[Swift-commit] r6922 - in SwiftTutorials/CIC_2013-08-09: . OLD	OLD/part01 app bin cloud cloud/service doc part06 part08 scripts
    wilde at ci.uchicago.edu
    Wed Aug 21 15:44:20 CDT 2013
Author: wilde
Date: 2013-08-21 15:44:20 -0500 (Wed, 21 Aug 2013)
New Revision: 6922
Added:
   SwiftTutorials/CIC_2013-08-09/OLD/cf
   SwiftTutorials/CIC_2013-08-09/OLD/part01/
   SwiftTutorials/CIC_2013-08-09/app/simulate.sh
   SwiftTutorials/CIC_2013-08-09/app/simulatepos.sh
   SwiftTutorials/CIC_2013-08-09/bin/sitecount.sh
   SwiftTutorials/CIC_2013-08-09/cloud/RL2stage.swift
   SwiftTutorials/CIC_2013-08-09/cloud/app
   SwiftTutorials/CIC_2013-08-09/cloud/nodecount
   SwiftTutorials/CIC_2013-08-09/cloud/service/
   SwiftTutorials/CIC_2013-08-09/cloud/service/cleancloud
   SwiftTutorials/CIC_2013-08-09/cloud/service/coaster-service.conf
   SwiftTutorials/CIC_2013-08-09/cloud/service/hosts.txt
   SwiftTutorials/CIC_2013-08-09/cloud/service/pool.txt
   SwiftTutorials/CIC_2013-08-09/cloud/service/startcloud
   SwiftTutorials/CIC_2013-08-09/cloud/service/stopcloud
   SwiftTutorials/CIC_2013-08-09/cloud/service/tutorial.pem
   SwiftTutorials/CIC_2013-08-09/part08/rensemble.swift
   SwiftTutorials/CIC_2013-08-09/scripts/
   SwiftTutorials/CIC_2013-08-09/scripts/rensemble.swift
Removed:
   SwiftTutorials/CIC_2013-08-09/app/simulate2.sh
   SwiftTutorials/CIC_2013-08-09/cloud/cf
   SwiftTutorials/CIC_2013-08-09/cloud/coaster-service.conf
   SwiftTutorials/CIC_2013-08-09/cloud/data.txt
   SwiftTutorials/CIC_2013-08-09/cloud/dynamic_bias.dat
   SwiftTutorials/CIC_2013-08-09/cloud/hosts.txt
   SwiftTutorials/CIC_2013-08-09/cloud/pool.txt
   SwiftTutorials/CIC_2013-08-09/cloud/run.catsn
   SwiftTutorials/CIC_2013-08-09/cloud/simulate.sh
   SwiftTutorials/CIC_2013-08-09/cloud/sitecount.sh
   SwiftTutorials/CIC_2013-08-09/cloud/sites.xml
   SwiftTutorials/CIC_2013-08-09/cloud/startcloud
   SwiftTutorials/CIC_2013-08-09/cloud/stats.sh
   SwiftTutorials/CIC_2013-08-09/cloud/stopcloud
   SwiftTutorials/CIC_2013-08-09/cloud/tc.data
   SwiftTutorials/CIC_2013-08-09/cloud/tutorial.pem
   SwiftTutorials/CIC_2013-08-09/part01/
   SwiftTutorials/CIC_2013-08-09/part08/p8.swift
Modified:
   SwiftTutorials/CIC_2013-08-09/OLD/part01/apps
   SwiftTutorials/CIC_2013-08-09/doc/README
   SwiftTutorials/CIC_2013-08-09/doc/TODO
   SwiftTutorials/CIC_2013-08-09/part06/sites.xml
   SwiftTutorials/CIC_2013-08-09/part08/sites.xml
   SwiftTutorials/CIC_2013-08-09/setup.sh
Log:
Changes for CIC workshop.
Copied: SwiftTutorials/CIC_2013-08-09/OLD/cf (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/cf)
--- SwiftTutorials/CIC_2013-08-09/OLD/cf	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/OLD/cf	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,6 @@
+use.provider.staging=true
+wrapperlog.always.transfer=false
+execution.retries=10
+provider.staging.pin.swiftfiles=false
+sitedir.keep=false
+use.wrapper.staging=false
Modified: SwiftTutorials/CIC_2013-08-09/OLD/part01/apps
--- SwiftTutorials/CIC_2013-08-09/part01/apps	2013-08-15 16:31:36 UTC (rev 6868)
+++ SwiftTutorials/CIC_2013-08-09/OLD/part01/apps	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,2 +1,2 @@
-localhost simulate simulate.sh
+localhost simulate simulate2.sh
 persistent-coasters simulate simulate.sh
Deleted: SwiftTutorials/CIC_2013-08-09/app/simulate.sh
--- SwiftTutorials/CIC_2013-08-09/app/simulate.sh	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/app/simulate.sh	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,38 +0,0 @@
-#! /bin/bash
-log() {
-  printf "Start time: "; /bin/date
-  printf "Job is running on node: "; /bin/hostname
-  printf "Job running as user: "; /usr/bin/id
-  echo "Environment:"
-  /bin/env | /bin/sort
-runtime=${1:-0}
-range=${2:-100}
-biasfile=${3:-nobias}
-scale=${4:-1}
-n=${5:-1}
-if [ $biasfile = nobias ]; then
-  offset=0
-else
-  read offset <$biasfile
-fi
-# run for some number of "timesteps"
-sleep $runtime
-# emit n "simulation results", scaled and biased by the specified argument values
-for ((i=0;i<n;i++)); do
-  value=$(((($RANDOM)*32768)+$RANDOM))
-  echo $(( ($value%range)*scale+offset))
-done
-# log environmental data
-log 1>&2
Copied: SwiftTutorials/CIC_2013-08-09/app/simulate.sh (from rev 6892, SwiftTutorials/CIC_2013-08-09/app/simulate2.sh)
--- SwiftTutorials/CIC_2013-08-09/app/simulate.sh	                        (rev 0)
@@ -0,0 +1,131 @@
+#! /bin/bash
+printparams()
+  printf "\nSimulation parameters:\n\n"
+  echo bias=$bias
+  echo biasfile=$biasfile
+  echo initseed=$initseed
+  echo log=$log
+  echo paramfile=$paramfile
+  echo range=$range
+  echo scale=$scale
+  echo seedfile=$seedfile
+  echo timesteps=$timesteps
+  echo output width=$width
+log() {
+  printf "\nCalled as: $0: $cmdargs\n\n"
+  printf "Start time: "; /bin/date
+  printf "Running on node: "; /bin/hostname
+  printf "Running as user: "; /usr/bin/id
+  printparams
+  printf "\nEnvironment:\n\n"
+  /bin/env | /bin/sort
+addsims() {
+  while read f1 ; do
+    read -u 3 f2
+    if [ _$f1 = _ ]; then f1=0; fi
+    if [ _$f2 = _ ]; then f2=0; fi
+    printf "%${width}d\n" $(($f1+$f2))
+  done <$1 3<$2
+# set defaults
+bias=0
+biasfile=none
+initseed=none
+log=yes
+paramfile=none
+range=100
+scale=1
+seedfile=none
+timesteps=0
+nvalues=1
+width=8
+cmdargs="$*"
+usage()
+  echo $0: usage:
+  cat <<END
+    -b|--bias       offset bias: add this integer to all results
+    -B|--biasfile   file of integer biases to add to results
