[Swift-commit] r6995 - SwiftTutorials/swift-cray-tutorial/doc
wilde at ci.uchicago.edu
Sat Aug 24 19:38:53 CDT 2013
Author: wilde
Date: 2013-08-24 19:38:53 -0500 (Sat, 24 Aug 2013)
New Revision: 6995
Added:
SwiftTutorials/swift-cray-tutorial/doc/part01.png
SwiftTutorials/swift-cray-tutorial/doc/part02.png
SwiftTutorials/swift-cray-tutorial/doc/part03.png
SwiftTutorials/swift-cray-tutorial/doc/part04.png
SwiftTutorials/swift-cray-tutorial/doc/part05.png
SwiftTutorials/swift-cray-tutorial/doc/part06.png
Modified:
SwiftTutorials/swift-cray-tutorial/doc/README
SwiftTutorials/swift-cray-tutorial/doc/push.sh
Log:
Add updated figures.
Modified: SwiftTutorials/swift-cray-tutorial/doc/README
--- SwiftTutorials/swift-cray-tutorial/doc/README 2013-08-25 00:36:13 UTC (rev 6994)
+++ SwiftTutorials/swift-cray-tutorial/doc/README 2013-08-25 00:38:53 UTC (rev 6995)
@@ -21,70 +21,105 @@
+Introduction: Why Parallel Scripting?
+Swift is a simple scripting language for executing many instances of
+ordinary application programs on distributed parallel resources.
+Swift scripts run many copies of ordinary programs concurrently, using
+statements like this:
+foreach protein in proteinList {
+ runBLAST(protein);
-Workflow tutorial setup
+Swift acts like a structured "shell" language. It runs programs
+concurrently as soon as their inputs are available, reducing the need
+for complex parallel programming. Swift expresses your workflow
+in a portable fashion: The same script runs on grids like OSG, as well
+as on multicore computers, clusters, clouds, and supercomputers.
-Installing scripts on Raven
-If you are installing these scripts on Raven, run the following command to extract the tutorial scripts:
+In this tutorial, you'll be able to first try a few Swift examples
+(parts 1-3) on the OSG Connect login host, to get a sense of the
+language. Then in parts 4-6 you'll run similar workflows on
+distributed OSG Connect resources, and see how more complex workflows
+can be expressed with Swift scripts.
+Swift tutorial setup
+To install the tutorial scripts on Raven, do:
+$ cd $HOME
$ tar xfz /home/users/p01537/swift-cray-tutorial.tar.gz
+$ cd cray-swift
+$ source setup.sh # You must run this with "source" !
-This will create a directory called "tutorial" which contains all of the
-scripts mentioned in this document.
+Verify your environment
-Installing scripts on other systems
-If you are running on a machine other than Raven, you can install the scripts via SVN.
+To verify that Swift (and the Java environment it requires) are working, do:
-$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/swift-cray-tutorial
+$ java -version # verify that you have Java (ideally Oracle JAVA 1.6 or later)
+$ swift -version # verify that you have Swift 0.94.1
-Run setup
-Once the scripts are checked out, run the following commands to perform
-the initial setup.
+NOTE: If you re-login or open new ssh sessions, you must
+re-run `source setup.sh` in each ssh shell window:
+To check out the tutorial scripts from SVN
+If you later want to get the most recent version of this tutorial from
+the Swift Subversion repository, do:
-$ cd swift-cray-tutorial # change to the newly created tutorial directory
-$ source setup.sh # sets swift config files in $HOME/.swift
-$ java -version # verify that you have Java installed
-$ swift -version # verify that Swift 0.94 is in your $PATH and functional
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/Cray-Swift
-NOTE: If you re-login, you will need to re-run source setup.sh.
+This will create a directory called "Cray-Swift" which contains all of the
+files used in this tutorial.
