[Swift-commit] r6992 - trunk/docs/userguide
    ketan at ci.uchicago.edu
    Sat Aug 24 00:10:07 CDT 2013
Author: ketan
Date: 2013-08-24 00:10:07 -0500 (Sat, 24 Aug 2013)
New Revision: 6992
Added:
   trunk/docs/userguide/swift-galaxy
Log:
adding swift galaxy integration doc
Added: trunk/docs/userguide/swift-galaxy
--- trunk/docs/userguide/swift-galaxy	                        (rev 0)
+++ trunk/docs/userguide/swift-galaxy	2013-08-24 05:10:07 UTC (rev 6992)
@@ -0,0 +1,44 @@
+Swift Enabled Galaxy Workflows
+This section documents running Swift enabled workflows in Galaxy environment.
+Galaxy is a workflow portal environment through which users can compose
+workflows via galaxy-tools chained together via inputs and outputs. See Galaxy
+home page to know more about Galaxy user environment.
+Writing Swift-enabled Galaxy Tool
+Following is a template to write Swift-enabled Galaxy tools. It contains a
+single self contained script.
+Following is an example Galaxy-tool generated with the above mentioned template
+script.
+It has capability to process a dataset that resides outside of Galaxy, and to
+create a new dataset that resides outside of Galaxy. Each dataset could be a
+list of one or more external references such as GridFTP URIs or authenticated
+GO transfers.
+The tool can invoke other (non-swift) Galaxy tools as app() functions within
+the embedded Swift script.
+Generic Swift Galaxy Tool
+A Generic Swift Galaxy Tool which allows users to add arbitrary Swift scripts,
+input data and designated outputs. This tool can be used as a hosted
+'try-swift' capability. User can push in new Swift workflows as tools. User can
+set config related values using web forms: drop-downs or checkboxes for various
+throttle levels, site options, tc elements, etc. Reuse existing Galaxy tools to
+upload scripts and/or input data.
+A Special Swift Galaxy Tool: The foreach-tool
+The for-each can enable many workflows with parallel iteration ("foreach") to
+be composed in Galaxy.
+Convert Galaxy Workflows to Swift
+A tool that converts existing Galaxy workflow representation to Swift script.
More information about the Swift-commit
