[Swift-commit] r6940 - SwiftTutorials/CIC_2013-08-09/part06
wilde at ci.uchicago.edu
Thu Aug 22 10:30:57 CDT 2013
Author: wilde
Date: 2013-08-22 10:30:56 -0500 (Thu, 22 Aug 2013)
New Revision: 6940
Added:
SwiftTutorials/CIC_2013-08-09/part06/app
Modified:
SwiftTutorials/CIC_2013-08-09/part06/apps
SwiftTutorials/CIC_2013-08-09/part06/p6.swift
SwiftTutorials/CIC_2013-08-09/part06/sites.xml
Log:
for CIC
Added: SwiftTutorials/CIC_2013-08-09/part06/app
--- SwiftTutorials/CIC_2013-08-09/part06/app (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/part06/app 2013-08-22 15:30:56 UTC (rev 6940)
@@ -0,0 +1 @@
+link ../app
\ No newline at end of file
Property changes on: SwiftTutorials/CIC_2013-08-09/part06/app
___________________________________________________________________
Added: svn:special
Modified: SwiftTutorials/CIC_2013-08-09/part06/apps
--- SwiftTutorials/CIC_2013-08-09/part06/apps 2013-08-22 14:27:15 UTC (rev 6939)
+++ SwiftTutorials/CIC_2013-08-09/part06/apps 2013-08-22 15:30:56 UTC (rev 6940)
@@ -1 +1 @@
-uc3 sh /bin/bash
+osg sh /bin/bash
Modified: SwiftTutorials/CIC_2013-08-09/part06/p6.swift
--- SwiftTutorials/CIC_2013-08-09/part06/p6.swift 2013-08-22 14:27:15 UTC (rev 6939)
+++ SwiftTutorials/CIC_2013-08-09/part06/p6.swift 2013-08-22 15:30:56 UTC (rev 6940)
@@ -1,52 +1,63 @@
type file;
-# Applications to be called by this script
+# Define external application programs to be invoked
-file simulation_script <"simulate.sh">;
-file analysis_script <"stats.sh">;
+file simulation_prog <"app/simulate.sh">;
+file analysis_prog <"app/stats.sh">;
+file genbias_prog = simulation_prog;
+file genseed_prog = simulation_prog;
# app() functions for application programs to be called:
-app (file out) genrand (file script, int timesteps, int sim_range)
+app (file out) genseed (file prog, int nseeds)
- sh @filename(script) timesteps sim_range stdout=@filename(out);
+ sh @prog "-r" 2000000 "-n" nseeds stdout=@out;
-app (file out) simulation (file script, int timesteps, int sim_range, file bias_file, int scale, int sim_count)
+app (file out) genbias (file prog, int bias_range, int nvalues)
- sh @filename(script) timesteps sim_range @filename(bias_file) scale sim_count stdout=@filename(out);
+ sh @prog "-r" bias_range "-n" nvalues stdout=@out;
-app (file out) analyze (file script, file s[])
+app (file out, file log) simulation (file prog, int timesteps, int sim_range,
+ file bias_file, int scale, int sim_count)
- sh @script @filenames(s) stdout=@filename(out);
+ sh @prog "-t" timesteps "-r" sim_range "-B" @bias_file "-x" scale
+ "-n" sim_count stdout=@out stderr=@log;
-# Command line params to this script:
+app (file out) analyze (file prog, file s[])
+ sh @prog @filenames(s) stdout=@out;
+# Command line arguments
int nsim = @toInt(@arg("nsim", "10")); # number of simulation programs to run
int range = @toInt(@arg("range", "100")); # range of the generated random numbers
-int count = @toInt(@arg("count", "10")); # number of random numbers generated per simulation
+int count = @toInt(@arg("count", "10")); # number of values generated per simulation
+int steps = @toInt(@arg("steps", "1")); # number of timesteps (seconds) per simulation
# Main script and data
tracef("\n*** Script parameters: nsim=%i range=%i count=%i\n\n", nsim, range, count);
-file bias<"dynamic_bias.dat">; # Dynamically generated bias for simulation ensemble
+file seedfile<"output/seed.dat">; # Dynamically generated bias for simulation ensemble
+seedfile = genseed(genseed_prog, 1);
-bias = genrand(simulation_script, 1, 1000);
+int seedval = readData(seedfile);
+tracef("Generated seed=%i\n", seedval);
-file sims[]; # Array of files to hold each simulation output
+file sims[]; # Array of files to hold each simulation output
foreach i in [0:nsim-1] {
- int steps = readData(genrand(simulation_script, 1, 5));
- tracef(" for simulation[%i] steps=%i\n", i, steps+1);
- file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