Simple "science applications" for the workflow tutorial
-There are two shell scripts included that serve as very simple stand-ins for science application:
-simulation.sh and stats.sh
+This tutorial is based on two simple example programs (both
+implemented as bash shell scripts) that serve a very simple stand-ins
+for real science applications: `simulation.sh` and `stats.sh`.
simulation.sh
-The simulation.sh script serves as a trivial substitute for a complex scientific simulation application. It generates and prints a set of one or more random integers in the range [0-2^32) as controlled by its optional arguments, which are:
+The simulation.sh script serves as a trivial substitute for a complex
+scientific simulation application. It generates and prints a set of
+one or more random integers in the range [0-2^62) as controlled by its
+command line arguments, which are:
$ ./app/simulate.sh --help
./app/simulate.sh: usage:
- -b|--bias offset bias: add this integer to all results
- -B|--biasfile file of integer biases to add to results
- -l|--log generate a log in stderr if not null
- -n|--nvalues print this many values per simulation
- -r|--range range (limit) of generated results
- -s|--seed use this integer [0..32767] as a seed
- -S|--seedfile use this file (containing integer seeds [0..32767]) one per line
- -t|--timesteps number of simulated "timesteps" in seconds (determines runtime)
- -x|--scale scale the results by this integer
+ -b|--bias offset bias: add this integer to all results [0]
+ -B|--biasfile file of integer biases to add to results [none]
+ -l|--log generate a log in stderr if not null [y]
+ -n|--nvalues print this many values per simulation [1]
+ -r|--range range (limit) of generated results [100]
+ -s|--seed use this integer [0..32767] as a seed [none]
+ -S|--seedfile use this file (containing integer seeds [0..32767]) one per line [none]
+ -t|--timesteps number of simulated "timesteps" in seconds (determines runtime) [1]
+ -x|--scale scale the results by this integer [1]
-h|-?|?|--help print this help
+All of thess arguments are optional, with default values indicated above as `[n]`.
.simulation.sh arguments
[width="80%",cols="^2,10",options="header"]
@@ -101,86 +136,156 @@
With no arguments, simulate.sh prints 1 number in the range of 1-100. Otherwise it generates n numbers of the form (R*scale)+bias where R is a random integer. By default it logs information about its execution environment to stderr. Here's some examples of its usage:
+With no arguments, simulate.sh prints 1 number in the range of
+1-100. Otherwise it generates n numbers of the form (R*scale)+bias
+where R is a random integer. By default it logs information about its
+execution environment to stderr. Here's some examples of its usage:
$ simulate.sh 2>log
5
-$ head -5 log
+$ head -4 log
-Called as: /home/users/p01537/swift-cray-tutorial/app/simulate.sh:
+Called as: /home/wilde/swift/tut/CIC_2013-08-09/app/simulate.sh:
+Start time: Thu Aug 22 12:40:24 CDT 2013
+Running on node: login01.osgconnect.net
-Start time: Fri Aug 23 15:07:16 CDT 2013
-Running on node: raven
-$ tail -5 log
-SSH_CLIENT=67.173.156.31 46887 22
-SSH_CONNECTION=67.173.156.31 46887 128.135.158.173 22
-SSH_TTY=/dev/pts/9
-TERM=xterm-color
-USER=wilde
-$ simulate.sh -n 3 -r 1000000 2>log
- 386702
+$ simulate.sh -n 4 -r 1000000 2>log
239454
+ 386702
13849
+ 873526
$ simulate.sh -n 3 -r 1000000 -x 100 2>log
6643700
62182300
5230600
-$ simulate.sh -n 3 -r 1000 -x 1000 2>log
+$ simulate.sh -n 2 -r 1000 -x 1000 2>log
565000
636000
- 477000
-$ time simulate.sh -n 3 -r 1000 -x 1000 -t 3 2>log
+$ time simulate.sh -n 2 -r 1000 -x 1000 -t 3 2>log
336000
- 20000
320000
real 0m3.012s
user 0m0.005s
sys 0m0.006s
+stats.sh
+The stats.sh script serves as a trivial model of an "analysis"
+program. It reads N files each containing M integers and simply prints
+the\ average of all those numbers to stdout. Similarly to simulate.sh
+it logs environmental information to the stderr.
