[Swift-commit] r6820 - in SwiftTutorials: . CIC_2013-08-09 CIC_2013-08-09/logs CIC_2013-08-09/site_catalog CIC_2013-08-09/site_catalog/cloud CIC_2013-08-09/site_catalog/cloud/logs CIC_2013-08-09/site_catalog/local CIC_2013-08-09/site_catalog/tukey CIC_2013-08-09/site_catalog/uc3
yadunandb at ci.uchicago.edu
Fri Aug 9 15:48:21 CDT 2013
Author: yadunandb
Date: 2013-08-09 15:48:19 -0500 (Fri, 09 Aug 2013)
New Revision: 6820
Added:
SwiftTutorials/CIC_2013-08-09/
SwiftTutorials/CIC_2013-08-09/README
SwiftTutorials/CIC_2013-08-09/build_docs.sh
SwiftTutorials/CIC_2013-08-09/logs/
SwiftTutorials/CIC_2013-08-09/logs/coaster.log
SwiftTutorials/CIC_2013-08-09/p1.png
SwiftTutorials/CIC_2013-08-09/p2.png
SwiftTutorials/CIC_2013-08-09/p3.png
SwiftTutorials/CIC_2013-08-09/p4.png
SwiftTutorials/CIC_2013-08-09/p5.png
SwiftTutorials/CIC_2013-08-09/p6.png
SwiftTutorials/CIC_2013-08-09/p7.png
SwiftTutorials/CIC_2013-08-09/p8.png
SwiftTutorials/CIC_2013-08-09/p9.png
SwiftTutorials/CIC_2013-08-09/push.sh
SwiftTutorials/CIC_2013-08-09/setup.bak.sh
SwiftTutorials/CIC_2013-08-09/setup.sh
SwiftTutorials/CIC_2013-08-09/setup.sh~
SwiftTutorials/CIC_2013-08-09/simulate.sh
SwiftTutorials/CIC_2013-08-09/site_catalog/
SwiftTutorials/CIC_2013-08-09/site_catalog/beagle/
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/apps
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cf
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/coaster-service.conf
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_13-28-48.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_13-56-29.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_15-03-53.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_15-09-46.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1324-j7orj4xe.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1325-8751olnf.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1329-xbfrp1v7.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1341-mgfzzx18.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1356-hl1k32ja.d/
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1356-hl1k32ja.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1504-9rz1uo2f.d/
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1504-9rz1uo2f.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1510-3s32v3pd.d/
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi-20130809-1510-3s32v3pd.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi.kml
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi.swift
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hi.swiftx
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/hosts.txt
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/logs/
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/logs/coaster.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/pool.txt
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/setup.sh
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/sites.xml
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/swift.log
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/tc.data
SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/tutorial.pem
SwiftTutorials/CIC_2013-08-09/site_catalog/local/
SwiftTutorials/CIC_2013-08-09/site_catalog/local/apps
SwiftTutorials/CIC_2013-08-09/site_catalog/local/sites.xml
SwiftTutorials/CIC_2013-08-09/site_catalog/midway/
SwiftTutorials/CIC_2013-08-09/site_catalog/tukey/
SwiftTutorials/CIC_2013-08-09/site_catalog/tukey/apps
SwiftTutorials/CIC_2013-08-09/site_catalog/tukey/sites.xml
SwiftTutorials/CIC_2013-08-09/site_catalog/uc3/
SwiftTutorials/CIC_2013-08-09/site_catalog/uc3/apps
SwiftTutorials/CIC_2013-08-09/site_catalog/uc3/setup.sh
SwiftTutorials/CIC_2013-08-09/site_catalog/uc3/sites.xml
SwiftTutorials/CIC_2013-08-09/stats.sh
SwiftTutorials/CIC_2013-08-09/swift-t-extras.pptx
SwiftTutorials/CIC_2013-08-09/swift.log
Log:
Committing changes for CIC demo
Added: SwiftTutorials/CIC_2013-08-09/README
--- SwiftTutorials/CIC_2013-08-09/README (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/README 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,867 @@
+ATPESC 2013 Workflow Tutorial Exercises
+Workflow tutorial setup
+Check out scripts from SVN
+To checkout the most recent ATPESC tutorial scripts from SVN, run the following
+command:
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/ATPESC_2013-08-06
+This will create a directory called ATPESC_2013-08-06 which contains all of the
+scripts mentioned in this document.
+Run setup
+Once the scripts are checked out, run the following commands to perform
+the initial setup.
+$ cd ATPESC_2013-08-06 # change to the newly created ATPESC_2013-08-06 directory
+$ source setup.sh # sets swift config files in $HOME/.swift
+$ swift -version # verify that Swift 0.94 is in your $PATH and functional
+NOTE: If you disconnect from the machine, you will need to re-run source setup.sh.
+Mock "science applications" for the workflow tutorial
+There are two shell scripts included that serve a very simple stand-ins for science application:
+simulation.sh and stats.sh
+simulation.sh
+The simulation.sh script is a simple substitute for a scientific simulation application. It generates and prints a set of one or more random integers in the range 0-29,999 as controlled by its optional arguments, which are:
+.simulation.sh arguments
+[options="header"]
+|Argument number|Description
+|1 |runtime. Set how long simulation.sh should run, in seconds.
+|2 |range. Limit random numbers to the range [0,range-1]
+|3 |biasfile. Adds the integer contained in this file to each random number generated.
+|4 |scale. Multiplies each random number by this integer argument.
+|5 |n. Generate n number of random numbers.
+With no arguments, simulate.sh prints 1 number in the range of 1-100. Otherwise it generates n numbers of the form R * scale + bias.
+$ ./simulate.sh
+96
+stats.sh
+The stats.sh script reads a file containing n numbers and prints the average
+of those numbers to stdout.
+Introductory exercises
+Parts 1-6 (p1.swift - p6.swift) run locally and serve as examples of the Swift language.
+Parts 7-9 (p7.swift - p9.swift) submit jobs via Cobalt to the Tukey data analysis and visualization cluster.
+p1 - Run an application under Swift
+The first swift script, p1.swift, runs simulate.sh to generate a single random
+number. It writes the number to a file.
+image:p1.png[]
+.p1.swift
+type file;
+app (file o) mysim ()
+ simulate stdout=@filename(o);
+file f = mysim();
+To run this script, run the following command:
+$ cd part01
+$ swift p1.swift
+The simulate application gets translated to simulate.sh within the 'apps' file.
+NOTE: Since the file you created is not named, swift will generate a random
+name for the file in a directory called _concurrent. To view the created
+output, run "cat _concurrent/*"
+To cleanup the directory and remove all outputs, run:
+$ ./cleanup.sh
+p2 - Mapping (naming) output files
+The second swift script shows an example of naming the file. The output is now
+in a file called sim.out.
+image:p2.png[]
+.p2.swift
+type file;
+file f <"sim.out">;
+f = mysim();
+To run the script:
+$ cd part02
+$ swift p2.swift
+p3 - Parallel loops with foreach
+The p3.swift script introduces the foreach loop. This script runs many
+simulations. Output files are named here by Swift and will get created
+in the _concurrent directory.
+image:p3.png[]
+.p3.swift
+type file;
+foreach i in [0:9] {
+ file f = mysim();
+To run:
+$ cd part03
+$ swift p3.swift
+p4 - Mapping arrays to files
+p4.swift gives an example of naming multiple files within a foreach loop.
+image:p4.png[]
+.p4.swift
+type file;
+ file f <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+ f = mysim();
+To run:
+$ swift p4.swift
+Output files will be named output/sim_N.out.
+p5 - merging/reducing the results of a parallel foreach loop
+p5.swift introduces a postprocessing step. After all the parallel simulations have completed, the files
+created by simulation.sh will be averaged by stats.sh.
+image:p5.png[]
+.p5.swift
+type file;
+app (file o) analyze (file s[])
+ stats @filenames(s) stdout=@filename(o);
+file sims[];
+int nsim = @toInt(@arg("nsim","10"));
+foreach i in [0:nsim-1] {
+ file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+ simout = mysim();
+ sims[i] = simout;
+file stats<"output/average.out">;
+stats = analyze(sims);
+To run:
+$ swift p5.swift
+p6 - Sending arguments to applications
+p6.swift introduces command line arguments. The script sets a variable called
+"steps" here, which determines the length of time that the simulation.sh
+will run for. It also defines a variable called nsim, which determines the
+number of simulations to run.
+image:p6.png[]
+.p6.swift
+type file;
+app (file o) mysim (int timesteps)
+ simulate timesteps stdout=@filename(o);
+file sims[];
+int steps = @toInt(@arg("steps","1"));
+ simout = mysim(steps);
+ sims[i] = simout;
+Use the command below to specify the time for each simulation.
+$ cd part06
+$ swift p6.swift -steps=3 # each simulation takes 3 seconds
+p7 - Running on the Tukey analysis cluster compute nodes
+p7.swift is the first script that will submit jobs to Tukey via the Cobalt scheduler.
+It is similar to earlier scripts, with a few minor exceptions. To generalize the script
+for other types of remote execution (e.g., when no shared filesystem is available to the compute nodes), the application simulate.sh
+will get transferred to the worker node by Swift, in the same manner as any other input data file.
+image:p7.png[]
+.p7.swift
+type file;
+# Application to be called by this script
+file simulation_script <"simulate.sh">;
+# app() functions for application programs to be called:
+app (file out) simulation (file script, int timesteps, int sim_range)
+ sh @filename(script) timesteps sim_range stdout=@filename(out);
+# Command line params to this script:
+int nsim = @toInt(@arg("nsim", "10")); # number of simulation programs to run
+int range = @toInt(@arg("range", "100")); # range of the generated random numbers
+# Main script and data
+int steps=3;
+tracef("\n*** Script parameters: nsim=%i steps=%i range=%i \n\n", nsim, steps, range);
+ simout = simulation(simulation_script, steps, range);
+To run:
+$ cd part07
+$ swift p7.swift
+p8 - Running the stats summary step on the Tukey cluster
+p8.swift will also stage in and run stats.sh to calculate averages. It adds a
+trace statement so you can see the order in which things execute.
+image:p8.png[]
+.p8.swift
+type file;
+# Applications to be called by this script
+file analysis_script <"stats.sh">;
+app (file out) simulation (file script, int timesteps, int sim_range, file bias_file, int scale, int sim_count)
+ sh @filename(script) timesteps sim_range @filename(bias_file) scale sim_count stdout=@filename(out);
+app (file out) analyze (file script, file s[])
+ sh @script @filenames(s) stdout=@filename(out);
+int steps = @toInt(@arg("steps", "1")); # number of "steps" each simulation (==seconds of runtime)
+int count = @toInt(@arg("count", "10")); # number of random numbers generated per simulation
+tracef("\n*** Script parameters: nsim=%i steps=%i range=%i count=%i\n\n", nsim, steps, range, count);
+file sims[]; # Array of files to hold each simulation output
+file bias<"bias.dat">; # Input data file to "bias" the numbers:
+ # 1 line: scale offset ( N = n*scale + offset)
+ simout = simulation(simulation_script, steps, range, bias, 100000, count);
+ sims[i] = simout;
+file stats<"output/stats.out">; # Final output file: average of all "simulations"
+stats = analyze(analysis_script,sims);
+To run:
+$ cd part08
+$ swift p8.swift
+p9 - A more complex workflow pattern: multiple parallel pipelines
+p9.swift adds another app function called genrand. Genrand will produce a random
+number that will be used to determine how long each simulation app will run.
+image:p9.png[]
+.p9.swift
+type file;
+app (file out) genrand (file script, int timesteps, int sim_range)
+tracef("\n*** Script parameters: nsim=%i range=%i count=%i\n\n", nsim, range, count);
+file bias<"dynamic_bias.dat">; # Dynamically generated bias for simulation ensemble
+bias = genrand(simulation_script, 1, 1000);
+ int steps = readData(genrand(simulation_script, 1, 5));
+ tracef(" for simulation[%i] steps=%i\n", i, steps+1);
+ simout = simulation(simulation_script, steps+1, range, bias, 100000, count);
+ sims[i] = simout;
+To run:
+$ cd part09
+$ swift p9.swift
+Running Swift scripts on Cloud resources
+Setting up the Cloud exercises
+A number of preconfigured Amazon EC2 nodes are set up for running Swift.
+Run the Cloud exercises
+* Change to cloud dir:
+ cd ~/cloud
+* Copy the private key tutorial.pem to your .ssh dir:
+ cp tutorial.pem ~/.ssh/
+* Source the setup script on command line:
+ source ./setup
+* Run the catsn Swift script:
+ ./run.catsn
+* Run the Cloud versions of the Swift scripts p7, p8,and p9.swift:
+ swift -sites.file sites.xml -config cf -tc.file tc p7.swift
+ swift -sites.file sites.xml -config cf -tc.file tc p8.swift
+ swift -sites.file sites.xml -config cf -tc.file tc p9.swift
+* Add cloud resources to existing examples:
+ ./addcloud.sh <dir> #where dir is a tutorial script directory
+ e.g.
+ ./addcloud.sh ../part01 #will create a new site pool "both.xml" in ../part01
+* Finally, to clean up the log files, kill agent and shutdown the coaster service:
+ ./cleanme
+Notes on the Cloud exercises
+The run.catsn shell script contains the full command line to call Swift scripts with configuration files. This script runs swift as follows:
+swift -sites.file sites.xml -tc.file tc -config cf catsn.swift -n=10
+To learn more about the configuration files, see Swift user-guide:
+http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html
+Running Swift/T on Vesta with Python and R integration
+Normally it is difficult to run scripted programs such as Python and
+R on the Blue Gene/Q because of the limited OS environment. However,
+Swift/T allows you to create a composite application that is linked
+into one Cobalt job at run time. Thus, you can write a scripted
+program that coordinates calls from Swift to C, C++, Fortran, Python,
+R, or Tcl. All data movement is handled by the Swift/T runtime over
+MPI, removing the overhead of file access.
+=== p11 - Scripted parallel numerics with Python and R
+As shown on the slides, this example calls the
+http://www.numpy.org[Numpy] numerical libraries via Python as well as
+the http://www.r-project.org[R language] for statistics. In this
+example, we use Numpy to construct matrices, perform matrix
+arithmetic, and compute determinants. Since determinant is _O(n^3^)_,
+we compute each determinant in parallel using the Swift +foreach+
+loop. All result are collected and passed to the R +max()+ function.
+==== Scripts
+This example is designed to run on Vesta.
+To compile and run the script, run:
+.run-dets.sh
+include::part11-swift-py-r/code/run-dets.sh.txt[]
+As a reference, an equivalent plain Python code is provided:
+.dets.py
+include::part11-swift-py-r/code/dets.py[]
+The Swift script is:
+.dets.swift
+include::part11-swift-py-r/code/dets.swift[]
+==== Analysis
+The Turbine run time script creates a +TURBINE_OUTPUT+ directory and
+reports it. Standard output from the job is in +output.txt+.
+Use +grep dets+ to find the results printed by the Swift script. You
+will see each determinant as inserted into the Swift array, and the
+maximal result.
+Turbine was launched with +-n 10+; that is, 10 total processes, 8 of
+which are workers, ranks 1-8. Much of the output is created by rank
+0, the Turbine engine. (Only one engine is used in this case,
+although Swift/T supports multiple engines for scalability.) The ADLB
+server runs on rank 9 and produces almost no output. (Swift/T and
+ADLB support multiple servers.)
+You may +grep+ for +python: expression:+ to see the Python expressions
+evaluated on the workers. Note the rank numbers.
+For production cases, you may disable logging by setting
++TURBINE_LOG=0+ in the environment.
+=== More information
+For more information about Swift/T, see:
+* https://sites.google.com/site/exmcomputing/swift-t[Swift/T Overview]
+* http://www.mcs.anl.gov/exm/local/guides/swift.html[Swift/T Guide]
+* http://www.mcs.anl.gov/exm/local/guides/turbine-sites.html[Sites Guide]
+ — notes for running Swift/T on various systems
+Running MPI apps under Swift
+Modis - Satellite image data processing
+In this section we will use swift to process data from a large dataset of
+files that categorize the Earth's surface, derived from the MODIS sensor
+instruments that orbit the Earth on two NASA satellites of the Earth Observing System.
+The dataset we use (for 2002, named +mcd12q1+) consists of 317 "tile" files
+that categorize every 250-meter square of non-ocean surface of the Earth into
+one of 17 "land cover" categories (for example, water, ice, forest, barren, urban).
+Each pixel of these data files has a value of 0 to 16, describing one square
+of the Earth's surface at a specific point in time. Each tile file has
+approximately 5 million 1-byte pixels (5.7 MB), covering 2400x2400 250-meter
+squares, based on a specific map projection.
+image:sinusoidal_v5.gif[]
+modis01 - Process 1 image
+The first modis example defines one app function called getLandUse.
+This app takes a satellite image (data/modis/2002/h00v09.pgm.gz) as
+input. getLandUse creates a text file called landuse/h00v08.landuse.byfreq
+that counts the frequency of each land type defined in the input image.
+.modis01.swift
+type imagefile;
+type landuse;
+app (landuse output) getLandUse (imagefile input)
+ getlanduse @filename(input) stdout=@filename(output);
+imagefile modisImage <"data/global/h00v09.rgb">;
+landuse result <"landuse/h00v09.landuse.byfreq">;
+result = getLandUse(modisImage);
+To run modis01.swift:
+$ cd modis/modis01/
+$ swift modis01.swift
+modis02 - Process multiple images in parallel
+The second modis example expands upon the first example by running getLandUse
+with multiple (317) input files. Ouptut files are stored in the landuse directory.
+In order to map several input files we will use the ext mapper here to specify
+the mapper script, location a suffix to identify matching files.
+TODO: More on mappers
+.modis02.swift
+type imagefile;
+type landuse;
+# Constants and command line arguments
+int nFiles = @toInt(@arg("nfiles", "1000"));
+string MODISdir = @arg("modisdir", "data/global");
+# Input Dataset
+imagefile geos[] <ext; exec="../bin/modis.mapper", location=MODISdir, suffix=".rgb", n=n\
+Files>;
+# Compute the land use summary of each MODIS tile
+landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strc\
+at("landuse/\\1.landuse.byfreq")>;
+foreach g,i in geos {
+ land[i] = getLandUse(g);
+To run modis02.swift
+$ cd modis/modis02/
+$ swift modis02.swift
+modis03 - Analyse the processed images
+The third modis example builds on the previous example. It defines a new app function
+called analyzeLandUse. The analyzeLandUse app examines the data generated by getLandUse
+and creates two summary files called topselected.txt and selectedtiles.txt. These
+files contain information about the top 10 urban areas.
+In the previous example, you have noticed that running all 317 input files on
+your laptop, even with 4 tasks a time, is not very efficient.
+TODO : In the next example, instead of running locally, we will use a cluster called midway at the University of Chicago to improve performance.
+.modis03.swift
+type file;
+type imagefile;
+type landuse;
+app (file output, file tilelist) analyzeLandUse (landuse input[], string usetype, int ma\
+xnum)
+ analyzelanduse @output @tilelist usetype maxnum @input;
+int nSelect = @toInt(@arg("nselect", "10"));
+string landType = @arg("landtype", "urban");
+# Input Dataset
+Files>;
+# Find the top N tiles (by total area of selected landuse types)
+file topSelected <"topselected.txt">;
+file selectedTiles <"selectedtiles.txt">;
+(topSelected, selectedTiles) = analyzeLandUse(land, landType, nSelect);
+To run modis03.swift
+$ cd modis/modis03/
+$ swift modis03.swift
+modis04 - Mark the top N tiles on a map
+The fourth modis example adds another app called markMap that looks at selectedtiles.txt
+and highlights the selected areas on a map. It will create a new image called
+gridmap.png which marks the top N tiles on a sinusoidal gridded map.
+.modis04.swift
+type file;
+type imagefile;
+type landuse;
+xnum)
+app (imagefile grid) markMap (file tilelist)
+ markmap @tilelist @grid;
+# Input Dataset
+Files>;
+landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@s\
+trcat("landuse/\\1.landuse.byfreq")>;
+# Mark the top N tiles on a sinusoidal gridded map
+imagefile gridmap <"gridmap.png">;
+gridmap = markMap(topSelected);
+To run modis04.swift
+$ cd modis/modis04/
+$ swift modis04.swift
+modis05 - Create multi-color tile images
+The fifth modis example extends the previous examples by adding the colorModis app
+to create multi-color images for all tiles.
+.modis05.swift
+type file;
+type imagefile;
+type landuse;
+app (file output, file tilelist) analyzeLandUse (landuse input[], string usetype, int maxnum)
+app (imagefile output) colorModis (imagefile input)
+ colormodis @input @output;
+# Input Dataset
+imagefile geos[] <ext; exec="../bin/modis.mapper", location=MODISdir, suffix=".rgb", n=nFiles>;
+landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("landuse/\\1.landuse.byfreq")>;
+# Create multi-color images for all tiles
+imagefile colorImage[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("colorImages/\\1.color.rgb")>;
+foreach g, i in geos {
+ colorImage[i] = colorModis(g);
+To run modis05.swift:
+$ cd modis/modis05/
+$ swift modis05.swift
Added: SwiftTutorials/CIC_2013-08-09/build_docs.sh
--- SwiftTutorials/CIC_2013-08-09/build_docs.sh (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/build_docs.sh 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,11 @@
+#!/bin/bash -e
+pushd part11-swift-py-r/code >& /dev/null
+# Strip comments, blank lines; prepend shell prompt ($)
+grep -A 20 stc run-dets.sh | \
+ grep -v -e "^$\|#" | \
+ sed 's/^/$ /' > run-dets.sh.txt
+popd >& /dev/null
+~davidk/asciidoc-8.6.4/asciidoc -a toc -a toplevels=2 -a stylesheet=~davidk/swift-0.94/cog/modules/swift/docs/stylesheets/asciidoc.css -a max-width=800px -o tutorial.html README
Property changes on: SwiftTutorials/CIC_2013-08-09/build_docs.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftTutorials/CIC_2013-08-09/logs/coaster.log
--- SwiftTutorials/CIC_2013-08-09/logs/coaster.log (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/logs/coaster.log 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,3 @@
+Error occurred during initialization of VM
+Could not reserve enough space for object heap
+Could not create the Java virtual machine.
Added: SwiftTutorials/CIC_2013-08-09/p1.png
(Binary files differ)
Property changes on: SwiftTutorials/CIC_2013-08-09/p1.png
Added: svn:mime-type
+ application/octet-stream
Added: SwiftTutorials/CIC_2013-08-09/p2.png
Property changes on: SwiftTutorials/CIC_2013-08-09/p2.png
Added: SwiftTutorials/CIC_2013-08-09/p3.png
Property changes on: SwiftTutorials/CIC_2013-08-09/p3.png
Added: SwiftTutorials/CIC_2013-08-09/p4.png
Property changes on: SwiftTutorials/CIC_2013-08-09/p4.png
Added: SwiftTutorials/CIC_2013-08-09/p5.png
Property changes on: SwiftTutorials/CIC_2013-08-09/p5.png
Added: SwiftTutorials/CIC_2013-08-09/p6.png
Property changes on: SwiftTutorials/CIC_2013-08-09/p6.png
Added: SwiftTutorials/CIC_2013-08-09/p7.png
Property changes on: SwiftTutorials/CIC_2013-08-09/p7.png
Added: SwiftTutorials/CIC_2013-08-09/p8.png
Property changes on: SwiftTutorials/CIC_2013-08-09/p8.png
Added: SwiftTutorials/CIC_2013-08-09/p9.png
Property changes on: SwiftTutorials/CIC_2013-08-09/p9.png
Added: SwiftTutorials/CIC_2013-08-09/push.sh
--- SwiftTutorials/CIC_2013-08-09/push.sh (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/push.sh 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,8 @@
+#! /bin/sh
+www=/ci/www/projects/swift/ATPESC
+cp --backup=numbered tutorial.html $www
+cp --backup=numbered *.png $www
+chmod g+w,a+r $www/tutorial.html $www/*png
+ls -l $www
Property changes on: SwiftTutorials/CIC_2013-08-09/push.sh
Added: SwiftTutorials/CIC_2013-08-09/setup.bak.sh
--- SwiftTutorials/CIC_2013-08-09/setup.bak.sh (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/setup.bak.sh 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,51 @@
+export SWIFT_HEAP_MAX=4G
+if which swift >& /dev/null; then
+else
+ echo "Trying to load swift module:"
+ module load swift
+ if which swift >& /dev/null; then
+ Swift loaded from module
+ else
+ echo "Cant find a swift to run"
+ return
+ fi
+fi
+echo -e "\\nUsing swift release from: \\c"
+which swift
+swift -version
+DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
+echo Adding $DIR to PATH:
+PATH=$DIR:$PATH
+if [ -e $HOME/.swift ]; then
+ savedotswift=$(mktemp -d $HOME/.swift.save.XXXX)
+ echo Saving $HOME/.swift in $savedotswift
+ mv $HOME/.swift/* $savedotswift
+else
+ mkdir -p $HOME/.swift
+fi
+cat >>$HOME/.swift/swift.properties <<END
+# Properties for Swift Tutorial
+sites.file=sites.xml
+tc.file=apps
+wrapperlog.always.transfer=true
+sitedir.keep=true
+file.gc.enabled=false
+status.mode=provider
+execution.retries=0
+lazy.errors=false
+use.wrapper.staging=false
+use.provider.staging=true
+provider.staging.pin.swiftfiles=true
+END
Property changes on: SwiftTutorials/CIC_2013-08-09/setup.bak.sh
Added: SwiftTutorials/CIC_2013-08-09/setup.sh
--- SwiftTutorials/CIC_2013-08-09/setup.sh (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/setup.sh 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,71 @@
+#The following line sets the default site
+site="uc3"
+declare -a SITE_SPECIFIC=("part07 part08 part09 modis/modis01 modis/modis02 modis/modis03 modis/modis04 modis/modis05 modis/modis06");
+site_setup()
+ SITEPATH="site_catalog/$1"
+ if [ -x "$SITEPATH/setup.sh" ]; then
+ echo "Sourcing site specific setup"
+ source ./$SITEPATH/setup.sh
+ fi
+ if [ -f "$SITEPATH/sites.xml" ]; then
+ for tutorial in ${SITE_SPECIFIC[*]}
+ do
+ cp "$SITEPATH/sites.xml" $tutorial/
+ done
+ fi
+ if [ -f "$SITEPATH/apps" ]; then
+ do
+ cp "$SITEPATH/apps" $tutorial/
+ done
+ fi
+if [ ! -z $1 ]; then
+ if [ -d "site_catalog/$1" ]; then
+ site="$1"
+ else
+ echo "Requested site not present in catalog: Setting to default site"
+ fi
+fi
+echo "Site selected : $site"
+site_setup $site
+# Setting scripts folder to the PATH env var.
+PATH=$DIR:$PATH
+# Setting .swift files
+else
+fi
+tc.file=apps
+sitedir.keep=true
+lazy.errors=false
+END
Property changes on: SwiftTutorials/CIC_2013-08-09/setup.sh
Added: SwiftTutorials/CIC_2013-08-09/setup.sh~
--- SwiftTutorials/CIC_2013-08-09/setup.sh~ (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/setup.sh~ 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,71 @@
+site="uc3"
+declare -a SITE_SPECIFIC=("part07 part08 part09");
+site_setup()
+ fi
+ do
+ done
+ fi
+ do
+ done
+ fi
+ site="$1"
+ else
+ fi
+fi
+site_setup $site
+PATH=$DIR:$PATH
+else
+fi
+tc.file=apps
+sitedir.keep=true
+lazy.errors=false
+END
Property changes on: SwiftTutorials/CIC_2013-08-09/setup.sh~
Added: SwiftTutorials/CIC_2013-08-09/simulate.sh
--- SwiftTutorials/CIC_2013-08-09/simulate.sh (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/simulate.sh 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,23 @@
+#! /bin/bash
+runtime=${1:-0}
+range=${2:-100}
+biasfile=${3:-nobias}
+scale=${4:-1}
+n=${5:-1}
+if [ $biasfile = nobias ]; then
+ offset=0
+else
+ read offset <$biasfile
+fi
+# run for some number of "timesteps"
+sleep $runtime
+# emit n "simulation results", scaled and biased by the specified argument values
+for ((i=0;i<n;i++)); do
+ echo $(( ($RANDOM%range)*scale+offset))
+done
Property changes on: SwiftTutorials/CIC_2013-08-09/simulate.sh
Added: SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/apps
--- SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/apps (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/apps 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,8 @@
+persistent-coasters echo echo
+persistent-coasters sh /bin/bash
+persistent-coasters cat cat
+persistent-coasters random /root/cloud/bin/random.sh
+persistent-coasters average /root/cloud/bin/avg.sh
+persistent-coasters randpl /root/cloud/bin/random.pl
+persistent-coasters calcpi /root/cloud/bin/pi.sh
Added: SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cf
--- SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cf (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cf 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,6 @@
+wrapperlog.always.transfer=false
+execution.retries=10
+provider.staging.pin.swiftfiles=false
+sitedir.keep=false
Added: SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/coaster-service.conf
--- SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/coaster-service.conf (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/coaster-service.conf 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,47 @@
+#Location of SWIFT. If empty, PATH is referenced
+ export SWIFT=
+ # Where to place/launch worker.pl on the remote machine for sites.xml
+ export WORKER_LOCATION=/root
+ # How to launch workers: local, ssh, or cobalt
+ export WORKER_MODE=ssh
+ # Worker logging setting passed to worker.pl for sites.xml
+ export WORKER_LOGGING_LEVEL=DEBUG
+ export SSH_TUNNELING=yes
+ # User name to use for all systems
+ export WORKER_USERNAME=root
+ # Worker host names for ssh
+# export WORKER_HOSTS="crush thwomp stomp crank grind churn trounce thrash vanquish"
+#export WORKER_HOSTS="ip-10-36-196-96.eu-west-1.compute.internal ip-10-36-195-69.eu-west-1.compute.internal"
+ # Directory to keep log files, relative to working directory when launching start-coaster-service
+ export LOG_DIR=logs
+ export WORKER_LOG_DIR=/root
+ # Manually define ports. If not specified, ports will be automatically generated
+ #export LOCAL_PORT=50100
+ #export SERVICE_PORT=50200
+ # Set shared filesystem to no since work will be done in local /sandbox directory
+ export SHARED_FILESYSTEM=no
+ # start-coaster-service tries to automatically detect IP address.
+ # Specify here if auto detection is not working correctly
+ export IPADDR=
+ # Below are various settings to give information about how to create sites.xml
+ export WORK=/tmp/ketan
+ export JOBS_PER_NODE=8
+ export JOBSPERNODE=8
+ export JOBTHROTTLE=$( echo "scale=5; ($JOBS_PER_NODE * $( echo $WORKER_HOSTS | wc -w ))/100 - 0.00001"|bc )
+ # Swift applications
+ #app cat=/bin/cat
+ #app bash=/bin/bash
+ #app echo=/bin/echo
Added: SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_13-28-48.log
--- SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_13-28-48.log (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_13-28-48.log 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,248 @@
+2013-08-09 13:28:48,906-0500 INFO Settings Local contacts: [http://128.135.158.243:50175, http://10.1.3.94:50175]
+2013-08-09 13:28:48,918-0500 INFO BlockQueueProcessor Starting... id=0809-2801480
+2013-08-09 13:28:48,918-0500 INFO CoasterService Started local service: http://128.135.158.243:50175
+2013-08-09 13:28:48,918-0500 INFO CoasterService Started coaster service: http://128.135.158.243:36052
+2013-08-09 13:29:33,488-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 13:29:33,530-0500 INFO LocalTCPService Received registration: blockid = 54.212.81.224, url = ip-10-224-24-142
+2013-08-09 13:29:33,539-0500 INFO MetaChannel MetaChannel[worker-1] -> null bind -> TCP-null
+2013-08-09 13:29:33,541-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=0
+2013-08-09 13:29:33,542-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=0
+2013-08-09 13:29:33,543-0500 INFO Block Started CPU 0:1376072973s
+2013-08-09 13:29:33,543-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=0 Cpus sleeping: 1
+2013-08-09 13:29:33,543-0500 INFO Block Started worker 54.212.81.224:000000
+2013-08-09 13:29:33,543-0500 INFO AbstractStreamKarajanChannel Using NIO sender for TCP-54.212.81.224-000000
+2013-08-09 13:29:33,544-0500 DEBUG Cpu 54.212.81.224:0 sleeping
+2013-08-09 13:29:33,548-0500 INFO RequestHandler Handler(tag: 1764, REGISTER) unregistering (send)
+2013-08-09 13:29:35,267-0500 INFO TCPBufferManager Adjusting buffer size to 8650752 for 2 sockets
+2013-08-09 13:29:35,268-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 13:29:35,325-0500 INFO LocalTCPService Received registration: blockid = 54.244.171.51, url = ip-10-251-21-212
+2013-08-09 13:29:35,325-0500 INFO MetaChannel MetaChannel[worker-2] -> null bind -> TCP-null
+2013-08-09 13:29:35,325-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=0
+2013-08-09 13:29:35,325-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=0
+2013-08-09 13:29:35,325-0500 INFO Block Started CPU 0:1376072975s
+2013-08-09 13:29:35,326-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=0 Cpus sleeping: 2
+2013-08-09 13:29:35,326-0500 INFO Block Started worker 54.244.171.51:000000
+2013-08-09 13:29:35,326-0500 DEBUG Cpu 54.244.171.51:0 sleeping
+2013-08-09 13:29:35,326-0500 INFO RequestHandler Handler(tag: 3750, REGISTER) unregistering (send)
+2013-08-09 13:29:37,531-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 13:29:37,591-0500 INFO LocalTCPService Received registration: blockid = 54.212.37.161, url = ip-10-250-62-33
+2013-08-09 13:29:37,591-0500 INFO MetaChannel MetaChannel[worker-3] -> null bind -> TCP-null
+2013-08-09 13:29:37,591-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=0
+2013-08-09 13:29:37,592-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=0
+2013-08-09 13:29:37,592-0500 INFO Block Started CPU 0:1376072977s
+2013-08-09 13:29:37,592-0500 INFO Block Started worker 54.212.37.161:000000
+2013-08-09 13:29:37,592-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=0 Cpus sleeping: 3
+2013-08-09 13:29:37,592-0500 DEBUG Cpu 54.212.37.161:0 sleeping
+2013-08-09 13:29:37,592-0500 INFO RequestHandler Handler(tag: 1610, REGISTER) unregistering (send)
+2013-08-09 13:30:07,021-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -56ms, rtt: 114ms
+2013-08-09 13:30:10,678-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -114ms, rtt: 121ms
+2013-08-09 13:30:12,877-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -10ms, rtt: 122ms
+2013-08-09 13:30:40,185-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -63ms, rtt: 155ms
+2013-08-09 13:30:41,965-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -109ms, rtt: 161ms
+2013-08-09 13:30:51,767-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -18ms, rtt: 161ms
+2013-08-09 13:31:13,213-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -117ms, rtt: 162ms
+2013-08-09 13:31:13,320-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -69ms, rtt: 164ms
+2013-08-09 13:31:30,620-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -13ms, rtt: 162ms
+2013-08-09 13:31:44,459-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -112ms, rtt: 161ms
+2013-08-09 13:31:46,446-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -62ms, rtt: 164ms
+2013-08-09 13:32:09,471-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -21ms, rtt: 162ms
+2013-08-09 13:32:15,738-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -104ms, rtt: 192ms
+2013-08-09 13:32:19,565-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -71ms, rtt: 157ms
+2013-08-09 13:32:46,955-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -115ms, rtt: 161ms
+2013-08-09 13:32:48,322-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -29ms, rtt: 162ms
+2013-08-09 13:32:52,690-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -67ms, rtt: 156ms
+2013-08-09 13:33:18,215-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -121ms, rtt: 174ms
+2013-08-09 13:33:25,815-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -74ms, rtt: 155ms
+2013-08-09 13:33:27,172-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -23ms, rtt: 161ms
+2013-08-09 13:33:49,455-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -118ms, rtt: 167ms
+2013-08-09 13:33:58,940-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -70ms, rtt: 154ms
+2013-08-09 13:34:06,023-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -32ms, rtt: 161ms
+2013-08-09 13:34:20,697-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -126ms, rtt: 162ms
+2013-08-09 13:34:32,070-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -77ms, rtt: 158ms
+2013-08-09 13:34:44,874-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -40ms, rtt: 161ms
+2013-08-09 13:34:51,943-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -121ms, rtt: 161ms
+2013-08-09 13:35:05,193-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -72ms, rtt: 154ms
+2013-08-09 13:35:23,200-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -130ms, rtt: 170ms
+2013-08-09 13:35:23,725-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -35ms, rtt: 161ms
+2013-08-09 13:35:38,319-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -79ms, rtt: 154ms
+2013-08-09 13:35:54,438-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -124ms, rtt: 160ms
+2013-08-09 13:36:02,576-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -42ms, rtt: 161ms
+2013-08-09 13:36:11,446-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -87ms, rtt: 155ms
+2013-08-09 13:36:25,684-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -133ms, rtt: 160ms
+2013-08-09 13:36:41,427-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -37ms, rtt: 161ms
+2013-08-09 13:36:44,571-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -82ms, rtt: 154ms
+2013-08-09 13:36:56,931-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -140ms, rtt: 160ms
+2013-08-09 13:37:17,697-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -89ms, rtt: 154ms
+2013-08-09 13:37:20,278-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -45ms, rtt: 161ms
+2013-08-09 13:37:28,179-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -135ms, rtt: 161ms
+2013-08-09 13:37:50,824-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -84ms, rtt: 155ms
+2013-08-09 13:37:59,145-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -53ms, rtt: 177ms
+2013-08-09 13:37:59,436-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -144ms, rtt: 170ms
+2013-08-09 13:38:23,949-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -91ms, rtt: 154ms
+2013-08-09 13:38:30,674-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -138ms, rtt: 161ms
+2013-08-09 13:38:37,981-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -48ms, rtt: 162ms
+2013-08-09 13:38:57,075-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -86ms, rtt: 154ms
+2013-08-09 13:39:01,922-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -146ms, rtt: 162ms
+2013-08-09 13:39:16,831-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -55ms, rtt: 161ms
+2013-08-09 13:39:30,215-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -93ms, rtt: 168ms
+2013-08-09 13:39:33,168-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -142ms, rtt: 161ms
+2013-08-09 13:39:55,682-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -64ms, rtt: 161ms
+2013-08-09 13:40:03,328-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -88ms, rtt: 155ms
+2013-08-09 13:40:04,415-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -149ms, rtt: 161ms
+2013-08-09 13:40:34,533-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -59ms, rtt: 161ms
+2013-08-09 13:40:35,662-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -145ms, rtt: 161ms
+2013-08-09 13:40:36,453-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -96ms, rtt: 154ms
+2013-08-09 13:41:06,909-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -152ms, rtt: 161ms
+2013-08-09 13:41:09,580-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -103ms, rtt: 155ms
+2013-08-09 13:41:13,384-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -66ms, rtt: 161ms
+2013-08-09 13:41:38,156-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -148ms, rtt: 161ms
+2013-08-09 13:41:42,706-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -98ms, rtt: 155ms
+2013-08-09 13:41:52,235-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -75ms, rtt: 161ms
+2013-08-09 13:42:09,403-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -156ms, rtt: 160ms
+2013-08-09 13:42:15,831-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -106ms, rtt: 154ms
+2013-08-09 13:42:31,086-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -69ms, rtt: 161ms
+2013-08-09 13:42:40,651-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -150ms, rtt: 161ms
+2013-08-09 13:42:48,958-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -100ms, rtt: 155ms
+2013-08-09 13:43:09,938-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -77ms, rtt: 161ms
+2013-08-09 13:43:11,899-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -159ms, rtt: 162ms
+2013-08-09 13:43:22,106-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -107ms, rtt: 177ms
+2013-08-09 13:43:43,154-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 30ms, rtt: 170ms
+2013-08-09 13:43:48,788-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -84ms, rtt: 161ms
+2013-08-09 13:43:55,209-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -102ms, rtt: 154ms
+2013-08-09 13:44:14,393-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 36ms, rtt: 161ms
+2013-08-09 13:44:27,640-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -80ms, rtt: 161ms
+2013-08-09 13:44:28,336-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -109ms, rtt: 155ms
+2013-08-09 13:44:45,640-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 27ms, rtt: 161ms
+2013-08-09 13:45:01,462-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -104ms, rtt: 155ms
+2013-08-09 13:45:06,502-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -88ms, rtt: 172ms
+2013-08-09 13:45:16,887-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 32ms, rtt: 161ms
+2013-08-09 13:45:34,590-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: -111ms, rtt: 156ms
+2013-08-09 13:45:45,342-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -96ms, rtt: 160ms
+2013-08-09 13:45:48,133-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 24ms, rtt: 160ms
+2013-08-09 13:46:19,342-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 16ms, rtt: 120ms
+2013-08-09 13:46:24,158-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -90ms, rtt: 126ms
+2013-08-09 13:46:40,687-0500 INFO AbstractKarajanChannel Channel config: null
+2013-08-09 13:46:40,688-0500 INFO ChannelManager TCP-54.244.171.51-000000 handling channel exception
+java.io.IOException: Broken pipe
+ at sun.nio.ch.FileDispatcher.write0(Native Method)
+ at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:29)
+ at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:69)
+ at sun.nio.ch.IOUtil.write(IOUtil.java:40)
+ at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:336)
+ at org.globus.cog.karajan.workflow.service.channels.NIOSender.write(NIOSender.java:168)
+ at org.globus.cog.karajan.workflow.service.channels.NIOSender.run(NIOSender.java:133)
+2013-08-09 13:46:40,690-0500 INFO AbstractTCPChannel 54.244.171.51-000000: Channel shut down
+2013-08-09 13:46:40,691-0500 INFO MetaChannel MetaChannel[worker-2] -> TCP-54.244.171.51-000000 bind -> NullChannel
+2013-08-09 13:46:40,691-0500 INFO AbstractStreamKarajanChannel Using threaded sender for TCP-54.244.171.51-000000
+2013-08-09 13:46:40,691-0500 INFO ChannelContext Notifying commands and handlers about exception
+2013-08-09 13:46:40,692-0500 INFO ChannelContext => Command(tag: 31, HEARTBEAT)
+2013-08-09 13:46:40,692-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 13:46:40,692-0500 INFO ChannelContext => Command(tag: 30, HEARTBEAT)
+2013-08-09 13:46:40,693-0500 INFO ChannelManager Channel exception handled
+2013-08-09 13:46:40,693-0500 INFO AbstractTCPChannel 54.244.171.51-000000: Channel shut down
+2013-08-09 13:46:50,630-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 21ms, rtt: 162ms
+2013-08-09 13:47:03,044-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -99ms, rtt: 161ms
+2013-08-09 13:47:21,877-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 14ms, rtt: 162ms
+2013-08-09 13:47:35,269-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-134534.589, now=130809-134735.269, channel=TCP-54.244.171.51-000000
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.checkTimeouts(AbstractKarajanChannel.java:130)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel$1.run(AbstractKarajanChannel.java:121)
+ at java.util.TimerThread.mainLoop(Timer.java:512)
+ at java.util.TimerThread.run(Timer.java:462)
+2013-08-09 13:47:35,269-0500 INFO ChannelContext => Command(tag: 31, HEARTBEAT)
+2013-08-09 13:47:35,269-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 13:47:35,270-0500 INFO ChannelContext => Command(tag: 30, HEARTBEAT)
+2013-08-09 13:47:35,270-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 13:47:35,270-0500 INFO AbstractKarajanChannel Channel config: null
+2013-08-09 13:47:35,270-0500 INFO ChannelManager TCP-54.244.171.51-000000 handling channel exception
+2013-08-09 13:47:35,271-0500 INFO ChannelManager Channel already shut down
+2013-08-09 13:47:35,271-0500 INFO AbstractTCPChannel 54.244.171.51-000000: Channel shut down
+2013-08-09 13:47:41,895-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -94ms, rtt: 160ms
+2013-08-09 13:47:53,122-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 18ms, rtt: 160ms
+2013-08-09 13:48:20,748-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -102ms, rtt: 161ms
+2013-08-09 13:48:24,371-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 11ms, rtt: 162ms
+2013-08-09 13:48:55,618-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 16ms, rtt: 161ms
+2013-08-09 13:48:59,598-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -109ms, rtt: 161ms
+2013-08-09 13:49:26,918-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 7ms, rtt: 214ms
+2013-08-09 13:49:38,449-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -104ms, rtt: 161ms
+2013-08-09 13:49:58,114-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 13ms, rtt: 163ms
+2013-08-09 13:50:17,300-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -111ms, rtt: 161ms
+2013-08-09 13:50:29,361-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 4ms, rtt: 163ms
+2013-08-09 13:50:56,151-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -120ms, rtt: 161ms
+2013-08-09 13:51:00,626-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 9ms, rtt: 181ms
+2013-08-09 13:51:31,853-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 2ms, rtt: 161ms
+2013-08-09 13:51:34,903-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -115ms, rtt: 62ms
+2013-08-09 13:52:03,100-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 6ms, rtt: 161ms
+2013-08-09 13:52:13,873-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -122ms, rtt: 181ms
+2013-08-09 13:52:34,249-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -2ms, rtt: 61ms
+2013-08-09 13:52:52,704-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -131ms, rtt: 160ms
+2013-08-09 13:53:05,596-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 4ms, rtt: 162ms
+2013-08-09 13:53:31,556-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -125ms, rtt: 161ms
+2013-08-09 13:53:36,842-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -5ms, rtt: 160ms
+2013-08-09 13:54:08,091-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: 0ms, rtt: 162ms
+2013-08-09 13:54:10,308-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -133ms, rtt: 62ms
+2013-08-09 13:54:39,238-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -7ms, rtt: 62ms
+2013-08-09 13:54:49,258-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -141ms, rtt: 161ms
+2013-08-09 13:55:10,584-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -3ms, rtt: 161ms
+2013-08-09 13:55:12,357-0500 INFO BlockQueueProcessor Shutting down blocks
+2013-08-09 13:55:12,358-0500 INFO Block Shutting down block Block 54.212.37.161 (1x4611686018427388.000s)
+2013-08-09 13:55:12,358-0500 INFO Block Adding short shutdown watchdog: count = 1, workers = 1, now = true
+2013-08-09 13:55:12,359-0500 INFO Block Shutting down block Block 54.212.81.224 (1x4611686018427388.000s)
+2013-08-09 13:55:12,359-0500 INFO Block Adding short shutdown watchdog: count = 1, workers = 1, now = true
+2013-08-09 13:55:12,359-0500 INFO Block Shutting down block Block 54.244.171.51 (1x4611686018427388.000s)
+2013-08-09 13:55:12,359-0500 INFO Node Failed to shut down worker
+org.globus.cog.karajan.workflow.service.channels.ChannelException: Channel died and no contact available
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.connect(ChannelManager.java:234)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:255)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:226)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Node.getChannel(Node.java:135)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Node.shutdown(Node.java:87)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Cpu.shutdown(Cpu.java:289)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Block.shutdown(Block.java:283)
+ at org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdownBlocks(BlockQueueProcessor.java:800)
+ at org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdown(BlockQueueProcessor.java:789)
+ at org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.shutdown(JobQueue.java:119)
+ at org.globus.cog.abstraction.coaster.service.CoasterService.shutdown(CoasterService.java:271)
+ at org.globus.cog.abstraction.coaster.service.CoasterPersistentService$2.run(CoasterPersistentService.java:236)
+2013-08-09 13:55:12,360-0500 INFO Block Adding short shutdown watchdog: count = 1, workers = 1, now = true
+2013-08-09 13:55:12,360-0500 INFO CoasterService Shutdown sequence completed
Added: SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_13-56-29.log
--- SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_13-56-29.log (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/site_catalog/cloud/cps-2013-08-09_13-56-29.log 2013-08-09 20:48:19 UTC (rev 6820)
@@ -0,0 +1,29985 @@
+2013-08-09 13:56:29,776-0500 INFO Settings Local contacts: [http://128.135.158.243:48483, http://10.1.3.94:48483]
+2013-08-09 13:56:29,788-0500 INFO BlockQueueProcessor Starting... id=0809-5601290
+2013-08-09 13:56:29,788-0500 INFO CoasterService Started local service: http://128.135.158.243:48483
+2013-08-09 13:56:29,789-0500 INFO CoasterService Started coaster service: http://128.135.158.243:46867
+2013-08-09 13:56:46,520-0500 INFO Multiplexer Multiplexer 0 started
+2013-08-09 13:56:46,520-0500 INFO Multiplexer Multiplexer 1 started
+2013-08-09 13:56:46,520-0500 INFO Multiplexer (0) Scheduling TCP-null for addition
+2013-08-09 13:56:46,521-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 13:56:46,544-0500 INFO ChannelConfigurationHandler Channel id: u-667342fe-140647027b2--8000-u63ed4446-140647027d0--8000
+2013-08-09 13:56:46,549-0500 INFO MetaChannel MetaChannel[cps-38181] -> null bind -> TCP-null
+2013-08-09 13:56:46,550-0500 INFO AbstractStreamKarajanChannel Using threaded sender for TCP-null
+2013-08-09 13:56:46,551-0500 INFO RequestHandler Handler(tag: 1, CHANNELCONFIG) unregistering (send)
+2013-08-09 13:56:46,613-0500 INFO RequestHandler Handler(tag: 2, CONFIGSERVICE) unregistering (send)
+2013-08-09 13:56:46,729-0500 INFO RequestHandler Handler(tag: 3, SUBMITJOB) unregistering (send)
+2013-08-09 13:56:56,523-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:56:56,726-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:57:03,060-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 13:57:03,119-0500 INFO LocalTCPService Received registration: blockid = 54.212.81.224, url = ip-10-224-24-142
+2013-08-09 13:57:03,122-0500 INFO MetaChannel MetaChannel[worker-1] -> null bind -> TCP-null
+2013-08-09 13:57:03,125-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=0
+2013-08-09 13:57:03,125-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=0
+2013-08-09 13:57:03,126-0500 INFO Block Started CPU 0:1376074623s
+2013-08-09 13:57:03,126-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=1
+2013-08-09 13:57:03,127-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=1
+2013-08-09 13:57:03,127-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=0 Cpus sleeping: 1
+2013-08-09 13:57:03,127-0500 INFO Block Started CPU 1:1376074623s
+2013-08-09 13:57:03,127-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=2
+2013-08-09 13:57:03,127-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=2
+2013-08-09 13:57:03,127-0500 INFO Block Started CPU 2:1376074623s
+2013-08-09 13:57:03,127-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=3
+2013-08-09 13:57:03,127-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=3
+2013-08-09 13:57:03,127-0500 INFO Block Started CPU 3:1376074623s
+2013-08-09 13:57:03,128-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=4
+2013-08-09 13:57:03,128-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=4
+2013-08-09 13:57:03,128-0500 INFO Block Started CPU 4:1376074623s
+2013-08-09 13:57:03,128-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=5
+2013-08-09 13:57:03,128-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=5
+2013-08-09 13:57:03,128-0500 INFO Block Started CPU 5:1376074623s
+2013-08-09 13:57:03,128-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=6
+2013-08-09 13:57:03,128-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=6
+2013-08-09 13:57:03,128-0500 INFO Block Started CPU 6:1376074623s
+2013-08-09 13:57:03,129-0500 DEBUG Cpu worker started: block=54.212.81.224 host=ip-10-224-24-142 id=7
+2013-08-09 13:57:03,129-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=7
+2013-08-09 13:57:03,129-0500 INFO Block Started CPU 7:1376074623s
+2013-08-09 13:57:03,129-0500 INFO Block Started worker 54.212.81.224:000000
+2013-08-09 13:57:03,130-0500 INFO Cpu 54.212.81.224:0 (quality: 1.0) submitting urn:1376074605942-1376074606719-1376074606720: /bin/bash _swiftwrap.staging -e /bin/echo -out stdout.txt -err stderr.txt -i -d -if -of -k -cdmfile -status provider -a hi
+2013-08-09 13:57:03,130-0500 INFO Sender Sender TCPChannel queue size: 0
+2013-08-09 13:57:03,131-0500 INFO AbstractStreamKarajanChannel Using NIO sender for TCP-54.212.81.224-000000
+2013-08-09 13:57:03,132-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074605942-1376074606719-1376074606720) Submitting
+2013-08-09 13:57:03,136-0500 INFO RequestHandler Handler(tag: 4035, REGISTER) unregistering (send)
+2013-08-09 13:57:03,137-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=1 Cpus sleeping: 1
+2013-08-09 13:57:03,137-0500 DEBUG Cpu 54.212.81.224:1 sleeping
+2013-08-09 13:57:03,137-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=2 Cpus sleeping: 2
+2013-08-09 13:57:03,137-0500 DEBUG Cpu 54.212.81.224:2 sleeping
+2013-08-09 13:57:03,137-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=3 Cpus sleeping: 3
+2013-08-09 13:57:03,137-0500 DEBUG Cpu 54.212.81.224:3 sleeping
+2013-08-09 13:57:03,137-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=4 Cpus sleeping: 4
+2013-08-09 13:57:03,137-0500 DEBUG Cpu 54.212.81.224:4 sleeping
+2013-08-09 13:57:03,138-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=5 Cpus sleeping: 5
+2013-08-09 13:57:03,138-0500 DEBUG Cpu 54.212.81.224:5 sleeping
+2013-08-09 13:57:03,138-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=6 Cpus sleeping: 6
+2013-08-09 13:57:03,138-0500 DEBUG Cpu 54.212.81.224:6 sleeping
+2013-08-09 13:57:03,138-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=7 Cpus sleeping: 7
+2013-08-09 13:57:03,138-0500 DEBUG Cpu 54.212.81.224:7 sleeping
+2013-08-09 13:57:03,336-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074605942-1376074606719-1376074606720) Submitted
+2013-08-09 13:57:03,397-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074605942-1376074606719-1376074606720) Stagein workerid=000000
+2013-08-09 13:57:03,398-0500 INFO RequestHandler Handler(tag: 4036, JOBSTATUS) unregistering (send)
+2013-08-09 13:57:03,399-0500 INFO GetFileHandler Handler(tag: 4037, GET) request complete; src=proxy://u-667342fe-140647027b2--8000-u63ed4446-140647027d0--8000S//usr/local/swift-0.94/bin/../libexec/_swiftwrap.staging
+2013-08-09 13:57:03,420-0500 INFO GetFileHandler Handler(tag: 4037, GET) reader: PR proxy://u-667342fe-140647027b2--8000-u63ed4446-140647027d0--8000S//usr/local/swift-0.94/bin/../libexec/_swiftwrap.staging
+2013-08-09 13:57:03,420-0500 INFO GetFileHandler Handler(tag: 4037, GET) -> 4
+2013-08-09 13:57:03,456-0500 INFO GetFileHandler Handler(tag: 4037, GET) sending length: 6078, 1698873038
+2013-08-09 13:57:03,458-0500 INFO Buffers O allocated buffers: {POW-Command(tag: -1, GET) -> 1} (1)
+2013-08-09 13:57:03,458-0500 INFO GetFileHandler Handler(tag: 4037, GET) unregistering (last)
+2013-08-09 13:57:03,651-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074605942-1376074606719-1376074606720) Active workerid=000000
+2013-08-09 13:57:03,652-0500 INFO RequestHandler Handler(tag: 4038, JOBSTATUS) unregistering (send)
+2013-08-09 13:57:03,716-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074605942-1376074606719-1376074606720) Completed
+2013-08-09 13:57:03,716-0500 INFO Cpu 54.212.81.224:0 jobTerminated
+2013-08-09 13:57:03,716-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=0
+2013-08-09 13:57:03,716-0500 INFO RequestHandler Handler(tag: 4039, JOBSTATUS) unregistering (send)
+2013-08-09 13:57:03,716-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=0 Cpus sleeping: 8
+2013-08-09 13:57:03,717-0500 DEBUG Cpu 54.212.81.224:0 sleeping
+2013-08-09 13:57:03,920-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:03,920-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:57:03,958-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:03,960-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:04,421-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:04,460-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:04,460-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:04,921-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:04,960-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:04,961-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:05,230-0500 INFO TCPBufferManager Adjusting buffer size to 8650752 for 2 sockets
+2013-08-09 13:57:05,230-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 13:57:05,296-0500 INFO LocalTCPService Received registration: blockid = 54.244.171.51, url = ip-10-251-21-212
+2013-08-09 13:57:05,296-0500 INFO MetaChannel MetaChannel[worker-2] -> null bind -> TCP-null
+2013-08-09 13:57:05,296-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=0
+2013-08-09 13:57:05,296-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=0
+2013-08-09 13:57:05,296-0500 INFO Block Started CPU 0:1376074625s
+2013-08-09 13:57:05,296-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=1
+2013-08-09 13:57:05,296-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=1
+2013-08-09 13:57:05,296-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=0 Cpus sleeping: 9
+2013-08-09 13:57:05,296-0500 INFO Block Started CPU 1:1376074625s
+2013-08-09 13:57:05,296-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=2
+2013-08-09 13:57:05,296-0500 DEBUG Cpu 54.244.171.51:0 sleeping
+2013-08-09 13:57:05,297-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=2
+2013-08-09 13:57:05,297-0500 INFO Block Started CPU 2:1376074625s
+2013-08-09 13:57:05,297-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=3
+2013-08-09 13:57:05,297-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=3
+2013-08-09 13:57:05,297-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=1 Cpus sleeping: 10
+2013-08-09 13:57:05,297-0500 INFO Block Started CPU 3:1376074625s
+2013-08-09 13:57:05,297-0500 DEBUG Cpu 54.244.171.51:1 sleeping
+2013-08-09 13:57:05,297-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=4
+2013-08-09 13:57:05,297-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=2 Cpus sleeping: 11
+2013-08-09 13:57:05,297-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=4
+2013-08-09 13:57:05,298-0500 DEBUG Cpu 54.244.171.51:2 sleeping
+2013-08-09 13:57:05,298-0500 INFO Block Started CPU 4:1376074625s
+2013-08-09 13:57:05,298-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=5
+2013-08-09 13:57:05,298-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=3 Cpus sleeping: 12
+2013-08-09 13:57:05,298-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=5
+2013-08-09 13:57:05,298-0500 DEBUG Cpu 54.244.171.51:3 sleeping
+2013-08-09 13:57:05,298-0500 INFO Block Started CPU 5:1376074625s
+2013-08-09 13:57:05,298-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=4 Cpus sleeping: 13
+2013-08-09 13:57:05,298-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=6
+2013-08-09 13:57:05,299-0500 DEBUG Cpu 54.244.171.51:4 sleeping
+2013-08-09 13:57:05,299-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=6
+2013-08-09 13:57:05,299-0500 INFO Block Started CPU 6:1376074625s
+2013-08-09 13:57:05,299-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=5 Cpus sleeping: 14
+2013-08-09 13:57:05,299-0500 DEBUG Cpu worker started: block=54.244.171.51 host=ip-10-251-21-212 id=7
+2013-08-09 13:57:05,299-0500 DEBUG Cpu 54.244.171.51:5 sleeping
+2013-08-09 13:57:05,299-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=7
+2013-08-09 13:57:05,299-0500 INFO Block Started CPU 7:1376074625s
+2013-08-09 13:57:05,299-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=6 Cpus sleeping: 15
+2013-08-09 13:57:05,299-0500 INFO Block Started worker 54.244.171.51:000000
+2013-08-09 13:57:05,299-0500 DEBUG Cpu 54.244.171.51:6 sleeping
+2013-08-09 13:57:05,300-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=7 Cpus sleeping: 16
+2013-08-09 13:57:05,300-0500 INFO RequestHandler Handler(tag: 2474, REGISTER) unregistering (send)
+2013-08-09 13:57:05,300-0500 DEBUG Cpu 54.244.171.51:7 sleeping
+2013-08-09 13:57:05,301-0500 INFO Sender Channel IOException
+java.net.SocketException: Broken pipe
+ at java.net.SocketOutputStream.socketWrite0(Native Method)
+ at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
+ at java.net.SocketOutputStream.write(SocketOutputStream.java:124)
+ at org.globus.cog.karajan.workflow.service.channels.Sender.send(Sender.java:130)
+ at org.globus.cog.karajan.workflow.service.channels.Sender.run(Sender.java:66)
+2013-08-09 13:57:05,302-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 13:57:05,302-0500 INFO ChannelManager TCP-null handling channel exception
+2013-08-09 13:57:05,313-0500 INFO AbstractTCPChannel null: Channel shut down
+2013-08-09 13:57:05,313-0500 INFO Multiplexer Exception in channel step
+java.io.IOException: Stream closed.
