[Swift-commit] r6912 - in trunk/tests: . multi_remote
yadunandb at ci.uchicago.edu
Wed Aug 21 12:43:53 CDT 2013
Author: yadunandb
Date: 2013-08-21 12:43:53 -0500 (Wed, 21 Aug 2013)
New Revision: 6912
Added:
trunk/tests/multi_remote/
trunk/tests/multi_remote/.log
trunk/tests/multi_remote/README
trunk/tests/multi_remote/clean.sh
trunk/tests/multi_remote/remote_driver.check.sh
trunk/tests/multi_remote/remote_driver.setup.sh
trunk/tests/multi_remote/remote_driver.source.sh
trunk/tests/multi_remote/remote_driver.swift
trunk/tests/multi_remote/remote_driver.timeout
trunk/tests/multi_remote/run.sh
trunk/tests/multi_remote/sites.template.xml
trunk/tests/multi_remote/swift.properties
trunk/tests/multi_remote/tc.template.data
trunk/tests/multi_remote/title.txt
Log:
Committing remote-cluster test engine
Added: trunk/tests/multi_remote/.log
Added: trunk/tests/multi_remote/README
--- trunk/tests/multi_remote/README (rev 0)
+++ trunk/tests/multi_remote/README 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,50 @@
+What
+This test-group multi-remote is recursive call on the test-suite from itself.
+How
+Assuming that the site of execution of the top-level run has sufficient auth
+for connecting to all remote sites, the remote-driver.swift script will connect
+with several remote sites, and initiate an instance of the test-suite at the
+remote login nodes.
+Get started
+I have made this with the assumption that swift.rcc will be the site from which
+the top-level run and hence the multi-remote.swift script will be invoked. Yet,
+it should be quite possible to run this anywhere.
+- Setup keys to have passwordless access to the following sites:
+ Beagle, UC3, MCS, Midway
+ - For connecting to MCS machines frisbee and crush directly you could add
+ the following to the .ssh/config file :
+ Host frisbee.mcs.anl.gov
+ Hostname frisbee.mcs.anl.gov
+ ProxyCommand ssh -A <USERNAME>@login.mcs.anl.gov nc %h %p 2> /dev/null
+ ForwardAgent yes
+ Host crush.mcs.anl.gov
+ Hostname crush.mcs.anl.gov
+ ForwardAgent yes
+- Get keychain on the machine for more ease of use.
+ Add following to ~/.bashrc
+ # Start keychain and point it to private key
+ /PATH/TO/KEYCHAIN /PATH/TO/PRIVATE-KEY/id_rsa
+ # Let the shell know the agent
+ # The file will be <HOSTNAME>.sh under ~/.keychain
+ source ~/.keychain/midway001-sh > /dev/null
+- Start a screen session and ensure that an agent is present which will
+ hold the auth for you.