+$ ls f*
+f1 f2 f3 f4
+$ cat f*
+25
+60
+40
+75
-stats.sh
-The stats.sh script reads a file containing n numbers and prints the average
-of those numbers to stdout.
+$ stats.sh f* 2>log
+50
-Introductory exercises
-Parts 1-3 (p1.swift - p3.swift) run locally and serve as examples of the Swift language.
-Parts 4-6 (p4.swift - p6.swift) submit jobs to the site specified the setup stage
-p1 - Run an application under Swift
-The first swift script, p1.swift, runs simulate.sh to generate a single random
-number. It writes the number to a file.
+Basic of the Swift language with local execution
-image:p1.png[]
+A Summary of Swift in a nutshell
+* Swift scripts are text files ending in `.swift` The `swift` command
+runs on any host, and executes these scripts. `swift` is a Java
+application, which you can install almost anywhere. On Linux, just
+unpack the distribution `tar` file and add its `bin/` directory to
+your `PATH`.
+* Swift scripts run ordinary applications, just like shell scripts
+do. Swift makes it easy to run these applications on parallel and
+remote computers (from laptops to supercomputers). If you can `ssh` to
+the system, Swift can likely run applications there.
+* The details of where to run applications and how to get files back
+and forth are described in configuration files separate from your
+program. Swift speaks ssh, PBS, Condor, SLURM, LSF, SGE, Cobalt, and
+Globus to run applications, and scp, http, ftp, and GridFTP to move
+data.
+* The Swift language has 5 main data types: `boolean`, `int`,
+`string`, `float`, and `file`. Collections of these are dynamic,
+sparse arrays of arbitrary dimension and structures of scalars and/or
+arrays defined by the `type` declaration.
+* Swift file variables are "mapped" to external files. Swift sends
+files to and from remote systems for you automatically.
+* Swift variables are "single assignment": once you set them you can't
+change them (in a given block of code). This makes Swift a natural,
+"parallel data flow" language. This programming model keeps your
+workflow scripts simple and easy to write and understand.
+* Swift lets you define functions to "wrap" application programs, and
+to cleanly structure more complex scripts. Swift `app` functions take
+files and parameters as inputs and return files as outputs.
+* A compact set of built-in functions for string and file
+manipulation, type conversions, high level IO, etc. is provided.
+Swift's equivalent of `printf()` is `tracef()`, with limited and
+slightly different format codes.
+* Swift's `foreach {}` statement is the main parallel workhorse of the
+language, and executes all iterations of the loop concurrently. The
+actual number of parallel tasks executed is based on available
+resources and settable "throttles".
+* In fact, Swift conceptually executes *all* the statements,
+expressions and function calls in your program in parallel, based on
+data flow. These are similarly throttled based on available resources
+and settings.
+* Swift also has `if` and `switch` statements for conditional
+execution. These are seldom needed in simple workflows but they enable
+very dynamic workflow patterns to be specified.
+We'll see many of these points in action in the examples below. Lets
+get started!
+Part 1: Run a single application under Swift
+The first swift script, p1.swift, runs simulate.sh to generate a
+single random number. It writes the number to a file.
+image::part01.png["p1 workflow",align="center"]
.p1.swift
sys::[cat -n ../part01/p1.swift]
-The sites.xml file included in each part directory gives Swift information about the machines we will be running on.
-It defines things like the work directory, the scheduler to use, and how to control parallelism. The sites.xml file
-below will tell Swift to run on the local machine only, and run just 1 task at a time.
+The sites.xml file included in each part directory gives Swift
+information about the machines we will be running on. It defines
+things like the work directory, the scheduler to use, and how to
+control parallelism. The sites.xml file below will tell Swift to run
+on the local machine only, and run just 1 task at a time.
.sites.xml
sys::[cat -n ../part01/sites.xml]
-The app file translates from a Swift app function to the path of an executable on the file system.