+    -l|--log        generate a log in stderr if not null
+    -n|--nvalues    print this many values per simulation
+    -p|--paramfile  take these parameters (in form param=value) from this file
+    -r|--range      range (limit) of generated results
+    -s|--seed       use this integer [0..32767] as a seed
+    -S|--seedfile   use this file (containing integer seeds [0..32767]) one per line
+    -t|--timesteps  number of simulated "timesteps" in seconds (determines runtime)
+    -x|--scale      scale the results by this integer
+    -h|-?|?|--help  print this help
+END
+while [ $# -gt 0 ]; do
+  case $1 in
+    -b|--bias)      bias=$2      ;;
+    -B|--biasfile)  biasfile=$2  ;;
+    -l|--log)       log=$2       ;;
+    -n|--nvalues)   nvalues=$2   ;;
+    -p|--paramfile) paramfile=$2 ;;
+    -s|--seed)      initseed=$2  ;;
+    -S|--seedfile)  seedfile=$2  ;;
+    -t|--timesteps) timesteps=$2 ;;
+    -r|--range)     range=$2     ;;
+    -w|--width)     width=$2     ;;
+    -x|--scale)     scale=$2     ;;
+    -h|-?|--help|*) usage; exit  ;;
+  esac
+  shift 2
+done
+# process initial seed
+if [ $initseed != none ]; then
+  RANDOM=$initseed
+fi
+# process file of seeds
+if [ $seedfile != none ]; then
+  seed=0
+  while read $seedfile s; do
+    seed=$(($seed+$s))
+  done <$seedfile
+  RANDOM=$seed
+fi
+# run for some number of "timesteps"
+sleep $timesteps
+# emit N (nvalues) "simulation results" scaled and biased by argument values
+simout=$(mktemp simout.XXXX)
+for ((i=0;i<nvalues;i++)); do
+  # value=$(( (($RANDOM)*(2**16))+$RANDOM ))
+  value=$(( (($RANDOM)*(2**48)) + (($RANDOM)*(2**32)) + (($RANDOM)*(2**16)) + $RANDOM ))
+  printf "%${width}d\n" $(( ($value%range)*scale+bias))
+done  >$simout
+# process file of biases
+if [ $biasfile != none ]; then
+  printf "\nMerged:\n\n"
+  addsims $simout $biasfile
+else
+  cat $simout
+fi
+rm $simout
+# log environmental data
+if [ $log != none ]; then
+  log 1>&2
+fi
Deleted: SwiftTutorials/CIC_2013-08-09/app/simulate2.sh
--- SwiftTutorials/CIC_2013-08-09/app/simulate2.sh	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/app/simulate2.sh	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,131 +0,0 @@
-#! /bin/bash
-printparams()
-  printf "\nSimulation parameters:\n\n"
-  echo bias=$bias
-  echo biasfile=$biasfile
-  echo initseed=$initseed
-  echo log=$log
-  echo paramfile=$paramfile
-  echo range=$range
-  echo scale=$scale
-  echo seedfile=$seedfile
-  echo timesteps=$timesteps
-  echo output width=$width
-log() {
-  printf "\nCalled as: $0: $cmdargs\n\n"
-  printf "Running on node: "; /bin/hostname
-  printf "Running as user: "; /usr/bin/id
-  printparams
-  printf "\nEnvironment:\n\n"
-addsims() {
-  while read f1 ; do
-    read -u 3 f2
-    if [ _$f1 = _ ]; then f1=0; fi
-    if [ _$f2 = _ ]; then f2=0; fi
-    printf "%${width}d\n" $(($f1+$f2))
-  done <$1 3<$2
-# set defaults
-bias=0
-biasfile=none
-initseed=none
-log=yes
-paramfile=none
-range=100
-scale=1
-seedfile=none
-timesteps=0
-nvalues=1
-width=8
-cmdargs="$*"
-usage()
-  echo $0: usage:
-  cat <<END
-    -t|--timesteps  number of simulated "timesteps" in seconds (determines runtime)
-    -r|--range      range (limit) of generated results
-    -B|--biasfile   file of integer biases to add to results
-    -l|--log        generate a log in stderr if not null
-    -x|--scale      scale the results by this integer
-    -n|--nvalues    print this many values per simulation
-    -S|--seedfile   use this file (containing integer seeds [0..32767]) one per line
-    -i|--seed       use this integer [0..32767] as a seed
-    -b|--bias       offset bias: add this integer to all results
-    -p|--paramfile  take these parameters (in form param=value) from this file
-    -h|-?|?|--help  print this help
-END
-while [ $# -gt 0 ]; do
-  case $1 in
-    -t|--timesteps) timesteps=$2 ;;
-    -r|--range)     range=$2     ;;
-    -B|--biasfile)  biasfile=$2  ;;
-    -l|--log)       log=$2       ;;
-    -x|--scale)     scale=$2     ;;
-    -n|--nvalues)   nvalues=$2   ;;
-    -S|--seedfile)  seedfile=$2  ;;
-    -s|--seed)      initseed=$2  ;;
-    -b|--bias)      bias=$2      ;;
-    -p|--paramfile) paramfile=$2 ;;
-    -w|--width)     width=$2     ;;
-    -h|-?|--help|*) usage; exit  ;;
-  esac
-  shift 2
-done
-# process initial seed
-if [ $initseed != none ]; then
-  RANDOM=$initseed
-fi
-# process file of seeds
-if [ $seedfile != none ]; then
-  seed=0
-  while read $seedfile s; do
-    seed=$(($seed+$s))
-  done <$seedfile
-  RANDOM=$seed
-fi
-sleep $timesteps
-# emit n "simulation results" scaled and biased by argument values
-simout=$(mktemp simout.XXXX)
-for ((i=0;i<nvalues;i++)); do
-  # value=$(( (($RANDOM)*(2**16))+$RANDOM ))
-  value=$(( (($RANDOM)*(2**48)) + (($RANDOM)*(2**32)) + (($RANDOM)*(2**16)) + $RANDOM ))
-  printf "%${width}d\n" $(( ($value%range)*scale+bias))
-done  >$simout
-# process file of biases
-if [ $biasfile != none ]; then
-  printf "\nMerged:\n\n"
-  addsims $simout $biasfile
-else
-  cat $simout
-fi
-rm $simout
-if [ $log != none ]; then
-  log 1>&2
-fi
Copied: SwiftTutorials/CIC_2013-08-09/app/simulatepos.sh (from rev 6892, SwiftTutorials/CIC_2013-08-09/app/simulate.sh)
--- SwiftTutorials/CIC_2013-08-09/app/simulatepos.sh	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/app/simulatepos.sh	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,38 @@
+#! /bin/bash
+log() {
