[Swift-commit] r6969 - in SwiftTutorials/CIC_2013-08-09: . doc
wilde at ci.uchicago.edu
Fri Aug 23 00:52:01 CDT 2013
Author: wilde
Date: 2013-08-23 00:52:01 -0500 (Fri, 23 Aug 2013)
New Revision: 6969
Modified:
SwiftTutorials/CIC_2013-08-09/doc/README
SwiftTutorials/CIC_2013-08-09/setup.sh
Log:
Adjust sites file format; center figures.
Modified: SwiftTutorials/CIC_2013-08-09/doc/README
--- SwiftTutorials/CIC_2013-08-09/doc/README 2013-08-23 05:31:45 UTC (rev 6968)
+++ SwiftTutorials/CIC_2013-08-09/doc/README 2013-08-23 05:52:01 UTC (rev 6969)
@@ -1,5 +1,5 @@
-Swift CIC Tutorial - 2013.0827
+OSGconnect Swift Tutorial - 2013.0827
@@ -22,8 +22,6 @@
Workflow tutorial setup
@@ -145,17 +143,17 @@
The stats.sh script reads a file containing n numbers and prints the average
of those numbers to stdout.
-Introductory exercises
-Parts 1-3 (p1.swift - p3.swift) run locally and serve as examples of the Swift language.
-Parts 4-6 (p4.swift - p6.swift) submit jobs to the site specified the setup stage
+OSG Connect exercises
+Parts 1-3 (p1.swift - p3.swift) run on your login host and serve as examples of the Swift language.
+Parts 4-6 (p4.swift - p6.swift) submit jobs to OSG Connect resources.
-p1 - Run an application under Swift
+Part 1: Run a single application under Swift
The first swift script, p1.swift, runs simulate.sh to generate a single random
number. It writes the number to a file.
-image:p1.png[]
+image::part01.png["p1 workflow",align="center"]
.p1.swift
@@ -197,13 +195,13 @@
$ ./clean.sh
-p2 - Parallel loops with foreach
+Part 2: Running an ensemble of many apps in parallel with "foreach" loops
The p2.swift script introduces the foreach loop. This script runs many
simulations. The script also shows an example of naming the files. The output files
are now called sim_N.out.
-image:p2.png[]
+image::part02.png[align="center"]
.p2.swift
@@ -216,12 +214,12 @@
$ swift p2.swift
-p3 - Merging/reducing the results of a parallel foreach loop
+Part 3: Analyzing results of a parallel ensemble
p3.swift introduces a postprocessing step. After all the parallel simulations have completed, the files
created by simulation.sh will be averaged by stats.sh.
-image:p3.png[]
+image::part03.png[align="center"]
.p3.swift
@@ -234,15 +232,18 @@
$ swift p3.swift
-p4 - Running on the remote site nodes
-p4.swift is the first script that will submit jobs to remote site nodes for analysis.
-It is similar to earlier scripts, with a few minor exceptions. To generalize the script
-for other types of remote execution (e.g., when no shared filesystem is available to the compute nodes), the application simulate.sh
-will get transferred to the worker node by Swift, in the same manner as any other input data file.
+Part 4: Running a parallel ensemble on OSG Connect resources
-image:p4.png[]
+p4.swift is the first script that will submit jobs to remote site
+nodes for analysis. It is similar to earlier scripts, with a few
+minor exceptions. To generalize the script for other types of remote
+execution (e.g., when no shared filesystem is available to the compute
+nodes), the application simulate.sh will get transferred to the worker
+node by Swift, in the same manner as any other input data file.
+image::part04.png[align="center"]
.p4.swift
sys::[cat -n ../part04/p4.swift]
@@ -255,14 +256,16 @@
Output files will be named output/sim_N.out.
-p5 - Running the stats summary step on the remote site
-p5.swift introduces a postprocessing step. After all the parallel simulations have completed, the files
-created by simulation.sh will be averaged by stats.sh. This is similar to p3, but all app invocations
-are done on remote nodes with Swift managing file transfers.
+Part 5: Controlling where applications run
-image:p5.png[]
+p5.swift introduces a postprocessing step. After all the parallel
+simulations have completed, the files created by simulation.sh will be
+averaged by stats.sh. This is similar to p3, but all app invocations
+are done on remote nodes with Swift managing file transfers.
+image::part05.png[align="center"]
.p5.swift
sys::[cat -n ../part05/p5.swift]
@@ -273,29 +276,32 @@
$ swift p5.swift
-p6 - Add additional apps and randomness
+Part 6: Specifying more complex workflow patterns
p6.swift build on p5.swift, but adds new apps for generating a random
-seed and a random bias value.
+seed and a random bias value.
-image:p6.png[]
+image::part06.png[align="center"]
.p6.swift
sys::[cat -n ../part06/p6.swift]
-In order to run on the cluster, sites.xml needed to be modified. Here is
-the new sites.xml we are using for this example. Note the changes between the sites.xml file
-in this example which uses condor, and the sites.xml file in part 1, which runs locally.
+In order to run on the cluster, sites.xml needed to be modified. Here
+is the new sites.xml we are using for this example. Note the changes
+between the sites.xml file in this example which uses condor, and the
+sites.xml file in part 1, which runs locally.