-In this case, it translates from "simulate" to simulate.sh and assumes that simulate.sh will
-be available in your $PATH.
+The app file translates from a Swift app function to the path of an
+executable on the file system. In this case, it translates from
+"simulate" to simulate.sh and assumes that simulate.sh will be
+available in your $PATH.
.apps
@@ -204,13 +309,15 @@
$ ./clean.sh
-p2 - Parallel loops with foreach
+Part 2: Running an ensemble of many apps in parallel with "foreach" loops
The p2.swift script introduces the foreach loop. This script runs many
simulations. The script also shows an example of naming the files. The output files
are now called sim_N.out.
-image:p2.png[]
+image::part02.png[align="center"]
.p2.swift
@@ -223,13 +330,15 @@
$ swift p2.swift
-p3 - Merging/reducing the results of a parallel foreach loop
-p3.swift introduces a postprocessing step. After all the parallel simulations have completed, the files
-created by simulation.sh will be averaged by stats.sh.
+Part 3: Analyzing results of a parallel ensemble
-image:p3.png[]
+p3.swift introduces a postprocessing step. After all the parallel
+simulations have completed, the files created by simulation.sh will be
+averaged by stats.sh.
+image::part03.png[align="center"]
.p3.swift
sys::[cat -n ../part03/p3.swift]
@@ -241,15 +350,18 @@
$ swift p3.swift
-p4 - Running on the remote site nodes
-p4.swift is the first script that will submit jobs to remote site nodes for analysis.
-It is similar to earlier scripts, with a few minor exceptions. To generalize the script
-for other types of remote execution (e.g., when no shared filesystem is available to the compute nodes), the application simulate.sh
-will get transferred to the worker node by Swift, in the same manner as any other input data file.
-image:p4.png[]
+Running applications on Cray compute nodes with Swift
+Part 4: Running a parallel ensemble on Cray compute nodes
+p4.swift is the first script that will run our mock "simulation" jobs
+on Cray compute nodes. The script is the same as `p3.swift`.
+image::part04.png[align="center"]
.p4.swift
sys::[cat -n ../part04/p4.swift]
@@ -262,14 +374,39 @@
Output files will be named output/sim_N.out.
-p5 - Running the stats summary step on the remote site
-p5.swift introduces a postprocessing step. After all the parallel simulations have completed, the files
-created by simulation.sh will be averaged by stats.sh. This is similar to p3, but all app invocations
-are done on remote nodes with Swift managing file transfers.
+In order to run on Cray compute nodes, sites.xml was modified. Here is
+the new sites.xml we are using for this example. Note the changes
+between the sites.xml file in this example which specifies
-image:p5.png[]
+"execution
+provider=condor", and the sites.xml file in part 1, which runs locally
+by specifying "execution provider=local".
+.sites.xml
+sys::[cat -n ../part06/sites.xml]
+Below is the updated apps file. Since Swift is staging shell scripts
+remotely to nodes on the cluster, the only application you need to
+define here is the shell.
+.apps
+sys::[cat -n ../part06/apps]
+Part 5: Controlling where applications run
+p5.swift introduces a postprocessing step. After all the parallel
+averaged by stats.sh. This is similar to p3, but all app invocations
+are done on remote nodes with Swift managing file transfers.
+image::part05.png[align="center"]
.p5.swift
sys::[cat -n ../part05/p5.swift]
@@ -280,41 +417,33 @@
$ swift p5.swift
-p6 - Add additional apps and randomness
+Part 6: Specifying more complex workflow patterns
p6.swift build on p5.swift, but adds new apps for generating a random
-seed and a random bias value.
+seed and a random bias value.
-image:p6.png[]
+image::part06.png[align="center"]
.p6.swift
sys::[cat -n ../part06/p6.swift]
-In order to run on the cluster, sites.xml needed to be modified. Here is
-the new sites.xml we are using for this example. Note the changes between the sites.xml file
-in this example which uses condor, and the sites.xml file in part 1, which runs locally.