+- Use cron / script to schedule regular runs of the tests
+ - On swift.rcc slurm-cron is supposed to work, but I haven't been
+ able to schedule on midway001 node due to an error when submitting the
+ cron.sbatch script
Added: trunk/tests/multi_remote/clean.sh
--- trunk/tests/multi_remote/clean.sh (rev 0)
+++ trunk/tests/multi_remote/clean.sh 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,7 @@
+#!/bin/bash
+rm -rf *log *d
+rm -rf *swiftx *kml
+rm -rf *~
+rm -rf driver*
+rm -rf Logs_*tar
\ No newline at end of file
Property changes on: trunk/tests/multi_remote/clean.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/multi_remote/remote_driver.check.sh
--- trunk/tests/multi_remote/remote_driver.check.sh (rev 0)
+++ trunk/tests/multi_remote/remote_driver.check.sh 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,48 @@
+#!/bin/bash
+if [ -d "swift" ]
+then
+ rm -rf swift swift.tar
+fi
+SITES_PASSED=`ls out/*out | wc -l`
+HOME=$PWD
+MAIL="$HOME/Mail.content"
+cd out;
+echo "Test-Results" > $MAIL
+echo "=====================================">> $MAIL
+echo "Test home : $PWD" >> $MAIL
+echo "Sites successful : $SITES_PASSED" >> $MAIL
+VERSION=`swift -version | cut -d " " -f -2 | sed 's/\ /-/g' | tr '[A-Z]' '[a-z]'`
+for i in `ls *tar`
+do
+ scp $i ci:~/public_html/$VERSION/
+ tar -xf $i
+ folder=`tar -tf $i | head -n 1`
+ echo "Results for site : $folder" >> $MAIL
+ grep "Tests run" $folder/run*/tests*html >> $MAIL
+ grep "Tests succeeded" $folder/run*/tests*html >> $MAIL
+ grep "Tests failed" $folder/run*/tests*html >> $MAIL
+ grep "Total Time" $folder/run*/tests*html >> $MAIL
+ echo ""
+ rm -rf $folder
+done
+cd $HOME;
+cd ..;
+RUN_DIR=$(basename $PWD);
+cd ..;
+mv $RUN_DIR "$RUN_DIR-local"
+tar -cf Local.tar "$RUN_DIR-local"
+scp Local.tar ci:~/public_html/$VERSION/
+echo "Running update and maintenance script on publish server";
+ssh ci "cd ~/public_html/$VERSION/; ./maint.sh"
+mv "$RUN_DIR-local" $RUN_DIR
+rm Local.tar
+cd $HOME;
+cat $MAIL
+mailx -s "Test results from $HOSTNAME" -r $FROM_MAIL $TO_MAIL < $MAIL
Property changes on: trunk/tests/multi_remote/remote_driver.check.sh
Added: trunk/tests/multi_remote/remote_driver.setup.sh
--- trunk/tests/multi_remote/remote_driver.setup.sh (rev 0)
+++ trunk/tests/multi_remote/remote_driver.setup.sh 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,201 @@
+#!/bin/bash
+#CLEAN_CHECKOUT="yes"
+CLEAN_CHECKOUT="no"
+#[ ! -z $COG_URL ] || COG_URL=https://cogkit.svn.sourceforge.net/svnroot/cogkit/branches/4.1.10/src/cog
+#[ ! -z $SWIFT_URL ] || SWIFT_URL=https://svn.ci.uchicago.edu/svn/vdl2/branches/release-0.94
+[ ! -z $COG_URL ] || COG_URL=https://svn.code.sf.net/p/cogkit/svn/trunk/src/cog
+[ ! -z $SWIFT_URL ] || SWIFT_URL=https://svn.ci.uchicago.edu/svn/vdl2/trunk
+[ ! -z $SWIFT_VERSION ] || SWIFT_VERSION=trunk
+[ ! -z $BEAGLE_USERNAME ] || BEAGLE_USERNAME="yadunandb"
+[ ! -z $MIDWAY_USERNAME ] || MIDWAY_USERNAME="yadunand"
+[ ! -z $UC3_USERNAME ] || UC3_USERNAME="yadunand"
+[ ! -z $MCS_USERNAME ] || MCS_USERNAME="yadunand"
+[ ! -z $PUBLISH_FOLDER ] || PUBLISH_FOLDER="\/home\/yadunandb\/public_html\/results"
+[ ! -z $SWIFT_SOURCE ] || SWIFT_SOURCE="/home/yadunand/swift"
+[ ! -z $RUN_TYPE ] || RUN_TYPE="daily"
+SITES="sites.xml"
+cp $SITES $SITES.bak
+cat $SITES | sed "s/BEAGLE_USERNAME/$BEAGLE_USERNAME/g" > tmp && mv tmp $SITES
+cat $SITES | sed "s/MIDWAY_USERNAME/$MIDWAY_USERNAME/g" > tmp && mv tmp $SITES
+cat $SITES | sed "s/UC3_USERNAME/$UC3_USERNAME/g" > tmp && mv tmp $SITES
+cat $SITES | sed "s/MCS_USERNAME/$MCS_USERNAME/g" > tmp && mv tmp $SITES
+cat $SITES | sed "s/PUBLISH_FOLDER/$PUBLISH_FOLDER/g" > tmp && mv tmp $SITES
+export GLOBUS_HOSTNAME="swift.rcc.uchicago.edu"
+BASE=$PWD
+# Make clean checkout if no swift dir is present or
+# Clean checkout requested
+[ -f "/scratch/midway/yadunand/swift.tar" ] && cp /scratch/midway/yadunand/swift.tar ./
+if [ "$REMOTE_DRIVER_FASTSETUP" == "true" ]
+then
+ echo "FASTSETUP: Skipping svn update and rebuild"
+else
+ if [ -f "swift.tar" ]
+ then
+ echo "Found swift.tar. Extracting.."