.sites.xml
sys::[cat -n ../part06/sites.xml]
-Below is the updated apps file. Since Swift is staging shell scripts remotely to nodes on the cluster,
-the only application it needs defined here is the shell.
+Below is the updated apps file. Since Swift is staging shell scripts
+remotely to nodes on the cluster, the only application you need to
+define here is the shell.
.apps
@@ -308,6 +314,8 @@
$ swift p6.swift -steps=3 # each simulation takes 3 seconds
Running Swift scripts on Cloud resources
@@ -342,14 +350,12 @@
swift -sites.file sites.xml -config cf -tc.file tc p9.swift
* Add cloud resources to existing examples:
./addcloud.sh <dir> #where dir is a tutorial script directory
e.g.
./addcloud.sh ../part01 #will create a new site pool "both.xml" in ../part01
* Finally, to clean up the log files, kill agent and shutdown the coaster service:
@@ -366,7 +372,6 @@
To learn more about the configuration files, see Swift user-guide:
http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html
Running Swift/T on Vesta with Python and R integration
Modified: SwiftTutorials/CIC_2013-08-09/setup.sh
--- SwiftTutorials/CIC_2013-08-09/setup.sh 2013-08-23 05:31:45 UTC (rev 6968)
+++ SwiftTutorials/CIC_2013-08-09/setup.sh 2013-08-23 05:52:01 UTC (rev 6969)
@@ -77,7 +77,7 @@
return
fi
-cat >>sites.condor<<END
+cat >sites.condor <<END
<config>
<pool handle="osg">
@@ -89,40 +89,19 @@
<profile namespace="globus" key="maxWalltime">00:01:00</profile>
<profile namespace="globus" key="highOverAllocation">10000</profile>
<profile namespace="globus" key="lowOverAllocation">10000</profile>
- <profile namespace="globus" key="internalHostname">$CONTACTHOST</profile> <!-- FIXME Make Dynamic from setup -->
+ <profile namespace="globus" key="internalHostname">$CONTACTHOST</profile>
<profile namespace="globus" key="slots">20</profile>
<profile namespace="globus" key="maxNodes">1</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
+ <workdirectory>.</workdirectory> <!-- Alt: /tmp/swift/OSG/{env.USER} -->
<!-- For UC3: -->
<profile namespace="globus" key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
<!-- For OSGConnect -->
<profile namespace="globus" key="condor.+ProjectName">"swift"</profile>
<profile namespace="globus" key="jobType">nonshared</profile>
- <!-- UC3 --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("uc3-c*", Machine)</profile> -->
- <!-- UCIT --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("appcloud[0-1][0-9].*", Machine)</profile> -->
- <!-- MWUC --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("uct2-c*", Machine)</profile> -->
- <!-- MWIU --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("iut2-c*", Machine)</profile> -->
- <!-- MWUI --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("taub*", Machine)</profile> -->
- <!-- MWT2 --> <!-- <profile namespace="globus" key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile> -->
- <!-- OSG --> <!-- <profile namespace="globus" key="condor.Requirements">isUndefined(GLIDECLIENT_Name) == FALSE</profile> -->
- <!-- MULT --> <!-- <profile namespace="globus" key="condor.Requirements">UidDomain == "osg-gk.mwt2.org" && (regexp("iut2-c*", Machine) || regexp("uct2-c*", Machine)) </profile> -->
- <workdirectory>.</workdirectory> <!-- VERIFY OK FOR ALL OSG! -->
</pool>
</config>
-MWT2 @UC Requirements = regexp("uct2-c*", Machine)
-MWT2 @IU Requirements = regexp("iut2-c*", Machine)
-MWT2 @UIUC Requirements = regexp("taub*", Machine)
-UC ATLAS Tier 3 Requirements = regexp("uct3*", Machine)
-ITS Virtualization Lab Requirements = regexp("appcloud[0-1][0-9].*", Machine)
-Open Science Grid
-Requirements = isUndefined(GLIDECLIENT_Name) == FALSE
END
for p in 04 05 06; do
@@ -130,3 +109,19 @@
done
return
+# Integrate somewhere:
+cat <<END
+ <!-- OSG Connect Resource selector expressions: -->
+ <!-- UC3S regexp("uc3-c*", Machine) -->
+ <!-- UCIT regexp("appcloud[0-1][0-9].*", Machine)-->
+ <!-- MWUC regexp("uct2-c*", Machine) -->
+ <!-- MWIU regexp("iut2-c*", Machine) -->
+ <!-- MWUI regexp("taub*", Machine) -->
+ <!-- MWT2 UidDomain == "osg-gk.mwt2.org" -->
+ <!-- OSG isUndefined(GLIDECLIENT_Name) == FALSE -->
+ <!-- MULT UidDomain == "osg-gk.mwt2.org" && (regexp("iut2-c*", Machine) || regexp("uct2-c*", Machine)) -->
+ <!-- E.g. for UC3 cycle seeder: -->
+ <!-- <profile namespace="globus" key="condor.Requirements">regexp("uc3-c*", Machine)</profile> -->
+END
More information about the Swift-commit
