[Swift-commit] r6999 - branches/release-0.94/src/org/griphyn/vdl/engine
hategan at ci.uchicago.edu
Mon Aug 26 02:08:47 CDT 2013
Author: hategan
Date: 2013-08-26 02:08:46 -0500 (Mon, 26 Aug 2013)
New Revision: 6999
Modified:
branches/release-0.94/src/org/griphyn/vdl/engine/FormalArgumentSignature.java
branches/release-0.94/src/org/griphyn/vdl/engine/Karajan.java
branches/release-0.94/src/org/griphyn/vdl/engine/ProcedureSignature.java
Log:
use inference when assigning from procedure calls and properly complain when inference is not possible
Modified: branches/release-0.94/src/org/griphyn/vdl/engine/FormalArgumentSignature.java
--- branches/release-0.94/src/org/griphyn/vdl/engine/FormalArgumentSignature.java 2013-08-26 07:06:13 UTC (rev 6998)
+++ branches/release-0.94/src/org/griphyn/vdl/engine/FormalArgumentSignature.java 2013-08-26 07:08:46 UTC (rev 6999)
@@ -41,6 +41,9 @@
public FormalArgumentSignature(boolean anyType) {
this.anyType = anyType;
this.optionalArg = false;
+ if (anyType) {
+ this.type = ProcedureSignature.ANY;
public FormalArgumentSignature(String type) {
Modified: branches/release-0.94/src/org/griphyn/vdl/engine/Karajan.java
--- branches/release-0.94/src/org/griphyn/vdl/engine/Karajan.java 2013-08-26 07:06:13 UTC (rev 6998)
+++ branches/release-0.94/src/org/griphyn/vdl/engine/Karajan.java 2013-08-26 07:08:46 UTC (rev 6999)
@@ -583,11 +583,34 @@
try {
StringTemplate assignST = template("assign");
StringTemplate varST = expressionToKarajan(assign.getAbstractExpressionArray(0), scope, true);
- StringTemplate valueST = expressionToKarajan(assign.getAbstractExpressionArray(1),scope);
- if (! (datatype(varST).equals(datatype(valueST)) ||
- datatype(valueST).equals("java")))
- throw new CompilationException("You cannot assign value of type " + datatype(valueST) +
- " to a variable of type " + datatype(varST));
+ String lValueType = datatype(varST);
+ StringTemplate valueST = expressionToKarajan(assign.getAbstractExpressionArray(1), scope, false, lValueType);
+ String rValueType = datatype(valueST);
+ if (isAnyType(lValueType)) {
+ if (isAnyType(rValueType)) {
+ // any <- any
+ else {
+ // any <- someType, so infer lValueType as rValueType
+ setDatatype(varST, rValueType);
+ else {
+ // someType <- any
+ // only expressions that are allowed to return 'any' are procedures
+ // for example readData(ret, file). These are special procedures that
+ // need to look at the return type at run-time.
+ else if (!lValueType.equals(rValueType)){
+ throw new CompilationException("You cannot assign value of type " + rValueType +
+ " to a variable of type " + lValueType);
assignST.setAttribute("var", varST);
assignST.setAttribute("value", valueST);
assignST.setAttribute("line", getLine(assign));
@@ -599,7 +622,11 @@
- public void append(Append append, VariableScope scope) throws CompilationException {
+ private boolean isAnyType(String type) {
+ return ProcedureSignature.ANY.equals(type);
+ public void append(Append append, VariableScope scope) throws CompilationException {
try {
StringTemplate appendST = template("append");
StringTemplate array = expressionToKarajan(append.getAbstractExpressionArray(0),scope);
@@ -1228,14 +1255,20 @@
static final QName CALL_EXPR = new QName(SWIFTSCRIPT_NS, "call");
public StringTemplate expressionToKarajan(XmlObject expression, VariableScope scope) throws CompilationException {
- return expressionToKarajan(expression, scope, false);
+ return expressionToKarajan(expression, scope, false, null);
+ public StringTemplate expressionToKarajan(XmlObject expression, VariableScope scope,
+ boolean lvalue) throws CompilationException {
+ return expressionToKarajan(expression, scope, lvalue, null);
/** converts an XML intermediate form expression into a
* Karajan expression.
- public StringTemplate expressionToKarajan(XmlObject expression, VariableScope scope, boolean lvalue) throws CompilationException
+ boolean lvalue, String expectedType) throws CompilationException {
Node expressionDOM = expression.getDomNode();
String namespaceURI = expressionDOM.getNamespaceURI();
String localName = expressionDOM.getLocalName();
@@ -1559,6 +1592,14 @@
StringTemplate call = template("callexpr");
String type = funcSignature.getOutputArray(0).getType();
+ if (isAnyType(type)) {
+ if (expectedType != null) {
+ type = expectedType;
+ else {
+ throw new CompilationException("Cannot infer return type of procedure call");
subscope.addInternalVariable("swift#callintermediate", type, null);
call.setAttribute("datatype", type);
@@ -1719,4 +1760,9 @@
throw new RuntimeException("Not typed properly: " + st);
+ protected void setDatatype(StringTemplate st, String type) {
+ st.removeAttribute("datatype");
+ st.setAttribute("datatype", type);
Modified: branches/release-0.94/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- branches/release-0.94/src/org/griphyn/vdl/engine/ProcedureSignature.java 2013-08-26 07:06:13 UTC (rev 6998)
+++ branches/release-0.94/src/org/griphyn/vdl/engine/ProcedureSignature.java 2013-08-26 07:08:46 UTC (rev 6999)
@@ -147,7 +147,7 @@
public static final String INT = "int";
public static final String FLOAT = "float";
public static final String BOOLEAN = "boolean";
- public static final String ANY = "-any";
+ public static final String ANY = "any";
public static final String VARGS = "-vargs";
public static Map<String,ProcedureSignature>
@@ -204,7 +204,7 @@
add(functionsMap, "format", returns(STRING), args(FLOAT, INT));
add(functionsMap, "pad", returns(STRING), args(INT, INT));
- add(functionsMap, "java", returns("java"), args(VARGS));
+ add(functionsMap, "java", returns(ANY), args(VARGS));
add(functionsMap, "exists", returns(BOOLEAN), args(VARGS));
More information about the Swift-commit