+ at java.net.PlainSocketImpl.available(PlainSocketImpl.java:452)
+ at java.net.SocketInputStream.available(SocketInputStream.java:217)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.step(AbstractStreamKarajanChannel.java:105)
+ at org.globus.cog.karajan.workflow.service.channels.Multiplexer.run(Multiplexer.java:70)
+2013-08-09 13:57:05,313-0500 INFO MetaChannel MetaChannel[cps-38181] -> TCP-null bind -> BufferingChannel
+2013-08-09 13:57:05,314-0500 INFO Multiplexer Unregistering channel TCP-null
+2013-08-09 13:57:05,314-0500 INFO ChannelContext Notifying commands and handlers about exception
+2013-08-09 13:57:05,314-0500 INFO ChannelContext => Command(tag: 7, RESOURCEUPDATE)
+2013-08-09 13:57:05,314-0500 INFO ChannelManager Channel exception handled
+2013-08-09 13:57:05,315-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 13:57:05,315-0500 INFO ChannelManager TCP-null handling channel exception
+2013-08-09 13:57:05,315-0500 INFO ChannelManager Channel already shut down
+2013-08-09 13:57:05,315-0500 INFO Multiplexer Removing faulty channel TCP-null
+2013-08-09 13:57:05,421-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:05,461-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:05,461-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:05,922-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:05,961-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:05,962-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:06,422-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:06,462-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:06,462-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:06,524-0500 INFO Multiplexer No streams
+2013-08-09 13:57:06,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:57:06,922-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:06,962-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:06,962-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:07,423-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:07,463-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:07,463-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:07,515-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 13:57:07,575-0500 INFO LocalTCPService Received registration: blockid = 54.212.37.161, url = ip-10-250-62-33
+2013-08-09 13:57:07,575-0500 INFO MetaChannel MetaChannel[worker-3] -> null bind -> TCP-null
+2013-08-09 13:57:07,575-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=0
+2013-08-09 13:57:07,575-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=0
+2013-08-09 13:57:07,575-0500 INFO Block Started CPU 0:1376074627s
+2013-08-09 13:57:07,575-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=1
+2013-08-09 13:57:07,576-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=0 Cpus sleeping: 17
+2013-08-09 13:57:07,576-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=1
+2013-08-09 13:57:07,576-0500 DEBUG Cpu 54.212.37.161:0 sleeping
+2013-08-09 13:57:07,576-0500 INFO Block Started CPU 1:1376074627s
+2013-08-09 13:57:07,576-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=1 Cpus sleeping: 18
+2013-08-09 13:57:07,576-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=2
+2013-08-09 13:57:07,576-0500 DEBUG Cpu 54.212.37.161:1 sleeping
+2013-08-09 13:57:07,576-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=2
+2013-08-09 13:57:07,576-0500 INFO Block Started CPU 2:1376074627s
+2013-08-09 13:57:07,576-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=2 Cpus sleeping: 19
+2013-08-09 13:57:07,576-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=3
+2013-08-09 13:57:07,576-0500 DEBUG Cpu 54.212.37.161:2 sleeping
+2013-08-09 13:57:07,577-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=3
+2013-08-09 13:57:07,577-0500 INFO Block Started CPU 3:1376074627s
+2013-08-09 13:57:07,577-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=3 Cpus sleeping: 20
+2013-08-09 13:57:07,577-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=4
+2013-08-09 13:57:07,577-0500 DEBUG Cpu 54.212.37.161:3 sleeping
+2013-08-09 13:57:07,577-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=4
+2013-08-09 13:57:07,577-0500 INFO Block Started CPU 4:1376074627s
+2013-08-09 13:57:07,577-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=4 Cpus sleeping: 21
+2013-08-09 13:57:07,577-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=5
+2013-08-09 13:57:07,577-0500 DEBUG Cpu 54.212.37.161:4 sleeping
+2013-08-09 13:57:07,577-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=5
+2013-08-09 13:57:07,578-0500 INFO Block Started CPU 5:1376074627s
+2013-08-09 13:57:07,578-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=5 Cpus sleeping: 22
+2013-08-09 13:57:07,578-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=6
+2013-08-09 13:57:07,578-0500 DEBUG Cpu 54.212.37.161:5 sleeping
+2013-08-09 13:57:07,578-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=6
+2013-08-09 13:57:07,578-0500 INFO Block Started CPU 6:1376074627s
+2013-08-09 13:57:07,578-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=6 Cpus sleeping: 23
+2013-08-09 13:57:07,578-0500 DEBUG Cpu worker started: block=54.212.37.161 host=ip-10-250-62-33 id=7
+2013-08-09 13:57:07,578-0500 DEBUG Cpu 54.212.37.161:6 sleeping
+2013-08-09 13:57:07,578-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=7
+2013-08-09 13:57:07,578-0500 INFO Block Started CPU 7:1376074627s
+2013-08-09 13:57:07,579-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=7 Cpus sleeping: 24
+2013-08-09 13:57:07,579-0500 INFO Block Started worker 54.212.37.161:000000
+2013-08-09 13:57:07,579-0500 DEBUG Cpu 54.212.37.161:7 sleeping
+2013-08-09 13:57:07,579-0500 INFO BlockQueueProcessor Failed to send worker status update to client
+ at org.globus.cog.abstraction.coaster.service.job.manager.PassiveQueueProcessor.registrationReceived(PassiveQueueProcessor.java:73)
+ at org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.registrationReceived(JobQueue.java:143)
+ at org.globus.cog.abstraction.coaster.service.LocalTCPService.registrationReceived(LocalTCPService.java:76)
+ at org.globus.cog.abstraction.coaster.service.local.RegistrationHandler.requestComplete(RegistrationHandler.java:59)
+ at org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:524)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.stepNIO(AbstractStreamKarajanChannel.java:238)
+ at org.globus.cog.karajan.workflow.service.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
+ at org.globus.cog.karajan.workflow.service.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
+2013-08-09 13:57:07,580-0500 INFO RequestHandler Handler(tag: 1379, REGISTER) unregistering (send)
+2013-08-09 13:57:07,923-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:07,963-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:07,963-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:08,424-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:08,464-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:08,464-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:08,924-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:08,964-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:08,964-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:09,424-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:09,464-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:09,465-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:09,925-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:09,965-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:09,965-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:10,425-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:10,465-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:10,465-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:10,925-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:10,966-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:10,966-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:11,425-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:11,466-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:11,466-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:11,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:11,967-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:11,967-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:12,426-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:12,467-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:12,467-0500 INFO ThrottleManager mem=56.7 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:12,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:57:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:57:12,967-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:12,968-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:13,427-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:13,468-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:13,468-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:13,468-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:57:13,927-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:13,927-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:57:13,968-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:13,968-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:14,428-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:14,469-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:14,469-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:14,928-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:14,969-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:14,969-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:15,428-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:15,470-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:15,470-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:15,929-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:15,970-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:15,970-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:16,429-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:16,471-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:16,471-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:16,537-0500 INFO Multiplexer No streams
+2013-08-09 13:57:16,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:57:16,929-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:16,971-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:16,971-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:17,430-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:17,472-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:17,472-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:17,930-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:17,972-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:17,972-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:18,430-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:18,473-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:18,473-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:18,931-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:18,973-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:18,973-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:19,431-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:19,474-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:19,474-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:19,931-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:19,974-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:19,974-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:20,432-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:20,474-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:20,475-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:20,932-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:20,975-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:20,975-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:21,432-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:21,475-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:21,476-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:21,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:21,976-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:21,976-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:22,433-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:22,476-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:22,477-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:22,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:57:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:57:22,977-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:22,977-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:23,434-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:23,477-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:23,477-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:23,478-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:57:23,934-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:23,934-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:57:23,978-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:23,978-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:24,434-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:24,478-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:24,479-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:24,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:24,979-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:24,979-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:25,435-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:25,479-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:25,479-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:25,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:25,980-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:25,980-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:26,436-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:26,480-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:26,480-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:26,552-0500 INFO Multiplexer No streams
+2013-08-09 13:57:26,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:57:26,936-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:26,981-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:26,981-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:27,436-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:27,481-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:27,481-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:27,937-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:27,982-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:27,982-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:28,437-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:28,482-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:28,482-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:28,937-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:28,982-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:28,983-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:29,438-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:29,483-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:29,483-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:29,938-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:29,983-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:29,983-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:30,438-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:30,484-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:30,484-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:30,939-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:30,984-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:30,984-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:31,439-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:31,485-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:31,485-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:31,939-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:31,985-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:31,985-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:32,440-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:32,486-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:32,486-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:32,940-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:57:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:57:32,986-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:32,986-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:33,440-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:33,487-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:33,487-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:33,487-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:57:33,940-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:33,941-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:57:33,987-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:33,987-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:34,441-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:34,488-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:34,488-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:34,941-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:34,988-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:34,989-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:35,441-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:35,489-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:35,489-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:35,942-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:35,989-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:35,989-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:36,442-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:36,490-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:36,490-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:36,564-0500 INFO Multiplexer No streams
+2013-08-09 13:57:36,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:57:36,942-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:36,990-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:36,990-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:37,259-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: 26ms, rtt: 134ms
+2013-08-09 13:57:37,443-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:37,491-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:37,491-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:37,884-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -145ms, rtt: 121ms
+2013-08-09 13:57:37,943-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:37,991-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:37,991-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:38,443-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:38,491-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:38,492-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:38,622-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -18ms, rtt: 127ms
+2013-08-09 13:57:38,944-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:38,992-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:38,992-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:39,444-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:39,492-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:39,492-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:39,944-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:39,993-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:39,993-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:40,445-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:40,493-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:40,494-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:40,945-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:40,994-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:40,994-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:41,445-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:41,494-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:41,494-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:41,946-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:41,995-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:41,995-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:42,446-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:42,495-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:42,495-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:42,946-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:57:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:57:42,995-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:42,996-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:43,447-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:43,496-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:43,496-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:43,496-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:57:43,947-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:43,947-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:57:43,996-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:43,997-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:44,447-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:44,497-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:44,497-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:44,948-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:44,997-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:44,997-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:45,448-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:45,498-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:45,498-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:45,948-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:45,998-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:45,998-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:46,449-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:46,499-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:46,499-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:46,569-0500 INFO Multiplexer No streams
+2013-08-09 13:57:46,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:57:46,949-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:46,999-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:46,999-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:47,449-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:47,499-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:47,500-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:47,950-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:48,000-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:48,000-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:48,450-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:48,500-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:48,500-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:48,950-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:49,001-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:49,001-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:49,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:49,501-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:49,501-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:49,951-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:50,002-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:50,002-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:50,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:50,502-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:50,502-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:50,951-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:51,002-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:51,003-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:51,452-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:51,503-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:51,503-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:51,952-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:52,003-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:52,003-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:52,452-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:52,504-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:52,504-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:52,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:52,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:57:52,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:57:53,004-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:53,004-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:53,453-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:53,505-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:53,505-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:53,505-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:57:53,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:53,953-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:57:54,005-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:54,005-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:54,454-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:54,506-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:54,506-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:54,954-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:55,006-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:55,006-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:55,454-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:55,506-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:55,507-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:55,954-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:56,007-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:56,007-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:56,455-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:56,507-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:56,507-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:56,582-0500 INFO Multiplexer No streams
+2013-08-09 13:57:56,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:57:56,955-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:57,008-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:57,008-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:57,455-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:57,508-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:57,508-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:57,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:58,009-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:58,009-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:58,456-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:58,509-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:58,509-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:58,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:59,009-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:59,010-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:59,457-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:59,510-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:57:59,510-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:57:59,957-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:00,010-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:00,010-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:00,457-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:00,511-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:00,511-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:00,958-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:01,011-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:01,011-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:01,458-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:01,512-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:01,512-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:01,958-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:02,012-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:02,012-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:02,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:02,512-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:02,513-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:02,959-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:58:02,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:58:03,013-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:03,013-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:03,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:03,513-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:03,514-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:03,514-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:58:03,897-0500 INFO Multiplexer (0) Scheduling TCP-null for addition
+2013-08-09 13:58:03,897-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 13:58:03,927-0500 INFO ChannelConfigurationHandler Channel id: u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fff
+2013-08-09 13:58:03,927-0500 INFO MetaChannel MetaChannel[cps-58539] -> null bind -> TCP-null
+2013-08-09 13:58:03,928-0500 INFO RequestHandler Handler(tag: 1, CHANNELCONFIG) unregistering (send)
+2013-08-09 13:58:03,959-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:03,960-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:58:03,988-0500 INFO RequestHandler Handler(tag: 2, CONFIGSERVICE) unregistering (send)
+2013-08-09 13:58:03,988-0500 INFO Sender Sender TCPChannel queue size: 0
+2013-08-09 13:58:04,014-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:04,014-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:04,090-0500 INFO RequestHandler Handler(tag: 3, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,090-0500 INFO RequestHandler Handler(tag: 4, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,091-0500 INFO RequestHandler Handler(tag: 5, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,092-0500 INFO RequestHandler Handler(tag: 6, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,092-0500 INFO RequestHandler Handler(tag: 7, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,093-0500 INFO RequestHandler Handler(tag: 8, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,094-0500 INFO RequestHandler Handler(tag: 9, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,094-0500 INFO RequestHandler Handler(tag: 10, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,095-0500 INFO RequestHandler Handler(tag: 11, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,095-0500 INFO RequestHandler Handler(tag: 12, SUBMITJOB) unregistering (send)
+2013-08-09 13:58:04,099-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=0 Cpus sleeping: 1
+2013-08-09 13:58:04,099-0500 INFO Cpu 54.212.81.224:0 (quality: 2.0) submitting urn:1376074683319-1376074606722-1376074606723: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_3.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_3.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,099-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683319-1376074606722-1376074606723) Submitting
+2013-08-09 13:58:04,100-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=6 Cpus sleeping: 1
+2013-08-09 13:58:04,101-0500 INFO Cpu 54.212.37.161:6 (quality: 1.0) submitting urn:1376074683328-1376074606725-1376074606726: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_4.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_4.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,101-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683328-1376074606725-1376074606726) Submitting
+2013-08-09 13:58:04,102-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=3 Cpus sleeping: 1
+2013-08-09 13:58:04,102-0500 INFO Cpu 54.212.81.224:3 (quality: 1.0) submitting urn:1376074683326-1376074606728-1376074606729: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_9.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_9.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,102-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683326-1376074606728-1376074606729) Submitting
+2013-08-09 13:58:04,103-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=2 Cpus sleeping: 1
+2013-08-09 13:58:04,103-0500 INFO Cpu 54.244.171.51:2 (quality: 1.0) submitting urn:1376074683324-1376074606731-1376074606732: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_0.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_0.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,103-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683324-1376074606731-1376074606732) Submitting
+2013-08-09 13:58:04,104-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=2 Cpus sleeping: 1
+2013-08-09 13:58:04,105-0500 INFO Cpu 54.212.81.224:2 (quality: 1.0) submitting urn:1376074683323-1376074606734-1376074606735: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_8.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_8.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,105-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683323-1376074606734-1376074606735) Submitting
+2013-08-09 13:58:04,105-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=3 Cpus sleeping: 1
+2013-08-09 13:58:04,106-0500 INFO Cpu 54.244.171.51:3 (quality: 1.0) submitting urn:1376074683320-1376074606737-1376074606738: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_2.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_2.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,106-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683320-1376074606737-1376074606738) Submitting
+2013-08-09 13:58:04,106-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=0 Cpus sleeping: 1
+2013-08-09 13:58:04,107-0500 INFO Cpu 54.244.171.51:0 (quality: 1.0) submitting urn:1376074683321-1376074606740-1376074606741: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_7.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_7.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,107-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683321-1376074606740-1376074606741) Submitting
+2013-08-09 13:58:04,107-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=6 Cpus sleeping: 1
+2013-08-09 13:58:04,108-0500 INFO Cpu 54.244.171.51:6 (quality: 1.0) submitting urn:1376074683325-1376074606743-1376074606744: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_1.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_1.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,108-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683325-1376074606743-1376074606744) Submitting
+2013-08-09 13:58:04,108-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=7 Cpus sleeping: 1
+2013-08-09 13:58:04,109-0500 INFO Cpu 54.244.171.51:7 (quality: 1.0) submitting urn:1376074683322-1376074606746-1376074606747: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_6.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_6.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,109-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683322-1376074606746-1376074606747) Submitting
+2013-08-09 13:58:04,109-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=0 Cpus sleeping: 1
+2013-08-09 13:58:04,110-0500 INFO Cpu 54.212.37.161:0 (quality: 1.0) submitting urn:1376074683327-1376074606749-1376074606750: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_5.out -err stderr.txt -i -d output -if simulate.sh -of output/sim_5.out -k -cdmfile -status provider -a simulate.sh 3 100
+2013-08-09 13:58:04,110-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683327-1376074606749-1376074606750) Submitting
+2013-08-09 13:58:04,111-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=5 Cpus sleeping: 1
+2013-08-09 13:58:04,111-0500 DEBUG Cpu 54.212.37.161:5 sleeping
+2013-08-09 13:58:04,111-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=1 Cpus sleeping: 2
+2013-08-09 13:58:04,111-0500 DEBUG Cpu 54.244.171.51:1 sleeping
+2013-08-09 13:58:04,111-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=7 Cpus sleeping: 3
+2013-08-09 13:58:04,111-0500 DEBUG Cpu 54.212.81.224:7 sleeping
+2013-08-09 13:58:04,111-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=4 Cpus sleeping: 4
+2013-08-09 13:58:04,111-0500 DEBUG Cpu 54.212.81.224:4 sleeping
+2013-08-09 13:58:04,111-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=4 Cpus sleeping: 5
+2013-08-09 13:58:04,111-0500 DEBUG Cpu 54.244.171.51:4 sleeping
+2013-08-09 13:58:04,111-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=4 Cpus sleeping: 6
+2013-08-09 13:58:04,111-0500 DEBUG Cpu 54.212.37.161:4 sleeping
+2013-08-09 13:58:04,111-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=1 Cpus sleeping: 7
+2013-08-09 13:58:04,111-0500 DEBUG Cpu 54.212.37.161:1 sleeping
+2013-08-09 13:58:04,111-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=2 Cpus sleeping: 8
+2013-08-09 13:58:04,112-0500 DEBUG Cpu 54.212.37.161:2 sleeping
+2013-08-09 13:58:04,112-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=3 Cpus sleeping: 9
+2013-08-09 13:58:04,112-0500 DEBUG Cpu 54.212.37.161:3 sleeping
+2013-08-09 13:58:04,112-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=6 Cpus sleeping: 10
+2013-08-09 13:58:04,112-0500 DEBUG Cpu 54.212.81.224:6 sleeping
+2013-08-09 13:58:04,112-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=7 Cpus sleeping: 11
+2013-08-09 13:58:04,112-0500 DEBUG Cpu 54.212.37.161:7 sleeping
+2013-08-09 13:58:04,112-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=5 Cpus sleeping: 12
+2013-08-09 13:58:04,112-0500 DEBUG Cpu 54.244.171.51:5 sleeping
+2013-08-09 13:58:04,112-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=5 Cpus sleeping: 13
+2013-08-09 13:58:04,112-0500 DEBUG Cpu 54.212.81.224:5 sleeping
+2013-08-09 13:58:04,112-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=1 Cpus sleeping: 14
+2013-08-09 13:58:04,112-0500 DEBUG Cpu 54.212.81.224:1 sleeping
+2013-08-09 13:58:04,202-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683319-1376074606722-1376074606723) Submitted
+2013-08-09 13:58:04,203-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683319-1376074606722-1376074606723) Stagein workerid=000000
+2013-08-09 13:58:04,203-0500 INFO RequestHandler Handler(tag: 4040, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,203-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683328-1376074606725-1376074606726) Submitted
+2013-08-09 13:58:04,204-0500 INFO GetFileHandler Handler(tag: 4041, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS//usr/local/swift-0.94/bin/../libexec/_swiftwrap.staging
+2013-08-09 13:58:04,204-0500 INFO GetFileHandler Handler(tag: 4041, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS//usr/local/swift-0.94/bin/../libexec/_swiftwrap.staging
+2013-08-09 13:58:04,204-0500 INFO GetFileHandler Handler(tag: 4041, GET) -> 2
+2013-08-09 13:58:04,204-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683326-1376074606728-1376074606729) Submitted
+2013-08-09 13:58:04,205-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683326-1376074606728-1376074606729) Stagein workerid=000000
+2013-08-09 13:58:04,205-0500 INFO RequestHandler Handler(tag: 4042, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,217-0500 INFO GetFileHandler Handler(tag: 4041, GET) sending length: 6078, 1953619005
+2013-08-09 13:58:04,221-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683324-1376074606731-1376074606732) Submitted
+2013-08-09 13:58:04,234-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683323-1376074606734-1376074606735) Submitted
+2013-08-09 13:58:04,235-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683323-1376074606734-1376074606735) Stagein workerid=000000
+2013-08-09 13:58:04,235-0500 INFO RequestHandler Handler(tag: 4043, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,237-0500 INFO GetFileHandler Handler(tag: 4041, GET) unregistering (last)
+2013-08-09 13:58:04,263-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683328-1376074606725-1376074606726) Stagein workerid=000000
+2013-08-09 13:58:04,263-0500 INFO RequestHandler Handler(tag: 1380, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,264-0500 INFO GetFileHandler Handler(tag: 1381, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS//usr/local/swift-0.94/bin/../libexec/_swiftwrap.staging
+2013-08-09 13:58:04,264-0500 INFO GetFileHandler Handler(tag: 1381, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS//usr/local/swift-0.94/bin/../libexec/_swiftwrap.staging
+2013-08-09 13:58:04,264-0500 INFO GetFileHandler Handler(tag: 1381, GET) -> 6
+2013-08-09 13:58:04,264-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683327-1376074606749-1376074606750) Submitted
+2013-08-09 13:58:04,265-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683327-1376074606749-1376074606750) Stagein workerid=000000
+2013-08-09 13:58:04,265-0500 INFO RequestHandler Handler(tag: 1382, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,278-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683324-1376074606731-1376074606732) Stagein workerid=000000
+2013-08-09 13:58:04,278-0500 INFO RequestHandler Handler(tag: 2475, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,279-0500 INFO GetFileHandler Handler(tag: 2476, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS//usr/local/swift-0.94/bin/../libexec/_swiftwrap.staging
+2013-08-09 13:58:04,279-0500 INFO GetFileHandler Handler(tag: 2476, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS//usr/local/swift-0.94/bin/../libexec/_swiftwrap.staging
+2013-08-09 13:58:04,279-0500 INFO GetFileHandler Handler(tag: 2476, GET) -> 9
+2013-08-09 13:58:04,279-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683320-1376074606737-1376074606738) Submitted
+2013-08-09 13:58:04,280-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683320-1376074606737-1376074606738) Stagein workerid=000000
+2013-08-09 13:58:04,280-0500 INFO RequestHandler Handler(tag: 2477, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,280-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683321-1376074606740-1376074606741) Submitted
+2013-08-09 13:58:04,280-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683321-1376074606740-1376074606741) Stagein workerid=000000
+2013-08-09 13:58:04,281-0500 INFO RequestHandler Handler(tag: 2478, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,281-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683325-1376074606743-1376074606744) Submitted
+2013-08-09 13:58:04,281-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683325-1376074606743-1376074606744) Stagein workerid=000000
+2013-08-09 13:58:04,282-0500 INFO RequestHandler Handler(tag: 2479, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,282-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683322-1376074606746-1376074606747) Submitted
+2013-08-09 13:58:04,282-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683322-1376074606746-1376074606747) Stagein workerid=000000
+2013-08-09 13:58:04,283-0500 INFO RequestHandler Handler(tag: 2480, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,298-0500 INFO GetFileHandler Handler(tag: 1381, GET) sending length: 6078, 1939768105
+2013-08-09 13:58:04,299-0500 INFO GetFileHandler Handler(tag: 1381, GET) unregistering (last)
+2013-08-09 13:58:04,360-0500 INFO GetFileHandler Handler(tag: 2476, GET) sending length: 6078, 2010005445
+2013-08-09 13:58:04,360-0500 INFO GetFileHandler Handler(tag: 4044, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,360-0500 INFO GetFileHandler Handler(tag: 4044, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,360-0500 INFO GetFileHandler Handler(tag: 4044, GET) -> 14
+2013-08-09 13:58:04,360-0500 INFO GetFileHandler Handler(tag: 2476, GET) unregistering (last)
+2013-08-09 13:58:04,420-0500 INFO GetFileHandler Handler(tag: 4045, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,420-0500 INFO GetFileHandler Handler(tag: 4045, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,420-0500 INFO GetFileHandler Handler(tag: 4045, GET) -> 15
+2013-08-09 13:58:04,420-0500 INFO GetFileHandler Handler(tag: 4046, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,421-0500 INFO GetFileHandler Handler(tag: 4046, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,421-0500 INFO GetFileHandler Handler(tag: 4046, GET) -> 16
+2013-08-09 13:58:04,421-0500 INFO GetFileHandler Handler(tag: 1383, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,421-0500 INFO GetFileHandler Handler(tag: 1383, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,421-0500 INFO GetFileHandler Handler(tag: 1383, GET) -> 17
+2013-08-09 13:58:04,422-0500 INFO GetFileHandler Handler(tag: 4044, GET) sending length: 378, 695149991
+2013-08-09 13:58:04,422-0500 INFO GetFileHandler Handler(tag: 4044, GET) unregistering (last)
+2013-08-09 13:58:04,460-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:04,481-0500 INFO GetFileHandler Handler(tag: 1384, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,481-0500 INFO GetFileHandler Handler(tag: 1384, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,481-0500 INFO GetFileHandler Handler(tag: 1384, GET) -> 18
+2013-08-09 13:58:04,482-0500 INFO GetFileHandler Handler(tag: 2481, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,482-0500 INFO GetFileHandler Handler(tag: 2481, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,482-0500 INFO GetFileHandler Handler(tag: 2481, GET) -> 19
+2013-08-09 13:58:04,482-0500 INFO GetFileHandler Handler(tag: 2482, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,482-0500 INFO GetFileHandler Handler(tag: 2482, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,482-0500 INFO GetFileHandler Handler(tag: 4045, GET) sending length: 378, 627418050
+2013-08-09 13:58:04,482-0500 INFO GetFileHandler Handler(tag: 2482, GET) -> 20
+2013-08-09 13:58:04,483-0500 INFO GetFileHandler Handler(tag: 4046, GET) sending length: 378, 866838863
+2013-08-09 13:58:04,483-0500 INFO GetFileHandler Handler(tag: 4045, GET) unregistering (last)
+2013-08-09 13:58:04,483-0500 INFO GetFileHandler Handler(tag: 1383, GET) sending length: 378, 790899473
+2013-08-09 13:58:04,483-0500 INFO GetFileHandler Handler(tag: 2483, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,483-0500 INFO GetFileHandler Handler(tag: 4046, GET) unregistering (last)
+2013-08-09 13:58:04,484-0500 INFO GetFileHandler Handler(tag: 2483, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,484-0500 INFO GetFileHandler Handler(tag: 1383, GET) unregistering (last)
+2013-08-09 13:58:04,484-0500 INFO GetFileHandler Handler(tag: 2483, GET) -> 21
+2013-08-09 13:58:04,484-0500 INFO GetFileHandler Handler(tag: 2484, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,484-0500 INFO GetFileHandler Handler(tag: 2484, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,485-0500 INFO GetFileHandler Handler(tag: 2484, GET) -> 22
+2013-08-09 13:58:04,485-0500 INFO GetFileHandler Handler(tag: 2485, GET) request complete; src=proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,485-0500 INFO GetFileHandler Handler(tag: 2485, GET) reader: PR proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/simulate.sh
+2013-08-09 13:58:04,485-0500 INFO GetFileHandler Handler(tag: 2485, GET) -> 23
+2013-08-09 13:58:04,564-0500 INFO GetFileHandler Handler(tag: 1384, GET) sending length: 378, 1738275632
+2013-08-09 13:58:04,564-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=1, allowedTransfers=255, active=0, suspended=0
+2013-08-09 13:58:04,565-0500 INFO GetFileHandler Handler(tag: 2481, GET) sending length: 378, 2010296347
+2013-08-09 13:58:04,565-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:04,565-0500 INFO GetFileHandler Handler(tag: 1384, GET) unregistering (last)
+2013-08-09 13:58:04,565-0500 INFO GetFileHandler Handler(tag: 2482, GET) sending length: 378, 367145653
+2013-08-09 13:58:04,565-0500 INFO GetFileHandler Handler(tag: 2481, GET) unregistering (last)
+2013-08-09 13:58:04,566-0500 INFO GetFileHandler Handler(tag: 2482, GET) unregistering (last)
+2013-08-09 13:58:04,566-0500 INFO GetFileHandler Handler(tag: 2483, GET) sending length: 378, 394215580
+2013-08-09 13:58:04,566-0500 INFO GetFileHandler Handler(tag: 2483, GET) unregistering (last)
+2013-08-09 13:58:04,566-0500 INFO GetFileHandler Handler(tag: 2484, GET) sending length: 378, 1660604171
+2013-08-09 13:58:04,567-0500 INFO GetFileHandler Handler(tag: 2484, GET) unregistering (last)
+2013-08-09 13:58:04,567-0500 INFO GetFileHandler Handler(tag: 2485, GET) sending length: 378, 1328853118
+2013-08-09 13:58:04,567-0500 INFO GetFileHandler Handler(tag: 2485, GET) unregistering (last)
+2013-08-09 13:58:04,576-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683326-1376074606728-1376074606729) Active workerid=000000
+2013-08-09 13:58:04,577-0500 INFO RequestHandler Handler(tag: 4047, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,577-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683323-1376074606734-1376074606735) Active workerid=000000
+2013-08-09 13:58:04,577-0500 INFO RequestHandler Handler(tag: 4048, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,636-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683319-1376074606722-1376074606723) Active workerid=000000
+2013-08-09 13:58:04,636-0500 INFO RequestHandler Handler(tag: 4049, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,647-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683320-1376074606737-1376074606738) Active workerid=000000
+2013-08-09 13:58:04,647-0500 INFO RequestHandler Handler(tag: 2486, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,667-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683321-1376074606740-1376074606741) Active workerid=000000
+2013-08-09 13:58:04,667-0500 INFO RequestHandler Handler(tag: 2487, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,712-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683327-1376074606749-1376074606750) Active workerid=000000
+2013-08-09 13:58:04,712-0500 INFO RequestHandler Handler(tag: 1385, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,712-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683328-1376074606725-1376074606726) Active workerid=000000
+2013-08-09 13:58:04,713-0500 INFO RequestHandler Handler(tag: 1386, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,724-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683325-1376074606743-1376074606744) Active workerid=000000
+2013-08-09 13:58:04,724-0500 INFO RequestHandler Handler(tag: 2488, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,771-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683322-1376074606746-1376074606747) Active workerid=000000
+2013-08-09 13:58:04,771-0500 INFO RequestHandler Handler(tag: 2489, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,772-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683324-1376074606731-1376074606732) Active workerid=000000
+2013-08-09 13:58:04,772-0500 INFO RequestHandler Handler(tag: 2490, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:04,960-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:05,068-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:05,068-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:05,460-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:05,568-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:05,568-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:05,960-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:06,069-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:06,069-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:06,461-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:06,569-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:06,569-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:06,583-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:58:06,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:58:06,961-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:07,069-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:07,070-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:07,461-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:07,570-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:07,570-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:07,617-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683319-1376074606722-1376074606723) Stageout workerid=000000
+2013-08-09 13:58:07,617-0500 INFO RequestHandler Handler(tag: 4050, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,618-0500 INFO PutFileHandler Handler(tag: 4051, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/o/sh-oqb11kdl/wrapper.log
+2013-08-09 13:58:07,618-0500 INFO PutFileHandler Handler(tag: 4051, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-oqb11kdl.info
+2013-08-09 13:58:07,621-0500 INFO PutFileCommand Sending Command(tag: 35, PUT) (t) on TCP-null
+2013-08-09 13:58:07,621-0500 INFO PutFileCommand Command(tag: 35, PUT) (t) sending data
+2013-08-09 13:58:07,621-0500 INFO PutFileHandler Handler(tag: 4051, PUT) -> 35
+2013-08-09 13:58:07,622-0500 INFO RequestHandler Handler(tag: 4052, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,671-0500 INFO PutFileHandler Handler(tag: 4051, PUT) Transfer done
+2013-08-09 13:58:07,672-0500 INFO RequestHandler Handler(tag: 4051, PUT) unregistering (send)
+2013-08-09 13:58:07,676-0500 INFO PutFileHandler Handler(tag: 4053, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/o/sh-oqb11kdl/./output/sim_3.out
+2013-08-09 13:58:07,676-0500 INFO PutFileHandler Handler(tag: 4053, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_3.out
+2013-08-09 13:58:07,676-0500 INFO PutFileCommand Sending Command(tag: 36, PUT) (t) on TCP-null
+2013-08-09 13:58:07,676-0500 INFO PutFileCommand Command(tag: 36, PUT) (t) sending data
+2013-08-09 13:58:07,676-0500 INFO PutFileHandler Handler(tag: 4053, PUT) -> 36
+2013-08-09 13:58:07,677-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683323-1376074606734-1376074606735) Stageout workerid=000000
+2013-08-09 13:58:07,677-0500 INFO RequestHandler Handler(tag: 4054, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,677-0500 INFO PutFileHandler Handler(tag: 4055, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/m/sh-mqb11kdl/./output/sim_8.out
+2013-08-09 13:58:07,677-0500 INFO PutFileHandler Handler(tag: 4055, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_8.out
+2013-08-09 13:58:07,677-0500 INFO PutFileCommand Sending Command(tag: 38, PUT) (t) on TCP-null
+2013-08-09 13:58:07,678-0500 INFO PutFileCommand Command(tag: 38, PUT) (t) sending data
+2013-08-09 13:58:07,678-0500 INFO PutFileHandler Handler(tag: 4055, PUT) -> 38
+2013-08-09 13:58:07,678-0500 INFO RequestHandler Handler(tag: 4056, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,678-0500 INFO PutFileHandler Handler(tag: 4057, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/m/sh-mqb11kdl/wrapper.log
+2013-08-09 13:58:07,678-0500 INFO PutFileHandler Handler(tag: 4057, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-mqb11kdl.info
+2013-08-09 13:58:07,679-0500 INFO PutFileCommand Sending Command(tag: 39, PUT) (t) on TCP-null
+2013-08-09 13:58:07,679-0500 INFO PutFileCommand Command(tag: 39, PUT) (t) sending data
+2013-08-09 13:58:07,679-0500 INFO PutFileHandler Handler(tag: 4057, PUT) -> 39
+2013-08-09 13:58:07,679-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683326-1376074606728-1376074606729) Stageout workerid=000000
+2013-08-09 13:58:07,680-0500 INFO RequestHandler Handler(tag: 4058, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,680-0500 INFO PutFileHandler Handler(tag: 4059, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/k/sh-kqb11kdl/wrapper.log
+2013-08-09 13:58:07,680-0500 INFO PutFileHandler Handler(tag: 4059, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-kqb11kdl.info
+2013-08-09 13:58:07,680-0500 INFO PutFileCommand Sending Command(tag: 41, PUT) (t) on TCP-null
+2013-08-09 13:58:07,680-0500 INFO PutFileCommand Command(tag: 41, PUT) (t) sending data
+2013-08-09 13:58:07,680-0500 INFO PutFileHandler Handler(tag: 4059, PUT) -> 41
+2013-08-09 13:58:07,681-0500 INFO RequestHandler Handler(tag: 4060, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,681-0500 INFO PutFileHandler Handler(tag: 4061, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/k/sh-kqb11kdl/./output/sim_9.out
+2013-08-09 13:58:07,681-0500 INFO PutFileHandler Handler(tag: 4061, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_9.out
+2013-08-09 13:58:07,681-0500 INFO PutFileCommand Sending Command(tag: 42, PUT) (t) on TCP-null
+2013-08-09 13:58:07,681-0500 INFO PutFileCommand Command(tag: 42, PUT) (t) sending data
+2013-08-09 13:58:07,681-0500 INFO PutFileHandler Handler(tag: 4061, PUT) -> 42
+2013-08-09 13:58:07,740-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683327-1376074606749-1376074606750) Stageout workerid=000000
+2013-08-09 13:58:07,740-0500 INFO RequestHandler Handler(tag: 1387, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,740-0500 INFO PutFileHandler Handler(tag: 1388, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/h/sh-hqb11kdl/wrapper.log
+2013-08-09 13:58:07,740-0500 INFO PutFileHandler Handler(tag: 1388, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-hqb11kdl.info
+2013-08-09 13:58:07,740-0500 INFO PutFileCommand Sending Command(tag: 44, PUT) (t) on TCP-null
+2013-08-09 13:58:07,740-0500 INFO PutFileCommand Command(tag: 44, PUT) (t) sending data
+2013-08-09 13:58:07,741-0500 INFO PutFileHandler Handler(tag: 1388, PUT) -> 44
+2013-08-09 13:58:07,741-0500 INFO RequestHandler Handler(tag: 1389, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,741-0500 INFO PutFileHandler Handler(tag: 1390, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/h/sh-hqb11kdl/./output/sim_5.out
+2013-08-09 13:58:07,742-0500 INFO PutFileHandler Handler(tag: 1390, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_5.out
+2013-08-09 13:58:07,742-0500 INFO PutFileCommand Sending Command(tag: 45, PUT) (t) on TCP-null
+2013-08-09 13:58:07,742-0500 INFO PutFileCommand Command(tag: 45, PUT) (t) sending data
+2013-08-09 13:58:07,742-0500 INFO PutFileHandler Handler(tag: 1390, PUT) -> 45
+2013-08-09 13:58:07,742-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683325-1376074606743-1376074606744) Stageout workerid=000000
+2013-08-09 13:58:07,742-0500 INFO RequestHandler Handler(tag: 2491, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,743-0500 INFO PutFileHandler Handler(tag: 2492, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/i/sh-iqb11kdl/wrapper.log
+2013-08-09 13:58:07,743-0500 INFO PutFileHandler Handler(tag: 2492, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-iqb11kdl.info
+2013-08-09 13:58:07,743-0500 INFO PutFileCommand Sending Command(tag: 47, PUT) (t) on TCP-null
+2013-08-09 13:58:07,743-0500 INFO PutFileCommand Command(tag: 47, PUT) (t) sending data
+2013-08-09 13:58:07,743-0500 INFO PutFileHandler Handler(tag: 2492, PUT) -> 47
+2013-08-09 13:58:07,744-0500 INFO RequestHandler Handler(tag: 2493, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,744-0500 INFO PutFileHandler Handler(tag: 2494, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/i/sh-iqb11kdl/./output/sim_1.out
+2013-08-09 13:58:07,744-0500 INFO PutFileHandler Handler(tag: 2494, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_1.out
+2013-08-09 13:58:07,744-0500 INFO PutFileCommand Sending Command(tag: 48, PUT) (t) on TCP-null
+2013-08-09 13:58:07,744-0500 INFO PutFileCommand Command(tag: 48, PUT) (t) sending data
+2013-08-09 13:58:07,744-0500 INFO PutFileHandler Handler(tag: 2494, PUT) -> 48
+2013-08-09 13:58:07,752-0500 INFO PutFileHandler Handler(tag: 4053, PUT) Transfer done
+2013-08-09 13:58:07,752-0500 INFO RequestHandler Handler(tag: 4053, PUT) unregistering (send)
+2013-08-09 13:58:07,752-0500 INFO PutFileHandler Handler(tag: 4055, PUT) Transfer done
+2013-08-09 13:58:07,753-0500 INFO RequestHandler Handler(tag: 4055, PUT) unregistering (send)
+2013-08-09 13:58:07,753-0500 INFO PutFileHandler Handler(tag: 4057, PUT) Transfer done
+2013-08-09 13:58:07,753-0500 INFO RequestHandler Handler(tag: 4057, PUT) unregistering (send)
+2013-08-09 13:58:07,753-0500 INFO PutFileHandler Handler(tag: 4059, PUT) Transfer done
+2013-08-09 13:58:07,753-0500 INFO RequestHandler Handler(tag: 4059, PUT) unregistering (send)
+2013-08-09 13:58:07,753-0500 INFO PutFileHandler Handler(tag: 4061, PUT) Transfer done
+2013-08-09 13:58:07,753-0500 INFO RequestHandler Handler(tag: 4061, PUT) unregistering (send)
+2013-08-09 13:58:07,798-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683321-1376074606740-1376074606741) Stageout workerid=000000
+2013-08-09 13:58:07,798-0500 INFO RequestHandler Handler(tag: 2495, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,799-0500 INFO PutFileHandler Handler(tag: 2496, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/n/sh-nqb11kdl/wrapper.log
+2013-08-09 13:58:07,799-0500 INFO PutFileHandler Handler(tag: 2496, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-nqb11kdl.info
+2013-08-09 13:58:07,799-0500 INFO PutFileCommand Sending Command(tag: 50, PUT) (t) on TCP-null
+2013-08-09 13:58:07,799-0500 INFO PutFileCommand Command(tag: 50, PUT) (t) sending data
+2013-08-09 13:58:07,799-0500 INFO PutFileHandler Handler(tag: 2496, PUT) -> 50
+2013-08-09 13:58:07,799-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683328-1376074606725-1376074606726) Stageout workerid=000000
+2013-08-09 13:58:07,800-0500 INFO RequestHandler Handler(tag: 1391, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,800-0500 INFO PutFileHandler Handler(tag: 1392, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/g/sh-gqb11kdl/./output/sim_4.out
+2013-08-09 13:58:07,800-0500 INFO PutFileHandler Handler(tag: 1392, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_4.out
+2013-08-09 13:58:07,800-0500 INFO PutFileCommand Sending Command(tag: 52, PUT) (t) on TCP-null
+2013-08-09 13:58:07,800-0500 INFO PutFileCommand Command(tag: 52, PUT) (t) sending data
+2013-08-09 13:58:07,800-0500 INFO PutFileHandler Handler(tag: 1392, PUT) -> 52
+2013-08-09 13:58:07,801-0500 INFO RequestHandler Handler(tag: 2497, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,801-0500 INFO PutFileHandler Handler(tag: 2498, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/n/sh-nqb11kdl/./output/sim_7.out
+2013-08-09 13:58:07,801-0500 INFO PutFileHandler Handler(tag: 2498, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_7.out
+2013-08-09 13:58:07,801-0500 INFO PutFileCommand Sending Command(tag: 53, PUT) (t) on TCP-null
+2013-08-09 13:58:07,801-0500 INFO PutFileCommand Command(tag: 53, PUT) (t) sending data
+2013-08-09 13:58:07,802-0500 INFO PutFileHandler Handler(tag: 2498, PUT) -> 53
+2013-08-09 13:58:07,802-0500 INFO RequestHandler Handler(tag: 1393, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,802-0500 INFO PutFileHandler Handler(tag: 1394, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/g/sh-gqb11kdl/wrapper.log
+2013-08-09 13:58:07,802-0500 INFO PutFileHandler Handler(tag: 1394, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-gqb11kdl.info
+2013-08-09 13:58:07,802-0500 INFO PutFileCommand Sending Command(tag: 54, PUT) (t) on TCP-null
+2013-08-09 13:58:07,803-0500 INFO PutFileCommand Command(tag: 54, PUT) (t) sending data
+2013-08-09 13:58:07,803-0500 INFO PutFileHandler Handler(tag: 1394, PUT) -> 54
+2013-08-09 13:58:07,803-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683324-1376074606731-1376074606732) Stageout workerid=000000
+2013-08-09 13:58:07,803-0500 INFO RequestHandler Handler(tag: 2499, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,803-0500 INFO PutFileHandler Handler(tag: 2500, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/f/sh-fqb11kdl/wrapper.log
+2013-08-09 13:58:07,804-0500 INFO PutFileHandler Handler(tag: 2500, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-fqb11kdl.info
+2013-08-09 13:58:07,804-0500 INFO PutFileCommand Sending Command(tag: 56, PUT) (t) on TCP-null
+2013-08-09 13:58:07,804-0500 INFO PutFileCommand Command(tag: 56, PUT) (t) sending data
+2013-08-09 13:58:07,804-0500 INFO PutFileHandler Handler(tag: 2500, PUT) -> 56
+2013-08-09 13:58:07,804-0500 INFO RequestHandler Handler(tag: 2501, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,805-0500 INFO PutFileHandler Handler(tag: 2502, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/f/sh-fqb11kdl/./output/sim_0.out
+2013-08-09 13:58:07,805-0500 INFO PutFileHandler Handler(tag: 2502, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_0.out
+2013-08-09 13:58:07,805-0500 INFO PutFileCommand Sending Command(tag: 57, PUT) (t) on TCP-null
+2013-08-09 13:58:07,806-0500 INFO PutFileCommand Command(tag: 57, PUT) (t) sending data
+2013-08-09 13:58:07,806-0500 INFO PutFileHandler Handler(tag: 2502, PUT) -> 57
+2013-08-09 13:58:07,806-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683320-1376074606737-1376074606738) Stageout workerid=000000
+2013-08-09 13:58:07,807-0500 INFO RequestHandler Handler(tag: 2503, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,807-0500 INFO PutFileHandler Handler(tag: 2504, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/l/sh-lqb11kdl/wrapper.log
+2013-08-09 13:58:07,807-0500 INFO PutFileHandler Handler(tag: 2504, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-lqb11kdl.info
+2013-08-09 13:58:07,807-0500 INFO PutFileCommand Sending Command(tag: 59, PUT) (t) on TCP-null
+2013-08-09 13:58:07,807-0500 INFO PutFileCommand Command(tag: 59, PUT) (t) sending data
+2013-08-09 13:58:07,807-0500 INFO PutFileHandler Handler(tag: 2504, PUT) -> 59
+2013-08-09 13:58:07,814-0500 INFO PutFileHandler Handler(tag: 1388, PUT) Transfer done
+2013-08-09 13:58:07,814-0500 INFO RequestHandler Handler(tag: 1388, PUT) unregistering (send)
+2013-08-09 13:58:07,815-0500 INFO PutFileHandler Handler(tag: 1390, PUT) Transfer done
+2013-08-09 13:58:07,815-0500 INFO RequestHandler Handler(tag: 1390, PUT) unregistering (send)
+2013-08-09 13:58:07,815-0500 INFO PutFileHandler Handler(tag: 2492, PUT) Transfer done
+2013-08-09 13:58:07,815-0500 INFO RequestHandler Handler(tag: 2492, PUT) unregistering (send)
+2013-08-09 13:58:07,815-0500 INFO PutFileHandler Handler(tag: 2494, PUT) Transfer done
+2013-08-09 13:58:07,815-0500 INFO RequestHandler Handler(tag: 2494, PUT) unregistering (send)
+2013-08-09 13:58:07,854-0500 INFO RequestHandler Handler(tag: 2505, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,854-0500 INFO PutFileHandler Handler(tag: 2506, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/l/sh-lqb11kdl/./output/sim_2.out
+2013-08-09 13:58:07,855-0500 INFO PutFileHandler Handler(tag: 2506, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_2.out
+2013-08-09 13:58:07,855-0500 INFO PutFileCommand Sending Command(tag: 60, PUT) (t) on TCP-null
+2013-08-09 13:58:07,855-0500 INFO PutFileCommand Command(tag: 60, PUT) (t) sending data
+2013-08-09 13:58:07,855-0500 INFO PutFileHandler Handler(tag: 2506, PUT) -> 60
+2013-08-09 13:58:07,855-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683322-1376074606746-1376074606747) Stageout workerid=000000
+2013-08-09 13:58:07,856-0500 INFO RequestHandler Handler(tag: 2507, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,856-0500 INFO PutFileHandler Handler(tag: 2496, PUT) Transfer done
+2013-08-09 13:58:07,856-0500 INFO PutFileHandler Handler(tag: 2508, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/j/sh-jqb11kdl/wrapper.log
+2013-08-09 13:58:07,856-0500 INFO RequestHandler Handler(tag: 2496, PUT) unregistering (send)
+2013-08-09 13:58:07,856-0500 INFO PutFileHandler Handler(tag: 2508, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/p7-20130809-1358-5x85n5s4.d/sh-jqb11kdl.info
+2013-08-09 13:58:07,856-0500 INFO PutFileCommand Sending Command(tag: 62, PUT) (t) on TCP-null
+2013-08-09 13:58:07,856-0500 INFO PutFileHandler Handler(tag: 1392, PUT) Transfer done
+2013-08-09 13:58:07,856-0500 INFO PutFileCommand Command(tag: 62, PUT) (t) sending data
+2013-08-09 13:58:07,857-0500 INFO RequestHandler Handler(tag: 1392, PUT) unregistering (send)
+2013-08-09 13:58:07,857-0500 INFO PutFileHandler Handler(tag: 2508, PUT) -> 62
+2013-08-09 13:58:07,857-0500 INFO PutFileHandler Handler(tag: 2498, PUT) Transfer done
+2013-08-09 13:58:07,857-0500 INFO RequestHandler Handler(tag: 2498, PUT) unregistering (send)
+2013-08-09 13:58:07,857-0500 INFO PutFileHandler Handler(tag: 1394, PUT) Transfer done
+2013-08-09 13:58:07,857-0500 INFO RequestHandler Handler(tag: 1394, PUT) unregistering (send)
+2013-08-09 13:58:07,857-0500 INFO RequestHandler Handler(tag: 2509, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,857-0500 INFO PutFileHandler Handler(tag: 2500, PUT) Transfer done
+2013-08-09 13:58:07,858-0500 INFO RequestHandler Handler(tag: 2500, PUT) unregistering (send)
+2013-08-09 13:58:07,858-0500 INFO PutFileHandler Handler(tag: 2510, PUT) source: /tmp/ketan/p7-20130809-1358-5x85n5s4/jobs/j/sh-jqb11kdl/./output/sim_6.out
+2013-08-09 13:58:07,858-0500 INFO PutFileHandler Handler(tag: 2502, PUT) Transfer done
+2013-08-09 13:58:07,858-0500 INFO PutFileHandler Handler(tag: 2510, PUT) destination: proxy://u5ed13040-14064715601--8000-u63ed4446-140647027d0--7fffS/output/sim_6.out
+2013-08-09 13:58:07,858-0500 INFO RequestHandler Handler(tag: 2502, PUT) unregistering (send)
+2013-08-09 13:58:07,858-0500 INFO PutFileCommand Sending Command(tag: 63, PUT) (t) on TCP-null
+2013-08-09 13:58:07,858-0500 INFO PutFileCommand Command(tag: 63, PUT) (t) sending data
+2013-08-09 13:58:07,858-0500 INFO PutFileHandler Handler(tag: 2504, PUT) Transfer done
+2013-08-09 13:58:07,858-0500 INFO PutFileHandler Handler(tag: 2510, PUT) -> 63
+2013-08-09 13:58:07,859-0500 INFO RequestHandler Handler(tag: 2504, PUT) unregistering (send)
+2013-08-09 13:58:07,859-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683319-1376074606722-1376074606723) Completed
+2013-08-09 13:58:07,859-0500 INFO Cpu 54.212.81.224:0 jobTerminated
+2013-08-09 13:58:07,859-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=0
+2013-08-09 13:58:07,859-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=0 Cpus sleeping: 15
+2013-08-09 13:58:07,859-0500 INFO RequestHandler Handler(tag: 4062, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,859-0500 DEBUG Cpu 54.212.81.224:0 sleeping
+2013-08-09 13:58:07,917-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683325-1376074606743-1376074606744) Completed
+2013-08-09 13:58:07,917-0500 INFO Cpu 54.244.171.51:6 jobTerminated
+2013-08-09 13:58:07,917-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=6
+2013-08-09 13:58:07,917-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=6 Cpus sleeping: 16
+2013-08-09 13:58:07,918-0500 INFO RequestHandler Handler(tag: 2511, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,918-0500 DEBUG Cpu 54.244.171.51:6 sleeping
+2013-08-09 13:58:07,918-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683323-1376074606734-1376074606735) Completed
+2013-08-09 13:58:07,918-0500 INFO Cpu 54.212.81.224:2 jobTerminated
+2013-08-09 13:58:07,918-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=2
+2013-08-09 13:58:07,918-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=2 Cpus sleeping: 17
+2013-08-09 13:58:07,918-0500 INFO RequestHandler Handler(tag: 4063, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,918-0500 DEBUG Cpu 54.212.81.224:2 sleeping
+2013-08-09 13:58:07,919-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683326-1376074606728-1376074606729) Completed
+2013-08-09 13:58:07,919-0500 INFO Cpu 54.212.81.224:3 jobTerminated
+2013-08-09 13:58:07,919-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=3
+2013-08-09 13:58:07,919-0500 INFO RequestHandler Handler(tag: 4064, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,919-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=3 Cpus sleeping: 18
+2013-08-09 13:58:07,919-0500 INFO PutFileHandler Handler(tag: 2506, PUT) Transfer done
+2013-08-09 13:58:07,919-0500 DEBUG Cpu 54.212.81.224:3 sleeping
+2013-08-09 13:58:07,919-0500 INFO RequestHandler Handler(tag: 2506, PUT) unregistering (send)
+2013-08-09 13:58:07,920-0500 INFO PutFileHandler Handler(tag: 2508, PUT) Transfer done
+2013-08-09 13:58:07,920-0500 INFO RequestHandler Handler(tag: 2508, PUT) unregistering (send)
+2013-08-09 13:58:07,920-0500 INFO PutFileHandler Handler(tag: 2510, PUT) Transfer done
+2013-08-09 13:58:07,920-0500 INFO RequestHandler Handler(tag: 2510, PUT) unregistering (send)
+2013-08-09 13:58:07,922-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683327-1376074606749-1376074606750) Completed
+2013-08-09 13:58:07,922-0500 INFO Cpu 54.212.37.161:0 jobTerminated
+2013-08-09 13:58:07,922-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=0
+2013-08-09 13:58:07,922-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=0 Cpus sleeping: 19
+2013-08-09 13:58:07,922-0500 INFO RequestHandler Handler(tag: 1395, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,922-0500 DEBUG Cpu 54.212.37.161:0 sleeping
+2013-08-09 13:58:07,973-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683321-1376074606740-1376074606741) Completed
+2013-08-09 13:58:07,973-0500 INFO Cpu 54.244.171.51:0 jobTerminated
+2013-08-09 13:58:07,973-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=0
+2013-08-09 13:58:07,974-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=0 Cpus sleeping: 20
+2013-08-09 13:58:07,974-0500 DEBUG Cpu 54.244.171.51:0 sleeping
+2013-08-09 13:58:07,974-0500 INFO RequestHandler Handler(tag: 2512, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,974-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683324-1376074606731-1376074606732) Completed
+2013-08-09 13:58:07,974-0500 INFO Cpu 54.244.171.51:2 jobTerminated
+2013-08-09 13:58:07,974-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=2
+2013-08-09 13:58:07,974-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=2 Cpus sleeping: 21
+2013-08-09 13:58:07,974-0500 DEBUG Cpu 54.244.171.51:2 sleeping
+2013-08-09 13:58:07,974-0500 INFO RequestHandler Handler(tag: 2513, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:07,981-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683328-1376074606725-1376074606726) Completed
+2013-08-09 13:58:07,981-0500 INFO Cpu 54.212.37.161:6 jobTerminated
+2013-08-09 13:58:07,982-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=6
+2013-08-09 13:58:07,982-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=6 Cpus sleeping: 22
+2013-08-09 13:58:07,982-0500 DEBUG Cpu 54.212.37.161:6 sleeping
+2013-08-09 13:58:07,982-0500 INFO RequestHandler Handler(tag: 1396, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:08,031-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683320-1376074606737-1376074606738) Completed
+2013-08-09 13:58:08,031-0500 INFO Cpu 54.244.171.51:3 jobTerminated
+2013-08-09 13:58:08,032-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=3
+2013-08-09 13:58:08,032-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=3 Cpus sleeping: 23
+2013-08-09 13:58:08,032-0500 DEBUG Cpu 54.244.171.51:3 sleeping
+2013-08-09 13:58:08,032-0500 INFO RequestHandler Handler(tag: 2514, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:08,070-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:08,070-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:08,087-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074683322-1376074606746-1376074606747) Completed
+2013-08-09 13:58:08,088-0500 INFO Cpu 54.244.171.51:7 jobTerminated
+2013-08-09 13:58:08,088-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=7
+2013-08-09 13:58:08,088-0500 INFO RequestHandler Handler(tag: 2515, JOBSTATUS) unregistering (send)
+2013-08-09 13:58:08,088-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=7 Cpus sleeping: 24
+2013-08-09 13:58:08,088-0500 DEBUG Cpu 54.244.171.51:7 sleeping
+2013-08-09 13:58:08,344-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: -154ms, rtt: 124ms
+2013-08-09 13:58:08,359-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:08,571-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:08,571-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:08,859-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:09,071-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:09,071-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:09,360-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:09,571-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:09,572-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:09,860-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:10,072-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:10,072-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:10,360-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:10,572-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:10,572-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:10,861-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:11,073-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:11,073-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:11,361-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:11,573-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:11,573-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:11,861-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:12,074-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:12,074-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:12,361-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:12,574-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:12,574-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:12,862-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:58:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:58:13,074-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:13,075-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:13,362-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:13,512-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -12ms, rtt: 134ms
+2013-08-09 13:58:13,575-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:13,575-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:13,575-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:58:13,862-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:14,075-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:14,075-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:14,363-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:14,363-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:58:14,576-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:14,576-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:14,863-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:15,076-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:15,076-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:15,363-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:15,576-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:15,577-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:15,740-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: 32ms, rtt: 124ms
+2013-08-09 13:58:15,864-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:16,077-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:16,077-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:16,364-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:16,577-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:16,577-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:16,584-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:58:16,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:58:16,864-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:17,078-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:17,078-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:17,364-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:17,578-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:17,578-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:17,865-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:18,078-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:18,079-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:18,365-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:18,579-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:18,579-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:18,865-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:19,079-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:19,079-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:19,366-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:19,580-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:19,580-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:19,866-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:20,080-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:20,080-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:20,366-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:20,580-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:20,581-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:20,867-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:21,081-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:21,081-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:21,367-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:21,581-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:21,581-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:21,867-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:22,082-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:22,082-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:22,368-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:22,582-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:22,582-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:22,868-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:58:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:58:23,083-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:23,083-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:23,368-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:23,583-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:23,583-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:23,583-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:58:23,868-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:24,084-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:24,084-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:24,369-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:24,369-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:58:24,584-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:24,584-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:24,869-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:25,085-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:25,085-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:25,369-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:25,585-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:25,585-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:25,870-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:26,085-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:26,086-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:26,370-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:26,586-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:26,586-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:26,597-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:58:26,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:58:26,870-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:27,086-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:27,086-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:27,370-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:27,587-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:27,587-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:27,871-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:28,087-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:28,087-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:28,371-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:28,588-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:28,588-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:28,871-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:29,088-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:29,088-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:29,372-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:29,588-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:29,589-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:29,872-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:30,089-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:30,089-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:30,372-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:30,589-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:30,590-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:30,873-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:31,090-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:31,090-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:31,373-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:31,590-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:31,591-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:31,873-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:32,091-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:32,091-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:32,373-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:32,591-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:32,592-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:32,874-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:58:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:58:33,092-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:33,092-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:33,374-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:33,592-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:33,592-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:33,592-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:58:33,874-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:34,093-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:34,093-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:34,375-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:34,375-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:58:34,593-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:34,593-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:34,875-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:35,094-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:35,094-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:35,375-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:35,594-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:35,594-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:35,876-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:36,094-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:36,095-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:36,376-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:36,595-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:36,595-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:36,609-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:58:36,727-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:58:36,876-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:37,095-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:37,095-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:37,376-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:37,596-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:37,596-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:37,877-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:38,096-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:38,096-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:38,377-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:38,596-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:38,597-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:38,839-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: 29ms, rtt: 162ms
+2013-08-09 13:58:38,877-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:39,097-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:39,097-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:39,378-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:39,597-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:39,597-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:39,878-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:40,098-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:40,098-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:40,378-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:40,598-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:40,599-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:40,879-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:41,099-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:41,099-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:41,379-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:41,599-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:41,599-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:41,879-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:42,100-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:42,100-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:42,379-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:42,600-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:42,600-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:42,880-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:58:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:58:43,100-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:43,101-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:43,380-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:43,601-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:43,601-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:43,601-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:58:43,880-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:44,101-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:44,101-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:44,381-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:44,381-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:58:44,602-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:44,602-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:44,881-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:45,102-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:45,102-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:45,381-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:45,602-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:45,603-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:45,881-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:46,103-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:46,103-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:46,382-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:46,603-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:46,603-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:46,621-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:58:46,728-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:58:46,882-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:47,104-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:47,104-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:47,382-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:47,604-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:47,604-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:47,883-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:48,105-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:48,105-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:48,383-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:48,421-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -20ms, rtt: 162ms
+2013-08-09 13:58:48,605-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:48,605-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:48,883-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:49,105-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:49,106-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:49,383-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:49,606-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:49,606-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:49,884-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:50,106-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:50,106-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:50,384-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:50,607-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:50,607-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:50,884-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:51,107-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:51,107-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:51,385-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:51,608-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:51,608-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:51,885-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:52,108-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:52,108-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:52,385-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:52,608-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:52,609-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:52,885-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:58:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:58:53,109-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:53,109-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:53,386-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:53,610-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:53,610-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:53,610-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:58:53,886-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:54,110-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:54,110-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:54,264-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: 26ms, rtt: 155ms
+2013-08-09 13:58:54,386-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:54,386-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:58:54,610-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:54,611-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:54,887-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:55,111-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:55,111-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:55,387-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:55,611-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:55,611-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:55,887-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:56,112-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:56,112-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:56,387-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:56,612-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:56,612-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:56,634-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:58:56,728-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:58:56,888-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:57,113-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:57,113-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:57,388-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:57,613-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:57,613-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:57,888-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:58,113-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:58,114-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:58,388-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:58,614-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:58,614-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:58,889-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:59,114-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:59,115-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:59,389-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:59,615-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:58:59,615-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:58:59,889-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:00,115-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:00,115-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:00,390-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:00,616-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:00,616-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:00,890-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:01,116-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:01,116-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:01,390-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:01,616-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:01,617-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:01,891-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:02,117-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:02,117-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:02,391-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:02,617-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:02,618-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:02,891-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:59:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:59:03,118-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:03,118-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:03,391-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:03,618-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:03,618-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:03,618-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:59:03,892-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:04,119-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:04,119-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:04,392-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:04,392-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:59:04,518-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-135703.800, now=130809-135904.518, channel=TCP-null
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.checkTimeouts(AbstractKarajanChannel.java:130)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel$1.run(AbstractKarajanChannel.java:121)
+ at java.util.TimerThread.mainLoop(Timer.java:512)
+ at java.util.TimerThread.run(Timer.java:462)
+2013-08-09 13:59:04,518-0500 INFO ChannelContext => Command(tag: 7, RESOURCEUPDATE)
+2013-08-09 13:59:04,518-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 13:59:04,518-0500 INFO ChannelManager TCP-null handling channel exception
+2013-08-09 13:59:04,519-0500 INFO ChannelManager Channel already shut down
+2013-08-09 13:59:04,619-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:04,619-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:04,892-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:05,120-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:05,120-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:05,393-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:05,620-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:05,620-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:05,893-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:06,120-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:06,121-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:06,313-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-135705.313, now=130809-135906.313, channel=BufferingChannel
+2013-08-09 13:59:06,314-0500 INFO ChannelContext => Command(tag: 7, RESOURCEUPDATE)
+2013-08-09 13:59:06,314-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 13:59:06,314-0500 INFO ChannelManager BufferingChannel handling channel exception
+2013-08-09 13:59:06,314-0500 INFO ChannelManager Channel already shut down
+2013-08-09 13:59:06,393-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:06,621-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:06,621-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:06,645-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:59:06,728-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:59:06,893-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:07,121-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:07,121-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:07,394-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:07,622-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:07,622-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:07,894-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:08,122-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:08,122-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:08,394-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:08,623-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:08,623-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:08,895-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:09,123-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:09,123-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:09,295-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: 32ms, rtt: 161ms
+2013-08-09 13:59:09,395-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:09,623-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:09,624-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:09,895-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:10,124-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:10,124-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:10,395-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:10,624-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:10,625-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:10,896-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:11,125-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:11,125-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:11,396-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:11,625-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:11,625-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:11,896-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:12,126-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:12,126-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:12,397-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:12,626-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:12,626-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:12,897-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:59:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:59:13,126-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:13,127-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:13,397-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:13,627-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:13,627-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:13,627-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:59:13,897-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:14,127-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:14,127-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:14,398-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:14,398-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:59:14,628-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:14,628-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:14,898-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:15,128-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:15,128-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:15,398-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:15,629-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:15,629-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:15,899-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:16,129-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:16,129-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:16,399-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:16,629-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:16,630-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:16,655-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:59:16,728-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:59:16,899-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:17,130-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:17,130-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:17,399-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:17,630-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:17,630-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:17,900-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:18,131-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:18,131-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:18,400-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:18,631-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:18,631-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:18,900-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:19,131-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:19,132-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:19,401-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:19,632-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:19,632-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:19,901-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:20,132-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:20,132-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:20,401-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:20,633-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:20,633-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:20,901-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:21,133-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:21,133-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:21,402-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:21,633-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:21,634-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:21,902-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:22,134-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:22,134-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:22,402-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:22,634-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:22,634-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:22,903-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:59:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:59:23,135-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:23,135-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:23,303-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -27ms, rtt: 161ms
+2013-08-09 13:59:23,403-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:23,635-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:23,635-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:23,635-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:59:23,903-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:24,136-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:24,136-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:24,403-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:24,404-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:59:24,636-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:24,636-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:24,904-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:25,136-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:25,137-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:25,404-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:25,637-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:25,637-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:25,904-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:26,137-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:26,137-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:26,405-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:26,638-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:26,638-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:26,664-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:59:26,728-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:59:26,905-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:27,138-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:27,138-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:27,405-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:27,638-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:27,639-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:27,906-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:28,139-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:28,139-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:28,406-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:28,639-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:28,639-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:28,906-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:29,140-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:29,140-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:29,406-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:29,640-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:29,640-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:29,907-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:30,140-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:30,140-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:30,407-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:30,641-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:30,641-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:30,907-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:31,141-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:31,141-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:31,408-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:31,641-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:31,642-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:31,908-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:32,142-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:32,142-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:32,408-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:32,642-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:32,642-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:32,757-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: 19ms, rtt: 155ms
+2013-08-09 13:59:32,908-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:59:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:59:33,143-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:33,143-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:33,409-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:33,643-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:33,643-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:33,643-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:59:33,909-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:34,143-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:34,144-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:34,409-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:34,409-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:59:34,644-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:34,644-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:34,910-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:35,144-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:35,145-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:35,410-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:35,645-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:35,645-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:35,910-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:36,145-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:36,145-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:36,411-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:36,645-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:36,645-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:36,671-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:59:36,728-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:59:36,911-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:37,146-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:37,146-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:37,411-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:37,646-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:37,646-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:37,912-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:38,146-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:38,146-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:38,412-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:38,647-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:38,647-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:38,912-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:39,147-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:39,147-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:39,412-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:39,647-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:39,647-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:39,751-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: 23ms, rtt: 160ms
+2013-08-09 13:59:39,913-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:40,148-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:40,148-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:40,413-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:40,648-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:40,648-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:40,913-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:41,148-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:41,149-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:41,414-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:41,649-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:41,649-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:41,914-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:42,149-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:42,149-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:42,414-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:42,650-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:42,650-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:42,915-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:59:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:59:43,150-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:43,150-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:43,415-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:43,650-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:43,650-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:43,650-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:59:43,915-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:44,151-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:44,151-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:44,416-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:44,416-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:59:44,651-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:44,651-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:44,916-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:45,151-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:45,151-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:45,416-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:45,652-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:45,652-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:45,917-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:46,152-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:46,152-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:46,417-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:46,652-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:46,653-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:46,682-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:59:46,728-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:59:46,917-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:47,153-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:47,153-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:47,417-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:47,653-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:47,653-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:47,918-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:48,154-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:48,154-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:48,418-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:48,654-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:48,654-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:48,918-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:49,154-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:49,155-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:49,419-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:49,655-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:49,655-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:49,919-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:50,155-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:50,155-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:50,419-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:50,656-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:50,656-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:50,920-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:51,156-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:51,156-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:51,420-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:51,656-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:51,657-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:51,920-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:52,157-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:52,157-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:52,420-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:52,657-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:52,657-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:52,921-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:52,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 13:59:52,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 13:59:53,158-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:53,158-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:53,421-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:53,658-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:53,658-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:53,658-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 13:59:53,921-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:54,159-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:54,159-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:54,422-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:54,422-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 13:59:54,659-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:54,659-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:54,922-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:55,159-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:55,159-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:55,422-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:55,660-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:55,660-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:55,922-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:56,160-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:56,160-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:56,423-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:56,661-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:56,661-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:56,694-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 13:59:56,728-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 13:59:56,923-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:57,161-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:57,161-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:57,423-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:57,661-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:57,661-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:57,924-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:58,162-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:58,162-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:58,185-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -22ms, rtt: 160ms
+2013-08-09 13:59:58,424-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:58,662-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:58,662-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:58,924-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:59,162-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:59,163-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:59,424-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:59,663-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 13:59:59,663-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 13:59:59,925-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:00,163-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:00,163-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:00,425-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:00,664-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:00,664-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:00,925-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:01,164-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:01,164-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:01,426-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:01,664-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:01,665-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:01,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:02,165-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:02,165-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:02,426-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:02,665-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:02,665-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:02,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:00:02,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 14:00:03,165-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:03,166-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:03,427-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:03,666-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:03,666-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:03,666-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:00:03,927-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:04,166-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:04,166-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:04,427-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:04,427-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:00:04,666-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:04,667-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:04,928-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:05,167-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:05,167-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:05,428-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:05,667-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:05,667-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:05,928-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:06,167-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:06,168-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:06,428-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:06,668-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:06,668-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:06,715-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 14:00:06,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:00:06,929-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:07,168-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:07,168-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:07,429-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:07,668-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:07,669-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:07,929-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:08,169-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:08,169-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:08,429-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:08,669-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:08,669-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:08,897-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-135808.183, now=130809-140008.897, channel=TCP-null
+2013-08-09 14:00:08,897-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 14:00:08,897-0500 INFO ChannelManager TCP-null handling channel exception
+2013-08-09 14:00:08,898-0500 INFO AbstractTCPChannel null: Channel shut down
+2013-08-09 14:00:08,898-0500 INFO MetaChannel MetaChannel[cps-58539] -> TCP-null bind -> BufferingChannel
+2013-08-09 14:00:08,898-0500 INFO Multiplexer Unregistering channel TCP-null
+2013-08-09 14:00:08,898-0500 INFO ChannelContext Notifying commands and handlers about exception
+2013-08-09 14:00:08,898-0500 INFO ChannelManager Channel exception handled
+2013-08-09 14:00:08,909-0500 INFO Multiplexer Channel is closed. Removing.
+2013-08-09 14:00:08,909-0500 INFO Multiplexer Exception in channel step
+java.io.IOException: Stream closed.
+ at java.net.PlainSocketImpl.available(PlainSocketImpl.java:452)
+ at java.net.SocketInputStream.available(SocketInputStream.java:217)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.step(AbstractStreamKarajanChannel.java:105)
+ at org.globus.cog.karajan.workflow.service.channels.Multiplexer.run(Multiplexer.java:70)
+2013-08-09 14:00:08,910-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 14:00:08,910-0500 INFO ChannelManager TCP-null handling channel exception
+2013-08-09 14:00:08,910-0500 INFO ChannelManager Channel already shut down
+2013-08-09 14:00:08,910-0500 INFO Multiplexer Removing faulty channel TCP-null
+2013-08-09 14:00:08,930-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:09,169-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:09,170-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:09,430-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:09,670-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:09,670-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:09,930-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:10,170-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:10,170-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:10,208-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: 27ms, rtt: 160ms
+2013-08-09 14:00:10,430-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:10,670-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:10,671-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:10,930-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:11,171-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:11,171-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:11,250-0500 INFO HeartBeatCommand TCP-54.244.171.51-000000 up latency: 25ms, rtt: 155ms
+2013-08-09 14:00:11,431-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:11,671-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:11,671-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:11,931-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:12,171-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:12,172-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:12,431-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:12,672-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:12,672-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:12,932-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:00:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 14:00:13,172-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:13,172-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:13,432-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:13,673-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:13,673-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:13,673-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:00:13,932-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:14,173-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:14,173-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:14,433-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:14,433-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:00:14,673-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:14,673-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:14,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:15,174-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:15,174-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:15,433-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:15,674-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:15,674-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:15,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:16,174-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:16,175-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:16,434-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:16,675-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:16,675-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:16,719-0500 INFO Multiplexer No streams
+2013-08-09 14:00:16,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:00:16,934-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:17,175-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:17,175-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:17,434-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:17,675-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:17,676-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:17,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:18,176-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:18,176-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:18,435-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:18,676-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:18,676-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:18,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:19,176-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:19,177-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:19,435-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:19,677-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:19,677-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:19,936-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:20,177-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:20,177-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:20,436-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:20,678-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:20,678-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:20,936-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:21,178-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:21,178-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:21,437-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:21,678-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:21,678-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:21,937-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:22,179-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:22,179-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:22,437-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:22,679-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:22,679-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:22,937-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:00:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 14:00:23,179-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:23,180-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:23,438-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:23,680-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:23,680-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:23,680-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:00:23,938-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:24,180-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:24,180-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:24,438-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:24,438-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:00:24,681-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:24,681-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:24,939-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:25,181-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:25,181-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:25,439-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:25,681-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:25,681-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:25,939-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:26,182-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:26,182-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:26,439-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:26,682-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:26,682-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:26,725-0500 INFO Multiplexer No streams
+2013-08-09 14:00:26,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:00:26,940-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:27,182-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:27,182-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:27,440-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:27,683-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:27,683-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:27,940-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:28,183-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:28,183-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:28,440-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:28,683-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:28,683-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:28,941-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:29,184-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:29,184-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:29,441-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:29,684-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:29,684-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:29,941-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:30,184-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:30,185-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:30,442-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:30,685-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:30,685-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:30,942-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:31,185-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:31,185-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:31,442-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:31,685-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:31,686-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:31,942-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:32,186-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:32,186-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:32,443-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:32,686-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:32,686-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:32,943-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:32,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:00:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 14:00:33,068-0500 INFO HeartBeatCommand TCP-54.212.81.224-000000 up latency: -30ms, rtt: 161ms
+2013-08-09 14:00:33,187-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:33,187-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:33,443-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:33,687-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:33,687-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:33,687-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:00:33,944-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:34,187-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:34,187-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:34,444-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:34,444-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:00:34,688-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:34,688-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:34,944-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:35,188-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:35,188-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:35,444-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:35,689-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:35,689-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:35,945-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:36,189-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:36,189-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:36,445-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:36,689-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:36,690-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:36,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:00:36,733-0500 INFO Multiplexer No streams
+2013-08-09 14:00:36,945-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:37,190-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:37,190-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:37,446-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:37,690-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:37,690-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:37,946-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:38,190-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:38,191-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:38,446-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:38,691-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:38,691-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:38,947-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:39,191-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:39,191-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:39,447-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:39,691-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:39,692-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:39,947-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:40,192-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:40,192-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:40,447-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:40,666-0500 INFO HeartBeatCommand TCP-54.212.37.161-000000 up latency: 19ms, rtt: 161ms
+2013-08-09 14:00:40,692-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:40,692-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:40,948-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:41,193-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:41,193-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:41,448-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:41,693-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:41,693-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:41,948-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:42,193-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:42,194-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:42,448-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:42,694-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:42,694-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:42,949-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:00:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 60.48 MB
+2013-08-09 14:00:43,194-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:43,194-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:43,449-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:43,694-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:43,695-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:43,695-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:00:43,949-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:44,195-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:44,195-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:44,449-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:44,450-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:00:44,695-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:44,695-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:44,950-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:45,196-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:45,196-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:45,450-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:45,696-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:45,696-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:45,950-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:46,196-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:46,196-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:46,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:46,697-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:46,697-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:46,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:00:46,741-0500 INFO Multiplexer No streams
+2013-08-09 14:00:46,951-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:47,197-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:47,197-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:47,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:47,697-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:47,697-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:47,951-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:48,198-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:48,198-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:48,452-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:48,648-0500 INFO Multiplexer (0) Scheduling TCP-null for addition
+2013-08-09 14:00:48,648-0500 INFO AbstractTCPChannel Channel started: TCP-null
+2013-08-09 14:00:48,669-0500 INFO ChannelConfigurationHandler Channel id: u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffe
+2013-08-09 14:00:48,669-0500 INFO MetaChannel MetaChannel[cps-58546] -> null bind -> TCP-null
+2013-08-09 14:00:48,669-0500 INFO RequestHandler Handler(tag: 1, CHANNELCONFIG) unregistering (send)
+2013-08-09 14:00:48,698-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:48,698-0500 INFO ThrottleManager mem=60.48 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:48,710-0500 INFO RequestHandler Handler(tag: 2, CONFIGSERVICE) unregistering (send)
+2013-08-09 14:00:48,710-0500 INFO Sender Sender TCPChannel queue size: 0
+2013-08-09 14:00:48,811-0500 INFO RequestHandler Handler(tag: 4, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,812-0500 INFO RequestHandler Handler(tag: 3, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,813-0500 INFO RequestHandler Handler(tag: 5, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,813-0500 INFO RequestHandler Handler(tag: 6, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,814-0500 INFO RequestHandler Handler(tag: 7, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,815-0500 INFO RequestHandler Handler(tag: 8, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,815-0500 INFO RequestHandler Handler(tag: 9, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,816-0500 INFO RequestHandler Handler(tag: 10, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,816-0500 INFO RequestHandler Handler(tag: 11, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,817-0500 INFO RequestHandler Handler(tag: 12, SUBMITJOB) unregistering (send)
+2013-08-09 14:00:48,836-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=0 Cpus sleeping: 1
+2013-08-09 14:00:48,836-0500 INFO Cpu 54.212.81.224:0 (quality: 3.0) submitting urn:1376074848034-1376074606752-1376074606753: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_7.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_7.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,836-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848034-1376074606752-1376074606753) Submitting
+2013-08-09 14:00:48,837-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=6 Cpus sleeping: 1
+2013-08-09 14:00:48,837-0500 INFO Cpu 54.212.37.161:6 (quality: 2.0) submitting urn:1376074848040-1376074606755-1376074606756: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_9.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_9.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,837-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848040-1376074606755-1376074606756) Submitting
+2013-08-09 14:00:48,837-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=3 Cpus sleeping: 1
+2013-08-09 14:00:48,838-0500 INFO Cpu 54.212.81.224:3 (quality: 2.0) submitting urn:1376074848039-1376074606758-1376074606759: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_3.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_3.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,838-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848039-1376074606758-1376074606759) Submitting
+2013-08-09 14:00:48,838-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=2 Cpus sleeping: 1
+2013-08-09 14:00:48,838-0500 INFO Cpu 54.244.171.51:2 (quality: 2.0) submitting urn:1376074848041-1376074606761-1376074606762: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_1.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_1.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,838-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848041-1376074606761-1376074606762) Submitting
+2013-08-09 14:00:48,839-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=2 Cpus sleeping: 1
+2013-08-09 14:00:48,839-0500 INFO Cpu 54.212.81.224:2 (quality: 2.0) submitting urn:1376074848035-1376074606764-1376074606765: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_5.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_5.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,839-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848035-1376074606764-1376074606765) Submitting
+2013-08-09 14:00:48,839-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=3 Cpus sleeping: 1
+2013-08-09 14:00:48,839-0500 INFO Cpu 54.244.171.51:3 (quality: 2.0) submitting urn:1376074848036-1376074606767-1376074606768: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_0.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_0.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,839-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848036-1376074606767-1376074606768) Submitting
+2013-08-09 14:00:48,840-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=0 Cpus sleeping: 1
+2013-08-09 14:00:48,840-0500 INFO Cpu 54.244.171.51:0 (quality: 2.0) submitting urn:1376074848033-1376074606770-1376074606771: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_2.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_2.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,840-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848033-1376074606770-1376074606771) Submitting
+2013-08-09 14:00:48,840-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=6 Cpus sleeping: 1
+2013-08-09 14:00:48,841-0500 INFO Cpu 54.244.171.51:6 (quality: 2.0) submitting urn:1376074848042-1376074606773-1376074606774: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_8.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_8.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,841-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848042-1376074606773-1376074606774) Submitting
+2013-08-09 14:00:48,841-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=7 Cpus sleeping: 1
+2013-08-09 14:00:48,841-0500 INFO Cpu 54.244.171.51:7 (quality: 2.0) submitting urn:1376074848037-1376074606776-1376074606777: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_4.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_4.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,841-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848037-1376074606776-1376074606777) Submitting
+2013-08-09 14:00:48,842-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=0 Cpus sleeping: 1
+2013-08-09 14:00:48,842-0500 INFO Cpu 54.212.37.161:0 (quality: 2.0) submitting urn:1376074848038-1376074606779-1376074606780: /bin/bash _swiftwrap.staging -e /bin/bash -out output/sim_6.out -err stderr.txt -i -d output -if simulate.sh|bias.dat -of output/sim_6.out -k -cdmfile -status provider -a simulate.sh 1 100 bias.dat 100000 10
+2013-08-09 14:00:48,842-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848038-1376074606779-1376074606780) Submitting
+2013-08-09 14:00:48,842-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=5 Cpus sleeping: 1
+2013-08-09 14:00:48,842-0500 DEBUG Cpu 54.212.37.161:5 sleeping
+2013-08-09 14:00:48,842-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=1 Cpus sleeping: 2
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.244.171.51:1 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=7 Cpus sleeping: 3
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.81.224:7 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=4 Cpus sleeping: 4
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.81.224:4 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=4 Cpus sleeping: 5
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.244.171.51:4 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=4 Cpus sleeping: 6
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.37.161:4 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=1 Cpus sleeping: 7
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.37.161:1 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=2 Cpus sleeping: 8
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.37.161:2 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=3 Cpus sleeping: 9
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.37.161:3 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=6 Cpus sleeping: 10
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.81.224:6 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.37.161 id=7 Cpus sleeping: 11
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.37.161:7 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.244.171.51 id=5 Cpus sleeping: 12
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.244.171.51:5 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=5 Cpus sleeping: 13
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.81.224:5 sleeping
+2013-08-09 14:00:48,843-0500 DEBUG Cpu requesting work: block=54.212.81.224 id=1 Cpus sleeping: 14
+2013-08-09 14:00:48,843-0500 DEBUG Cpu 54.212.81.224:1 sleeping
+2013-08-09 14:00:48,902-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848034-1376074606752-1376074606753) Submitted
+2013-08-09 14:00:48,903-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848034-1376074606752-1376074606753) Stagein workerid=000000
+2013-08-09 14:00:48,903-0500 INFO RequestHandler Handler(tag: 4065, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,903-0500 INFO GetFileHandler Handler(tag: 4066, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,904-0500 INFO GetFileHandler Handler(tag: 4066, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,904-0500 INFO GetFileHandler Handler(tag: 4066, GET) -> 2
+2013-08-09 14:00:48,904-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848039-1376074606758-1376074606759) Submitted
+2013-08-09 14:00:48,908-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848041-1376074606761-1376074606762) Submitted
+2013-08-09 14:00:48,909-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848041-1376074606761-1376074606762) Stagein workerid=000000
+2013-08-09 14:00:48,909-0500 INFO RequestHandler Handler(tag: 2516, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,910-0500 INFO GetFileHandler Handler(tag: 2517, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,910-0500 INFO GetFileHandler Handler(tag: 2517, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,910-0500 INFO GetFileHandler Handler(tag: 2517, GET) -> 4
+2013-08-09 14:00:48,910-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848036-1376074606767-1376074606768) Submitted
+2013-08-09 14:00:48,910-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848036-1376074606767-1376074606768) Stagein workerid=000000
+2013-08-09 14:00:48,911-0500 INFO RequestHandler Handler(tag: 2518, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,911-0500 INFO GetFileHandler Handler(tag: 2519, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,911-0500 INFO GetFileHandler Handler(tag: 2519, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,911-0500 INFO GetFileHandler Handler(tag: 2519, GET) -> 6
+2013-08-09 14:00:48,915-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848040-1376074606755-1376074606756) Submitted
+2013-08-09 14:00:48,915-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848040-1376074606755-1376074606756) Stagein workerid=000000
+2013-08-09 14:00:48,915-0500 INFO RequestHandler Handler(tag: 1397, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,916-0500 INFO GetFileHandler Handler(tag: 1398, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,916-0500 INFO GetFileHandler Handler(tag: 1398, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,916-0500 INFO GetFileHandler Handler(tag: 1398, GET) -> 8
+2013-08-09 14:00:48,918-0500 INFO GetFileHandler Handler(tag: 4066, GET) sending length: 378, 912753321
+2013-08-09 14:00:48,952-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:48,957-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848033-1376074606770-1376074606771) Submitted
+2013-08-09 14:00:48,958-0500 INFO GetFileHandler Handler(tag: 4066, GET) unregistering (last)
+2013-08-09 14:00:48,959-0500 INFO GetFileHandler Handler(tag: 2517, GET) sending length: 378, 1040288884
+2013-08-09 14:00:48,959-0500 INFO GetFileHandler Handler(tag: 2517, GET) unregistering (last)
+2013-08-09 14:00:48,959-0500 INFO GetFileHandler Handler(tag: 2519, GET) sending length: 378, 1260137319
+2013-08-09 14:00:48,959-0500 INFO GetFileHandler Handler(tag: 2519, GET) unregistering (last)
+2013-08-09 14:00:48,960-0500 INFO GetFileHandler Handler(tag: 1398, GET) sending length: 378, 1290662793
+2013-08-09 14:00:48,960-0500 INFO GetFileHandler Handler(tag: 1398, GET) unregistering (last)
+2013-08-09 14:00:48,962-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848039-1376074606758-1376074606759) Stagein workerid=000000
+2013-08-09 14:00:48,962-0500 INFO RequestHandler Handler(tag: 4067, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,963-0500 INFO GetFileHandler Handler(tag: 4068, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,963-0500 INFO GetFileHandler Handler(tag: 4068, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,963-0500 INFO GetFileHandler Handler(tag: 4068, GET) -> 10
+2013-08-09 14:00:48,963-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848035-1376074606764-1376074606765) Submitted
+2013-08-09 14:00:48,964-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848035-1376074606764-1376074606765) Stagein workerid=000000
+2013-08-09 14:00:48,964-0500 INFO RequestHandler Handler(tag: 4069, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,964-0500 INFO GetFileHandler Handler(tag: 4070, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,964-0500 INFO GetFileHandler Handler(tag: 4070, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,964-0500 INFO GetFileHandler Handler(tag: 4070, GET) -> 12
+2013-08-09 14:00:48,965-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848033-1376074606770-1376074606771) Stagein workerid=000000
+2013-08-09 14:00:48,965-0500 INFO RequestHandler Handler(tag: 2520, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,965-0500 INFO GetFileHandler Handler(tag: 2521, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,965-0500 INFO GetFileHandler Handler(tag: 2521, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,965-0500 INFO GetFileHandler Handler(tag: 2521, GET) -> 14
+2013-08-09 14:00:48,966-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848042-1376074606773-1376074606774) Submitted
+2013-08-09 14:00:48,966-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848042-1376074606773-1376074606774) Stagein workerid=000000
+2013-08-09 14:00:48,966-0500 INFO RequestHandler Handler(tag: 2522, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,966-0500 INFO GetFileHandler Handler(tag: 2523, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,967-0500 INFO GetFileHandler Handler(tag: 2523, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,967-0500 INFO GetFileHandler Handler(tag: 2523, GET) -> 16
+2013-08-09 14:00:48,967-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848037-1376074606776-1376074606777) Submitted
+2013-08-09 14:00:48,967-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848038-1376074606779-1376074606780) Submitted
+2013-08-09 14:00:48,968-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848037-1376074606776-1376074606777) Stagein workerid=000000
+2013-08-09 14:00:48,968-0500 INFO RequestHandler Handler(tag: 2524, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,968-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848038-1376074606779-1376074606780) Stagein workerid=000000
+2013-08-09 14:00:48,968-0500 INFO RequestHandler Handler(tag: 1399, JOBSTATUS) unregistering (send)
+2013-08-09 14:00:48,969-0500 INFO GetFileHandler Handler(tag: 2525, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,969-0500 INFO GetFileHandler Handler(tag: 2525, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,969-0500 INFO GetFileHandler Handler(tag: 2525, GET) -> 19
+2013-08-09 14:00:48,969-0500 INFO GetFileHandler Handler(tag: 1400, GET) request complete; src=proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,969-0500 INFO GetFileHandler Handler(tag: 1400, GET) reader: PR proxy://u-522a0db7-1406473d990--8000-u63ed4446-140647027d0--7ffeS/simulate.sh
+2013-08-09 14:00:48,969-0500 INFO GetFileHandler Handler(tag: 1400, GET) -> 20
+2013-08-09 14:00:49,027-0500 WARN RemoteLogHandler getPinnedFile(): Could not link: No such file or directory
+2013-08-09 14:00:49,027-0500 INFO RequestHandler Handler(tag: 4071, RLOG) unregistering (send)
+2013-08-09 14:00:49,028-0500 WARN RemoteLogHandler getPinnedFile(): Could not link: No such file or directory
+2013-08-09 14:00:49,028-0500 INFO RequestHandler Handler(tag: 2526, RLOG) unregistering (send)
+2013-08-09 14:00:49,030-0500 WARN RemoteLogHandler getPinnedFile(): Could not link: No such file or directory
+2013-08-09 14:00:49,030-0500 INFO RequestHandler Handler(tag: 1401, RLOG) unregistering (send)
+2013-08-09 14:00:49,040-0500 INFO GetFileHandler Handler(tag: 4068, GET) sending length: 378, 532404146
+2013-08-09 14:00:49,041-0500 INFO GetFileHandler Handler(tag: 4068, GET) unregistering (last)
+2013-08-09 14:00:49,041-0500 INFO GetFileHandler Handler(tag: 4070, GET) sending length: 378, 1716894611
+2013-08-09 14:00:49,041-0500 INFO GetFileHandler Handler(tag: 4070, GET) unregistering (last)
+2013-08-09 14:00:49,041-0500 INFO GetFileHandler Handler(tag: 2521, GET) sending length: 378, 1790591505
+2013-08-09 14:00:49,042-0500 INFO GetFileHandler Handler(tag: 2521, GET) unregistering (last)
+2013-08-09 14:00:49,042-0500 INFO GetFileHandler Handler(tag: 2523, GET) sending length: 378, 118572128
+2013-08-09 14:00:49,042-0500 INFO GetFileHandler Handler(tag: 2523, GET) unregistering (last)
+2013-08-09 14:00:49,042-0500 INFO GetFileHandler Handler(tag: 2525, GET) sending length: 378, 2106232034
+2013-08-09 14:00:49,042-0500 INFO GetFileHandler Handler(tag: 2525, GET) unregistering (last)
+2013-08-09 14:00:49,042-0500 INFO GetFileHandler Handler(tag: 1400, GET) sending length: 378, 147407825
+2013-08-09 14:00:49,042-0500 INFO GetFileHandler Handler(tag: 1400, GET) unregistering (last)
+2013-08-09 14:00:49,452-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:49,543-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:49,543-0500 INFO ThrottleManager mem=90.72 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:49,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:50,043-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:50,044-0500 INFO ThrottleManager mem=147.42 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:50,453-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:50,544-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:50,544-0500 INFO ThrottleManager mem=31.83 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:50,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:51,044-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:51,044-0500 INFO ThrottleManager mem=96.09 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:51,453-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:51,544-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:51,545-0500 INFO ThrottleManager mem=163.57 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:51,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:52,045-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:52,045-0500 INFO ThrottleManager mem=46.2 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:52,454-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:52,545-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:52,545-0500 INFO ThrottleManager mem=113.16 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:52,954-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:00:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 724.62 MB, Heap used: 168.65 MB
+2013-08-09 14:00:53,045-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:53,045-0500 INFO ThrottleManager mem=182.04 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:53,454-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:53,546-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:53,546-0500 INFO ThrottleManager mem=63.11 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:53,955-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:54,046-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:54,046-0500 INFO ThrottleManager mem=130.88 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:54,046-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:00:54,455-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:54,455-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:00:54,546-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:54,546-0500 INFO ThrottleManager mem=9.84 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:54,955-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:55,047-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:55,047-0500 INFO ThrottleManager mem=78.07 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:55,456-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:55,547-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:55,547-0500 INFO ThrottleManager mem=145.75 MB, heap=724.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:55,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:56,047-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:56,047-0500 INFO ThrottleManager mem=23.78 MB, heap=689.56 MB, maxHeap=10.5 GB
+2013-08-09 14:00:56,456-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:56,548-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:56,548-0500 INFO ThrottleManager mem=87.62 MB, heap=689.56 MB, maxHeap=10.5 GB
+2013-08-09 14:00:56,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:00:56,754-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 14:00:56,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:57,048-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:57,048-0500 INFO ThrottleManager mem=156.89 MB, heap=689.56 MB, maxHeap=10.5 GB
+2013-08-09 14:00:57,457-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:57,548-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:57,548-0500 INFO ThrottleManager mem=40.48 MB, heap=684.94 MB, maxHeap=10.5 GB
+2013-08-09 14:00:57,957-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:58,049-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:58,049-0500 INFO ThrottleManager mem=107.14 MB, heap=684.94 MB, maxHeap=10.5 GB
+2013-08-09 14:00:58,457-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:58,549-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:58,549-0500 INFO ThrottleManager mem=173.81 MB, heap=684.94 MB, maxHeap=10.5 GB
+2013-08-09 14:00:58,957-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:59,049-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:59,049-0500 INFO ThrottleManager mem=60.01 MB, heap=679.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:59,458-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:59,550-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:00:59,550-0500 INFO ThrottleManager mem=125.51 MB, heap=679.62 MB, maxHeap=10.5 GB
+2013-08-09 14:00:59,958-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:00,050-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:00,050-0500 INFO ThrottleManager mem=18.12 MB, heap=675.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:00,458-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:00,550-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:00,550-0500 INFO ThrottleManager mem=82.5 MB, heap=675.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:00,959-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:01,051-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:01,051-0500 INFO ThrottleManager mem=150.27 MB, heap=675.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:01,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:01,551-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:01,551-0500 INFO ThrottleManager mem=44.35 MB, heap=671.38 MB, maxHeap=10.5 GB
+2013-08-09 14:01:01,959-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:02,051-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:02,051-0500 INFO ThrottleManager mem=110.97 MB, heap=671.38 MB, maxHeap=10.5 GB
+2013-08-09 14:01:02,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:02,552-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:02,552-0500 INFO ThrottleManager mem=7.5 MB, heap=667.5 MB, maxHeap=10.5 GB
+2013-08-09 14:01:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:01:02,960-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:02,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 667.5 MB, Heap used: 64.34 MB
+2013-08-09 14:01:03,052-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:03,052-0500 INFO ThrottleManager mem=77.45 MB, heap=667.5 MB, maxHeap=10.5 GB
+2013-08-09 14:01:03,460-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:03,552-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:03,553-0500 INFO ThrottleManager mem=142.99 MB, heap=667.5 MB, maxHeap=10.5 GB
+2013-08-09 14:01:03,960-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:04,053-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:04,053-0500 INFO ThrottleManager mem=46.83 MB, heap=665.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:04,053-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:01:04,460-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:04,460-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:01:04,553-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:04,554-0500 INFO ThrottleManager mem=114.06 MB, heap=665.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:04,961-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:05,054-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:05,054-0500 INFO ThrottleManager mem=19.7 MB, heap=660.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:05,461-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:05,554-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:05,554-0500 INFO ThrottleManager mem=85.41 MB, heap=660.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:05,961-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:06,054-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:06,055-0500 INFO ThrottleManager mem=151.12 MB, heap=660.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:06,461-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:06,555-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:06,555-0500 INFO ThrottleManager mem=58.99 MB, heap=658.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:06,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:01:06,762-0500 INFO Multiplexer Avg stream buf: 0
+2013-08-09 14:01:06,962-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:07,055-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:07,055-0500 INFO ThrottleManager mem=127.3 MB, heap=658.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:07,462-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:07,555-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:07,556-0500 INFO ThrottleManager mem=39.74 MB, heap=653.25 MB, maxHeap=10.5 GB
+2013-08-09 14:01:07,790-0500 INFO AbstractKarajanChannel Channel config: null
+2013-08-09 14:01:07,790-0500 INFO ChannelManager TCP-54.212.81.224-000000 handling channel exception
+java.io.IOException: Broken pipe
+ at sun.nio.ch.FileDispatcher.write0(Native Method)
+ at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:29)
+ at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:69)
+ at sun.nio.ch.IOUtil.write(IOUtil.java:40)
+ at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:336)
+ at org.globus.cog.karajan.workflow.service.channels.NIOSender.write(NIOSender.java:168)
+ at org.globus.cog.karajan.workflow.service.channels.NIOSender.run(NIOSender.java:133)
+2013-08-09 14:01:07,791-0500 INFO AbstractTCPChannel 54.212.81.224-000000: Channel shut down
+2013-08-09 14:01:07,791-0500 INFO MetaChannel MetaChannel[worker-1] -> TCP-54.212.81.224-000000 bind -> NullChannel
+2013-08-09 14:01:07,791-0500 INFO AbstractStreamKarajanChannel Using threaded sender for TCP-54.212.81.224-000000
+2013-08-09 14:01:07,792-0500 INFO ChannelContext Notifying commands and handlers about exception
+2013-08-09 14:01:07,792-0500 INFO ChannelContext => Command(tag: 14, HEARTBEAT)
+2013-08-09 14:01:07,792-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 14:01:07,792-0500 INFO Node Node [ip-10-224-24-142] 0 lost connection to worker; removing node from block.