- simout = simulation(simulation_script, steps+1, range, bias, 100000, count);
+ file biasfile <single_file_mapper; file=@strcat("output/bias_",i,".dat")>;
+ file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+ file simlog <single_file_mapper; file=@strcat("output/sim_",i,".log")>;
+ biasfile = genbias(genbias_prog, 1000, 20);
+ (simout,simlog) = simulation(simulation_prog, steps, range, biasfile, 100000, count);
sims[i] = simout;
file stats<"output/stats.out">; # Final output file: average of all "simulations"
-stats = analyze(analysis_script,sims);
+stats = analyze(analysis_prog,sims);
Modified: SwiftTutorials/CIC_2013-08-09/part06/sites.xml
--- SwiftTutorials/CIC_2013-08-09/part06/sites.xml 2013-08-22 14:27:15 UTC (rev 6939)
+++ SwiftTutorials/CIC_2013-08-09/part06/sites.xml 2013-08-22 15:30:56 UTC (rev 6940)
@@ -1,24 +1,45 @@
<config>
- <pool handle="uc3">
+ <pool handle="osg">
<execution provider="coaster" jobmanager="local:condor"/>
- <profile namespace="karajan" key="jobThrottle">10.00</profile>
+ <profile namespace="karajan" key="jobThrottle">5.00</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<profile namespace="globus" key="jobsPerNode">1</profile>
- <profile namespace="globus" key="maxtime">300</profile>
+ <profile namespace="globus" key="maxtime">3600</profile>
<profile namespace="globus" key="maxWalltime">00:01:00</profile>
- <profile namespace="globus" key="highOverAllocation">100</profile>
- <profile namespace="globus" key="lowOverAllocation">100</profile>
- <profile namespace="globus" key="slots">20</profile>
+ <profile namespace="globus" key="highOverAllocation">10000</profile>
+ <profile namespace="globus" key="lowOverAllocation">10000</profile>
+ <profile namespace="globus" key="internalHostname">128.135.158.243</profile> <!-- FIXME Make Dynamic from setup -->
+ <profile namespace="globus" key="slots">20</profile>
<profile namespace="globus" key="maxNodes">1</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
+ <!-- For UC3: -->
<profile namespace="globus" key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
+ <!-- For OSGConnect -->
+ <!-- <profile namespace="globus" key="condor.+ProjectName">"swift"</profile> -->
<profile namespace="globus" key="jobType">nonshared</profile>
- <!-- Requirements = regexp("uc3-c*", Machine) -->
- <!-- <profile namespace="globus" key="condor.Requirements">regexp("uc3-c*", Machine)</profile> -->
- <!-- <profile namespace="globus" key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile> -->
+ <!-- UC3 --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("uc3-c*", Machine)</profile> -->
+ <!-- UCIT --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("appcloud[0-1][0-9].*", Machine)</profile> -->
+ <!-- MWUC --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("uct2-c*", Machine)</profile> -->
+ <!-- MWIU --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("iut2-c*", Machine)</profile> -->
+ <!-- MWUI --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("taub*", Machine)</profile> -->
+ <!-- MWT2 --> <!-- <profile namespace="globus" key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile> -->
+ <!-- OSG --> <!-- <profile namespace="globus" key="condor.Requirements">isUndefined(GLIDECLIENT_Name) == FALSE</profile> -->
+ <!-- MULT --> <!-- <profile namespace="globus" key="condor.Requirements">UidDomain == "osg-gk.mwt2.org" && (regexp("iut2-c*", Machine) || regexp("uct2-c*", Machine)) </profile> -->
<workdirectory>.</workdirectory>
</pool>
</config>
+MWT2 @UC Requirements = regexp("uct2-c*", Machine)
+MWT2 @IU Requirements = regexp("iut2-c*", Machine)
+MWT2 @UIUC Requirements = regexp("taub*", Machine)
+UC ATLAS Tier 3 Requirements = regexp("uct3*", Machine)
+ITS Virtualization Lab Requirements = regexp("appcloud[0-1][0-9].*", Machine)
+Open Science Grid
+Requirements = isUndefined(GLIDECLIENT_Name) == FALSE
More information about the Swift-commit
