOutOfMemoryError | grep -o ^[0-9]*`
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote1x1.check.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x1.setup.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote1x1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+ARGS_FILE=${0%.setup.sh}.args
+UC3_USERNAME=$UC3_USERNAME
+case $STRESS in
+    "S1")
+        SIZE=10
+        LOOPS=0
+    "S2")
+        SIZE=15
+        LOOPS=0
+        SIZE=10
+        LOOPS=0
+esac
+echo "-loops=$LOOPS -size=$SIZE " > $ARGS_FILE
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+    echo "Remote username not provided. Skipping sites configs"
+else
+    ls *xml
+    cat sites.xml  | sed "s/{env.USER}/$UC3_USERNAME/" > tmp && mv tmp sites.xml
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote1x1.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x1.source.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote1x1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote1x1.source.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x1.swift
--- trunk/tests/stress/IO/uc3/stage_from_remote1x1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x1.timeout
--- trunk/tests/stress/IO/uc3/stage_from_remote1x1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x2.check.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote1x2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+    killall -u $USER java -9
+fi
+IN=`grep "PerformanceDiagnosticInputStream\ \[IN\]" $BASE*log | tail -n 1`
+MEM=`grep "PerformanceDiagnosticInputStream\ \[MEM\]" $BASE*log`
+OUT=`grep "PerformanceDiagnosticOutputStream\ \[OUT\]" $BASE*log | tail -n 1`
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote1x2.check.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x2.setup.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote1x2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=100
+        LOOPS=0
+    "S2")
+        SIZE=150
+        LOOPS=0
+        SIZE=100
+        LOOPS=0
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote1x2.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x2.source.sh
--- trunk/tests/stress/IO/uc3/stage_from_remote1x2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remote1x2.source.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x2.swift
--- trunk/tests/stress/IO/uc3/stage_from_remote1x2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/uc3/stage_from_remote1x2.timeout
--- trunk/tests/stress/IO/uc3/stage_from_remote1x2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remote1x2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx1.check.sh
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remoteNx1.check.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx1.setup.sh
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=20
+        LOOPS=10
+    "S2")
+        SIZE=30
+        LOOPS=20
+        SIZE=20
+        LOOPS=10
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remoteNx1.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx1.source.sh
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remoteNx1.source.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx1.swift
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx1.timeout
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx2.check.sh
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remoteNx2.check.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx2.setup.sh
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,39 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        SIZE=20
+        LOOPS=50
+    "S2")
+        SIZE=50
+        LOOPS=50
+        SIZE=20
+        LOOPS=50
+esac
+#!/bin/bash
+MAXSIZE=$1
+OUT=$2
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remoteNx2.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx2.source.sh
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_from_remoteNx2.source.sh
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx2.swift
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/uc3/stage_from_remoteNx2.timeout
--- trunk/tests/stress/IO/uc3/stage_from_remoteNx2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_from_remoteNx2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x1.args
--- trunk/tests/stress/IO/uc3/stage_to_remote1x1.args	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x1.args	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+-loops=0
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x1.check.sh
--- trunk/tests/stress/IO/uc3/stage_to_remote1x1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remote1x1.check.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x1.setup.sh
--- trunk/tests/stress/IO/uc3/stage_to_remote1x1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,56 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=50
+        LOOPS=0
+    "S2")
+        FILES=100
+        LOOPS=0
+        FILES=50
+        LOOPS=0
+esac
+dd if=/dev/zero of=dummy bs=1024 count=0 seek=$((1024*FILES))
+echo "-loops=$LOOPS" > $ARGS_FILE
+cat <<'EOF' > wrapper.sh
+#!/bin/bash
+ARG1=$1
+ls | grep "$1" &> /dev/null
+if [ $? == 0 ]
+then
+    echo "Hey this is wrapper and the $1 exists as a file";
+    ls -lah;
+else
+    echo "Doinks! the file we need isn't here";
+    ls -lah
+fi
+cat $ARG1 > $ARG1.test
+if [ $? == 0 ]
+then
+    echo "The cat worked! ";
+else
+    echo "The cat failed ";
+fi
+rm $ARG1 $ARG1.test
+echo "Residual files cleaned up"
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remote1x1.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x1.source.sh
--- trunk/tests/stress/IO/uc3/stage_to_remote1x1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remote1x1.source.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x1.swift
--- trunk/tests/stress/IO/uc3/stage_to_remote1x1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
+file package <"dummy">;
+file script  <"wrapper.sh">;
+app (file out, file err) remote_driver (file run, file tar)
+    bash @run @filename(tar) stdout=@filename(out) stderr=@filename(err);
+file driver_err[] <simple_mapper; prefix="driver", suffix=".err">;
+        (driver_out[i], driver_err[i]) = remote_driver(script, package);
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x1.timeout
--- trunk/tests/stress/IO/uc3/stage_to_remote1x1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x2.check.sh
--- trunk/tests/stress/IO/uc3/stage_to_remote1x2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remote1x2.check.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x2.setup.sh
--- trunk/tests/stress/IO/uc3/stage_to_remote1x2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+	FILES=100
+	LOOPS=0
+    "S2")
+	FILES=500
+	LOOPS=0
+        FILES=100
+        LOOPS=0
