[Swift-commit] r7023 - trunk/src/org/griphyn/vdl/karajan/lib
    hategan at ci.uchicago.edu
    Sat Aug 31 14:54:29 CDT 2013
Author: hategan
Date: 2013-08-31 14:54:29 -0500 (Sat, 31 Aug 2013)
New Revision: 7023
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
Log:
only print status every second if it has been updated
Modified: trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
--- trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java	2013-08-31 19:53:44 UTC (rev 7022)
+++ trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java	2013-08-31 19:54:29 UTC (rev 7023)
@@ -67,8 +67,8 @@
     //formatter for timestamp against std.err lines
 	public static SimpleDateFormat formatter =
 		new SimpleDateFormat("E, dd MMM yyyy HH:mm:ss Z");
-	public static final int MIN_PERIOD_MS=1000;
-	public static final int MAX_PERIOD_MS=1000;
+	public static final int MIN_PERIOD_MS = 1000;
+	public static final int MAX_PERIOD_MS = 30000;
 	public static final String[] preferredOutputOrder = {
 		"uninitialized",
@@ -185,6 +185,22 @@
 	    public String toString() {
 	        return String.valueOf(value);
+        @Override
+        public int hashCode() {
+            return value;
+        @Override
+        public boolean equals(Object obj) {
+            if (obj instanceof MutableInt) {
+                MutableInt o = (MutableInt) obj;
+                return o.value == value;
+            else {
+                return false;
 	public static class StopProgressTicker extends Node {
@@ -230,6 +246,7 @@
 		long lastDumpTime = 0;
 		private boolean disabled;
 		private boolean shutdown;
+		private Map<String, MutableInt> lastState;
 		String tickerPrefix;
@@ -264,9 +281,10 @@
 				dumpState();
 				try {
-					Thread.sleep(MAX_PERIOD_MS);
-				} catch(InterruptedException e) {
-					System.err.println("Runtime ticker interrupted. Looping immediately.");
+					Thread.sleep(MIN_PERIOD_MS);
+				catch (InterruptedException e) {
+					break;
@@ -280,16 +298,17 @@
 				return;
 			long now = System.currentTimeMillis();
-			if(lastDumpTime + MIN_PERIOD_MS > now) return;
-			lastDumpTime = now;
-			printStates(tickerPrefix);
+			boolean updated = printStates(tickerPrefix, now - lastDumpTime > MAX_PERIOD_MS);
+			if (updated) {
+			    lastDumpTime = now;
 		void finalDumpState() {
 			if (disabled) {
 				return;
-			printStates("Final status:");
+			printStates("Final status:", true);
 		private Map<String, MutableInt> getSummary() {
@@ -317,9 +336,15 @@
 		    i.inc();
-        synchronized void printStates(String prefix) {
+        synchronized boolean printStates(String prefix, boolean forced) {
 			Map<String, MutableInt> summary = getSummary();
+			long now = System.currentTimeMillis();
+			if (!forced && lastState != null && lastState.equals(summary)) {
+			    return false;
+			lastState = new HashMap<String, MutableInt>(summary);
 			StringBuilder sb = new StringBuilder();
 			// output the results of summarization, in a relatively
@@ -327,7 +352,7 @@
 			// and then anything remaining
 			System.err.print(prefix);
 			System.err.print(" ");
-			System.err.print(formatter.format(System.currentTimeMillis()));
+			System.err.print(formatter.format(now));
 			for (int pos = 0; pos < preferredOutputOrder.length; pos++) {
 				String key = preferredOutputOrder[pos];
@@ -354,6 +379,8 @@
 			if (logger.isInfoEnabled()) {
 			    logger.info(msg);
+			return true;
More information about the Swift-commit
