[Swift-commit] r6958 - SwiftTutorials/CIC_2013-08-09/doc
wilde at ci.uchicago.edu
Thu Aug 22 13:01:36 CDT 2013
Author: wilde
Date: 2013-08-22 13:01:36 -0500 (Thu, 22 Aug 2013)
New Revision: 6958
Added:
SwiftTutorials/CIC_2013-08-09/doc/2-stage-diamond.png
Modified:
SwiftTutorials/CIC_2013-08-09/doc/README
Log:
cic doc edits.
Added: SwiftTutorials/CIC_2013-08-09/doc/2-stage-diamond.png
(Binary files differ)
Property changes on: SwiftTutorials/CIC_2013-08-09/doc/2-stage-diamond.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: SwiftTutorials/CIC_2013-08-09/doc/README
--- SwiftTutorials/CIC_2013-08-09/doc/README 2013-08-22 17:22:03 UTC (rev 6957)
+++ SwiftTutorials/CIC_2013-08-09/doc/README 2013-08-22 18:01:36 UTC (rev 6958)
@@ -52,39 +52,97 @@
$ cd tutorial # change to the newly created tutorial directory
-$ source setup.sh <SITE> # sets swift config files in $HOME/.swift
+$ source setup.sh # sets swift config files in $HOME/.swift
$ java -version # verify that you have Oracle JAVA (prefered; 1.6 or later)
$ swift -version # verify that Swift 0.94 is in your $PATH and functional
-NOTE: If you re-login, you will need to re-run source setup.sh.
+NOTE: If you re-login or create additional terminal sessions, you must re-run `source setup.sh` in each one.
Simple "science applications" for the workflow tutorial
-There are two shell scripts included that serve a very simple stand-ins for science application:
-simulation.sh and stats.sh
+We use two shell scripts in this tutorial to serve as very simple stand-ins for a real science application:
+`simulation.sh` and `stats.sh`. These are located in the `tutorial/app` directory.
simulation.sh
-The simulation.sh script serves as a trivial substitute for a complex scientific simulation application. It generates and prints a set of one or more random integers in the range [0-2^32) as controlled by its optional arguments, which are:
+The simulation.sh script serves as a trivial substitute for a complex scientific simulation application. It generates and prints a set of one or more random integers in the range [0-2^62) as controlled by its optional arguments, which are:
+$ ./app/simulate.sh --help
+./app/simulate.sh: usage:
+ -b|--bias offset bias: add this integer to all results
+ -B|--biasfile file of integer biases to add to results
+ -l|--log generate a log in stderr if not null
+ -n|--nvalues print this many values per simulation
+ -r|--range range (limit) of generated results
+ -s|--seed use this integer [0..32767] as a seed
+ -S|--seedfile use this file (containing integer seeds [0..32767]) one per line
+ -t|--timesteps number of simulated "timesteps" in seconds (determines runtime)
+ -x|--scale scale the results by this integer
+ -h|-?|?|--help print this help
.simulation.sh arguments
[width="80%",cols="^2,10",options="header"]
-|Argument number|Description
+|Argument|Short|Description
|1 |runtime: sets run time of simulation.sh in seconds
|2 |range: limits generated values to the range [0,range-1]
|3 |biasfile: add the integer contained in this file to each value generated
|4 |scale: multiplies each generated value by this integer
|5 |count: number of values to generate in the simulation
-With no arguments, simulate.sh prints 1 number in the range of 1-100. Otherwise it generates n numbers of the form (R*scale)+bias where R is a random integer.
+With no arguments, simulate.sh prints 1 number in the range of 1-100. Otherwise it generates n numbers of the form (R*scale)+bias where R is a random integer. By default it logs information about its execution environment to stderr. Here's some examples of its usage:
-$ ./simulate.sh
-96
+$ simulate.sh 2>log
+ 5
+$ head -5 log
+Called as: /home/wilde/swift/tut/CIC_2013-08-09/app/simulate.sh:
+Start time: Thu Aug 22 12:40:24 CDT 2013
+Running on node: login01.osgconnect.net
+$ tail -5 log
+SSH_CLIENT=67.173.156.31 46887 22
+SSH_CONNECTION=67.173.156.31 46887 128.135.158.173 22
+SSH_TTY=/dev/pts/9
+TERM=xterm-color
+USER=wilde
+$ simulate.sh -n 3 -r 1000000 2>log
+ 386702
+ 239454
+ 13849
+$ simulate.sh -n 3 -r 1000000 -x 100 2>log
+ 6643700
+62182300
+ 5230600
+$ simulate.sh -n 3 -r 1000 -x 1000 2>log
+ 565000
+ 636000
+ 477000
+$ time simulate.sh -n 3 -r 1000 -x 1000 -t 3 2>log
+ 336000
+ 20000
+ 320000
+real 0m3.012s
+user 0m0.005s
+sys 0m0.006s
stats.sh
More information about the Swift-commit