+2013-08-09 14:01:07,793-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848034-1376074606752-1376074606753) Active
+2013-08-09 14:01:07,793-0500 INFO Sender Sender TCPChannel queue size: 4
+2013-08-09 14:01:07,793-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848034-1376074606752-1376074606753) Failed Task failed: Connection to worker lost
+2013-08-09 14:01:07,793-0500 INFO Cpu 54.212.81.224:0 jobTerminated
+2013-08-09 14:01:07,793-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=0
+2013-08-09 14:01:07,793-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848035-1376074606764-1376074606765) Active
+2013-08-09 14:01:07,793-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848035-1376074606764-1376074606765) Failed Task failed: Connection to worker lost
+2013-08-09 14:01:07,793-0500 INFO Cpu 54.212.81.224:2 jobTerminated
+2013-08-09 14:01:07,793-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=2
+2013-08-09 14:01:07,794-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848039-1376074606758-1376074606759) Active
+2013-08-09 14:01:07,794-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848039-1376074606758-1376074606759) Failed Task failed: Connection to worker lost
+2013-08-09 14:01:07,794-0500 INFO Cpu 54.212.81.224:3 jobTerminated
+2013-08-09 14:01:07,794-0500 DEBUG Cpu ready for work: block=54.212.81.224 id=3
+2013-08-09 14:01:07,794-0500 INFO MetaChannel MetaChannel[worker-1] -> NullChannel bind -> NullChannel
+2013-08-09 14:01:07,794-0500 WARN BlockQueueProcessor Failed to send worker status update to client
+org.globus.cog.karajan.workflow.service.channels.ChannelException: Channel died and no contact available
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.connect(ChannelManager.java:234)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:255)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:226)
+ at org.globus.cog.abstraction.coaster.service.job.manager.PassiveQueueProcessor.nodeRemoved(PassiveQueueProcessor.java:109)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Block.removeNode(Block.java:561)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Node.channelShutDown(Node.java:160)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelContext.channelShutDown(ChannelContext.java:317)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.handleChannelException(ChannelManager.java:292)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleChannelException(AbstractKarajanChannel.java:566)
+ at org.globus.cog.karajan.workflow.service.channels.NIOSender.run(NIOSender.java:140)
+2013-08-09 14:01:07,794-0500 INFO ChannelManager Channel exception handled
+2013-08-09 14:01:07,794-0500 INFO AbstractTCPChannel 54.212.81.224-000000: Channel shut down
+2013-08-09 14:01:07,962-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:08,056-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:08,056-0500 INFO ThrottleManager mem=109.25 MB, heap=653.25 MB, maxHeap=10.5 GB
+2013-08-09 14:01:08,462-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:08,556-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:08,556-0500 INFO ThrottleManager mem=32.9 MB, heap=651.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:08,963-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:09,056-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:09,057-0500 INFO ThrottleManager mem=108.44 MB, heap=651.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:09,463-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:09,557-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:09,557-0500 INFO ThrottleManager mem=35.19 MB, heap=646.88 MB, maxHeap=10.5 GB
+2013-08-09 14:01:09,963-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:10,057-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:10,057-0500 INFO ThrottleManager mem=106.77 MB, heap=646.88 MB, maxHeap=10.5 GB
+2013-08-09 14:01:10,463-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:10,558-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:10,558-0500 INFO ThrottleManager mem=40.14 MB, heap=645.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:10,963-0500 INFO AbstractKarajanChannel Channel config: null
+2013-08-09 14:01:10,963-0500 INFO ChannelManager TCP-54.212.37.161-000000 handling channel exception
+2013-08-09 14:01:10,963-0500 INFO AbstractTCPChannel 54.212.37.161-000000: Channel shut down
+2013-08-09 14:01:10,963-0500 INFO MetaChannel MetaChannel[worker-3] -> TCP-54.212.37.161-000000 bind -> NullChannel
+2013-08-09 14:01:10,963-0500 INFO ChannelContext Notifying commands and handlers about exception
+2013-08-09 14:01:10,964-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:10,964-0500 INFO ChannelContext => Command(tag: 12, HEARTBEAT)
+2013-08-09 14:01:10,964-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 14:01:10,964-0500 INFO Node Node [ip-10-250-62-33] 0 lost connection to worker; removing node from block.
+2013-08-09 14:01:10,965-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848038-1376074606779-1376074606780) Active
+2013-08-09 14:01:10,965-0500 INFO Sender Channel IOException
+java.net.SocketException: Broken pipe
+ at java.net.SocketOutputStream.socketWrite0(Native Method)
+ at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
+ at java.net.SocketOutputStream.write(SocketOutputStream.java:124)
+ at org.globus.cog.karajan.workflow.service.channels.Sender.send(Sender.java:130)
+ at org.globus.cog.karajan.workflow.service.channels.Sender.run(Sender.java:66)
+2013-08-09 14:01:10,965-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848038-1376074606779-1376074606780) Failed Task failed: Connection to worker lost
+2013-08-09 14:01:10,965-0500 INFO Cpu 54.212.37.161:0 jobTerminated
+2013-08-09 14:01:10,965-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 14:01:10,965-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=0
+2013-08-09 14:01:10,965-0500 INFO ChannelManager TCP-null handling channel exception
+2013-08-09 14:01:10,965-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848040-1376074606755-1376074606756) Active
+2013-08-09 14:01:10,966-0500 INFO AbstractTCPChannel null: Channel shut down
+2013-08-09 14:01:10,966-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848040-1376074606755-1376074606756) Failed Task failed: Connection to worker lost
+2013-08-09 14:01:10,966-0500 INFO MetaChannel MetaChannel[cps-58546] -> TCP-null bind -> BufferingChannel
+2013-08-09 14:01:10,966-0500 INFO Cpu 54.212.37.161:6 jobTerminated
+2013-08-09 14:01:10,966-0500 DEBUG Cpu ready for work: block=54.212.37.161 id=6
+2013-08-09 14:01:10,966-0500 INFO Multiplexer Unregistering channel TCP-null
+2013-08-09 14:01:10,966-0500 INFO ChannelContext Notifying commands and handlers about exception
+2013-08-09 14:01:10,966-0500 INFO ChannelContext => Command(tag: 27, JOBSTATUS)
+2013-08-09 14:01:10,966-0500 INFO Multiplexer Channel is closed. Removing.
+2013-08-09 14:01:10,966-0500 WARN TaskNotifier Failed to send task notification
+ at org.globus.cog.abstraction.coaster.service.job.manager.TaskNotifier.sendStatus(TaskNotifier.java:76)
+ at org.globus.cog.abstraction.coaster.service.job.manager.TaskNotifier.statusChanged(TaskNotifier.java:64)
+ at org.globus.cog.abstraction.impl.common.task.TaskImpl.notifyListeners(TaskImpl.java:240)
+ at org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:228)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Job.fail(Job.java:182)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Cpu.taskFailed(Cpu.java:349)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Node.channelShutDown(Node.java:147)
+2013-08-09 14:01:10,967-0500 INFO MetaChannel MetaChannel[worker-3] -> NullChannel bind -> NullChannel
+2013-08-09 14:01:10,967-0500 INFO Multiplexer Exception in channel step
+java.io.IOException: Stream closed.
+ at java.net.PlainSocketImpl.available(PlainSocketImpl.java:452)
+ at java.net.SocketInputStream.available(SocketInputStream.java:217)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.step(AbstractStreamKarajanChannel.java:105)
+ at org.globus.cog.karajan.workflow.service.channels.Multiplexer.run(Multiplexer.java:70)
+2013-08-09 14:01:10,966-0500 WARN TaskNotifier Client could not properly process notification: null
+2013-08-09 14:01:10,967-0500 WARN BlockQueueProcessor Failed to send worker status update to client
+2013-08-09 14:01:10,967-0500 INFO ChannelContext => Command(tag: 29, JOBSTATUS)
+2013-08-09 14:01:10,968-0500 INFO ChannelManager Channel exception handled
+2013-08-09 14:01:10,968-0500 WARN TaskNotifier Client could not properly process notification: null
+2013-08-09 14:01:10,968-0500 INFO AbstractTCPChannel 54.212.37.161-000000: Channel shut down
+2013-08-09 14:01:10,968-0500 INFO ChannelContext => Command(tag: 28, JOBSTATUS)
+2013-08-09 14:01:10,968-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 14:01:10,968-0500 INFO ChannelManager TCP-null handling channel exception
+2013-08-09 14:01:10,969-0500 INFO ChannelManager Channel already shut down
+2013-08-09 14:01:10,969-0500 INFO Multiplexer Removing faulty channel TCP-null
+2013-08-09 14:01:11,058-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:11,058-0500 INFO ThrottleManager mem=118.14 MB, heap=645.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:11,464-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:11,558-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:11,559-0500 INFO ThrottleManager mem=63.56 MB, heap=640.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:11,964-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:12,059-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:12,059-0500 INFO ThrottleManager mem=11.59 MB, heap=639.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:12,465-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:12,559-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:12,559-0500 INFO ThrottleManager mem=100.23 MB, heap=639.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:01:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 635.31 MB, Heap used: 35.29 MB
+2013-08-09 14:01:12,965-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:13,060-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:13,060-0500 INFO ThrottleManager mem=53.71 MB, heap=635.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:13,465-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:13,560-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:13,560-0500 INFO ThrottleManager mem=8.64 MB, heap=633.81 MB, maxHeap=10.5 GB
+2013-08-09 14:01:13,965-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:14,060-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:14,060-0500 INFO ThrottleManager mem=96.87 MB, heap=633.81 MB, maxHeap=10.5 GB
+2013-08-09 14:01:14,061-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:01:14,466-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:14,466-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:01:14,561-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:14,561-0500 INFO ThrottleManager mem=53.91 MB, heap=630.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:14,966-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:15,061-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:15,061-0500 INFO ThrottleManager mem=15.76 MB, heap=628.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:15,466-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:15,561-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:15,562-0500 INFO ThrottleManager mem=102.45 MB, heap=628.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:15,966-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:16,062-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:16,062-0500 INFO ThrottleManager mem=66.45 MB, heap=625.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:16,467-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:16,562-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:16,562-0500 INFO ThrottleManager mem=34.18 MB, heap=623.81 MB, maxHeap=10.5 GB
+2013-08-09 14:01:16,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:01:16,765-0500 INFO Multiplexer No streams
+2013-08-09 14:01:16,967-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:17,063-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:17,066-0500 INFO ThrottleManager mem=3.27 MB, heap=620.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:17,467-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:17,566-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:17,566-0500 INFO ThrottleManager mem=89.72 MB, heap=620.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:17,968-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:18,066-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:18,066-0500 INFO ThrottleManager mem=58.15 MB, heap=619.25 MB, maxHeap=10.5 GB
+2013-08-09 14:01:18,468-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:18,566-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:18,566-0500 INFO ThrottleManager mem=32.37 MB, heap=616.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:18,968-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:19,067-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:19,067-0500 INFO ThrottleManager mem=7.47 MB, heap=614.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:19,468-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:19,567-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:19,567-0500 INFO ThrottleManager mem=95.81 MB, heap=614.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:19,969-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:20,067-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:20,067-0500 INFO ThrottleManager mem=72.42 MB, heap=612.25 MB, maxHeap=10.5 GB
+2013-08-09 14:01:20,469-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:20,568-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:20,568-0500 INFO ThrottleManager mem=49.82 MB, heap=610.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:20,969-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:21,068-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:21,068-0500 INFO ThrottleManager mem=32.25 MB, heap=608.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:21,469-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:21,568-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:21,569-0500 INFO ThrottleManager mem=13.17 MB, heap=607.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:21,970-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:22,069-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:22,069-0500 INFO ThrottleManager mem=101.56 MB, heap=607.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:22,470-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:22,569-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:22,569-0500 INFO ThrottleManager mem=85.69 MB, heap=604.88 MB, maxHeap=10.5 GB
+2013-08-09 14:01:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:01:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 603.69 MB, Heap used: 52.61 MB
+2013-08-09 14:01:22,970-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:23,070-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:23,070-0500 INFO ThrottleManager mem=72.48 MB, heap=603.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:23,470-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:23,570-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:23,570-0500 INFO ThrottleManager mem=61.37 MB, heap=601.5 MB, maxHeap=10.5 GB
+2013-08-09 14:01:23,971-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:24,070-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:24,070-0500 INFO ThrottleManager mem=49.15 MB, heap=600.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:24,070-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:01:24,471-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:24,471-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:01:24,571-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:24,571-0500 INFO ThrottleManager mem=40.5 MB, heap=598.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:24,971-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:25,071-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:25,071-0500 INFO ThrottleManager mem=32.45 MB, heap=597.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:25,472-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:25,571-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:25,571-0500 INFO ThrottleManager mem=26.42 MB, heap=595.25 MB, maxHeap=10.5 GB
+2013-08-09 14:01:25,972-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:26,072-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:26,072-0500 INFO ThrottleManager mem=20.66 MB, heap=594.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:26,474-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:26,572-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:26,572-0500 INFO ThrottleManager mem=18.66 MB, heap=592.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:26,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:01:26,769-0500 INFO Multiplexer No streams
+2013-08-09 14:01:26,974-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:27,072-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:27,072-0500 INFO ThrottleManager mem=16.52 MB, heap=591.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:27,475-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:27,573-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:27,573-0500 INFO ThrottleManager mem=14.6 MB, heap=589.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:27,975-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:28,073-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:28,073-0500 INFO ThrottleManager mem=16.04 MB, heap=588.62 MB, maxHeap=10.5 GB
+2013-08-09 14:01:28,475-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:28,573-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:28,573-0500 INFO ThrottleManager mem=9.19 MB, heap=587.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:28,975-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:29,073-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:29,074-0500 INFO ThrottleManager mem=4.14 MB, heap=586.06 MB, maxHeap=10.5 GB
+2013-08-09 14:01:29,476-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:29,574-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:29,574-0500 INFO ThrottleManager mem=10.55 MB, heap=584.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:29,976-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:30,074-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:30,074-0500 INFO ThrottleManager mem=15.18 MB, heap=583.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:30,476-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:30,574-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:30,575-0500 INFO ThrottleManager mem=22.82 MB, heap=582.38 MB, maxHeap=10.5 GB
+2013-08-09 14:01:30,977-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:31,075-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:31,075-0500 INFO ThrottleManager mem=30.24 MB, heap=581.38 MB, maxHeap=10.5 GB
+2013-08-09 14:01:31,477-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:31,575-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:31,575-0500 INFO ThrottleManager mem=38.98 MB, heap=580.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:31,977-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:32,076-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:32,076-0500 INFO ThrottleManager mem=50.47 MB, heap=579.25 MB, maxHeap=10.5 GB
+2013-08-09 14:01:32,477-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:32,576-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:32,576-0500 INFO ThrottleManager mem=60.14 MB, heap=578.06 MB, maxHeap=10.5 GB
+2013-08-09 14:01:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:01:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 577.19 MB, Heap used: 52.07 MB
+2013-08-09 14:01:32,978-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:33,076-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:33,076-0500 INFO ThrottleManager mem=71.08 MB, heap=577.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:33,478-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:33,577-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:33,577-0500 INFO ThrottleManager mem=12.27 MB, heap=575.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:33,978-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:34,077-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:34,077-0500 INFO ThrottleManager mem=26.14 MB, heap=574.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:34,077-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:01:34,478-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:34,479-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:01:34,577-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:34,577-0500 INFO ThrottleManager mem=42.46 MB, heap=573.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:34,979-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:35,078-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:35,078-0500 INFO ThrottleManager mem=59.68 MB, heap=572.38 MB, maxHeap=10.5 GB
+2013-08-09 14:01:35,479-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:35,578-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:35,578-0500 INFO ThrottleManager mem=10.19 MB, heap=570.62 MB, maxHeap=10.5 GB
+2013-08-09 14:01:35,979-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:36,078-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:36,078-0500 INFO ThrottleManager mem=29.86 MB, heap=569.88 MB, maxHeap=10.5 GB
+2013-08-09 14:01:36,479-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:36,579-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:36,579-0500 INFO ThrottleManager mem=50.27 MB, heap=569 MB, maxHeap=10.5 GB
+2013-08-09 14:01:36,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:01:36,775-0500 INFO Multiplexer No streams
+2013-08-09 14:01:36,980-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:37,079-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:37,079-0500 INFO ThrottleManager mem=7.2 MB, heap=567.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:37,480-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:37,579-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:37,580-0500 INFO ThrottleManager mem=30.95 MB, heap=566.75 MB, maxHeap=10.5 GB
+2013-08-09 14:01:37,980-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:38,080-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:38,080-0500 INFO ThrottleManager mem=54.13 MB, heap=565.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:38,483-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:38,580-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:38,580-0500 INFO ThrottleManager mem=17.8 MB, heap=564.5 MB, maxHeap=10.5 GB
+2013-08-09 14:01:38,983-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:39,080-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:39,081-0500 INFO ThrottleManager mem=45.12 MB, heap=563.81 MB, maxHeap=10.5 GB
+2013-08-09 14:01:39,483-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:39,581-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:39,581-0500 INFO ThrottleManager mem=12.54 MB, heap=562.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:39,983-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:40,081-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:40,081-0500 INFO ThrottleManager mem=41.32 MB, heap=561.81 MB, maxHeap=10.5 GB
+2013-08-09 14:01:40,484-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:40,581-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:40,582-0500 INFO ThrottleManager mem=12.17 MB, heap=560.56 MB, maxHeap=10.5 GB
+2013-08-09 14:01:40,984-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:41,082-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:41,082-0500 INFO ThrottleManager mem=42.24 MB, heap=559.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:41,484-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:41,582-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:41,582-0500 INFO ThrottleManager mem=16.18 MB, heap=558.75 MB, maxHeap=10.5 GB
+2013-08-09 14:01:41,984-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:42,083-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:42,083-0500 INFO ThrottleManager mem=49.68 MB, heap=558.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:42,485-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:42,583-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:42,583-0500 INFO ThrottleManager mem=27.39 MB, heap=557.06 MB, maxHeap=10.5 GB
+2013-08-09 14:01:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:01:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 556.5 MB, Heap used: 37.61 MB
+2013-08-09 14:01:42,985-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:43,083-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:43,083-0500 INFO ThrottleManager mem=7.13 MB, heap=555.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:43,485-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:43,584-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:43,584-0500 INFO ThrottleManager mem=40.97 MB, heap=555.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:43,985-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:44,084-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:44,084-0500 INFO ThrottleManager mem=25.06 MB, heap=554.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:44,084-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:01:44,486-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:44,486-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:01:44,584-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:44,584-0500 INFO ThrottleManager mem=10.75 MB, heap=553.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:44,986-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:45,085-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:45,085-0500 INFO ThrottleManager mem=47.84 MB, heap=552.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:45,486-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:45,585-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:45,585-0500 INFO ThrottleManager mem=36.41 MB, heap=552.06 MB, maxHeap=10.5 GB
+2013-08-09 14:01:45,987-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:46,085-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:46,085-0500 INFO ThrottleManager mem=27.3 MB, heap=551.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:46,487-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:46,586-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:46,586-0500 INFO ThrottleManager mem=19.37 MB, heap=550.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:46,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:01:46,794-0500 INFO Multiplexer No streams
+2013-08-09 14:01:46,987-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:47,086-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:47,086-0500 INFO ThrottleManager mem=12.67 MB, heap=549.44 MB, maxHeap=10.5 GB
+2013-08-09 14:01:47,487-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:47,586-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:47,586-0500 INFO ThrottleManager mem=8.01 MB, heap=548.69 MB, maxHeap=10.5 GB
+2013-08-09 14:01:47,988-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:48,086-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:48,086-0500 INFO ThrottleManager mem=2.99 MB, heap=557.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:48,488-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:48,587-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:48,587-0500 INFO ThrottleManager mem=35.58 MB, heap=556.62 MB, maxHeap=10.5 GB
+2013-08-09 14:01:48,989-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:49,087-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:49,087-0500 INFO ThrottleManager mem=18.46 MB, heap=555.56 MB, maxHeap=10.5 GB
+2013-08-09 14:01:49,490-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:49,588-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:49,588-0500 INFO ThrottleManager mem=1.91 MB, heap=554.56 MB, maxHeap=10.5 GB
+2013-08-09 14:01:49,990-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:50,088-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:50,088-0500 INFO ThrottleManager mem=36.96 MB, heap=554.06 MB, maxHeap=10.5 GB
+2013-08-09 14:01:50,490-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:50,588-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:50,588-0500 INFO ThrottleManager mem=23.43 MB, heap=553.06 MB, maxHeap=10.5 GB
+2013-08-09 14:01:50,990-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:51,089-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:51,089-0500 INFO ThrottleManager mem=13.38 MB, heap=552.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:51,491-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:51,589-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:51,589-0500 INFO ThrottleManager mem=3.74 MB, heap=551.25 MB, maxHeap=10.5 GB
+2013-08-09 14:01:51,991-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:52,089-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:52,089-0500 INFO ThrottleManager mem=42.97 MB, heap=550.81 MB, maxHeap=10.5 GB
+2013-08-09 14:01:52,491-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:52,590-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:52,590-0500 INFO ThrottleManager mem=34.83 MB, heap=549.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:52,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:01:52,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 549.06 MB, Heap used: 6.28 MB
+2013-08-09 14:01:52,991-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:53,090-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:53,090-0500 INFO ThrottleManager mem=28.79 MB, heap=549.06 MB, maxHeap=10.5 GB
+2013-08-09 14:01:53,492-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:53,591-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:53,591-0500 INFO ThrottleManager mem=25.66 MB, heap=548.31 MB, maxHeap=10.5 GB
+2013-08-09 14:01:53,992-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:54,091-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:54,091-0500 INFO ThrottleManager mem=23.5 MB, heap=547.56 MB, maxHeap=10.5 GB
+2013-08-09 14:01:54,091-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:01:54,492-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:54,492-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:01:54,591-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:54,591-0500 INFO ThrottleManager mem=23.11 MB, heap=546.81 MB, maxHeap=10.5 GB
+2013-08-09 14:01:54,992-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:55,092-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:55,092-0500 INFO ThrottleManager mem=23.59 MB, heap=546.06 MB, maxHeap=10.5 GB
+2013-08-09 14:01:55,493-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:55,592-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:55,592-0500 INFO ThrottleManager mem=25.66 MB, heap=545.38 MB, maxHeap=10.5 GB
+2013-08-09 14:01:55,993-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:56,092-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:56,092-0500 INFO ThrottleManager mem=30.2 MB, heap=544.75 MB, maxHeap=10.5 GB
+2013-08-09 14:01:56,493-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:56,593-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:56,593-0500 INFO ThrottleManager mem=34.56 MB, heap=544.12 MB, maxHeap=10.5 GB
+2013-08-09 14:01:56,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:01:56,815-0500 INFO Multiplexer No streams
+2013-08-09 14:01:56,993-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:57,093-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:57,093-0500 INFO ThrottleManager mem=2.43 MB, heap=543.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:57,494-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:57,593-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:57,593-0500 INFO ThrottleManager mem=8.57 MB, heap=542.56 MB, maxHeap=10.5 GB
+2013-08-09 14:01:57,994-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:58,094-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:58,094-0500 INFO ThrottleManager mem=16.02 MB, heap=541.94 MB, maxHeap=10.5 GB
+2013-08-09 14:01:58,494-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:58,594-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:58,594-0500 INFO ThrottleManager mem=26.24 MB, heap=541.38 MB, maxHeap=10.5 GB
+2013-08-09 14:01:58,995-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:59,095-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:59,096-0500 INFO ThrottleManager mem=1.67 MB, heap=540.62 MB, maxHeap=10.5 GB
+2013-08-09 14:01:59,495-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:59,596-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:01:59,596-0500 INFO ThrottleManager mem=15.3 MB, heap=540.19 MB, maxHeap=10.5 GB
+2013-08-09 14:01:59,995-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:00,096-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:00,096-0500 INFO ThrottleManager mem=28.61 MB, heap=539.69 MB, maxHeap=10.5 GB
+2013-08-09 14:02:00,495-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:00,596-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:00,597-0500 INFO ThrottleManager mem=7.84 MB, heap=538.88 MB, maxHeap=10.5 GB
+2013-08-09 14:02:00,996-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:01,097-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:01,097-0500 INFO ThrottleManager mem=24.2 MB, heap=538.38 MB, maxHeap=10.5 GB
+2013-08-09 14:02:01,496-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:01,597-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:01,597-0500 INFO ThrottleManager mem=8.93 MB, heap=537.62 MB, maxHeap=10.5 GB
+2013-08-09 14:02:01,996-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:02,098-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:02,098-0500 INFO ThrottleManager mem=28.06 MB, heap=537.19 MB, maxHeap=10.5 GB
+2013-08-09 14:02:02,496-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:02,598-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:02,598-0500 INFO ThrottleManager mem=13.9 MB, heap=536.62 MB, maxHeap=10.5 GB
+2013-08-09 14:02:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:02:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 536.25 MB, Heap used: 11.17 MB
+2013-08-09 14:02:02,997-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:03,098-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:03,098-0500 INFO ThrottleManager mem=2.83 MB, heap=536.06 MB, maxHeap=10.5 GB
+2013-08-09 14:02:03,497-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:03,598-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:03,599-0500 INFO ThrottleManager mem=24.93 MB, heap=535.69 MB, maxHeap=10.5 GB
+2013-08-09 14:02:03,997-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:04,099-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:04,099-0500 INFO ThrottleManager mem=16.4 MB, heap=535.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:04,099-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:02:04,497-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:04,498-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:02:04,599-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:04,600-0500 INFO ThrottleManager mem=10.02 MB, heap=534.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:04,998-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:05,100-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:05,100-0500 INFO ThrottleManager mem=5.67 MB, heap=534 MB, maxHeap=10.5 GB
+2013-08-09 14:02:05,498-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:05,600-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:05,600-0500 INFO ThrottleManager mem=1.48 MB, heap=533.5 MB, maxHeap=10.5 GB
+2013-08-09 14:02:05,998-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:06,100-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:06,101-0500 INFO ThrottleManager mem=28.7 MB, heap=533.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:06,499-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:06,601-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:06,601-0500 INFO ThrottleManager mem=26.6 MB, heap=532.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:06,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:02:06,816-0500 INFO Multiplexer No streams
+2013-08-09 14:02:06,999-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:07,101-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:07,101-0500 INFO ThrottleManager mem=26.74 MB, heap=532.19 MB, maxHeap=10.5 GB
+2013-08-09 14:02:07,499-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:07,601-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:07,602-0500 INFO ThrottleManager mem=2.04 MB, heap=531.69 MB, maxHeap=10.5 GB
+2013-08-09 14:02:07,999-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:08,102-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:08,102-0500 INFO ThrottleManager mem=5.8 MB, heap=531.31 MB, maxHeap=10.5 GB
+2013-08-09 14:02:08,500-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:08,602-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:08,602-0500 INFO ThrottleManager mem=10.03 MB, heap=530.94 MB, maxHeap=10.5 GB
+2013-08-09 14:02:09,000-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:09,102-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:09,103-0500 INFO ThrottleManager mem=15.72 MB, heap=530.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:09,500-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:09,603-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:09,603-0500 INFO ThrottleManager mem=23.33 MB, heap=530.19 MB, maxHeap=10.5 GB
+2013-08-09 14:02:09,898-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-140008.898, now=130809-140209.898, channel=BufferingChannel
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.checkTimeouts(AbstractKarajanChannel.java:130)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel$1.run(AbstractKarajanChannel.java:121)
+ at java.util.TimerThread.mainLoop(Timer.java:512)
+ at java.util.TimerThread.run(Timer.java:462)
+2013-08-09 14:02:09,899-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 14:02:09,899-0500 INFO ChannelManager BufferingChannel handling channel exception
+2013-08-09 14:02:09,899-0500 INFO ChannelManager Channel already shut down
+2013-08-09 14:02:10,000-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:10,103-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:10,103-0500 INFO ThrottleManager mem=4.49 MB, heap=529.69 MB, maxHeap=10.5 GB
+2013-08-09 14:02:10,501-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:10,603-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:10,604-0500 INFO ThrottleManager mem=14.01 MB, heap=529.31 MB, maxHeap=10.5 GB
+2013-08-09 14:02:11,001-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:11,104-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:11,104-0500 INFO ThrottleManager mem=23.74 MB, heap=528.94 MB, maxHeap=10.5 GB
+2013-08-09 14:02:11,501-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:11,604-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:11,604-0500 INFO ThrottleManager mem=9.2 MB, heap=528.44 MB, maxHeap=10.5 GB
+2013-08-09 14:02:12,001-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:12,105-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:12,105-0500 INFO ThrottleManager mem=21.13 MB, heap=533 MB, maxHeap=10.5 GB
+2013-08-09 14:02:12,502-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:12,605-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:12,605-0500 INFO ThrottleManager mem=8.43 MB, heap=538.31 MB, maxHeap=10.5 GB
+2013-08-09 14:02:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:02:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 537.81 MB, Heap used: 1.61 MB
+2013-08-09 14:02:13,002-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:13,105-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:13,105-0500 INFO ThrottleManager mem=26.57 MB, heap=537.81 MB, maxHeap=10.5 GB
+2013-08-09 14:02:13,502-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:13,606-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:13,606-0500 INFO ThrottleManager mem=12.14 MB, heap=537.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:14,002-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:14,106-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:14,106-0500 INFO ThrottleManager mem=32.3 MB, heap=536.75 MB, maxHeap=10.5 GB
+2013-08-09 14:02:14,106-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:02:14,503-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:14,503-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:02:14,606-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:14,606-0500 INFO ThrottleManager mem=21.45 MB, heap=536.19 MB, maxHeap=10.5 GB
+2013-08-09 14:02:15,003-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:15,107-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:15,107-0500 INFO ThrottleManager mem=11.66 MB, heap=535.62 MB, maxHeap=10.5 GB
+2013-08-09 14:02:15,503-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:15,607-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:15,607-0500 INFO ThrottleManager mem=2.76 MB, heap=535.06 MB, maxHeap=10.5 GB
+2013-08-09 14:02:16,004-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:16,107-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:16,107-0500 INFO ThrottleManager mem=26.67 MB, heap=534.69 MB, maxHeap=10.5 GB
+2013-08-09 14:02:16,504-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:16,608-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:16,608-0500 INFO ThrottleManager mem=22.53 MB, heap=534.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:16,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:02:16,821-0500 INFO Multiplexer No streams
+2013-08-09 14:02:17,005-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:17,108-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:17,108-0500 INFO ThrottleManager mem=19.18 MB, heap=533.62 MB, maxHeap=10.5 GB
+2013-08-09 14:02:17,506-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:17,608-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:17,608-0500 INFO ThrottleManager mem=15.97 MB, heap=533 MB, maxHeap=10.5 GB
+2013-08-09 14:02:18,006-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:18,109-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:18,109-0500 INFO ThrottleManager mem=16.81 MB, heap=532.5 MB, maxHeap=10.5 GB
+2013-08-09 14:02:18,506-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:18,609-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:18,609-0500 INFO ThrottleManager mem=17.72 MB, heap=532.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:19,008-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:19,109-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:19,109-0500 INFO ThrottleManager mem=19.19 MB, heap=531.75 MB, maxHeap=10.5 GB
+2013-08-09 14:02:19,508-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:19,610-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:19,610-0500 INFO ThrottleManager mem=21.67 MB, heap=531.38 MB, maxHeap=10.5 GB
+2013-08-09 14:02:20,009-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:20,110-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:20,110-0500 INFO ThrottleManager mem=25.65 MB, heap=531 MB, maxHeap=10.5 GB
+2013-08-09 14:02:20,509-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:20,610-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:20,611-0500 INFO ThrottleManager mem=4.08 MB, heap=530.5 MB, maxHeap=10.5 GB
+2013-08-09 14:02:21,009-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:21,111-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:21,111-0500 INFO ThrottleManager mem=11.32 MB, heap=530.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:21,509-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:21,611-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:21,611-0500 INFO ThrottleManager mem=8.36 MB, heap=541.31 MB, maxHeap=10.5 GB
+2013-08-09 14:02:22,010-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:22,111-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:22,111-0500 INFO ThrottleManager mem=20.75 MB, heap=540.81 MB, maxHeap=10.5 GB
+2013-08-09 14:02:22,510-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:22,612-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:22,612-0500 INFO ThrottleManager mem=33.55 MB, heap=540.31 MB, maxHeap=10.5 GB
+2013-08-09 14:02:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:02:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 539.81 MB, Heap used: 20.92 MB
+2013-08-09 14:02:23,010-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:23,112-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:23,112-0500 INFO ThrottleManager mem=11.55 MB, heap=539.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:23,511-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:23,612-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:23,613-0500 INFO ThrottleManager mem=26.09 MB, heap=539.06 MB, maxHeap=10.5 GB
+2013-08-09 14:02:24,011-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:24,113-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:24,113-0500 INFO ThrottleManager mem=7.76 MB, heap=538.31 MB, maxHeap=10.5 GB
+2013-08-09 14:02:24,113-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:02:24,511-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:24,511-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:02:24,613-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:24,613-0500 INFO ThrottleManager mem=26.54 MB, heap=537.81 MB, maxHeap=10.5 GB
+2013-08-09 14:02:25,011-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:25,113-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:25,113-0500 INFO ThrottleManager mem=11.48 MB, heap=537.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:25,512-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:25,613-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:25,614-0500 INFO ThrottleManager mem=31.61 MB, heap=536.75 MB, maxHeap=10.5 GB
+2013-08-09 14:02:26,012-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:26,114-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:26,114-0500 INFO ThrottleManager mem=20.81 MB, heap=536.19 MB, maxHeap=10.5 GB
+2013-08-09 14:02:26,512-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:26,614-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:26,614-0500 INFO ThrottleManager mem=11.66 MB, heap=535.62 MB, maxHeap=10.5 GB
+2013-08-09 14:02:26,729-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:02:26,827-0500 INFO Multiplexer No streams
+2013-08-09 14:02:27,013-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:27,114-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:27,114-0500 INFO ThrottleManager mem=4.63 MB, heap=535.06 MB, maxHeap=10.5 GB
+2013-08-09 14:02:27,513-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:27,615-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:27,615-0500 INFO ThrottleManager mem=28.44 MB, heap=534.69 MB, maxHeap=10.5 GB
+2013-08-09 14:02:28,013-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:28,115-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:28,115-0500 INFO ThrottleManager mem=22.53 MB, heap=534.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:28,515-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:28,615-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:28,615-0500 INFO ThrottleManager mem=18.66 MB, heap=533.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:29,015-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:29,116-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:29,116-0500 INFO ThrottleManager mem=15.4 MB, heap=533 MB, maxHeap=10.5 GB
+2013-08-09 14:02:29,515-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:29,616-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:29,616-0500 INFO ThrottleManager mem=15.68 MB, heap=532.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:30,016-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:30,116-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:30,116-0500 INFO ThrottleManager mem=16.64 MB, heap=532.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:30,516-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:30,617-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:30,617-0500 INFO ThrottleManager mem=18.64 MB, heap=531.81 MB, maxHeap=10.5 GB
+2013-08-09 14:02:31,016-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:31,117-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:31,117-0500 INFO ThrottleManager mem=22.76 MB, heap=531.38 MB, maxHeap=10.5 GB
+2013-08-09 14:02:31,517-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:31,619-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:31,619-0500 INFO ThrottleManager mem=1.45 MB, heap=530.88 MB, maxHeap=10.5 GB
+2013-08-09 14:02:32,017-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:32,119-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:32,119-0500 INFO ThrottleManager mem=7.78 MB, heap=530.5 MB, maxHeap=10.5 GB
+2013-08-09 14:02:32,517-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:32,619-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:32,619-0500 INFO ThrottleManager mem=14.44 MB, heap=530.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:02:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 529.88 MB, Heap used: 21.04 MB
+2013-08-09 14:02:33,017-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:33,119-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:33,120-0500 INFO ThrottleManager mem=22.96 MB, heap=529.75 MB, maxHeap=10.5 GB
+2013-08-09 14:02:33,518-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:33,620-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:33,620-0500 INFO ThrottleManager mem=6.95 MB, heap=529.25 MB, maxHeap=10.5 GB
+2013-08-09 14:02:34,018-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:34,120-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:34,120-0500 INFO ThrottleManager mem=12.45 MB, heap=540.12 MB, maxHeap=10.5 GB
+2013-08-09 14:02:34,120-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:02:34,519-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:34,520-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:02:34,621-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:34,621-0500 INFO ThrottleManager mem=18.56 MB, heap=555.94 MB, maxHeap=10.5 GB
+2013-08-09 14:02:35,020-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:35,121-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:35,121-0500 INFO ThrottleManager mem=1.94 MB, heap=554.94 MB, maxHeap=10.5 GB
+2013-08-09 14:02:35,520-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:35,621-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:35,621-0500 INFO ThrottleManager mem=38.23 MB, heap=554.44 MB, maxHeap=10.5 GB
+2013-08-09 14:02:36,020-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:36,122-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:36,122-0500 INFO ThrottleManager mem=25.61 MB, heap=553.44 MB, maxHeap=10.5 GB
+2013-08-09 14:02:36,521-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:36,622-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:36,622-0500 INFO ThrottleManager mem=14.51 MB, heap=552.5 MB, maxHeap=10.5 GB
+2013-08-09 14:02:36,730-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:02:36,830-0500 INFO Multiplexer No streams
+2013-08-09 14:02:37,021-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:37,122-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:37,122-0500 INFO ThrottleManager mem=5.68 MB, heap=551.62 MB, maxHeap=10.5 GB
+2013-08-09 14:02:37,521-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:37,623-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:37,623-0500 INFO ThrottleManager mem=44.27 MB, heap=551.19 MB, maxHeap=10.5 GB
+2013-08-09 14:02:38,021-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:38,123-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:38,123-0500 INFO ThrottleManager mem=35.65 MB, heap=560.06 MB, maxHeap=10.5 GB
+2013-08-09 14:02:38,522-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:38,625-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:38,625-0500 INFO ThrottleManager mem=2.31 MB, heap=570.38 MB, maxHeap=10.5 GB
+2013-08-09 14:02:39,022-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:39,125-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:39,126-0500 INFO ThrottleManager mem=21.9 MB, heap=569.62 MB, maxHeap=10.5 GB
+2013-08-09 14:02:39,522-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:39,626-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:39,626-0500 INFO ThrottleManager mem=43.64 MB, heap=568.75 MB, maxHeap=10.5 GB
+2013-08-09 14:02:40,022-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:40,126-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:40,126-0500 INFO ThrottleManager mem=4.77 MB, heap=567.19 MB, maxHeap=10.5 GB
+2013-08-09 14:02:40,523-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:40,626-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:40,627-0500 INFO ThrottleManager mem=28.38 MB, heap=566.5 MB, maxHeap=10.5 GB
+2013-08-09 14:02:41,023-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:41,127-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:41,127-0500 INFO ThrottleManager mem=53.98 MB, heap=565.69 MB, maxHeap=10.5 GB
+2013-08-09 14:02:41,523-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:41,627-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:41,627-0500 INFO ThrottleManager mem=17.78 MB, heap=564.25 MB, maxHeap=10.5 GB
+2013-08-09 14:02:42,024-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:42,127-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:42,128-0500 INFO ThrottleManager mem=45 MB, heap=563.62 MB, maxHeap=10.5 GB
+2013-08-09 14:02:42,524-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:42,628-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:42,628-0500 INFO ThrottleManager mem=13.71 MB, heap=562.25 MB, maxHeap=10.5 GB
+2013-08-09 14:02:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:02:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 561.56 MB, Heap used: 12.43 MB
+2013-08-09 14:02:43,024-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:43,128-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:43,128-0500 INFO ThrottleManager mem=42.34 MB, heap=561.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:43,524-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:43,628-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:43,629-0500 INFO ThrottleManager mem=15.55 MB, heap=560.31 MB, maxHeap=10.5 GB
+2013-08-09 14:02:44,025-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:44,129-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:44,129-0500 INFO ThrottleManager mem=46.55 MB, heap=559.69 MB, maxHeap=10.5 GB
+2013-08-09 14:02:44,129-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:02:44,525-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:44,525-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:02:44,629-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:44,629-0500 INFO ThrottleManager mem=23.83 MB, heap=558.5 MB, maxHeap=10.5 GB
+2013-08-09 14:02:45,025-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:45,129-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:45,130-0500 INFO ThrottleManager mem=2.05 MB, heap=557.38 MB, maxHeap=10.5 GB
+2013-08-09 14:02:45,526-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:45,630-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:45,630-0500 INFO ThrottleManager mem=35.75 MB, heap=556.81 MB, maxHeap=10.5 GB
+2013-08-09 14:02:46,026-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:46,130-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:46,130-0500 INFO ThrottleManager mem=16.44 MB, heap=555.75 MB, maxHeap=10.5 GB
+2013-08-09 14:02:46,526-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:46,630-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:46,631-0500 INFO ThrottleManager mem=51.1 MB, heap=555.25 MB, maxHeap=10.5 GB
+2013-08-09 14:02:46,730-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:02:46,837-0500 INFO Multiplexer No streams
+2013-08-09 14:02:47,026-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:47,131-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:47,131-0500 INFO ThrottleManager mem=37.07 MB, heap=554.25 MB, maxHeap=10.5 GB
+2013-08-09 14:02:47,527-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:47,631-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:47,631-0500 INFO ThrottleManager mem=23.56 MB, heap=553.25 MB, maxHeap=10.5 GB
+2013-08-09 14:02:48,027-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:48,131-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:48,132-0500 INFO ThrottleManager mem=12.54 MB, heap=552.31 MB, maxHeap=10.5 GB
+2013-08-09 14:02:48,527-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:48,632-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:48,632-0500 INFO ThrottleManager mem=2.82 MB, heap=551.44 MB, maxHeap=10.5 GB
+2013-08-09 14:02:49,028-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:49,054-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-140049.026, now=130809-140249.054, channel=TCP-54.212.81.224-000000
+2013-08-09 14:02:49,055-0500 INFO ChannelContext => Command(tag: 14, HEARTBEAT)
+2013-08-09 14:02:49,055-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 14:02:49,055-0500 INFO AbstractKarajanChannel Channel config: null
+2013-08-09 14:02:49,055-0500 INFO ChannelManager TCP-54.212.81.224-000000 handling channel exception
+2013-08-09 14:02:49,055-0500 INFO ChannelManager Channel already shut down
+2013-08-09 14:02:49,055-0500 INFO AbstractTCPChannel 54.212.81.224-000000: Channel shut down
+2013-08-09 14:02:49,132-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:49,132-0500 INFO ThrottleManager mem=43.27 MB, heap=551 MB, maxHeap=10.5 GB
+2013-08-09 14:02:49,231-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-140049.028, now=130809-140249.231, channel=TCP-54.244.171.51-000000
+2013-08-09 14:02:49,231-0500 INFO ChannelContext => Command(tag: 17, HEARTBEAT)
+2013-08-09 14:02:49,231-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 14:02:49,231-0500 INFO ChannelContext => Command(tag: 16, HEARTBEAT)
+2013-08-09 14:02:49,231-0500 INFO ChannelContext => Command(tag: 19, HEARTBEAT)
+2013-08-09 14:02:49,231-0500 INFO ChannelContext => Command(tag: 18, HEARTBEAT)
+2013-08-09 14:02:49,232-0500 INFO AbstractKarajanChannel Channel config: null
+2013-08-09 14:02:49,232-0500 INFO ChannelManager TCP-54.244.171.51-000000 handling channel exception
+2013-08-09 14:02:49,232-0500 INFO AbstractTCPChannel 54.244.171.51-000000: Channel shut down
+2013-08-09 14:02:49,232-0500 INFO MetaChannel MetaChannel[worker-2] -> TCP-54.244.171.51-000000 bind -> NullChannel
+2013-08-09 14:02:49,232-0500 INFO ChannelContext Notifying commands and handlers about exception
+2013-08-09 14:02:49,232-0500 INFO ChannelContext => Command(tag: 17, HEARTBEAT)
+2013-08-09 14:02:49,232-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 14:02:49,232-0500 INFO ChannelContext => Command(tag: 16, HEARTBEAT)
+2013-08-09 14:02:49,233-0500 INFO ChannelContext => Command(tag: 19, HEARTBEAT)
+2013-08-09 14:02:49,233-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 14:02:49,233-0500 INFO ChannelContext => Command(tag: 18, HEARTBEAT)
+2013-08-09 14:02:49,233-0500 INFO Node Node [ip-10-251-21-212] 0 lost connection to worker; removing node from block.