+  printf "Job is running on node: "; /bin/hostname
+  printf "Job running as user: "; /usr/bin/id
+  echo "Environment:"
+runtime=${1:-0}
+range=${2:-100}
+biasfile=${3:-nobias}
+scale=${4:-1}
+n=${5:-1}
+if [ $biasfile = nobias ]; then
+  offset=0
+else
+  read offset <$biasfile
+fi
+sleep $runtime
+# emit n "simulation results", scaled and biased by the specified argument values
+for ((i=0;i<n;i++)); do
+  value=$(((($RANDOM)*32768)+$RANDOM))
+  echo $(( ($value%range)*scale+offset))
+done
+log 1>&2
Copied: SwiftTutorials/CIC_2013-08-09/bin/sitecount.sh (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/sitecount.sh)
--- SwiftTutorials/CIC_2013-08-09/bin/sitecount.sh	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/bin/sitecount.sh	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1 @@
+grep "submitting" cps*.log | awk '{print $5}' | sed -e 's/:.*//' | sort | uniq -c
Copied: SwiftTutorials/CIC_2013-08-09/cloud/RL2stage.swift (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/p9.swift)
--- SwiftTutorials/CIC_2013-08-09/cloud/RL2stage.swift	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/RL2stage.swift	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,64 @@
+type file;
+# Application programs to be called by this script
+global file simulation_prog  <"app/simulate.sh">;
+global file analysis_prog    <"app/stats.sh">;
+global file genrand_prog     <"app/genrand.sh">;
+# app() functions for application programs:
+app (file out) genrand (file pgm, int timesteps, int sim_range)
+  local_sh @filename(pgm) timesteps sim_range stdout=@filename(out);
+app (file out) simulation (file pgm, int timesteps, int sim_range, file bias_file, int scale, int sim_count)
+  sh @filename(pgm) timesteps sim_range @filename(bias_file) scale sim_count stdout=@filename(out);
+app (file out) analyze (file pgm, file s[])
+  local_sh @filename(pgm) @filenames(s) stdout=@filename(out);
+# Higher-level functions that call app() functions
+(int scale) calcScale(int maxScale)
+  scale = readData(genrand(simulation_prog, 1, maxScale));
+(file biasFile) calcBias (int maxBias)
+  biasFile = genrand(simulation_prog, 1, maxBias);
+# Command line params to this script:
+int  nsim  = @toInt(@arg("nsim",  "10"));  # number of simulation programs to run
+int  range = @toInt(@arg("range", "100")); # range of the generated random numbers
+int  count = @toInt(@arg("count", "10"));  # number of random numbers generated per simulation
+int  steps = @toInt(@arg("steps", "3"));   # number of time steps per simulation
+# Main script and data
+tracef("\n*** Script parameters: nsim=%i range=%i count=%i\n\n", nsim, range, count);
+file bias<"dynamic_bias.dat">;    # Dynamically generated bias for simulation ensemble
+bias = calcBias(1000);
+file sims[];                      # Array of files to hold each simulation output
+foreach i in [0:nsim-1] {
+  int scale;
+  scale = 1000 * calcScale(100);
+  tracef("  for simulation[%i] scale=%i\n", i, scale);
+  file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+  simout = simulation(simulation_prog, steps+1, range, bias, scale, count);
+  sims[i] = simout;
+file stats<"output/stats.out">;            # Final output file: average of all "simulations"
+stats = analyze(analysis_prog,sims);
Added: SwiftTutorials/CIC_2013-08-09/cloud/app
--- SwiftTutorials/CIC_2013-08-09/cloud/app	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/app	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1 @@
+link ../app
\ No newline at end of file
Property changes on: SwiftTutorials/CIC_2013-08-09/cloud/app
___________________________________________________________________
Added: svn:special
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/cf
--- SwiftTutorials/CIC_2013-08-09/cloud/cf	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/cf	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,6 +0,0 @@
-use.provider.staging=true
-wrapperlog.always.transfer=false
-execution.retries=10
-provider.staging.pin.swiftfiles=false
-sitedir.keep=false
-use.wrapper.staging=false
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/coaster-service.conf
--- SwiftTutorials/CIC_2013-08-09/cloud/coaster-service.conf	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/coaster-service.conf	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,47 +0,0 @@
-#Location of SWIFT. If empty, PATH is referenced
- export SWIFT=
- # Where to place/launch worker.pl on the remote machine for sites.xml
- export WORKER_LOCATION=/root
- # How to launch workers: local, ssh, or cobalt
- export WORKER_MODE=ssh
- # Worker logging setting passed to worker.pl for sites.xml
- export WORKER_LOGGING_LEVEL=DEBUG
- export SSH_TUNNELING=yes
- # User name to use for all systems
- export WORKER_USERNAME=root
- # Worker host names for ssh
-# export WORKER_HOSTS="crush thwomp stomp crank grind churn trounce thrash vanquish"
-#export WORKER_HOSTS="ip-10-36-196-96.eu-west-1.compute.internal ip-10-36-195-69.eu-west-1.compute.internal"
- # Directory to keep log files, relative to working directory when launching start-coaster-service
- export LOG_DIR=logs
- export WORKER_LOG_DIR=/root
- # Manually define ports. If not specified, ports will be automatically generated
- #export LOCAL_PORT=50100
- #export SERVICE_PORT=50200
- # Set shared filesystem to no since work will be done in local /sandbox directory
- export SHARED_FILESYSTEM=no
- # start-coaster-service tries to automatically detect IP address.