+ tar -xf swift.tar
+ fi
+ if [ "CLEAN_CHECKOUT" == "yes" ] || [ ! -d "swift" ]
+ then
+ echo "Cleaning and making fresh checkout"
+ rm -rf swift &> /dev/null
+ mkdir swift && cd swift
+ svn co $COG_URL
+ cd cog/modules
+ svn co $SWIFT_URL swift
+ cd swift
+ else
+ echo "Updating Cog sources"
+ cd swift/
+ svn up *
+ echo "Updating Swift sources"
+ cd cog/modules/swift
+ svn up *
+ fi
+ echo "$PWD : Starting compile"
+ ant redist | tee $BASE/compile.log
+ if [ "$?" != "0" ]
+ then
+ echo "Swift compile failed. Cannot proceed"
+ exit 1
+ fi
+ cd $BASE
+ if [ -d "swift" ]
+ then
+ tar -cf swift.tar.tmp ./swift && mv swift.tar.tmp swift.tar && echo "Tarred successfully"
+ else
+ echo "Could not find swift folder to tar"
+ fi;
+fi
+# Wrapper is the script that gets executed on the remote nodes
+# The outputs go to the out directory
+cat <<'EOF' > wrapper.sh
+#!/bin/bash
+SWIFT_TARBALL=$1
+LOG_TARBALL=$2
+RUN_HOME=$PWD
+echo "HOSTNAME: $HOSTNAME"
+if [ -f $SWIFT_TARBALL ]
+then
+ echo "Hey this is wrapper and the $1 exists as a file";
+ ls -lah;
+else
+ echo "Doinks! the file we need isn't here";
+ ls -lah
+ exit -1;
+fi
+BASENAME=""
+if echo $SWIFT_TARBALL | grep "\.tar$"
+then
+ tar -xf $SWIFT_TARBALL
+ BASENAME=${SWIFT_TARBALL%.tar}
+else
+ echo "BAD.. cannot decipher $SWIFT_TARBALL"
+ exit -1
+fi;
+cd $BASENAME;
+cd cog/modules/swift/
+#type ant 2>&1
+#if [ "$?" != "0" ]
+#then
+# echo "Ant not found. Cannot build. Exiting!.."
+# exit 0
+#fi
+#ant redist 2>&1 > tee $RUN_HOME/swift_build.log
+if [ ! -x "$PWD/dist/swift-svn/bin/swift" ]
+then
+ echo "No executable swift binary... Cannot proceed"
+ exit 0
+fi
+echo "Found swift executable!"