+2013-08-09 14:02:49,233-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848033-1376074606770-1376074606771) Active
+2013-08-09 14:02:49,233-0500 WARN TaskNotifier Failed to send task notification
+org.globus.cog.karajan.workflow.service.channels.ChannelException: Channel died and no contact available
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.connect(ChannelManager.java:234)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:255)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:226)
+ at org.globus.cog.abstraction.coaster.service.job.manager.TaskNotifier.sendStatus(TaskNotifier.java:76)
+ at org.globus.cog.abstraction.coaster.service.job.manager.TaskNotifier.statusChanged(TaskNotifier.java:64)
+ at org.globus.cog.abstraction.impl.common.task.TaskImpl.notifyListeners(TaskImpl.java:240)
+ at org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:228)
+ at org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:257)
+ at org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:218)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Job.fail(Job.java:182)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Cpu.taskFailed(Cpu.java:349)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Node.channelShutDown(Node.java:147)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelContext.channelShutDown(ChannelContext.java:317)
+ at org.globus.cog.karajan.workflow.service.channels.ChannelManager.handleChannelException(ChannelManager.java:292)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleChannelException(AbstractKarajanChannel.java:566)
+ at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.checkTimeouts(AbstractKarajanChannel.java:134)
+2013-08-09 14:02:49,234-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848033-1376074606770-1376074606771) Failed Task failed: Connection to worker lost
+2013-08-09 14:02:49,234-0500 INFO Cpu 54.244.171.51:0 jobTerminated
+2013-08-09 14:02:49,234-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=0
+2013-08-09 14:02:49,234-0500 WARN TaskNotifier Failed to send task notification
+2013-08-09 14:02:49,235-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848041-1376074606761-1376074606762) Active
+2013-08-09 14:02:49,235-0500 WARN TaskNotifier Failed to send task notification
+2013-08-09 14:02:49,235-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848041-1376074606761-1376074606762) Failed Task failed: Connection to worker lost
+2013-08-09 14:02:49,235-0500 INFO Cpu 54.244.171.51:2 jobTerminated
+2013-08-09 14:02:49,235-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=2
+2013-08-09 14:02:49,235-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848036-1376074606767-1376074606768) Active
+2013-08-09 14:02:49,236-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848036-1376074606767-1376074606768) Failed Task failed: Connection to worker lost
+2013-08-09 14:02:49,236-0500 INFO Cpu 54.244.171.51:3 jobTerminated
+2013-08-09 14:02:49,236-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=3
+2013-08-09 14:02:49,236-0500 WARN TaskNotifier Failed to send task notification
+2013-08-09 14:02:49,236-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848042-1376074606773-1376074606774) Active
+2013-08-09 14:02:49,237-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848042-1376074606773-1376074606774) Failed Task failed: Connection to worker lost
+2013-08-09 14:02:49,237-0500 INFO Cpu 54.244.171.51:6 jobTerminated
+2013-08-09 14:02:49,237-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=6
+2013-08-09 14:02:49,237-0500 WARN TaskNotifier Failed to send task notification
+2013-08-09 14:02:49,237-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848037-1376074606776-1376074606777) Active
+2013-08-09 14:02:49,238-0500 DEBUG Cpu StatusEvent: Task(type=JOB_SUBMISSION, identity=urn:1376074848037-1376074606776-1376074606777) Failed Task failed: Connection to worker lost
+2013-08-09 14:02:49,238-0500 INFO Cpu 54.244.171.51:7 jobTerminated
+2013-08-09 14:02:49,238-0500 DEBUG Cpu ready for work: block=54.244.171.51 id=7
+2013-08-09 14:02:49,238-0500 WARN TaskNotifier Failed to send task notification
+2013-08-09 14:02:49,238-0500 INFO MetaChannel MetaChannel[worker-2] -> NullChannel bind -> NullChannel
+2013-08-09 14:02:49,238-0500 WARN BlockQueueProcessor Failed to send worker status update to client
+ at org.globus.cog.abstraction.coaster.service.job.manager.PassiveQueueProcessor.nodeRemoved(PassiveQueueProcessor.java:109)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Block.removeNode(Block.java:561)
+ at org.globus.cog.abstraction.coaster.service.job.manager.Node.channelShutDown(Node.java:160)
+2013-08-09 14:02:49,239-0500 INFO ChannelManager Channel exception handled
+2013-08-09 14:02:49,239-0500 INFO AbstractTCPChannel 54.244.171.51-000000: Channel shut down
+2013-08-09 14:02:49,515-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-140049.030, now=130809-140249.515, channel=TCP-54.212.37.161-000000
+2013-08-09 14:02:49,515-0500 INFO ChannelContext => Command(tag: 12, HEARTBEAT)
+2013-08-09 14:02:49,515-0500 INFO HeartBeatTask Heartbeat failed: null
+2013-08-09 14:02:49,515-0500 INFO AbstractKarajanChannel Channel config: null
+2013-08-09 14:02:49,515-0500 INFO ChannelManager TCP-54.212.37.161-000000 handling channel exception
+2013-08-09 14:02:49,516-0500 INFO ChannelManager Channel already shut down
+2013-08-09 14:02:49,516-0500 INFO AbstractTCPChannel 54.212.37.161-000000: Channel shut down
+2013-08-09 14:02:49,528-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:49,632-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:49,632-0500 INFO ThrottleManager mem=15.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:50,028-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:50,133-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:50,133-0500 INFO ThrottleManager mem=15.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:50,528-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:50,633-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:50,633-0500 INFO ThrottleManager mem=15.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:51,029-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:51,133-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:51,133-0500 INFO ThrottleManager mem=15.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:51,529-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:51,634-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:51,634-0500 INFO ThrottleManager mem=15.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:52,029-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:52,134-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:52,134-0500 INFO ThrottleManager mem=15.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:52,529-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:52,634-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:52,634-0500 INFO ThrottleManager mem=15.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:02:52,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 15.46 MB
+2013-08-09 14:02:53,030-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:53,135-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:53,135-0500 INFO ThrottleManager mem=15.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:53,530-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:53,635-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:53,635-0500 INFO ThrottleManager mem=15.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:54,030-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:54,135-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:54,135-0500 INFO ThrottleManager mem=15.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:54,136-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:02:54,531-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:54,531-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:02:54,636-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:54,636-0500 INFO ThrottleManager mem=15.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:55,031-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:55,136-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:55,136-0500 INFO ThrottleManager mem=15.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:55,531-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:55,636-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:55,637-0500 INFO ThrottleManager mem=15.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:56,031-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:56,137-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:56,137-0500 INFO ThrottleManager mem=15.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:56,532-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:56,637-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:56,637-0500 INFO ThrottleManager mem=15.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:56,730-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:02:56,843-0500 INFO Multiplexer No streams
+2013-08-09 14:02:57,032-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:57,137-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:57,138-0500 INFO ThrottleManager mem=15.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:57,532-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:57,638-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:57,638-0500 INFO ThrottleManager mem=15.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:58,032-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:58,138-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:58,138-0500 INFO ThrottleManager mem=15.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:58,533-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:58,639-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:58,639-0500 INFO ThrottleManager mem=15.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:59,033-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:59,139-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:59,139-0500 INFO ThrottleManager mem=15.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:02:59,533-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:59,639-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:02:59,639-0500 INFO ThrottleManager mem=15.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:00,033-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:00,139-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:00,140-0500 INFO ThrottleManager mem=15.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:00,534-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:00,640-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:00,640-0500 INFO ThrottleManager mem=15.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:01,034-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:01,140-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:01,140-0500 INFO ThrottleManager mem=15.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:01,534-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:01,640-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:01,641-0500 INFO ThrottleManager mem=15.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:02,035-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:02,141-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:02,141-0500 INFO ThrottleManager mem=15.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:02,535-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:02,641-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:02,641-0500 INFO ThrottleManager mem=15.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:03:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 15.72 MB
+2013-08-09 14:03:03,035-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:03,141-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:03,142-0500 INFO ThrottleManager mem=15.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:03,536-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:03,642-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:03,642-0500 INFO ThrottleManager mem=15.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:04,036-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:04,142-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:04,142-0500 INFO ThrottleManager mem=15.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:04,142-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:03:04,536-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:04,537-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:03:04,643-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:04,643-0500 INFO ThrottleManager mem=15.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:05,037-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:05,143-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:05,143-0500 INFO ThrottleManager mem=15.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:05,537-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:05,643-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:05,643-0500 INFO ThrottleManager mem=15.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:06,037-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:06,144-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:06,144-0500 INFO ThrottleManager mem=15.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:06,538-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:06,644-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:06,644-0500 INFO ThrottleManager mem=15.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:06,730-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:03:06,848-0500 INFO Multiplexer No streams
+2013-08-09 14:03:07,038-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:07,144-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:07,145-0500 INFO ThrottleManager mem=15.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:07,538-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:07,645-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:07,645-0500 INFO ThrottleManager mem=15.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:08,038-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:08,145-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:08,145-0500 INFO ThrottleManager mem=15.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:08,539-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:08,646-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:08,646-0500 INFO ThrottleManager mem=15.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:08,648-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-140107.847, now=130809-140308.648, channel=TCP-null
+2013-08-09 14:03:08,649-0500 INFO ChannelContext => Command(tag: 27, JOBSTATUS)
+2013-08-09 14:03:08,649-0500 WARN TaskNotifier Client could not properly process notification: null
+2013-08-09 14:03:08,649-0500 INFO ChannelContext => Command(tag: 29, JOBSTATUS)
+2013-08-09 14:03:08,649-0500 INFO ChannelContext => Command(tag: 28, JOBSTATUS)
+2013-08-09 14:03:08,649-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 14:03:08,649-0500 INFO ChannelManager TCP-null handling channel exception
+2013-08-09 14:03:08,649-0500 INFO ChannelManager Channel already shut down
+2013-08-09 14:03:09,039-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:09,146-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:09,146-0500 INFO ThrottleManager mem=16.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:09,539-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:09,646-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:09,646-0500 INFO ThrottleManager mem=16.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:10,039-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:10,146-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:10,147-0500 INFO ThrottleManager mem=16.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:10,540-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:10,647-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:10,647-0500 INFO ThrottleManager mem=16.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:11,040-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:11,147-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:11,147-0500 INFO ThrottleManager mem=16.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:11,540-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:11,648-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:11,648-0500 INFO ThrottleManager mem=16.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:11,967-0500 INFO ChannelContext Notifying commands and handlers about exception
+org.globus.cog.karajan.workflow.service.TimeoutException: Channel timed out. lastTime=130809-140110.966, now=130809-140311.967, channel=BufferingChannel
+2013-08-09 14:03:11,967-0500 INFO ChannelContext => Command(tag: 27, JOBSTATUS)
+2013-08-09 14:03:11,967-0500 WARN TaskNotifier Client could not properly process notification: null
+2013-08-09 14:03:11,967-0500 INFO ChannelContext => Command(tag: 29, JOBSTATUS)
+2013-08-09 14:03:11,967-0500 INFO ChannelContext => Command(tag: 28, JOBSTATUS)
+2013-08-09 14:03:11,968-0500 INFO AbstractKarajanChannel Channel config: null -> {buffer=null, keepalive=null}
+2013-08-09 14:03:11,968-0500 INFO ChannelManager BufferingChannel handling channel exception
+2013-08-09 14:03:11,968-0500 INFO ChannelManager Channel already shut down
+2013-08-09 14:03:12,041-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:12,148-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:12,148-0500 INFO ThrottleManager mem=16.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:12,541-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:12,648-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:12,648-0500 INFO ThrottleManager mem=16.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:03:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 16.32 MB
+2013-08-09 14:03:13,041-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:13,149-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:13,149-0500 INFO ThrottleManager mem=16.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:13,541-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:13,649-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:13,649-0500 INFO ThrottleManager mem=16.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:14,042-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:14,149-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:14,150-0500 INFO ThrottleManager mem=16.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:14,150-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:03:14,542-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:14,542-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:03:14,650-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:14,650-0500 INFO ThrottleManager mem=16.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:15,042-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:15,150-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:15,150-0500 INFO ThrottleManager mem=16.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:15,542-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:15,651-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:15,651-0500 INFO ThrottleManager mem=16.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:16,043-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:16,151-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:16,151-0500 INFO ThrottleManager mem=16.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:16,543-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:16,651-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:16,651-0500 INFO ThrottleManager mem=16.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:16,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:03:16,851-0500 INFO Multiplexer No streams
+2013-08-09 14:03:17,043-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:17,152-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:17,152-0500 INFO ThrottleManager mem=16.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:17,544-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:17,652-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:17,652-0500 INFO ThrottleManager mem=16.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:18,044-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:18,152-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:18,153-0500 INFO ThrottleManager mem=16.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:18,544-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:18,653-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:18,653-0500 INFO ThrottleManager mem=16.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:19,044-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:19,153-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:19,153-0500 INFO ThrottleManager mem=16.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:19,545-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:19,654-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:19,654-0500 INFO ThrottleManager mem=16.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:20,045-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:20,154-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:20,154-0500 INFO ThrottleManager mem=16.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:20,545-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:20,654-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:20,654-0500 INFO ThrottleManager mem=16.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:21,045-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:21,155-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:21,155-0500 INFO ThrottleManager mem=16.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:21,546-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:21,655-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:21,655-0500 INFO ThrottleManager mem=16.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:22,046-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:22,155-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:22,156-0500 INFO ThrottleManager mem=16.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:22,546-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:22,656-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:22,656-0500 INFO ThrottleManager mem=16.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:03:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 16.58 MB
+2013-08-09 14:03:23,047-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:23,156-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:23,156-0500 INFO ThrottleManager mem=16.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:23,547-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:23,656-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:23,657-0500 INFO ThrottleManager mem=16.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:24,047-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:24,157-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:24,157-0500 INFO ThrottleManager mem=16.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:24,157-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:03:24,548-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:24,548-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:03:24,657-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:24,657-0500 INFO ThrottleManager mem=16.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:25,048-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:25,158-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:25,158-0500 INFO ThrottleManager mem=16.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:25,548-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:25,658-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:25,658-0500 INFO ThrottleManager mem=16.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:26,048-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:26,158-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:26,159-0500 INFO ThrottleManager mem=16.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:26,549-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:26,659-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:26,659-0500 INFO ThrottleManager mem=16.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:26,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:03:26,858-0500 INFO Multiplexer No streams
+2013-08-09 14:03:27,049-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:27,159-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:27,159-0500 INFO ThrottleManager mem=16.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:27,549-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:27,659-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:27,660-0500 INFO ThrottleManager mem=16.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:28,050-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:28,160-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:28,160-0500 INFO ThrottleManager mem=16.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:28,550-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:28,660-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:28,660-0500 INFO ThrottleManager mem=16.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:29,050-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:29,160-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:29,161-0500 INFO ThrottleManager mem=16.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:29,550-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:29,661-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:29,661-0500 INFO ThrottleManager mem=16.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:30,051-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:30,161-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:30,161-0500 INFO ThrottleManager mem=16.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:30,551-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:30,661-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:30,662-0500 INFO ThrottleManager mem=16.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:31,051-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:31,162-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:31,162-0500 INFO ThrottleManager mem=16.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:31,552-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:31,662-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:31,662-0500 INFO ThrottleManager mem=16.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:32,052-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:32,163-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:32,163-0500 INFO ThrottleManager mem=16.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:32,552-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:32,663-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:32,663-0500 INFO ThrottleManager mem=16.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:32,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:03:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 16.84 MB
+2013-08-09 14:03:33,053-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:33,163-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:33,163-0500 INFO ThrottleManager mem=16.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:33,553-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:33,663-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:33,664-0500 INFO ThrottleManager mem=16.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:34,053-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:34,164-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:34,164-0500 INFO ThrottleManager mem=16.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:34,164-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:03:34,553-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:34,554-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:03:34,664-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:34,664-0500 INFO ThrottleManager mem=16.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:35,054-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:35,165-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:35,165-0500 INFO ThrottleManager mem=16.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:35,554-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:35,665-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:35,665-0500 INFO ThrottleManager mem=16.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:36,054-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:36,165-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:36,165-0500 INFO ThrottleManager mem=16.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:36,555-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:36,666-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:36,666-0500 INFO ThrottleManager mem=16.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:36,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:03:36,866-0500 INFO Multiplexer No streams
+2013-08-09 14:03:37,055-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:37,166-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:37,166-0500 INFO ThrottleManager mem=16.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:37,555-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:37,666-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:37,666-0500 INFO ThrottleManager mem=16.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:38,056-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:38,167-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:38,167-0500 INFO ThrottleManager mem=16.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:38,556-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:38,667-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:38,667-0500 INFO ThrottleManager mem=16.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:39,056-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:39,167-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:39,168-0500 INFO ThrottleManager mem=17.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:39,556-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:39,668-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:39,668-0500 INFO ThrottleManager mem=17.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:40,057-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:40,168-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:40,168-0500 INFO ThrottleManager mem=17.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:40,557-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:40,668-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:40,669-0500 INFO ThrottleManager mem=17.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:41,058-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:41,169-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:41,169-0500 INFO ThrottleManager mem=17.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:41,558-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:41,669-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:41,669-0500 INFO ThrottleManager mem=17.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:42,058-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:42,169-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:42,170-0500 INFO ThrottleManager mem=17.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:42,558-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:42,670-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:42,670-0500 INFO ThrottleManager mem=17.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:03:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 17.1 MB
+2013-08-09 14:03:43,059-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:43,170-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:43,170-0500 INFO ThrottleManager mem=17.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:43,559-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:43,670-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:43,670-0500 INFO ThrottleManager mem=17.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:44,059-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:44,171-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:44,171-0500 INFO ThrottleManager mem=17.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:44,171-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:03:44,559-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:44,560-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:03:44,671-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:44,671-0500 INFO ThrottleManager mem=17.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:45,060-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:45,171-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:45,172-0500 INFO ThrottleManager mem=17.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:45,560-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:45,672-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:45,672-0500 INFO ThrottleManager mem=17.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:46,060-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:46,172-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:46,172-0500 INFO ThrottleManager mem=17.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:46,561-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:46,672-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:46,672-0500 INFO ThrottleManager mem=17.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:46,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:03:46,873-0500 INFO Multiplexer No streams
+2013-08-09 14:03:47,061-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:47,173-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:47,173-0500 INFO ThrottleManager mem=17.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:47,561-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:47,673-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:47,673-0500 INFO ThrottleManager mem=17.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:48,061-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:48,173-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:48,173-0500 INFO ThrottleManager mem=17.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:48,562-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:48,674-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:48,674-0500 INFO ThrottleManager mem=17.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:49,062-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:49,174-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:49,174-0500 INFO ThrottleManager mem=17.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:49,562-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:49,674-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:49,674-0500 INFO ThrottleManager mem=17.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:50,063-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:50,175-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:50,175-0500 INFO ThrottleManager mem=17.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:50,563-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:50,675-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:50,675-0500 INFO ThrottleManager mem=17.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:51,063-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:51,175-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:51,175-0500 INFO ThrottleManager mem=17.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:51,563-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:51,676-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:51,676-0500 INFO ThrottleManager mem=17.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:52,064-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:52,176-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:52,176-0500 INFO ThrottleManager mem=17.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:52,564-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:52,676-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:52,676-0500 INFO ThrottleManager mem=17.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:03:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 17.37 MB
+2013-08-09 14:03:53,065-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:53,176-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:53,177-0500 INFO ThrottleManager mem=17.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:53,565-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:53,677-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:53,677-0500 INFO ThrottleManager mem=17.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:54,065-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:54,177-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:54,177-0500 INFO ThrottleManager mem=17.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:54,177-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:03:54,565-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:54,566-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:03:54,678-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:54,678-0500 INFO ThrottleManager mem=17.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:55,066-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:55,178-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:55,178-0500 INFO ThrottleManager mem=17.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:55,566-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:55,678-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:55,678-0500 INFO ThrottleManager mem=17.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:56,066-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:56,179-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:56,179-0500 INFO ThrottleManager mem=17.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:56,567-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:56,679-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:56,679-0500 INFO ThrottleManager mem=17.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:56,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:03:56,882-0500 INFO Multiplexer No streams
+2013-08-09 14:03:57,067-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:57,179-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:57,179-0500 INFO ThrottleManager mem=17.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:57,567-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:57,680-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:57,680-0500 INFO ThrottleManager mem=17.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:58,067-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:58,180-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:58,180-0500 INFO ThrottleManager mem=17.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:58,568-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:58,680-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:58,680-0500 INFO ThrottleManager mem=17.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:59,068-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:59,181-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:59,181-0500 INFO ThrottleManager mem=17.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:03:59,568-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:59,681-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:03:59,681-0500 INFO ThrottleManager mem=17.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:00,069-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:00,181-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:00,181-0500 INFO ThrottleManager mem=17.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:00,569-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:00,682-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:00,682-0500 INFO ThrottleManager mem=17.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:01,069-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:01,182-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:01,182-0500 INFO ThrottleManager mem=17.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:01,569-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:01,682-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:01,682-0500 INFO ThrottleManager mem=17.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:02,070-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:02,183-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:02,183-0500 INFO ThrottleManager mem=17.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:02,570-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:02,683-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:02,683-0500 INFO ThrottleManager mem=17.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:04:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 17.63 MB
+2013-08-09 14:04:03,070-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:03,183-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:03,183-0500 INFO ThrottleManager mem=17.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:03,570-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:03,684-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:03,684-0500 INFO ThrottleManager mem=17.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:04,071-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:04,184-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:04,184-0500 INFO ThrottleManager mem=17.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:04,184-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:04:04,571-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:04,571-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:04:04,684-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:04,684-0500 INFO ThrottleManager mem=17.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:05,072-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:05,185-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:05,185-0500 INFO ThrottleManager mem=17.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:05,572-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:05,685-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:05,685-0500 INFO ThrottleManager mem=17.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:06,072-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:06,185-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:06,185-0500 INFO ThrottleManager mem=17.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:06,572-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:06,686-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:06,686-0500 INFO ThrottleManager mem=17.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:06,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:04:06,890-0500 INFO Multiplexer No streams
+2013-08-09 14:04:07,073-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:07,186-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:07,186-0500 INFO ThrottleManager mem=17.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:07,573-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:07,686-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:07,687-0500 INFO ThrottleManager mem=17.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:08,073-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:08,187-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:08,187-0500 INFO ThrottleManager mem=17.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:08,574-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:08,687-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:08,687-0500 INFO ThrottleManager mem=17.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:09,074-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:09,187-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:09,188-0500 INFO ThrottleManager mem=17.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:09,574-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:09,688-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:09,688-0500 INFO ThrottleManager mem=17.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:10,074-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:10,188-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:10,188-0500 INFO ThrottleManager mem=17.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:10,575-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:10,689-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:10,689-0500 INFO ThrottleManager mem=17.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:11,075-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:11,189-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:11,189-0500 INFO ThrottleManager mem=17.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:11,576-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:11,689-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:11,689-0500 INFO ThrottleManager mem=17.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:12,076-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:12,190-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:12,190-0500 INFO ThrottleManager mem=17.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:12,576-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:12,690-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:12,690-0500 INFO ThrottleManager mem=17.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:04:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 17.89 MB
+2013-08-09 14:04:13,076-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:13,190-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:13,190-0500 INFO ThrottleManager mem=17.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:13,577-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:13,691-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:13,691-0500 INFO ThrottleManager mem=17.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:14,077-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:14,191-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:14,191-0500 INFO ThrottleManager mem=17.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:14,191-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:04:14,577-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:14,577-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:04:14,691-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:14,691-0500 INFO ThrottleManager mem=17.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:15,077-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:15,192-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:15,192-0500 INFO ThrottleManager mem=17.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:15,578-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:15,692-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:15,692-0500 INFO ThrottleManager mem=17.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:16,078-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:16,192-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:16,192-0500 INFO ThrottleManager mem=17.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:16,578-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:16,693-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:16,693-0500 INFO ThrottleManager mem=17.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:16,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:04:16,892-0500 INFO Multiplexer No streams
+2013-08-09 14:04:17,078-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:17,193-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:17,193-0500 INFO ThrottleManager mem=18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:17,579-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:17,693-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:17,693-0500 INFO ThrottleManager mem=18.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:18,079-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:18,193-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:18,193-0500 INFO ThrottleManager mem=18.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:18,579-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:18,694-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:18,694-0500 INFO ThrottleManager mem=18.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:19,080-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:19,194-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:19,194-0500 INFO ThrottleManager mem=18.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:19,580-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:19,694-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:19,694-0500 INFO ThrottleManager mem=18.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:20,080-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:20,194-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:20,195-0500 INFO ThrottleManager mem=18.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:20,580-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:20,695-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:20,695-0500 INFO ThrottleManager mem=18.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:21,081-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:21,195-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:21,195-0500 INFO ThrottleManager mem=18.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:21,581-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:21,695-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:21,696-0500 INFO ThrottleManager mem=18.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:22,081-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:22,196-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:22,196-0500 INFO ThrottleManager mem=18.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:22,581-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:22,696-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:22,696-0500 INFO ThrottleManager mem=18.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:04:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 18.15 MB
+2013-08-09 14:04:23,082-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:23,197-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:23,197-0500 INFO ThrottleManager mem=18.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:23,582-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:23,697-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:23,697-0500 INFO ThrottleManager mem=18.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:24,082-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:24,197-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:24,197-0500 INFO ThrottleManager mem=18.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:24,197-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:04:24,583-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:24,583-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:04:24,698-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:24,698-0500 INFO ThrottleManager mem=18.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:25,083-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:25,198-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:25,198-0500 INFO ThrottleManager mem=18.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:25,583-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:25,698-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:25,698-0500 INFO ThrottleManager mem=18.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:26,084-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:26,199-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:26,199-0500 INFO ThrottleManager mem=18.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:26,584-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:26,699-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:26,699-0500 INFO ThrottleManager mem=18.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:26,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:04:26,907-0500 INFO Multiplexer No streams
+2013-08-09 14:04:27,084-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:27,199-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:27,199-0500 INFO ThrottleManager mem=18.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:27,584-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:27,700-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:27,700-0500 INFO ThrottleManager mem=18.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:28,085-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:28,200-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:28,200-0500 INFO ThrottleManager mem=18.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:28,585-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:28,700-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:28,700-0500 INFO ThrottleManager mem=18.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:29,085-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:29,201-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:29,201-0500 INFO ThrottleManager mem=18.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:29,585-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:29,701-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:29,701-0500 INFO ThrottleManager mem=18.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:30,086-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:30,201-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:30,201-0500 INFO ThrottleManager mem=18.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:30,586-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:30,702-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:30,702-0500 INFO ThrottleManager mem=18.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:31,086-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:31,202-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:31,202-0500 INFO ThrottleManager mem=18.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:31,586-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:31,702-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:31,703-0500 INFO ThrottleManager mem=18.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:32,087-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:32,203-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:32,203-0500 INFO ThrottleManager mem=18.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:32,587-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:32,703-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:32,703-0500 INFO ThrottleManager mem=18.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:04:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 18.42 MB
+2013-08-09 14:04:33,087-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:33,203-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:33,203-0500 INFO ThrottleManager mem=18.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:33,588-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:33,704-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:33,704-0500 INFO ThrottleManager mem=18.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:34,088-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:34,204-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:34,204-0500 INFO ThrottleManager mem=18.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:34,204-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:04:34,588-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:34,588-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:04:34,704-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:34,705-0500 INFO ThrottleManager mem=18.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:35,089-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:35,205-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:35,205-0500 INFO ThrottleManager mem=18.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:35,589-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:35,705-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:35,705-0500 INFO ThrottleManager mem=18.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:36,089-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:36,206-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:36,206-0500 INFO ThrottleManager mem=18.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:36,589-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:36,706-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:36,706-0500 INFO ThrottleManager mem=18.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:36,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:04:36,912-0500 INFO Multiplexer No streams
+2013-08-09 14:04:37,090-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:37,206-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:37,206-0500 INFO ThrottleManager mem=18.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:37,590-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:37,707-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:37,707-0500 INFO ThrottleManager mem=18.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:38,090-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:38,207-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:38,207-0500 INFO ThrottleManager mem=18.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:38,590-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:38,707-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:38,707-0500 INFO ThrottleManager mem=18.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:39,091-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:39,208-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:39,208-0500 INFO ThrottleManager mem=18.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:39,591-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:39,708-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:39,708-0500 INFO ThrottleManager mem=18.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:40,091-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:40,208-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:40,208-0500 INFO ThrottleManager mem=18.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:40,591-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:40,709-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:40,709-0500 INFO ThrottleManager mem=18.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:41,092-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:41,209-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:41,209-0500 INFO ThrottleManager mem=18.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:41,592-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:41,709-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:41,710-0500 INFO ThrottleManager mem=18.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:42,092-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:42,210-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:42,210-0500 INFO ThrottleManager mem=18.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:42,593-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:42,710-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:42,710-0500 INFO ThrottleManager mem=18.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:04:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 18.68 MB
+2013-08-09 14:04:43,093-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:43,210-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:43,210-0500 INFO ThrottleManager mem=18.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:43,593-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:43,711-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:43,711-0500 INFO ThrottleManager mem=18.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:44,094-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:44,211-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:44,211-0500 INFO ThrottleManager mem=18.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:44,211-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:04:44,594-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:44,594-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:04:44,711-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:44,711-0500 INFO ThrottleManager mem=18.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:45,094-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:45,212-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:45,212-0500 INFO ThrottleManager mem=18.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:45,594-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:45,712-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:45,712-0500 INFO ThrottleManager mem=18.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:46,095-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:46,212-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:46,212-0500 INFO ThrottleManager mem=18.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:46,595-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:46,713-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:46,713-0500 INFO ThrottleManager mem=18.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:46,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:04:46,917-0500 INFO Multiplexer No streams
+2013-08-09 14:04:47,095-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:47,213-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:47,213-0500 INFO ThrottleManager mem=18.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:47,595-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:47,713-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:47,713-0500 INFO ThrottleManager mem=18.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:48,096-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:48,214-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:48,214-0500 INFO ThrottleManager mem=18.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:48,596-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:48,714-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:48,714-0500 INFO ThrottleManager mem=18.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:49,096-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:49,214-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:49,214-0500 INFO ThrottleManager mem=18.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:49,597-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:49,715-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:49,715-0500 INFO ThrottleManager mem=18.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:50,097-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:50,215-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:50,215-0500 INFO ThrottleManager mem=18.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:50,597-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:50,715-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:50,715-0500 INFO ThrottleManager mem=18.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:51,097-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:51,216-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:51,216-0500 INFO ThrottleManager mem=18.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:51,598-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:51,716-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:51,716-0500 INFO ThrottleManager mem=18.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:52,098-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:52,216-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:52,216-0500 INFO ThrottleManager mem=18.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:52,598-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:52,717-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:52,717-0500 INFO ThrottleManager mem=18.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:04:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 18.94 MB
+2013-08-09 14:04:53,099-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:53,217-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:53,217-0500 INFO ThrottleManager mem=18.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:53,599-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:53,717-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:53,718-0500 INFO ThrottleManager mem=18.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:54,099-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:54,218-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:54,218-0500 INFO ThrottleManager mem=18.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:54,218-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:04:54,599-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:54,600-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:04:54,718-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:54,718-0500 INFO ThrottleManager mem=18.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:55,100-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:55,218-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:55,219-0500 INFO ThrottleManager mem=19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:55,600-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:55,719-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:55,719-0500 INFO ThrottleManager mem=19.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:56,100-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:56,219-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:56,219-0500 INFO ThrottleManager mem=19.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:56,601-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:56,720-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:56,720-0500 INFO ThrottleManager mem=19.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:56,731-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:04:56,925-0500 INFO Multiplexer No streams
+2013-08-09 14:04:57,101-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:57,220-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:57,220-0500 INFO ThrottleManager mem=19.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:57,601-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:57,720-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:57,720-0500 INFO ThrottleManager mem=19.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:58,101-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:58,221-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:58,221-0500 INFO ThrottleManager mem=19.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:58,602-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:58,721-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:58,721-0500 INFO ThrottleManager mem=19.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:59,102-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:59,221-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:59,221-0500 INFO ThrottleManager mem=19.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:04:59,602-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:59,722-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:04:59,722-0500 INFO ThrottleManager mem=19.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:00,102-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:00,222-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:00,222-0500 INFO ThrottleManager mem=19.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:00,603-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:00,722-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:00,722-0500 INFO ThrottleManager mem=19.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:01,103-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:01,223-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:01,223-0500 INFO ThrottleManager mem=19.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:01,603-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:01,723-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:01,723-0500 INFO ThrottleManager mem=19.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:02,104-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:02,223-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:02,224-0500 INFO ThrottleManager mem=19.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:02,604-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:02,724-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:02,724-0500 INFO ThrottleManager mem=19.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:05:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 19.2 MB
+2013-08-09 14:05:03,104-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:03,224-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:03,224-0500 INFO ThrottleManager mem=19.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:03,604-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:03,724-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:03,725-0500 INFO ThrottleManager mem=19.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:04,105-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:04,225-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:04,225-0500 INFO ThrottleManager mem=19.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:04,225-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:05:04,605-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:04,605-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:05:04,725-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:04,725-0500 INFO ThrottleManager mem=19.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:05,106-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:05,225-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:05,226-0500 INFO ThrottleManager mem=19.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:05,606-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:05,726-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:05,726-0500 INFO ThrottleManager mem=19.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:06,106-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:06,226-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:06,226-0500 INFO ThrottleManager mem=19.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:06,606-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:06,726-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:06,727-0500 INFO ThrottleManager mem=19.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:06,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:05:06,932-0500 INFO Multiplexer No streams
+2013-08-09 14:05:07,107-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:07,227-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:07,227-0500 INFO ThrottleManager mem=19.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:07,607-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:07,727-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:07,727-0500 INFO ThrottleManager mem=19.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:08,107-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:08,228-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:08,228-0500 INFO ThrottleManager mem=19.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:08,607-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:08,728-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:08,728-0500 INFO ThrottleManager mem=19.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:09,108-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:09,228-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:09,228-0500 INFO ThrottleManager mem=19.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:09,608-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:09,729-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:09,729-0500 INFO ThrottleManager mem=19.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:10,108-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:10,229-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:10,229-0500 INFO ThrottleManager mem=19.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:10,608-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:10,729-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:10,729-0500 INFO ThrottleManager mem=19.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:11,109-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:11,230-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:11,230-0500 INFO ThrottleManager mem=19.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:11,609-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:11,730-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:11,730-0500 INFO ThrottleManager mem=19.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:12,109-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:12,230-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:12,230-0500 INFO ThrottleManager mem=19.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:12,610-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:12,731-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:12,731-0500 INFO ThrottleManager mem=19.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:05:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 19.47 MB
+2013-08-09 14:05:13,110-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:13,231-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:13,231-0500 INFO ThrottleManager mem=19.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:13,610-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:13,731-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:13,731-0500 INFO ThrottleManager mem=19.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:14,111-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:14,232-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:14,232-0500 INFO ThrottleManager mem=19.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:14,232-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:05:14,611-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:14,611-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:05:14,732-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:14,732-0500 INFO ThrottleManager mem=19.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:15,111-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:15,232-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:15,232-0500 INFO ThrottleManager mem=19.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:15,611-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:15,733-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:15,733-0500 INFO ThrottleManager mem=19.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:16,112-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:16,233-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:16,233-0500 INFO ThrottleManager mem=19.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:16,612-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:16,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:05:16,733-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:16,733-0500 INFO ThrottleManager mem=19.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:16,938-0500 INFO Multiplexer No streams
+2013-08-09 14:05:17,112-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:17,234-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:17,234-0500 INFO ThrottleManager mem=19.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:17,612-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:17,734-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:17,734-0500 INFO ThrottleManager mem=19.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:18,113-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:18,234-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:18,234-0500 INFO ThrottleManager mem=19.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:18,613-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:18,735-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:18,735-0500 INFO ThrottleManager mem=19.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:19,113-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:19,235-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:19,235-0500 INFO ThrottleManager mem=19.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:19,613-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:19,735-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:19,736-0500 INFO ThrottleManager mem=19.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:20,114-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:20,236-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:20,236-0500 INFO ThrottleManager mem=19.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:20,614-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:20,736-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:20,736-0500 INFO ThrottleManager mem=19.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:21,114-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:21,236-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:21,236-0500 INFO ThrottleManager mem=19.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:21,615-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:21,737-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:21,737-0500 INFO ThrottleManager mem=19.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:22,115-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:22,237-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:22,237-0500 INFO ThrottleManager mem=19.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:22,615-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:22,737-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:22,738-0500 INFO ThrottleManager mem=19.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:05:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 19.73 MB
+2013-08-09 14:05:23,116-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:23,238-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:23,238-0500 INFO ThrottleManager mem=19.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:23,616-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:23,738-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:23,738-0500 INFO ThrottleManager mem=19.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:24,116-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:24,238-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:24,239-0500 INFO ThrottleManager mem=19.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:24,239-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:05:24,616-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:24,616-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:05:24,739-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:24,739-0500 INFO ThrottleManager mem=19.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:25,117-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:25,239-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:25,239-0500 INFO ThrottleManager mem=19.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:25,617-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:25,740-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:25,740-0500 INFO ThrottleManager mem=19.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:26,117-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:26,240-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:26,240-0500 INFO ThrottleManager mem=19.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:26,617-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:26,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:05:26,740-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:26,740-0500 INFO ThrottleManager mem=19.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:26,942-0500 INFO Multiplexer No streams
+2013-08-09 14:05:27,118-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:27,240-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:27,241-0500 INFO ThrottleManager mem=19.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:27,618-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:27,741-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:27,741-0500 INFO ThrottleManager mem=19.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:28,118-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:28,241-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:28,241-0500 INFO ThrottleManager mem=19.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:28,618-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:28,741-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:28,742-0500 INFO ThrottleManager mem=19.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:29,118-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:29,242-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:29,242-0500 INFO ThrottleManager mem=19.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:29,618-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:29,742-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:29,742-0500 INFO ThrottleManager mem=19.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:30,119-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:30,242-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:30,243-0500 INFO ThrottleManager mem=19.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:30,619-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:30,743-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:30,743-0500 INFO ThrottleManager mem=19.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:31,119-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:31,243-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:31,243-0500 INFO ThrottleManager mem=19.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:31,619-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:31,744-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:31,744-0500 INFO ThrottleManager mem=19.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:32,120-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:32,244-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:32,244-0500 INFO ThrottleManager mem=19.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:32,620-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:32,744-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:32,744-0500 INFO ThrottleManager mem=19.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:05:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 19.99 MB
+2013-08-09 14:05:33,120-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:33,245-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:33,245-0500 INFO ThrottleManager mem=20 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:33,620-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:33,745-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:33,745-0500 INFO ThrottleManager mem=20.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:34,121-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:34,245-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:34,245-0500 INFO ThrottleManager mem=20.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:34,245-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:05:34,621-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:34,621-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:05:34,746-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:34,746-0500 INFO ThrottleManager mem=20.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:35,121-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:35,246-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:35,246-0500 INFO ThrottleManager mem=20.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:35,622-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:35,746-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:35,746-0500 INFO ThrottleManager mem=20.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:36,122-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:36,247-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:36,247-0500 INFO ThrottleManager mem=20.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:36,622-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:36,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:05:36,747-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:36,747-0500 INFO ThrottleManager mem=20.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:36,946-0500 INFO Multiplexer No streams
+2013-08-09 14:05:37,122-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:37,247-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:37,247-0500 INFO ThrottleManager mem=20.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:37,623-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:37,748-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:37,748-0500 INFO ThrottleManager mem=20.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:38,123-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:38,248-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:38,248-0500 INFO ThrottleManager mem=20.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:38,623-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:38,748-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:38,748-0500 INFO ThrottleManager mem=20.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:39,123-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:39,249-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:39,249-0500 INFO ThrottleManager mem=20.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:39,624-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:39,749-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:39,749-0500 INFO ThrottleManager mem=20.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:40,124-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:40,249-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:40,249-0500 INFO ThrottleManager mem=20.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:40,624-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:40,750-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:40,750-0500 INFO ThrottleManager mem=20.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:41,124-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:41,250-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:41,250-0500 INFO ThrottleManager mem=20.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:41,625-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:41,750-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:41,751-0500 INFO ThrottleManager mem=20.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:42,125-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:42,251-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:42,251-0500 INFO ThrottleManager mem=20.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:42,625-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:42,751-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:42,751-0500 INFO ThrottleManager mem=20.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:05:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 20.25 MB
+2013-08-09 14:05:43,125-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:43,251-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:43,252-0500 INFO ThrottleManager mem=20.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:43,626-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:43,752-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:43,752-0500 INFO ThrottleManager mem=20.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:44,126-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:44,252-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:44,252-0500 INFO ThrottleManager mem=20.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:44,252-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:05:44,626-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:44,626-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:05:44,752-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:44,753-0500 INFO ThrottleManager mem=20.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:45,126-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:45,253-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:45,253-0500 INFO ThrottleManager mem=20.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:45,627-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:45,753-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:45,753-0500 INFO ThrottleManager mem=20.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:46,127-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:46,253-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:46,254-0500 INFO ThrottleManager mem=20.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:46,627-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:46,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:05:46,754-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:46,754-0500 INFO ThrottleManager mem=20.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:46,949-0500 INFO Multiplexer No streams
+2013-08-09 14:05:47,127-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:47,254-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:47,254-0500 INFO ThrottleManager mem=20.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:47,628-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:47,755-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:47,755-0500 INFO ThrottleManager mem=20.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:48,128-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:48,255-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:48,255-0500 INFO ThrottleManager mem=20.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:48,628-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:48,755-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:48,755-0500 INFO ThrottleManager mem=20.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:49,128-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:49,256-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:49,256-0500 INFO ThrottleManager mem=20.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:49,629-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:49,756-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:49,756-0500 INFO ThrottleManager mem=20.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:50,129-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:50,256-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:50,256-0500 INFO ThrottleManager mem=20.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:50,629-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:50,757-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:50,757-0500 INFO ThrottleManager mem=20.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:51,129-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:51,257-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:51,257-0500 INFO ThrottleManager mem=20.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:51,630-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:51,757-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:51,757-0500 INFO ThrottleManager mem=20.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:52,130-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:52,258-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:52,258-0500 INFO ThrottleManager mem=20.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:52,630-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:52,758-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:52,758-0500 INFO ThrottleManager mem=20.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:52,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:05:52,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 20.51 MB
+2013-08-09 14:05:53,131-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:53,258-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:53,258-0500 INFO ThrottleManager mem=20.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:53,631-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:53,759-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:53,759-0500 INFO ThrottleManager mem=20.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:54,131-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:54,259-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:54,259-0500 INFO ThrottleManager mem=20.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:54,259-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:05:54,631-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:54,631-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:05:54,759-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:54,759-0500 INFO ThrottleManager mem=20.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:55,132-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:55,260-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:55,260-0500 INFO ThrottleManager mem=20.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:55,632-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:55,760-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:55,760-0500 INFO ThrottleManager mem=20.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:56,132-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:56,260-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:56,261-0500 INFO ThrottleManager mem=20.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:56,632-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:56,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:05:56,761-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:56,761-0500 INFO ThrottleManager mem=20.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:56,954-0500 INFO Multiplexer No streams
+2013-08-09 14:05:57,133-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:57,261-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:57,261-0500 INFO ThrottleManager mem=20.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:57,633-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:57,761-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:57,762-0500 INFO ThrottleManager mem=20.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:58,133-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:58,262-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:58,262-0500 INFO ThrottleManager mem=20.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:58,633-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:58,762-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:58,762-0500 INFO ThrottleManager mem=20.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:59,134-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:59,262-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:59,263-0500 INFO ThrottleManager mem=20.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:05:59,634-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:59,763-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:05:59,763-0500 INFO ThrottleManager mem=20.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:00,134-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:00,263-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:00,263-0500 INFO ThrottleManager mem=20.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:00,634-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:00,763-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:00,763-0500 INFO ThrottleManager mem=20.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:01,135-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:01,264-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:01,264-0500 INFO ThrottleManager mem=20.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:01,635-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:01,764-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:01,764-0500 INFO ThrottleManager mem=20.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:02,135-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:02,264-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:02,265-0500 INFO ThrottleManager mem=20.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:02,635-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:02,765-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:02,765-0500 INFO ThrottleManager mem=20.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:06:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 20.78 MB
+2013-08-09 14:06:03,136-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:03,265-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:03,265-0500 INFO ThrottleManager mem=20.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:03,636-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:03,765-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:03,766-0500 INFO ThrottleManager mem=20.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:04,136-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:04,266-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:04,266-0500 INFO ThrottleManager mem=20.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:04,266-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:06:04,636-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:04,637-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:06:04,766-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:04,766-0500 INFO ThrottleManager mem=20.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:05,137-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:05,266-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:05,267-0500 INFO ThrottleManager mem=20.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:05,637-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:05,767-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:05,767-0500 INFO ThrottleManager mem=20.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:06,137-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:06,267-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:06,267-0500 INFO ThrottleManager mem=20.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:06,637-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:06,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:06:06,767-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:06,768-0500 INFO ThrottleManager mem=20.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:06,960-0500 INFO Multiplexer No streams
+2013-08-09 14:06:07,138-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:07,268-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:07,268-0500 INFO ThrottleManager mem=20.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:07,638-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:07,768-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:07,768-0500 INFO ThrottleManager mem=20.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:08,138-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:08,268-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:08,269-0500 INFO ThrottleManager mem=20.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:08,638-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:08,769-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:08,769-0500 INFO ThrottleManager mem=20.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:09,139-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:09,269-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:09,269-0500 INFO ThrottleManager mem=20.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:09,639-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:09,770-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:09,770-0500 INFO ThrottleManager mem=20.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:10,139-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:10,270-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:10,270-0500 INFO ThrottleManager mem=20.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:10,639-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:10,770-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:10,770-0500 INFO ThrottleManager mem=20.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:11,140-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:11,271-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:11,271-0500 INFO ThrottleManager mem=20.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:11,640-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:11,771-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:11,771-0500 INFO ThrottleManager mem=21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:12,140-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:12,271-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:12,271-0500 INFO ThrottleManager mem=21.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:12,641-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:12,772-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:12,772-0500 INFO ThrottleManager mem=21.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:06:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 21.04 MB
+2013-08-09 14:06:13,141-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:13,272-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:13,272-0500 INFO ThrottleManager mem=21.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:13,641-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:13,772-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:13,772-0500 INFO ThrottleManager mem=21.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:14,141-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:14,273-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:14,273-0500 INFO ThrottleManager mem=21.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:14,273-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:06:14,642-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:14,642-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:06:14,773-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:14,773-0500 INFO ThrottleManager mem=21.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:15,142-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:15,273-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:15,273-0500 INFO ThrottleManager mem=21.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:15,642-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:15,774-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:15,774-0500 INFO ThrottleManager mem=21.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:16,142-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:16,274-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:16,274-0500 INFO ThrottleManager mem=21.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:16,643-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:16,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:06:16,774-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:16,774-0500 INFO ThrottleManager mem=21.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:16,963-0500 INFO Multiplexer No streams
+2013-08-09 14:06:17,143-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:17,275-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:17,275-0500 INFO ThrottleManager mem=21.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:17,643-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:17,775-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:17,775-0500 INFO ThrottleManager mem=21.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:18,143-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:18,275-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:18,275-0500 INFO ThrottleManager mem=21.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:18,644-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:18,776-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:18,776-0500 INFO ThrottleManager mem=21.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:19,144-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:19,276-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:19,276-0500 INFO ThrottleManager mem=21.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:19,644-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:19,776-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:19,776-0500 INFO ThrottleManager mem=21.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:20,144-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:20,277-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:20,277-0500 INFO ThrottleManager mem=21.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:20,645-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:20,777-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:20,777-0500 INFO ThrottleManager mem=21.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:21,145-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:21,277-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:21,277-0500 INFO ThrottleManager mem=21.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:21,645-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:21,778-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:21,778-0500 INFO ThrottleManager mem=21.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:22,145-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:22,278-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:22,278-0500 INFO ThrottleManager mem=21.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:22,646-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:22,778-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:22,778-0500 INFO ThrottleManager mem=21.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:06:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 21.3 MB
+2013-08-09 14:06:23,146-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:23,279-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:23,279-0500 INFO ThrottleManager mem=21.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:23,646-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:23,779-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:23,779-0500 INFO ThrottleManager mem=21.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:24,147-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:24,279-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:24,279-0500 INFO ThrottleManager mem=21.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:24,279-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:06:24,647-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:24,647-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:06:24,779-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:24,780-0500 INFO ThrottleManager mem=21.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:25,147-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:25,280-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:25,280-0500 INFO ThrottleManager mem=21.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:25,647-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:25,780-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:25,780-0500 INFO ThrottleManager mem=21.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:26,148-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:26,281-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:26,281-0500 INFO ThrottleManager mem=21.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:26,648-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:26,732-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:06:26,781-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:26,781-0500 INFO ThrottleManager mem=21.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:26,967-0500 INFO Multiplexer No streams
+2013-08-09 14:06:27,148-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:27,281-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:27,281-0500 INFO ThrottleManager mem=21.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:27,648-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:27,782-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:27,782-0500 INFO ThrottleManager mem=21.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:28,149-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:28,282-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:28,282-0500 INFO ThrottleManager mem=21.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:28,649-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:28,782-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:28,782-0500 INFO ThrottleManager mem=21.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:29,149-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:29,283-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:29,283-0500 INFO ThrottleManager mem=21.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:29,649-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:29,783-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:29,783-0500 INFO ThrottleManager mem=21.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:30,150-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:30,283-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:30,283-0500 INFO ThrottleManager mem=21.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:30,650-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:30,784-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:30,784-0500 INFO ThrottleManager mem=21.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:31,150-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:31,284-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:31,284-0500 INFO ThrottleManager mem=21.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:31,650-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:31,784-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:31,784-0500 INFO ThrottleManager mem=21.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:32,151-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:32,285-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:32,285-0500 INFO ThrottleManager mem=21.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:32,651-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:32,785-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:32,785-0500 INFO ThrottleManager mem=21.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:32,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:06:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 21.56 MB
+2013-08-09 14:06:33,151-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:33,285-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:33,285-0500 INFO ThrottleManager mem=21.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:33,652-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:33,786-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:33,786-0500 INFO ThrottleManager mem=21.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:34,152-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:34,286-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:34,286-0500 INFO ThrottleManager mem=21.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:34,286-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:06:34,652-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:34,652-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:06:34,786-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:34,786-0500 INFO ThrottleManager mem=21.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:35,153-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:35,287-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:35,287-0500 INFO ThrottleManager mem=21.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:35,653-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:35,787-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:35,787-0500 INFO ThrottleManager mem=21.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:36,153-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:36,287-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:36,287-0500 INFO ThrottleManager mem=21.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:36,653-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:36,733-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:06:36,788-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:36,788-0500 INFO ThrottleManager mem=21.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:36,972-0500 INFO Multiplexer No streams
+2013-08-09 14:06:37,154-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:37,288-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:37,288-0500 INFO ThrottleManager mem=21.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:37,654-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:37,788-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:37,788-0500 INFO ThrottleManager mem=21.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:38,154-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:38,289-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:38,289-0500 INFO ThrottleManager mem=21.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:38,654-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:38,789-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:38,789-0500 INFO ThrottleManager mem=21.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:39,155-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:39,289-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:39,289-0500 INFO ThrottleManager mem=21.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:39,655-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:39,790-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:39,790-0500 INFO ThrottleManager mem=21.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:40,155-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:40,290-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:40,290-0500 INFO ThrottleManager mem=21.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:40,655-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:40,790-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:40,790-0500 INFO ThrottleManager mem=21.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:41,156-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:41,291-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:41,291-0500 INFO ThrottleManager mem=21.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:41,656-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:41,791-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:41,791-0500 INFO ThrottleManager mem=21.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:42,156-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:42,291-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:42,291-0500 INFO ThrottleManager mem=21.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:42,657-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:42,792-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:42,792-0500 INFO ThrottleManager mem=21.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:06:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 21.82 MB
+2013-08-09 14:06:43,157-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:43,292-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:43,292-0500 INFO ThrottleManager mem=21.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:43,657-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:43,792-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:43,792-0500 INFO ThrottleManager mem=21.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:44,157-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:44,293-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:44,293-0500 INFO ThrottleManager mem=21.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:44,293-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:06:44,658-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:44,658-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:06:44,793-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:44,793-0500 INFO ThrottleManager mem=21.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:45,158-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:45,293-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:45,293-0500 INFO ThrottleManager mem=21.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:45,658-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:45,794-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:45,794-0500 INFO ThrottleManager mem=21.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:46,158-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:46,294-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:46,294-0500 INFO ThrottleManager mem=21.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:46,659-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:46,733-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:06:46,794-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:46,794-0500 INFO ThrottleManager mem=21.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:46,976-0500 INFO Multiplexer No streams
+2013-08-09 14:06:47,159-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:47,295-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:47,295-0500 INFO ThrottleManager mem=21.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:47,659-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:47,795-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:47,795-0500 INFO ThrottleManager mem=21.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:48,159-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:48,295-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:48,295-0500 INFO ThrottleManager mem=21.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:48,660-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:48,796-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:48,796-0500 INFO ThrottleManager mem=21.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:49,160-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:49,296-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:49,296-0500 INFO ThrottleManager mem=21.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:49,660-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:49,796-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:49,796-0500 INFO ThrottleManager mem=22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:50,160-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:50,297-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:50,297-0500 INFO ThrottleManager mem=22.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:50,661-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:50,797-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:50,797-0500 INFO ThrottleManager mem=22.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:51,161-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:51,297-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:51,297-0500 INFO ThrottleManager mem=22.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:51,661-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:51,798-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:51,798-0500 INFO ThrottleManager mem=22.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:52,161-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:52,298-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:52,298-0500 INFO ThrottleManager mem=22.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:52,662-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:52,798-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:52,798-0500 INFO ThrottleManager mem=22.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:06:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 22.08 MB
+2013-08-09 14:06:53,162-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:53,299-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:53,299-0500 INFO ThrottleManager mem=22.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:53,662-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:53,799-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:53,799-0500 INFO ThrottleManager mem=22.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:54,163-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:54,299-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:54,299-0500 INFO ThrottleManager mem=22.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:54,299-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:06:54,663-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:54,663-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:06:54,800-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:54,800-0500 INFO ThrottleManager mem=22.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:55,163-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:55,300-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:55,300-0500 INFO ThrottleManager mem=22.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:55,663-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:55,800-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:55,800-0500 INFO ThrottleManager mem=22.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:56,164-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:56,301-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:56,301-0500 INFO ThrottleManager mem=22.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:56,664-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:56,733-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:06:56,801-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:56,801-0500 INFO ThrottleManager mem=22.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:56,980-0500 INFO Multiplexer No streams
+2013-08-09 14:06:57,164-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:57,301-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:57,301-0500 INFO ThrottleManager mem=22.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:57,664-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:57,802-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:57,802-0500 INFO ThrottleManager mem=22.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:58,165-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:58,302-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:58,302-0500 INFO ThrottleManager mem=22.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:58,665-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:58,802-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:58,802-0500 INFO ThrottleManager mem=22.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:59,165-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:59,303-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:59,303-0500 INFO ThrottleManager mem=22.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:06:59,665-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:59,803-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:06:59,803-0500 INFO ThrottleManager mem=22.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:00,166-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:00,303-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:00,303-0500 INFO ThrottleManager mem=22.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:00,666-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:00,804-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:00,804-0500 INFO ThrottleManager mem=22.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:01,166-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:01,304-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:01,304-0500 INFO ThrottleManager mem=22.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:01,666-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:01,804-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:01,804-0500 INFO ThrottleManager mem=22.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:02,167-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:02,305-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:02,305-0500 INFO ThrottleManager mem=22.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:02,667-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:02,805-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:02,805-0500 INFO ThrottleManager mem=22.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:07:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 22.34 MB
+2013-08-09 14:07:03,167-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:03,305-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:03,305-0500 INFO ThrottleManager mem=22.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:03,667-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:03,806-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:03,806-0500 INFO ThrottleManager mem=22.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:04,168-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:04,306-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:04,306-0500 INFO ThrottleManager mem=22.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:04,306-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:07:04,668-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:04,668-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:07:04,806-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:04,806-0500 INFO ThrottleManager mem=22.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:05,168-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:05,307-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:05,307-0500 INFO ThrottleManager mem=22.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:05,669-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:05,807-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:05,807-0500 INFO ThrottleManager mem=22.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:06,169-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:06,307-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:06,307-0500 INFO ThrottleManager mem=22.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:06,669-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:06,733-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:07:06,808-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:06,808-0500 INFO ThrottleManager mem=22.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:06,985-0500 INFO Multiplexer No streams
+2013-08-09 14:07:07,169-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:07,308-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:07,308-0500 INFO ThrottleManager mem=22.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:07,670-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:07,808-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:07,808-0500 INFO ThrottleManager mem=22.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:08,170-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:08,309-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:08,309-0500 INFO ThrottleManager mem=22.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:08,670-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:08,809-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:08,809-0500 INFO ThrottleManager mem=22.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:09,170-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:09,309-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:09,309-0500 INFO ThrottleManager mem=22.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:09,671-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:09,810-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:09,810-0500 INFO ThrottleManager mem=22.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:10,171-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:10,310-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:10,310-0500 INFO ThrottleManager mem=22.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:10,671-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:10,810-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:10,810-0500 INFO ThrottleManager mem=22.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:11,171-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:11,311-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:11,311-0500 INFO ThrottleManager mem=22.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:11,672-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:11,811-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:11,811-0500 INFO ThrottleManager mem=22.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:12,172-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:12,311-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:12,311-0500 INFO ThrottleManager mem=22.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:12,672-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:12,812-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:12,812-0500 INFO ThrottleManager mem=22.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:07:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 22.59 MB
+2013-08-09 14:07:13,172-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:13,312-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:13,312-0500 INFO ThrottleManager mem=22.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:13,673-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:13,812-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:13,812-0500 INFO ThrottleManager mem=22.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:14,173-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:14,313-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:14,313-0500 INFO ThrottleManager mem=22.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:14,313-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:07:14,673-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:14,673-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:07:14,813-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:14,813-0500 INFO ThrottleManager mem=22.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:15,174-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:15,313-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:15,313-0500 INFO ThrottleManager mem=22.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:15,674-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:15,814-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:15,814-0500 INFO ThrottleManager mem=22.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:16,174-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:16,314-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:16,314-0500 INFO ThrottleManager mem=22.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:16,674-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:16,734-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:07:16,814-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:16,814-0500 INFO ThrottleManager mem=22.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:16,989-0500 INFO Multiplexer No streams
+2013-08-09 14:07:17,175-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:17,315-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:17,315-0500 INFO ThrottleManager mem=22.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:17,675-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:17,815-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:17,815-0500 INFO ThrottleManager mem=22.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:18,175-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:18,315-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:18,315-0500 INFO ThrottleManager mem=22.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:18,675-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:18,816-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:18,816-0500 INFO ThrottleManager mem=22.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:19,176-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:19,316-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:19,316-0500 INFO ThrottleManager mem=22.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:19,676-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:19,816-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:19,816-0500 INFO ThrottleManager mem=22.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:20,176-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:20,317-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:20,317-0500 INFO ThrottleManager mem=22.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:20,676-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:20,817-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:20,817-0500 INFO ThrottleManager mem=22.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:21,176-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:21,317-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:21,317-0500 INFO ThrottleManager mem=22.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:21,677-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:21,818-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:21,818-0500 INFO ThrottleManager mem=22.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:22,177-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:22,318-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:22,318-0500 INFO ThrottleManager mem=22.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:22,677-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:22,818-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:22,818-0500 INFO ThrottleManager mem=22.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:07:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 22.85 MB
+2013-08-09 14:07:23,178-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:23,319-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:23,319-0500 INFO ThrottleManager mem=22.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:23,678-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:23,819-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:23,819-0500 INFO ThrottleManager mem=22.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:24,178-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:24,319-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:24,319-0500 INFO ThrottleManager mem=22.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:24,319-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:07:24,678-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:24,678-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:07:24,820-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:24,820-0500 INFO ThrottleManager mem=22.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:25,179-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:25,320-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:25,320-0500 INFO ThrottleManager mem=22.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:25,679-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:25,820-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:25,820-0500 INFO ThrottleManager mem=22.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:26,179-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:26,321-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:26,321-0500 INFO ThrottleManager mem=22.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:26,679-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:26,734-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:07:26,821-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:26,821-0500 INFO ThrottleManager mem=22.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:26,997-0500 INFO Multiplexer No streams
+2013-08-09 14:07:27,180-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:27,321-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:27,321-0500 INFO ThrottleManager mem=22.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:27,680-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:27,822-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:27,822-0500 INFO ThrottleManager mem=22.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:28,180-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:28,322-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:28,322-0500 INFO ThrottleManager mem=22.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:28,680-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:28,822-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:28,822-0500 INFO ThrottleManager mem=23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:29,181-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:29,323-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:29,323-0500 INFO ThrottleManager mem=23.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:29,681-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:29,823-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:29,823-0500 INFO ThrottleManager mem=23.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:30,181-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:30,323-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:30,323-0500 INFO ThrottleManager mem=23.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:30,681-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:30,824-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:30,824-0500 INFO ThrottleManager mem=23.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:31,182-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:31,324-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:31,324-0500 INFO ThrottleManager mem=23.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:31,682-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:31,824-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:31,824-0500 INFO ThrottleManager mem=23.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:32,182-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:32,325-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:32,325-0500 INFO ThrottleManager mem=23.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:32,682-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:32,825-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:32,825-0500 INFO ThrottleManager mem=23.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:07:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 23.11 MB
+2013-08-09 14:07:33,183-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:33,325-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:33,325-0500 INFO ThrottleManager mem=23.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:33,683-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:33,826-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:33,826-0500 INFO ThrottleManager mem=23.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:34,183-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:34,326-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:34,326-0500 INFO ThrottleManager mem=23.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:34,326-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:07:34,683-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:34,684-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:07:34,826-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:34,826-0500 INFO ThrottleManager mem=23.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:35,184-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:35,327-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:35,327-0500 INFO ThrottleManager mem=23.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:35,684-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:35,827-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:35,827-0500 INFO ThrottleManager mem=23.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:36,185-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:36,327-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:36,327-0500 INFO ThrottleManager mem=23.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:36,685-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:36,734-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:07:36,828-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:36,828-0500 INFO ThrottleManager mem=23.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:37,004-0500 INFO Multiplexer No streams
+2013-08-09 14:07:37,185-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:37,328-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:37,328-0500 INFO ThrottleManager mem=23.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:37,685-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:37,828-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:37,828-0500 INFO ThrottleManager mem=23.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:38,186-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:38,329-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:38,329-0500 INFO ThrottleManager mem=23.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:38,686-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:38,829-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:38,829-0500 INFO ThrottleManager mem=23.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:39,186-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:39,329-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:39,329-0500 INFO ThrottleManager mem=23.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:39,686-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:39,830-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:39,830-0500 INFO ThrottleManager mem=23.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:40,187-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:40,330-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:40,330-0500 INFO ThrottleManager mem=23.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:40,687-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:40,830-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:40,830-0500 INFO ThrottleManager mem=23.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:41,187-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:41,331-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:41,331-0500 INFO ThrottleManager mem=23.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:41,688-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:41,831-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:41,831-0500 INFO ThrottleManager mem=23.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:42,188-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:42,331-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:42,331-0500 INFO ThrottleManager mem=23.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:42,688-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:42,832-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:42,832-0500 INFO ThrottleManager mem=23.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:07:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 23.37 MB
+2013-08-09 14:07:43,188-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:43,332-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:43,332-0500 INFO ThrottleManager mem=23.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:43,689-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:43,832-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:43,832-0500 INFO ThrottleManager mem=23.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:44,189-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:44,333-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:44,333-0500 INFO ThrottleManager mem=23.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:44,333-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:07:44,689-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:44,689-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:07:44,833-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:44,833-0500 INFO ThrottleManager mem=23.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:45,189-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:45,333-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:45,333-0500 INFO ThrottleManager mem=23.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:45,690-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:45,834-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:45,834-0500 INFO ThrottleManager mem=23.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:46,190-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:46,334-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:46,334-0500 INFO ThrottleManager mem=23.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:46,690-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:46,734-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:07:46,834-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:46,835-0500 INFO ThrottleManager mem=23.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:47,008-0500 INFO Multiplexer No streams
+2013-08-09 14:07:47,190-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:47,335-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:47,335-0500 INFO ThrottleManager mem=23.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:47,691-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:47,835-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:47,835-0500 INFO ThrottleManager mem=23.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:48,191-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:48,335-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:48,336-0500 INFO ThrottleManager mem=23.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:48,691-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:48,836-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:48,836-0500 INFO ThrottleManager mem=23.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:49,191-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:49,336-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:49,336-0500 INFO ThrottleManager mem=23.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:49,692-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:49,837-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:49,837-0500 INFO ThrottleManager mem=23.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:50,192-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:50,337-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:50,337-0500 INFO ThrottleManager mem=23.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:50,692-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:50,837-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:50,837-0500 INFO ThrottleManager mem=23.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:51,192-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:51,338-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:51,338-0500 INFO ThrottleManager mem=23.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:51,693-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:51,838-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:51,838-0500 INFO ThrottleManager mem=23.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:52,193-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:52,338-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:52,338-0500 INFO ThrottleManager mem=23.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:52,693-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:52,839-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:52,839-0500 INFO ThrottleManager mem=23.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:07:52,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 23.63 MB
+2013-08-09 14:07:53,194-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:53,339-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:53,339-0500 INFO ThrottleManager mem=23.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:53,694-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:53,839-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:53,839-0500 INFO ThrottleManager mem=23.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:54,194-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:54,340-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:54,340-0500 INFO ThrottleManager mem=23.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:54,340-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:07:54,694-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:54,694-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:07:54,840-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:54,840-0500 INFO ThrottleManager mem=23.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:55,195-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:55,340-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:55,340-0500 INFO ThrottleManager mem=23.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:55,695-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:55,841-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:55,841-0500 INFO ThrottleManager mem=23.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:56,195-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:56,341-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:56,341-0500 INFO ThrottleManager mem=23.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:56,695-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:56,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:07:56,841-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:56,841-0500 INFO ThrottleManager mem=23.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:57,013-0500 INFO Multiplexer No streams
+2013-08-09 14:07:57,196-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:57,342-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:57,342-0500 INFO ThrottleManager mem=23.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:57,696-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:57,842-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:57,842-0500 INFO ThrottleManager mem=23.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:58,196-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:58,342-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:58,342-0500 INFO ThrottleManager mem=23.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:58,696-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:58,843-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:58,843-0500 INFO ThrottleManager mem=23.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:59,197-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:59,343-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:59,343-0500 INFO ThrottleManager mem=23.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:07:59,697-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:59,843-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:07:59,843-0500 INFO ThrottleManager mem=23.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:00,197-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:00,344-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:00,344-0500 INFO ThrottleManager mem=23.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:00,697-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:00,844-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:00,844-0500 INFO ThrottleManager mem=23.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:01,198-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:01,344-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:01,344-0500 INFO ThrottleManager mem=23.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:01,698-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:01,845-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:01,845-0500 INFO ThrottleManager mem=23.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:02,198-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:02,345-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:02,345-0500 INFO ThrottleManager mem=23.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:02,698-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:02,845-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:02,845-0500 INFO ThrottleManager mem=23.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:08:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 23.89 MB
+2013-08-09 14:08:03,199-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:03,346-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:03,346-0500 INFO ThrottleManager mem=23.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:03,699-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:03,846-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:03,846-0500 INFO ThrottleManager mem=23.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:04,199-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:04,346-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:04,347-0500 INFO ThrottleManager mem=23.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:04,347-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:08:04,699-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:04,700-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:08:04,847-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:04,847-0500 INFO ThrottleManager mem=23.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:05,200-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:05,347-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:05,347-0500 INFO ThrottleManager mem=23.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:05,700-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:05,847-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:05,848-0500 INFO ThrottleManager mem=23.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:06,200-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:06,348-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:06,348-0500 INFO ThrottleManager mem=23.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:06,701-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:06,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:08:06,848-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:06,848-0500 INFO ThrottleManager mem=23.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:07,015-0500 INFO Multiplexer No streams
+2013-08-09 14:08:07,201-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:07,349-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:07,349-0500 INFO ThrottleManager mem=24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:07,701-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:07,849-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:07,849-0500 INFO ThrottleManager mem=24.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:08,201-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:08,349-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:08,349-0500 INFO ThrottleManager mem=24.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:08,702-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:08,850-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:08,850-0500 INFO ThrottleManager mem=24.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:09,202-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:09,350-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:09,350-0500 INFO ThrottleManager mem=24.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:09,702-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:09,850-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:09,850-0500 INFO ThrottleManager mem=24.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:10,202-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:10,351-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:10,351-0500 INFO ThrottleManager mem=24.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:10,703-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:10,851-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:10,851-0500 INFO ThrottleManager mem=24.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:11,203-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:11,351-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:11,351-0500 INFO ThrottleManager mem=24.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:11,703-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:11,852-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:11,852-0500 INFO ThrottleManager mem=24.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:12,204-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:12,352-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:12,352-0500 INFO ThrottleManager mem=24.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:12,704-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:12,852-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:12,852-0500 INFO ThrottleManager mem=24.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:08:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 24.15 MB
+2013-08-09 14:08:13,204-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:13,353-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:13,353-0500 INFO ThrottleManager mem=24.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:13,704-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:13,853-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:13,853-0500 INFO ThrottleManager mem=24.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:14,205-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:14,353-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:14,353-0500 INFO ThrottleManager mem=24.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:14,354-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:08:14,705-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:14,705-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:08:14,854-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:14,854-0500 INFO ThrottleManager mem=24.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:15,205-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:15,354-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:15,354-0500 INFO ThrottleManager mem=24.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:15,706-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:15,854-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:15,855-0500 INFO ThrottleManager mem=24.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:16,206-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:16,355-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:16,355-0500 INFO ThrottleManager mem=24.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:16,706-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:16,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:08:16,855-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:16,855-0500 INFO ThrottleManager mem=24.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:17,020-0500 INFO Multiplexer No streams
+2013-08-09 14:08:17,206-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:17,355-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:17,356-0500 INFO ThrottleManager mem=24.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:17,707-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:17,856-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:17,856-0500 INFO ThrottleManager mem=24.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:18,207-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:18,356-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:18,356-0500 INFO ThrottleManager mem=24.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:18,707-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:18,857-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:18,857-0500 INFO ThrottleManager mem=24.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:19,207-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:19,357-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:19,357-0500 INFO ThrottleManager mem=24.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:19,708-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:19,857-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:19,857-0500 INFO ThrottleManager mem=24.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:20,208-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:20,358-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:20,358-0500 INFO ThrottleManager mem=24.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:20,708-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:20,858-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:20,858-0500 INFO ThrottleManager mem=24.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:21,208-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:21,358-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:21,358-0500 INFO ThrottleManager mem=24.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:21,709-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:21,859-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:21,859-0500 INFO ThrottleManager mem=24.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:22,209-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:22,359-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:22,359-0500 INFO ThrottleManager mem=24.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:22,709-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:22,859-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:22,859-0500 INFO ThrottleManager mem=24.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:22,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:08:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 24.41 MB
+2013-08-09 14:08:23,209-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:23,360-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:23,360-0500 INFO ThrottleManager mem=24.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:23,710-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:23,860-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:23,860-0500 INFO ThrottleManager mem=24.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:24,210-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:24,360-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:24,360-0500 INFO ThrottleManager mem=24.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:24,360-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:08:24,710-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:24,710-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:08:24,861-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:24,861-0500 INFO ThrottleManager mem=24.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:25,210-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:25,361-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:25,361-0500 INFO ThrottleManager mem=24.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:25,711-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:25,861-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:25,861-0500 INFO ThrottleManager mem=24.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:26,211-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:26,362-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:26,362-0500 INFO ThrottleManager mem=24.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:26,711-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:26,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:08:26,862-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:26,862-0500 INFO ThrottleManager mem=24.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:27,024-0500 INFO Multiplexer No streams
+2013-08-09 14:08:27,211-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:27,362-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:27,363-0500 INFO ThrottleManager mem=24.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:27,712-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:27,863-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:27,863-0500 INFO ThrottleManager mem=24.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:28,212-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:28,363-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:28,363-0500 INFO ThrottleManager mem=24.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:28,712-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:28,863-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:28,864-0500 INFO ThrottleManager mem=24.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:29,212-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:29,364-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:29,364-0500 INFO ThrottleManager mem=24.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:29,713-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:29,864-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:29,864-0500 INFO ThrottleManager mem=24.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:30,213-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:30,365-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:30,365-0500 INFO ThrottleManager mem=24.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:30,713-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:30,865-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:30,865-0500 INFO ThrottleManager mem=24.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:31,213-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:31,365-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:31,365-0500 INFO ThrottleManager mem=24.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:31,714-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:31,866-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:31,866-0500 INFO ThrottleManager mem=24.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:32,214-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:32,366-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:32,366-0500 INFO ThrottleManager mem=24.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:32,714-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:32,866-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:32,866-0500 INFO ThrottleManager mem=24.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:08:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 24.66 MB
+2013-08-09 14:08:33,214-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:33,367-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:33,367-0500 INFO ThrottleManager mem=24.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:33,715-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:33,867-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:33,867-0500 INFO ThrottleManager mem=24.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:34,215-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:34,367-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:34,367-0500 INFO ThrottleManager mem=24.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:34,367-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:08:34,715-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:34,715-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:08:34,868-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:34,868-0500 INFO ThrottleManager mem=24.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:35,216-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:35,368-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:35,368-0500 INFO ThrottleManager mem=24.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:35,716-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:35,868-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:35,868-0500 INFO ThrottleManager mem=24.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:36,216-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:36,369-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:36,369-0500 INFO ThrottleManager mem=24.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:36,716-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:36,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:08:36,869-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:36,869-0500 INFO ThrottleManager mem=24.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:37,028-0500 INFO Multiplexer No streams
+2013-08-09 14:08:37,217-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:37,369-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:37,369-0500 INFO ThrottleManager mem=24.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:37,717-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:37,870-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:37,870-0500 INFO ThrottleManager mem=24.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:38,217-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:38,370-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:38,370-0500 INFO ThrottleManager mem=24.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:38,717-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:38,870-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:38,870-0500 INFO ThrottleManager mem=24.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:39,218-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:39,371-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:39,371-0500 INFO ThrottleManager mem=24.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:39,718-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:39,871-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:39,871-0500 INFO ThrottleManager mem=24.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:40,218-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:40,371-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:40,371-0500 INFO ThrottleManager mem=24.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:40,718-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:40,872-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:40,872-0500 INFO ThrottleManager mem=24.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:41,219-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:41,372-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:41,372-0500 INFO ThrottleManager mem=24.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:41,719-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:41,872-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:41,872-0500 INFO ThrottleManager mem=24.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:42,219-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:42,373-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:42,373-0500 INFO ThrottleManager mem=24.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:42,720-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:42,873-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:42,873-0500 INFO ThrottleManager mem=24.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:08:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 24.92 MB
+2013-08-09 14:08:43,220-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:43,373-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:43,374-0500 INFO ThrottleManager mem=24.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:43,720-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:43,874-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:43,874-0500 INFO ThrottleManager mem=24.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:44,220-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:44,374-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:44,374-0500 INFO ThrottleManager mem=24.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:44,374-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:08:44,721-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:44,721-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:08:44,875-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:44,875-0500 INFO ThrottleManager mem=24.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:45,221-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:45,375-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:45,375-0500 INFO ThrottleManager mem=24.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:45,721-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:45,875-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:45,875-0500 INFO ThrottleManager mem=25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:46,221-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:46,376-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:46,376-0500 INFO ThrottleManager mem=25.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:46,722-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:46,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:08:46,876-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:46,876-0500 INFO ThrottleManager mem=25.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:47,033-0500 INFO Multiplexer No streams
+2013-08-09 14:08:47,222-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:47,376-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:47,376-0500 INFO ThrottleManager mem=25.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:47,722-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:47,876-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:47,876-0500 INFO ThrottleManager mem=25.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:48,222-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:48,377-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:48,377-0500 INFO ThrottleManager mem=25.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:48,723-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:48,877-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:48,877-0500 INFO ThrottleManager mem=25.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:49,223-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:49,377-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:49,378-0500 INFO ThrottleManager mem=25.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:49,723-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:49,878-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:49,878-0500 INFO ThrottleManager mem=25.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:50,223-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:50,378-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:50,378-0500 INFO ThrottleManager mem=25.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:50,724-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:50,878-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:50,879-0500 INFO ThrottleManager mem=25.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:51,224-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:51,379-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:51,379-0500 INFO ThrottleManager mem=25.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:51,724-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:51,879-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:51,879-0500 INFO ThrottleManager mem=25.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:52,224-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:52,379-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:52,380-0500 INFO ThrottleManager mem=25.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:52,725-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:52,880-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:52,880-0500 INFO ThrottleManager mem=25.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:08:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 25.18 MB
+2013-08-09 14:08:53,225-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:53,380-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:53,380-0500 INFO ThrottleManager mem=25.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:53,725-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:53,881-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:53,881-0500 INFO ThrottleManager mem=25.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:54,226-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:54,381-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:54,381-0500 INFO ThrottleManager mem=25.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:54,381-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:08:54,726-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:54,726-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:08:54,881-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:54,881-0500 INFO ThrottleManager mem=25.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:55,226-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:55,382-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:55,382-0500 INFO ThrottleManager mem=25.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:55,726-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:55,882-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:55,882-0500 INFO ThrottleManager mem=25.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:56,227-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:56,382-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:56,383-0500 INFO ThrottleManager mem=25.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:56,727-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:56,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:08:56,883-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:56,883-0500 INFO ThrottleManager mem=25.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:57,039-0500 INFO Multiplexer No streams
+2013-08-09 14:08:57,227-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:57,383-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:57,383-0500 INFO ThrottleManager mem=25.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:57,727-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:57,883-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:57,884-0500 INFO ThrottleManager mem=25.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:58,228-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:58,384-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:58,384-0500 INFO ThrottleManager mem=25.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:58,728-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:58,884-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:58,884-0500 INFO ThrottleManager mem=25.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:59,228-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:59,385-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:59,385-0500 INFO ThrottleManager mem=25.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:08:59,728-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:59,885-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:08:59,885-0500 INFO ThrottleManager mem=25.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:00,229-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:00,385-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:00,385-0500 INFO ThrottleManager mem=25.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:00,729-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:00,886-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:00,886-0500 INFO ThrottleManager mem=25.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:01,229-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:01,386-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:01,386-0500 INFO ThrottleManager mem=25.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:01,729-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:01,886-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:01,886-0500 INFO ThrottleManager mem=25.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:02,230-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:02,387-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:02,387-0500 INFO ThrottleManager mem=25.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:02,730-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:02,887-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:02,887-0500 INFO ThrottleManager mem=25.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:02,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:09:02,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 25.44 MB
+2013-08-09 14:09:03,230-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:03,387-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:03,387-0500 INFO ThrottleManager mem=25.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:03,730-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:03,888-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:03,888-0500 INFO ThrottleManager mem=25.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:04,231-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:04,388-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:04,388-0500 INFO ThrottleManager mem=25.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:04,388-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:09:04,731-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:04,731-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:09:04,888-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:04,888-0500 INFO ThrottleManager mem=25.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:05,231-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:05,389-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:05,389-0500 INFO ThrottleManager mem=25.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:05,732-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:05,889-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:05,889-0500 INFO ThrottleManager mem=25.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:06,232-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:06,389-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:06,389-0500 INFO ThrottleManager mem=25.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:06,732-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:06,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:09:06,890-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:06,890-0500 INFO ThrottleManager mem=25.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:07,045-0500 INFO Multiplexer No streams
+2013-08-09 14:09:07,232-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:07,390-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:07,390-0500 INFO ThrottleManager mem=25.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:07,733-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:07,890-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:07,891-0500 INFO ThrottleManager mem=25.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:08,233-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:08,391-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:08,391-0500 INFO ThrottleManager mem=25.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:08,733-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:08,891-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:08,891-0500 INFO ThrottleManager mem=25.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:09,233-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:09,391-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:09,392-0500 INFO ThrottleManager mem=25.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:09,734-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:09,892-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:09,892-0500 INFO ThrottleManager mem=25.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:10,234-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:10,392-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:10,392-0500 INFO ThrottleManager mem=25.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:10,734-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:10,892-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:10,893-0500 INFO ThrottleManager mem=25.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:11,235-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:11,393-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:11,393-0500 INFO ThrottleManager mem=25.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:11,735-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:11,893-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:11,893-0500 INFO ThrottleManager mem=25.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:12,235-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:12,393-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:12,394-0500 INFO ThrottleManager mem=25.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:12,735-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:12,894-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:12,894-0500 INFO ThrottleManager mem=25.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:09:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 25.7 MB