- # Specify here if auto detection is not working correctly
- export IPADDR=
- # Below are various settings to give information about how to create sites.xml
- export WORK=/tmp/ketan
- export JOBS_PER_NODE=8
- export JOBSPERNODE=8
- export JOBTHROTTLE=$( echo "scale=5; ($JOBS_PER_NODE * $( echo $WORKER_HOSTS | wc -w ))/100 - 0.00001"|bc )
- # Swift applications
- #app cat=/bin/cat
- #app bash=/bin/bash
- #app echo=/bin/echo
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/data.txt
--- SwiftTutorials/CIC_2013-08-09/cloud/data.txt	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/data.txt	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,3 +0,0 @@
-Test Data
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/dynamic_bias.dat
--- SwiftTutorials/CIC_2013-08-09/cloud/dynamic_bias.dat	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/dynamic_bias.dat	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1 +0,0 @@
-821
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/hosts.txt
--- SwiftTutorials/CIC_2013-08-09/cloud/hosts.txt	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/hosts.txt	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,3 +0,0 @@
-54.212.81.224
-54.244.171.51
-54.212.37.161
Added: SwiftTutorials/CIC_2013-08-09/cloud/nodecount
--- SwiftTutorials/CIC_2013-08-09/cloud/nodecount	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/nodecount	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1 @@
+grep node: output/*.log | sed -e 's/^.*Job is //' | sort | uniq -c
Property changes on: SwiftTutorials/CIC_2013-08-09/cloud/nodecount
Added: svn:executable
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/pool.txt
--- SwiftTutorials/CIC_2013-08-09/cloud/pool.txt	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/pool.txt	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,3 +0,0 @@
-54.212.81.224
-54.244.171.51
-54.212.37.161
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/run.catsn
--- SwiftTutorials/CIC_2013-08-09/cloud/run.catsn	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/run.catsn	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1 +0,0 @@
-swift -sites.file sites.xml -tc.file tc -config cf catsn.swift -n=10
Added: SwiftTutorials/CIC_2013-08-09/cloud/service/cleancloud
--- SwiftTutorials/CIC_2013-08-09/cloud/service/cleancloud	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/service/cleancloud	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,10 @@
+#! /bin/bash
+if [ -d service ]; then
+  ( cd service
+    rm -rf cf sites.xml hosts.txt logs *.log
+else
+  echo ERROR: no service directory
+fi
Property changes on: SwiftTutorials/CIC_2013-08-09/cloud/service/cleancloud
Copied: SwiftTutorials/CIC_2013-08-09/cloud/service/coaster-service.conf (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/coaster-service.conf)
--- SwiftTutorials/CIC_2013-08-09/cloud/service/coaster-service.conf	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/service/coaster-service.conf	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,48 @@
+#Location of SWIFT. If empty, PATH is referenced
+ export SWIFT=
+ # Where to place/launch worker.pl on the remote machine for sites.xml
+ export WORKER_LOCATION=/root
+ # How to launch workers: local, ssh, or cobalt
+ export WORKER_MODE=ssh
+ # Worker logging setting passed to worker.pl for sites.xml
+ # export WORKER_LOGGING_LEVEL=DEBUG
+ export WORKER_LOGGING_LEVEL=INFO
+ export SSH_TUNNELING=yes
+ # User name to use for all systems
+ export WORKER_USERNAME=root
+ # Worker host names for ssh
+# export WORKER_HOSTS="crush thwomp stomp crank grind churn trounce thrash vanquish"
+#export WORKER_HOSTS="ip-10-36-196-96.eu-west-1.compute.internal ip-10-36-195-69.eu-west-1.compute.internal"
+ # Directory to keep log files, relative to working directory when launching start-coaster-service
+ export LOG_DIR=logs
+ export WORKER_LOG_DIR=/root
+ # Manually define ports. If not specified, ports will be automatically generated
+ #export LOCAL_PORT=50100
+ #export SERVICE_PORT=50200
+ # Set shared filesystem to no since work will be done in local /sandbox directory
+ export SHARED_FILESYSTEM=no
+ # start-coaster-service tries to automatically detect IP address.
+ # Specify here if auto detection is not working correctly
+ export IPADDR=
+ # Below are various settings to give information about how to create sites.xml
+ export WORK=/tmp
+ export JOBS_PER_NODE=8
+ export JOBSPERNODE=8
+ export JOBTHROTTLE=$( echo "scale=5; ($JOBS_PER_NODE * $( echo $WORKER_HOSTS | wc -w ))/100"|bc )
+ # Swift applications
+ # no app cat=/bin/cat
+ # no app bash=/bin/bash
+ #app echo=/bin/echo
Copied: SwiftTutorials/CIC_2013-08-09/cloud/service/hosts.txt (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/hosts.txt)
--- SwiftTutorials/CIC_2013-08-09/cloud/service/hosts.txt	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/service/hosts.txt	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,3 @@
+54.212.81.224
+54.244.171.51
+54.212.37.161
Copied: SwiftTutorials/CIC_2013-08-09/cloud/service/pool.txt (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/pool.txt)
--- SwiftTutorials/CIC_2013-08-09/cloud/service/pool.txt	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/service/pool.txt	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,3 @@
+54.212.81.224
+54.244.171.51
+54.212.37.161
Copied: SwiftTutorials/CIC_2013-08-09/cloud/service/startcloud (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/startcloud)
--- SwiftTutorials/CIC_2013-08-09/cloud/service/startcloud	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/service/startcloud	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,78 @@
+#!/bin/bash
+echo 0: $0
+echo BASH_SOURCE: ${BASH_SOURCE[0]}
+if [ ${BASH_VERSINFO[0]} -gt 2 -a "${BASH_SOURCE[0]}" = "${0}" ] ; then
+  echo ERROR_1: script ${BASH_SOURCE[0]} must be executed as: source service/startcloud
+  exit 1
+fi
+if [ ${BASH_VERSINFO[0]} -gt 2 -a "${BASH_SOURCE[0]}" != service/startcloud ] ; then
+  echo ERROR_2: script ${BASH_SOURCE[0]} must be executed as: source service/startcloud
+  return 1
+fi
+addlocalpool()
+cat <<END
+  <pool handle="localhost">
+    <execution provider="coaster" jobmanager="local:local" url="http://localhost"/>
+    <profile key="jobThrottle" namespace="karajan">.23</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <workdirectory>$PWD/swiftwork</workdirectory>
+  </pool>
+END
+echo -e "\nSetting up Swift cloud service in $PWD/service\n"
+( cd service
+# pick 3 random hosts from pool # FIXME: disabled for now because sort -R is not univerally available
+# sort -R pool.txt |head -n 3 > hosts.txt
+# FIXME: Get the hosts from a dynamic file for each tutorial
+head -n 3 pool.txt > hosts.txt
+echo "Enabling cloud host access in $HOME/.ssh/config"
+touch ~/.ssh/config
+chmod 600 ~/.ssh/config
+while read line
+do
+  if grep -q $line ~/.ssh/config; then :
+  else
+    echo -ne "Host $line\n  IdentityFile ~/.ssh/tutorial.pem\n  User root\n" >> ~/.ssh/config
+  fi
+done < hosts.txt
+if grep -q StrictHostKeyChecking ~/.ssh/config; then :
+else
+   echo -ne "\nHost * \n  StrictHostKeyChecking=no\n" >> ~/.ssh/config
+fi
+export WORKER_HOSTS=`cat hosts.txt`
+chmod 0600 ~/.ssh/tutorial.pem
+echo "Starting ssh-agent"
+eval $(ssh-agent)
+ssh-add ~/.ssh/tutorial.pem
+echo "Starting Swift coaster service"
+start-coaster-service
+mv sites.xml _temp.xml
+grep -v config _temp.xml | (
+  echo "<config>"
+  cat
+  addlocalpool
+  echo "</config>"
+) >sites.xml
+rm _temp.xml
+mv sites.xml ..