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remote1x2.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x2.source.sh
--- trunk/tests/stress/IO/uc3/stage_to_remote1x2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remote1x2.source.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x2.swift
--- trunk/tests/stress/IO/uc3/stage_to_remote1x2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/uc3/stage_to_remote1x2.timeout
--- trunk/tests/stress/IO/uc3/stage_to_remote1x2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remote1x2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+600
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx1.check.sh
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx1.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx1.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+#!/bin/bash
+echo "Cleaning up"
+then
+    do
+        kill -9 $dead
+    done
+else
+    echo "No"
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remoteNx1.check.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx1.setup.sh
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx1.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx1.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=10
+        LOOPS=10
+    "S2")
+        FILES=10
+        LOOPS=50
+        FILES=10
+        LOOPS=10
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remoteNx1.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx1.source.sh
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx1.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx1.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remoteNx1.source.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx1.swift
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx1.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx1.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
+    bash @run @tar stdout=@out stderr=@err;
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx1.timeout
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx1.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx1.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+1200
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx2.check.sh
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx2.check.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx2.check.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,19 @@
+#!/bin/bash
+then
+fi
+echo "====="
+echo "IN  : $IN"
+echo "MEM : $MEM"
+echo "OUT : $OUT"
+echo "====="
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remoteNx2.check.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx2.setup.sh
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx2.setup.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx2.setup.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,55 @@
+#!/bin/bash
+case $STRESS in
+    "S1")
+        FILES=50
+        LOOPS=50
+    "S2")
+        FILES=100
+        LOOPS=100
+        FILES=50
+        LOOPS=50
+esac
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
+EOF
+then
+else
+    ls *xml
+fi
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remoteNx2.setup.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx2.source.sh
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx2.source.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx2.source.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,6 @@
+#!/bin/bash
+then
+fi;
Property changes on: trunk/tests/stress/IO/uc3/stage_to_remoteNx2.source.sh
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx2.swift
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx2.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx2.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,17 @@
+type file;
Added: trunk/tests/stress/IO/uc3/stage_to_remoteNx2.timeout
--- trunk/tests/stress/IO/uc3/stage_to_remoteNx2.timeout	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/stage_to_remoteNx2.timeout	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+1200
Added: trunk/tests/stress/IO/uc3/swift.properties
--- trunk/tests/stress/IO/uc3/swift.properties	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/swift.properties	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,8 @@
+use.provider.staging=true
+use.wrapper.staging=false
+wrapperlog.always.transfer=true
+execution.retries=0
+lazy.errors=false
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+tcp.port.range=50000,51000
Added: trunk/tests/stress/IO/uc3/tc.template.data
--- trunk/tests/stress/IO/uc3/tc.template.data	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/tc.template.data	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,2 @@
+uc3    bash /bin/bash null null null
Added: trunk/tests/stress/IO/uc3/temp.sh
--- trunk/tests/stress/IO/uc3/temp.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/temp.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,16 @@
+#!/bin/bash
+for i in `ls *setup.sh`
+do
+    BASE=${i%.setup.sh};
+    echo $BASE
+    echo "Source file : $BASE.source.sh"
+    cat <<'EOF' > $BASE.check.sh
+#!/bin/bash
+echo "Cleaning up"
+rm -rf "dummy" driver*.out &> /dev/null
+EOF
+done;
Property changes on: trunk/tests/stress/IO/uc3/temp.sh
Added: trunk/tests/stress/IO/uc3/title.txt
--- trunk/tests/stress/IO/uc3/title.txt	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/title.txt	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+IO stress testing at remote site: UC3
Added: trunk/tests/stress/IO/uc3/wrapper.sh
--- trunk/tests/stress/IO/uc3/wrapper.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/wrapper.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,21 @@
+#!/bin/bash
+ARG1=$1
+if [ $? == 0 ]
+then
+    ls -lah;
+else
+    ls -lah
+fi
+if [ $? == 0 ]
+then
+else
+fi
Property changes on: trunk/tests/stress/IO/uc3/wrapper.sh
Added: trunk/tests/stress/IO/uc3/z_stats.clean.sh
--- trunk/tests/stress/IO/uc3/z_stats.clean.sh	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/z_stats.clean.sh	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1,24 @@
+#!/bin/bash
+HOME=$PWD
+echo "Current test : $HOME"
+TESTS_HOME=$(dirname $HOME)
+echo "Tests home : $TESTS_HOME"
+ps -u $USER
+echo "Clearing all java instances"
+ps -u $USER | grep java
+if [ "$?" == "0" ]
+then
+fi
+echo "Collecting stats"
+for test_case in `ls $TESTS_HOME | grep stage`
+do
+    echo "$test_case"
+    cat $TESTS_HOME/$test_case/*check.stdout
+    echo
+done
Property changes on: trunk/tests/stress/IO/uc3/z_stats.clean.sh
Added: trunk/tests/stress/IO/uc3/z_stats.swift
--- trunk/tests/stress/IO/uc3/z_stats.swift	                        (rev 0)
+++ trunk/tests/stress/IO/uc3/z_stats.swift	2013-08-21 16:40:28 UTC (rev 6908)
@@ -0,0 +1 @@
+type file;
More information about the Swift-commit