+2013-08-09 14:09:13,236-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:13,394-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:13,394-0500 INFO ThrottleManager mem=25.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:13,736-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:13,895-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:13,895-0500 INFO ThrottleManager mem=25.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:14,236-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:14,395-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:14,395-0500 INFO ThrottleManager mem=25.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:14,395-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:09:14,736-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:14,737-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:09:14,895-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:14,895-0500 INFO ThrottleManager mem=25.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:15,237-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:15,396-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:15,396-0500 INFO ThrottleManager mem=25.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:15,737-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:15,896-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:15,896-0500 INFO ThrottleManager mem=25.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:16,237-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:16,396-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:16,396-0500 INFO ThrottleManager mem=25.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:16,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:09:16,737-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:16,897-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:16,897-0500 INFO ThrottleManager mem=25.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:17,051-0500 INFO Multiplexer No streams
+2013-08-09 14:09:17,238-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:17,397-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:17,397-0500 INFO ThrottleManager mem=25.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:17,738-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:17,897-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:17,897-0500 INFO ThrottleManager mem=25.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:18,238-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:18,398-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:18,398-0500 INFO ThrottleManager mem=25.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:18,739-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:18,898-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:18,898-0500 INFO ThrottleManager mem=25.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:19,239-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:19,398-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:19,399-0500 INFO ThrottleManager mem=25.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:19,739-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:19,899-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:19,899-0500 INFO ThrottleManager mem=25.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:20,239-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:20,399-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:20,399-0500 INFO ThrottleManager mem=25.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:20,740-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:20,899-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:20,900-0500 INFO ThrottleManager mem=25.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:21,240-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:21,400-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:21,400-0500 INFO ThrottleManager mem=25.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:21,740-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:21,900-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:21,900-0500 INFO ThrottleManager mem=25.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:22,240-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:22,400-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:22,401-0500 INFO ThrottleManager mem=25.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:22,741-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:22,901-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:22,901-0500 INFO ThrottleManager mem=25.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:09:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 25.96 MB
+2013-08-09 14:09:23,241-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:23,401-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:23,401-0500 INFO ThrottleManager mem=25.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:23,741-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:23,901-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:23,902-0500 INFO ThrottleManager mem=25.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:24,242-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:24,402-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:24,402-0500 INFO ThrottleManager mem=25.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:24,402-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:09:24,742-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:24,742-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:09:24,902-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:24,902-0500 INFO ThrottleManager mem=26.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:25,242-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:25,403-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:25,403-0500 INFO ThrottleManager mem=26.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:25,743-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:25,903-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:25,903-0500 INFO ThrottleManager mem=26.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:26,243-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:26,403-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:26,403-0500 INFO ThrottleManager mem=26.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:26,735-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:09:26,743-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:26,904-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:26,904-0500 INFO ThrottleManager mem=26.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:27,059-0500 INFO Multiplexer No streams
+2013-08-09 14:09:27,243-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:27,404-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:27,404-0500 INFO ThrottleManager mem=26.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:27,743-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:27,904-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:27,904-0500 INFO ThrottleManager mem=26.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:28,244-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:28,405-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:28,405-0500 INFO ThrottleManager mem=26.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:28,744-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:28,905-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:28,905-0500 INFO ThrottleManager mem=26.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:29,244-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:29,405-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:29,406-0500 INFO ThrottleManager mem=26.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:29,745-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:29,906-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:29,906-0500 INFO ThrottleManager mem=26.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:30,245-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:30,406-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:30,406-0500 INFO ThrottleManager mem=26.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:30,745-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:30,906-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:30,907-0500 INFO ThrottleManager mem=26.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:31,245-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:31,407-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:31,407-0500 INFO ThrottleManager mem=26.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:31,746-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:31,907-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:31,907-0500 INFO ThrottleManager mem=26.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:32,246-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:32,407-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:32,408-0500 INFO ThrottleManager mem=26.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:32,746-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:32,908-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:32,908-0500 INFO ThrottleManager mem=26.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:32,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:09:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 26.22 MB
+2013-08-09 14:09:33,247-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:33,408-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:33,408-0500 INFO ThrottleManager mem=26.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:33,747-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:33,908-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:33,909-0500 INFO ThrottleManager mem=26.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:34,247-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:34,409-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:34,409-0500 INFO ThrottleManager mem=26.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:34,409-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:09:34,747-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:34,748-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:09:34,909-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:34,909-0500 INFO ThrottleManager mem=26.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:35,248-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:35,410-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:35,410-0500 INFO ThrottleManager mem=26.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:35,748-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:35,910-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:35,910-0500 INFO ThrottleManager mem=26.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:36,248-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:36,410-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:36,410-0500 INFO ThrottleManager mem=26.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:36,736-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:09:36,749-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:36,911-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:36,911-0500 INFO ThrottleManager mem=26.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:37,068-0500 INFO Multiplexer No streams
+2013-08-09 14:09:37,249-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:37,411-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:37,411-0500 INFO ThrottleManager mem=26.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:37,749-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:37,911-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:37,911-0500 INFO ThrottleManager mem=26.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:38,249-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:38,412-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:38,412-0500 INFO ThrottleManager mem=26.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:38,750-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:38,912-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:38,912-0500 INFO ThrottleManager mem=26.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:39,250-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:39,412-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:39,412-0500 INFO ThrottleManager mem=26.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:39,750-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:39,913-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:39,913-0500 INFO ThrottleManager mem=26.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:40,250-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:40,413-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:40,413-0500 INFO ThrottleManager mem=26.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:40,751-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:40,913-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:40,913-0500 INFO ThrottleManager mem=26.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:41,251-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:41,414-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:41,414-0500 INFO ThrottleManager mem=26.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:41,751-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:41,914-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:41,914-0500 INFO ThrottleManager mem=26.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:42,252-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:42,414-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:42,414-0500 INFO ThrottleManager mem=26.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:42,752-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:42,915-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:42,915-0500 INFO ThrottleManager mem=26.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:09:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 26.48 MB
+2013-08-09 14:09:43,252-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:43,415-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:43,415-0500 INFO ThrottleManager mem=26.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:43,752-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:43,915-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:43,915-0500 INFO ThrottleManager mem=26.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:44,253-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:44,416-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:44,416-0500 INFO ThrottleManager mem=26.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:44,416-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:09:44,753-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:44,753-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:09:44,916-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:44,916-0500 INFO ThrottleManager mem=26.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:45,253-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:45,416-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:45,416-0500 INFO ThrottleManager mem=26.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:45,753-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:45,917-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:45,917-0500 INFO ThrottleManager mem=26.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:46,254-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:46,417-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:46,417-0500 INFO ThrottleManager mem=26.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:46,736-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:09:46,754-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:46,917-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:46,917-0500 INFO ThrottleManager mem=26.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:47,077-0500 INFO Multiplexer No streams
+2013-08-09 14:09:47,254-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:47,418-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:47,418-0500 INFO ThrottleManager mem=26.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:47,754-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:47,918-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:47,918-0500 INFO ThrottleManager mem=26.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:48,255-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:48,418-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:48,418-0500 INFO ThrottleManager mem=26.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:48,755-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:48,919-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:48,919-0500 INFO ThrottleManager mem=26.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:49,255-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:49,419-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:49,419-0500 INFO ThrottleManager mem=26.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:49,755-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:49,919-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:49,919-0500 INFO ThrottleManager mem=26.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:50,256-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:50,419-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:50,419-0500 INFO ThrottleManager mem=26.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:50,756-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:50,920-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:50,920-0500 INFO ThrottleManager mem=26.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:51,256-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:51,420-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:51,420-0500 INFO ThrottleManager mem=26.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:51,756-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:51,920-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:51,920-0500 INFO ThrottleManager mem=26.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:52,257-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:52,421-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:52,421-0500 INFO ThrottleManager mem=26.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:52,757-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:52,921-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:52,921-0500 INFO ThrottleManager mem=26.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:09:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 26.73 MB
+2013-08-09 14:09:53,257-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:53,421-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:53,421-0500 INFO ThrottleManager mem=26.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:53,758-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:53,922-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:53,922-0500 INFO ThrottleManager mem=26.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:54,258-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:54,422-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:54,422-0500 INFO ThrottleManager mem=26.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:54,422-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:09:54,758-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:54,758-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:09:54,922-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:54,922-0500 INFO ThrottleManager mem=26.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:55,259-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:55,422-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:55,423-0500 INFO ThrottleManager mem=26.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:55,759-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:55,923-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:55,923-0500 INFO ThrottleManager mem=26.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:56,259-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:56,423-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:56,423-0500 INFO ThrottleManager mem=26.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:56,736-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:09:56,759-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:56,923-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:56,924-0500 INFO ThrottleManager mem=26.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:57,086-0500 INFO Multiplexer No streams
+2013-08-09 14:09:57,260-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:57,424-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:57,424-0500 INFO ThrottleManager mem=26.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:57,760-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:57,924-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:57,924-0500 INFO ThrottleManager mem=26.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:58,260-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:58,424-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:58,425-0500 INFO ThrottleManager mem=26.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:58,760-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:58,925-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:58,925-0500 INFO ThrottleManager mem=26.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:59,261-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:59,425-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:59,425-0500 INFO ThrottleManager mem=26.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:09:59,761-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:59,925-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:09:59,925-0500 INFO ThrottleManager mem=26.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:00,261-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:00,426-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:00,426-0500 INFO ThrottleManager mem=26.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:00,761-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:00,926-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:00,926-0500 INFO ThrottleManager mem=26.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:01,262-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:01,426-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:01,426-0500 INFO ThrottleManager mem=26.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:01,762-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:01,927-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:01,927-0500 INFO ThrottleManager mem=26.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:02,262-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:02,427-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:02,427-0500 INFO ThrottleManager mem=26.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:02,762-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:02,927-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:02,927-0500 INFO ThrottleManager mem=26.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:10:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 26.99 MB
+2013-08-09 14:10:03,263-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:03,428-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:03,428-0500 INFO ThrottleManager mem=27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:03,763-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:03,928-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:03,928-0500 INFO ThrottleManager mem=27.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:04,263-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:04,428-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:04,428-0500 INFO ThrottleManager mem=27.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:04,428-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:10:04,763-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:04,764-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:10:04,928-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:04,929-0500 INFO ThrottleManager mem=27.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:05,264-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:05,429-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:05,429-0500 INFO ThrottleManager mem=27.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:05,764-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:05,929-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:05,929-0500 INFO ThrottleManager mem=27.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:06,264-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:06,429-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:06,430-0500 INFO ThrottleManager mem=27.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:06,737-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:10:06,765-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:06,930-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:06,930-0500 INFO ThrottleManager mem=27.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:07,093-0500 INFO Multiplexer No streams
+2013-08-09 14:10:07,265-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:07,430-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:07,430-0500 INFO ThrottleManager mem=27.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:07,765-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:07,930-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:07,930-0500 INFO ThrottleManager mem=27.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:08,265-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:08,431-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:08,431-0500 INFO ThrottleManager mem=27.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:08,766-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:08,931-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:08,931-0500 INFO ThrottleManager mem=27.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:09,266-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:09,431-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:09,431-0500 INFO ThrottleManager mem=27.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:09,766-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:09,932-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:09,932-0500 INFO ThrottleManager mem=27.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:10,266-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:10,432-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:10,432-0500 INFO ThrottleManager mem=27.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:10,767-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:10,932-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:10,932-0500 INFO ThrottleManager mem=27.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:11,267-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:11,433-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:11,433-0500 INFO ThrottleManager mem=27.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:11,767-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:11,933-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:11,933-0500 INFO ThrottleManager mem=27.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:12,268-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:12,433-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:12,433-0500 INFO ThrottleManager mem=27.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:12,768-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:12,933-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:12,933-0500 INFO ThrottleManager mem=27.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:10:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 27.25 MB
+2013-08-09 14:10:13,268-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:13,434-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:13,434-0500 INFO ThrottleManager mem=27.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:13,768-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:13,934-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:13,934-0500 INFO ThrottleManager mem=27.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:14,269-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:14,434-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:14,434-0500 INFO ThrottleManager mem=27.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:14,434-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:10:14,769-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:14,769-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:10:14,935-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:14,935-0500 INFO ThrottleManager mem=27.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:15,269-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:15,435-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:15,435-0500 INFO ThrottleManager mem=27.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:15,769-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:15,935-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:15,935-0500 INFO ThrottleManager mem=27.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:16,270-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:16,436-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:16,436-0500 INFO ThrottleManager mem=27.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:16,737-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:10:16,770-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:16,936-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:16,936-0500 INFO ThrottleManager mem=27.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:17,103-0500 INFO Multiplexer No streams
+2013-08-09 14:10:17,270-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:17,436-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:17,436-0500 INFO ThrottleManager mem=27.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:17,770-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:17,937-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:17,937-0500 INFO ThrottleManager mem=27.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:18,271-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:18,437-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:18,437-0500 INFO ThrottleManager mem=27.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:18,771-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:18,937-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:18,937-0500 INFO ThrottleManager mem=27.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:19,271-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:19,437-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:19,438-0500 INFO ThrottleManager mem=27.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:19,771-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:19,938-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:19,938-0500 INFO ThrottleManager mem=27.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:20,272-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:20,438-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:20,438-0500 INFO ThrottleManager mem=27.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:20,772-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:20,938-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:20,939-0500 INFO ThrottleManager mem=27.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:21,272-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:21,439-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:21,439-0500 INFO ThrottleManager mem=27.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:21,772-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:21,939-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:21,939-0500 INFO ThrottleManager mem=27.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:22,273-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:22,439-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:22,439-0500 INFO ThrottleManager mem=27.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:22,773-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:22,940-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:22,940-0500 INFO ThrottleManager mem=27.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:10:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 27.51 MB
+2013-08-09 14:10:23,273-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:23,440-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:23,440-0500 INFO ThrottleManager mem=27.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:23,774-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:23,940-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:23,940-0500 INFO ThrottleManager mem=27.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:24,274-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:24,441-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:24,441-0500 INFO ThrottleManager mem=27.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:24,441-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:10:24,774-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:24,774-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:10:24,941-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:24,941-0500 INFO ThrottleManager mem=27.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:25,274-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:25,441-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:25,441-0500 INFO ThrottleManager mem=27.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:25,775-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:25,941-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:25,942-0500 INFO ThrottleManager mem=27.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:26,275-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:26,442-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:26,442-0500 INFO ThrottleManager mem=27.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:26,737-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:10:26,775-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:26,942-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:26,942-0500 INFO ThrottleManager mem=27.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:27,110-0500 INFO Multiplexer No streams
+2013-08-09 14:10:27,275-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:27,442-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:27,443-0500 INFO ThrottleManager mem=27.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:27,776-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:27,943-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:27,943-0500 INFO ThrottleManager mem=27.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:28,276-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:28,443-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:28,443-0500 INFO ThrottleManager mem=27.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:28,776-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:28,943-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:28,943-0500 INFO ThrottleManager mem=27.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:29,276-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:29,444-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:29,444-0500 INFO ThrottleManager mem=27.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:29,777-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:29,944-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:29,944-0500 INFO ThrottleManager mem=27.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:30,277-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:30,444-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:30,444-0500 INFO ThrottleManager mem=27.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:30,777-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:30,945-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:30,945-0500 INFO ThrottleManager mem=27.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:31,277-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:31,445-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:31,445-0500 INFO ThrottleManager mem=27.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:31,778-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:31,945-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:31,945-0500 INFO ThrottleManager mem=27.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:32,278-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:32,446-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:32,446-0500 INFO ThrottleManager mem=27.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:32,778-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:32,946-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:32,946-0500 INFO ThrottleManager mem=27.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:10:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 27.77 MB
+2013-08-09 14:10:33,278-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:33,446-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:33,446-0500 INFO ThrottleManager mem=27.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:33,779-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:33,946-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:33,947-0500 INFO ThrottleManager mem=27.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:34,279-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:34,447-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:34,447-0500 INFO ThrottleManager mem=27.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:34,447-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:10:34,779-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:34,780-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:10:34,947-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:34,947-0500 INFO ThrottleManager mem=27.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:35,280-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:35,447-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:35,448-0500 INFO ThrottleManager mem=27.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:35,780-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:35,948-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:35,948-0500 INFO ThrottleManager mem=27.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:36,280-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:36,448-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:36,448-0500 INFO ThrottleManager mem=27.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:36,737-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:10:36,781-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:36,948-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:36,948-0500 INFO ThrottleManager mem=27.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:37,118-0500 INFO Multiplexer No streams
+2013-08-09 14:10:37,281-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:37,449-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:37,449-0500 INFO ThrottleManager mem=27.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:37,781-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:37,949-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:37,949-0500 INFO ThrottleManager mem=27.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:38,281-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:38,449-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:38,449-0500 INFO ThrottleManager mem=27.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:38,782-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:38,950-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:38,950-0500 INFO ThrottleManager mem=27.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:39,282-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:39,450-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:39,450-0500 INFO ThrottleManager mem=27.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:39,782-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:39,950-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:39,950-0500 INFO ThrottleManager mem=27.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:40,282-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:40,450-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:40,451-0500 INFO ThrottleManager mem=27.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:40,783-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:40,951-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:40,951-0500 INFO ThrottleManager mem=27.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:41,283-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:41,451-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:41,451-0500 INFO ThrottleManager mem=27.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:41,783-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:41,951-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:41,952-0500 INFO ThrottleManager mem=28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:42,284-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:42,452-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:42,452-0500 INFO ThrottleManager mem=28.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:42,784-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:42,952-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:42,952-0500 INFO ThrottleManager mem=28.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:10:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 28.03 MB
+2013-08-09 14:10:43,284-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:43,452-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:43,452-0500 INFO ThrottleManager mem=28.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:43,784-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:43,953-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:43,953-0500 INFO ThrottleManager mem=28.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:44,285-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:44,453-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:44,453-0500 INFO ThrottleManager mem=28.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:44,453-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:10:44,785-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:44,785-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:10:44,953-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:44,953-0500 INFO ThrottleManager mem=28.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:45,285-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:45,454-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:45,454-0500 INFO ThrottleManager mem=28.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:45,785-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:45,954-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:45,954-0500 INFO ThrottleManager mem=28.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:46,286-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:46,454-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:46,454-0500 INFO ThrottleManager mem=28.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:46,738-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:10:46,786-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:46,955-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:46,955-0500 INFO ThrottleManager mem=28.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:47,127-0500 INFO Multiplexer No streams
+2013-08-09 14:10:47,286-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:47,455-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:47,455-0500 INFO ThrottleManager mem=28.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:47,786-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:47,955-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:47,955-0500 INFO ThrottleManager mem=28.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:48,287-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:48,455-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:48,456-0500 INFO ThrottleManager mem=28.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:48,787-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:48,956-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:48,956-0500 INFO ThrottleManager mem=28.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:49,287-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:49,456-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:49,456-0500 INFO ThrottleManager mem=28.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:49,787-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:49,956-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:49,957-0500 INFO ThrottleManager mem=28.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:50,288-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:50,457-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:50,457-0500 INFO ThrottleManager mem=28.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:50,788-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:50,957-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:50,957-0500 INFO ThrottleManager mem=28.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:51,288-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:51,457-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:51,457-0500 INFO ThrottleManager mem=28.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:51,788-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:51,958-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:51,958-0500 INFO ThrottleManager mem=28.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:52,289-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:52,458-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:52,458-0500 INFO ThrottleManager mem=28.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:52,789-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:52,958-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:52,958-0500 INFO ThrottleManager mem=28.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:10:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 28.29 MB
+2013-08-09 14:10:53,289-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:53,459-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:53,459-0500 INFO ThrottleManager mem=28.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:53,790-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:53,959-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:53,959-0500 INFO ThrottleManager mem=28.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:54,290-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:54,459-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:54,459-0500 INFO ThrottleManager mem=28.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:54,459-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:10:54,790-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:54,790-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:10:54,960-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:54,960-0500 INFO ThrottleManager mem=28.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:55,290-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:55,460-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:55,460-0500 INFO ThrottleManager mem=28.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:55,791-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:55,960-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:55,960-0500 INFO ThrottleManager mem=28.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:56,291-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:56,460-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:56,461-0500 INFO ThrottleManager mem=28.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:56,738-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:10:56,791-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:56,961-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:56,961-0500 INFO ThrottleManager mem=28.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:57,135-0500 INFO Multiplexer No streams
+2013-08-09 14:10:57,291-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:57,461-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:57,461-0500 INFO ThrottleManager mem=28.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:57,792-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:57,961-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:57,962-0500 INFO ThrottleManager mem=28.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:58,292-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:58,462-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:58,462-0500 INFO ThrottleManager mem=28.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:58,792-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:58,962-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:58,962-0500 INFO ThrottleManager mem=28.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:59,292-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:59,462-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:59,462-0500 INFO ThrottleManager mem=28.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:10:59,793-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:59,963-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:10:59,963-0500 INFO ThrottleManager mem=28.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:00,293-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:00,463-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:00,463-0500 INFO ThrottleManager mem=28.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:00,793-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:00,963-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:00,963-0500 INFO ThrottleManager mem=28.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:01,293-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:01,464-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:01,464-0500 INFO ThrottleManager mem=28.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:01,794-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:01,964-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:01,964-0500 INFO ThrottleManager mem=28.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:02,294-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:02,464-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:02,464-0500 INFO ThrottleManager mem=28.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:02,794-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:11:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 28.54 MB
+2013-08-09 14:11:02,965-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:02,965-0500 INFO ThrottleManager mem=28.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:03,295-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:03,465-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:03,465-0500 INFO ThrottleManager mem=28.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:03,795-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:03,965-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:03,965-0500 INFO ThrottleManager mem=28.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:04,295-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:04,465-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:04,466-0500 INFO ThrottleManager mem=28.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:04,466-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:11:04,795-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:04,796-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:11:04,966-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:04,966-0500 INFO ThrottleManager mem=28.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:05,296-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:05,466-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:05,466-0500 INFO ThrottleManager mem=28.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:05,796-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:05,966-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:05,967-0500 INFO ThrottleManager mem=28.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:06,296-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:06,467-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:06,467-0500 INFO ThrottleManager mem=28.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:06,738-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:11:06,797-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:06,967-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:06,967-0500 INFO ThrottleManager mem=28.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:07,144-0500 INFO Multiplexer No streams
+2013-08-09 14:11:07,297-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:07,467-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:07,468-0500 INFO ThrottleManager mem=28.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:07,797-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:07,968-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:07,968-0500 INFO ThrottleManager mem=28.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:08,297-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:08,468-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:08,468-0500 INFO ThrottleManager mem=28.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:08,798-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:08,968-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:08,968-0500 INFO ThrottleManager mem=28.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:09,298-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:09,469-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:09,469-0500 INFO ThrottleManager mem=28.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:09,798-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:09,969-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:09,969-0500 INFO ThrottleManager mem=28.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:10,298-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:10,469-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:10,469-0500 INFO ThrottleManager mem=28.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:10,799-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:10,969-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:10,970-0500 INFO ThrottleManager mem=28.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:11,299-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:11,470-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:11,470-0500 INFO ThrottleManager mem=28.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:11,799-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:11,970-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:11,970-0500 INFO ThrottleManager mem=28.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:12,300-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:12,470-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:12,470-0500 INFO ThrottleManager mem=28.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:12,800-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:11:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 28.8 MB
+2013-08-09 14:11:12,971-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:12,971-0500 INFO ThrottleManager mem=28.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:13,300-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:13,471-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:13,471-0500 INFO ThrottleManager mem=28.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:13,800-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:13,971-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:13,971-0500 INFO ThrottleManager mem=28.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:14,301-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:14,472-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:14,472-0500 INFO ThrottleManager mem=28.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:14,472-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:11:14,801-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:14,801-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:11:14,972-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:14,972-0500 INFO ThrottleManager mem=28.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:15,301-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:15,472-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:15,472-0500 INFO ThrottleManager mem=28.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:15,801-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:15,972-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:15,973-0500 INFO ThrottleManager mem=28.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:16,302-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:16,473-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:16,473-0500 INFO ThrottleManager mem=28.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:16,738-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:11:16,802-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:16,973-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:16,973-0500 INFO ThrottleManager mem=28.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:17,152-0500 INFO Multiplexer No streams
+2013-08-09 14:11:17,302-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:17,473-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:17,474-0500 INFO ThrottleManager mem=28.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:17,802-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:17,974-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:17,974-0500 INFO ThrottleManager mem=28.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:18,303-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:18,474-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:18,474-0500 INFO ThrottleManager mem=28.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:18,803-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:18,974-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:18,974-0500 INFO ThrottleManager mem=28.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:19,303-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:19,475-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:19,475-0500 INFO ThrottleManager mem=28.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:19,803-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:19,975-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:19,975-0500 INFO ThrottleManager mem=28.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:20,304-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:20,475-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:20,475-0500 INFO ThrottleManager mem=29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:20,804-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:20,976-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:20,976-0500 INFO ThrottleManager mem=29.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:21,304-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:21,476-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:21,476-0500 INFO ThrottleManager mem=29.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:21,804-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:21,976-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:21,976-0500 INFO ThrottleManager mem=29.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:22,305-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:22,476-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:22,476-0500 INFO ThrottleManager mem=29.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:22,805-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:11:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 29.06 MB
+2013-08-09 14:11:22,977-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:22,977-0500 INFO ThrottleManager mem=29.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:23,305-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:23,477-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:23,477-0500 INFO ThrottleManager mem=29.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:23,806-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:23,977-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:23,977-0500 INFO ThrottleManager mem=29.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:24,306-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:24,478-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:24,478-0500 INFO ThrottleManager mem=29.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:24,478-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:11:24,806-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:24,806-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:11:24,978-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:24,978-0500 INFO ThrottleManager mem=29.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:25,307-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:25,478-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:25,478-0500 INFO ThrottleManager mem=29.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:25,807-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:25,979-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:25,979-0500 INFO ThrottleManager mem=29.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:26,307-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:26,479-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:26,479-0500 INFO ThrottleManager mem=29.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:26,739-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:11:26,807-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:26,979-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:26,979-0500 INFO ThrottleManager mem=29.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:27,160-0500 INFO Multiplexer No streams
+2013-08-09 14:11:27,308-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:27,479-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:27,480-0500 INFO ThrottleManager mem=29.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:27,808-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:27,980-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:27,980-0500 INFO ThrottleManager mem=29.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:28,308-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:28,480-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:28,480-0500 INFO ThrottleManager mem=29.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:28,808-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:28,980-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:28,980-0500 INFO ThrottleManager mem=29.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:29,309-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:29,480-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:29,481-0500 INFO ThrottleManager mem=29.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:29,809-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:29,981-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:29,981-0500 INFO ThrottleManager mem=29.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:30,309-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:30,481-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:30,481-0500 INFO ThrottleManager mem=29.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:30,809-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:30,981-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:30,981-0500 INFO ThrottleManager mem=29.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:31,310-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:31,482-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:31,482-0500 INFO ThrottleManager mem=29.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:31,810-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:31,982-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:31,982-0500 INFO ThrottleManager mem=29.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:32,310-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:32,482-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:32,482-0500 INFO ThrottleManager mem=29.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:32,810-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:11:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 29.32 MB
+2013-08-09 14:11:32,982-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:32,983-0500 INFO ThrottleManager mem=29.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:33,311-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:33,483-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:33,483-0500 INFO ThrottleManager mem=29.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:33,811-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:33,983-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:33,983-0500 INFO ThrottleManager mem=29.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:34,311-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:34,483-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:34,484-0500 INFO ThrottleManager mem=29.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:34,484-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:11:34,811-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:34,812-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:11:34,984-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:34,984-0500 INFO ThrottleManager mem=29.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:35,312-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:35,484-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:35,484-0500 INFO ThrottleManager mem=29.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:35,812-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:35,984-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:35,984-0500 INFO ThrottleManager mem=29.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:36,312-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:36,485-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:36,485-0500 INFO ThrottleManager mem=29.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:36,739-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:11:36,813-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:36,985-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:36,985-0500 INFO ThrottleManager mem=29.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:37,169-0500 INFO Multiplexer No streams
+2013-08-09 14:11:37,313-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:37,485-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:37,485-0500 INFO ThrottleManager mem=29.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:37,813-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:37,985-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:37,986-0500 INFO ThrottleManager mem=29.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:38,313-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:38,486-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:38,486-0500 INFO ThrottleManager mem=29.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:38,814-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:38,986-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:38,986-0500 INFO ThrottleManager mem=29.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:39,314-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:39,486-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:39,486-0500 INFO ThrottleManager mem=29.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:39,814-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:39,987-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:39,987-0500 INFO ThrottleManager mem=29.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:40,314-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:40,487-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:40,487-0500 INFO ThrottleManager mem=29.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:40,815-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:40,987-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:40,987-0500 INFO ThrottleManager mem=29.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:41,315-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:41,488-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:41,488-0500 INFO ThrottleManager mem=29.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:41,815-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:41,988-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:41,988-0500 INFO ThrottleManager mem=29.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:42,315-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:42,488-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:42,488-0500 INFO ThrottleManager mem=29.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:42,816-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:11:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 29.58 MB
+2013-08-09 14:11:42,988-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:42,989-0500 INFO ThrottleManager mem=29.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:43,316-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:43,489-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:43,489-0500 INFO ThrottleManager mem=29.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:43,816-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:43,989-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:43,989-0500 INFO ThrottleManager mem=29.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:44,316-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:44,489-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:44,489-0500 INFO ThrottleManager mem=29.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:44,489-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:11:44,817-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:44,817-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:11:44,990-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:44,990-0500 INFO ThrottleManager mem=29.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:45,317-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:45,490-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:45,490-0500 INFO ThrottleManager mem=29.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:45,817-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:45,990-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:45,990-0500 INFO ThrottleManager mem=29.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:46,317-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:46,490-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:46,490-0500 INFO ThrottleManager mem=29.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:46,739-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:11:46,818-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:46,991-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:46,991-0500 INFO ThrottleManager mem=29.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:47,177-0500 INFO Multiplexer No streams
+2013-08-09 14:11:47,318-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:47,491-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:47,491-0500 INFO ThrottleManager mem=29.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:47,818-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:47,991-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:47,991-0500 INFO ThrottleManager mem=29.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:48,318-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:48,491-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:48,492-0500 INFO ThrottleManager mem=29.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:48,819-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:48,992-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:48,992-0500 INFO ThrottleManager mem=29.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:49,319-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:49,492-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:49,492-0500 INFO ThrottleManager mem=29.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:49,819-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:49,992-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:49,993-0500 INFO ThrottleManager mem=29.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:50,319-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:50,493-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:50,493-0500 INFO ThrottleManager mem=29.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:50,820-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:50,993-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:50,993-0500 INFO ThrottleManager mem=29.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:51,320-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:51,493-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:51,493-0500 INFO ThrottleManager mem=29.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:51,820-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:51,993-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:51,994-0500 INFO ThrottleManager mem=29.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:52,320-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:52,494-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:52,494-0500 INFO ThrottleManager mem=29.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:52,821-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:11:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 29.84 MB
+2013-08-09 14:11:52,994-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:52,994-0500 INFO ThrottleManager mem=29.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:53,321-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:53,494-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:53,494-0500 INFO ThrottleManager mem=29.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:53,821-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:53,994-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:53,995-0500 INFO ThrottleManager mem=29.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:54,322-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:54,495-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:54,495-0500 INFO ThrottleManager mem=29.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:54,495-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:11:54,822-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:54,822-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:11:54,995-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:54,995-0500 INFO ThrottleManager mem=29.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:55,322-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:55,495-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:55,495-0500 INFO ThrottleManager mem=29.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:55,822-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:55,996-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:55,996-0500 INFO ThrottleManager mem=29.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:56,323-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:56,496-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:56,496-0500 INFO ThrottleManager mem=29.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:56,739-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:11:56,823-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:56,996-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:56,996-0500 INFO ThrottleManager mem=29.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:57,182-0500 INFO Multiplexer No streams
+2013-08-09 14:11:57,323-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:57,497-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:57,497-0500 INFO ThrottleManager mem=29.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:57,823-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:57,997-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:57,997-0500 INFO ThrottleManager mem=29.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:58,324-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:58,497-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:58,497-0500 INFO ThrottleManager mem=29.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:58,824-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:58,997-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:58,998-0500 INFO ThrottleManager mem=29.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:59,324-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:59,498-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:59,498-0500 INFO ThrottleManager mem=30 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:11:59,824-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:59,998-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:11:59,998-0500 INFO ThrottleManager mem=30.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:00,325-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:00,498-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:00,499-0500 INFO ThrottleManager mem=30.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:00,825-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:00,999-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:00,999-0500 INFO ThrottleManager mem=30.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:01,325-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:01,499-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:01,499-0500 INFO ThrottleManager mem=30.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:01,825-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:01,999-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:01,999-0500 INFO ThrottleManager mem=30.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:02,326-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:02,500-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:02,500-0500 INFO ThrottleManager mem=30.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:02,826-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:12:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 30.09 MB
+2013-08-09 14:12:03,000-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:03,000-0500 INFO ThrottleManager mem=30.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:03,326-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:03,500-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:03,500-0500 INFO ThrottleManager mem=30.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:03,826-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:04,000-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:04,001-0500 INFO ThrottleManager mem=30.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:04,327-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:04,501-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:04,501-0500 INFO ThrottleManager mem=30.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:04,501-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:12:04,827-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:04,827-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:12:05,001-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:05,001-0500 INFO ThrottleManager mem=30.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:05,327-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:05,501-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:05,501-0500 INFO ThrottleManager mem=30.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:05,828-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:06,002-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:06,002-0500 INFO ThrottleManager mem=30.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:06,328-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:06,502-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:06,502-0500 INFO ThrottleManager mem=30.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:06,740-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:12:06,828-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:07,002-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:07,002-0500 INFO ThrottleManager mem=30.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:07,188-0500 INFO Multiplexer No streams
+2013-08-09 14:12:07,328-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:07,503-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:07,503-0500 INFO ThrottleManager mem=30.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:07,829-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:08,003-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:08,003-0500 INFO ThrottleManager mem=30.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:08,329-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:08,503-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:08,503-0500 INFO ThrottleManager mem=30.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:08,829-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:09,003-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:09,004-0500 INFO ThrottleManager mem=30.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:09,329-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:09,504-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:09,504-0500 INFO ThrottleManager mem=30.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:09,830-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:10,004-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:10,004-0500 INFO ThrottleManager mem=30.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:10,330-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:10,504-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:10,504-0500 INFO ThrottleManager mem=30.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:10,830-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:11,005-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:11,005-0500 INFO ThrottleManager mem=30.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:11,331-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:11,505-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:11,505-0500 INFO ThrottleManager mem=30.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:11,831-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:12,005-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:12,005-0500 INFO ThrottleManager mem=30.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:12,331-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:12,506-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:12,506-0500 INFO ThrottleManager mem=30.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:12,831-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:12:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 30.35 MB
+2013-08-09 14:12:13,006-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:13,006-0500 INFO ThrottleManager mem=30.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:13,332-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:13,506-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:13,506-0500 INFO ThrottleManager mem=30.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:13,832-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:14,007-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:14,007-0500 INFO ThrottleManager mem=30.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:14,332-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:14,507-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:14,507-0500 INFO ThrottleManager mem=30.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:14,507-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:12:14,833-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:14,833-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:12:15,007-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:15,007-0500 INFO ThrottleManager mem=30.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:15,333-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:15,507-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:15,508-0500 INFO ThrottleManager mem=30.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:15,833-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:16,008-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:16,008-0500 INFO ThrottleManager mem=30.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:16,333-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:16,508-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:16,508-0500 INFO ThrottleManager mem=30.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:16,740-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:12:16,834-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:17,008-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:17,008-0500 INFO ThrottleManager mem=30.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:17,195-0500 INFO Multiplexer No streams
+2013-08-09 14:12:17,334-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:17,509-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:17,509-0500 INFO ThrottleManager mem=30.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:17,834-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:18,009-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:18,009-0500 INFO ThrottleManager mem=30.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:18,334-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:18,509-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:18,509-0500 INFO ThrottleManager mem=30.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:18,835-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:19,009-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:19,010-0500 INFO ThrottleManager mem=30.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:19,335-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:19,510-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:19,510-0500 INFO ThrottleManager mem=30.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:19,835-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:20,010-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:20,010-0500 INFO ThrottleManager mem=30.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:20,335-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:20,510-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:20,510-0500 INFO ThrottleManager mem=30.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:20,836-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:21,011-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:21,011-0500 INFO ThrottleManager mem=30.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:21,336-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:21,511-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:21,511-0500 INFO ThrottleManager mem=30.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:21,836-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:22,011-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:22,011-0500 INFO ThrottleManager mem=30.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:22,336-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:22,512-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:22,512-0500 INFO ThrottleManager mem=30.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:22,837-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:12:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 30.61 MB
+2013-08-09 14:12:23,012-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:23,012-0500 INFO ThrottleManager mem=30.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:23,337-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:23,512-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:23,512-0500 INFO ThrottleManager mem=30.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:23,837-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:24,012-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:24,013-0500 INFO ThrottleManager mem=30.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:24,338-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:24,513-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:24,513-0500 INFO ThrottleManager mem=30.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:24,513-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:12:24,838-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:24,838-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:12:25,013-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:25,013-0500 INFO ThrottleManager mem=30.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:25,338-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:25,513-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:25,513-0500 INFO ThrottleManager mem=30.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:25,838-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:26,014-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:26,014-0500 INFO ThrottleManager mem=30.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:26,339-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:26,514-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:26,514-0500 INFO ThrottleManager mem=30.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:26,740-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:12:26,839-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:27,014-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:27,014-0500 INFO ThrottleManager mem=30.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:27,202-0500 INFO Multiplexer No streams
+2013-08-09 14:12:27,339-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:27,515-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:27,515-0500 INFO ThrottleManager mem=30.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:27,839-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:28,015-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:28,015-0500 INFO ThrottleManager mem=30.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:28,340-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:28,515-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:28,515-0500 INFO ThrottleManager mem=30.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:28,840-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:29,015-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:29,016-0500 INFO ThrottleManager mem=30.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:29,340-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:29,516-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:29,516-0500 INFO ThrottleManager mem=30.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:29,840-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:30,016-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:30,016-0500 INFO ThrottleManager mem=30.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:30,341-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:30,516-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:30,516-0500 INFO ThrottleManager mem=30.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:30,841-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:31,017-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:31,017-0500 INFO ThrottleManager mem=30.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:31,341-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:31,517-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:31,517-0500 INFO ThrottleManager mem=30.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:31,841-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:32,017-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:32,017-0500 INFO ThrottleManager mem=30.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:32,342-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:32,518-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:32,518-0500 INFO ThrottleManager mem=30.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:32,842-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:12:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 30.87 MB
+2013-08-09 14:12:33,018-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:33,018-0500 INFO ThrottleManager mem=30.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:33,342-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:33,518-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:33,518-0500 INFO ThrottleManager mem=30.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:33,843-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:34,019-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:34,019-0500 INFO ThrottleManager mem=30.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:34,343-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:34,519-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:34,519-0500 INFO ThrottleManager mem=30.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:34,519-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:12:34,843-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:34,843-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:12:35,019-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:35,019-0500 INFO ThrottleManager mem=30.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:35,344-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:35,519-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:35,519-0500 INFO ThrottleManager mem=30.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:35,844-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:36,020-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:36,020-0500 INFO ThrottleManager mem=30.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:36,344-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:36,520-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:36,520-0500 INFO ThrottleManager mem=30.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:36,741-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:12:36,844-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:37,020-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:37,020-0500 INFO ThrottleManager mem=30.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:37,210-0500 INFO Multiplexer No streams
+2013-08-09 14:12:37,345-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:37,520-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:37,520-0500 INFO ThrottleManager mem=31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:37,845-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:38,021-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:38,021-0500 INFO ThrottleManager mem=31.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:38,345-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:38,521-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:38,521-0500 INFO ThrottleManager mem=31.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:38,845-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:39,021-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:39,021-0500 INFO ThrottleManager mem=31.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:39,346-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:39,522-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:39,522-0500 INFO ThrottleManager mem=31.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:39,846-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:40,022-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:40,022-0500 INFO ThrottleManager mem=31.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:40,346-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:40,522-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:40,522-0500 INFO ThrottleManager mem=31.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:40,846-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:41,022-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:41,022-0500 INFO ThrottleManager mem=31.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:41,347-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:41,523-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:41,523-0500 INFO ThrottleManager mem=31.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:41,847-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:42,023-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:42,023-0500 INFO ThrottleManager mem=31.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:42,347-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:42,523-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:42,523-0500 INFO ThrottleManager mem=31.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:42,848-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:12:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 31.13 MB
+2013-08-09 14:12:43,024-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:43,024-0500 INFO ThrottleManager mem=31.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:43,348-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:43,524-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:43,524-0500 INFO ThrottleManager mem=31.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:43,848-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:44,024-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:44,024-0500 INFO ThrottleManager mem=31.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:44,348-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:44,524-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:44,524-0500 INFO ThrottleManager mem=31.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:44,524-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:12:44,849-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:44,849-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:12:45,025-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:45,025-0500 INFO ThrottleManager mem=31.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:45,349-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:45,525-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:45,525-0500 INFO ThrottleManager mem=31.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:45,849-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:46,025-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:46,025-0500 INFO ThrottleManager mem=31.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:46,349-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:46,525-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:46,526-0500 INFO ThrottleManager mem=31.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:46,741-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:12:46,850-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:47,026-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:47,026-0500 INFO ThrottleManager mem=31.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:47,217-0500 INFO Multiplexer No streams
+2013-08-09 14:12:47,350-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:47,526-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:47,526-0500 INFO ThrottleManager mem=31.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:47,850-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:48,026-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:48,026-0500 INFO ThrottleManager mem=31.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:48,350-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:48,527-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:48,527-0500 INFO ThrottleManager mem=31.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:48,851-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:49,027-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:49,027-0500 INFO ThrottleManager mem=31.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:49,351-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:49,527-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:49,527-0500 INFO ThrottleManager mem=31.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:49,851-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:50,028-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:50,028-0500 INFO ThrottleManager mem=31.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:50,351-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:50,528-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:50,528-0500 INFO ThrottleManager mem=31.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:50,852-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:51,028-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:51,028-0500 INFO ThrottleManager mem=31.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:51,352-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:51,528-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:51,529-0500 INFO ThrottleManager mem=31.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:51,852-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:52,029-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:52,029-0500 INFO ThrottleManager mem=31.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:52,352-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:52,529-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:52,529-0500 INFO ThrottleManager mem=31.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:52,853-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:12:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 31.39 MB
+2013-08-09 14:12:53,029-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:53,030-0500 INFO ThrottleManager mem=31.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:53,353-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:53,530-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:53,530-0500 INFO ThrottleManager mem=31.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:53,853-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:54,030-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:54,030-0500 INFO ThrottleManager mem=31.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:54,354-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:54,530-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:54,530-0500 INFO ThrottleManager mem=31.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:54,530-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:12:54,854-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:54,854-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:12:55,031-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:55,031-0500 INFO ThrottleManager mem=31.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:55,354-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:55,531-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:55,531-0500 INFO ThrottleManager mem=31.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:55,854-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:56,031-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:56,031-0500 INFO ThrottleManager mem=31.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:56,355-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:56,532-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:56,532-0500 INFO ThrottleManager mem=31.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:56,741-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:12:56,855-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:57,032-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:57,032-0500 INFO ThrottleManager mem=31.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:57,224-0500 INFO Multiplexer No streams
+2013-08-09 14:12:57,355-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:57,532-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:57,532-0500 INFO ThrottleManager mem=31.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:57,855-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:58,032-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:58,033-0500 INFO ThrottleManager mem=31.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:58,356-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:58,533-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:58,533-0500 INFO ThrottleManager mem=31.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:58,856-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:59,033-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:59,033-0500 INFO ThrottleManager mem=31.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:59,356-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:59,533-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:12:59,534-0500 INFO ThrottleManager mem=31.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:12:59,856-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:00,034-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:00,034-0500 INFO ThrottleManager mem=31.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:00,357-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:00,534-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:00,534-0500 INFO ThrottleManager mem=31.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:00,857-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:01,034-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:01,034-0500 INFO ThrottleManager mem=31.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:01,357-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:01,535-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:01,535-0500 INFO ThrottleManager mem=31.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:01,857-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:02,035-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:02,035-0500 INFO ThrottleManager mem=31.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:02,358-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:02,535-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:02,535-0500 INFO ThrottleManager mem=31.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:02,858-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:13:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 31.65 MB
+2013-08-09 14:13:03,036-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:03,036-0500 INFO ThrottleManager mem=31.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:03,358-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:03,536-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:03,536-0500 INFO ThrottleManager mem=31.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:03,858-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:04,036-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:04,036-0500 INFO ThrottleManager mem=31.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:04,359-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:04,536-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:04,537-0500 INFO ThrottleManager mem=31.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:04,537-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:13:04,859-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:04,859-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:13:05,037-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:05,037-0500 INFO ThrottleManager mem=31.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:05,359-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:05,537-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:05,537-0500 INFO ThrottleManager mem=31.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:05,860-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:06,037-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:06,037-0500 INFO ThrottleManager mem=31.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:06,360-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:06,538-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:06,538-0500 INFO ThrottleManager mem=31.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:06,742-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:13:06,860-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:07,038-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:07,038-0500 INFO ThrottleManager mem=31.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:07,231-0500 INFO Multiplexer No streams
+2013-08-09 14:13:07,360-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:07,538-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:07,538-0500 INFO ThrottleManager mem=31.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:07,861-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:08,039-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:08,039-0500 INFO ThrottleManager mem=31.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:08,361-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:08,539-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:08,539-0500 INFO ThrottleManager mem=31.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:08,861-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:09,039-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:09,039-0500 INFO ThrottleManager mem=31.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:09,361-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:09,539-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:09,539-0500 INFO ThrottleManager mem=31.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:09,862-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:10,040-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:10,040-0500 INFO ThrottleManager mem=31.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:10,362-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:10,540-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:10,540-0500 INFO ThrottleManager mem=31.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:10,862-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:11,040-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:11,040-0500 INFO ThrottleManager mem=31.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:11,363-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:11,541-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:11,541-0500 INFO ThrottleManager mem=31.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:11,863-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:12,041-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:12,041-0500 INFO ThrottleManager mem=31.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:12,363-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:12,541-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:12,541-0500 INFO ThrottleManager mem=31.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:12,863-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:13:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 31.91 MB
+2013-08-09 14:13:13,041-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:13,042-0500 INFO ThrottleManager mem=31.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:13,364-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:13,542-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:13,542-0500 INFO ThrottleManager mem=31.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:13,864-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:14,042-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:14,042-0500 INFO ThrottleManager mem=31.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:14,364-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:14,542-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:14,542-0500 INFO ThrottleManager mem=31.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:14,543-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:13:14,864-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:14,864-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:13:15,043-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:15,043-0500 INFO ThrottleManager mem=31.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:15,365-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:15,543-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:15,543-0500 INFO ThrottleManager mem=31.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:15,865-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:16,043-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:16,043-0500 INFO ThrottleManager mem=31.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:16,365-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:16,544-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:16,544-0500 INFO ThrottleManager mem=32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:16,742-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:13:16,865-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:17,044-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:17,044-0500 INFO ThrottleManager mem=32.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:17,239-0500 INFO Multiplexer No streams
+2013-08-09 14:13:17,366-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:17,544-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:17,544-0500 INFO ThrottleManager mem=32.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:17,866-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:18,044-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:18,045-0500 INFO ThrottleManager mem=32.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:18,366-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:18,545-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:18,545-0500 INFO ThrottleManager mem=32.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:18,866-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:19,045-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:19,045-0500 INFO ThrottleManager mem=32.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:19,367-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:19,545-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:19,545-0500 INFO ThrottleManager mem=32.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:19,867-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:20,046-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:20,046-0500 INFO ThrottleManager mem=32.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:20,367-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:20,546-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:20,546-0500 INFO ThrottleManager mem=32.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:20,867-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:21,046-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:21,046-0500 INFO ThrottleManager mem=32.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:21,368-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:21,547-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:21,547-0500 INFO ThrottleManager mem=32.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:21,868-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:22,047-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:22,047-0500 INFO ThrottleManager mem=32.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:22,368-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:22,547-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:22,547-0500 INFO ThrottleManager mem=32.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:22,868-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:13:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 32.17 MB
+2013-08-09 14:13:23,047-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:23,048-0500 INFO ThrottleManager mem=32.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:23,369-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:23,548-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:23,548-0500 INFO ThrottleManager mem=32.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:23,869-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:24,048-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:24,048-0500 INFO ThrottleManager mem=32.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:24,369-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:24,548-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:24,548-0500 INFO ThrottleManager mem=32.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:24,549-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:13:24,869-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:24,870-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:13:25,049-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:25,049-0500 INFO ThrottleManager mem=32.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:25,370-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:25,549-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:25,549-0500 INFO ThrottleManager mem=32.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:25,870-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:26,049-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:26,049-0500 INFO ThrottleManager mem=32.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:26,370-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:26,550-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:26,550-0500 INFO ThrottleManager mem=32.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:26,742-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:13:26,871-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:27,050-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:27,050-0500 INFO ThrottleManager mem=32.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:27,246-0500 INFO Multiplexer No streams
+2013-08-09 14:13:27,371-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:27,550-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:27,550-0500 INFO ThrottleManager mem=32.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:27,871-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:28,050-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:28,050-0500 INFO ThrottleManager mem=32.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:28,371-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:28,551-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:28,551-0500 INFO ThrottleManager mem=32.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:28,871-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:29,051-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:29,051-0500 INFO ThrottleManager mem=32.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:29,372-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:29,551-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:29,551-0500 INFO ThrottleManager mem=32.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:29,872-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:30,051-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:30,052-0500 INFO ThrottleManager mem=32.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:30,372-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:30,552-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:30,552-0500 INFO ThrottleManager mem=32.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:30,872-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:31,052-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:31,052-0500 INFO ThrottleManager mem=32.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:31,373-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:31,552-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:31,552-0500 INFO ThrottleManager mem=32.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:31,873-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:32,053-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:32,053-0500 INFO ThrottleManager mem=32.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:32,373-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:32,553-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:32,553-0500 INFO ThrottleManager mem=32.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:32,873-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:13:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 32.43 MB
+2013-08-09 14:13:33,053-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:33,053-0500 INFO ThrottleManager mem=32.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:33,374-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:33,554-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:33,554-0500 INFO ThrottleManager mem=32.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:33,874-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:34,054-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:34,054-0500 INFO ThrottleManager mem=32.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:34,374-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:34,554-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:34,554-0500 INFO ThrottleManager mem=32.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:34,554-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:13:34,874-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:34,875-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:13:35,054-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:35,055-0500 INFO ThrottleManager mem=32.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:35,375-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:35,555-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:35,555-0500 INFO ThrottleManager mem=32.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:35,875-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:36,055-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:36,055-0500 INFO ThrottleManager mem=32.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:36,375-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:36,555-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:36,556-0500 INFO ThrottleManager mem=32.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:36,742-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:13:36,876-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:37,056-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:37,056-0500 INFO ThrottleManager mem=32.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:37,253-0500 INFO Multiplexer No streams
+2013-08-09 14:13:37,376-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:37,556-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:37,556-0500 INFO ThrottleManager mem=32.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:37,876-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:38,056-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:38,056-0500 INFO ThrottleManager mem=32.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:38,376-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:38,557-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:38,557-0500 INFO ThrottleManager mem=32.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:38,877-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:39,057-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:39,057-0500 INFO ThrottleManager mem=32.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:39,377-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:39,557-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:39,557-0500 INFO ThrottleManager mem=32.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:39,877-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:40,058-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:40,058-0500 INFO ThrottleManager mem=32.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:40,377-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:40,558-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:40,558-0500 INFO ThrottleManager mem=32.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:40,878-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:41,058-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:41,058-0500 INFO ThrottleManager mem=32.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:41,378-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:41,558-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:41,559-0500 INFO ThrottleManager mem=32.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:41,878-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:42,059-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:42,059-0500 INFO ThrottleManager mem=32.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:42,379-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:42,559-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:42,559-0500 INFO ThrottleManager mem=32.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:42,879-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:13:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 32.69 MB
+2013-08-09 14:13:43,059-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:43,059-0500 INFO ThrottleManager mem=32.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:43,379-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:43,560-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:43,560-0500 INFO ThrottleManager mem=32.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:43,879-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:44,060-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:44,060-0500 INFO ThrottleManager mem=32.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:44,380-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:44,560-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:44,560-0500 INFO ThrottleManager mem=32.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:44,560-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:13:44,880-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:44,880-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:13:45,061-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:45,061-0500 INFO ThrottleManager mem=32.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:45,380-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:45,561-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:45,561-0500 INFO ThrottleManager mem=32.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:45,880-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:46,061-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:46,061-0500 INFO ThrottleManager mem=32.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:46,381-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:46,561-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:46,562-0500 INFO ThrottleManager mem=32.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:46,743-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:13:46,881-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:47,062-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:47,062-0500 INFO ThrottleManager mem=32.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:47,262-0500 INFO Multiplexer No streams
+2013-08-09 14:13:47,381-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:47,562-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:47,562-0500 INFO ThrottleManager mem=32.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:47,881-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:48,062-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:48,062-0500 INFO ThrottleManager mem=32.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:48,382-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:48,563-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:48,563-0500 INFO ThrottleManager mem=32.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:48,882-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:49,063-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:49,063-0500 INFO ThrottleManager mem=32.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:49,382-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:49,563-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:49,563-0500 INFO ThrottleManager mem=32.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:49,882-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:50,063-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:50,064-0500 INFO ThrottleManager mem=32.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:50,383-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:50,564-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:50,564-0500 INFO ThrottleManager mem=32.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:50,883-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:51,064-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:51,064-0500 INFO ThrottleManager mem=32.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:51,383-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:51,564-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:51,565-0500 INFO ThrottleManager mem=32.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:51,883-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:52,065-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:52,065-0500 INFO ThrottleManager mem=32.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:52,384-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:52,565-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:52,565-0500 INFO ThrottleManager mem=32.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:52,884-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:13:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 32.95 MB
+2013-08-09 14:13:53,065-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:53,065-0500 INFO ThrottleManager mem=32.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:53,384-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:53,565-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:53,566-0500 INFO ThrottleManager mem=32.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:53,885-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:54,066-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:54,066-0500 INFO ThrottleManager mem=32.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:54,385-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:54,566-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:54,566-0500 INFO ThrottleManager mem=32.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:54,566-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:13:54,885-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:54,885-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:13:55,066-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:55,067-0500 INFO ThrottleManager mem=33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:55,385-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:55,567-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:55,567-0500 INFO ThrottleManager mem=33.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:55,886-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:56,067-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:56,067-0500 INFO ThrottleManager mem=33.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:56,386-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:56,567-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:56,567-0500 INFO ThrottleManager mem=33.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:56,743-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:13:56,886-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:57,068-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:57,068-0500 INFO ThrottleManager mem=33.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:57,268-0500 INFO Multiplexer No streams
+2013-08-09 14:13:57,386-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:57,568-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:57,568-0500 INFO ThrottleManager mem=33.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:57,887-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:58,068-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:58,068-0500 INFO ThrottleManager mem=33.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:58,387-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:58,568-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:58,569-0500 INFO ThrottleManager mem=33.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:58,887-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:59,069-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:59,069-0500 INFO ThrottleManager mem=33.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:59,387-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:59,569-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:13:59,569-0500 INFO ThrottleManager mem=33.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:13:59,887-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:00,069-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:00,069-0500 INFO ThrottleManager mem=33.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:00,388-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:00,570-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:00,570-0500 INFO ThrottleManager mem=33.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:00,888-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:01,070-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:01,070-0500 INFO ThrottleManager mem=33.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:01,388-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:01,570-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:01,570-0500 INFO ThrottleManager mem=33.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:01,888-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:02,071-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:02,071-0500 INFO ThrottleManager mem=33.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:02,389-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:02,571-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:02,571-0500 INFO ThrottleManager mem=33.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:02,889-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:14:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 33.2 MB
+2013-08-09 14:14:03,071-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:03,071-0500 INFO ThrottleManager mem=33.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:03,389-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:03,571-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:03,572-0500 INFO ThrottleManager mem=33.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:03,890-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:04,072-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:04,072-0500 INFO ThrottleManager mem=33.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:04,390-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:04,572-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:04,572-0500 INFO ThrottleManager mem=33.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:04,572-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:14:04,890-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:04,890-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:14:05,072-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:05,073-0500 INFO ThrottleManager mem=33.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:05,391-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:05,573-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:05,573-0500 INFO ThrottleManager mem=33.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:05,891-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:06,073-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:06,073-0500 INFO ThrottleManager mem=33.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:06,391-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:06,573-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:06,573-0500 INFO ThrottleManager mem=33.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:06,743-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:14:06,891-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:07,074-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:07,074-0500 INFO ThrottleManager mem=33.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:07,274-0500 INFO Multiplexer No streams
+2013-08-09 14:14:07,392-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:07,574-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:07,574-0500 INFO ThrottleManager mem=33.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:07,892-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:08,074-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:08,074-0500 INFO ThrottleManager mem=33.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:08,392-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:08,574-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:08,575-0500 INFO ThrottleManager mem=33.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:08,892-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:09,075-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:09,075-0500 INFO ThrottleManager mem=33.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:09,393-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:09,575-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:09,575-0500 INFO ThrottleManager mem=33.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:09,893-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:10,075-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:10,076-0500 INFO ThrottleManager mem=33.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:10,393-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:10,576-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:10,576-0500 INFO ThrottleManager mem=33.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:10,894-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:11,076-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:11,076-0500 INFO ThrottleManager mem=33.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:11,394-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:11,576-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:11,576-0500 INFO ThrottleManager mem=33.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:11,894-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:12,077-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:12,077-0500 INFO ThrottleManager mem=33.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:12,395-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:12,577-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:12,577-0500 INFO ThrottleManager mem=33.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:12,895-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:14:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 33.46 MB
+2013-08-09 14:14:13,077-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:13,077-0500 INFO ThrottleManager mem=33.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:13,395-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:13,577-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:13,578-0500 INFO ThrottleManager mem=33.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:13,895-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:14,078-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:14,078-0500 INFO ThrottleManager mem=33.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:14,396-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:14,578-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:14,578-0500 INFO ThrottleManager mem=33.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:14,578-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:14:14,896-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:14,896-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:14:15,078-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:15,078-0500 INFO ThrottleManager mem=33.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:15,396-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:15,579-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:15,579-0500 INFO ThrottleManager mem=33.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:15,896-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:16,079-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:16,079-0500 INFO ThrottleManager mem=33.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:16,397-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:16,579-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:16,579-0500 INFO ThrottleManager mem=33.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:16,744-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:14:16,897-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:17,080-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:17,080-0500 INFO ThrottleManager mem=33.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:17,280-0500 INFO Multiplexer No streams
+2013-08-09 14:14:17,397-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:17,580-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:17,580-0500 INFO ThrottleManager mem=33.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:17,897-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:18,080-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:18,080-0500 INFO ThrottleManager mem=33.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:18,398-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:18,580-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:18,581-0500 INFO ThrottleManager mem=33.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:18,898-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:19,081-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:19,081-0500 INFO ThrottleManager mem=33.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:19,398-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:19,581-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:19,581-0500 INFO ThrottleManager mem=33.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:19,899-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:20,081-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:20,082-0500 INFO ThrottleManager mem=33.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:20,399-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:20,582-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:20,582-0500 INFO ThrottleManager mem=33.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:20,899-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:21,082-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:21,082-0500 INFO ThrottleManager mem=33.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:21,399-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:21,582-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:21,582-0500 INFO ThrottleManager mem=33.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:21,900-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:22,083-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:22,083-0500 INFO ThrottleManager mem=33.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:22,400-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:22,583-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:22,583-0500 INFO ThrottleManager mem=33.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:22,900-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:14:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 33.72 MB
+2013-08-09 14:14:23,083-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:23,083-0500 INFO ThrottleManager mem=33.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:23,401-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:23,583-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:23,584-0500 INFO ThrottleManager mem=33.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:23,901-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:24,084-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:24,084-0500 INFO ThrottleManager mem=33.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:24,401-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:24,584-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:24,584-0500 INFO ThrottleManager mem=33.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:24,584-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:14:24,901-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:24,901-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:14:25,084-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:25,084-0500 INFO ThrottleManager mem=33.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:25,402-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:25,585-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:25,585-0500 INFO ThrottleManager mem=33.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:25,902-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:26,085-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:26,085-0500 INFO ThrottleManager mem=33.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:26,402-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:26,585-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:26,585-0500 INFO ThrottleManager mem=33.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:26,744-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:14:26,902-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:27,086-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:27,086-0500 INFO ThrottleManager mem=33.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:27,285-0500 INFO Multiplexer No streams
+2013-08-09 14:14:27,403-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:27,586-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:27,586-0500 INFO ThrottleManager mem=33.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:27,903-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:28,086-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:28,086-0500 INFO ThrottleManager mem=33.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:28,403-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:28,587-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:28,587-0500 INFO ThrottleManager mem=33.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:28,904-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:29,087-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:29,087-0500 INFO ThrottleManager mem=33.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:29,404-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:29,587-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:29,587-0500 INFO ThrottleManager mem=33.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:29,904-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:30,087-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:30,088-0500 INFO ThrottleManager mem=33.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:30,404-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:30,588-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:30,588-0500 INFO ThrottleManager mem=33.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:30,905-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:31,088-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:31,088-0500 INFO ThrottleManager mem=33.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:31,405-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:31,588-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:31,588-0500 INFO ThrottleManager mem=33.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:31,905-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:32,089-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:32,089-0500 INFO ThrottleManager mem=33.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:32,406-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:32,589-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:32,589-0500 INFO ThrottleManager mem=33.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:32,906-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:14:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 33.98 MB
+2013-08-09 14:14:33,089-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:33,089-0500 INFO ThrottleManager mem=33.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:33,406-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:33,589-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:33,590-0500 INFO ThrottleManager mem=33.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:33,906-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:34,090-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:34,090-0500 INFO ThrottleManager mem=34.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:34,407-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:34,590-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:34,590-0500 INFO ThrottleManager mem=34.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:34,590-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:14:34,907-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:34,907-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:14:35,090-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:35,090-0500 INFO ThrottleManager mem=34.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:35,407-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:35,591-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:35,591-0500 INFO ThrottleManager mem=34.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:35,908-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:36,091-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:36,091-0500 INFO ThrottleManager mem=34.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:36,408-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:36,591-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:36,591-0500 INFO ThrottleManager mem=34.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:36,744-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:14:36,908-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:37,092-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:37,092-0500 INFO ThrottleManager mem=34.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:37,290-0500 INFO Multiplexer No streams
+2013-08-09 14:14:37,408-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:37,592-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:37,592-0500 INFO ThrottleManager mem=34.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:37,909-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:38,092-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:38,092-0500 INFO ThrottleManager mem=34.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:38,409-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:38,592-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:38,593-0500 INFO ThrottleManager mem=34.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:38,909-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:39,093-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:39,093-0500 INFO ThrottleManager mem=34.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:39,409-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:39,593-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:39,593-0500 INFO ThrottleManager mem=34.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:39,910-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:40,093-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:40,093-0500 INFO ThrottleManager mem=34.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:40,410-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:40,594-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:40,594-0500 INFO ThrottleManager mem=34.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:40,910-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:41,094-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:41,094-0500 INFO ThrottleManager mem=34.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:41,411-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:41,594-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:41,594-0500 INFO ThrottleManager mem=34.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:41,911-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:42,095-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:42,095-0500 INFO ThrottleManager mem=34.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:42,411-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:42,595-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:42,595-0500 INFO ThrottleManager mem=34.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:42,912-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:14:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 34.24 MB
+2013-08-09 14:14:43,095-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:43,095-0500 INFO ThrottleManager mem=34.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:43,412-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:43,596-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:43,596-0500 INFO ThrottleManager mem=34.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:43,912-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:44,096-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:44,096-0500 INFO ThrottleManager mem=34.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:44,412-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:44,596-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:44,596-0500 INFO ThrottleManager mem=34.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:44,596-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:14:44,913-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:44,913-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:14:45,097-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:45,097-0500 INFO ThrottleManager mem=34.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:45,413-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:45,597-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:45,597-0500 INFO ThrottleManager mem=34.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:45,913-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:46,097-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:46,097-0500 INFO ThrottleManager mem=34.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:46,413-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:46,598-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:46,598-0500 INFO ThrottleManager mem=34.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:46,744-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:14:46,914-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:47,098-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:47,098-0500 INFO ThrottleManager mem=34.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:47,297-0500 INFO Multiplexer No streams
+2013-08-09 14:14:47,414-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:47,598-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:47,598-0500 INFO ThrottleManager mem=34.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:47,914-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:48,099-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:48,099-0500 INFO ThrottleManager mem=34.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:48,414-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:48,599-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:48,599-0500 INFO ThrottleManager mem=34.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:48,915-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:49,099-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:49,100-0500 INFO ThrottleManager mem=34.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:49,415-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:49,600-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:49,600-0500 INFO ThrottleManager mem=34.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:49,915-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:50,100-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:50,100-0500 INFO ThrottleManager mem=34.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:50,416-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:50,600-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:50,600-0500 INFO ThrottleManager mem=34.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:50,916-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:51,101-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:51,101-0500 INFO ThrottleManager mem=34.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:51,416-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:51,601-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:51,601-0500 INFO ThrottleManager mem=34.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:51,916-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:52,101-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:52,102-0500 INFO ThrottleManager mem=34.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:52,417-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:52,602-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:52,602-0500 INFO ThrottleManager mem=34.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:52,917-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:14:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 34.5 MB
+2013-08-09 14:14:53,102-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:53,102-0500 INFO ThrottleManager mem=34.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:53,417-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:53,602-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:53,602-0500 INFO ThrottleManager mem=34.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:53,918-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:54,103-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:54,103-0500 INFO ThrottleManager mem=34.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:54,418-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:54,603-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:54,603-0500 INFO ThrottleManager mem=34.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:54,603-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:14:54,918-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:54,918-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:14:55,103-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:55,103-0500 INFO ThrottleManager mem=34.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:55,418-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:55,604-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:55,604-0500 INFO ThrottleManager mem=34.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:55,919-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:56,104-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:56,104-0500 INFO ThrottleManager mem=34.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:56,419-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:56,604-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:56,604-0500 INFO ThrottleManager mem=34.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:56,745-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:14:56,919-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:57,105-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:57,105-0500 INFO ThrottleManager mem=34.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:57,303-0500 INFO Multiplexer No streams
+2013-08-09 14:14:57,419-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:57,605-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:57,605-0500 INFO ThrottleManager mem=34.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:57,920-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:58,105-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:58,105-0500 INFO ThrottleManager mem=34.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:58,420-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:58,606-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:58,606-0500 INFO ThrottleManager mem=34.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:58,920-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:59,106-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:59,106-0500 INFO ThrottleManager mem=34.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:59,420-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:59,606-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:14:59,606-0500 INFO ThrottleManager mem=34.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:14:59,921-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:00,107-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:00,107-0500 INFO ThrottleManager mem=34.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:00,421-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:00,607-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:00,607-0500 INFO ThrottleManager mem=34.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:00,921-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:01,107-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:01,107-0500 INFO ThrottleManager mem=34.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:01,421-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:01,608-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:01,608-0500 INFO ThrottleManager mem=34.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:01,922-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:02,108-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:02,108-0500 INFO ThrottleManager mem=34.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:02,422-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:02,608-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:02,608-0500 INFO ThrottleManager mem=34.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:02,922-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:15:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 34.76 MB
+2013-08-09 14:15:03,109-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:03,109-0500 INFO ThrottleManager mem=34.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:03,422-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:03,609-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:03,609-0500 INFO ThrottleManager mem=34.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:03,923-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:04,109-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:04,109-0500 INFO ThrottleManager mem=34.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:04,423-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:04,610-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:04,610-0500 INFO ThrottleManager mem=34.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:04,610-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:15:04,923-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:04,923-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:15:05,110-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:05,110-0500 INFO ThrottleManager mem=34.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:05,424-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:05,610-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:05,611-0500 INFO ThrottleManager mem=34.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:05,924-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:06,111-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:06,111-0500 INFO ThrottleManager mem=34.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:06,424-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:06,611-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:06,611-0500 INFO ThrottleManager mem=34.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:06,745-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:15:06,924-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:07,111-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:07,111-0500 INFO ThrottleManager mem=34.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:07,308-0500 INFO Multiplexer No streams
+2013-08-09 14:15:07,425-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:07,612-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:07,612-0500 INFO ThrottleManager mem=34.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:07,925-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:08,112-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:08,112-0500 INFO ThrottleManager mem=34.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:08,425-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:08,612-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:08,612-0500 INFO ThrottleManager mem=34.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:08,925-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:09,112-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:09,113-0500 INFO ThrottleManager mem=34.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:09,426-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:09,613-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:09,613-0500 INFO ThrottleManager mem=34.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:09,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:10,113-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:10,113-0500 INFO ThrottleManager mem=34.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:10,426-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:10,613-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:10,614-0500 INFO ThrottleManager mem=34.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:10,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:11,114-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:11,114-0500 INFO ThrottleManager mem=34.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:11,427-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:11,614-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:11,614-0500 INFO ThrottleManager mem=34.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:11,927-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:12,114-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:12,114-0500 INFO ThrottleManager mem=34.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:12,427-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:12,615-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:12,615-0500 INFO ThrottleManager mem=35.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:12,927-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:15:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 35.02 MB
+2013-08-09 14:15:13,115-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:13,115-0500 INFO ThrottleManager mem=35.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:13,428-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:13,615-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:13,615-0500 INFO ThrottleManager mem=35.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:13,928-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:14,115-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:14,116-0500 INFO ThrottleManager mem=35.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:14,428-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:14,616-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:14,616-0500 INFO ThrottleManager mem=35.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:14,616-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:15:14,928-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:14,928-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:15:15,116-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:15,116-0500 INFO ThrottleManager mem=35.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:15,429-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:15,616-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:15,617-0500 INFO ThrottleManager mem=35.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:15,929-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:16,117-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:16,117-0500 INFO ThrottleManager mem=35.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:16,429-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:16,617-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:16,617-0500 INFO ThrottleManager mem=35.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:16,745-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:15:16,929-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:17,117-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:17,117-0500 INFO ThrottleManager mem=35.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:17,315-0500 INFO Multiplexer No streams
+2013-08-09 14:15:17,430-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:17,618-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:17,618-0500 INFO ThrottleManager mem=35.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:17,930-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:18,118-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:18,118-0500 INFO ThrottleManager mem=35.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:18,430-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:18,618-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:18,618-0500 INFO ThrottleManager mem=35.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:18,930-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:19,118-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:19,119-0500 INFO ThrottleManager mem=35.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:19,431-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:19,619-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:19,619-0500 INFO ThrottleManager mem=35.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:19,931-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:20,119-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:20,119-0500 INFO ThrottleManager mem=35.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:20,431-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:20,619-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:20,619-0500 INFO ThrottleManager mem=35.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:20,931-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:21,120-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:21,120-0500 INFO ThrottleManager mem=35.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:21,432-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:21,620-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:21,620-0500 INFO ThrottleManager mem=35.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:21,932-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:22,120-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:22,120-0500 INFO ThrottleManager mem=35.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:22,432-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:22,621-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:22,621-0500 INFO ThrottleManager mem=35.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:22,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:15:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 35.27 MB
+2013-08-09 14:15:23,121-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:23,121-0500 INFO ThrottleManager mem=35.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:23,433-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:23,621-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:23,622-0500 INFO ThrottleManager mem=35.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:23,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:24,122-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:24,122-0500 INFO ThrottleManager mem=35.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:24,433-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:24,622-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:24,622-0500 INFO ThrottleManager mem=35.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:24,622-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:15:24,934-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:24,934-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:15:25,122-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:25,122-0500 INFO ThrottleManager mem=35.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:25,434-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:25,623-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:25,623-0500 INFO ThrottleManager mem=35.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:25,934-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:26,123-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:26,123-0500 INFO ThrottleManager mem=35.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:26,434-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:26,623-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:26,623-0500 INFO ThrottleManager mem=35.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:26,745-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:15:26,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:27,124-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:27,124-0500 INFO ThrottleManager mem=35.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:27,320-0500 INFO Multiplexer No streams
+2013-08-09 14:15:27,435-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:27,624-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:27,624-0500 INFO ThrottleManager mem=35.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:27,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:28,124-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:28,124-0500 INFO ThrottleManager mem=35.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:28,435-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:28,624-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:28,625-0500 INFO ThrottleManager mem=35.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:28,936-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:29,125-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:29,125-0500 INFO ThrottleManager mem=35.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:29,436-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:29,625-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:29,625-0500 INFO ThrottleManager mem=35.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:29,936-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:30,125-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:30,125-0500 INFO ThrottleManager mem=35.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:30,436-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:30,626-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:30,626-0500 INFO ThrottleManager mem=35.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:30,937-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:31,126-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:31,126-0500 INFO ThrottleManager mem=35.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:31,437-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:31,626-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:31,627-0500 INFO ThrottleManager mem=35.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:31,937-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:32,127-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:32,127-0500 INFO ThrottleManager mem=35.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:32,438-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:32,627-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:32,627-0500 INFO ThrottleManager mem=35.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:32,938-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:15:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 35.53 MB
+2013-08-09 14:15:33,127-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:33,127-0500 INFO ThrottleManager mem=35.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:33,438-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:33,628-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:33,628-0500 INFO ThrottleManager mem=35.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:33,938-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:34,128-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:34,128-0500 INFO ThrottleManager mem=35.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:34,439-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:34,628-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:34,629-0500 INFO ThrottleManager mem=35.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:34,629-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:15:34,939-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:34,939-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:15:35,129-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:35,129-0500 INFO ThrottleManager mem=35.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:35,439-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:35,629-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:35,629-0500 INFO ThrottleManager mem=35.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:35,939-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:36,130-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:36,130-0500 INFO ThrottleManager mem=35.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:36,439-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:36,630-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:36,630-0500 INFO ThrottleManager mem=35.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:36,746-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:15:36,940-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:37,130-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:37,130-0500 INFO ThrottleManager mem=35.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:37,325-0500 INFO Multiplexer No streams
+2013-08-09 14:15:37,440-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:37,630-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:37,631-0500 INFO ThrottleManager mem=35.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:37,940-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:38,131-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:38,131-0500 INFO ThrottleManager mem=35.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:38,440-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:38,631-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:38,631-0500 INFO ThrottleManager mem=35.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:38,941-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:39,131-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:39,131-0500 INFO ThrottleManager mem=35.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:39,441-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:39,632-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:39,632-0500 INFO ThrottleManager mem=35.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:39,941-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:40,132-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:40,132-0500 INFO ThrottleManager mem=35.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:40,442-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:40,632-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:40,632-0500 INFO ThrottleManager mem=35.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:40,942-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:41,133-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:41,133-0500 INFO ThrottleManager mem=35.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:41,442-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:41,633-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:41,633-0500 INFO ThrottleManager mem=35.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:41,942-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:42,133-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:42,133-0500 INFO ThrottleManager mem=35.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:42,443-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:42,633-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:42,634-0500 INFO ThrottleManager mem=35.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:42,943-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:15:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 35.79 MB
+2013-08-09 14:15:43,134-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:43,134-0500 INFO ThrottleManager mem=35.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:43,443-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:43,634-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:43,634-0500 INFO ThrottleManager mem=35.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:43,943-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:44,134-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:44,134-0500 INFO ThrottleManager mem=35.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:44,444-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:44,635-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:44,635-0500 INFO ThrottleManager mem=35.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:44,635-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:15:44,944-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:44,944-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:15:45,135-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:45,135-0500 INFO ThrottleManager mem=35.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:45,444-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:45,635-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:45,635-0500 INFO ThrottleManager mem=35.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:45,944-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:46,136-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:46,136-0500 INFO ThrottleManager mem=35.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:46,445-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:46,636-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:46,636-0500 INFO ThrottleManager mem=35.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:46,746-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:15:46,945-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:47,136-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:47,136-0500 INFO ThrottleManager mem=35.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:47,332-0500 INFO Multiplexer No streams