+echo "Swift cloud setup complete"
+# rm -rf hi.* hi-*
+) # Leave user in original directory
Copied: SwiftTutorials/CIC_2013-08-09/cloud/service/stopcloud (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/stopcloud)
--- SwiftTutorials/CIC_2013-08-09/cloud/service/stopcloud	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/service/stopcloud	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,8 @@
+#!/bin/bash
+echo "stopping coaster service"
+stop-coaster-service
+echo "Killing ssh-agent"
+killall -u $USER ssh-agent ssh
Copied: SwiftTutorials/CIC_2013-08-09/cloud/service/tutorial.pem (from rev 6868, SwiftTutorials/CIC_2013-08-09/cloud/tutorial.pem)
--- SwiftTutorials/CIC_2013-08-09/cloud/service/tutorial.pem	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/cloud/service/tutorial.pem	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,23 @@
+-----BEGIN RSA PRIVATE KEY-----
+MIIEpAIBAAKCAQEAvPJTneRDhB5wlRsWEr2l6LoFi/PulPm0J0A1Vi2skzWYC9J6I4Ftb2YbSbtp
+3d+BJUSK3wyJqfYgY/ynC4vtbdG4HU7/Fr6R2BBKtfiiVHET1K3OTCp3JzFVqQoJoSYkrkgW7XE9
+9GF7hvpza8JVvV9JPwxOcuhDAVHQFkoIRAq1TK9VaRulZFJapubWnEHM2UoUrmBS10IZmUwGHqR5
+I6soUyBqapAYoQmL5fzqT+dhsnu7rXrUmF37Va5kX309N4Dp0D4/WJY7FeF9Q9to2i+G7HPA+gEY
+/ptYxlTk89l5MBIY1czZvz7Fso5NHCEMW1468mD/NtJIWBDS8x1yHQIDAQABAoIBAHY2ur//b4p6
+rP9s+etxwhqQQCYm0O9eJyujjXtEikNz9ZP39LjAImLfJFWGLx9E1f0mHCifJIY02mEUUsLzofHi
+k2mq4ggt5PukfcnKLG3ebYTT1U1sCC56PFjNUecEAVEVA1s9TYDXeLyjd5FE/fXEZwROQ8q6rClo
+MWOwn+lJII9La8lLFIBxXNQbyt2nwO26iSzw51wBYsWDglV/T6qnB9JOcQ+uyn8/e4kQYuD52iV3
+Vx3QN+F+YPC7ebYOS8kVR/bFo+JDggNU4jZ+Zk31Sbepfb7p7IdYTjtrlQAd48tIxdvKFpFqy0mC
+GDmkVKBAXSc7DNqy3osvq1DdtbUCgYEA+IwsADb2iY6QPt7KNl0edJRSjDmeR8wSV7QIJYm0mxTB
+tVUZn+cpdeDsK5RkJYzDNKy3gjXhsp3B9Ogsu1aO2KVuv2ffk4wUF6nFLASQifMebUvMtqZM3g3N
+/yhMh7jGqfEu3tCmRSztCm0K3AodTtxacyRZKlKM4iAe0tbIO9cCgYEAwpypzFQvX83a2X+SU9rz
+rb7S10U2sZz3YwCHTRr2BCS8EaFA5xuEZBDmGR8OegUMfmQweD57JboQKB95KpuojGUpVBt6XoFv
+SaVLg7Ehskp71XZAgG6D9AHV1mm7hGkGoqj9zdlScc+nEZw57UEPzp/hXTTtc9hapOvOH1l7IysC
+gYB7CRh2+r5MFdB97td21d3Po+TBGXyq2fByjeJCgspuwnWph/jpWQsDGVaPtCNnGyk+mAk3YejZ
+/JIY5B3QluabhDkwcwEQDxWbKSU7xv6t6zWysQUjnWsLuRWyK4bG4McnNQcYsXy9XaHxuUzY5ADi
+Gt6DhQjGlJq9DV10zXHNfQKBgQCsVbUbZxVInm+FmS3IKiUNn+TvkrAbWqfLuOUXx59CDhGo/wYN
+YdW8Eybf6huUvDHTHv+5C4Nb5kd2cGCI9aytHswZWffkBnS5X7HeXZY8Xy8H2Z7G3JbnFlT5eUn/
+uE2S71lJ13/lnwAQXSsCyVGpJPWZ50u7AUVLtDEkm8WqXwKBgQDh0X21ufkWeparJ4GxWjodxnYK
+i1mtzghE3FjhcrrKBKJ3Sm5ZUYPVbOe97071zB+u2S0a83/tHP9Sr5KuS1sHiN++IB2FVo7UMBMC
+1Ktg+yK9MoERr1xzNrqeR59U5uvRBypd8MSzxuk4LjePYFYeyFaz8GOusCw/ZPU4R83zWA==
+-----END RSA PRIVATE KEY-----
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/simulate.sh
--- SwiftTutorials/CIC_2013-08-09/cloud/simulate.sh	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/simulate.sh	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,23 +0,0 @@
-#! /bin/bash
-runtime=${1:-0}
-range=${2:-100}
-scale=${4:-1}
-n=${5:-1}
-  offset=0
-else
-fi
-sleep $runtime
-  echo $(( ($RANDOM%range)*scale+offset))
-done
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/sitecount.sh
--- SwiftTutorials/CIC_2013-08-09/cloud/sitecount.sh	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/sitecount.sh	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1 +0,0 @@
-grep "submitting" cps*.log | awk '{print $5}' | sed -e 's/:.*//' | sort | uniq -c
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/sites.xml
--- SwiftTutorials/CIC_2013-08-09/cloud/sites.xml	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/sites.xml	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,19 +0,0 @@
-<config>
-  <pool handle="persistent-coasters">
-    <execution provider="coaster-persistent"
-               url="http://localhost:55592"
-               jobmanager="local:local"/>
-    <profile namespace="globus" key="workerManager">passive</profile>
-    <profile namespace="globus" key="jobsPerNode">8</profile>
-    <profile key="jobThrottle" namespace="karajan">.23999</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-    <filesystem provider="local" url="none" />
-    <workdirectory>/tmp/ketan</workdirectory>
-  </pool>
-  <pool handle="localhost">
-    <execution provider="coaster" jobmanager="local:local" url="http://localhost"/>
-    <profile key="jobThrottle" namespace="karajan">.23</profile>
-    <workdirectory>/home/wilde/swift/demo/CIC.2013.0815/svn/cloud/swiftwork</workdirectory>
-  </pool>
-</config>
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/startcloud
--- SwiftTutorials/CIC_2013-08-09/cloud/startcloud	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/startcloud	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,67 +0,0 @@
-#!/bin/bash
-if [ ${BASH_VERSINFO[0]} -gt 2 -a "${BASH_SOURCE[0]}" = "${0}" ] ; then
-  echo ERROR: script ${BASH_SOURCE[0]} must be executed as: source ${BASH_SOURCE[0]}
-  exit 1
-fi
-addlocalpool()
-cat <<END
-    <workdirectory>$PWD/swiftwork</workdirectory>
-  </pool>
-END
-echo -e "\nSwift cloud setup\n"
-#pick 3 random hosts from pool
-# sort -R pool.txt |head -n 3 > hosts.txt
-head -n 3 pool.txt > hosts.txt # FIXME: disabled for now because sort -R is not univerally available