+SWIFT_PATH=$PWD/dist/swift-svn/bin
+export PATH=$SWIFT_PATH:$PATH
+T=`which swift`
+if [ "$T" == "$SWIFT_PATH/swift" ]
+then
+ swift -version
+else
+ echo "Swift not being pulled from SWIFT_PATH"
+fi;
+cd tests/
+EOF
+if [ "$RUN_TYPE" == "daily" ]; then
+cat <<'EOF' >> wrapper.sh
+#./suite.sh -l 1 -t $PWD/groups/group-functions.sh 2>&1 | tee $RUN_HOME/TEST.log
+#./suite.sh -l 1 -t $PWD/groups/group-remote-site.sh 2>&1 | tee $RUN_HOME/TEST.log
+./suite.sh -l 1 -t $PWD/groups/group-all-local.sh 2>&1 | tee $RUN_HOME/TEST.log
+EOF
+elif [ "$RUN_TYPE" == "weekly" ]; then
+EOF
+elif [ "$RUN_TYPE" == "manual" ]; then
+EOF
+elif [ "$RUN_TYPE" == "test" ]; then
+./suite.sh -l 1 -t $PWD/groups/group-functions.sh 2>&1 | tee $RUN_HOME/TEST.log
+EOF
+fi
+cd $RUN_HOME
+echo "Current dir : $PWD"
+rm -rf $BASENAME/cog
+RUNDIR=`ls $BASENAME | grep run`
+cp *log $BASENAME/$RUNDIR/
+mv $BASENAME/$RUNDIR "$RUNDIR-$HOSTNAME"
+tar -cvf $LOG_TARBALL "$RUNDIR-$HOSTNAME" &> /dev/null
+rm -rf $BASENAME* "$RUNDIR-$HOSTNAME" &> /dev/null
+echo "Folder cleaned"
+PID=$$
+CPIDS=$(pgrep -P $PID); (sleep 20 && kill -KILL $CPIDS &); kill -TERM $CPIDS;
+exit 0
+EOF
+cat<<'EOF' > publish.sh
+#!/bin/bash
+echo "Hostname : $HOSTNAME"
+echo "PWD : $PWD"
+ls
+EOF
+echo "$0 : Completed"
+exit 0
Property changes on: trunk/tests/multi_remote/remote_driver.setup.sh
Added: trunk/tests/multi_remote/remote_driver.source.sh
--- trunk/tests/multi_remote/remote_driver.source.sh (rev 0)
+++ trunk/tests/multi_remote/remote_driver.source.sh 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,6 @@
+#!/bin/bash
+if [ "$HOSTNAME" == "midway001" ]
+then
+ export GLOBUS_HOSTNAME=swift.rcc.uchicago.edu
+ export GLOBUS_TCP_PORT_RANGE=50000,51000
+fi;
Property changes on: trunk/tests/multi_remote/remote_driver.source.sh
Added: trunk/tests/multi_remote/remote_driver.swift
--- trunk/tests/multi_remote/remote_driver.swift (rev 0)
+++ trunk/tests/multi_remote/remote_driver.swift 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,71 @@
+type file;
+type script;
+file swift_package <"swift.tar">;
+script wrapper <"wrapper.sh">;
+script publish <"publish.sh">;
+file out[] <simple_mapper;prefix="out/driver", suffix=".out">;
+file err[] <simple_mapper;prefix="out/driver", suffix=".err">;
+file log[] <simple_mapper;prefix="out/Logs_", suffix=".tar">;
+string sites[] = ["uc3", "beagle", "midway", "crush", "frisbee"];
+app (file out, file err, file log) remote_uc3 (script run, file tar)
+ uc3 @run @filename(tar) @log stdout=@filename(out) stderr=@filename(err);
+app (file out, file err, file log) remote_beagle (script run, file tar)
+ bgl @run @filename(tar) @log stdout=@filename(out) stderr=@filename(err);
+app (file out, file err, file log) remote_midway (script run, file tar)
+ mid @run @filename(tar) @log stdout=@filename(out) stderr=@filename(err);
+app (file out, file err, file log) remote_mcs (script run, file tar)
+ mcs @run @filename(tar) @log stdout=@filename(out) stderr=@filename(err);
+app (file out, file err, file log) remote_frisbee (script run, file tar)
+ fsb @run @filename(tar) @log stdout=@filename(out) stderr=@filename(err);
+app (file out, file err) publish_results (script publish, file tar, file out, file err)
+ pub @publish stdout=@out stderr=@err;