-.sites.xml
-sys::[cat -n ../part06/sites.xml]
-Below is the updated apps file. Since Swift is staging shell scripts remotely to nodes on the cluster,
-the only application it needs defined here is the shell.
-.apps
-sys::[cat -n ../part06/apps]
Use the command below to specify the time for each simulation.
$ cd ../part06
$ swift p6.swift -steps=3 # each simulation takes 3 seconds
Larger runs
To test with larger runs, there are two changes that are required. The first is a
@@ -332,6 +461,10 @@
<profile namespace="globus" key="maxNodes">2</profile>
Plotting
Each part directory contains a file called plot.sh that can be used for plotting.
@@ -345,435 +478,3 @@
$ ./plot.sh <logfile>
-Running Swift scripts on Cloud resources
-Setting up the Cloud exercises
-A number of preconfigured Amazon EC2 nodes are set up for running Swift.
-Run the Cloud exercises
-* Change to cloud dir:
- cd ~/cloud
-* Copy the private key tutorial.pem to your .ssh dir:
- cp tutorial.pem ~/.ssh/
-* Source the setup script on command line:
- source ./setup
-* Run the catsn Swift script:
- ./run.catsn
-* Run the Cloud versions of the Swift scripts p7, p8,and p9.swift:
- swift -sites.file sites.xml -config cf -tc.file tc p7.swift
- swift -sites.file sites.xml -config cf -tc.file tc p8.swift
- swift -sites.file sites.xml -config cf -tc.file tc p9.swift
-* Add cloud resources to existing examples:
- ./addcloud.sh <dir> #where dir is a tutorial script directory
- e.g.
- ./addcloud.sh ../part01 #will create a new site pool "both.xml" in ../part01
-* Finally, to clean up the log files, kill agent and shutdown the coaster service:
- ./cleanme
-Notes on the Cloud exercises
-The run.catsn shell script contains the full command line to call Swift scripts with configuration files. This script runs swift as follows:
-swift -sites.file sites.xml -tc.file tc -config cf catsn.swift -n=10
-To learn more about the configuration files, see Swift user-guide:
-http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html
-Running Swift/T on Vesta with Python and R integration
-Normally it is difficult to run scripted programs such as Python and
-R on the Blue Gene/Q because of the limited OS environment. However,
-Swift/T allows you to create a composite application that is linked
-into one Cobalt job at run time. Thus, you can write a scripted
-program that coordinates calls from Swift to C, C++, Fortran, Python,
-R, or Tcl. All data movement is handled by the Swift/T runtime over
-MPI, removing the overhead of file access.
-=== p11 - Scripted parallel numerics with Python and R
-As shown on the slides, this example calls the
-http://www.numpy.org[Numpy] numerical libraries via Python as well as
-the http://www.r-project.org[R language] for statistics. In this
-example, we use Numpy to construct matrices, perform matrix
-arithmetic, and compute determinants. Since determinant is _O(n^3^)_,
-we compute each determinant in parallel using the Swift +foreach+
-loop. All result are collected and passed to the R +max()+ function.
-==== Scripts
-This example is designed to run on Vesta.
-To compile and run the script, run:
-.run-dets.sh
- include::part11-swift-py-r/code/run-dets.sh.txt[]
-As a reference, an equivalent plain Python code is provided:
-.dets.py
- include::part11-swift-py-r/code/dets.py[]
-The Swift script is:
-.dets.swift
- include::part11-swift-py-r/code/dets.swift[]
-==== Analysis
-The Turbine run time script creates a +TURBINE_OUTPUT+ directory and
-reports it. Standard output from the job is in +output.txt+.
-Use +grep dets+ to find the results printed by the Swift script. You
-will see each determinant as inserted into the Swift array, and the
-maximal result.
-Turbine was launched with +-n 10+; that is, 10 total processes, 8 of
-which are workers, ranks 1-8. Much of the output is created by rank
-0, the Turbine engine. (Only one engine is used in this case,
-although Swift/T supports multiple engines for scalability.) The ADLB
-server runs on rank 9 and produces almost no output. (Swift/T and
-ADLB support multiple servers.)
