[Swift-commit] r7018 - SwiftTutorials/swift-cray-tutorial/doc
ketan at ci.uchicago.edu
Tue Aug 27 21:08:45 CDT 2013
Author: ketan
Date: 2013-08-27 21:08:45 -0500 (Tue, 27 Aug 2013)
New Revision: 7018
Modified:
SwiftTutorials/swift-cray-tutorial/doc/README
Log:
small changes
Modified: SwiftTutorials/swift-cray-tutorial/doc/README
--- SwiftTutorials/swift-cray-tutorial/doc/README 2013-08-28 01:49:44 UTC (rev 7017)
+++ SwiftTutorials/swift-cray-tutorial/doc/README 2013-08-28 02:08:45 UTC (rev 7018)
@@ -100,7 +100,7 @@
that serve as easy-to-understand proxies for real science
applications. These "programs" behave as follows.
-simulation.sh
+simulate.sh
The simulation.sh script serves as a trivial proxy for any more
@@ -297,7 +297,7 @@
which is located in the tutorial PATH:
-$ cleanup.sh
+$ cleanup
NOTE: You'll also find two Swift configuration files in each `partNN`
@@ -675,7 +675,7 @@
"pilot jobs" using qsub. These pilot jobs hold on to compute nodes and
allow Swift to run many app invocations within a single job. This
mechanism is described in
-http://www.swift-lang.org/papers/UCC-coasters.pdf[this paper from UCC-2011]
+http://www.swift-lang.org/papers/UCC-coasters.pdf[this paper from UCC-2011].
`profile` tags specify additional attributes for the execution
provider. (A "provider" is like a driver which knows how to handle
@@ -722,7 +722,7 @@
(specifically 1 over) `jobThrottle` * 100 to be used.
The last two attributes specify where and how Swift should perform
-data management. `workdirectory lus/scratch/{env.USER}/swiftwork`
+data management. `workdirectory /lus/scratch/{env.USER}/swiftwork`
specifies where the Swift "application execution sanbox directory"
used for each app will be located. In some situations this can be a
directory local to the compute node (eg, for Cray systems, `/dev/shm`
@@ -847,7 +847,6 @@
We use the following `apps` file:
$ cat multipools
-$ cat multipools
raven simulate simulate.sh
ravenGPU simulate simulate.sh
localhost stats stats.sh
More information about the Swift-commit