+2013-08-09 14:15:47,445-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:47,636-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:47,637-0500 INFO ThrottleManager mem=35.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:47,945-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:48,137-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:48,137-0500 INFO ThrottleManager mem=35.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:48,446-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:48,637-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:48,637-0500 INFO ThrottleManager mem=35.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:48,946-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:49,137-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:49,137-0500 INFO ThrottleManager mem=35.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:49,446-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:49,638-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:49,638-0500 INFO ThrottleManager mem=35.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:49,946-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:50,138-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:50,138-0500 INFO ThrottleManager mem=35.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:50,447-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:50,638-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:50,638-0500 INFO ThrottleManager mem=35.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:50,947-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:51,139-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:51,139-0500 INFO ThrottleManager mem=36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:51,447-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:51,639-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:51,639-0500 INFO ThrottleManager mem=36.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:51,947-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:52,139-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:52,139-0500 INFO ThrottleManager mem=36.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:52,448-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:52,639-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:52,640-0500 INFO ThrottleManager mem=36.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:52,948-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:15:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 36.05 MB
+2013-08-09 14:15:53,140-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:53,140-0500 INFO ThrottleManager mem=36.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:53,448-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:53,640-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:53,640-0500 INFO ThrottleManager mem=36.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:53,948-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:54,141-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:54,141-0500 INFO ThrottleManager mem=36.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:54,449-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:54,641-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:54,641-0500 INFO ThrottleManager mem=36.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:54,641-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:15:54,949-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:54,949-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:15:55,141-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:55,141-0500 INFO ThrottleManager mem=36.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:55,449-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:55,642-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:55,642-0500 INFO ThrottleManager mem=36.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:55,950-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:56,142-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:56,142-0500 INFO ThrottleManager mem=36.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:56,450-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:56,642-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:56,642-0500 INFO ThrottleManager mem=36.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:56,746-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:15:56,950-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:57,142-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:57,143-0500 INFO ThrottleManager mem=36.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:57,337-0500 INFO Multiplexer No streams
+2013-08-09 14:15:57,450-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:57,643-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:57,643-0500 INFO ThrottleManager mem=36.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:57,951-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:58,143-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:58,143-0500 INFO ThrottleManager mem=36.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:58,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:58,643-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:58,643-0500 INFO ThrottleManager mem=36.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:58,951-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:59,143-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:59,143-0500 INFO ThrottleManager mem=36.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:59,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:59,644-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:15:59,644-0500 INFO ThrottleManager mem=36.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:15:59,952-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:00,144-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:00,144-0500 INFO ThrottleManager mem=36.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:00,452-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:00,644-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:00,644-0500 INFO ThrottleManager mem=36.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:00,952-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:01,144-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:01,145-0500 INFO ThrottleManager mem=36.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:01,452-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:01,645-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:01,645-0500 INFO ThrottleManager mem=36.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:01,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:02,145-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:02,145-0500 INFO ThrottleManager mem=36.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:02,453-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:02,645-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:02,645-0500 INFO ThrottleManager mem=36.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:02,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:16:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 36.31 MB
+2013-08-09 14:16:03,146-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:03,146-0500 INFO ThrottleManager mem=36.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:03,453-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:03,646-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:03,646-0500 INFO ThrottleManager mem=36.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:03,954-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:04,146-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:04,146-0500 INFO ThrottleManager mem=36.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:04,454-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:04,646-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:04,647-0500 INFO ThrottleManager mem=36.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:04,647-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:16:04,954-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:04,954-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:16:05,147-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:05,147-0500 INFO ThrottleManager mem=36.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:05,454-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:05,647-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:05,647-0500 INFO ThrottleManager mem=36.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:05,955-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:06,148-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:06,148-0500 INFO ThrottleManager mem=36.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:06,455-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:06,648-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:06,648-0500 INFO ThrottleManager mem=36.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:06,746-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:16:06,955-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:07,148-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:07,148-0500 INFO ThrottleManager mem=36.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:07,343-0500 INFO Multiplexer No streams
+2013-08-09 14:16:07,455-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:07,648-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:07,649-0500 INFO ThrottleManager mem=36.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:07,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:08,149-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:08,149-0500 INFO ThrottleManager mem=36.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:08,456-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:08,649-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:08,649-0500 INFO ThrottleManager mem=36.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:08,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:09,149-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:09,149-0500 INFO ThrottleManager mem=36.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:09,456-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:09,650-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:09,650-0500 INFO ThrottleManager mem=36.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:09,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:10,150-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:10,150-0500 INFO ThrottleManager mem=36.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:10,457-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:10,650-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:10,650-0500 INFO ThrottleManager mem=36.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:10,957-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:11,151-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:11,151-0500 INFO ThrottleManager mem=36.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:11,457-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:11,651-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:11,651-0500 INFO ThrottleManager mem=36.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:11,957-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:12,151-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:12,151-0500 INFO ThrottleManager mem=36.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:12,458-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:12,651-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:12,652-0500 INFO ThrottleManager mem=36.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:12,958-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:16:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 36.57 MB
+2013-08-09 14:16:13,152-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:13,152-0500 INFO ThrottleManager mem=36.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:13,458-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:13,652-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:13,652-0500 INFO ThrottleManager mem=36.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:13,958-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:14,152-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:14,153-0500 INFO ThrottleManager mem=36.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:14,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:14,653-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:14,653-0500 INFO ThrottleManager mem=36.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:14,653-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:16:14,959-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:14,959-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:16:15,153-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:15,153-0500 INFO ThrottleManager mem=36.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:15,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:15,653-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:15,653-0500 INFO ThrottleManager mem=36.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:15,959-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:16,154-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:16,154-0500 INFO ThrottleManager mem=36.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:16,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:16,654-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:16,654-0500 INFO ThrottleManager mem=36.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:16,747-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:16:16,960-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:17,154-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:17,154-0500 INFO ThrottleManager mem=36.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:17,348-0500 INFO Multiplexer No streams
+2013-08-09 14:16:17,460-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:17,654-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:17,655-0500 INFO ThrottleManager mem=36.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:17,960-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:18,155-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:18,155-0500 INFO ThrottleManager mem=36.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:18,460-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:18,655-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:18,655-0500 INFO ThrottleManager mem=36.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:18,961-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:19,155-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:19,155-0500 INFO ThrottleManager mem=36.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:19,461-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:19,656-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:19,656-0500 INFO ThrottleManager mem=36.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:19,961-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:20,156-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:20,156-0500 INFO ThrottleManager mem=36.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:20,461-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:20,656-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:20,656-0500 INFO ThrottleManager mem=36.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:20,962-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:21,157-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:21,157-0500 INFO ThrottleManager mem=36.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:21,462-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:21,657-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:21,657-0500 INFO ThrottleManager mem=36.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:21,962-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:22,157-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:22,157-0500 INFO ThrottleManager mem=36.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:22,462-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:22,657-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:22,658-0500 INFO ThrottleManager mem=36.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:16:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 36.82 MB
+2013-08-09 14:16:22,963-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:23,158-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:23,158-0500 INFO ThrottleManager mem=36.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:23,463-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:23,658-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:23,658-0500 INFO ThrottleManager mem=36.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:23,963-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:24,159-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:24,159-0500 INFO ThrottleManager mem=36.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:24,463-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:24,659-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:24,659-0500 INFO ThrottleManager mem=36.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:24,659-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:16:24,964-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:24,964-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:16:25,159-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:25,159-0500 INFO ThrottleManager mem=36.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:25,464-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:25,659-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:25,659-0500 INFO ThrottleManager mem=36.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:25,964-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:26,160-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:26,160-0500 INFO ThrottleManager mem=36.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:26,464-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:26,660-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:26,660-0500 INFO ThrottleManager mem=36.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:26,747-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:16:26,965-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:27,160-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:27,160-0500 INFO ThrottleManager mem=36.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:27,353-0500 INFO Multiplexer No streams
+2013-08-09 14:16:27,465-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:27,661-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:27,661-0500 INFO ThrottleManager mem=36.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:27,965-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:28,161-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:28,161-0500 INFO ThrottleManager mem=36.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:28,465-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:28,661-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:28,661-0500 INFO ThrottleManager mem=36.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:28,966-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:29,161-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:29,162-0500 INFO ThrottleManager mem=36.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:29,466-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:29,662-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:29,662-0500 INFO ThrottleManager mem=37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:29,966-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:30,162-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:30,162-0500 INFO ThrottleManager mem=37.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:30,466-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:30,662-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:30,662-0500 INFO ThrottleManager mem=37.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:30,967-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:31,162-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:31,162-0500 INFO ThrottleManager mem=37.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:31,467-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:31,662-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:31,663-0500 INFO ThrottleManager mem=37.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:31,967-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:32,163-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:32,163-0500 INFO ThrottleManager mem=37.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:32,467-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:32,663-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:32,663-0500 INFO ThrottleManager mem=37.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:16:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 37.09 MB
+2013-08-09 14:16:32,968-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:33,163-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:33,163-0500 INFO ThrottleManager mem=37.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:33,468-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:33,664-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:33,664-0500 INFO ThrottleManager mem=37.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:33,968-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:34,164-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:34,164-0500 INFO ThrottleManager mem=37.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:34,468-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:34,664-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:34,665-0500 INFO ThrottleManager mem=37.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:34,665-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:16:34,969-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:34,969-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:16:35,165-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:35,165-0500 INFO ThrottleManager mem=37.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:35,469-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:35,665-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:35,665-0500 INFO ThrottleManager mem=37.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:35,969-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:36,165-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:36,166-0500 INFO ThrottleManager mem=37.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:36,469-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:36,666-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:36,666-0500 INFO ThrottleManager mem=37.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:36,747-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:16:36,970-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:37,166-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:37,166-0500 INFO ThrottleManager mem=37.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:37,358-0500 INFO Multiplexer No streams
+2013-08-09 14:16:37,470-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:37,666-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:37,666-0500 INFO ThrottleManager mem=37.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:37,970-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:38,167-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:38,167-0500 INFO ThrottleManager mem=37.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:38,470-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:38,667-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:38,667-0500 INFO ThrottleManager mem=37.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:38,971-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:39,167-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:39,167-0500 INFO ThrottleManager mem=37.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:39,471-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:39,668-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:39,668-0500 INFO ThrottleManager mem=37.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:39,971-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:40,168-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:40,168-0500 INFO ThrottleManager mem=37.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:40,471-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:40,668-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:40,668-0500 INFO ThrottleManager mem=37.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:40,972-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:41,168-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:41,169-0500 INFO ThrottleManager mem=37.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:41,472-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:41,669-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:41,669-0500 INFO ThrottleManager mem=37.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:41,972-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:42,169-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:42,169-0500 INFO ThrottleManager mem=37.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:42,472-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:42,669-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:42,669-0500 INFO ThrottleManager mem=37.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:16:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 37.34 MB
+2013-08-09 14:16:42,973-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:43,170-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:43,170-0500 INFO ThrottleManager mem=37.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:43,473-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:43,670-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:43,670-0500 INFO ThrottleManager mem=37.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:43,973-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:44,170-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:44,170-0500 INFO ThrottleManager mem=37.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:44,473-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:44,670-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:44,671-0500 INFO ThrottleManager mem=37.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:44,671-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:16:44,974-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:44,974-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:16:45,171-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:45,171-0500 INFO ThrottleManager mem=37.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:45,474-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:45,671-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:45,671-0500 INFO ThrottleManager mem=37.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:45,974-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:46,171-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:46,172-0500 INFO ThrottleManager mem=37.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:46,474-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:46,672-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:46,672-0500 INFO ThrottleManager mem=37.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:46,747-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:16:46,975-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:47,172-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:47,172-0500 INFO ThrottleManager mem=37.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:47,369-0500 INFO Multiplexer No streams
+2013-08-09 14:16:47,475-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:47,672-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:47,672-0500 INFO ThrottleManager mem=37.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:47,975-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:48,173-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:48,173-0500 INFO ThrottleManager mem=37.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:48,475-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:48,673-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:48,673-0500 INFO ThrottleManager mem=37.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:48,976-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:49,173-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:49,173-0500 INFO ThrottleManager mem=37.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:49,476-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:49,673-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:49,674-0500 INFO ThrottleManager mem=37.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:49,976-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:50,174-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:50,174-0500 INFO ThrottleManager mem=37.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:50,476-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:50,674-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:50,674-0500 INFO ThrottleManager mem=37.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:50,977-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:51,174-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:51,174-0500 INFO ThrottleManager mem=37.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:51,477-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:51,675-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:51,675-0500 INFO ThrottleManager mem=37.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:51,977-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:52,175-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:52,175-0500 INFO ThrottleManager mem=37.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:52,477-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:52,675-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:52,676-0500 INFO ThrottleManager mem=37.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:16:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 37.6 MB
+2013-08-09 14:16:52,978-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:53,176-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:53,176-0500 INFO ThrottleManager mem=37.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:53,478-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:53,676-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:53,676-0500 INFO ThrottleManager mem=37.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:53,978-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:54,176-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:54,176-0500 INFO ThrottleManager mem=37.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:54,478-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:54,676-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:54,677-0500 INFO ThrottleManager mem=37.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:54,677-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:16:54,978-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:54,979-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:16:55,177-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:55,177-0500 INFO ThrottleManager mem=37.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:55,479-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:55,677-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:55,677-0500 INFO ThrottleManager mem=37.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:55,979-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:56,177-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:56,177-0500 INFO ThrottleManager mem=37.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:56,479-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:56,677-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:56,678-0500 INFO ThrottleManager mem=37.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:56,748-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:16:56,979-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:57,178-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:57,178-0500 INFO ThrottleManager mem=37.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:57,376-0500 INFO Multiplexer No streams
+2013-08-09 14:16:57,480-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:57,678-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:57,678-0500 INFO ThrottleManager mem=37.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:57,980-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:58,178-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:58,178-0500 INFO ThrottleManager mem=37.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:58,480-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:58,679-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:58,679-0500 INFO ThrottleManager mem=37.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:58,980-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:59,179-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:59,179-0500 INFO ThrottleManager mem=37.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:59,481-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:59,679-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:16:59,679-0500 INFO ThrottleManager mem=37.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:16:59,981-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:00,180-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:00,180-0500 INFO ThrottleManager mem=37.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:00,481-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:00,680-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:00,680-0500 INFO ThrottleManager mem=37.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:00,981-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:01,180-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:01,180-0500 INFO ThrottleManager mem=37.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:01,482-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:01,680-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:01,681-0500 INFO ThrottleManager mem=37.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:01,982-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:02,181-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:02,181-0500 INFO ThrottleManager mem=37.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:02,482-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:02,681-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:02,681-0500 INFO ThrottleManager mem=37.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:02,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:17:02,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 37.87 MB
+2013-08-09 14:17:02,982-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:03,182-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:03,182-0500 INFO ThrottleManager mem=37.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:03,483-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:03,682-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:03,682-0500 INFO ThrottleManager mem=37.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:03,983-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:04,182-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:04,182-0500 INFO ThrottleManager mem=37.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:04,483-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:04,682-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:04,683-0500 INFO ThrottleManager mem=37.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:04,683-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:17:04,983-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:04,983-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:17:05,183-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:05,183-0500 INFO ThrottleManager mem=37.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:05,484-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:05,683-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:05,683-0500 INFO ThrottleManager mem=37.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:05,984-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:06,184-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:06,184-0500 INFO ThrottleManager mem=37.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:06,484-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:06,684-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:06,684-0500 INFO ThrottleManager mem=37.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:06,748-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:17:06,984-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:07,184-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:07,184-0500 INFO ThrottleManager mem=37.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:07,384-0500 INFO Multiplexer No streams
+2013-08-09 14:17:07,485-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:07,685-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:07,685-0500 INFO ThrottleManager mem=37.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:07,985-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:08,185-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:08,185-0500 INFO ThrottleManager mem=38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:08,485-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:08,685-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:08,685-0500 INFO ThrottleManager mem=38.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:08,985-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:09,185-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:09,186-0500 INFO ThrottleManager mem=38.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:09,486-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:09,686-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:09,686-0500 INFO ThrottleManager mem=38.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:09,986-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:10,186-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:10,186-0500 INFO ThrottleManager mem=38.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:10,486-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:10,686-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:10,687-0500 INFO ThrottleManager mem=38.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:10,986-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:11,187-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:11,187-0500 INFO ThrottleManager mem=38.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:11,487-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:11,687-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:11,687-0500 INFO ThrottleManager mem=38.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:11,987-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:12,187-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:12,187-0500 INFO ThrottleManager mem=38.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:12,487-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:12,688-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:12,688-0500 INFO ThrottleManager mem=38.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:17:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 38.12 MB
+2013-08-09 14:17:12,987-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:13,188-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:13,188-0500 INFO ThrottleManager mem=38.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:13,488-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:13,688-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:13,688-0500 INFO ThrottleManager mem=38.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:13,988-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:14,188-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:14,189-0500 INFO ThrottleManager mem=38.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:14,488-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:14,689-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:14,689-0500 INFO ThrottleManager mem=38.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:14,689-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:17:14,988-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:14,988-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:17:15,189-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:15,189-0500 INFO ThrottleManager mem=38.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:15,489-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:15,689-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:15,689-0500 INFO ThrottleManager mem=38.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:15,989-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:16,190-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:16,190-0500 INFO ThrottleManager mem=38.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:16,489-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:16,690-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:16,690-0500 INFO ThrottleManager mem=38.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:16,748-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:17:16,989-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:17,190-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:17,190-0500 INFO ThrottleManager mem=38.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:17,388-0500 INFO Multiplexer No streams
+2013-08-09 14:17:17,490-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:17,690-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:17,691-0500 INFO ThrottleManager mem=38.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:17,990-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:18,191-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:18,191-0500 INFO ThrottleManager mem=38.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:18,490-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:18,691-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:18,691-0500 INFO ThrottleManager mem=38.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:18,990-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:19,191-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:19,191-0500 INFO ThrottleManager mem=38.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:19,491-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:19,691-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:19,692-0500 INFO ThrottleManager mem=38.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:19,991-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:20,192-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:20,192-0500 INFO ThrottleManager mem=38.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:20,491-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:20,692-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:20,692-0500 INFO ThrottleManager mem=38.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:20,991-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:21,192-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:21,192-0500 INFO ThrottleManager mem=38.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:21,492-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:21,693-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:21,693-0500 INFO ThrottleManager mem=38.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:21,992-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:22,193-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:22,193-0500 INFO ThrottleManager mem=38.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:22,492-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:22,693-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:22,693-0500 INFO ThrottleManager mem=38.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:22,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:17:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 38.38 MB
+2013-08-09 14:17:22,992-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:23,194-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:23,194-0500 INFO ThrottleManager mem=38.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:23,493-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:23,694-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:23,694-0500 INFO ThrottleManager mem=38.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:23,993-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:24,194-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:24,194-0500 INFO ThrottleManager mem=38.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:24,493-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:24,694-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:24,695-0500 INFO ThrottleManager mem=38.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:24,695-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:17:24,993-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:24,993-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:17:25,195-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:25,195-0500 INFO ThrottleManager mem=38.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:25,494-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:25,695-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:25,695-0500 INFO ThrottleManager mem=38.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:25,994-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:26,195-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:26,196-0500 INFO ThrottleManager mem=38.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:26,494-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:26,696-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:26,696-0500 INFO ThrottleManager mem=38.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:26,748-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:17:26,994-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:27,196-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:27,196-0500 INFO ThrottleManager mem=38.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:27,392-0500 INFO Multiplexer No streams
+2013-08-09 14:17:27,495-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:27,696-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:27,696-0500 INFO ThrottleManager mem=38.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:27,995-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:28,197-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:28,197-0500 INFO ThrottleManager mem=38.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:28,495-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:28,697-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:28,697-0500 INFO ThrottleManager mem=38.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:28,995-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:29,197-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:29,197-0500 INFO ThrottleManager mem=38.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:29,496-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:29,697-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:29,698-0500 INFO ThrottleManager mem=38.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:29,996-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:30,198-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:30,198-0500 INFO ThrottleManager mem=38.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:30,496-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:30,698-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:30,698-0500 INFO ThrottleManager mem=38.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:30,996-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:31,198-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:31,199-0500 INFO ThrottleManager mem=38.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:31,497-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:31,699-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:31,699-0500 INFO ThrottleManager mem=38.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:31,997-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:32,199-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:32,199-0500 INFO ThrottleManager mem=38.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:32,497-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:32,699-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:32,699-0500 INFO ThrottleManager mem=38.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:17:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 38.64 MB
+2013-08-09 14:17:32,997-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:33,200-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:33,200-0500 INFO ThrottleManager mem=38.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:33,498-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:33,700-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:33,700-0500 INFO ThrottleManager mem=38.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:33,998-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:34,200-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:34,200-0500 INFO ThrottleManager mem=38.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:34,498-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:34,700-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:34,700-0500 INFO ThrottleManager mem=38.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:34,701-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:17:34,998-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:34,998-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:17:35,201-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:35,201-0500 INFO ThrottleManager mem=38.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:35,499-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:35,701-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:35,701-0500 INFO ThrottleManager mem=38.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:35,999-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:36,201-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:36,201-0500 INFO ThrottleManager mem=38.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:36,499-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:36,701-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:36,702-0500 INFO ThrottleManager mem=38.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:36,749-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:17:36,999-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:37,202-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:37,202-0500 INFO ThrottleManager mem=38.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:37,398-0500 INFO Multiplexer No streams
+2013-08-09 14:17:37,500-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:37,702-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:37,702-0500 INFO ThrottleManager mem=38.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:38,000-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:38,202-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:38,203-0500 INFO ThrottleManager mem=38.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:38,500-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:38,703-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:38,703-0500 INFO ThrottleManager mem=38.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:39,000-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:39,203-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:39,203-0500 INFO ThrottleManager mem=38.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:39,500-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:39,703-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:39,703-0500 INFO ThrottleManager mem=38.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:40,001-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:40,204-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:40,204-0500 INFO ThrottleManager mem=38.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:40,501-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:40,704-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:40,704-0500 INFO ThrottleManager mem=38.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:41,001-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:41,204-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:41,205-0500 INFO ThrottleManager mem=38.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:41,501-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:41,705-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:41,705-0500 INFO ThrottleManager mem=38.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:42,002-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:42,205-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:42,205-0500 INFO ThrottleManager mem=38.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:42,502-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:42,705-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:42,705-0500 INFO ThrottleManager mem=38.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:17:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 38.9 MB
+2013-08-09 14:17:43,002-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:43,206-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:43,206-0500 INFO ThrottleManager mem=38.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:43,502-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:43,706-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:43,706-0500 INFO ThrottleManager mem=38.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:44,003-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:44,206-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:44,206-0500 INFO ThrottleManager mem=38.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:44,503-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:44,707-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:44,707-0500 INFO ThrottleManager mem=38.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:44,707-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:17:45,003-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:45,003-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:17:45,207-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:45,207-0500 INFO ThrottleManager mem=38.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:45,504-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:45,707-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:45,707-0500 INFO ThrottleManager mem=38.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:46,004-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:46,207-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:46,208-0500 INFO ThrottleManager mem=38.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:46,504-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:46,708-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:46,708-0500 INFO ThrottleManager mem=38.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:46,749-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:17:47,004-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:47,208-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:47,208-0500 INFO ThrottleManager mem=39.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:47,403-0500 INFO Multiplexer No streams
+2013-08-09 14:17:47,504-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:47,708-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:47,708-0500 INFO ThrottleManager mem=39.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:48,005-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:48,209-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:48,209-0500 INFO ThrottleManager mem=39.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:48,505-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:48,709-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:48,709-0500 INFO ThrottleManager mem=39.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:49,005-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:49,209-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:49,209-0500 INFO ThrottleManager mem=39.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:49,505-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:49,710-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:49,710-0500 INFO ThrottleManager mem=39.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:50,006-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:50,210-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:50,210-0500 INFO ThrottleManager mem=39.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:50,506-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:50,710-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:50,710-0500 INFO ThrottleManager mem=39.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:51,006-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:51,210-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:51,211-0500 INFO ThrottleManager mem=39.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:51,506-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:51,711-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:51,711-0500 INFO ThrottleManager mem=39.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:52,007-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:52,211-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:52,211-0500 INFO ThrottleManager mem=39.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:52,507-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:52,711-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:52,712-0500 INFO ThrottleManager mem=39.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:17:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 39.16 MB
+2013-08-09 14:17:53,007-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:53,212-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:53,212-0500 INFO ThrottleManager mem=39.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:53,507-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:53,712-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:53,712-0500 INFO ThrottleManager mem=39.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:54,008-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:54,213-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:54,213-0500 INFO ThrottleManager mem=39.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:54,508-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:54,713-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:54,713-0500 INFO ThrottleManager mem=39.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:54,713-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:17:55,008-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:55,008-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:17:55,213-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:55,213-0500 INFO ThrottleManager mem=39.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:55,508-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:55,713-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:55,714-0500 INFO ThrottleManager mem=39.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:56,009-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:56,214-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:56,214-0500 INFO ThrottleManager mem=39.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:56,509-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:56,714-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:56,714-0500 INFO ThrottleManager mem=39.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:56,749-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:17:57,009-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:57,214-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:57,214-0500 INFO ThrottleManager mem=39.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:57,407-0500 INFO Multiplexer No streams
+2013-08-09 14:17:57,509-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:57,715-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:57,715-0500 INFO ThrottleManager mem=39.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:58,010-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:58,215-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:58,215-0500 INFO ThrottleManager mem=39.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:58,510-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:58,715-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:58,715-0500 INFO ThrottleManager mem=39.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:59,010-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:59,215-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:59,216-0500 INFO ThrottleManager mem=39.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:17:59,510-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:59,716-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:17:59,716-0500 INFO ThrottleManager mem=39.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:00,011-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:00,216-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:00,216-0500 INFO ThrottleManager mem=39.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:00,511-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:00,716-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:00,716-0500 INFO ThrottleManager mem=39.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:01,011-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:01,217-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:01,217-0500 INFO ThrottleManager mem=39.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:01,511-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:01,717-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:01,717-0500 INFO ThrottleManager mem=39.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:02,012-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:02,217-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:02,217-0500 INFO ThrottleManager mem=39.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:02,512-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:02,717-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:02,718-0500 INFO ThrottleManager mem=39.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:18:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 39.42 MB
+2013-08-09 14:18:03,012-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:03,218-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:03,218-0500 INFO ThrottleManager mem=39.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:03,512-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:03,718-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:03,718-0500 INFO ThrottleManager mem=39.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:04,013-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:04,218-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:04,218-0500 INFO ThrottleManager mem=39.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:04,513-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:04,719-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:04,719-0500 INFO ThrottleManager mem=39.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:04,719-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:18:05,013-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:05,013-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:18:05,219-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:05,219-0500 INFO ThrottleManager mem=39.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:05,513-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:05,719-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:05,719-0500 INFO ThrottleManager mem=39.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:06,014-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:06,220-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:06,220-0500 INFO ThrottleManager mem=39.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:06,514-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:06,720-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:06,720-0500 INFO ThrottleManager mem=39.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:06,749-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:18:07,014-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:07,220-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:07,220-0500 INFO ThrottleManager mem=39.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:07,412-0500 INFO Multiplexer No streams
+2013-08-09 14:18:07,514-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:07,721-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:07,721-0500 INFO ThrottleManager mem=39.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:08,015-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:08,221-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:08,221-0500 INFO ThrottleManager mem=39.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:08,515-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:08,721-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:08,721-0500 INFO ThrottleManager mem=39.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:09,015-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:09,221-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:09,222-0500 INFO ThrottleManager mem=39.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:09,515-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:09,722-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:09,722-0500 INFO ThrottleManager mem=39.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:10,016-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:10,222-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:10,222-0500 INFO ThrottleManager mem=39.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:10,516-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:10,722-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:10,723-0500 INFO ThrottleManager mem=39.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:11,016-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:11,223-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:11,223-0500 INFO ThrottleManager mem=39.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:11,516-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:11,723-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:11,723-0500 INFO ThrottleManager mem=39.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:12,017-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:12,223-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:12,223-0500 INFO ThrottleManager mem=39.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:12,517-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:12,724-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:12,724-0500 INFO ThrottleManager mem=39.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:18:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 39.68 MB
+2013-08-09 14:18:13,017-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:13,224-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:13,224-0500 INFO ThrottleManager mem=39.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:13,517-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:13,724-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:13,724-0500 INFO ThrottleManager mem=39.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:14,018-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:14,224-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:14,225-0500 INFO ThrottleManager mem=39.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:14,518-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:14,725-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:14,725-0500 INFO ThrottleManager mem=39.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:14,725-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:18:15,018-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:15,018-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:18:15,225-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:15,225-0500 INFO ThrottleManager mem=39.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:15,518-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:15,725-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:15,725-0500 INFO ThrottleManager mem=39.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:16,019-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:16,226-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:16,226-0500 INFO ThrottleManager mem=39.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:16,519-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:16,726-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:16,726-0500 INFO ThrottleManager mem=39.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:16,750-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:18:17,019-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:17,226-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:17,226-0500 INFO ThrottleManager mem=39.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:17,417-0500 INFO Multiplexer No streams
+2013-08-09 14:18:17,519-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:17,726-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:17,727-0500 INFO ThrottleManager mem=39.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:18,020-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:18,227-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:18,227-0500 INFO ThrottleManager mem=39.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:18,520-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:18,727-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:18,727-0500 INFO ThrottleManager mem=39.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:19,020-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:19,227-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:19,227-0500 INFO ThrottleManager mem=39.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:19,520-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:19,728-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:19,728-0500 INFO ThrottleManager mem=39.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:20,021-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:20,228-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:20,228-0500 INFO ThrottleManager mem=39.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:20,521-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:20,728-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:20,728-0500 INFO ThrottleManager mem=39.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:21,021-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:21,228-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:21,229-0500 INFO ThrottleManager mem=39.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:21,521-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:21,729-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:21,729-0500 INFO ThrottleManager mem=39.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:22,022-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:22,229-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:22,229-0500 INFO ThrottleManager mem=39.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:22,522-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:22,729-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:22,730-0500 INFO ThrottleManager mem=39.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:18:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 39.93 MB
+2013-08-09 14:18:23,022-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:23,230-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:23,230-0500 INFO ThrottleManager mem=39.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:23,522-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:23,730-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:23,730-0500 INFO ThrottleManager mem=39.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:24,023-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:24,230-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:24,231-0500 INFO ThrottleManager mem=39.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:24,523-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:24,731-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:24,731-0500 INFO ThrottleManager mem=39.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:24,731-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:18:25,023-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:25,023-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:18:25,231-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:25,231-0500 INFO ThrottleManager mem=40 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:25,523-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:25,731-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:25,732-0500 INFO ThrottleManager mem=40.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:26,024-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:26,232-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:26,232-0500 INFO ThrottleManager mem=40.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:26,524-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:26,732-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:26,732-0500 INFO ThrottleManager mem=40.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:26,750-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:18:27,024-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:27,232-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:27,232-0500 INFO ThrottleManager mem=40.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:27,423-0500 INFO Multiplexer No streams
+2013-08-09 14:18:27,525-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:27,733-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:27,733-0500 INFO ThrottleManager mem=40.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:28,025-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:28,233-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:28,233-0500 INFO ThrottleManager mem=40.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:28,525-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:28,733-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:28,733-0500 INFO ThrottleManager mem=40.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:29,025-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:29,234-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:29,234-0500 INFO ThrottleManager mem=40.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:29,526-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:29,734-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:29,734-0500 INFO ThrottleManager mem=40.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:30,026-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:30,234-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:30,234-0500 INFO ThrottleManager mem=40.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:30,526-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:30,734-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:30,734-0500 INFO ThrottleManager mem=40.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:31,026-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:31,235-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:31,235-0500 INFO ThrottleManager mem=40.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:31,527-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:31,735-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:31,735-0500 INFO ThrottleManager mem=40.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:32,027-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:32,235-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:32,236-0500 INFO ThrottleManager mem=40.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:32,527-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:32,736-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:32,736-0500 INFO ThrottleManager mem=40.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:18:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 40.19 MB
+2013-08-09 14:18:33,027-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:33,236-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:33,236-0500 INFO ThrottleManager mem=40.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:33,528-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:33,736-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:33,736-0500 INFO ThrottleManager mem=40.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:34,028-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:34,237-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:34,237-0500 INFO ThrottleManager mem=40.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:34,528-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:34,737-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:34,737-0500 INFO ThrottleManager mem=40.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:34,737-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:18:35,028-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:35,028-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:18:35,238-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:35,238-0500 INFO ThrottleManager mem=40.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:35,529-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:35,738-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:35,738-0500 INFO ThrottleManager mem=40.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:36,029-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:36,238-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:36,238-0500 INFO ThrottleManager mem=40.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:36,529-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:36,738-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:36,739-0500 INFO ThrottleManager mem=40.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:36,750-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:18:37,029-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:37,239-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:37,239-0500 INFO ThrottleManager mem=40.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:37,430-0500 INFO Multiplexer No streams
+2013-08-09 14:18:37,530-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:37,739-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:37,739-0500 INFO ThrottleManager mem=40.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:38,030-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:38,239-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:38,239-0500 INFO ThrottleManager mem=40.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:38,530-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:38,740-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:38,740-0500 INFO ThrottleManager mem=40.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:39,030-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:39,240-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:39,240-0500 INFO ThrottleManager mem=40.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:39,531-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:39,740-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:39,740-0500 INFO ThrottleManager mem=40.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:40,031-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:40,240-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:40,241-0500 INFO ThrottleManager mem=40.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:40,531-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:40,741-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:40,741-0500 INFO ThrottleManager mem=40.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:41,031-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:41,241-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:41,241-0500 INFO ThrottleManager mem=40.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:41,532-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:41,742-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:41,742-0500 INFO ThrottleManager mem=40.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:42,032-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:42,242-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:42,242-0500 INFO ThrottleManager mem=40.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:42,532-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:42,742-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:42,742-0500 INFO ThrottleManager mem=40.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:18:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 40.45 MB
+2013-08-09 14:18:43,032-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:43,242-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:43,243-0500 INFO ThrottleManager mem=40.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:43,533-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:43,743-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:43,743-0500 INFO ThrottleManager mem=40.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:44,033-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:44,243-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:44,243-0500 INFO ThrottleManager mem=40.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:44,533-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:44,743-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:44,743-0500 INFO ThrottleManager mem=40.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:44,743-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:18:45,033-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:45,033-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:18:45,243-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:45,244-0500 INFO ThrottleManager mem=40.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:45,534-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:45,744-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:45,744-0500 INFO ThrottleManager mem=40.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:46,034-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:46,244-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:46,244-0500 INFO ThrottleManager mem=40.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:46,534-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:46,744-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:46,744-0500 INFO ThrottleManager mem=40.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:46,750-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:18:47,034-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:47,245-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:47,245-0500 INFO ThrottleManager mem=40.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:47,436-0500 INFO Multiplexer No streams
+2013-08-09 14:18:47,535-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:47,745-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:47,745-0500 INFO ThrottleManager mem=40.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:48,035-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:48,245-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:48,245-0500 INFO ThrottleManager mem=40.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:48,535-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:48,745-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:48,745-0500 INFO ThrottleManager mem=40.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:49,035-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:49,246-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:49,246-0500 INFO ThrottleManager mem=40.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:49,536-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:49,746-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:49,746-0500 INFO ThrottleManager mem=40.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:50,036-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:50,246-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:50,246-0500 INFO ThrottleManager mem=40.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:50,536-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:50,746-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:50,747-0500 INFO ThrottleManager mem=40.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:51,036-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:51,247-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:51,247-0500 INFO ThrottleManager mem=40.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:51,537-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:51,747-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:51,747-0500 INFO ThrottleManager mem=40.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:52,037-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:52,247-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:52,247-0500 INFO ThrottleManager mem=40.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:52,537-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:52,748-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:52,748-0500 INFO ThrottleManager mem=40.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:18:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 40.71 MB
+2013-08-09 14:18:53,037-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:53,248-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:53,248-0500 INFO ThrottleManager mem=40.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:53,538-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:53,748-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:53,749-0500 INFO ThrottleManager mem=40.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:54,038-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:54,249-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:54,249-0500 INFO ThrottleManager mem=40.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:54,538-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:54,749-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:54,749-0500 INFO ThrottleManager mem=40.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:54,749-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:18:55,038-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:55,038-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:18:55,249-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:55,249-0500 INFO ThrottleManager mem=40.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:55,539-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:55,750-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:55,750-0500 INFO ThrottleManager mem=40.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:56,039-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:56,250-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:56,250-0500 INFO ThrottleManager mem=40.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:56,539-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:56,750-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:56,750-0500 INFO ThrottleManager mem=40.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:56,751-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:18:57,039-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:57,250-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:57,251-0500 INFO ThrottleManager mem=40.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:57,444-0500 INFO Multiplexer No streams
+2013-08-09 14:18:57,540-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:57,751-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:57,751-0500 INFO ThrottleManager mem=40.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:58,040-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:58,251-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:58,251-0500 INFO ThrottleManager mem=40.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:58,540-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:58,751-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:58,751-0500 INFO ThrottleManager mem=40.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:59,040-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:59,252-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:59,252-0500 INFO ThrottleManager mem=40.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:18:59,541-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:59,752-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:18:59,752-0500 INFO ThrottleManager mem=40.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:00,041-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:00,252-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:00,252-0500 INFO ThrottleManager mem=40.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:00,541-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:00,752-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:00,753-0500 INFO ThrottleManager mem=40.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:01,041-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:01,253-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:01,253-0500 INFO ThrottleManager mem=40.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:01,541-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:01,753-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:01,753-0500 INFO ThrottleManager mem=40.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:02,042-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:02,253-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:02,253-0500 INFO ThrottleManager mem=40.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:02,542-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:02,753-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:02,754-0500 INFO ThrottleManager mem=40.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:02,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:19:02,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 40.97 MB
+2013-08-09 14:19:03,042-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:03,254-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:03,254-0500 INFO ThrottleManager mem=40.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:03,542-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:03,754-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:03,754-0500 INFO ThrottleManager mem=40.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:04,043-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:04,254-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:04,254-0500 INFO ThrottleManager mem=41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:04,543-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:04,755-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:04,755-0500 INFO ThrottleManager mem=41.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:04,755-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:19:05,043-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:05,043-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:19:05,255-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:05,255-0500 INFO ThrottleManager mem=41.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:05,543-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:05,755-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:05,756-0500 INFO ThrottleManager mem=41.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:06,044-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:06,256-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:06,256-0500 INFO ThrottleManager mem=41.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:06,544-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:06,750-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:19:06,756-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:06,756-0500 INFO ThrottleManager mem=41.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:07,044-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:07,256-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:07,256-0500 INFO ThrottleManager mem=41.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:07,450-0500 INFO Multiplexer No streams
+2013-08-09 14:19:07,544-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:07,757-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:07,757-0500 INFO ThrottleManager mem=41.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:08,045-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:08,257-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:08,257-0500 INFO ThrottleManager mem=41.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:08,545-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:08,757-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:08,757-0500 INFO ThrottleManager mem=41.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:09,045-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:09,258-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:09,258-0500 INFO ThrottleManager mem=41.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:09,545-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:09,758-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:09,758-0500 INFO ThrottleManager mem=41.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:10,046-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:10,258-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:10,258-0500 INFO ThrottleManager mem=41.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:10,546-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:10,759-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:10,759-0500 INFO ThrottleManager mem=41.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:11,046-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:11,259-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:11,259-0500 INFO ThrottleManager mem=41.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:11,546-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:11,759-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:11,759-0500 INFO ThrottleManager mem=41.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:12,047-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:12,259-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:12,260-0500 INFO ThrottleManager mem=41.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:12,547-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:12,760-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:12,760-0500 INFO ThrottleManager mem=41.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:19:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 41.23 MB
+2013-08-09 14:19:13,047-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:13,260-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:13,260-0500 INFO ThrottleManager mem=41.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:13,547-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:13,760-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:13,760-0500 INFO ThrottleManager mem=41.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:14,047-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:14,260-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:14,260-0500 INFO ThrottleManager mem=41.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:14,548-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:14,761-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:14,761-0500 INFO ThrottleManager mem=41.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:14,761-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:19:15,048-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:15,048-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:19:15,261-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:15,261-0500 INFO ThrottleManager mem=41.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:15,548-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:15,761-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:15,761-0500 INFO ThrottleManager mem=41.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:16,048-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:16,262-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:16,262-0500 INFO ThrottleManager mem=41.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:16,549-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:16,750-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:19:16,762-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:16,762-0500 INFO ThrottleManager mem=41.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:17,049-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:17,262-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:17,262-0500 INFO ThrottleManager mem=41.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:17,459-0500 INFO Multiplexer No streams
+2013-08-09 14:19:17,549-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:17,762-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:17,763-0500 INFO ThrottleManager mem=41.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:18,049-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:18,263-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:18,263-0500 INFO ThrottleManager mem=41.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:18,550-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:18,763-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:18,763-0500 INFO ThrottleManager mem=41.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:19,050-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:19,263-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:19,263-0500 INFO ThrottleManager mem=41.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:19,550-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:19,763-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:19,764-0500 INFO ThrottleManager mem=41.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:20,050-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:20,264-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:20,264-0500 INFO ThrottleManager mem=41.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:20,551-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:20,764-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:20,764-0500 INFO ThrottleManager mem=41.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:21,051-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:21,264-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:21,264-0500 INFO ThrottleManager mem=41.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:21,551-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:21,765-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:21,765-0500 INFO ThrottleManager mem=41.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:22,051-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:22,265-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:22,265-0500 INFO ThrottleManager mem=41.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:22,552-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:22,765-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:22,766-0500 INFO ThrottleManager mem=41.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:19:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 41.49 MB
+2013-08-09 14:19:23,052-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:23,266-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:23,266-0500 INFO ThrottleManager mem=41.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:23,552-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:23,766-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:23,766-0500 INFO ThrottleManager mem=41.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:24,052-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:24,266-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:24,266-0500 INFO ThrottleManager mem=41.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:24,553-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:24,767-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:24,767-0500 INFO ThrottleManager mem=41.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:24,767-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:19:25,053-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:25,053-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:19:25,267-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:25,267-0500 INFO ThrottleManager mem=41.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:25,553-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:25,767-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:25,767-0500 INFO ThrottleManager mem=41.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:26,053-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:26,268-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:26,268-0500 INFO ThrottleManager mem=41.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:26,554-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:26,750-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:19:26,768-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:26,768-0500 INFO ThrottleManager mem=41.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:27,054-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:27,268-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:27,268-0500 INFO ThrottleManager mem=41.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:27,468-0500 INFO Multiplexer No streams
+2013-08-09 14:19:27,554-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:27,768-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:27,769-0500 INFO ThrottleManager mem=41.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:28,054-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:28,269-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:28,269-0500 INFO ThrottleManager mem=41.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:28,554-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:28,769-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:28,769-0500 INFO ThrottleManager mem=41.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:29,055-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:29,269-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:29,269-0500 INFO ThrottleManager mem=41.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:29,555-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:29,769-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:29,770-0500 INFO ThrottleManager mem=41.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:30,055-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:30,270-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:30,270-0500 INFO ThrottleManager mem=41.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:30,555-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:30,770-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:30,770-0500 INFO ThrottleManager mem=41.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:31,056-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:31,270-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:31,271-0500 INFO ThrottleManager mem=41.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:31,556-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:31,771-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:31,771-0500 INFO ThrottleManager mem=41.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:32,056-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:32,271-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:32,271-0500 INFO ThrottleManager mem=41.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:32,556-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:32,771-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:32,771-0500 INFO ThrottleManager mem=41.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:19:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 41.75 MB
+2013-08-09 14:19:33,057-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:33,271-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:33,272-0500 INFO ThrottleManager mem=41.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:33,557-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:33,772-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:33,772-0500 INFO ThrottleManager mem=41.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:34,057-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:34,272-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:34,272-0500 INFO ThrottleManager mem=41.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:34,557-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:34,772-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:34,773-0500 INFO ThrottleManager mem=41.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:34,773-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:19:35,058-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:35,058-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:19:35,273-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:35,273-0500 INFO ThrottleManager mem=41.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:35,558-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:35,773-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:35,773-0500 INFO ThrottleManager mem=41.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:36,058-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:36,273-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:36,273-0500 INFO ThrottleManager mem=41.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:36,558-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:36,751-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:19:36,774-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:36,774-0500 INFO ThrottleManager mem=41.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:37,059-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:37,274-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:37,274-0500 INFO ThrottleManager mem=41.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:37,474-0500 INFO Multiplexer No streams
+2013-08-09 14:19:37,559-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:37,774-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:37,774-0500 INFO ThrottleManager mem=41.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:38,059-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:38,274-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:38,275-0500 INFO ThrottleManager mem=41.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:38,559-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:38,775-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:38,775-0500 INFO ThrottleManager mem=41.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:39,060-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:39,275-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:39,275-0500 INFO ThrottleManager mem=41.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:39,560-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:39,775-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:39,775-0500 INFO ThrottleManager mem=41.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:40,060-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:40,276-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:40,276-0500 INFO ThrottleManager mem=41.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:40,560-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:40,776-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:40,776-0500 INFO ThrottleManager mem=41.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:41,061-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:41,276-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:41,277-0500 INFO ThrottleManager mem=41.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:41,561-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:41,777-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:41,777-0500 INFO ThrottleManager mem=41.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:42,061-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:42,277-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:42,277-0500 INFO ThrottleManager mem=41.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:42,561-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:42,777-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:42,777-0500 INFO ThrottleManager mem=42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:19:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 42.01 MB
+2013-08-09 14:19:43,061-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:43,277-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:43,278-0500 INFO ThrottleManager mem=42.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:43,562-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:43,778-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:43,778-0500 INFO ThrottleManager mem=42.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:44,062-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:44,278-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:44,278-0500 INFO ThrottleManager mem=42.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:44,562-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:44,778-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:44,778-0500 INFO ThrottleManager mem=42.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:44,778-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:19:45,062-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:45,062-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:19:45,279-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:45,279-0500 INFO ThrottleManager mem=42.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:45,562-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:45,779-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:45,779-0500 INFO ThrottleManager mem=42.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:46,063-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:46,279-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:46,279-0500 INFO ThrottleManager mem=42.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:46,563-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:46,751-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:19:46,779-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:46,780-0500 INFO ThrottleManager mem=42.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:47,063-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:47,280-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:47,280-0500 INFO ThrottleManager mem=42.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:47,478-0500 INFO Multiplexer No streams
+2013-08-09 14:19:47,563-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:47,780-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:47,780-0500 INFO ThrottleManager mem=42.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:48,064-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:48,280-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:48,280-0500 INFO ThrottleManager mem=42.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:48,564-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:48,781-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:48,781-0500 INFO ThrottleManager mem=42.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:49,064-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:49,281-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:49,281-0500 INFO ThrottleManager mem=42.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:49,564-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:49,781-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:49,781-0500 INFO ThrottleManager mem=42.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:50,065-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:50,281-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:50,282-0500 INFO ThrottleManager mem=42.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:50,565-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:50,782-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:50,782-0500 INFO ThrottleManager mem=42.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:51,065-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:51,282-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:51,282-0500 INFO ThrottleManager mem=42.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:51,565-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:51,782-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:51,782-0500 INFO ThrottleManager mem=42.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:52,066-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:52,283-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:52,283-0500 INFO ThrottleManager mem=42.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:52,566-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:52,783-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:52,783-0500 INFO ThrottleManager mem=42.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:52,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:19:52,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 42.26 MB
+2013-08-09 14:19:53,066-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:53,283-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:53,283-0500 INFO ThrottleManager mem=42.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:53,566-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:53,784-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:53,784-0500 INFO ThrottleManager mem=42.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:54,066-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:54,284-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:54,284-0500 INFO ThrottleManager mem=42.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:54,567-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:54,784-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:54,784-0500 INFO ThrottleManager mem=42.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:54,784-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:19:55,067-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:55,067-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:19:55,284-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:55,285-0500 INFO ThrottleManager mem=42.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:55,567-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:55,785-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:55,785-0500 INFO ThrottleManager mem=42.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:56,068-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:56,285-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:56,285-0500 INFO ThrottleManager mem=42.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:56,568-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:56,751-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:19:56,785-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:56,785-0500 INFO ThrottleManager mem=42.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:57,068-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:57,286-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:57,286-0500 INFO ThrottleManager mem=42.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:57,485-0500 INFO Multiplexer No streams
+2013-08-09 14:19:57,568-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:57,786-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:57,786-0500 INFO ThrottleManager mem=42.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:58,069-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:58,286-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:58,286-0500 INFO ThrottleManager mem=42.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:58,569-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:58,786-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:58,787-0500 INFO ThrottleManager mem=42.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:59,069-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:59,287-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:59,287-0500 INFO ThrottleManager mem=42.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:19:59,569-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:59,787-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:19:59,787-0500 INFO ThrottleManager mem=42.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:00,070-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:00,287-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:00,287-0500 INFO ThrottleManager mem=42.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:00,570-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:00,788-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:00,788-0500 INFO ThrottleManager mem=42.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:01,070-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:01,288-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:01,288-0500 INFO ThrottleManager mem=42.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:01,570-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:01,788-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:01,788-0500 INFO ThrottleManager mem=42.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:02,071-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:02,289-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:02,289-0500 INFO ThrottleManager mem=42.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:02,571-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:02,789-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:02,789-0500 INFO ThrottleManager mem=42.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:20:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 42.52 MB
+2013-08-09 14:20:03,071-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:03,289-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:03,289-0500 INFO ThrottleManager mem=42.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:03,571-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:03,789-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:03,790-0500 INFO ThrottleManager mem=42.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:04,072-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:04,290-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:04,290-0500 INFO ThrottleManager mem=42.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:04,572-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:04,790-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:04,790-0500 INFO ThrottleManager mem=42.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:04,790-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:20:05,072-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:05,072-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:20:05,290-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:05,291-0500 INFO ThrottleManager mem=42.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:05,572-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:05,791-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:05,791-0500 INFO ThrottleManager mem=42.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:06,073-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:06,291-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:06,291-0500 INFO ThrottleManager mem=42.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:06,573-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:06,751-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:20:06,791-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:06,791-0500 INFO ThrottleManager mem=42.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:07,073-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:07,292-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:07,292-0500 INFO ThrottleManager mem=42.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:07,493-0500 INFO Multiplexer No streams
+2013-08-09 14:20:07,573-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:07,792-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:07,792-0500 INFO ThrottleManager mem=42.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:08,074-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:08,292-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:08,292-0500 INFO ThrottleManager mem=42.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:08,574-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:08,792-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:08,793-0500 INFO ThrottleManager mem=42.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:09,074-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:09,293-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:09,293-0500 INFO ThrottleManager mem=42.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:09,574-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:09,793-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:09,793-0500 INFO ThrottleManager mem=42.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:10,075-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:10,293-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:10,294-0500 INFO ThrottleManager mem=42.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:10,575-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:10,794-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:10,794-0500 INFO ThrottleManager mem=42.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:11,075-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:11,294-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:11,294-0500 INFO ThrottleManager mem=42.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:11,575-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:11,794-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:11,795-0500 INFO ThrottleManager mem=42.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:12,076-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:12,295-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:12,295-0500 INFO ThrottleManager mem=42.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:12,576-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:12,795-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:12,795-0500 INFO ThrottleManager mem=42.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:20:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 42.79 MB
+2013-08-09 14:20:13,076-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:13,295-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:13,295-0500 INFO ThrottleManager mem=42.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:13,576-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:13,796-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:13,796-0500 INFO ThrottleManager mem=42.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:14,077-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:14,296-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:14,296-0500 INFO ThrottleManager mem=42.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:14,577-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:14,796-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:14,796-0500 INFO ThrottleManager mem=42.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:14,796-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:20:15,077-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:15,077-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:20:15,297-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:15,297-0500 INFO ThrottleManager mem=42.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:15,578-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:15,797-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:15,797-0500 INFO ThrottleManager mem=42.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:16,078-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:16,297-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:16,297-0500 INFO ThrottleManager mem=42.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:16,578-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:16,751-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:20:16,797-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:16,797-0500 INFO ThrottleManager mem=42.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:17,078-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:17,298-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:17,298-0500 INFO ThrottleManager mem=42.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:17,500-0500 INFO Multiplexer No streams
+2013-08-09 14:20:17,579-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:17,798-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:17,798-0500 INFO ThrottleManager mem=42.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:18,079-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:18,298-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:18,298-0500 INFO ThrottleManager mem=42.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:18,579-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:18,799-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:18,799-0500 INFO ThrottleManager mem=42.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:19,079-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:19,299-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:19,299-0500 INFO ThrottleManager mem=42.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:19,580-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:19,799-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:19,799-0500 INFO ThrottleManager mem=42.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:20,080-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:20,299-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:20,299-0500 INFO ThrottleManager mem=42.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:20,580-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:20,800-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:20,800-0500 INFO ThrottleManager mem=42.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:21,080-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:21,300-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:21,300-0500 INFO ThrottleManager mem=43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:21,581-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:21,800-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:21,800-0500 INFO ThrottleManager mem=43.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:22,081-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:22,300-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:22,300-0500 INFO ThrottleManager mem=43.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:22,581-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:22,801-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:22,801-0500 INFO ThrottleManager mem=43.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:20:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 43.04 MB
+2013-08-09 14:20:23,081-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:23,301-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:23,301-0500 INFO ThrottleManager mem=43.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:23,582-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:23,801-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:23,802-0500 INFO ThrottleManager mem=43.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:24,082-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:24,302-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:24,302-0500 INFO ThrottleManager mem=43.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:24,582-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:24,802-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:24,802-0500 INFO ThrottleManager mem=43.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:24,802-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:20:25,082-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:25,082-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:20:25,302-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:25,302-0500 INFO ThrottleManager mem=43.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:25,583-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:25,803-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:25,803-0500 INFO ThrottleManager mem=43.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:26,083-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:26,303-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:26,303-0500 INFO ThrottleManager mem=43.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:26,583-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:26,752-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:20:26,803-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:26,803-0500 INFO ThrottleManager mem=43.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:27,083-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:27,304-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:27,304-0500 INFO ThrottleManager mem=43.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:27,508-0500 INFO Multiplexer No streams
+2013-08-09 14:20:27,584-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:27,804-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:27,804-0500 INFO ThrottleManager mem=43.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:28,084-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:28,304-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:28,304-0500 INFO ThrottleManager mem=43.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:28,584-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:28,804-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:28,805-0500 INFO ThrottleManager mem=43.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:29,084-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:29,305-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:29,305-0500 INFO ThrottleManager mem=43.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:29,585-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:29,805-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:29,805-0500 INFO ThrottleManager mem=43.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:30,085-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:30,305-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:30,305-0500 INFO ThrottleManager mem=43.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:30,585-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:30,806-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:30,806-0500 INFO ThrottleManager mem=43.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:31,085-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:31,306-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:31,306-0500 INFO ThrottleManager mem=43.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:31,586-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:31,806-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:31,806-0500 INFO ThrottleManager mem=43.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:32,086-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:32,306-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:32,307-0500 INFO ThrottleManager mem=43.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:32,586-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:32,807-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:32,807-0500 INFO ThrottleManager mem=43.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:20:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 43.3 MB
+2013-08-09 14:20:33,086-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:33,307-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:33,307-0500 INFO ThrottleManager mem=43.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:33,587-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:33,807-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:33,807-0500 INFO ThrottleManager mem=43.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:34,087-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:34,308-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:34,308-0500 INFO ThrottleManager mem=43.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:34,587-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:34,808-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:34,808-0500 INFO ThrottleManager mem=43.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:34,808-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:20:35,087-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:35,087-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:20:35,308-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:35,308-0500 INFO ThrottleManager mem=43.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:35,588-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:35,809-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:35,809-0500 INFO ThrottleManager mem=43.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:36,088-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:36,309-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:36,309-0500 INFO ThrottleManager mem=43.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:36,588-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:36,752-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:20:36,809-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:36,809-0500 INFO ThrottleManager mem=43.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:37,088-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:37,310-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:37,310-0500 INFO ThrottleManager mem=43.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:37,515-0500 INFO Multiplexer No streams
+2013-08-09 14:20:37,589-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:37,810-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:37,810-0500 INFO ThrottleManager mem=43.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:38,089-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:38,310-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:38,310-0500 INFO ThrottleManager mem=43.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:38,589-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:38,810-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:38,811-0500 INFO ThrottleManager mem=43.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:39,089-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:39,311-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:39,311-0500 INFO ThrottleManager mem=43.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:39,590-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:39,811-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:39,811-0500 INFO ThrottleManager mem=43.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:40,090-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:40,311-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:40,311-0500 INFO ThrottleManager mem=43.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:40,590-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:40,812-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:40,812-0500 INFO ThrottleManager mem=43.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:41,090-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:41,312-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:41,312-0500 INFO ThrottleManager mem=43.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:41,591-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:41,812-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:41,813-0500 INFO ThrottleManager mem=43.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:42,091-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:42,313-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:42,313-0500 INFO ThrottleManager mem=43.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:42,591-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:42,813-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:42,813-0500 INFO ThrottleManager mem=43.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:20:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 43.56 MB
+2013-08-09 14:20:43,091-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:43,313-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:43,313-0500 INFO ThrottleManager mem=43.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:43,592-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:43,814-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:43,814-0500 INFO ThrottleManager mem=43.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:44,092-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:44,314-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:44,314-0500 INFO ThrottleManager mem=43.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:44,592-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:44,814-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:44,814-0500 INFO ThrottleManager mem=43.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:44,814-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:20:45,092-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:45,092-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:20:45,314-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:45,314-0500 INFO ThrottleManager mem=43.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:45,592-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:45,815-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:45,815-0500 INFO ThrottleManager mem=43.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:46,093-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:46,315-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:46,315-0500 INFO ThrottleManager mem=43.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:46,593-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:46,752-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:20:46,815-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:46,815-0500 INFO ThrottleManager mem=43.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:47,093-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:47,316-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:47,316-0500 INFO ThrottleManager mem=43.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:47,522-0500 INFO Multiplexer No streams
+2013-08-09 14:20:47,593-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:47,816-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:47,816-0500 INFO ThrottleManager mem=43.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:48,094-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:48,316-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:48,316-0500 INFO ThrottleManager mem=43.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:48,594-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:48,816-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:48,817-0500 INFO ThrottleManager mem=43.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:49,094-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:49,317-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:49,317-0500 INFO ThrottleManager mem=43.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:49,594-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:49,817-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:49,817-0500 INFO ThrottleManager mem=43.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:50,095-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:50,317-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:50,317-0500 INFO ThrottleManager mem=43.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:50,595-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:50,817-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:50,818-0500 INFO ThrottleManager mem=43.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:51,095-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:51,318-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:51,318-0500 INFO ThrottleManager mem=43.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:51,595-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:51,818-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:51,818-0500 INFO ThrottleManager mem=43.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:52,096-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:52,318-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:52,318-0500 INFO ThrottleManager mem=43.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:52,596-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:52,819-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:52,819-0500 INFO ThrottleManager mem=43.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:20:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 43.82 MB
+2013-08-09 14:20:53,096-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:53,319-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:53,319-0500 INFO ThrottleManager mem=43.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:53,596-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:53,819-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:53,819-0500 INFO ThrottleManager mem=43.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:54,097-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:54,320-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:54,320-0500 INFO ThrottleManager mem=43.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:54,597-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:54,820-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:54,820-0500 INFO ThrottleManager mem=43.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:54,820-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:20:55,097-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:55,097-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:20:55,320-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:55,320-0500 INFO ThrottleManager mem=43.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:55,597-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:55,821-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:55,821-0500 INFO ThrottleManager mem=43.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:56,098-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:56,321-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:56,321-0500 INFO ThrottleManager mem=43.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:56,598-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:56,752-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:20:56,821-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:56,821-0500 INFO ThrottleManager mem=43.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:57,098-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:57,321-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:57,322-0500 INFO ThrottleManager mem=43.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:57,529-0500 INFO Multiplexer No streams
+2013-08-09 14:20:57,598-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:57,822-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:57,822-0500 INFO ThrottleManager mem=43.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:58,099-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:58,322-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:58,322-0500 INFO ThrottleManager mem=43.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:58,599-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:58,822-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:58,822-0500 INFO ThrottleManager mem=43.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:59,099-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:59,323-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:59,323-0500 INFO ThrottleManager mem=43.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:20:59,599-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:59,823-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:20:59,823-0500 INFO ThrottleManager mem=43.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:00,099-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:00,323-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:00,323-0500 INFO ThrottleManager mem=44.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:00,600-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:00,823-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:00,824-0500 INFO ThrottleManager mem=44.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:01,100-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:01,324-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:01,324-0500 INFO ThrottleManager mem=44.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:01,600-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:01,824-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:01,824-0500 INFO ThrottleManager mem=44.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:02,100-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:02,324-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:02,324-0500 INFO ThrottleManager mem=44.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:02,601-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:02,825-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:02,825-0500 INFO ThrottleManager mem=44.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:21:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 44.08 MB
+2013-08-09 14:21:03,101-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:03,325-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:03,325-0500 INFO ThrottleManager mem=44.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:03,601-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:03,825-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:03,825-0500 INFO ThrottleManager mem=44.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:04,101-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:04,326-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:04,326-0500 INFO ThrottleManager mem=44.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:04,601-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:04,826-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:04,826-0500 INFO ThrottleManager mem=44.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:04,826-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:21:05,102-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:05,102-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:21:05,326-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:05,326-0500 INFO ThrottleManager mem=44.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:05,602-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:05,827-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:05,827-0500 INFO ThrottleManager mem=44.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:06,102-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:06,327-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:06,327-0500 INFO ThrottleManager mem=44.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:06,602-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:06,753-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:21:06,827-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:06,827-0500 INFO ThrottleManager mem=44.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:07,103-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:07,328-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:07,328-0500 INFO ThrottleManager mem=44.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:07,536-0500 INFO Multiplexer No streams
+2013-08-09 14:21:07,603-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:07,828-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:07,828-0500 INFO ThrottleManager mem=44.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:08,103-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:08,328-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:08,328-0500 INFO ThrottleManager mem=44.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:08,603-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:08,828-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:08,828-0500 INFO ThrottleManager mem=44.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:09,103-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:09,329-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:09,329-0500 INFO ThrottleManager mem=44.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:09,604-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:09,829-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:09,829-0500 INFO ThrottleManager mem=44.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:10,104-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:10,329-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:10,329-0500 INFO ThrottleManager mem=44.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:10,604-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:10,829-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:10,830-0500 INFO ThrottleManager mem=44.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:11,104-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:11,330-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:11,330-0500 INFO ThrottleManager mem=44.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:11,605-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:11,830-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:11,830-0500 INFO ThrottleManager mem=44.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:12,105-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:12,331-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:12,331-0500 INFO ThrottleManager mem=44.32 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:12,605-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:12,831-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:12,831-0500 INFO ThrottleManager mem=44.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:21:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 44.34 MB
+2013-08-09 14:21:13,105-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:13,331-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:13,331-0500 INFO ThrottleManager mem=44.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:13,606-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:13,831-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:13,832-0500 INFO ThrottleManager mem=44.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:14,106-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:14,332-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:14,332-0500 INFO ThrottleManager mem=44.37 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:14,606-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:14,832-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:14,832-0500 INFO ThrottleManager mem=44.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:14,832-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:21:15,106-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:15,106-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:21:15,332-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:15,332-0500 INFO ThrottleManager mem=44.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:15,607-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:15,832-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:15,833-0500 INFO ThrottleManager mem=44.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:16,107-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:16,333-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:16,333-0500 INFO ThrottleManager mem=44.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:16,607-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:16,752-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:21:16,833-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:16,833-0500 INFO ThrottleManager mem=44.44 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:17,107-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:17,333-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:17,333-0500 INFO ThrottleManager mem=44.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:17,542-0500 INFO Multiplexer No streams
+2013-08-09 14:21:17,608-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:17,834-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:17,834-0500 INFO ThrottleManager mem=44.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:18,108-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:18,334-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:18,334-0500 INFO ThrottleManager mem=44.48 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:18,608-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:18,834-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:18,834-0500 INFO ThrottleManager mem=44.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:19,108-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:19,335-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:19,335-0500 INFO ThrottleManager mem=44.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:19,609-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:19,835-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:19,835-0500 INFO ThrottleManager mem=44.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:20,109-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:20,335-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:20,335-0500 INFO ThrottleManager mem=44.53 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:20,609-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:20,835-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:20,836-0500 INFO ThrottleManager mem=44.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:21,109-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:21,336-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:21,336-0500 INFO ThrottleManager mem=44.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:21,610-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:21,836-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:21,836-0500 INFO ThrottleManager mem=44.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:22,110-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:22,336-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:22,336-0500 INFO ThrottleManager mem=44.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:22,610-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:22,837-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:22,837-0500 INFO ThrottleManager mem=44.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:21:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 44.6 MB
+2013-08-09 14:21:23,110-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:23,337-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:23,337-0500 INFO ThrottleManager mem=44.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:23,611-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:23,837-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:23,837-0500 INFO ThrottleManager mem=44.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:24,111-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:24,338-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:24,338-0500 INFO ThrottleManager mem=44.63 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:24,611-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:24,838-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:24,838-0500 INFO ThrottleManager mem=44.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:24,838-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:21:25,111-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:25,111-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:21:25,338-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:25,338-0500 INFO ThrottleManager mem=44.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:25,612-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:25,839-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:25,839-0500 INFO ThrottleManager mem=44.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:26,112-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:26,339-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:26,339-0500 INFO ThrottleManager mem=44.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:26,612-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:26,752-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:21:26,839-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:26,839-0500 INFO ThrottleManager mem=44.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:27,112-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:27,339-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:27,340-0500 INFO ThrottleManager mem=44.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:27,549-0500 INFO Multiplexer No streams
+2013-08-09 14:21:27,613-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:27,840-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:27,840-0500 INFO ThrottleManager mem=44.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:28,113-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:28,340-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:28,340-0500 INFO ThrottleManager mem=44.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:28,613-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:28,840-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:28,841-0500 INFO ThrottleManager mem=44.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:29,113-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:29,341-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:29,341-0500 INFO ThrottleManager mem=44.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:29,614-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:29,841-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:29,841-0500 INFO ThrottleManager mem=44.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:30,114-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:30,341-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:30,341-0500 INFO ThrottleManager mem=44.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:30,614-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:30,842-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:30,842-0500 INFO ThrottleManager mem=44.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:31,114-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:31,342-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:31,342-0500 INFO ThrottleManager mem=44.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:31,615-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:31,842-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:31,842-0500 INFO ThrottleManager mem=44.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:32,115-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:32,343-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:32,343-0500 INFO ThrottleManager mem=44.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:32,615-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:32,843-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:32,843-0500 INFO ThrottleManager mem=44.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:21:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 44.85 MB
+2013-08-09 14:21:33,115-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:33,343-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:33,343-0500 INFO ThrottleManager mem=44.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:33,615-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:33,843-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:33,844-0500 INFO ThrottleManager mem=44.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:34,116-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:34,344-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:34,344-0500 INFO ThrottleManager mem=44.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:34,616-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:34,844-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:34,844-0500 INFO ThrottleManager mem=44.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:34,844-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:21:35,116-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:35,116-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:21:35,345-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:35,345-0500 INFO ThrottleManager mem=44.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:35,617-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:35,845-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:35,845-0500 INFO ThrottleManager mem=44.93 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:36,117-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:36,345-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:36,345-0500 INFO ThrottleManager mem=44.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:36,617-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:36,752-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:21:36,845-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:36,845-0500 INFO ThrottleManager mem=44.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:37,117-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:37,346-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:37,346-0500 INFO ThrottleManager mem=44.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:37,553-0500 INFO Multiplexer No streams
+2013-08-09 14:21:37,617-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:37,846-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:37,846-0500 INFO ThrottleManager mem=44.98 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:38,118-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:38,346-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:38,346-0500 INFO ThrottleManager mem=44.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:38,618-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:38,847-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:38,847-0500 INFO ThrottleManager mem=45.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:39,118-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:39,347-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:39,347-0500 INFO ThrottleManager mem=45.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:39,618-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:39,847-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:39,847-0500 INFO ThrottleManager mem=45.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:40,119-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:40,347-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:40,348-0500 INFO ThrottleManager mem=45.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:40,619-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:40,848-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:40,848-0500 INFO ThrottleManager mem=45.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:41,119-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:41,348-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:41,348-0500 INFO ThrottleManager mem=45.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:41,619-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:41,849-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:41,849-0500 INFO ThrottleManager mem=45.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:42,120-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:42,349-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:42,349-0500 INFO ThrottleManager mem=45.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:42,620-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:42,849-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:42,849-0500 INFO ThrottleManager mem=45.11 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:21:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 45.11 MB
+2013-08-09 14:21:43,120-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:43,349-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:43,350-0500 INFO ThrottleManager mem=45.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:43,620-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:43,850-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:43,850-0500 INFO ThrottleManager mem=45.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:44,120-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:44,350-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:44,350-0500 INFO ThrottleManager mem=45.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:44,621-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:44,850-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:44,850-0500 INFO ThrottleManager mem=45.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:44,850-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:21:45,121-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:45,121-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:21:45,351-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:45,351-0500 INFO ThrottleManager mem=45.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:45,621-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:45,851-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:45,851-0500 INFO ThrottleManager mem=45.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:46,121-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:46,351-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:46,351-0500 INFO ThrottleManager mem=45.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:46,622-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:46,752-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:21:46,851-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:46,852-0500 INFO ThrottleManager mem=45.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:47,122-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:47,352-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:47,352-0500 INFO ThrottleManager mem=45.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:47,558-0500 INFO Multiplexer No streams
+2013-08-09 14:21:47,622-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:47,852-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:47,852-0500 INFO ThrottleManager mem=45.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:48,122-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:48,352-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:48,352-0500 INFO ThrottleManager mem=45.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:48,622-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:48,853-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:48,853-0500 INFO ThrottleManager mem=45.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:49,123-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:49,353-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:49,353-0500 INFO ThrottleManager mem=45.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:49,623-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:49,853-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:49,853-0500 INFO ThrottleManager mem=45.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:50,123-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:50,353-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:50,354-0500 INFO ThrottleManager mem=45.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:50,623-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:50,854-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:50,854-0500 INFO ThrottleManager mem=45.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:51,124-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:51,354-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:51,354-0500 INFO ThrottleManager mem=45.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:51,624-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:51,854-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:51,854-0500 INFO ThrottleManager mem=45.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:52,124-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:52,355-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:52,355-0500 INFO ThrottleManager mem=45.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:52,624-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:52,855-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:52,855-0500 INFO ThrottleManager mem=45.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:21:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 45.37 MB
+2013-08-09 14:21:53,125-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:53,355-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:53,356-0500 INFO ThrottleManager mem=45.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:53,625-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:53,856-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:53,856-0500 INFO ThrottleManager mem=45.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:54,125-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:54,356-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:54,356-0500 INFO ThrottleManager mem=45.41 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:54,625-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:54,856-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:54,857-0500 INFO ThrottleManager mem=45.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:54,857-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:21:55,125-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:55,126-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:21:55,357-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:55,357-0500 INFO ThrottleManager mem=45.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:55,626-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:55,857-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:55,857-0500 INFO ThrottleManager mem=45.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:56,126-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:56,357-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:56,357-0500 INFO ThrottleManager mem=45.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:56,626-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:56,753-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:21:56,858-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:56,858-0500 INFO ThrottleManager mem=45.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:57,126-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:57,358-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:57,358-0500 INFO ThrottleManager mem=45.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:57,563-0500 INFO Multiplexer No streams
+2013-08-09 14:21:57,627-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:57,858-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:57,858-0500 INFO ThrottleManager mem=45.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:58,127-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:58,359-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:58,359-0500 INFO ThrottleManager mem=45.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:58,627-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:58,859-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:58,859-0500 INFO ThrottleManager mem=45.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:59,127-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:59,359-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:59,359-0500 INFO ThrottleManager mem=45.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:21:59,628-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:59,859-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:21:59,860-0500 INFO ThrottleManager mem=45.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:00,128-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:00,360-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:00,360-0500 INFO ThrottleManager mem=45.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:00,628-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:00,860-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:00,860-0500 INFO ThrottleManager mem=45.57 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:01,128-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:01,360-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:01,360-0500 INFO ThrottleManager mem=45.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:01,629-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:01,860-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:01,861-0500 INFO ThrottleManager mem=45.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:02,129-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:02,361-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:02,361-0500 INFO ThrottleManager mem=45.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:02,629-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:02,861-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:02,861-0500 INFO ThrottleManager mem=45.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:22:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 45.63 MB
+2013-08-09 14:22:03,129-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:03,361-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:03,361-0500 INFO ThrottleManager mem=45.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:03,629-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:03,862-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:03,862-0500 INFO ThrottleManager mem=45.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:04,130-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:04,362-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:04,362-0500 INFO ThrottleManager mem=45.67 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:04,630-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:04,862-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:04,862-0500 INFO ThrottleManager mem=45.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:04,863-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:22:05,130-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:05,130-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:22:05,363-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:05,363-0500 INFO ThrottleManager mem=45.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:05,630-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:05,863-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:05,863-0500 INFO ThrottleManager mem=45.71 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:06,131-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:06,363-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:06,363-0500 INFO ThrottleManager mem=45.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:06,631-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:06,753-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:22:06,864-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:06,864-0500 INFO ThrottleManager mem=45.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:07,131-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:07,364-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:07,364-0500 INFO ThrottleManager mem=45.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:07,568-0500 INFO Multiplexer No streams
+2013-08-09 14:22:07,631-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:07,864-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:07,864-0500 INFO ThrottleManager mem=45.76 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:08,131-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:08,364-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:08,364-0500 INFO ThrottleManager mem=45.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:08,632-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:08,865-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:08,865-0500 INFO ThrottleManager mem=45.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:09,132-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:09,365-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:09,365-0500 INFO ThrottleManager mem=45.8 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:09,632-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:09,865-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:09,865-0500 INFO ThrottleManager mem=45.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:10,132-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:10,365-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:10,366-0500 INFO ThrottleManager mem=45.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:10,633-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:10,866-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:10,866-0500 INFO ThrottleManager mem=45.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:11,133-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:11,366-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:11,366-0500 INFO ThrottleManager mem=45.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:11,633-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:11,867-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:11,867-0500 INFO ThrottleManager mem=45.86 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:12,133-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:12,367-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:12,367-0500 INFO ThrottleManager mem=45.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:12,633-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:12,867-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:12,867-0500 INFO ThrottleManager mem=45.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:22:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 45.89 MB
+2013-08-09 14:22:13,134-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:13,367-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:13,367-0500 INFO ThrottleManager mem=45.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:13,634-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:13,868-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:13,868-0500 INFO ThrottleManager mem=45.91 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:14,134-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:14,368-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:14,368-0500 INFO ThrottleManager mem=45.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:14,634-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:14,868-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:14,868-0500 INFO ThrottleManager mem=45.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:14,868-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:22:15,135-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:15,135-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:22:15,369-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:15,369-0500 INFO ThrottleManager mem=45.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:15,635-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:15,869-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:15,869-0500 INFO ThrottleManager mem=45.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:16,135-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:16,369-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:16,369-0500 INFO ThrottleManager mem=45.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:16,635-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:16,753-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:22:16,869-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:16,870-0500 INFO ThrottleManager mem=45.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:17,136-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:17,370-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:17,370-0500 INFO ThrottleManager mem=46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:17,575-0500 INFO Multiplexer No streams
+2013-08-09 14:22:17,636-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:17,870-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:17,870-0500 INFO ThrottleManager mem=46.02 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:18,136-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:18,370-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:18,370-0500 INFO ThrottleManager mem=46.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:18,636-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:18,871-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:18,871-0500 INFO ThrottleManager mem=46.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:19,136-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:19,371-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:19,371-0500 INFO ThrottleManager mem=46.05 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:19,637-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:19,871-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:19,871-0500 INFO ThrottleManager mem=46.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:20,137-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:20,371-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:20,372-0500 INFO ThrottleManager mem=46.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:20,637-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:20,872-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:20,872-0500 INFO ThrottleManager mem=46.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:21,137-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:21,372-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:21,372-0500 INFO ThrottleManager mem=46.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:21,638-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:21,872-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:21,872-0500 INFO ThrottleManager mem=46.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:22,138-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:22,373-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:22,373-0500 INFO ThrottleManager mem=46.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:22,638-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:22,873-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:22,873-0500 INFO ThrottleManager mem=46.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:22:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 46.15 MB
+2013-08-09 14:22:23,138-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:23,373-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:23,374-0500 INFO ThrottleManager mem=46.16 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:23,638-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:23,874-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:23,874-0500 INFO ThrottleManager mem=46.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:24,139-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:24,374-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:24,374-0500 INFO ThrottleManager mem=46.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:24,639-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:24,874-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:24,874-0500 INFO ThrottleManager mem=46.19 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:24,874-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:22:25,139-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:25,139-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:22:25,375-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:25,375-0500 INFO ThrottleManager mem=46.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:25,639-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:25,875-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:25,875-0500 INFO ThrottleManager mem=46.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:26,140-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:26,375-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:26,375-0500 INFO ThrottleManager mem=46.24 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:26,640-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:26,753-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:22:26,875-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:26,875-0500 INFO ThrottleManager mem=46.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:27,140-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:27,376-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:27,376-0500 INFO ThrottleManager mem=46.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:27,579-0500 INFO Multiplexer No streams