+tracef("Filename of the wraper : %s \n", @filename(wrapper));
+tracef("Filename of the package : %s \n", @filename(swift_package));
+foreach site, i in sites {
+ //tracef("Site : %s \n", site);
+ switch(i)
+ case 0:
+ tracef("Calling uc3\n");
+ //(out[i], err[i], log[i]) = remote_uc3 (wrapper, swift_package);
+ case 1:
+ tracef("Calling beagle \n");
+ //(out[i], err[i], log[i]) = remote_beagle (wrapper, swift_package);
+ case 2:
+ tracef("Calling Midway\n");
+ //(out[i], err[i], log[i]) = remote_midway (wrapper, swift_package);
+ case 3:
+ tracef("Crush on MCS\n");
+ (out[i], err[i], log[i]) = remote_crush(wrapper, swift_package);
+ case 4:
+ tracef("Skipping Frisbee on MCS (Will fail due to BUG:1030)\n");
+ //(out[i], err[i], log[i]) = remote_frisbee(wrapper, swift_package);
+ default:
+ tracef("Fail: Unknown site %s : %i \n", site, i);
Added: trunk/tests/multi_remote/remote_driver.timeout
--- trunk/tests/multi_remote/remote_driver.timeout (rev 0)
+++ trunk/tests/multi_remote/remote_driver.timeout 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1 @@
+3600
Added: trunk/tests/multi_remote/run.sh
--- trunk/tests/multi_remote/run.sh (rev 0)
+++ trunk/tests/multi_remote/run.sh 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,16 @@
+#!/bin/bash
+# Start keychain and point it to private key
+/home/yadunand/bin/keychain ~/.ssh/id_rsa
+# Let the shell know the agent
+source ~/.keychain/midway001-sh > /dev/null
+./remote_driver.setup.sh
+echo "Running remote_driver2.swift"
+#swift -tc.file tc.data.2 -config cf -sites.file multiple.xml.bak remote_driver2.swift
+#swift -tc.file tc.data.2 -config cf -sites.file multiple.xml remote_driver2.swift
+swift -tc.file tc.data -config cf -sites.file $SITES remote_driver.swift | tee root_level.LOG
+rm $SITES
Property changes on: trunk/tests/multi_remote/run.sh
Added: trunk/tests/multi_remote/sites.template.xml
--- trunk/tests/multi_remote/sites.template.xml (rev 0)
+++ trunk/tests/multi_remote/sites.template.xml 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,112 @@
+<config>
+ <pool handle="local">
+ <execution provider="coaster" jobmanager="local:local"/>
+ <profile namespace="globus" key="jobsPerNode">4</profile>
+ <profile namespace="globus" key="maxWalltime">00:15:00</profile>
+ <profile namespace="globus" key="highOverAllocation">100</profile>
+ <profile namespace="globus" key="lowOverAllocation">100</profile>
+ <profile namespace="globus" key="slots">1</profile>
+ <profile namespace="globus" key="maxNodes">1</profile>
+ <profile namespace="globus" key="nodeGranularity">1</profile>
+ <profile namespace="karajan" key="jobThrottle">0.03</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <filesystem provider="local"/>
+ <workdirectory>.</workdirectory>
+ </pool>
+ <pool handle="ci">
+ <execution provider="coaster" jobmanager="ssh-cl:local" url="login.ci.uchicago.edu"/>
+ <profile namespace="globus" key="jobsPerNode">24</profile>
+ <profile namespace="globus" key="maxtime">120</profile>
+ <profile namespace="globus" key="maxWalltime">00:02:00</profile>
+ <profile namespace="globus" key="slots">5</profile>
+ <profile namespace="globus" key="maxnodes">1</profile>
+ <profile namespace="karajan" key="jobThrottle">4.80</profile>
+ <workdirectory>PUBLISH_FOLDER</workdirectory>
+ </pool>
+ <pool handle="beagle">