-echo "Enabling cloud host access in $HOME/.ssh/config"
-touch ~/.ssh/config
-chmod 600 ~/.ssh/config
-while read line
-do
-  count=$(grep $line ~/.ssh/config | wc -l)
-  if [ $count -eq 0 ]
-  then
-	echo -ne "Host $line \n IdentityFile ~/.ssh/tutorial.pem \n User root \n" >> ~/.ssh/config
-  fi
-done < hosts.txt
-count=$(grep StrictHostKeyChecking ~/.ssh/config | wc -l)
-if [ $count -eq 0 ]
-then
-   echo -ne "\n Host * \n StrictHostKeyChecking=no \n" >> ~/.ssh/config
-fi
-export WORKER_HOSTS=`cat hosts.txt`
-chmod 0600 ~/.ssh/tutorial.pem
-echo "Starting ssh-agent"
-eval $(ssh-agent)
-ssh-add ~/.ssh/tutorial.pem
-echo "Starting Swift coaster service"
-start-coaster-service
-mv sites.xml cloud.xml
-grep -v config cloud.xml | (
-  echo "<config>"
-  cat
-  addlocalpool
-  echo "</config>"
-) >sites.xml
-echo "Swift cloud setup complete"
-rm -rf hi.* hi-*
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/stats.sh
--- SwiftTutorials/CIC_2013-08-09/cloud/stats.sh	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/stats.sh	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,9 +0,0 @@
-#! /bin/sh
-awk '
-{ sum += $1}
-END { print sum/NR }
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/stopcloud
--- SwiftTutorials/CIC_2013-08-09/cloud/stopcloud	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/stopcloud	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,8 +0,0 @@
-#!/bin/bash
-echo "stopping coaster service"
-stop-coaster-service
-echo "Killing ssh-agent"
-killall -u $USER ssh-agent
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/tc.data
--- SwiftTutorials/CIC_2013-08-09/cloud/tc.data	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/tc.data	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,111 +0,0 @@
-persistent-coasters cat /bin/cat null null null
-persistent-coasters bash /bin/bash null null null
-persistent-coasters echo /bin/echo null null null
Deleted: SwiftTutorials/CIC_2013-08-09/cloud/tutorial.pem
--- SwiftTutorials/CIC_2013-08-09/cloud/tutorial.pem	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/cloud/tutorial.pem	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,23 +0,0 @@
------BEGIN RSA PRIVATE KEY-----
-MIIEpAIBAAKCAQEAvPJTneRDhB5wlRsWEr2l6LoFi/PulPm0J0A1Vi2skzWYC9J6I4Ftb2YbSbtp
-3d+BJUSK3wyJqfYgY/ynC4vtbdG4HU7/Fr6R2BBKtfiiVHET1K3OTCp3JzFVqQoJoSYkrkgW7XE9
-9GF7hvpza8JVvV9JPwxOcuhDAVHQFkoIRAq1TK9VaRulZFJapubWnEHM2UoUrmBS10IZmUwGHqR5
-I6soUyBqapAYoQmL5fzqT+dhsnu7rXrUmF37Va5kX309N4Dp0D4/WJY7FeF9Q9to2i+G7HPA+gEY
-/ptYxlTk89l5MBIY1czZvz7Fso5NHCEMW1468mD/NtJIWBDS8x1yHQIDAQABAoIBAHY2ur//b4p6
-rP9s+etxwhqQQCYm0O9eJyujjXtEikNz9ZP39LjAImLfJFWGLx9E1f0mHCifJIY02mEUUsLzofHi
-k2mq4ggt5PukfcnKLG3ebYTT1U1sCC56PFjNUecEAVEVA1s9TYDXeLyjd5FE/fXEZwROQ8q6rClo
-MWOwn+lJII9La8lLFIBxXNQbyt2nwO26iSzw51wBYsWDglV/T6qnB9JOcQ+uyn8/e4kQYuD52iV3
-Vx3QN+F+YPC7ebYOS8kVR/bFo+JDggNU4jZ+Zk31Sbepfb7p7IdYTjtrlQAd48tIxdvKFpFqy0mC
-GDmkVKBAXSc7DNqy3osvq1DdtbUCgYEA+IwsADb2iY6QPt7KNl0edJRSjDmeR8wSV7QIJYm0mxTB
-tVUZn+cpdeDsK5RkJYzDNKy3gjXhsp3B9Ogsu1aO2KVuv2ffk4wUF6nFLASQifMebUvMtqZM3g3N
-/yhMh7jGqfEu3tCmRSztCm0K3AodTtxacyRZKlKM4iAe0tbIO9cCgYEAwpypzFQvX83a2X+SU9rz
-rb7S10U2sZz3YwCHTRr2BCS8EaFA5xuEZBDmGR8OegUMfmQweD57JboQKB95KpuojGUpVBt6XoFv
-SaVLg7Ehskp71XZAgG6D9AHV1mm7hGkGoqj9zdlScc+nEZw57UEPzp/hXTTtc9hapOvOH1l7IysC
-gYB7CRh2+r5MFdB97td21d3Po+TBGXyq2fByjeJCgspuwnWph/jpWQsDGVaPtCNnGyk+mAk3YejZ
-/JIY5B3QluabhDkwcwEQDxWbKSU7xv6t6zWysQUjnWsLuRWyK4bG4McnNQcYsXy9XaHxuUzY5ADi
-Gt6DhQjGlJq9DV10zXHNfQKBgQCsVbUbZxVInm+FmS3IKiUNn+TvkrAbWqfLuOUXx59CDhGo/wYN
-YdW8Eybf6huUvDHTHv+5C4Nb5kd2cGCI9aytHswZWffkBnS5X7HeXZY8Xy8H2Z7G3JbnFlT5eUn/
-uE2S71lJ13/lnwAQXSsCyVGpJPWZ50u7AUVLtDEkm8WqXwKBgQDh0X21ufkWeparJ4GxWjodxnYK
-i1mtzghE3FjhcrrKBKJ3Sm5ZUYPVbOe97071zB+u2S0a83/tHP9Sr5KuS1sHiN++IB2FVo7UMBMC
-1Ktg+yK9MoERr1xzNrqeR59U5uvRBypd8MSzxuk4LjePYFYeyFaz8GOusCw/ZPU4R83zWA==
------END RSA PRIVATE KEY-----
Modified: SwiftTutorials/CIC_2013-08-09/doc/README
--- SwiftTutorials/CIC_2013-08-09/doc/README	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/doc/README	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,6 +1,35 @@
-Swift CIC Tutorial - 2013.0815
+Swift CIC Tutorial - 2013.0827
+Outline
+Introductory exercises
+p1 - Run an application under Swift
+p2 - Mapping (naming) output files
+p3 - Parallel loops with foreach
+p4 - Mapping arrays to files
+p5 - merging/reducing the results of a parallel foreach loop
+p6 - Sending arguments to applications
+p7 - Running on the remote site nodes
+p8 - Running the stats summary step on the remote site
+p9 - A more complex workflow pattern: multiple parallel pipelines
 Workflow tutorial setup
Modified: SwiftTutorials/CIC_2013-08-09/doc/TODO
--- SwiftTutorials/CIC_2013-08-09/doc/TODO	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/doc/TODO	2013-08-21 20:44:20 UTC (rev 6922)
@@ -10,8 +10,51 @@
 Show variety of UC3 activity and what ran where
+get hostname and app_resources into provider staging (hostname into all _swiftwrap)
+Show gridftp and go connect to process the modis dataset