+2013-08-09 14:22:27,640-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:27,876-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:27,876-0500 INFO ThrottleManager mem=46.28 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:28,141-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:28,376-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:28,376-0500 INFO ThrottleManager mem=46.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:28,641-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:28,877-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:28,877-0500 INFO ThrottleManager mem=46.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:29,141-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:29,377-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:29,377-0500 INFO ThrottleManager mem=46.31 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:29,641-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:29,877-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:29,877-0500 INFO ThrottleManager mem=46.33 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:30,142-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:30,377-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:30,378-0500 INFO ThrottleManager mem=46.34 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:30,642-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:30,878-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:30,878-0500 INFO ThrottleManager mem=46.35 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:31,142-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:31,378-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:31,378-0500 INFO ThrottleManager mem=46.36 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:31,642-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:31,878-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:31,878-0500 INFO ThrottleManager mem=46.38 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:32,142-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:32,379-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:32,379-0500 INFO ThrottleManager mem=46.39 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:32,643-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:32,879-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:32,879-0500 INFO ThrottleManager mem=46.4 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:32,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:22:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 46.41 MB
+2013-08-09 14:22:33,143-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:33,379-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:33,379-0500 INFO ThrottleManager mem=46.42 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:33,643-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:33,879-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:33,880-0500 INFO ThrottleManager mem=46.43 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:34,143-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:34,380-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:34,380-0500 INFO ThrottleManager mem=46.45 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:34,643-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:34,880-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:34,880-0500 INFO ThrottleManager mem=46.46 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:34,880-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:22:35,144-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:35,144-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:22:35,380-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:35,380-0500 INFO ThrottleManager mem=46.47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:35,644-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:35,880-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:35,880-0500 INFO ThrottleManager mem=46.49 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:36,144-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:36,381-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:36,381-0500 INFO ThrottleManager mem=46.5 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:36,645-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:36,754-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:22:36,881-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:36,881-0500 INFO ThrottleManager mem=46.51 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:37,145-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:37,381-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:37,381-0500 INFO ThrottleManager mem=46.52 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:37,587-0500 INFO Multiplexer No streams
+2013-08-09 14:22:37,645-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:37,881-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:37,882-0500 INFO ThrottleManager mem=46.54 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:38,145-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:38,382-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:38,382-0500 INFO ThrottleManager mem=46.55 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:38,646-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:38,882-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:38,882-0500 INFO ThrottleManager mem=46.56 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:39,146-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:39,382-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:39,382-0500 INFO ThrottleManager mem=46.58 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:39,646-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:39,883-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:39,883-0500 INFO ThrottleManager mem=46.59 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:40,146-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:40,383-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:40,383-0500 INFO ThrottleManager mem=46.6 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:40,646-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:40,883-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:40,883-0500 INFO ThrottleManager mem=46.61 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:41,147-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:41,383-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:41,383-0500 INFO ThrottleManager mem=46.62 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:41,647-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:41,884-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:41,884-0500 INFO ThrottleManager mem=46.64 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:42,147-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:42,384-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:42,384-0500 INFO ThrottleManager mem=46.65 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:42,648-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:42,884-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:42,884-0500 INFO ThrottleManager mem=46.66 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:22:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 46.67 MB
+2013-08-09 14:22:43,148-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:43,385-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:43,385-0500 INFO ThrottleManager mem=46.68 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:43,648-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:43,885-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:43,885-0500 INFO ThrottleManager mem=46.69 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:44,148-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:44,385-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:44,385-0500 INFO ThrottleManager mem=46.7 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:44,648-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:44,885-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:44,886-0500 INFO ThrottleManager mem=46.72 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:44,886-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:22:45,149-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:45,149-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:22:45,386-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:45,386-0500 INFO ThrottleManager mem=46.73 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:45,649-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:45,886-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:45,886-0500 INFO ThrottleManager mem=46.74 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:46,149-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:46,386-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:46,386-0500 INFO ThrottleManager mem=46.75 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:46,649-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:46,754-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:22:46,887-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:46,887-0500 INFO ThrottleManager mem=46.77 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:47,150-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:47,387-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:47,387-0500 INFO ThrottleManager mem=46.78 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:47,593-0500 INFO Multiplexer No streams
+2013-08-09 14:22:47,650-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:47,887-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:47,887-0500 INFO ThrottleManager mem=46.79 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:48,150-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:48,387-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:48,387-0500 INFO ThrottleManager mem=46.81 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:48,650-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:48,888-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:48,888-0500 INFO ThrottleManager mem=46.82 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:49,151-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:49,388-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:49,388-0500 INFO ThrottleManager mem=46.83 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:49,651-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:49,888-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:49,888-0500 INFO ThrottleManager mem=46.84 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:50,151-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:50,388-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:50,389-0500 INFO ThrottleManager mem=46.85 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:50,651-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:50,889-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:50,889-0500 INFO ThrottleManager mem=46.87 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:51,152-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:51,389-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:51,389-0500 INFO ThrottleManager mem=46.88 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:51,652-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:51,889-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:51,889-0500 INFO ThrottleManager mem=46.89 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:52,152-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:52,390-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:52,390-0500 INFO ThrottleManager mem=46.9 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:52,652-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:52,890-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:52,890-0500 INFO ThrottleManager mem=46.92 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:22:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 46.92 MB
+2013-08-09 14:22:53,153-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:53,390-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:53,390-0500 INFO ThrottleManager mem=46.94 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:53,653-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:53,890-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:53,891-0500 INFO ThrottleManager mem=46.95 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:54,153-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:54,391-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:54,391-0500 INFO ThrottleManager mem=46.96 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:54,654-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:54,891-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:54,891-0500 INFO ThrottleManager mem=46.97 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:54,891-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:22:55,154-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:55,154-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:22:55,391-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:55,391-0500 INFO ThrottleManager mem=46.99 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:55,654-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:55,892-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:55,892-0500 INFO ThrottleManager mem=47 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:56,154-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:56,392-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:56,392-0500 INFO ThrottleManager mem=47.01 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:56,655-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:56,754-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:22:56,892-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:56,892-0500 INFO ThrottleManager mem=47.03 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:57,155-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:57,393-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:57,393-0500 INFO ThrottleManager mem=47.04 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:57,599-0500 INFO Multiplexer No streams
+2013-08-09 14:22:57,655-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:57,893-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:57,893-0500 INFO ThrottleManager mem=47.06 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:58,155-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:58,393-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:58,393-0500 INFO ThrottleManager mem=47.07 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:58,656-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:58,893-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:58,893-0500 INFO ThrottleManager mem=47.08 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:59,156-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:59,394-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:59,394-0500 INFO ThrottleManager mem=47.09 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:22:59,656-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:59,894-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:22:59,894-0500 INFO ThrottleManager mem=47.1 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:00,156-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:00,394-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:00,394-0500 INFO ThrottleManager mem=47.12 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:00,657-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:00,895-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:00,895-0500 INFO ThrottleManager mem=47.13 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:01,157-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:01,395-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:01,395-0500 INFO ThrottleManager mem=47.14 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:01,657-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:01,895-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:01,895-0500 INFO ThrottleManager mem=47.15 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:02,158-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:02,395-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:02,396-0500 INFO ThrottleManager mem=47.17 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:02,658-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:02,896-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:02,896-0500 INFO ThrottleManager mem=47.18 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:23:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.56 MB, Heap used: 47.19 MB
+2013-08-09 14:23:03,158-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:03,396-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:03,396-0500 INFO ThrottleManager mem=47.2 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:03,658-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:03,896-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:03,896-0500 INFO ThrottleManager mem=47.21 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:04,158-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:04,397-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:04,397-0500 INFO ThrottleManager mem=47.22 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:04,659-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:04,897-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:04,897-0500 INFO ThrottleManager mem=47.23 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:04,897-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:23:05,159-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:05,159-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:23:05,397-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:05,397-0500 INFO ThrottleManager mem=47.25 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:05,659-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:05,897-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:05,897-0500 INFO ThrottleManager mem=47.26 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:06,160-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:06,398-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:06,398-0500 INFO ThrottleManager mem=47.27 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:06,660-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:06,754-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:23:06,898-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:06,898-0500 INFO ThrottleManager mem=47.29 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:07,160-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:07,398-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:07,401-0500 INFO ThrottleManager mem=47.3 MB, heap=550.56 MB, maxHeap=10.5 GB
+2013-08-09 14:23:07,602-0500 INFO Multiplexer No streams
+2013-08-09 14:23:07,660-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:07,901-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:07,901-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:08,161-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:08,402-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:08,402-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:08,661-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:08,902-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:08,902-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:09,161-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:09,402-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:09,402-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:09,661-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:09,902-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:09,903-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:10,162-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:10,403-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:10,403-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:10,662-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:10,903-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:10,903-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:11,162-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:11,403-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:11,403-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:11,663-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:11,904-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:11,904-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:12,163-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:12,404-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:12,404-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:12,663-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:12,904-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:12,904-0500 INFO ThrottleManager mem=1.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:23:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 1.21 MB
+2013-08-09 14:23:13,163-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:13,404-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:13,405-0500 INFO ThrottleManager mem=1.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:13,664-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:13,905-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:13,905-0500 INFO ThrottleManager mem=1.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:14,164-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:14,405-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:14,405-0500 INFO ThrottleManager mem=1.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:14,664-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:14,905-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:14,905-0500 INFO ThrottleManager mem=1.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:14,906-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:23:15,164-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:15,164-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:23:15,406-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:15,406-0500 INFO ThrottleManager mem=1.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:15,665-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:15,906-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:15,906-0500 INFO ThrottleManager mem=1.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:16,165-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:16,406-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:16,406-0500 INFO ThrottleManager mem=1.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:16,665-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:16,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:23:16,906-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:16,907-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:17,165-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:17,407-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:17,407-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:17,608-0500 INFO Multiplexer No streams
+2013-08-09 14:23:17,665-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:17,907-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:17,907-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:18,166-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:18,407-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:18,407-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:18,666-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:18,907-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:18,908-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:19,166-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:19,408-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:19,408-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:19,666-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:19,908-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:19,908-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:20,167-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:20,408-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:20,408-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:20,667-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:20,909-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:20,909-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:21,167-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:21,409-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:21,409-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:21,667-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:21,909-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:21,909-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:22,168-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:22,409-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:22,410-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:22,668-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:22,910-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:22,910-0500 INFO ThrottleManager mem=1.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:23:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 1.41 MB
+2013-08-09 14:23:23,168-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:23,410-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:23,410-0500 INFO ThrottleManager mem=1.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:23,669-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:23,910-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:23,910-0500 INFO ThrottleManager mem=1.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:24,169-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:24,410-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:24,410-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:24,669-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:24,911-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:24,911-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:24,911-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:23:25,169-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:25,169-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:23:25,411-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:25,411-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:25,670-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:25,911-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:25,911-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:26,170-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:26,411-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:26,412-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:26,670-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:26,754-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:23:26,912-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:26,912-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:27,170-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:27,412-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:27,412-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:27,615-0500 INFO Multiplexer No streams
+2013-08-09 14:23:27,670-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:27,912-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:27,912-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:28,171-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:28,413-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:28,413-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:28,671-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:28,913-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:28,913-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:29,171-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:29,413-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:29,413-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:29,671-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:29,913-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:29,914-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:30,172-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:30,414-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:30,414-0500 INFO ThrottleManager mem=1.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:30,672-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:30,914-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:30,914-0500 INFO ThrottleManager mem=1.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:31,172-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:31,414-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:31,414-0500 INFO ThrottleManager mem=1.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:31,672-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:31,915-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:31,915-0500 INFO ThrottleManager mem=1.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:32,173-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:32,415-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:32,415-0500 INFO ThrottleManager mem=1.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:32,673-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:32,915-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:32,915-0500 INFO ThrottleManager mem=1.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:23:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 1.82 MB
+2013-08-09 14:23:33,173-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:33,415-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:33,416-0500 INFO ThrottleManager mem=1.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:33,673-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:33,916-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:33,916-0500 INFO ThrottleManager mem=1.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:34,174-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:34,416-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:34,416-0500 INFO ThrottleManager mem=1.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:34,674-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:34,916-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:34,916-0500 INFO ThrottleManager mem=1.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:34,916-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:23:35,174-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:35,174-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:23:35,417-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:35,417-0500 INFO ThrottleManager mem=1.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:35,674-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:35,917-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:35,917-0500 INFO ThrottleManager mem=1.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:36,175-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:36,417-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:36,417-0500 INFO ThrottleManager mem=1.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:36,675-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:36,754-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:23:36,918-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:36,918-0500 INFO ThrottleManager mem=1.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:37,175-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:37,418-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:37,418-0500 INFO ThrottleManager mem=1.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:37,622-0500 INFO Multiplexer No streams
+2013-08-09 14:23:37,675-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:37,918-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:37,918-0500 INFO ThrottleManager mem=1.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:38,176-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:38,418-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:38,418-0500 INFO ThrottleManager mem=1.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:38,676-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:38,919-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:38,919-0500 INFO ThrottleManager mem=1.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:39,176-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:39,419-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:39,419-0500 INFO ThrottleManager mem=1.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:39,676-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:39,919-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:39,919-0500 INFO ThrottleManager mem=1.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:40,177-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:40,419-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:40,419-0500 INFO ThrottleManager mem=1.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:40,677-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:40,920-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:40,920-0500 INFO ThrottleManager mem=1.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:41,177-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:41,420-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:41,420-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:41,678-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:41,920-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:41,920-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:42,178-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:42,420-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:42,421-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:42,678-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:42,921-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:42,921-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:23:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 2.03 MB
+2013-08-09 14:23:43,178-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:43,421-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:43,421-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:43,679-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:43,921-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:43,921-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:44,179-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:44,422-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:44,422-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:44,679-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:44,922-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:44,922-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:44,922-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:23:45,179-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:45,179-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:23:45,422-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:45,422-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:45,680-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:45,922-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:45,923-0500 INFO ThrottleManager mem=2.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:46,180-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:46,423-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:46,423-0500 INFO ThrottleManager mem=2.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:46,680-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:46,754-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:23:46,923-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:46,923-0500 INFO ThrottleManager mem=2.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:47,180-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:47,423-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:47,423-0500 INFO ThrottleManager mem=2.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:47,629-0500 INFO Multiplexer No streams
+2013-08-09 14:23:47,680-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:47,923-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:47,923-0500 INFO ThrottleManager mem=2.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:48,181-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:48,424-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:48,424-0500 INFO ThrottleManager mem=2.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:48,681-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:48,924-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:48,924-0500 INFO ThrottleManager mem=2.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:49,181-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:49,424-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:49,424-0500 INFO ThrottleManager mem=2.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:49,681-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:49,924-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:49,925-0500 INFO ThrottleManager mem=2.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:50,182-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:50,425-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:50,425-0500 INFO ThrottleManager mem=2.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:50,682-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:50,925-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:50,925-0500 INFO ThrottleManager mem=2.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:51,182-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:51,425-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:51,425-0500 INFO ThrottleManager mem=2.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:51,682-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:51,926-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:51,926-0500 INFO ThrottleManager mem=2.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:52,183-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:52,426-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:52,426-0500 INFO ThrottleManager mem=2.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:52,683-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:52,926-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:52,926-0500 INFO ThrottleManager mem=2.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:23:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 2.24 MB
+2013-08-09 14:23:53,183-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:53,426-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:53,427-0500 INFO ThrottleManager mem=2.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:53,683-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:53,927-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:53,927-0500 INFO ThrottleManager mem=2.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:54,184-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:54,427-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:54,427-0500 INFO ThrottleManager mem=2.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:54,684-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:54,927-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:54,927-0500 INFO ThrottleManager mem=2.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:54,927-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:23:55,184-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:55,184-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:23:55,428-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:55,428-0500 INFO ThrottleManager mem=2.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:55,684-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:55,928-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:55,928-0500 INFO ThrottleManager mem=2.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:56,185-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:56,428-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:56,428-0500 INFO ThrottleManager mem=2.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:56,685-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:56,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:23:56,929-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:56,929-0500 INFO ThrottleManager mem=2.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:57,185-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:57,429-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:57,429-0500 INFO ThrottleManager mem=2.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:57,634-0500 INFO Multiplexer No streams
+2013-08-09 14:23:57,685-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:57,929-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:57,929-0500 INFO ThrottleManager mem=2.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:58,186-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:58,429-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:58,430-0500 INFO ThrottleManager mem=2.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:58,686-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:58,930-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:58,930-0500 INFO ThrottleManager mem=2.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:59,186-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:59,430-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:59,430-0500 INFO ThrottleManager mem=2.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:23:59,686-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:59,930-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:23:59,930-0500 INFO ThrottleManager mem=2.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:00,187-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:00,431-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:00,431-0500 INFO ThrottleManager mem=2.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:00,687-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:00,931-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:00,931-0500 INFO ThrottleManager mem=2.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:01,187-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:01,431-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:01,431-0500 INFO ThrottleManager mem=2.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:01,687-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:01,931-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:01,932-0500 INFO ThrottleManager mem=2.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:02,187-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:02,432-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:02,432-0500 INFO ThrottleManager mem=2.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:02,688-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:02,932-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:02,932-0500 INFO ThrottleManager mem=2.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:24:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 2.48 MB
+2013-08-09 14:24:03,188-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:03,432-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:03,432-0500 INFO ThrottleManager mem=2.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:03,688-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:03,933-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:03,933-0500 INFO ThrottleManager mem=2.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:04,188-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:04,433-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:04,433-0500 INFO ThrottleManager mem=2.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:04,689-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:04,933-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:04,933-0500 INFO ThrottleManager mem=2.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:04,933-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:24:05,189-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:05,189-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:24:05,433-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:05,434-0500 INFO ThrottleManager mem=2.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:05,689-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:05,934-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:05,934-0500 INFO ThrottleManager mem=2.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:06,190-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:06,434-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:06,434-0500 INFO ThrottleManager mem=2.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:06,690-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:06,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:24:06,934-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:06,934-0500 INFO ThrottleManager mem=2.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:07,190-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:07,435-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:07,435-0500 INFO ThrottleManager mem=2.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:07,639-0500 INFO Multiplexer No streams
+2013-08-09 14:24:07,690-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:07,935-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:07,935-0500 INFO ThrottleManager mem=2.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:08,191-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:08,435-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:08,435-0500 INFO ThrottleManager mem=2.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:08,691-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:08,935-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:08,936-0500 INFO ThrottleManager mem=2.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:09,191-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:09,436-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:09,436-0500 INFO ThrottleManager mem=2.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:09,691-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:09,936-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:09,936-0500 INFO ThrottleManager mem=2.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:10,192-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:10,436-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:10,436-0500 INFO ThrottleManager mem=2.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:10,692-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:10,936-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:10,936-0500 INFO ThrottleManager mem=2.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:11,192-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:11,437-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:11,437-0500 INFO ThrottleManager mem=2.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:11,692-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:11,937-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:11,937-0500 INFO ThrottleManager mem=2.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:12,193-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:12,437-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:12,437-0500 INFO ThrottleManager mem=2.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:12,693-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:12,937-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:12,938-0500 INFO ThrottleManager mem=2.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:24:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 2.77 MB
+2013-08-09 14:24:13,193-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:13,438-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:13,438-0500 INFO ThrottleManager mem=2.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:13,693-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:13,938-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:13,938-0500 INFO ThrottleManager mem=2.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:14,194-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:14,438-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:14,438-0500 INFO ThrottleManager mem=2.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:14,694-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:14,939-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:14,939-0500 INFO ThrottleManager mem=2.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:14,939-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:24:15,194-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:15,194-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:24:15,439-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:15,439-0500 INFO ThrottleManager mem=2.86 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:15,694-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:15,939-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:15,939-0500 INFO ThrottleManager mem=2.86 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:16,195-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:16,440-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:16,440-0500 INFO ThrottleManager mem=2.86 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:16,695-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:16,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:24:16,940-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:16,940-0500 INFO ThrottleManager mem=2.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:17,195-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:17,440-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:17,440-0500 INFO ThrottleManager mem=2.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:17,644-0500 INFO Multiplexer No streams
+2013-08-09 14:24:17,695-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:17,940-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:17,940-0500 INFO ThrottleManager mem=2.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:18,196-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:18,441-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:18,441-0500 INFO ThrottleManager mem=2.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:18,696-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:18,941-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:18,941-0500 INFO ThrottleManager mem=2.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:19,196-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:19,441-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:19,441-0500 INFO ThrottleManager mem=2.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:19,696-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:19,942-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:19,942-0500 INFO ThrottleManager mem=2.98 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:20,197-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:20,442-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:20,442-0500 INFO ThrottleManager mem=2.98 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:20,697-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:20,942-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:20,942-0500 INFO ThrottleManager mem=2.98 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:21,197-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:21,442-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:21,442-0500 INFO ThrottleManager mem=2.98 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:21,697-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:21,943-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:21,943-0500 INFO ThrottleManager mem=2.98 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:22,198-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:22,443-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:22,443-0500 INFO ThrottleManager mem=2.98 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:22,698-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:22,943-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:22,943-0500 INFO ThrottleManager mem=2.98 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:22,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:24:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 2.98 MB
+2013-08-09 14:24:23,198-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:23,444-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:23,444-0500 INFO ThrottleManager mem=3.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:23,698-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:23,944-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:23,944-0500 INFO ThrottleManager mem=3.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:24,199-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:24,444-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:24,444-0500 INFO ThrottleManager mem=3.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:24,699-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:24,944-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:24,944-0500 INFO ThrottleManager mem=3.09 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:24,944-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:24:25,199-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:25,199-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:24:25,445-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:25,445-0500 INFO ThrottleManager mem=3.09 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:25,699-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:25,945-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:25,945-0500 INFO ThrottleManager mem=3.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:26,200-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:26,445-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:26,445-0500 INFO ThrottleManager mem=3.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:26,700-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:26,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:24:26,945-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:26,946-0500 INFO ThrottleManager mem=3.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:27,200-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:27,446-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:27,446-0500 INFO ThrottleManager mem=3.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:27,649-0500 INFO Multiplexer No streams
+2013-08-09 14:24:27,700-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:27,946-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:27,946-0500 INFO ThrottleManager mem=3.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:28,201-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:28,446-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:28,446-0500 INFO ThrottleManager mem=3.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:28,701-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:28,947-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:28,947-0500 INFO ThrottleManager mem=3.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:29,201-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:29,447-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:29,447-0500 INFO ThrottleManager mem=3.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:29,701-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:29,947-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:29,947-0500 INFO ThrottleManager mem=3.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:30,202-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:30,448-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:30,448-0500 INFO ThrottleManager mem=3.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:30,702-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:30,948-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:30,948-0500 INFO ThrottleManager mem=3.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:31,202-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:31,448-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:31,448-0500 INFO ThrottleManager mem=3.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:31,702-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:31,948-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:31,949-0500 INFO ThrottleManager mem=3.22 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:32,203-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:32,449-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:32,449-0500 INFO ThrottleManager mem=3.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:32,703-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:32,949-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:32,949-0500 INFO ThrottleManager mem=3.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:24:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 3.31 MB
+2013-08-09 14:24:33,203-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:33,449-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:33,449-0500 INFO ThrottleManager mem=3.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:33,703-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:33,949-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:33,949-0500 INFO ThrottleManager mem=3.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:34,204-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:34,450-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:34,450-0500 INFO ThrottleManager mem=3.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:34,704-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:34,950-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:34,950-0500 INFO ThrottleManager mem=3.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:34,950-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:24:35,204-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:35,204-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:24:35,450-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:35,450-0500 INFO ThrottleManager mem=3.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:35,705-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:35,951-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:35,951-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:36,205-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:36,451-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:36,451-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:36,705-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:36,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:24:36,951-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:36,951-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:37,205-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:37,451-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:37,451-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:37,656-0500 INFO Multiplexer No streams
+2013-08-09 14:24:37,706-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:37,952-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:37,952-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:38,206-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:38,452-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:38,452-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:38,706-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:38,952-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:38,952-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:39,206-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:39,452-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:39,453-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:39,707-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:39,953-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:39,953-0500 INFO ThrottleManager mem=3.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:40,207-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:40,453-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:40,453-0500 INFO ThrottleManager mem=3.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:40,707-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:40,953-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:40,953-0500 INFO ThrottleManager mem=3.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:41,208-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:41,454-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:41,454-0500 INFO ThrottleManager mem=3.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:41,708-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:41,954-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:41,954-0500 INFO ThrottleManager mem=3.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:42,208-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:42,454-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:42,454-0500 INFO ThrottleManager mem=3.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:42,708-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:42,954-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:42,955-0500 INFO ThrottleManager mem=3.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:24:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 3.51 MB
+2013-08-09 14:24:43,209-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:43,455-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:43,455-0500 INFO ThrottleManager mem=3.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:43,709-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:43,955-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:43,955-0500 INFO ThrottleManager mem=3.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:44,209-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:44,455-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:44,455-0500 INFO ThrottleManager mem=3.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:44,709-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:44,956-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:44,956-0500 INFO ThrottleManager mem=3.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:44,956-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:24:45,210-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:45,210-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:24:45,456-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:45,456-0500 INFO ThrottleManager mem=3.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:45,710-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:45,956-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:45,956-0500 INFO ThrottleManager mem=3.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:46,210-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:46,457-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:46,457-0500 INFO ThrottleManager mem=3.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:46,710-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:46,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:24:46,957-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:46,957-0500 INFO ThrottleManager mem=3.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:47,211-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:47,457-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:47,457-0500 INFO ThrottleManager mem=3.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:47,663-0500 INFO Multiplexer No streams
+2013-08-09 14:24:47,711-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:47,957-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:47,957-0500 INFO ThrottleManager mem=3.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:48,211-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:48,458-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:48,458-0500 INFO ThrottleManager mem=3.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:48,711-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:48,958-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:48,958-0500 INFO ThrottleManager mem=3.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:49,212-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:49,458-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:49,458-0500 INFO ThrottleManager mem=3.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:49,712-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:49,958-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:49,959-0500 INFO ThrottleManager mem=3.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:50,212-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:50,459-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:50,459-0500 INFO ThrottleManager mem=3.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:50,712-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:50,959-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:50,959-0500 INFO ThrottleManager mem=3.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:51,213-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:51,459-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:51,459-0500 INFO ThrottleManager mem=3.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:51,713-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:51,960-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:51,960-0500 INFO ThrottleManager mem=3.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:52,213-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:52,460-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:52,460-0500 INFO ThrottleManager mem=3.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:52,713-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:24:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 3.81 MB
+2013-08-09 14:24:52,960-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:52,960-0500 INFO ThrottleManager mem=3.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:53,214-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:53,460-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:53,461-0500 INFO ThrottleManager mem=3.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:53,714-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:53,961-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:53,961-0500 INFO ThrottleManager mem=3.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:54,214-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:54,461-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:54,461-0500 INFO ThrottleManager mem=3.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:54,715-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:54,961-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:54,961-0500 INFO ThrottleManager mem=3.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:54,961-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:24:55,215-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:55,215-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:24:55,461-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:55,462-0500 INFO ThrottleManager mem=3.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:55,715-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:55,962-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:55,962-0500 INFO ThrottleManager mem=3.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:56,215-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:56,462-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:56,462-0500 INFO ThrottleManager mem=3.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:56,716-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:56,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:24:56,962-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:56,962-0500 INFO ThrottleManager mem=3.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:57,216-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:57,463-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:57,463-0500 INFO ThrottleManager mem=3.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:57,670-0500 INFO Multiplexer No streams
+2013-08-09 14:24:57,716-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:57,963-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:57,963-0500 INFO ThrottleManager mem=3.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:58,216-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:58,463-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:58,463-0500 INFO ThrottleManager mem=3.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:58,717-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:58,963-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:58,964-0500 INFO ThrottleManager mem=3.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:59,217-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:59,464-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:59,464-0500 INFO ThrottleManager mem=3.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:24:59,717-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:59,964-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:24:59,964-0500 INFO ThrottleManager mem=3.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:00,217-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:00,464-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:00,464-0500 INFO ThrottleManager mem=4.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:00,718-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:00,965-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:00,965-0500 INFO ThrottleManager mem=4.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:01,218-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:01,465-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:01,465-0500 INFO ThrottleManager mem=4.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:01,718-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:01,965-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:01,965-0500 INFO ThrottleManager mem=4.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:02,218-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:02,465-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:02,465-0500 INFO ThrottleManager mem=4.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:02,719-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:25:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 4.01 MB
+2013-08-09 14:25:02,966-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:02,966-0500 INFO ThrottleManager mem=4.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:03,219-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:03,466-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:03,466-0500 INFO ThrottleManager mem=4.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:03,719-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:03,966-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:03,966-0500 INFO ThrottleManager mem=4.05 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:04,219-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:04,467-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:04,467-0500 INFO ThrottleManager mem=4.05 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:04,720-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:04,967-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:04,967-0500 INFO ThrottleManager mem=4.05 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:04,967-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:25:05,220-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:05,220-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:25:05,467-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:05,467-0500 INFO ThrottleManager mem=4.05 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:05,720-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:05,967-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:05,968-0500 INFO ThrottleManager mem=4.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:06,221-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:06,468-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:06,468-0500 INFO ThrottleManager mem=4.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:06,721-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:06,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:25:06,968-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:06,968-0500 INFO ThrottleManager mem=4.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:07,221-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:07,468-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:07,468-0500 INFO ThrottleManager mem=4.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:07,678-0500 INFO Multiplexer No streams
+2013-08-09 14:25:07,721-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:07,969-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:07,969-0500 INFO ThrottleManager mem=4.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:08,222-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:08,469-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:08,469-0500 INFO ThrottleManager mem=4.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:08,722-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:08,969-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:08,969-0500 INFO ThrottleManager mem=4.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:09,222-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:09,469-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:09,470-0500 INFO ThrottleManager mem=4.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:09,722-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:09,970-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:09,970-0500 INFO ThrottleManager mem=4.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:10,223-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:10,470-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:10,470-0500 INFO ThrottleManager mem=4.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:10,723-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:10,970-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:10,970-0500 INFO ThrottleManager mem=4.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:11,223-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:11,471-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:11,471-0500 INFO ThrottleManager mem=4.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:11,724-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:11,971-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:11,971-0500 INFO ThrottleManager mem=4.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:12,224-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:12,471-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:12,471-0500 INFO ThrottleManager mem=4.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:12,724-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:25:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 4.26 MB
+2013-08-09 14:25:12,971-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:12,972-0500 INFO ThrottleManager mem=4.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:13,224-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:13,472-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:13,472-0500 INFO ThrottleManager mem=4.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:13,725-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:13,972-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:13,972-0500 INFO ThrottleManager mem=4.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:14,225-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:14,472-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:14,472-0500 INFO ThrottleManager mem=4.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:14,725-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:14,973-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:14,973-0500 INFO ThrottleManager mem=4.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:14,973-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:25:15,225-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:15,225-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:25:15,473-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:15,473-0500 INFO ThrottleManager mem=4.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:15,726-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:15,973-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:15,973-0500 INFO ThrottleManager mem=4.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:16,226-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:16,474-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:16,474-0500 INFO ThrottleManager mem=4.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:16,726-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:16,755-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:25:16,974-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:16,974-0500 INFO ThrottleManager mem=4.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:17,226-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:17,474-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:17,474-0500 INFO ThrottleManager mem=4.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:17,685-0500 INFO Multiplexer No streams
+2013-08-09 14:25:17,727-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:17,974-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:17,974-0500 INFO ThrottleManager mem=4.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:18,227-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:18,475-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:18,475-0500 INFO ThrottleManager mem=4.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:18,727-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:18,975-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:18,975-0500 INFO ThrottleManager mem=4.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:19,227-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:19,475-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:19,475-0500 INFO ThrottleManager mem=4.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:19,728-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:19,976-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:19,976-0500 INFO ThrottleManager mem=4.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:20,228-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:20,476-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:20,476-0500 INFO ThrottleManager mem=4.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:20,728-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:20,976-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:20,976-0500 INFO ThrottleManager mem=4.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:21,228-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:21,476-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:21,476-0500 INFO ThrottleManager mem=4.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:21,729-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:21,977-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:21,977-0500 INFO ThrottleManager mem=4.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:22,229-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:22,477-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:22,477-0500 INFO ThrottleManager mem=4.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:22,729-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:25:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 4.55 MB
+2013-08-09 14:25:22,977-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:22,977-0500 INFO ThrottleManager mem=4.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:23,230-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:23,477-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:23,477-0500 INFO ThrottleManager mem=4.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:23,730-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:23,978-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:23,978-0500 INFO ThrottleManager mem=4.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:24,230-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:24,478-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:24,478-0500 INFO ThrottleManager mem=4.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:24,730-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:24,978-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:24,978-0500 INFO ThrottleManager mem=4.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:24,978-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:25:25,231-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:25,231-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:25:25,479-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:25,479-0500 INFO ThrottleManager mem=4.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:25,731-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:25,979-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:25,979-0500 INFO ThrottleManager mem=4.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:26,231-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:26,479-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:26,479-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:26,731-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:26,756-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:25:26,980-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:26,980-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:27,232-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:27,480-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:27,480-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:27,691-0500 INFO Multiplexer No streams
+2013-08-09 14:25:27,732-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:27,980-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:27,980-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:28,232-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:28,480-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:28,481-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:28,732-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:28,981-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:28,981-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:29,233-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:29,481-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:29,481-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:29,733-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:29,981-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:29,982-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:30,233-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:30,482-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:30,482-0500 INFO ThrottleManager mem=4.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:30,733-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:30,982-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:30,982-0500 INFO ThrottleManager mem=4.71 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:31,234-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:31,482-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:31,483-0500 INFO ThrottleManager mem=4.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:31,734-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:31,983-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:31,983-0500 INFO ThrottleManager mem=4.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:32,234-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:32,483-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:32,483-0500 INFO ThrottleManager mem=4.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:32,734-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:25:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 4.84 MB
+2013-08-09 14:25:32,983-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:32,984-0500 INFO ThrottleManager mem=4.84 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:33,235-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:33,484-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:33,484-0500 INFO ThrottleManager mem=4.84 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:33,735-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:33,984-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:33,984-0500 INFO ThrottleManager mem=4.84 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:34,235-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:34,484-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:34,485-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:34,735-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:34,985-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:34,985-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:34,985-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:25:35,236-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:35,236-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:25:35,485-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:35,485-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:35,736-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:35,985-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:35,985-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:36,236-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:36,486-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:36,486-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:36,737-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:36,756-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:25:36,986-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:36,986-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:37,237-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:37,486-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:37,486-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:37,698-0500 INFO Multiplexer No streams
+2013-08-09 14:25:37,737-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:37,987-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:37,987-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:38,237-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:38,487-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:38,487-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:38,738-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:38,987-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:38,987-0500 INFO ThrottleManager mem=4.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:39,238-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:39,488-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:39,488-0500 INFO ThrottleManager mem=4.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:39,738-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:39,988-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:39,988-0500 INFO ThrottleManager mem=4.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:40,238-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:40,488-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:40,488-0500 INFO ThrottleManager mem=5.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:40,739-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:40,988-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:40,989-0500 INFO ThrottleManager mem=5.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:41,239-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:41,489-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:41,489-0500 INFO ThrottleManager mem=5.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:41,739-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:41,989-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:41,989-0500 INFO ThrottleManager mem=5.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:42,240-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:42,489-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:42,490-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:42,740-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:25:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 5.08 MB
+2013-08-09 14:25:42,990-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:42,990-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:43,240-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:43,490-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:43,490-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:43,740-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:43,990-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:43,991-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:44,241-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:44,491-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:44,491-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:44,741-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:44,991-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:44,991-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:44,991-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:25:45,241-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:45,241-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:25:45,491-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:45,492-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:45,741-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:45,992-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:45,992-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:46,242-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:46,492-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:46,492-0500 INFO ThrottleManager mem=5.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:46,742-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:46,756-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:25:46,992-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:46,992-0500 INFO ThrottleManager mem=5.09 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:47,242-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:47,493-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:47,493-0500 INFO ThrottleManager mem=5.09 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:47,705-0500 INFO Multiplexer No streams
+2013-08-09 14:25:47,742-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:47,993-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:47,993-0500 INFO ThrottleManager mem=5.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:48,243-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:48,493-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:48,493-0500 INFO ThrottleManager mem=5.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:48,743-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:48,994-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:48,994-0500 INFO ThrottleManager mem=5.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:49,243-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:49,494-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:49,494-0500 INFO ThrottleManager mem=5.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:49,743-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:49,994-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:49,994-0500 INFO ThrottleManager mem=5.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:50,244-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:50,495-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:50,495-0500 INFO ThrottleManager mem=5.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:50,744-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:50,995-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:50,995-0500 INFO ThrottleManager mem=5.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:51,244-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:51,495-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:51,495-0500 INFO ThrottleManager mem=5.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:51,744-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:51,995-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:51,996-0500 INFO ThrottleManager mem=5.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:52,245-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:52,496-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:52,496-0500 INFO ThrottleManager mem=5.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:52,745-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:25:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 5.29 MB
+2013-08-09 14:25:52,996-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:52,996-0500 INFO ThrottleManager mem=5.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:53,245-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:53,496-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:53,497-0500 INFO ThrottleManager mem=5.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:53,746-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:53,997-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:53,997-0500 INFO ThrottleManager mem=5.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:54,246-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:54,497-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:54,497-0500 INFO ThrottleManager mem=5.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:54,746-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:54,997-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:54,998-0500 INFO ThrottleManager mem=5.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:54,998-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:25:55,246-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:55,246-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:25:55,498-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:55,498-0500 INFO ThrottleManager mem=5.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:55,747-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:55,998-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:55,998-0500 INFO ThrottleManager mem=5.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:56,247-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:56,498-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:56,499-0500 INFO ThrottleManager mem=5.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:56,747-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:56,756-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:25:56,999-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:56,999-0500 INFO ThrottleManager mem=5.46 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:57,247-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:57,499-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:57,499-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:57,712-0500 INFO Multiplexer No streams
+2013-08-09 14:25:57,748-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:57,999-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:58,000-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:58,248-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:58,500-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:58,500-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:58,748-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:59,000-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:59,000-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:59,248-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:59,500-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:25:59,500-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:25:59,749-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:00,001-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:00,001-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:00,249-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:00,501-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:00,501-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:00,749-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:01,001-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:01,001-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:01,249-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:01,502-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:01,502-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:01,750-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:02,002-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:02,002-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:02,250-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:02,502-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:02,502-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:02,750-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:26:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 5.5 MB
+2013-08-09 14:26:03,003-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:03,003-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:03,251-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:03,503-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:03,503-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:03,751-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:04,003-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:04,003-0500 INFO ThrottleManager mem=5.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:04,251-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:04,504-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:04,504-0500 INFO ThrottleManager mem=5.58 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:04,751-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:05,004-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:05,004-0500 INFO ThrottleManager mem=5.62 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:05,004-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:26:05,252-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:05,252-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:26:05,504-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:05,504-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:05,752-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:06,004-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:06,005-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:06,253-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:06,505-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:06,505-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:06,753-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:06,757-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:26:07,005-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:07,005-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:07,253-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:07,505-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:07,506-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:07,719-0500 INFO Multiplexer No streams
+2013-08-09 14:26:07,753-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:08,006-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:08,006-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:08,253-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:08,506-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:08,506-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:08,754-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:09,006-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:09,006-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:09,254-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:09,507-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:09,507-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:09,754-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:10,007-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:10,007-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:10,254-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:10,507-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:10,507-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:10,755-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:11,008-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:11,008-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:11,255-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:11,508-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:11,508-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:11,755-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:12,008-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:12,008-0500 INFO ThrottleManager mem=5.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:12,256-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:12,508-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:12,508-0500 INFO ThrottleManager mem=5.78 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:12,756-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:26:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 5.79 MB
+2013-08-09 14:26:13,009-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:13,009-0500 INFO ThrottleManager mem=5.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:13,256-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:13,509-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:13,509-0500 INFO ThrottleManager mem=5.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:13,756-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:14,009-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:14,009-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:14,257-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:14,510-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:14,510-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:14,757-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:15,010-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:15,010-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:15,010-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:26:15,257-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:15,257-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:26:15,510-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:15,510-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:15,757-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:16,011-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:16,011-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:16,258-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:16,511-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:16,511-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:16,757-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:26:16,758-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:17,011-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:17,011-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:17,258-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:17,511-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:17,512-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:17,725-0500 INFO Multiplexer No streams
+2013-08-09 14:26:17,758-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:18,012-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:18,012-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:18,259-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:18,512-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:18,512-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:18,759-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:19,012-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:19,012-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:19,259-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:19,513-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:19,513-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:19,759-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:20,013-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:20,013-0500 INFO ThrottleManager mem=5.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:20,260-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:20,513-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:20,513-0500 INFO ThrottleManager mem=6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:20,760-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:21,014-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:21,014-0500 INFO ThrottleManager mem=6.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:21,260-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:21,514-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:21,514-0500 INFO ThrottleManager mem=6.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:21,760-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:22,014-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:22,014-0500 INFO ThrottleManager mem=6.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:22,261-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:22,515-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:22,515-0500 INFO ThrottleManager mem=6.11 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:22,761-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:26:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 6.12 MB
+2013-08-09 14:26:23,015-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:23,015-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:23,261-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:23,515-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:23,515-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:23,761-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:24,015-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:24,016-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:24,262-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:24,516-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:24,516-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:24,762-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:25,016-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:25,016-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:25,016-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:26:25,262-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:25,262-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:26:25,516-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:25,516-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:25,762-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:26,017-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:26,017-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:26,263-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:26,517-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:26,517-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:26,757-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:26:26,763-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:27,017-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:27,017-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:27,263-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:27,518-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:27,518-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:27,731-0500 INFO Multiplexer No streams
+2013-08-09 14:26:27,763-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:28,018-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:28,018-0500 INFO ThrottleManager mem=6.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:28,264-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:28,518-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:28,518-0500 INFO ThrottleManager mem=6.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:28,764-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:29,018-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:29,018-0500 INFO ThrottleManager mem=6.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:29,264-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:29,519-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:29,519-0500 INFO ThrottleManager mem=6.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:29,764-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:30,019-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:30,019-0500 INFO ThrottleManager mem=6.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:30,265-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:30,519-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:30,519-0500 INFO ThrottleManager mem=6.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:30,765-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:31,020-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:31,020-0500 INFO ThrottleManager mem=6.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:31,265-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:31,520-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:31,520-0500 INFO ThrottleManager mem=6.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:31,765-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:32,020-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:32,020-0500 INFO ThrottleManager mem=6.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:32,266-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:32,521-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:32,521-0500 INFO ThrottleManager mem=6.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:32,766-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:26:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 6.33 MB
+2013-08-09 14:26:33,021-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:33,021-0500 INFO ThrottleManager mem=6.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:33,266-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:33,521-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:33,521-0500 INFO ThrottleManager mem=6.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:33,766-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:34,022-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:34,022-0500 INFO ThrottleManager mem=6.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:34,267-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:34,522-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:34,522-0500 INFO ThrottleManager mem=6.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:34,767-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:35,022-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:35,022-0500 INFO ThrottleManager mem=6.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:35,022-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:26:35,267-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:35,267-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:26:35,522-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:35,523-0500 INFO ThrottleManager mem=6.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:35,768-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:36,023-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:36,023-0500 INFO ThrottleManager mem=6.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:36,268-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:36,523-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:36,523-0500 INFO ThrottleManager mem=6.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:36,757-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:26:36,768-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:37,023-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:37,023-0500 INFO ThrottleManager mem=6.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:37,268-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:37,524-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:37,524-0500 INFO ThrottleManager mem=6.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:37,738-0500 INFO Multiplexer No streams
+2013-08-09 14:26:37,768-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:38,024-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:38,024-0500 INFO ThrottleManager mem=6.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:38,269-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:38,524-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:38,524-0500 INFO ThrottleManager mem=6.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:38,769-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:39,025-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:39,025-0500 INFO ThrottleManager mem=6.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:39,269-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:39,525-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:39,525-0500 INFO ThrottleManager mem=6.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:39,769-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:40,025-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:40,025-0500 INFO ThrottleManager mem=6.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:40,270-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:40,525-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:40,526-0500 INFO ThrottleManager mem=6.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:40,770-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:41,026-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:41,026-0500 INFO ThrottleManager mem=6.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:41,270-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:41,526-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:41,526-0500 INFO ThrottleManager mem=6.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:41,771-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:42,026-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:42,026-0500 INFO ThrottleManager mem=6.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:42,271-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:42,527-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:42,527-0500 INFO ThrottleManager mem=6.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:42,771-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:26:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 6.54 MB
+2013-08-09 14:26:43,027-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:43,027-0500 INFO ThrottleManager mem=6.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:43,271-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:43,527-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:43,527-0500 INFO ThrottleManager mem=6.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:43,771-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:44,028-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:44,028-0500 INFO ThrottleManager mem=6.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:44,272-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:44,528-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:44,528-0500 INFO ThrottleManager mem=6.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:44,772-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:45,028-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:45,028-0500 INFO ThrottleManager mem=6.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:45,028-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:26:45,272-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:45,272-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:26:45,528-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:45,529-0500 INFO ThrottleManager mem=6.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:45,772-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:46,029-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:46,029-0500 INFO ThrottleManager mem=6.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:46,273-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:46,529-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:46,529-0500 INFO ThrottleManager mem=6.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:46,758-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:26:46,773-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:47,029-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:47,029-0500 INFO ThrottleManager mem=6.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:47,273-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:47,530-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:47,530-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:47,742-0500 INFO Multiplexer No streams
+2013-08-09 14:26:47,773-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:48,030-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:48,030-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:48,274-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:48,530-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:48,530-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:48,774-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:49,031-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:49,031-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:49,274-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:49,531-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:49,531-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:49,774-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:50,031-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:50,031-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:50,275-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:50,531-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:50,532-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:50,775-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:51,032-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:51,032-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:51,275-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:51,532-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:51,532-0500 INFO ThrottleManager mem=6.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:51,775-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:52,032-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:52,032-0500 INFO ThrottleManager mem=6.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:52,276-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:52,533-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:52,533-0500 INFO ThrottleManager mem=6.78 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:52,776-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:26:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 6.87 MB
+2013-08-09 14:26:53,033-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:53,033-0500 INFO ThrottleManager mem=6.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:53,276-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:53,533-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:53,533-0500 INFO ThrottleManager mem=6.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:53,777-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:54,034-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:54,034-0500 INFO ThrottleManager mem=6.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:54,277-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:54,534-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:54,534-0500 INFO ThrottleManager mem=6.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:54,777-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:55,034-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:55,034-0500 INFO ThrottleManager mem=6.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:55,034-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:26:55,277-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:55,277-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:26:55,534-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:55,535-0500 INFO ThrottleManager mem=6.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:55,777-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:56,035-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:56,035-0500 INFO ThrottleManager mem=6.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:56,278-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:56,535-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:56,535-0500 INFO ThrottleManager mem=6.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:56,758-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:26:56,778-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:57,035-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:57,036-0500 INFO ThrottleManager mem=6.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:57,278-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:57,536-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:57,536-0500 INFO ThrottleManager mem=6.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:57,746-0500 INFO Multiplexer No streams
+2013-08-09 14:26:57,778-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:58,036-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:58,036-0500 INFO ThrottleManager mem=6.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:58,279-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:58,536-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:58,537-0500 INFO ThrottleManager mem=6.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:58,779-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:59,037-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:59,037-0500 INFO ThrottleManager mem=6.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:59,279-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:59,537-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:26:59,537-0500 INFO ThrottleManager mem=6.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:26:59,779-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:00,037-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:00,037-0500 INFO ThrottleManager mem=6.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:00,280-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:00,538-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:00,538-0500 INFO ThrottleManager mem=6.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:00,780-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:01,038-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:01,038-0500 INFO ThrottleManager mem=7.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:01,280-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:01,538-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:01,538-0500 INFO ThrottleManager mem=7.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:01,780-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:02,039-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:02,039-0500 INFO ThrottleManager mem=7.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:02,281-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:02,539-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:02,539-0500 INFO ThrottleManager mem=7.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:02,781-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:27:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 7.07 MB
+2013-08-09 14:27:03,039-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:03,039-0500 INFO ThrottleManager mem=7.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:03,281-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:03,539-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:03,539-0500 INFO ThrottleManager mem=7.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:03,781-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:04,040-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:04,040-0500 INFO ThrottleManager mem=7.11 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:04,281-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:04,540-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:04,540-0500 INFO ThrottleManager mem=7.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:04,782-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:05,040-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:05,040-0500 INFO ThrottleManager mem=7.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:05,040-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:27:05,282-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:05,282-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:27:05,541-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:05,541-0500 INFO ThrottleManager mem=7.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:05,782-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:06,041-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:06,041-0500 INFO ThrottleManager mem=7.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:06,283-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:06,541-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:06,541-0500 INFO ThrottleManager mem=7.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:06,758-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:27:06,783-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:07,041-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:07,042-0500 INFO ThrottleManager mem=7.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:07,283-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:07,542-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:07,542-0500 INFO ThrottleManager mem=7.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:07,750-0500 INFO Multiplexer No streams
+2013-08-09 14:27:07,783-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:08,042-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:08,042-0500 INFO ThrottleManager mem=7.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:08,284-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:08,542-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:08,542-0500 INFO ThrottleManager mem=7.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:08,784-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:09,043-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:09,043-0500 INFO ThrottleManager mem=7.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:09,284-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:09,543-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:09,543-0500 INFO ThrottleManager mem=7.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:09,784-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:10,043-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:10,043-0500 INFO ThrottleManager mem=7.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:10,285-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:10,543-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:10,544-0500 INFO ThrottleManager mem=7.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:10,785-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:11,044-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:11,044-0500 INFO ThrottleManager mem=7.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:11,285-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:11,544-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:11,544-0500 INFO ThrottleManager mem=7.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:11,786-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:12,044-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:12,044-0500 INFO ThrottleManager mem=7.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:12,286-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:12,545-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:12,545-0500 INFO ThrottleManager mem=7.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:12,786-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:27:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 7.37 MB
+2013-08-09 14:27:13,045-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:13,045-0500 INFO ThrottleManager mem=7.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:13,286-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:13,545-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:13,545-0500 INFO ThrottleManager mem=7.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:13,787-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:14,045-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:14,046-0500 INFO ThrottleManager mem=7.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:14,287-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:14,546-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:14,546-0500 INFO ThrottleManager mem=7.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:14,787-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:15,046-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:15,046-0500 INFO ThrottleManager mem=7.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:15,046-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:27:15,287-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:15,287-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:27:15,546-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:15,546-0500 INFO ThrottleManager mem=7.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:15,788-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:16,047-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:16,047-0500 INFO ThrottleManager mem=7.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:16,288-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:16,547-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:16,547-0500 INFO ThrottleManager mem=7.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:16,758-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:27:16,788-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:17,047-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:17,047-0500 INFO ThrottleManager mem=7.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:17,288-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:17,547-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:17,548-0500 INFO ThrottleManager mem=7.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:17,752-0500 INFO Multiplexer No streams
+2013-08-09 14:27:17,788-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:18,048-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:18,048-0500 INFO ThrottleManager mem=7.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:18,289-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:18,548-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:18,548-0500 INFO ThrottleManager mem=7.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:18,789-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:19,048-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:19,048-0500 INFO ThrottleManager mem=7.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:19,289-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:19,549-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:19,549-0500 INFO ThrottleManager mem=7.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:19,789-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:20,049-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:20,049-0500 INFO ThrottleManager mem=7.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:20,290-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:20,549-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:20,549-0500 INFO ThrottleManager mem=7.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:20,790-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:21,050-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:21,050-0500 INFO ThrottleManager mem=7.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:21,290-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:21,550-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:21,550-0500 INFO ThrottleManager mem=7.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:21,790-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:22,050-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:22,050-0500 INFO ThrottleManager mem=7.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:22,291-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:22,550-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:22,550-0500 INFO ThrottleManager mem=7.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:22,791-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:27:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 7.61 MB
+2013-08-09 14:27:23,051-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:23,051-0500 INFO ThrottleManager mem=7.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:23,291-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:23,551-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:23,551-0500 INFO ThrottleManager mem=7.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:23,792-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:24,051-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:24,051-0500 INFO ThrottleManager mem=7.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:24,292-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:24,552-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:24,552-0500 INFO ThrottleManager mem=7.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:24,792-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:25,052-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:25,052-0500 INFO ThrottleManager mem=7.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:25,052-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:27:25,292-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:25,292-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:27:25,552-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:25,552-0500 INFO ThrottleManager mem=7.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:25,793-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:26,052-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:26,052-0500 INFO ThrottleManager mem=7.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:26,293-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:26,553-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:26,553-0500 INFO ThrottleManager mem=7.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:26,758-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:27:26,793-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:27,053-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:27,053-0500 INFO ThrottleManager mem=7.69 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:27,293-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:27,553-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:27,553-0500 INFO ThrottleManager mem=7.69 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:27,757-0500 INFO Multiplexer No streams
+2013-08-09 14:27:27,793-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:28,054-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:28,054-0500 INFO ThrottleManager mem=7.69 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:28,294-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:28,554-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:28,554-0500 INFO ThrottleManager mem=7.69 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:28,794-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:29,054-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:29,054-0500 INFO ThrottleManager mem=7.69 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:29,294-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:29,554-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:29,554-0500 INFO ThrottleManager mem=7.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:29,794-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:30,055-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:30,055-0500 INFO ThrottleManager mem=7.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:30,295-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:30,555-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:30,555-0500 INFO ThrottleManager mem=7.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:30,795-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:31,055-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:31,055-0500 INFO ThrottleManager mem=7.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:31,295-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:31,555-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:31,556-0500 INFO ThrottleManager mem=7.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:31,795-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:32,056-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:32,056-0500 INFO ThrottleManager mem=7.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:32,296-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:32,556-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:32,556-0500 INFO ThrottleManager mem=7.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:32,796-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:27:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 7.9 MB
+2013-08-09 14:27:33,056-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:33,056-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:33,296-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:33,557-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:33,557-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:33,796-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:34,057-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:34,057-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:34,297-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:34,557-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:34,557-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:34,797-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:35,057-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:35,058-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:35,058-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:27:35,297-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:35,297-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:27:35,558-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:35,558-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:35,798-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:36,058-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:36,058-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:36,298-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:36,558-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:36,558-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:36,759-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:27:36,798-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:37,059-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:37,059-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:37,298-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:37,559-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:37,559-0500 INFO ThrottleManager mem=7.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:37,760-0500 INFO Multiplexer No streams
+2013-08-09 14:27:37,798-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:38,059-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:38,059-0500 INFO ThrottleManager mem=7.98 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:38,299-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:38,559-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:38,560-0500 INFO ThrottleManager mem=8.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:38,799-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:39,060-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:39,060-0500 INFO ThrottleManager mem=8.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:39,299-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:39,560-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:39,560-0500 INFO ThrottleManager mem=8.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:39,799-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:40,060-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:40,060-0500 INFO ThrottleManager mem=8.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:40,300-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:40,561-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:40,561-0500 INFO ThrottleManager mem=8.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:40,800-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:41,061-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:41,061-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:41,300-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:41,561-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:41,561-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:41,801-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:42,061-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:42,061-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:42,301-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:42,562-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:42,562-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:42,801-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:27:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 8.1 MB
+2013-08-09 14:27:43,062-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:43,062-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:43,301-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:43,562-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:43,562-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:43,802-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:44,062-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:44,063-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:44,302-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:44,563-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:44,563-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:44,802-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:45,063-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:45,063-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:45,063-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:27:45,302-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:45,302-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:27:45,563-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:45,563-0500 INFO ThrottleManager mem=8.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:45,802-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:46,064-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:46,064-0500 INFO ThrottleManager mem=8.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:46,303-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:46,564-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:46,564-0500 INFO ThrottleManager mem=8.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:46,759-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:27:46,803-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:47,064-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:47,064-0500 INFO ThrottleManager mem=8.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:47,303-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:47,565-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:47,565-0500 INFO ThrottleManager mem=8.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:47,766-0500 INFO Multiplexer No streams
+2013-08-09 14:27:47,803-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:48,065-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:48,065-0500 INFO ThrottleManager mem=8.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:48,304-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:48,565-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:48,565-0500 INFO ThrottleManager mem=8.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:48,804-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:49,065-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:49,065-0500 INFO ThrottleManager mem=8.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:49,304-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:49,566-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:49,566-0500 INFO ThrottleManager mem=8.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:49,804-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:50,066-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:50,066-0500 INFO ThrottleManager mem=8.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:50,305-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:50,566-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:50,566-0500 INFO ThrottleManager mem=8.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:50,805-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:51,066-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:51,067-0500 INFO ThrottleManager mem=8.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:51,305-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:51,567-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:51,567-0500 INFO ThrottleManager mem=8.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:51,805-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:52,067-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:52,067-0500 INFO ThrottleManager mem=8.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:52,306-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:52,567-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:52,567-0500 INFO ThrottleManager mem=8.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:52,806-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:27:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 8.32 MB
+2013-08-09 14:27:53,068-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:53,068-0500 INFO ThrottleManager mem=8.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:53,306-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:53,568-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:53,568-0500 INFO ThrottleManager mem=8.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:53,807-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:54,068-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:54,068-0500 INFO ThrottleManager mem=8.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:54,307-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:54,568-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:54,568-0500 INFO ThrottleManager mem=8.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:54,807-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:55,069-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:55,069-0500 INFO ThrottleManager mem=8.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:55,069-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:27:55,307-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:55,307-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:27:55,569-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:55,569-0500 INFO ThrottleManager mem=8.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:55,807-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:56,069-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:56,069-0500 INFO ThrottleManager mem=8.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:56,308-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:56,570-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:56,570-0500 INFO ThrottleManager mem=8.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:56,759-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:27:56,808-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:57,070-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:57,070-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:57,308-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:57,570-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:57,570-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:57,769-0500 INFO Multiplexer No streams
+2013-08-09 14:27:57,808-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:58,070-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:58,071-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:58,309-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:58,571-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:58,571-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:58,809-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:59,071-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:59,071-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:59,309-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:59,571-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:27:59,571-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:27:59,809-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:00,072-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:00,072-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:00,310-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:00,572-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:00,572-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:00,810-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:01,072-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:01,072-0500 INFO ThrottleManager mem=8.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:01,310-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:01,572-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:01,573-0500 INFO ThrottleManager mem=8.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:01,810-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:02,073-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:02,073-0500 INFO ThrottleManager mem=8.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:02,311-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:02,573-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:02,573-0500 INFO ThrottleManager mem=8.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:02,811-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:28:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 8.56 MB
+2013-08-09 14:28:03,073-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:03,073-0500 INFO ThrottleManager mem=8.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:03,311-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:03,574-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:03,574-0500 INFO ThrottleManager mem=8.64 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:03,811-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:04,074-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:04,074-0500 INFO ThrottleManager mem=8.64 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:04,312-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:04,574-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:04,574-0500 INFO ThrottleManager mem=8.64 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:04,812-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:05,074-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:05,074-0500 INFO ThrottleManager mem=8.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:05,074-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:28:05,312-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:05,312-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:28:05,575-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:05,575-0500 INFO ThrottleManager mem=8.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:05,813-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:06,075-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:06,075-0500 INFO ThrottleManager mem=8.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:06,313-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:06,575-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:06,575-0500 INFO ThrottleManager mem=8.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:06,759-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:28:06,813-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:07,076-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:07,076-0500 INFO ThrottleManager mem=8.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:07,313-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:07,576-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:07,576-0500 INFO ThrottleManager mem=8.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:07,774-0500 INFO Multiplexer No streams
+2013-08-09 14:28:07,813-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:08,076-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:08,076-0500 INFO ThrottleManager mem=8.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:08,314-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:08,576-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:08,576-0500 INFO ThrottleManager mem=8.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:08,814-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:09,077-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:09,077-0500 INFO ThrottleManager mem=8.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:09,314-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:09,577-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:09,577-0500 INFO ThrottleManager mem=8.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:09,814-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:10,077-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:10,077-0500 INFO ThrottleManager mem=8.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:10,315-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:10,577-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:10,577-0500 INFO ThrottleManager mem=8.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:10,815-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:11,078-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:11,078-0500 INFO ThrottleManager mem=8.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:11,315-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:11,578-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:11,578-0500 INFO ThrottleManager mem=8.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:11,816-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:12,078-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:12,078-0500 INFO ThrottleManager mem=8.84 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:12,316-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:12,578-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:12,579-0500 INFO ThrottleManager mem=8.84 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:12,816-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:28:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 8.85 MB
+2013-08-09 14:28:13,079-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:13,079-0500 INFO ThrottleManager mem=8.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:13,316-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:13,579-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:13,579-0500 INFO ThrottleManager mem=8.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:13,816-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:14,079-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:14,079-0500 INFO ThrottleManager mem=8.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:14,317-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:14,580-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:14,580-0500 INFO ThrottleManager mem=8.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:14,817-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:15,080-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:15,080-0500 INFO ThrottleManager mem=8.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:15,080-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:28:15,317-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:15,317-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:28:15,580-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:15,580-0500 INFO ThrottleManager mem=8.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:15,817-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:16,080-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:16,080-0500 INFO ThrottleManager mem=8.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:16,318-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:16,581-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:16,581-0500 INFO ThrottleManager mem=8.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:16,760-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:28:16,818-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:17,081-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:17,081-0500 INFO ThrottleManager mem=8.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:17,318-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:17,581-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:17,581-0500 INFO ThrottleManager mem=8.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:17,781-0500 INFO Multiplexer No streams
+2013-08-09 14:28:17,818-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:18,081-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:18,081-0500 INFO ThrottleManager mem=8.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:18,319-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:18,582-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:18,582-0500 INFO ThrottleManager mem=8.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:18,819-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:19,082-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:19,082-0500 INFO ThrottleManager mem=8.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:19,319-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:19,582-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:19,582-0500 INFO ThrottleManager mem=8.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:19,819-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:20,083-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:20,083-0500 INFO ThrottleManager mem=9.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:20,319-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:20,583-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:20,583-0500 INFO ThrottleManager mem=9.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:20,820-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:21,083-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:21,083-0500 INFO ThrottleManager mem=9.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:21,320-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:21,583-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:21,583-0500 INFO ThrottleManager mem=9.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:21,820-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:22,084-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:22,084-0500 INFO ThrottleManager mem=9.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:22,320-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:22,584-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:22,584-0500 INFO ThrottleManager mem=9.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:22,821-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:22,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:28:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 9.14 MB
+2013-08-09 14:28:23,084-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:23,084-0500 INFO ThrottleManager mem=9.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:23,321-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:23,584-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:23,585-0500 INFO ThrottleManager mem=9.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:23,821-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:24,085-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:24,085-0500 INFO ThrottleManager mem=9.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:24,322-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:24,585-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:24,585-0500 INFO ThrottleManager mem=9.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:24,822-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:25,085-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:25,085-0500 INFO ThrottleManager mem=9.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:25,085-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:28:25,322-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:25,322-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:28:25,586-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:25,586-0500 INFO ThrottleManager mem=9.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:25,822-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:26,086-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:26,086-0500 INFO ThrottleManager mem=9.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:26,323-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:26,586-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:26,586-0500 INFO ThrottleManager mem=9.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:26,760-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:28:26,823-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:27,086-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:27,086-0500 INFO ThrottleManager mem=9.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:27,323-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:27,587-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:27,587-0500 INFO ThrottleManager mem=9.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:27,788-0500 INFO Multiplexer No streams
+2013-08-09 14:28:27,823-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:28,087-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:28,087-0500 INFO ThrottleManager mem=9.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:28,324-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:28,587-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:28,587-0500 INFO ThrottleManager mem=9.22 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:28,824-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:29,088-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:29,088-0500 INFO ThrottleManager mem=9.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:29,324-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:29,588-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:29,588-0500 INFO ThrottleManager mem=9.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:29,824-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:30,088-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:30,088-0500 INFO ThrottleManager mem=9.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:30,324-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:30,588-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:30,588-0500 INFO ThrottleManager mem=9.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:30,825-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:31,089-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:31,089-0500 INFO ThrottleManager mem=9.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:31,325-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:31,589-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:31,589-0500 INFO ThrottleManager mem=9.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:31,825-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:32,089-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:32,089-0500 INFO ThrottleManager mem=9.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:32,325-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:32,589-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:32,589-0500 INFO ThrottleManager mem=9.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:32,826-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:28:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 9.39 MB
+2013-08-09 14:28:33,090-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:33,090-0500 INFO ThrottleManager mem=9.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:33,326-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:33,590-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:33,590-0500 INFO ThrottleManager mem=9.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:33,826-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:34,090-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:34,090-0500 INFO ThrottleManager mem=9.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:34,326-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:34,590-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:34,591-0500 INFO ThrottleManager mem=9.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:34,826-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:35,091-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:35,091-0500 INFO ThrottleManager mem=9.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:35,091-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:28:35,327-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:35,327-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:28:35,591-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:35,591-0500 INFO ThrottleManager mem=9.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:35,827-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:36,091-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:36,091-0500 INFO ThrottleManager mem=9.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:36,327-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:36,592-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:36,592-0500 INFO ThrottleManager mem=9.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:36,760-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:28:36,828-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:37,092-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:37,092-0500 INFO ThrottleManager mem=9.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:37,328-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:37,592-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:37,592-0500 INFO ThrottleManager mem=9.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:37,793-0500 INFO Multiplexer No streams
+2013-08-09 14:28:37,828-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:38,092-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:38,092-0500 INFO ThrottleManager mem=9.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:38,328-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:38,593-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:38,593-0500 INFO ThrottleManager mem=9.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:38,829-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:39,093-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:39,093-0500 INFO ThrottleManager mem=9.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:39,329-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:39,593-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:39,593-0500 INFO ThrottleManager mem=9.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:39,829-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:40,093-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:40,093-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:40,329-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:40,593-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:40,594-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:40,829-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:41,094-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:41,094-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:41,330-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:41,594-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:41,594-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:41,830-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:42,094-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:42,094-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:42,330-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:42,594-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:42,594-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:42,831-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:28:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 9.59 MB
+2013-08-09 14:28:43,095-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:43,095-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:43,331-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:43,595-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:43,595-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:43,831-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:44,095-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:44,095-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:44,331-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:44,595-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:44,595-0500 INFO ThrottleManager mem=9.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:44,832-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:45,096-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:45,096-0500 INFO ThrottleManager mem=9.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:45,096-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:28:45,332-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:45,332-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:28:45,596-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:45,596-0500 INFO ThrottleManager mem=9.71 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:45,832-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:46,096-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:46,096-0500 INFO ThrottleManager mem=9.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:46,332-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:46,596-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:46,596-0500 INFO ThrottleManager mem=9.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:46,760-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:28:46,833-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:47,096-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:47,097-0500 INFO ThrottleManager mem=9.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:47,333-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:47,597-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:47,597-0500 INFO ThrottleManager mem=9.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:47,801-0500 INFO Multiplexer No streams
+2013-08-09 14:28:47,833-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:48,097-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:48,097-0500 INFO ThrottleManager mem=9.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:48,333-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:48,597-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:48,597-0500 INFO ThrottleManager mem=9.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:48,833-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:49,098-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:49,098-0500 INFO ThrottleManager mem=9.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:49,334-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:49,598-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:49,598-0500 INFO ThrottleManager mem=9.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:49,834-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:50,098-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:50,098-0500 INFO ThrottleManager mem=9.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:50,334-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:50,598-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:50,598-0500 INFO ThrottleManager mem=9.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:50,834-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:51,099-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:51,099-0500 INFO ThrottleManager mem=9.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:51,335-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:51,599-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:51,599-0500 INFO ThrottleManager mem=9.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:51,835-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:52,099-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:52,099-0500 INFO ThrottleManager mem=9.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:52,335-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:52,599-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:52,599-0500 INFO ThrottleManager mem=9.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:52,835-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:28:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 9.81 MB
+2013-08-09 14:28:53,100-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:53,100-0500 INFO ThrottleManager mem=9.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:53,336-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:53,600-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:53,600-0500 INFO ThrottleManager mem=9.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:53,836-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:54,100-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:54,100-0500 INFO ThrottleManager mem=9.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:54,336-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:54,600-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:54,601-0500 INFO ThrottleManager mem=9.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:54,836-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:55,101-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:55,101-0500 INFO ThrottleManager mem=9.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:55,101-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:28:55,337-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:55,337-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:28:55,601-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:55,601-0500 INFO ThrottleManager mem=10 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:55,837-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:56,101-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:56,101-0500 INFO ThrottleManager mem=10 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:56,337-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:56,602-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:56,602-0500 INFO ThrottleManager mem=10 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:56,761-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:28:56,837-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:57,102-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:57,102-0500 INFO ThrottleManager mem=10 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:57,338-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:57,602-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:57,602-0500 INFO ThrottleManager mem=10 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:57,807-0500 INFO Multiplexer No streams
+2013-08-09 14:28:57,838-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:58,102-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:58,103-0500 INFO ThrottleManager mem=10 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:58,338-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:58,603-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:58,603-0500 INFO ThrottleManager mem=10 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:58,838-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:59,103-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:59,103-0500 INFO ThrottleManager mem=10 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:59,339-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:59,603-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:28:59,603-0500 INFO ThrottleManager mem=10.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:28:59,839-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:00,104-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:00,104-0500 INFO ThrottleManager mem=10.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:00,339-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:00,604-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:00,604-0500 INFO ThrottleManager mem=10.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:00,839-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:01,104-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:01,104-0500 INFO ThrottleManager mem=10.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:01,340-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:01,604-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:01,604-0500 INFO ThrottleManager mem=10.09 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:01,840-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:02,105-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:02,105-0500 INFO ThrottleManager mem=10.09 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:02,340-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:02,605-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:02,605-0500 INFO ThrottleManager mem=10.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:02,841-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:29:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 10.17 MB
+2013-08-09 14:29:03,105-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:03,105-0500 INFO ThrottleManager mem=10.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:03,341-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:03,605-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:03,606-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:03,841-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:04,106-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:04,106-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:04,341-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:04,606-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:04,606-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:04,841-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:05,106-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:05,106-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:05,106-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:29:05,342-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:05,342-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:29:05,607-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:05,607-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:05,842-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:06,107-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:06,107-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:06,342-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:06,607-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:06,607-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:06,761-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:29:06,843-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:07,107-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:07,107-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:07,343-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:07,608-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:07,608-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:07,813-0500 INFO Multiplexer No streams
+2013-08-09 14:29:07,843-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:08,108-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:08,108-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:08,343-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:08,608-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:08,608-0500 INFO ThrottleManager mem=10.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:08,843-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:09,109-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:09,109-0500 INFO ThrottleManager mem=10.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:09,344-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:09,609-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:09,609-0500 INFO ThrottleManager mem=10.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:09,844-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:10,109-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:10,109-0500 INFO ThrottleManager mem=10.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:10,344-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:10,609-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:10,609-0500 INFO ThrottleManager mem=10.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:10,844-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:11,110-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:11,110-0500 INFO ThrottleManager mem=10.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:11,345-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:11,610-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:11,610-0500 INFO ThrottleManager mem=10.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:11,845-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:12,110-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:12,110-0500 INFO ThrottleManager mem=10.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:12,345-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:12,610-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:12,610-0500 INFO ThrottleManager mem=10.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:12,846-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:29:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 10.42 MB
+2013-08-09 14:29:13,111-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:13,111-0500 INFO ThrottleManager mem=10.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:13,346-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:13,611-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:13,611-0500 INFO ThrottleManager mem=10.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:13,846-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:14,111-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:14,111-0500 INFO ThrottleManager mem=10.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:14,346-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:14,611-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:14,611-0500 INFO ThrottleManager mem=10.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:14,847-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:15,112-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:15,112-0500 INFO ThrottleManager mem=10.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:15,112-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:29:15,347-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:15,347-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:29:15,612-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:15,612-0500 INFO ThrottleManager mem=10.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:15,847-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:16,112-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:16,112-0500 INFO ThrottleManager mem=10.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:16,347-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:16,612-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:16,613-0500 INFO ThrottleManager mem=10.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:16,761-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:29:16,848-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:17,113-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:17,113-0500 INFO ThrottleManager mem=10.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:17,348-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:17,613-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:17,613-0500 INFO ThrottleManager mem=10.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:17,820-0500 INFO Multiplexer No streams