-You may +grep+ for +python: expression:+ to see the Python expressions
-evaluated on the workers. Note the rank numbers.
-For production cases, you may disable logging by setting
-+TURBINE_LOG=0+ in the environment.
-=== More information
-For more information about Swift/T, see:
-* https://sites.google.com/site/exmcomputing/swift-t[Swift/T Overview]
-* http://www.mcs.anl.gov/exm/local/guides/swift.html[Swift/T Guide]
-* http://www.mcs.anl.gov/exm/local/guides/turbine-sites.html[Sites Guide]
- — notes for running Swift/T on various systems
-Running MPI apps under Swift
-Modis - Satellite image data processing
-In this section we will use swift to process data from a large dataset of
-files that categorize the Earth's surface, derived from the MODIS sensor
-instruments that orbit the Earth on two NASA satellites of the Earth Observing System.
-The dataset we use (for 2002, named +mcd12q1+) consists of 317 "tile" files
-that categorize every 250-meter square of non-ocean surface of the Earth into
-one of 17 "land cover" categories (for example, water, ice, forest, barren, urban).
-Each pixel of these data files has a value of 0 to 16, describing one square
-of the Earth's surface at a specific point in time. Each tile file has
-approximately 5 million 1-byte pixels (5.7 MB), covering 2400x2400 250-meter
-squares, based on a specific map projection.
-image:sinusoidal_v5.gif[]
-modis01 - Process 1 image
-The first modis example defines one app function called getLandUse.
-This app takes a satellite image (data/modis/2002/h00v09.pgm.gz) as
-input. getLandUse creates a text file called landuse/h00v08.landuse.byfreq
-that counts the frequency of each land type defined in the input image.
-.modis01.swift
-type imagefile;
-type landuse;
-app (landuse output) getLandUse (imagefile input)
- getlanduse @filename(input) stdout=@filename(output);
-imagefile modisImage <"data/global/h00v09.rgb">;
-landuse result <"landuse/h00v09.landuse.byfreq">;
-result = getLandUse(modisImage);
-To run modis01.swift:
-$ cd modis/modis01/
-$ swift modis01.swift
-modis02 - Process multiple images in parallel
-The second modis example expands upon the first example by running getLandUse
-with multiple (317) input files. Ouptut files are stored in the landuse directory.
-In order to map several input files we will use the ext mapper here to specify
-the mapper script, location a suffix to identify matching files.
-TODO: More on mappers
-.modis02.swift
-type imagefile;
-type landuse;
-# Constants and command line arguments
-int nFiles = @toInt(@arg("nfiles", "1000"));
-string MODISdir = @arg("modisdir", "data/global");
-# Input Dataset
-imagefile geos[] <ext; exec="../bin/modis.mapper", location=MODISdir, suffix=".rgb", n=n\
-Files>;
-# Compute the land use summary of each MODIS tile
-landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strc\
-at("landuse/\\1.landuse.byfreq")>;
-foreach g,i in geos {
- land[i] = getLandUse(g);
-To run modis02.swift
-$ cd modis/modis02/
-$ swift modis02.swift
-modis03 - Analyse the processed images
-The third modis example builds on the previous example. It defines a new app function
-called analyzeLandUse. The analyzeLandUse app examines the data generated by getLandUse
-and creates two summary files called topselected.txt and selectedtiles.txt. These
-files contain information about the top 10 urban areas.
-In the previous example, you have noticed that running all 317 input files on
-your laptop, even with 4 tasks a time, is not very efficient.
-TODO : In the next example, instead of running locally, we will use a cluster called midway at the University of Chicago to improve performance.