+Show SwiftR for R users, SwiftPy for Enthought PY?
+fetching apps vs sending apps vs parrot/cvmfs/oasis etc ????
+Demo script-aps, bin apps, building apps, caching apps. etc.
+Do a Swift BLAST workflow  -- with viz !!!  (spice it up with help from Dina)
+OSG page from Mats: "Is your job HTC-ready"
+Use new Trunk config in tutorial?
+Add viz and status display; add node probing to tutorial.
+Debug failure with pinfiles
+What "exercises to suggest?"
+- run stats app locally
+- installed vs transferred apps
+- transferred programs vs transferred scripts
+Y-style dag: 2 sims and average
+Show how to find temp files at runtime...
+Show how to find hung processes at runtime...  (or get other trace data...)
+make your owb versions of the programs; verify that you can substitute them
+Add a layer to isolate shell version v installed version
+Show how to handle a paramfile
+Test if OSGCOnnect works and account string (PorjectName) works OK for both!
 ISSUES
 error in pin files? debug and turn back on
Modified: SwiftTutorials/CIC_2013-08-09/part06/sites.xml
--- SwiftTutorials/CIC_2013-08-09/part06/sites.xml	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/part06/sites.xml	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,7 +1,7 @@
 <config>
       <execution provider="coaster" jobmanager="local:local"/>
-      <profile namespace="karajan" key="jobThrottle">0.03</profile>
+      <profile namespace="karajan" key="jobThrottle">0.20</profile>
       <filesystem provider="local"/>
       <workdirectory>{env.HOME}/work</workdirectory>
Deleted: SwiftTutorials/CIC_2013-08-09/part08/p8.swift
--- SwiftTutorials/CIC_2013-08-09/part08/p8.swift	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/part08/p8.swift	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,41 +0,0 @@
-type file;
-# Applications to be called by this script
-file simulation_prog <"app/simulate.sh">;
-file analysis_prog   <"app/stats.sh">;
-# app() functions for application programs to be called:
-app (file out) simulation (file prog, int timesteps, int sim_range, file bias_file, int scale, int sim_count)
-  sh @filename(prog) timesteps sim_range @filename(bias_file) scale sim_count stdout=@filename(out);
-app (file out) analyze (file prog, file s[])
-  sh @filename(prog) @filenames(s) stdout=@filename(out);
-# Command line params to this script:
-int  nsim  = @toInt(@arg("nsim",  "10"));  # number of simulation programs to run
-int  steps = @toInt(@arg("steps", "1"));   # number of "steps" each simulation (==seconds of runtime)
-int  range = @toInt(@arg("range", "100")); # range of the generated random numbers
-int  count = @toInt(@arg("count", "10"));  # number of random numbers generated per simulation
-# Main script and data
-tracef("\n*** Script parameters: nsim=%i steps=%i range=%i count=%i\n\n", nsim, steps, range, count);
-file sims[];                               # Array of files to hold each simulation output
-file bias<"bias.dat">;                     # Input data file to "bias" the numbers:
-                                           # 1 line: scale offset ( N = n*scale + offset)
-foreach i in [0:nsim-1] {
-  file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
-  simout = simulation(simulation_prog, steps, range, bias, 100000, count);
-  sims[i] = simout;
-file stats<"output/stats.out">;         # Final output file: average of all "simulations"
-stats = analyze(analysis_prog,sims);
Added: SwiftTutorials/CIC_2013-08-09/part08/rensemble.swift
--- SwiftTutorials/CIC_2013-08-09/part08/rensemble.swift	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/part08/rensemble.swift	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1 @@
+link ../scripts/rensemble.swift
Property changes on: SwiftTutorials/CIC_2013-08-09/part08/rensemble.swift
Added: svn:special
Modified: SwiftTutorials/CIC_2013-08-09/part08/sites.xml
--- SwiftTutorials/CIC_2013-08-09/part08/sites.xml	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/part08/sites.xml	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,20 +1,28 @@
 <config>
   <pool handle="uc3">
     <execution provider="coaster" jobmanager="local:condor"/>
-    <profile namespace="karajan" key="jobThrottle">2.00</profile>
+    <profile namespace="karajan" key="jobThrottle">5.00</profile>
     <profile namespace="globus"  key="jobsPerNode">1</profile>
-    <profile namespace="globus"  key="maxtime">300</profile>
+    <profile namespace="globus"  key="maxtime">3600</profile>
     <profile namespace="globus"  key="maxWalltime">00:01:00</profile>
-    <profile namespace="globus"  key="highOverAllocation">100</profile>
-    <profile namespace="globus"  key="lowOverAllocation">100</profile>
-    <profile namespace="globus"  key="slots">20</profile>
+    <profile namespace="globus"  key="highOverAllocation">10000</profile>
+    <profile namespace="globus"  key="lowOverAllocation">10000</profile>
+    <profile namespace="globus"  key="internalHostname">128.135.158.243</profile>
+    <profile namespace="globus"  key="slots">1</profile>
     <profile namespace="globus"  key="maxNodes">1</profile>