+ <execution provider="coaster" jobmanager="ssh-cl:local" url="login4.beagle.ci.uchicago.edu"/>
+ <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24;pbs.resource_list=advres=wilde.1768</profile>
+ <profile namespace="globus" key="maxtime">36000</profile>
+ <profile namespace="globus" key="maxWalltime">01:05:00</profile>
+ <profile namespace="globus" key="userHomeOverride">/lustre/beagle/BEAGLE_USERNAME/swiftwork</profile>
+ <workdirectory>/tmp/BEAGLE_USERNAME/swiftwork</workdirectory>
+ </pool>
+ <pool handle="midway">
+ <profile namespace="globus" key="queue">sandyb</profile>
+ <profile namespace="globus" key="jobsPerNode">16</profile>
+ <profile namespace="globus" key="maxTime">36000</profile>
+ <profile namespace="globus" key="slots">4</profile>
+ <profile namespace="karajan" key="jobThrottle">.64</profile>
+ <workdirectory>/tmp/MIDWAY_USERNAME</workdirectory>
+ </pool>
+ <pool handle="uc3">
+ <execution provider="coaster" url="uc3-sub.uchicago.edu" jobmanager="ssh-cl:local"/>
+ <profile namespace="karajan" key="jobThrottle">10.00</profile>
+ <profile namespace="globus" key="jobsPerNode">1</profile>
+ <profile namespace="globus" key="slots">1000</profile>
+ <!-- <profile namespace="globus" key="condor.+AccountingGroup">"group_friends.yadunand"</profile> -->
+ <profile namespace="globus" key="jobType">nonshared</profile>
+ <workdirectory>/home/UC3_USERNAME/swiftwork</workdirectory>
+ </pool>
+ <pool handle="mcs">
+ <execution provider="coaster" jobmanager="ssh-cl:local" url="thwomp.mcs.anl.gov"/>
+ <profile namespace="globus" key="jobsPerNode">8</profile>
+ <profile namespace="karajan" key="jobThrottle">0.0799</profile>
+ <profile namespace="globus" key="userHomeOverride">/sandbox/MCS_USERNAME/</profile>
+ <workdirectory>/sandbox/MCS_USERNAME/swiftwork</workdirectory>
+ </pool>
+ <pool handle="frisbee">
+ <execution provider="coaster" jobmanager="ssh-cl:local" url="frisbee.mcs.anl.gov"/>
+ <profile namespace="globus" key="maxtime">3600</profile>
+ <profile namespace="globus" key="maxWalltime">00:05:00</profile>
+ </pool>
+</config>
Added: trunk/tests/multi_remote/swift.properties
--- trunk/tests/multi_remote/swift.properties (rev 0)
+++ trunk/tests/multi_remote/swift.properties 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,9 @@
+use.provider.staging=true
+use.wrapper.staging=false
+wrapperlog.always.transfer=true
+execution.retries=0
+lazy.errors=true
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+tcp.port.range=50000,51000
+status.mode=provider
Added: trunk/tests/multi_remote/tc.template.data
--- trunk/tests/multi_remote/tc.template.data (rev 0)
+++ trunk/tests/multi_remote/tc.template.data 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,6 @@
+beagle bgl /bin/bash null null null
+uc3 uc3 /bin/bash null null null
+midway mid /bin/bash null null null
+mcs mcs /bin/bash null null null
+local l_bash /bin/bash null null null
+ci pub /bin/bash null null null
Added: trunk/tests/multi_remote/title.txt
--- trunk/tests/multi_remote/title.txt (rev 0)
+++ trunk/tests/multi_remote/title.txt 2013-08-21 17:43:53 UTC (rev 6912)
@@ -0,0 +1,3 @@
+Recursive Test-run
+| This test will connect to several remote login nodes and
+| initiate several local, local-cluster, and remote-cluster tests
More information about the Swift-commit