+2013-08-09 14:29:17,848-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:18,113-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:18,113-0500 INFO ThrottleManager mem=10.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:18,348-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:18,614-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:18,614-0500 INFO ThrottleManager mem=10.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:18,849-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:19,114-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:19,114-0500 INFO ThrottleManager mem=10.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:19,349-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:19,614-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:19,614-0500 INFO ThrottleManager mem=10.58 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:19,849-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:20,114-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:20,114-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:20,349-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:20,615-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:20,615-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:20,849-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:21,115-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:21,115-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:21,350-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:21,615-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:21,615-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:21,850-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:22,115-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:22,115-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:22,350-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:22,616-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:22,616-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:22,850-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:29:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 10.63 MB
+2013-08-09 14:29:23,116-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:23,116-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:23,351-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:23,616-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:23,616-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:23,851-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:24,116-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:24,116-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:24,351-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:24,617-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:24,617-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:24,852-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:25,117-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:25,117-0500 INFO ThrottleManager mem=10.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:25,117-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:29:25,352-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:25,352-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:29:25,617-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:25,617-0500 INFO ThrottleManager mem=10.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:25,852-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:26,118-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:26,118-0500 INFO ThrottleManager mem=10.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:26,352-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:26,618-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:26,618-0500 INFO ThrottleManager mem=10.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:26,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:29:26,853-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:27,118-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:27,118-0500 INFO ThrottleManager mem=10.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:27,353-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:27,618-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:27,618-0500 INFO ThrottleManager mem=10.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:27,824-0500 INFO Multiplexer No streams
+2013-08-09 14:29:27,853-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:28,119-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:28,119-0500 INFO ThrottleManager mem=10.78 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:28,353-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:28,619-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:28,619-0500 INFO ThrottleManager mem=10.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:28,853-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:29,119-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:29,119-0500 INFO ThrottleManager mem=10.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:29,354-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:29,619-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:29,619-0500 INFO ThrottleManager mem=10.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:29,854-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:30,120-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:30,120-0500 INFO ThrottleManager mem=10.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:30,354-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:30,620-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:30,620-0500 INFO ThrottleManager mem=10.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:30,854-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:31,120-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:31,120-0500 INFO ThrottleManager mem=10.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:31,355-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:31,621-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:31,621-0500 INFO ThrottleManager mem=10.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:31,855-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:32,121-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:32,121-0500 INFO ThrottleManager mem=10.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:32,355-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:32,621-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:32,621-0500 INFO ThrottleManager mem=10.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:32,855-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:32,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:29:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 10.84 MB
+2013-08-09 14:29:33,121-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:33,121-0500 INFO ThrottleManager mem=10.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:33,356-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:33,622-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:33,622-0500 INFO ThrottleManager mem=10.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:33,856-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:34,122-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:34,122-0500 INFO ThrottleManager mem=10.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:34,356-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:34,622-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:34,622-0500 INFO ThrottleManager mem=10.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:34,856-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:35,122-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:35,123-0500 INFO ThrottleManager mem=10.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:35,123-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:29:35,357-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:35,357-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:29:35,623-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:35,623-0500 INFO ThrottleManager mem=10.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:35,857-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:36,123-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:36,123-0500 INFO ThrottleManager mem=10.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:36,357-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:36,623-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:36,623-0500 INFO ThrottleManager mem=11 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:36,761-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:29:36,857-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:37,124-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:37,124-0500 INFO ThrottleManager mem=11.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:37,358-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:37,624-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:37,624-0500 INFO ThrottleManager mem=11.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:37,829-0500 INFO Multiplexer No streams
+2013-08-09 14:29:37,858-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:38,124-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:38,124-0500 INFO ThrottleManager mem=11.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:38,358-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:38,624-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:38,624-0500 INFO ThrottleManager mem=11.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:38,858-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:39,125-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:39,125-0500 INFO ThrottleManager mem=11.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:39,359-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:39,625-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:39,625-0500 INFO ThrottleManager mem=11.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:39,859-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:40,125-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:40,125-0500 INFO ThrottleManager mem=11.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:40,359-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:40,625-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:40,626-0500 INFO ThrottleManager mem=11.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:40,859-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:41,126-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:41,126-0500 INFO ThrottleManager mem=11.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:41,360-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:41,626-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:41,626-0500 INFO ThrottleManager mem=11.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:41,860-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:42,126-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:42,126-0500 INFO ThrottleManager mem=11.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:42,360-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:42,627-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:42,627-0500 INFO ThrottleManager mem=11.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:42,860-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:29:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 11.16 MB
+2013-08-09 14:29:43,127-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:43,127-0500 INFO ThrottleManager mem=11.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:43,361-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:43,627-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:43,627-0500 INFO ThrottleManager mem=11.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:43,861-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:44,127-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:44,127-0500 INFO ThrottleManager mem=11.16 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:44,361-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:44,628-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:44,628-0500 INFO ThrottleManager mem=11.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:44,861-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:45,128-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:45,128-0500 INFO ThrottleManager mem=11.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:45,128-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:29:45,362-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:45,362-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:29:45,628-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:45,628-0500 INFO ThrottleManager mem=11.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:45,862-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:46,128-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:46,128-0500 INFO ThrottleManager mem=11.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:46,362-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:46,629-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:46,629-0500 INFO ThrottleManager mem=11.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:46,761-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:29:46,862-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:47,129-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:47,129-0500 INFO ThrottleManager mem=11.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:47,363-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:47,629-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:47,629-0500 INFO ThrottleManager mem=11.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:47,838-0500 INFO Multiplexer No streams
+2013-08-09 14:29:47,863-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:48,129-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:48,130-0500 INFO ThrottleManager mem=11.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:48,363-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:48,630-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:48,630-0500 INFO ThrottleManager mem=11.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:48,863-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:49,130-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:49,130-0500 INFO ThrottleManager mem=11.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:49,363-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:49,630-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:49,630-0500 INFO ThrottleManager mem=11.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:49,864-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:50,131-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:50,131-0500 INFO ThrottleManager mem=11.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:50,364-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:50,631-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:50,631-0500 INFO ThrottleManager mem=11.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:50,864-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:51,131-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:51,131-0500 INFO ThrottleManager mem=11.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:51,364-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:51,631-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:51,631-0500 INFO ThrottleManager mem=11.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:51,865-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:52,132-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:52,132-0500 INFO ThrottleManager mem=11.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:52,365-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:52,632-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:52,632-0500 INFO ThrottleManager mem=11.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:52,865-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:29:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 11.37 MB
+2013-08-09 14:29:53,132-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:53,132-0500 INFO ThrottleManager mem=11.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:53,365-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:53,632-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:53,632-0500 INFO ThrottleManager mem=11.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:53,866-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:54,133-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:54,133-0500 INFO ThrottleManager mem=11.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:54,366-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:54,633-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:54,633-0500 INFO ThrottleManager mem=11.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:54,866-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:55,133-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:55,133-0500 INFO ThrottleManager mem=11.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:55,133-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:29:55,366-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:55,366-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:29:55,633-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:55,634-0500 INFO ThrottleManager mem=11.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:55,867-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:56,134-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:56,134-0500 INFO ThrottleManager mem=11.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:56,367-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:56,634-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:56,634-0500 INFO ThrottleManager mem=11.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:56,761-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:29:56,867-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:57,134-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:57,134-0500 INFO ThrottleManager mem=11.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:57,367-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:57,635-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:57,635-0500 INFO ThrottleManager mem=11.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:57,844-0500 INFO Multiplexer No streams
+2013-08-09 14:29:57,868-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:58,135-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:58,135-0500 INFO ThrottleManager mem=11.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:58,368-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:58,635-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:58,635-0500 INFO ThrottleManager mem=11.58 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:58,868-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:59,135-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:59,135-0500 INFO ThrottleManager mem=11.58 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:59,368-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:59,636-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:29:59,636-0500 INFO ThrottleManager mem=11.58 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:29:59,868-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:00,136-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:00,136-0500 INFO ThrottleManager mem=11.58 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:00,369-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:00,636-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:00,636-0500 INFO ThrottleManager mem=11.58 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:00,869-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:01,136-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:01,137-0500 INFO ThrottleManager mem=11.58 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:01,369-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:01,637-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:01,637-0500 INFO ThrottleManager mem=11.62 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:01,869-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:02,137-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:02,137-0500 INFO ThrottleManager mem=11.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:02,370-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:02,637-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:02,637-0500 INFO ThrottleManager mem=11.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:02,870-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:30:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 11.66 MB
+2013-08-09 14:30:03,137-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:03,138-0500 INFO ThrottleManager mem=11.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:03,370-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:03,638-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:03,638-0500 INFO ThrottleManager mem=11.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:03,870-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:04,138-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:04,138-0500 INFO ThrottleManager mem=11.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:04,371-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:04,638-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:04,638-0500 INFO ThrottleManager mem=11.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:04,871-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:05,139-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:05,139-0500 INFO ThrottleManager mem=11.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:05,139-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:30:05,371-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:05,371-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:30:05,639-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:05,639-0500 INFO ThrottleManager mem=11.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:05,872-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:06,139-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:06,139-0500 INFO ThrottleManager mem=11.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:06,372-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:06,639-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:06,639-0500 INFO ThrottleManager mem=11.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:06,761-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:30:06,872-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:07,140-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:07,140-0500 INFO ThrottleManager mem=11.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:07,372-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:07,640-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:07,640-0500 INFO ThrottleManager mem=11.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:07,850-0500 INFO Multiplexer No streams
+2013-08-09 14:30:07,872-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:08,140-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:08,140-0500 INFO ThrottleManager mem=11.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:08,373-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:08,640-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:08,641-0500 INFO ThrottleManager mem=11.78 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:08,873-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:09,141-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:09,141-0500 INFO ThrottleManager mem=11.78 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:09,373-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:09,641-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:09,641-0500 INFO ThrottleManager mem=11.78 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:09,873-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:10,141-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:10,141-0500 INFO ThrottleManager mem=11.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:10,374-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:10,642-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:10,642-0500 INFO ThrottleManager mem=11.86 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:10,874-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:11,142-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:11,142-0500 INFO ThrottleManager mem=11.86 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:11,374-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:11,642-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:11,642-0500 INFO ThrottleManager mem=11.86 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:11,874-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:12,142-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:12,142-0500 INFO ThrottleManager mem=11.86 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:12,375-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:12,643-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:12,643-0500 INFO ThrottleManager mem=11.86 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:12,875-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:30:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 11.91 MB
+2013-08-09 14:30:13,143-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:13,143-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:13,375-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:13,643-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:13,643-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:13,875-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:14,143-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:14,143-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:14,376-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:14,644-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:14,644-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:14,876-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:15,144-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:15,144-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:15,144-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:30:15,376-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:15,376-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:30:15,644-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:15,644-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:15,876-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:16,144-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:16,144-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:16,377-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:16,645-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:16,645-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:16,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:30:16,877-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:17,145-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:17,145-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:17,377-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:17,645-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:17,645-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:17,851-0500 INFO Multiplexer No streams
+2013-08-09 14:30:17,877-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:18,145-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:18,145-0500 INFO ThrottleManager mem=11.99 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:18,377-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:18,646-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:18,646-0500 INFO ThrottleManager mem=12.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:18,878-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:19,146-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:19,146-0500 INFO ThrottleManager mem=12.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:19,378-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:19,646-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:19,646-0500 INFO ThrottleManager mem=12.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:19,878-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:20,146-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:20,147-0500 INFO ThrottleManager mem=12.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:20,378-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:20,647-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:20,647-0500 INFO ThrottleManager mem=12.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:20,879-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:21,147-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:21,147-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:21,379-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:21,647-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:21,647-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:21,879-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:22,148-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:22,148-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:22,379-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:22,648-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:22,648-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:22,880-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:22,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:30:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 12.19 MB
+2013-08-09 14:30:23,148-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:23,148-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:23,380-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:23,648-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:23,648-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:23,880-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:24,149-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:24,149-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:24,380-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:24,649-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:24,649-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:24,881-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:25,149-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:25,149-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:25,149-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:30:25,381-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:25,381-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:30:25,649-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:25,650-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:25,881-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:26,150-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:26,150-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:26,381-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:26,650-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:26,650-0500 INFO ThrottleManager mem=12.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:26,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:30:26,882-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:27,150-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:27,150-0500 INFO ThrottleManager mem=12.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:27,382-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:27,651-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:27,651-0500 INFO ThrottleManager mem=12.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:27,857-0500 INFO Multiplexer No streams
+2013-08-09 14:30:27,882-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:28,151-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:28,151-0500 INFO ThrottleManager mem=12.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:28,382-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:28,651-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:28,651-0500 INFO ThrottleManager mem=12.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:28,883-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:29,151-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:29,151-0500 INFO ThrottleManager mem=12.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:29,383-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:29,652-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:29,652-0500 INFO ThrottleManager mem=12.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:29,883-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:30,152-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:30,152-0500 INFO ThrottleManager mem=12.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:30,383-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:30,652-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:30,652-0500 INFO ThrottleManager mem=12.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:30,884-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:31,153-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:31,153-0500 INFO ThrottleManager mem=12.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:31,384-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:31,653-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:31,653-0500 INFO ThrottleManager mem=12.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:31,884-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:32,153-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:32,153-0500 INFO ThrottleManager mem=12.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:32,384-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:32,653-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:32,653-0500 INFO ThrottleManager mem=12.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:32,885-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:30:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 12.41 MB
+2013-08-09 14:30:33,154-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:33,154-0500 INFO ThrottleManager mem=12.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:33,385-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:33,654-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:33,654-0500 INFO ThrottleManager mem=12.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:33,885-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:34,154-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:34,154-0500 INFO ThrottleManager mem=12.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:34,385-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:34,654-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:34,654-0500 INFO ThrottleManager mem=12.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:34,886-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:35,155-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:35,155-0500 INFO ThrottleManager mem=12.41 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:35,155-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:30:35,386-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:35,386-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:30:35,655-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:35,655-0500 INFO ThrottleManager mem=12.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:35,886-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:36,155-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:36,155-0500 INFO ThrottleManager mem=12.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:36,387-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:36,656-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:36,656-0500 INFO ThrottleManager mem=12.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:36,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:30:36,887-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:37,156-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:37,156-0500 INFO ThrottleManager mem=12.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:37,387-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:37,656-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:37,656-0500 INFO ThrottleManager mem=12.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:37,864-0500 INFO Multiplexer No streams
+2013-08-09 14:30:37,887-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:38,156-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:38,156-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:38,388-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:38,657-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:38,657-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:38,888-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:39,157-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:39,157-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:39,388-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:39,657-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:39,657-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:39,888-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:40,157-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:40,158-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:40,388-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:40,658-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:40,658-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:40,889-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:41,158-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:41,158-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:41,389-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:41,658-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:41,658-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:41,889-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:42,159-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:42,159-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:42,390-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:42,659-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:42,659-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:42,890-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:30:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 12.61 MB
+2013-08-09 14:30:43,159-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:43,159-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:43,390-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:43,659-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:43,659-0500 INFO ThrottleManager mem=12.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:43,890-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:44,160-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:44,160-0500 INFO ThrottleManager mem=12.69 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:44,391-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:44,660-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:44,660-0500 INFO ThrottleManager mem=12.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:44,891-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:45,160-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:45,160-0500 INFO ThrottleManager mem=12.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:45,160-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:30:45,391-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:45,391-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:30:45,661-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:45,661-0500 INFO ThrottleManager mem=12.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:45,891-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:46,161-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:46,161-0500 INFO ThrottleManager mem=12.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:46,392-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:46,661-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:46,661-0500 INFO ThrottleManager mem=12.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:46,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:30:46,892-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:47,161-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:47,161-0500 INFO ThrottleManager mem=12.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:47,392-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:47,662-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:47,662-0500 INFO ThrottleManager mem=12.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:47,871-0500 INFO Multiplexer No streams
+2013-08-09 14:30:47,892-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:48,162-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:48,162-0500 INFO ThrottleManager mem=12.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:48,393-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:48,662-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:48,662-0500 INFO ThrottleManager mem=12.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:48,893-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:49,162-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:49,162-0500 INFO ThrottleManager mem=12.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:49,393-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:49,663-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:49,663-0500 INFO ThrottleManager mem=12.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:49,893-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:50,163-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:50,163-0500 INFO ThrottleManager mem=12.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:50,393-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:50,663-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:50,663-0500 INFO ThrottleManager mem=12.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:50,894-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:51,163-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:51,163-0500 INFO ThrottleManager mem=12.82 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:51,394-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:51,664-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:51,664-0500 INFO ThrottleManager mem=12.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:51,894-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:52,164-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:52,164-0500 INFO ThrottleManager mem=12.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:52,394-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:52,664-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:52,664-0500 INFO ThrottleManager mem=12.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:52,895-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:30:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 12.95 MB
+2013-08-09 14:30:53,165-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:53,165-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:53,395-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:53,665-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:53,665-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:53,895-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:54,165-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:54,165-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:54,395-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:54,665-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:54,665-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:54,896-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:55,166-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:55,166-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:55,166-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:30:55,396-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:55,396-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:30:55,666-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:55,666-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:55,896-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:56,166-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:56,166-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:56,396-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:56,666-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:56,667-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:56,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:30:56,897-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:57,167-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:57,167-0500 INFO ThrottleManager mem=13.02 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:57,397-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:57,667-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:57,667-0500 INFO ThrottleManager mem=13.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:57,876-0500 INFO Multiplexer No streams
+2013-08-09 14:30:57,897-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:58,167-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:58,167-0500 INFO ThrottleManager mem=13.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:58,397-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:58,668-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:58,668-0500 INFO ThrottleManager mem=13.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:58,898-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:59,168-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:59,168-0500 INFO ThrottleManager mem=13.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:59,398-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:59,668-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:30:59,668-0500 INFO ThrottleManager mem=13.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:30:59,898-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:00,168-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:00,168-0500 INFO ThrottleManager mem=13.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:00,398-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:00,669-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:00,669-0500 INFO ThrottleManager mem=13.11 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:00,899-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:01,169-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:01,169-0500 INFO ThrottleManager mem=13.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:01,399-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:01,669-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:01,669-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:01,899-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:02,169-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:02,170-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:02,399-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:02,670-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:02,670-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:02,899-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:31:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 13.23 MB
+2013-08-09 14:31:03,170-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:03,170-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:03,400-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:03,670-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:03,670-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:03,900-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:04,171-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:04,171-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:04,400-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:04,671-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:04,671-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:04,900-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:05,171-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:05,171-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:05,171-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:31:05,401-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:05,401-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:31:05,671-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:05,671-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:05,901-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:06,172-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:06,172-0500 INFO ThrottleManager mem=13.23 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:06,401-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:06,672-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:06,672-0500 INFO ThrottleManager mem=13.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:06,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:31:06,902-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:07,172-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:07,172-0500 INFO ThrottleManager mem=13.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:07,402-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:07,672-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:07,672-0500 INFO ThrottleManager mem=13.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:07,881-0500 INFO Multiplexer No streams
+2013-08-09 14:31:07,902-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:08,173-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:08,173-0500 INFO ThrottleManager mem=13.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:08,402-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:08,673-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:08,673-0500 INFO ThrottleManager mem=13.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:08,902-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:09,173-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:09,173-0500 INFO ThrottleManager mem=13.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:09,403-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:09,673-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:09,674-0500 INFO ThrottleManager mem=13.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:09,903-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:10,174-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:10,174-0500 INFO ThrottleManager mem=13.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:10,403-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:10,674-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:10,674-0500 INFO ThrottleManager mem=13.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:10,903-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:11,174-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:11,174-0500 INFO ThrottleManager mem=13.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:11,404-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:11,675-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:11,675-0500 INFO ThrottleManager mem=13.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:11,904-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:12,175-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:12,175-0500 INFO ThrottleManager mem=13.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:12,404-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:12,675-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:12,675-0500 INFO ThrottleManager mem=13.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:12,905-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:31:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 13.44 MB
+2013-08-09 14:31:13,175-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:13,175-0500 INFO ThrottleManager mem=13.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:13,405-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:13,676-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:13,676-0500 INFO ThrottleManager mem=13.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:13,905-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:14,176-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:14,176-0500 INFO ThrottleManager mem=13.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:14,405-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:14,676-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:14,676-0500 INFO ThrottleManager mem=13.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:14,905-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:15,176-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:15,177-0500 INFO ThrottleManager mem=13.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:15,177-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:31:15,406-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:15,406-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:31:15,677-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:15,677-0500 INFO ThrottleManager mem=13.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:15,906-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:16,177-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:16,177-0500 INFO ThrottleManager mem=13.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:16,406-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:16,677-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:16,677-0500 INFO ThrottleManager mem=13.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:16,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:31:16,906-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:17,178-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:17,178-0500 INFO ThrottleManager mem=13.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:17,407-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:17,678-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:17,678-0500 INFO ThrottleManager mem=13.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:17,888-0500 INFO Multiplexer No streams
+2013-08-09 14:31:17,907-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:18,178-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:18,178-0500 INFO ThrottleManager mem=13.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:18,407-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:18,678-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:18,678-0500 INFO ThrottleManager mem=13.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:18,907-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:19,179-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:19,179-0500 INFO ThrottleManager mem=13.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:19,408-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:19,679-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:19,679-0500 INFO ThrottleManager mem=13.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:19,908-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:20,179-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:20,179-0500 INFO ThrottleManager mem=13.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:20,408-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:20,679-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:20,679-0500 INFO ThrottleManager mem=13.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:20,908-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:21,180-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:21,180-0500 INFO ThrottleManager mem=13.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:21,409-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:21,680-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:21,680-0500 INFO ThrottleManager mem=13.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:21,909-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:22,180-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:22,180-0500 INFO ThrottleManager mem=13.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:22,409-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:22,680-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:22,681-0500 INFO ThrottleManager mem=13.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:22,909-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:22,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:31:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 13.68 MB
+2013-08-09 14:31:23,181-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:23,181-0500 INFO ThrottleManager mem=13.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:23,410-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:23,681-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:23,681-0500 INFO ThrottleManager mem=13.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:23,910-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:24,181-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:24,181-0500 INFO ThrottleManager mem=13.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:24,410-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:24,682-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:24,682-0500 INFO ThrottleManager mem=13.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:24,911-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:25,182-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:25,182-0500 INFO ThrottleManager mem=13.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:25,182-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:31:25,411-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:25,411-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:31:25,682-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:25,682-0500 INFO ThrottleManager mem=13.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:25,911-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:26,182-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:26,182-0500 INFO ThrottleManager mem=13.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:26,411-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:26,683-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:26,683-0500 INFO ThrottleManager mem=13.84 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:26,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:31:26,911-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:27,183-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:27,183-0500 INFO ThrottleManager mem=13.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:27,412-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:27,683-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:27,683-0500 INFO ThrottleManager mem=13.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:27,894-0500 INFO Multiplexer No streams
+2013-08-09 14:31:27,912-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:28,183-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:28,184-0500 INFO ThrottleManager mem=13.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:28,412-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:28,684-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:28,684-0500 INFO ThrottleManager mem=13.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:28,912-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:29,184-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:29,184-0500 INFO ThrottleManager mem=13.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:29,413-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:29,684-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:29,684-0500 INFO ThrottleManager mem=13.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:29,913-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:30,185-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:30,185-0500 INFO ThrottleManager mem=13.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:30,413-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:30,685-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:30,685-0500 INFO ThrottleManager mem=13.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:30,913-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:31,185-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:31,185-0500 INFO ThrottleManager mem=13.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:31,414-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:31,685-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:31,685-0500 INFO ThrottleManager mem=13.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:31,914-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:32,186-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:32,186-0500 INFO ThrottleManager mem=13.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:32,414-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:32,686-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:32,686-0500 INFO ThrottleManager mem=13.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:32,914-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:32,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:31:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 13.97 MB
+2013-08-09 14:31:33,186-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:33,186-0500 INFO ThrottleManager mem=13.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:33,415-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:33,686-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:33,686-0500 INFO ThrottleManager mem=13.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:33,915-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:34,187-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:34,187-0500 INFO ThrottleManager mem=13.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:34,415-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:34,687-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:34,687-0500 INFO ThrottleManager mem=14.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:34,915-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:35,187-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:35,187-0500 INFO ThrottleManager mem=14.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:35,187-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:31:35,416-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:35,416-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:31:35,688-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:35,688-0500 INFO ThrottleManager mem=14.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:35,916-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:36,188-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:36,188-0500 INFO ThrottleManager mem=14.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:36,416-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:36,688-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:36,688-0500 INFO ThrottleManager mem=14.06 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:36,762-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:31:36,917-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:37,188-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:37,188-0500 INFO ThrottleManager mem=14.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:37,417-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:37,689-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:37,689-0500 INFO ThrottleManager mem=14.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:37,898-0500 INFO Multiplexer No streams
+2013-08-09 14:31:37,917-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:38,189-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:38,189-0500 INFO ThrottleManager mem=14.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:38,417-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:38,689-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:38,689-0500 INFO ThrottleManager mem=14.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:38,918-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:39,189-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:39,189-0500 INFO ThrottleManager mem=14.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:39,418-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:39,690-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:39,690-0500 INFO ThrottleManager mem=14.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:39,918-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:40,190-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:40,190-0500 INFO ThrottleManager mem=14.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:40,418-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:40,690-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:40,690-0500 INFO ThrottleManager mem=14.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:40,918-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:41,191-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:41,191-0500 INFO ThrottleManager mem=14.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:41,419-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:41,691-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:41,691-0500 INFO ThrottleManager mem=14.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:41,919-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:42,191-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:42,191-0500 INFO ThrottleManager mem=14.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:42,419-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:42,691-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:42,691-0500 INFO ThrottleManager mem=14.18 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:42,920-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:31:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 14.22 MB
+2013-08-09 14:31:43,192-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:43,192-0500 INFO ThrottleManager mem=14.22 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:43,420-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:43,692-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:43,692-0500 INFO ThrottleManager mem=14.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:43,920-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:44,192-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:44,192-0500 INFO ThrottleManager mem=14.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:44,420-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:44,692-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:44,692-0500 INFO ThrottleManager mem=14.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:44,921-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:45,193-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:45,193-0500 INFO ThrottleManager mem=14.26 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:45,193-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:31:45,421-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:45,421-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:31:45,693-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:45,693-0500 INFO ThrottleManager mem=14.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:45,921-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:46,193-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:46,193-0500 INFO ThrottleManager mem=14.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:46,421-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:46,693-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:46,694-0500 INFO ThrottleManager mem=14.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:46,763-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:31:46,922-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:47,194-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:47,194-0500 INFO ThrottleManager mem=14.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:47,422-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:47,694-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:47,694-0500 INFO ThrottleManager mem=14.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:47,904-0500 INFO Multiplexer No streams
+2013-08-09 14:31:47,922-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:48,194-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:48,194-0500 INFO ThrottleManager mem=14.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:48,422-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:48,695-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:48,695-0500 INFO ThrottleManager mem=14.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:48,923-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:49,195-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:49,195-0500 INFO ThrottleManager mem=14.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:49,423-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:49,695-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:49,695-0500 INFO ThrottleManager mem=14.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:49,923-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:50,195-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:50,195-0500 INFO ThrottleManager mem=14.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:50,423-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:50,696-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:50,696-0500 INFO ThrottleManager mem=14.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:50,924-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:51,196-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:51,196-0500 INFO ThrottleManager mem=14.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:51,424-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:51,696-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:51,696-0500 INFO ThrottleManager mem=14.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:51,924-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:52,196-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:52,197-0500 INFO ThrottleManager mem=14.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:52,424-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:52,697-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:52,697-0500 INFO ThrottleManager mem=14.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:52,924-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:52,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:31:52,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 14.48 MB
+2013-08-09 14:31:53,197-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:53,197-0500 INFO ThrottleManager mem=14.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:53,425-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:53,697-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:53,697-0500 INFO ThrottleManager mem=14.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:53,925-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:54,198-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:54,198-0500 INFO ThrottleManager mem=14.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:54,425-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:54,698-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:54,698-0500 INFO ThrottleManager mem=14.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:54,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:55,198-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:55,198-0500 INFO ThrottleManager mem=14.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:55,198-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:31:55,426-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:55,426-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:31:55,698-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:55,698-0500 INFO ThrottleManager mem=14.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:55,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:56,199-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:56,199-0500 INFO ThrottleManager mem=14.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:56,426-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:56,699-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:56,699-0500 INFO ThrottleManager mem=14.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:56,763-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:31:56,926-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:57,199-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:57,199-0500 INFO ThrottleManager mem=14.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:57,427-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:57,699-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:57,700-0500 INFO ThrottleManager mem=14.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:57,909-0500 INFO Multiplexer No streams
+2013-08-09 14:31:57,927-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:58,200-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:58,200-0500 INFO ThrottleManager mem=14.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:58,427-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:58,700-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:58,700-0500 INFO ThrottleManager mem=14.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:58,927-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:59,200-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:59,200-0500 INFO ThrottleManager mem=14.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:59,428-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:59,701-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:31:59,701-0500 INFO ThrottleManager mem=14.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:31:59,928-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:00,201-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:00,201-0500 INFO ThrottleManager mem=14.64 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:00,428-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:00,701-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:00,701-0500 INFO ThrottleManager mem=14.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:00,928-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:01,201-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:01,201-0500 INFO ThrottleManager mem=14.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:01,429-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:01,702-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:01,702-0500 INFO ThrottleManager mem=14.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:01,929-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:02,202-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:02,202-0500 INFO ThrottleManager mem=14.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:02,429-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:02,702-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:02,702-0500 INFO ThrottleManager mem=14.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:02,929-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:02,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:32:02,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 14.72 MB
+2013-08-09 14:32:03,202-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:03,203-0500 INFO ThrottleManager mem=14.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:03,430-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:03,703-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:03,703-0500 INFO ThrottleManager mem=14.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:03,930-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:04,203-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:04,203-0500 INFO ThrottleManager mem=14.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:04,430-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:04,703-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:04,703-0500 INFO ThrottleManager mem=14.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:04,930-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:05,204-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:05,204-0500 INFO ThrottleManager mem=14.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:05,204-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:32:05,431-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:05,431-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:32:05,704-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:05,704-0500 INFO ThrottleManager mem=14.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:05,931-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:06,204-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:06,204-0500 INFO ThrottleManager mem=14.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:06,431-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:06,704-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:06,704-0500 INFO ThrottleManager mem=14.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:06,763-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:32:06,932-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:07,205-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:07,205-0500 INFO ThrottleManager mem=14.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:07,432-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:07,705-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:07,705-0500 INFO ThrottleManager mem=14.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:07,913-0500 INFO Multiplexer No streams
+2013-08-09 14:32:07,932-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:08,205-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:08,205-0500 INFO ThrottleManager mem=14.84 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:08,432-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:08,706-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:08,706-0500 INFO ThrottleManager mem=14.88 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:08,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:09,206-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:09,206-0500 INFO ThrottleManager mem=14.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:09,433-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:09,706-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:09,706-0500 INFO ThrottleManager mem=14.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:09,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:10,206-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:10,206-0500 INFO ThrottleManager mem=14.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:10,433-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:10,707-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:10,707-0500 INFO ThrottleManager mem=14.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:10,933-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:11,207-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:11,207-0500 INFO ThrottleManager mem=14.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:11,434-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:11,707-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:11,707-0500 INFO ThrottleManager mem=14.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:11,934-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:12,207-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:12,207-0500 INFO ThrottleManager mem=14.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:12,434-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:12,708-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:12,708-0500 INFO ThrottleManager mem=14.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:12,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:32:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 15.01 MB
+2013-08-09 14:32:13,208-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:13,208-0500 INFO ThrottleManager mem=15.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:13,435-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:13,708-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:13,708-0500 INFO ThrottleManager mem=15.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:13,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:14,208-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:14,208-0500 INFO ThrottleManager mem=15.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:14,435-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:14,709-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:14,709-0500 INFO ThrottleManager mem=15.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:14,935-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:15,209-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:15,209-0500 INFO ThrottleManager mem=15.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:15,209-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:32:15,436-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:15,436-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:32:15,709-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:15,709-0500 INFO ThrottleManager mem=15.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:15,936-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:16,209-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:16,209-0500 INFO ThrottleManager mem=15.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:16,436-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:16,710-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:16,710-0500 INFO ThrottleManager mem=15.05 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:16,763-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:32:16,936-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:17,210-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:17,210-0500 INFO ThrottleManager mem=15.09 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:17,437-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:17,710-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:17,710-0500 INFO ThrottleManager mem=15.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:17,917-0500 INFO Multiplexer No streams
+2013-08-09 14:32:17,937-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:18,210-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:18,211-0500 INFO ThrottleManager mem=15.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:18,437-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:18,711-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:18,711-0500 INFO ThrottleManager mem=15.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:18,937-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:19,211-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:19,211-0500 INFO ThrottleManager mem=15.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:19,438-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:19,711-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:19,711-0500 INFO ThrottleManager mem=15.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:19,938-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:20,212-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:20,212-0500 INFO ThrottleManager mem=15.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:20,438-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:20,712-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:20,712-0500 INFO ThrottleManager mem=15.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:20,938-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:21,212-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:21,212-0500 INFO ThrottleManager mem=15.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:21,439-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:21,712-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:21,712-0500 INFO ThrottleManager mem=15.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:21,939-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:22,213-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:22,213-0500 INFO ThrottleManager mem=15.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:22,439-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:22,713-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:22,713-0500 INFO ThrottleManager mem=15.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:22,939-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:22,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:32:22,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 15.21 MB
+2013-08-09 14:32:23,213-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:23,213-0500 INFO ThrottleManager mem=15.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:23,440-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:23,713-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:23,714-0500 INFO ThrottleManager mem=15.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:23,940-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:24,214-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:24,214-0500 INFO ThrottleManager mem=15.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:24,440-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:24,714-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:24,714-0500 INFO ThrottleManager mem=15.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:24,940-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:25,214-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:25,214-0500 INFO ThrottleManager mem=15.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:25,214-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:32:25,441-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:25,441-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:32:25,715-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:25,715-0500 INFO ThrottleManager mem=15.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:25,941-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:26,215-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:26,215-0500 INFO ThrottleManager mem=15.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:26,441-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:26,715-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:26,715-0500 INFO ThrottleManager mem=15.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:26,763-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:32:26,941-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:27,215-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:27,215-0500 INFO ThrottleManager mem=15.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:27,442-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:27,716-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:27,716-0500 INFO ThrottleManager mem=15.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:27,923-0500 INFO Multiplexer No streams
+2013-08-09 14:32:27,942-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:28,216-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:28,216-0500 INFO ThrottleManager mem=15.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:28,442-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:28,716-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:28,716-0500 INFO ThrottleManager mem=15.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:28,942-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:29,216-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:29,217-0500 INFO ThrottleManager mem=15.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:29,443-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:29,717-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:29,717-0500 INFO ThrottleManager mem=15.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:29,943-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:30,217-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:30,217-0500 INFO ThrottleManager mem=15.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:30,443-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:30,717-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:30,717-0500 INFO ThrottleManager mem=15.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:30,943-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:31,218-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:31,218-0500 INFO ThrottleManager mem=15.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:31,444-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:31,718-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:31,718-0500 INFO ThrottleManager mem=15.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:31,944-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:32,218-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:32,218-0500 INFO ThrottleManager mem=15.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:32,444-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:32,718-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:32,718-0500 INFO ThrottleManager mem=15.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:32,944-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:32,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:32:32,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 15.46 MB
+2013-08-09 14:32:33,219-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:33,219-0500 INFO ThrottleManager mem=15.46 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:33,444-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:33,719-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:33,719-0500 INFO ThrottleManager mem=15.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:33,945-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:34,219-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:34,219-0500 INFO ThrottleManager mem=15.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:34,445-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:34,719-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:34,720-0500 INFO ThrottleManager mem=15.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:34,945-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:35,220-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:35,220-0500 INFO ThrottleManager mem=15.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:35,220-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:32:35,445-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:35,446-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:32:35,720-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:35,720-0500 INFO ThrottleManager mem=15.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:35,946-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:36,221-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:36,221-0500 INFO ThrottleManager mem=15.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:36,446-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:36,721-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:36,721-0500 INFO ThrottleManager mem=15.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:36,764-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:32:36,946-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:37,221-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:37,221-0500 INFO ThrottleManager mem=15.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:37,446-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:37,721-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:37,721-0500 INFO ThrottleManager mem=15.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:37,929-0500 INFO Multiplexer No streams
+2013-08-09 14:32:37,946-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:38,222-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:38,222-0500 INFO ThrottleManager mem=15.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:38,447-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:38,722-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:38,722-0500 INFO ThrottleManager mem=15.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:38,947-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:39,222-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:39,222-0500 INFO ThrottleManager mem=15.63 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:39,447-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:39,722-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:39,723-0500 INFO ThrottleManager mem=15.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:39,947-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:40,223-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:40,223-0500 INFO ThrottleManager mem=15.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:40,448-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:40,723-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:40,723-0500 INFO ThrottleManager mem=15.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:40,948-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:41,224-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:41,224-0500 INFO ThrottleManager mem=15.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:41,448-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:41,724-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:41,724-0500 INFO ThrottleManager mem=15.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:41,948-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:42,224-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:42,224-0500 INFO ThrottleManager mem=15.71 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:42,449-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:42,724-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:42,724-0500 INFO ThrottleManager mem=15.71 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:42,949-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:42,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:32:42,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 15.75 MB
+2013-08-09 14:32:43,225-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:43,225-0500 INFO ThrottleManager mem=15.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:43,449-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:43,725-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:43,725-0500 INFO ThrottleManager mem=15.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:43,949-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:44,225-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:44,225-0500 INFO ThrottleManager mem=15.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:44,450-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:44,725-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:44,725-0500 INFO ThrottleManager mem=15.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:44,950-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:45,226-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:45,226-0500 INFO ThrottleManager mem=15.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:45,226-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:32:45,450-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:45,450-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:32:45,726-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:45,726-0500 INFO ThrottleManager mem=15.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:45,950-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:46,226-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:46,226-0500 INFO ThrottleManager mem=15.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:46,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:46,726-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:46,727-0500 INFO ThrottleManager mem=15.83 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:46,764-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:32:46,951-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:47,227-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:47,227-0500 INFO ThrottleManager mem=15.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:47,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:47,727-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:47,727-0500 INFO ThrottleManager mem=15.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:47,933-0500 INFO Multiplexer No streams
+2013-08-09 14:32:47,951-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:48,227-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:48,227-0500 INFO ThrottleManager mem=15.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:48,451-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:48,728-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:48,728-0500 INFO ThrottleManager mem=15.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:48,952-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:49,228-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:49,228-0500 INFO ThrottleManager mem=15.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:49,452-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:49,728-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:49,728-0500 INFO ThrottleManager mem=15.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:49,952-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:50,228-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:50,228-0500 INFO ThrottleManager mem=15.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:50,452-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:50,729-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:50,729-0500 INFO ThrottleManager mem=15.91 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:50,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:51,229-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:51,229-0500 INFO ThrottleManager mem=15.91 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:51,453-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:51,729-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:51,729-0500 INFO ThrottleManager mem=15.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:51,953-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:52,229-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:52,229-0500 INFO ThrottleManager mem=15.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:52,453-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:52,730-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:52,730-0500 INFO ThrottleManager mem=15.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:52,954-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:32:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 16.04 MB
+2013-08-09 14:32:53,230-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:53,230-0500 INFO ThrottleManager mem=16.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:53,454-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:53,730-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:53,731-0500 INFO ThrottleManager mem=16.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:53,954-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:54,231-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:54,231-0500 INFO ThrottleManager mem=16.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:54,454-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:54,731-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:54,731-0500 INFO ThrottleManager mem=16.04 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:54,955-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:55,231-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:55,231-0500 INFO ThrottleManager mem=16.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:55,231-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:32:55,455-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:55,455-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:32:55,732-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:55,732-0500 INFO ThrottleManager mem=16.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:55,955-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:56,232-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:56,232-0500 INFO ThrottleManager mem=16.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:56,455-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:56,732-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:56,732-0500 INFO ThrottleManager mem=16.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:56,764-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:32:56,955-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:57,232-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:57,233-0500 INFO ThrottleManager mem=16.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:57,456-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:57,733-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:57,733-0500 INFO ThrottleManager mem=16.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:57,937-0500 INFO Multiplexer No streams
+2013-08-09 14:32:57,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:58,233-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:58,233-0500 INFO ThrottleManager mem=16.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:58,456-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:58,733-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:58,733-0500 INFO ThrottleManager mem=16.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:58,956-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:59,234-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:59,234-0500 INFO ThrottleManager mem=16.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:59,457-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:59,734-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:32:59,734-0500 INFO ThrottleManager mem=16.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:32:59,957-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:00,234-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:00,234-0500 INFO ThrottleManager mem=16.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:00,457-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:00,734-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:00,734-0500 INFO ThrottleManager mem=16.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:00,957-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:01,235-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:01,235-0500 INFO ThrottleManager mem=16.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:01,458-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:01,735-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:01,735-0500 INFO ThrottleManager mem=16.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:01,958-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:02,235-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:02,235-0500 INFO ThrottleManager mem=16.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:02,458-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:02,735-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:02,735-0500 INFO ThrottleManager mem=16.25 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:02,958-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:33:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 16.28 MB
+2013-08-09 14:33:03,236-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:03,236-0500 INFO ThrottleManager mem=16.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:03,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:03,736-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:03,736-0500 INFO ThrottleManager mem=16.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:03,959-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:04,236-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:04,236-0500 INFO ThrottleManager mem=16.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:04,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:04,736-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:04,737-0500 INFO ThrottleManager mem=16.28 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:04,959-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:05,237-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:05,237-0500 INFO ThrottleManager mem=16.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:05,237-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:33:05,459-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:05,460-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:33:05,737-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:05,737-0500 INFO ThrottleManager mem=16.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:05,960-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:06,238-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:06,238-0500 INFO ThrottleManager mem=16.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:06,460-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:06,738-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:06,738-0500 INFO ThrottleManager mem=16.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:06,764-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:33:06,960-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:07,238-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:07,238-0500 INFO ThrottleManager mem=16.29 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:07,460-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:07,738-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:07,738-0500 INFO ThrottleManager mem=16.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:07,957-0500 INFO Multiplexer No streams
+2013-08-09 14:33:07,961-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:08,239-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:08,239-0500 INFO ThrottleManager mem=16.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:08,461-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:08,739-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:08,739-0500 INFO ThrottleManager mem=16.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:08,961-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:09,239-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:09,239-0500 INFO ThrottleManager mem=16.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:09,461-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:09,739-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:09,740-0500 INFO ThrottleManager mem=16.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:09,962-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:10,240-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:10,240-0500 INFO ThrottleManager mem=16.45 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:10,462-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:10,740-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:10,740-0500 INFO ThrottleManager mem=16.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:10,962-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:11,241-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:11,241-0500 INFO ThrottleManager mem=16.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:11,462-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:11,741-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:11,741-0500 INFO ThrottleManager mem=16.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:11,963-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:12,241-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:12,241-0500 INFO ThrottleManager mem=16.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:12,463-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:12,741-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:12,741-0500 INFO ThrottleManager mem=16.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:33:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 16.49 MB
+2013-08-09 14:33:12,963-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:13,242-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:13,242-0500 INFO ThrottleManager mem=16.49 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:13,463-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:13,742-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:13,742-0500 INFO ThrottleManager mem=16.49 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:13,963-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:14,242-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:14,242-0500 INFO ThrottleManager mem=16.49 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:14,464-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:14,742-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:14,742-0500 INFO ThrottleManager mem=16.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:14,964-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:15,243-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:15,243-0500 INFO ThrottleManager mem=16.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:15,243-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:33:15,464-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:15,464-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:33:15,743-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:15,743-0500 INFO ThrottleManager mem=16.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:15,964-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:16,243-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:16,243-0500 INFO ThrottleManager mem=16.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:16,465-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:16,743-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:16,743-0500 INFO ThrottleManager mem=16.66 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:16,765-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:33:16,965-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:17,244-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:17,244-0500 INFO ThrottleManager mem=16.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:17,465-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:17,744-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:17,744-0500 INFO ThrottleManager mem=16.67 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:17,959-0500 INFO Multiplexer No streams
+2013-08-09 14:33:17,965-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:18,244-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:18,244-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:18,466-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:18,744-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:18,744-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:18,966-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:19,245-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:19,245-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:19,466-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:19,745-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:19,745-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:19,966-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:20,245-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:20,245-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:20,467-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:20,745-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:20,746-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:20,967-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:21,246-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:21,246-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:21,467-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:21,746-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:21,746-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:21,967-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:22,246-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:22,246-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:22,467-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:22,747-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:22,747-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:33:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 16.7 MB
+2013-08-09 14:33:22,968-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:23,247-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:23,247-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:23,468-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:23,747-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:23,747-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:23,968-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:24,248-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:24,248-0500 INFO ThrottleManager mem=16.7 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:24,468-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:24,748-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:24,748-0500 INFO ThrottleManager mem=16.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:24,969-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:25,248-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:25,248-0500 INFO ThrottleManager mem=16.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:25,248-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:33:25,469-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:25,469-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:33:25,749-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:25,749-0500 INFO ThrottleManager mem=16.87 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:25,969-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:26,249-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:26,249-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:26,469-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:26,749-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:26,749-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:26,764-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:33:26,970-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:27,249-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:27,249-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:27,470-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:27,750-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:27,750-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:27,962-0500 INFO Multiplexer No streams
+2013-08-09 14:33:27,970-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:28,250-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:28,250-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:28,470-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:28,750-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:28,750-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:28,971-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:29,250-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:29,250-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:29,471-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:29,751-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:29,751-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:29,971-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:30,251-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:30,251-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:30,471-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:30,751-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:30,751-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:30,972-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:31,251-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:31,252-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:31,472-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:31,752-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:31,752-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:31,972-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:32,252-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:32,252-0500 INFO ThrottleManager mem=16.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:32,472-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:32,753-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:32,753-0500 INFO ThrottleManager mem=16.95 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:33:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 17.03 MB
+2013-08-09 14:33:32,973-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:33,253-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:33,253-0500 INFO ThrottleManager mem=17.03 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:33,473-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:33,753-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:33,753-0500 INFO ThrottleManager mem=17.08 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:33,973-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:34,253-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:34,253-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:34,473-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:34,754-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:34,754-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:34,973-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:35,254-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:35,254-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:35,254-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:33:35,474-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:35,474-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:33:35,754-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:35,754-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:35,974-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:36,255-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:36,255-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:36,474-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:36,755-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:36,755-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:36,764-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:33:36,974-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:37,255-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:37,255-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:37,475-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:37,755-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:37,756-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:37,963-0500 INFO Multiplexer No streams
+2013-08-09 14:33:37,975-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:38,256-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:38,256-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:38,475-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:38,756-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:38,756-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:38,975-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:39,256-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:39,256-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:39,476-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:39,757-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:39,757-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:39,976-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:40,257-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:40,257-0500 INFO ThrottleManager mem=17.12 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:40,476-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:40,757-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:40,757-0500 INFO ThrottleManager mem=17.2 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:40,976-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:41,258-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:41,258-0500 INFO ThrottleManager mem=17.24 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:41,477-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:41,758-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:41,758-0500 INFO ThrottleManager mem=17.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:41,977-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:42,258-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:42,258-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:42,477-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:42,758-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:42,758-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:33:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 17.32 MB
+2013-08-09 14:33:42,977-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:43,259-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:43,259-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:43,477-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:43,759-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:43,759-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:43,978-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:44,259-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:44,259-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:44,478-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:44,759-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:44,760-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:44,978-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:45,260-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:45,260-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:45,260-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:33:45,478-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:45,478-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:33:45,760-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:45,760-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:45,979-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:46,260-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:46,260-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:46,479-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:46,761-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:46,761-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:46,764-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:33:46,979-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:47,261-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:47,261-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:47,479-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:47,761-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:47,761-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:47,970-0500 INFO Multiplexer No streams
+2013-08-09 14:33:47,980-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:48,261-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:48,261-0500 INFO ThrottleManager mem=17.32 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:48,480-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:48,762-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:48,762-0500 INFO ThrottleManager mem=17.4 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:48,980-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:49,262-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:49,262-0500 INFO ThrottleManager mem=17.44 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:49,480-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:49,762-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:49,762-0500 INFO ThrottleManager mem=17.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:49,981-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:50,262-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:50,263-0500 INFO ThrottleManager mem=17.48 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:50,481-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:50,763-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:50,763-0500 INFO ThrottleManager mem=17.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:50,981-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:51,263-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:51,263-0500 INFO ThrottleManager mem=17.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:51,481-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:51,763-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:51,763-0500 INFO ThrottleManager mem=17.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:51,982-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:52,263-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:52,264-0500 INFO ThrottleManager mem=17.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:52,482-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:52,764-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:52,764-0500 INFO ThrottleManager mem=17.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:33:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 17.53 MB
+2013-08-09 14:33:52,982-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:53,264-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:53,264-0500 INFO ThrottleManager mem=17.53 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:53,482-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:53,764-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:53,765-0500 INFO ThrottleManager mem=17.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:53,982-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:54,265-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:54,265-0500 INFO ThrottleManager mem=17.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:54,483-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:54,765-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:54,765-0500 INFO ThrottleManager mem=17.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:54,983-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:55,265-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:55,265-0500 INFO ThrottleManager mem=17.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:55,265-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:33:55,483-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:55,483-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:33:55,766-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:55,766-0500 INFO ThrottleManager mem=17.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:55,983-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:56,266-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:56,266-0500 INFO ThrottleManager mem=17.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:56,483-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:56,764-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:33:56,766-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:56,766-0500 INFO ThrottleManager mem=17.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:56,984-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:57,266-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:57,267-0500 INFO ThrottleManager mem=17.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:57,484-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:57,767-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:57,767-0500 INFO ThrottleManager mem=17.65 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:57,984-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:57,988-0500 INFO Multiplexer No streams
+2013-08-09 14:33:58,267-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:58,267-0500 INFO ThrottleManager mem=17.69 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:58,484-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:58,767-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:58,767-0500 INFO ThrottleManager mem=17.69 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:58,985-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:59,268-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:59,268-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:59,485-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:59,768-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:33:59,768-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:33:59,985-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:00,268-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:00,268-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:00,485-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:00,768-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:00,768-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:00,986-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:01,269-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:01,269-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:01,486-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:01,769-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:01,769-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:01,986-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:02,269-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:02,269-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:02,486-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:02,769-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:02,770-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:02,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:34:02,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 17.73 MB
+2013-08-09 14:34:02,987-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:03,270-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:03,270-0500 INFO ThrottleManager mem=17.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:03,487-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:03,770-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:03,770-0500 INFO ThrottleManager mem=17.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:03,987-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:04,270-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:04,270-0500 INFO ThrottleManager mem=17.74 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:04,487-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:04,771-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:04,771-0500 INFO ThrottleManager mem=17.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:04,987-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:05,271-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:05,271-0500 INFO ThrottleManager mem=17.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:05,271-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:34:05,488-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:05,488-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:34:05,771-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:05,771-0500 INFO ThrottleManager mem=17.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:05,988-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:06,272-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:06,272-0500 INFO ThrottleManager mem=17.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:06,488-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:06,765-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:34:06,772-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:06,772-0500 INFO ThrottleManager mem=17.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:06,988-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:07,272-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:07,272-0500 INFO ThrottleManager mem=17.9 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:07,489-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:07,772-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:07,772-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:07,989-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:07,990-0500 INFO Multiplexer No streams
+2013-08-09 14:34:08,273-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:08,273-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:08,489-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:08,773-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:08,773-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:08,989-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:09,273-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:09,273-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:09,489-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:09,773-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:09,774-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:09,990-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:10,274-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:10,274-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:10,490-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:10,774-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:10,774-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:10,990-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:11,274-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:11,275-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:11,490-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:11,775-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:11,775-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:11,991-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:12,275-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:12,275-0500 INFO ThrottleManager mem=17.94 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:12,491-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:12,775-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:12,775-0500 INFO ThrottleManager mem=18.05 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:12,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:34:12,960-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 18.06 MB
+2013-08-09 14:34:12,991-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:13,276-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:13,276-0500 INFO ThrottleManager mem=18.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:13,491-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:13,776-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:13,776-0500 INFO ThrottleManager mem=18.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:13,991-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:14,276-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:14,276-0500 INFO ThrottleManager mem=18.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:14,492-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:14,776-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:14,776-0500 INFO ThrottleManager mem=18.07 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:14,992-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:15,277-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:15,277-0500 INFO ThrottleManager mem=18.11 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:15,277-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:34:15,492-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:15,492-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:34:15,777-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:15,777-0500 INFO ThrottleManager mem=18.11 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:15,992-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:16,277-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:16,277-0500 INFO ThrottleManager mem=18.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:16,493-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:16,765-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:34:16,777-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:16,778-0500 INFO ThrottleManager mem=18.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:16,993-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:17,278-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:17,278-0500 INFO ThrottleManager mem=18.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:17,493-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:17,778-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:17,778-0500 INFO ThrottleManager mem=18.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:17,993-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:18,010-0500 INFO Multiplexer No streams
+2013-08-09 14:34:18,278-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:18,278-0500 INFO ThrottleManager mem=18.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:18,494-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:18,779-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:18,779-0500 INFO ThrottleManager mem=18.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:18,994-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:19,279-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:19,279-0500 INFO ThrottleManager mem=18.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:19,494-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:19,779-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:19,779-0500 INFO ThrottleManager mem=18.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:19,994-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:20,279-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:20,279-0500 INFO ThrottleManager mem=18.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:20,495-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:20,780-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:20,780-0500 INFO ThrottleManager mem=18.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:20,995-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:21,280-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:21,280-0500 INFO ThrottleManager mem=18.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:21,495-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:21,780-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:21,780-0500 INFO ThrottleManager mem=18.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:21,995-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:22,280-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:22,280-0500 INFO ThrottleManager mem=18.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:22,496-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:22,781-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:22,781-0500 INFO ThrottleManager mem=18.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:34:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 18.27 MB
+2013-08-09 14:34:22,996-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:23,281-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:23,281-0500 INFO ThrottleManager mem=18.27 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:23,496-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:23,781-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:23,782-0500 INFO ThrottleManager mem=18.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:23,996-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:24,282-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:24,282-0500 INFO ThrottleManager mem=18.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:24,496-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:24,782-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:24,782-0500 INFO ThrottleManager mem=18.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:24,997-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:25,282-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:25,282-0500 INFO ThrottleManager mem=18.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:25,282-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:34:25,497-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:25,497-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:34:25,783-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:25,783-0500 INFO ThrottleManager mem=18.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:25,997-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:26,283-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:26,283-0500 INFO ThrottleManager mem=18.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:26,497-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:26,765-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:34:26,783-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:26,783-0500 INFO ThrottleManager mem=18.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:26,998-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:27,283-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:27,283-0500 INFO ThrottleManager mem=18.36 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:27,498-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:27,784-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:27,784-0500 INFO ThrottleManager mem=18.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:27,998-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:28,013-0500 INFO Multiplexer No streams
+2013-08-09 14:34:28,284-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:28,284-0500 INFO ThrottleManager mem=18.39 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:28,498-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:28,784-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:28,784-0500 INFO ThrottleManager mem=18.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:28,999-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:29,284-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:29,285-0500 INFO ThrottleManager mem=18.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:29,499-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:29,785-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:29,785-0500 INFO ThrottleManager mem=18.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:29,999-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:30,285-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:30,285-0500 INFO ThrottleManager mem=18.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:30,499-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:30,785-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:30,785-0500 INFO ThrottleManager mem=18.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:30,999-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:31,285-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:31,285-0500 INFO ThrottleManager mem=18.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:31,500-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:31,786-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:31,786-0500 INFO ThrottleManager mem=18.47 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:32,000-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:32,286-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:32,286-0500 INFO ThrottleManager mem=18.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:32,500-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:32,786-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:32,786-0500 INFO ThrottleManager mem=18.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:34:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 18.57 MB
+2013-08-09 14:34:33,000-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:33,287-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:33,287-0500 INFO ThrottleManager mem=18.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:33,501-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:33,787-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:33,787-0500 INFO ThrottleManager mem=18.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:34,001-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:34,287-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:34,287-0500 INFO ThrottleManager mem=18.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:34,501-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:34,787-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:34,788-0500 INFO ThrottleManager mem=18.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:35,001-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:35,288-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:35,288-0500 INFO ThrottleManager mem=18.57 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:35,288-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:34:35,502-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:35,502-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:34:35,788-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:35,788-0500 INFO ThrottleManager mem=18.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:36,002-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:36,288-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:36,289-0500 INFO ThrottleManager mem=18.61 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:36,502-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:36,765-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:34:36,789-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:36,789-0500 INFO ThrottleManager mem=18.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:37,002-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:37,289-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:37,289-0500 INFO ThrottleManager mem=18.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:37,502-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:37,789-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:37,789-0500 INFO ThrottleManager mem=18.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:38,003-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:38,019-0500 INFO Multiplexer No streams
+2013-08-09 14:34:38,290-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:38,290-0500 INFO ThrottleManager mem=18.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:38,503-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:38,790-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:38,790-0500 INFO ThrottleManager mem=18.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:39,003-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:39,290-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:39,290-0500 INFO ThrottleManager mem=18.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:39,503-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:39,790-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:39,790-0500 INFO ThrottleManager mem=18.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:40,004-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:40,291-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:40,291-0500 INFO ThrottleManager mem=18.68 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:40,504-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:40,791-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:40,791-0500 INFO ThrottleManager mem=18.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:41,004-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:41,291-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:41,291-0500 INFO ThrottleManager mem=18.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:41,504-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:41,792-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:41,792-0500 INFO ThrottleManager mem=18.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:42,004-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:42,292-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:42,292-0500 INFO ThrottleManager mem=18.77 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:42,505-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:42,792-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:42,792-0500 INFO ThrottleManager mem=18.78 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:34:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 18.78 MB
+2013-08-09 14:34:43,005-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:43,292-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:43,292-0500 INFO ThrottleManager mem=18.78 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:43,505-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:43,793-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:43,793-0500 INFO ThrottleManager mem=18.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:44,005-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:44,293-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:44,293-0500 INFO ThrottleManager mem=18.81 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:44,506-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:44,793-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:44,793-0500 INFO ThrottleManager mem=18.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:45,006-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:45,293-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:45,293-0500 INFO ThrottleManager mem=18.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:45,293-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:34:45,506-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:45,506-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:34:45,794-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:45,794-0500 INFO ThrottleManager mem=18.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:46,006-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:46,294-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:46,294-0500 INFO ThrottleManager mem=18.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:46,506-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:46,765-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:34:46,794-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:46,794-0500 INFO ThrottleManager mem=18.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:47,007-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:47,294-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:47,294-0500 INFO ThrottleManager mem=18.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:47,507-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:47,794-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:47,794-0500 INFO ThrottleManager mem=18.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:48,007-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:48,038-0500 INFO Multiplexer No streams
+2013-08-09 14:34:48,295-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:48,295-0500 INFO ThrottleManager mem=18.89 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:48,507-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:48,795-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:48,795-0500 INFO ThrottleManager mem=18.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:49,007-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:49,295-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:49,295-0500 INFO ThrottleManager mem=18.93 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:49,508-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:49,795-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:49,795-0500 INFO ThrottleManager mem=18.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:50,008-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:50,295-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:50,296-0500 INFO ThrottleManager mem=18.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:50,508-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:50,796-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:50,796-0500 INFO ThrottleManager mem=18.97 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:51,008-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:51,296-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:51,296-0500 INFO ThrottleManager mem=19.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:51,508-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:51,796-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:51,796-0500 INFO ThrottleManager mem=19.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:52,009-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:52,296-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:52,296-0500 INFO ThrottleManager mem=19.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:52,509-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:52,796-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:52,797-0500 INFO ThrottleManager mem=19.09 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:34:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 19.1 MB
+2013-08-09 14:34:53,009-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:53,297-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:53,297-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:53,509-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:53,797-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:53,797-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:54,009-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:54,297-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:54,297-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:54,510-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:54,798-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:54,798-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:55,010-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:55,298-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:55,298-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:55,298-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:34:55,510-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:55,510-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:34:55,798-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:55,798-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:56,010-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:56,298-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:56,298-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:56,511-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:56,766-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:34:56,799-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:56,799-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:57,011-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:57,299-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:57,299-0500 INFO ThrottleManager mem=19.1 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:57,511-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:57,799-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:57,799-0500 INFO ThrottleManager mem=19.15 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:58,011-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:58,041-0500 INFO Multiplexer No streams
+2013-08-09 14:34:58,299-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:58,299-0500 INFO ThrottleManager mem=19.19 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:58,512-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:58,800-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:58,800-0500 INFO ThrottleManager mem=19.22 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:59,012-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:59,300-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:59,300-0500 INFO ThrottleManager mem=19.22 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:34:59,512-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:59,800-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:34:59,800-0500 INFO ThrottleManager mem=19.22 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:00,012-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:00,300-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:00,300-0500 INFO ThrottleManager mem=19.22 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:00,512-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:00,801-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:00,801-0500 INFO ThrottleManager mem=19.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:01,013-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:01,301-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:01,301-0500 INFO ThrottleManager mem=19.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:01,513-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:01,801-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:01,801-0500 INFO ThrottleManager mem=19.3 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:02,013-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:02,301-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:02,302-0500 INFO ThrottleManager mem=19.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:02,513-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:02,802-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:02,802-0500 INFO ThrottleManager mem=19.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:02,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:35:02,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 19.31 MB
+2013-08-09 14:35:03,014-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:03,302-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:03,302-0500 INFO ThrottleManager mem=19.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:03,514-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:03,802-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:03,802-0500 INFO ThrottleManager mem=19.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:04,014-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:04,302-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:04,302-0500 INFO ThrottleManager mem=19.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:04,514-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:04,803-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:04,803-0500 INFO ThrottleManager mem=19.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:05,015-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:05,303-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:05,303-0500 INFO ThrottleManager mem=19.31 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:05,303-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:35:05,515-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:05,515-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:35:05,803-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:05,803-0500 INFO ThrottleManager mem=19.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:06,015-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:06,304-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:06,304-0500 INFO ThrottleManager mem=19.35 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:06,515-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:06,766-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:35:06,804-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:06,804-0500 INFO ThrottleManager mem=19.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:07,016-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:07,304-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:07,304-0500 INFO ThrottleManager mem=19.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:07,516-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:07,804-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:07,804-0500 INFO ThrottleManager mem=19.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:08,016-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:08,048-0500 INFO Multiplexer No streams
+2013-08-09 14:35:08,305-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:08,305-0500 INFO ThrottleManager mem=19.43 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:08,516-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:08,805-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:08,805-0500 INFO ThrottleManager mem=19.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:09,016-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:09,305-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:09,305-0500 INFO ThrottleManager mem=19.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:09,517-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:09,805-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:09,805-0500 INFO ThrottleManager mem=19.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:10,017-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:10,305-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:10,305-0500 INFO ThrottleManager mem=19.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:10,517-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:10,806-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:10,806-0500 INFO ThrottleManager mem=19.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:11,017-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:11,306-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:11,306-0500 INFO ThrottleManager mem=19.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:11,518-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:11,806-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:11,806-0500 INFO ThrottleManager mem=19.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:12,018-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:12,307-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:12,307-0500 INFO ThrottleManager mem=19.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:12,518-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:12,807-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:12,807-0500 INFO ThrottleManager mem=19.51 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:12,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:35:12,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 19.52 MB
+2013-08-09 14:35:13,018-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:13,307-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:13,307-0500 INFO ThrottleManager mem=19.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:13,519-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:13,807-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:13,807-0500 INFO ThrottleManager mem=19.52 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:14,019-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:14,308-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:14,308-0500 INFO ThrottleManager mem=19.56 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:14,519-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:14,808-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:14,808-0500 INFO ThrottleManager mem=19.6 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:15,019-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:15,308-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:15,308-0500 INFO ThrottleManager mem=19.64 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:15,308-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:35:15,520-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:15,520-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:35:15,808-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:15,808-0500 INFO ThrottleManager mem=19.64 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:16,020-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:16,308-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:16,308-0500 INFO ThrottleManager mem=19.64 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:16,520-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:16,766-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:35:16,809-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:16,809-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:17,020-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:17,309-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:17,309-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:17,520-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:17,809-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:17,809-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:18,021-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:18,054-0500 INFO Multiplexer No streams
+2013-08-09 14:35:18,309-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:18,309-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:18,521-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:18,809-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:18,810-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:19,021-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:19,310-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:19,310-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:19,521-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:19,810-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:19,810-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:20,022-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:20,310-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:20,310-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:20,522-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:20,810-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:20,810-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:21,022-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:21,311-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:21,311-0500 INFO ThrottleManager mem=19.72 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:21,522-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:21,811-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:21,811-0500 INFO ThrottleManager mem=19.73 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:22,023-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:22,311-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:22,311-0500 INFO ThrottleManager mem=19.76 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:22,523-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:22,811-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:22,812-0500 INFO ThrottleManager mem=19.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:22,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:35:22,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 19.8 MB
+2013-08-09 14:35:23,023-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:23,312-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:23,312-0500 INFO ThrottleManager mem=19.8 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:23,523-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:23,812-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:23,812-0500 INFO ThrottleManager mem=19.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:24,023-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:24,312-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:24,312-0500 INFO ThrottleManager mem=19.85 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:24,524-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:24,812-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:24,812-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:25,024-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:25,313-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:25,313-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:25,313-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:35:25,524-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:25,524-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:35:25,813-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:25,813-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:26,024-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:26,313-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:26,313-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:26,524-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:26,766-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:35:26,813-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:26,813-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:27,025-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:27,314-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:27,314-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:27,525-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:27,814-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:27,814-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:28,025-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:28,060-0500 INFO Multiplexer No streams
+2013-08-09 14:35:28,314-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:28,314-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:28,525-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:28,814-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:28,814-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:29,026-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:29,315-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:29,315-0500 INFO ThrottleManager mem=19.92 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:29,526-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:29,815-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:29,815-0500 INFO ThrottleManager mem=19.96 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:30,026-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:30,315-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:30,315-0500 INFO ThrottleManager mem=19.96 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:30,526-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:30,815-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:30,815-0500 INFO ThrottleManager mem=19.96 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:31,026-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:31,315-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:31,315-0500 INFO ThrottleManager mem=20 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:31,527-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:31,816-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:31,816-0500 INFO ThrottleManager mem=20.01 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:32,027-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:32,316-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:32,316-0500 INFO ThrottleManager mem=20.05 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:32,527-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:32,816-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:32,816-0500 INFO ThrottleManager mem=20.13 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:32,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:35:32,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 20.14 MB
+2013-08-09 14:35:33,027-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:33,316-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:33,316-0500 INFO ThrottleManager mem=20.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:33,527-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:33,817-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:33,817-0500 INFO ThrottleManager mem=20.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:34,028-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:34,317-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:34,317-0500 INFO ThrottleManager mem=20.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:34,528-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:34,817-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:34,817-0500 INFO ThrottleManager mem=20.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:35,028-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:35,317-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:35,317-0500 INFO ThrottleManager mem=20.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:35,318-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:35:35,528-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:35,528-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:35:35,818-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:35,818-0500 INFO ThrottleManager mem=20.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:36,028-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:36,318-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:36,318-0500 INFO ThrottleManager mem=20.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:36,529-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:36,766-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:35:36,818-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:36,818-0500 INFO ThrottleManager mem=20.14 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:37,029-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:37,318-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:37,318-0500 INFO ThrottleManager mem=20.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:37,529-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:37,819-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:37,819-0500 INFO ThrottleManager mem=20.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:38,029-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:38,066-0500 INFO Multiplexer No streams
+2013-08-09 14:35:38,319-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:38,319-0500 INFO ThrottleManager mem=20.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:38,529-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:38,819-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:38,819-0500 INFO ThrottleManager mem=20.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:39,030-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:39,319-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:39,319-0500 INFO ThrottleManager mem=20.17 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:39,530-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:39,820-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:39,820-0500 INFO ThrottleManager mem=20.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:40,030-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:40,320-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:40,320-0500 INFO ThrottleManager mem=20.21 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:40,530-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:40,820-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:40,820-0500 INFO ThrottleManager mem=20.33 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:41,030-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:41,320-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:41,320-0500 INFO ThrottleManager mem=20.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:41,531-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:41,821-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:41,821-0500 INFO ThrottleManager mem=20.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:42,031-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:42,321-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:42,321-0500 INFO ThrottleManager mem=20.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:42,531-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:42,821-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:42,821-0500 INFO ThrottleManager mem=20.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:42,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:35:42,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 20.34 MB
+2013-08-09 14:35:43,031-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:43,321-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:43,321-0500 INFO ThrottleManager mem=20.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:43,531-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:43,822-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:43,822-0500 INFO ThrottleManager mem=20.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:44,032-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:44,322-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:44,322-0500 INFO ThrottleManager mem=20.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:44,532-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:44,822-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:44,822-0500 INFO ThrottleManager mem=20.34 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:45,032-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:45,322-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:45,322-0500 INFO ThrottleManager mem=20.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:45,322-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:35:45,532-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:45,532-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:35:45,823-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:45,823-0500 INFO ThrottleManager mem=20.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:46,033-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:46,323-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:46,323-0500 INFO ThrottleManager mem=20.37 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:46,533-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:46,766-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:35:46,823-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:46,823-0500 INFO ThrottleManager mem=20.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:47,033-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:47,323-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:47,323-0500 INFO ThrottleManager mem=20.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:47,533-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:47,823-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:47,823-0500 INFO ThrottleManager mem=20.38 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:48,034-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:48,069-0500 INFO Multiplexer No streams
+2013-08-09 14:35:48,324-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:48,324-0500 INFO ThrottleManager mem=20.42 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:48,534-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:48,824-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:48,824-0500 INFO ThrottleManager mem=20.5 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:49,034-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:49,324-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:49,324-0500 INFO ThrottleManager mem=20.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:49,534-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:49,824-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:49,824-0500 INFO ThrottleManager mem=20.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:50,035-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:50,325-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:50,325-0500 INFO ThrottleManager mem=20.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:50,535-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:50,825-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:50,825-0500 INFO ThrottleManager mem=20.54 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:51,035-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:51,325-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:51,325-0500 INFO ThrottleManager mem=20.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:51,535-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:51,825-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:51,825-0500 INFO ThrottleManager mem=20.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:52,036-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:52,326-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:52,326-0500 INFO ThrottleManager mem=20.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:52,536-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:52,826-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:52,826-0500 INFO ThrottleManager mem=20.55 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:52,959-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate: 0 B/s, average rate: 0 B/s
+2013-08-09 14:35:52,959-0500 INFO PerformanceDiagnosticInputStream [MEM] Heap total: 550.12 MB, Heap used: 20.56 MB
+2013-08-09 14:35:53,036-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:53,326-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:53,326-0500 INFO ThrottleManager mem=20.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:53,536-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:53,826-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:53,826-0500 INFO ThrottleManager mem=20.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:54,037-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:54,327-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:54,327-0500 INFO ThrottleManager mem=20.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:54,537-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:54,827-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:54,827-0500 INFO ThrottleManager mem=20.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:55,037-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:55,327-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:55,327-0500 INFO ThrottleManager mem=20.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:55,327-0500 INFO Buffers O allocated buffers: {} (0)
+2013-08-09 14:35:55,537-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:55,537-0500 INFO Buffers I allocated buffers: {} (0)
+2013-08-09 14:35:55,827-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:55,827-0500 INFO ThrottleManager mem=20.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:56,037-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:56,328-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:56,328-0500 INFO ThrottleManager mem=20.59 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:56,538-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:56,766-0500 INFO TaskNotifier Congestion queue size: 0
+2013-08-09 14:35:56,828-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:56,828-0500 INFO ThrottleManager mem=20.71 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:57,038-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:57,328-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:57,328-0500 INFO ThrottleManager mem=20.71 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:57,538-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:57,828-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:57,828-0500 INFO ThrottleManager mem=20.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:58,038-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:58,076-0500 INFO Multiplexer No streams
+2013-08-09 14:35:58,329-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:58,329-0500 INFO ThrottleManager mem=20.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:58,539-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:58,829-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:58,829-0500 INFO ThrottleManager mem=20.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:59,039-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:59,329-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:59,329-0500 INFO ThrottleManager mem=20.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:35:59,539-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:59,829-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:35:59,829-0500 INFO ThrottleManager mem=20.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:36:00,039-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:00,330-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:00,330-0500 INFO ThrottleManager mem=20.75 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:36:00,540-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:00,830-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:00,830-0500 INFO ThrottleManager mem=20.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:36:01,040-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:01,330-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:01,330-0500 INFO ThrottleManager mem=20.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:36:01,540-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:01,830-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:01,830-0500 INFO ThrottleManager mem=20.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:36:02,040-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:02,330-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:02,330-0500 INFO ThrottleManager mem=20.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:36:02,541-0500 INFO ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:02,831-0500 INFO ThrottleManager O maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
+2013-08-09 14:36:02,831-0500 INFO ThrottleManager mem=20.79 MB, heap=550.12 MB, maxHeap=10.5 GB
+2013-08-09 14:36:02,960-0500 INFO PerformanceDiagnosticInputStream [IN] Total transferred: 0 B, current rate