     <profile namespace="globus"  key="nodeGranularity">1</profile>
+    <!-- For UC3: -->
     <profile namespace="globus"  key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
+    <!-- For OSGConnect -->
+    <!-- <profile namespace="globus"  key="condor.+ProjectName">"swift"</profile> -->
     <profile namespace="globus"  key="jobType">nonshared</profile>
-    <!-- UC3  --> <profile namespace="globus" key="condor.Requirements">regexp("uc3-c*", Machine)</profile>
+    <!-- UC3  --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("uc3-c*", Machine)</profile> -->
+    <!-- UCIT --> <profile namespace="globus" key="condor.Requirements">regexp("appcloud[0-1][0-9].*", Machine)</profile>
+    <!-- MWUC --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("uct2-c*", Machine)</profile> -->
+    <!-- MWIU --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("iut2-c*", Machine)</profile> -->
+    <!-- MWUI --> <!-- <profile namespace="globus" key="condor.Requirements">regexp("taub*", Machine)</profile> -->
     <!-- MWT2 --> <!-- <profile namespace="globus" key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile> -->
     <!-- OSG  --> <!-- <profile namespace="globus" key="condor.Requirements">isUndefined(GLIDECLIENT_Name) == FALSE</profile> -->
     <!-- MULT --> <!-- <profile namespace="globus" key="condor.Requirements">UidDomain == "osg-gk.mwt2.org" && (regexp("iut2-c*", Machine) || regexp("uct2-c*", Machine)) </profile> -->
@@ -23,3 +31,15 @@
   </pool>
 </config>
+MWT2 @UC Requirements = regexp("uct2-c*", Machine)
+MWT2 @IU Requirements = regexp("iut2-c*", Machine)
+MWT2 @UIUC Requirements = regexp("taub*", Machine)
+UC ATLAS Tier 3	Requirements = regexp("uct3*", Machine)
+ITS Virtualization Lab Requirements = regexp("appcloud[0-1][0-9].*", Machine)
+Open Science Grid
+Requirements = isUndefined(GLIDECLIENT_Name) == FALSE
Copied: SwiftTutorials/CIC_2013-08-09/scripts/rensemble.swift (from rev 6872, SwiftTutorials/CIC_2013-08-09/part08/p8.swift)
--- SwiftTutorials/CIC_2013-08-09/scripts/rensemble.swift	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/scripts/rensemble.swift	2013-08-21 20:44:20 UTC (rev 6922)
@@ -0,0 +1,42 @@
+type file;
+# Applications to be called by this script
+file simulation_prog <"app/simulate.sh">;
+file analysis_prog   <"app/stats.sh">;
+# app() functions for application programs to be called:
+app (file out, file err) simulation (file prog, int timesteps, int sim_range, file bias_file, int scale, int sim_count)
+  sh @filename(prog) timesteps sim_range @filename(bias_file) scale sim_count stdout=@filename(out) stderr=@filename(err);
+app (file out) analyze (file prog, file s[])
+  sh @filename(prog) @filenames(s) stdout=@filename(out);
+int  steps = @toInt(@arg("steps", "1"));   # number of "steps" each simulation (==seconds of runtime)
+tracef("\n*** Script parameters: nsim=%i steps=%i range=%i count=%i\n\n", nsim, steps, range, count);
+file bias<"bias.dat">;                     # Input data file to "bias" the numbers:
+                                           # 1 line: scale offset ( N = n*scale + offset)
+  file simlog <single_file_mapper; file=@strcat("output/sim_",i,".log")>;
+  (simout, simlog) = simulation(simulation_prog, steps, range, bias, 100000, count);
+  sims[i] = simout;
Modified: SwiftTutorials/CIC_2013-08-09/setup.sh
--- SwiftTutorials/CIC_2013-08-09/setup.sh	2013-08-21 20:30:28 UTC (rev 6921)
+++ SwiftTutorials/CIC_2013-08-09/setup.sh	2013-08-21 20:44:20 UTC (rev 6922)
@@ -1,3 +1,4 @@
 # ensure that this script is being sourced
@@ -2,16 +3,41 @@
+  exit 1
 fi
+# Add swift to PATH
+TUTSWIFT=/usr/local/swift/stable
+PATHSWIFT=$(which swift 2>/dev/null)
+if [ _$PATHSWIFT = _$TUTSWIFT/bin/swift ]; then
+  echo using Swift from $TUTSWIFT,already in PATH
+elif [ -x $TUTSWIFT/bin/swift ]; then
+  echo Using Swift from $TUTSWIFT, and adding to PATH
+  PATH=$TUTSWIFT/bin:$PATH
+elif [ _$PATHSWIFT != _ ]; then
+  echo Using $PATHSWIFT from PATH
+else
+  echo ERROR: $TUTSWIFT not found and no swift in PATH. Tutorial will not function.
+  return
+fi
+echo Swift version is $(swift -version)
 # Setting scripts folder to the PATH env var.
-DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
-echo Adding $DIR to PATH:
-PATH=$DIR/bin:$DIR/app:$PATH
+TUTDIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
+if [ _$(which cleanup 2>/dev/null) != _$TUTDIR/bin/cleanup ]; then
+  echo Adding $TUTDIR/bin:$TUTDIR/app: to front of PATH
+  PATH=$TUTDIR/bin:$TUTDIR/app:$PATH
+else
+  echo Assuming $TUTDIR/bin:$TUTDIR/app: is already at front of PATH
+fi
 # Setting .swift files
-if [ -e $HOME/.swift ]; then
-  savedotswift=$(mktemp -d $HOME/.swift.save.XXXX)
-  echo Saving $HOME/.swift in $savedotswift
-  mv $HOME/.swift/* $savedotswift
+if [ -e $HOME/.swift/swift.properties ]; then
+  saveprop=$(mktemp $HOME/.swift/swift.properties.XXXX)
+  echo Saving $HOME/.swift/swift.properties in $saveprop
+  mv $HOME/.swift/swift.properties $saveprop
 else
@@ -41,7 +67,6 @@
 END
 return
 # OLD, to remove:
More information about the Swift-commit