-.modis03.swift
-type file;
-type imagefile;
-type landuse;
-app (file output, file tilelist) analyzeLandUse (landuse input[], string usetype, int ma\
-xnum)
- analyzelanduse @output @tilelist usetype maxnum @input;
-int nSelect = @toInt(@arg("nselect", "10"));
-string landType = @arg("landtype", "urban");
-# Input Dataset
-Files>;
-# Find the top N tiles (by total area of selected landuse types)
-file topSelected <"topselected.txt">;
-file selectedTiles <"selectedtiles.txt">;
-(topSelected, selectedTiles) = analyzeLandUse(land, landType, nSelect);
-To run modis03.swift
-$ cd modis/modis03/
-$ swift modis03.swift
-modis04 - Mark the top N tiles on a map
-The fourth modis example adds another app called markMap that looks at selectedtiles.txt
-and highlights the selected areas on a map. It will create a new image called
-gridmap.png which marks the top N tiles on a sinusoidal gridded map.
-.modis04.swift
-type file;
-type imagefile;
-type landuse;
-xnum)
-app (imagefile grid) markMap (file tilelist)
- markmap @tilelist @grid;
-# Input Dataset
-Files>;
-landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@s\
-trcat("landuse/\\1.landuse.byfreq")>;
-# Mark the top N tiles on a sinusoidal gridded map
-imagefile gridmap <"gridmap.png">;
-gridmap = markMap(topSelected);
-To run modis04.swift
-$ cd modis/modis04/
-$ swift modis04.swift
-modis05 - Create multi-color tile images
-The fifth modis example extends the previous examples by adding the colorModis app
-to create multi-color images for all tiles.
-.modis05.swift
-type file;
-type imagefile;
-type landuse;
-app (file output, file tilelist) analyzeLandUse (landuse input[], string usetype, int maxnum)
-app (imagefile output) colorModis (imagefile input)
- colormodis @input @output;
-# Input Dataset
-imagefile geos[] <ext; exec="../bin/modis.mapper", location=MODISdir, suffix=".rgb", n=nFiles>;
-landuse land[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("landuse/\\1.landuse.byfreq")>;
-# Create multi-color images for all tiles
-imagefile colorImage[] <structured_regexp_mapper; source=geos, match="(h..v..)", transform=@strcat("colorImages/\\1.color.rgb")>;
-foreach g, i in geos {
- colorImage[i] = colorModis(g);
-To run modis05.swift:
-$ cd modis/modis05/
-$ swift modis05.swift
Added: SwiftTutorials/swift-cray-tutorial/doc/part01.png
(Binary files differ)
Property changes on: SwiftTutorials/swift-cray-tutorial/doc/part01.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: SwiftTutorials/swift-cray-tutorial/doc/part02.png
Property changes on: SwiftTutorials/swift-cray-tutorial/doc/part02.png
Added: SwiftTutorials/swift-cray-tutorial/doc/part03.png
Property changes on: SwiftTutorials/swift-cray-tutorial/doc/part03.png
Added: SwiftTutorials/swift-cray-tutorial/doc/part04.png
Property changes on: SwiftTutorials/swift-cray-tutorial/doc/part04.png
Added: SwiftTutorials/swift-cray-tutorial/doc/part05.png
Property changes on: SwiftTutorials/swift-cray-tutorial/doc/part05.png
Added: SwiftTutorials/swift-cray-tutorial/doc/part06.png
Property changes on: SwiftTutorials/swift-cray-tutorial/doc/part06.png
Modified: SwiftTutorials/swift-cray-tutorial/doc/push.sh
--- SwiftTutorials/swift-cray-tutorial/doc/push.sh 2013-08-25 00:36:13 UTC (rev 6994)
+++ SwiftTutorials/swift-cray-tutorial/doc/push.sh 2013-08-25 00:38:53 UTC (rev 6995)
@@ -1,6 +1,6 @@
#! /bin/sh
-scp cic-tutorial.html *png login.ci.uchicago.edu:/ci/www/projects/swift/links
+scp swift-cray-tutorial.html *png login.ci.uchicago.edu:/ci/www/projects/swift/tutorials/cray
exit
More information about the Swift-commit
