[Swift-commit] r6906 - in trunk/tests: . groups
    yadunandb at ci.uchicago.edu
    Wed Aug 21 11:17:48 CDT 2013
Author: yadunandb
Date: 2013-08-21 11:17:47 -0500 (Wed, 21 Aug 2013)
New Revision: 6906
Added:
   trunk/tests/groups/group-IO-local.sh
   trunk/tests/groups/group-daily-remote.sh
   trunk/tests/groups/group-multi-remote.sh
   trunk/tests/user_env.sh
Modified:
   trunk/tests/groups/group-stress-heavy.sh
   trunk/tests/suite.sh
Log:
Committing test-engine to trunk
* Updates to the suite.sh
* Adding new groups
* Stress tests pending update
Added: trunk/tests/groups/group-IO-local.sh
--- trunk/tests/groups/group-IO-local.sh	                        (rev 0)
+++ trunk/tests/groups/group-IO-local.sh	2013-08-21 16:17:47 UTC (rev 6906)
@@ -0,0 +1,10 @@
+# GROUPLIST definition to run all local tests
+GROUPLIST=( $TESTDIR/stress/IO/beagle \
+            $TESTDIR/stress/IO/bagOnodes \
+            $TESTDIR/stress/IO/multiple \
+            $TESTDIR/stress/IO/uc3 \
+checkvars WORK
Added: trunk/tests/groups/group-daily-remote.sh
--- trunk/tests/groups/group-daily-remote.sh	                        (rev 0)
+++ trunk/tests/groups/group-daily-remote.sh	2013-08-21 16:17:47 UTC (rev 6906)
@@ -0,0 +1,28 @@
+GROUPLIST=( # Remote sanity test-group
+            $TESTDIR/sites/remote_sanity/beagle \
+            $TESTDIR/sites/remote_sanity/mcs    \
+            $TESTDIR/sites/remote_sanity/midway \
+            $TESTDIR/sites/remote_sanity/uc3    \
+	    # Frisbee will fail due to Bug 1030
+            $TESTDIR/sites/remote_sanity/mac-frisbee  \
+            # Remote-cluster IO tests
+	    $TESTDIR/stress/IO/beagle \
+	    # Remote-cluster Apps tests - MODIS
+            $TESTDIR/stress/apps/modis_beagle  \
+            $TESTDIR/stress/apps/modis_local   \
+	    $TESTDIR/stress/apps/modis_midway  \
+	    $TESTDIR/stress/apps/modis_uc3     \
+            $TESTDIR/stress/apps/modis_multiple\
+	    # Recursive Test invocation
+    	    $TESTDIR/multi_remote	       \
+checkvars WORK
Added: trunk/tests/groups/group-multi-remote.sh
--- trunk/tests/groups/group-multi-remote.sh	                        (rev 0)
+++ trunk/tests/groups/group-multi-remote.sh	2013-08-21 16:17:47 UTC (rev 6906)
@@ -0,0 +1,9 @@
+GROUPLIST=(
+             #$TESTDIR/test_submitter \
+checkvars WORK
Modified: trunk/tests/groups/group-stress-heavy.sh
--- trunk/tests/groups/group-stress-heavy.sh	2013-08-20 22:12:32 UTC (rev 6905)
+++ trunk/tests/groups/group-stress-heavy.sh	2013-08-21 16:17:47 UTC (rev 6906)
@@ -1,7 +1,7 @@
 # GROUPLIST definition to run all local tests                            \
 GROUPLIST=(
-             $TESTDIR/stress/IO \
+#             $TESTDIR/stress/IO \
              $TESTDIR/stress/internals \
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh	2013-08-20 22:12:32 UTC (rev 6905)
+++ trunk/tests/suite.sh	2013-08-21 16:17:47 UTC (rev 6906)
@@ -18,6 +18,7 @@
   printf "\t -v         Verbose (set -x, HTML comments)    \n"
   printf "\t -l         Stress level < 1/ 2/ 3/ 4>         \n"
   printf "\t -o output  Location for cog and output        \n"
+  printf "\t -z file    Set environment for entire run     \n"
   printf "\t <GROUP>    GROUP argument                     \n"
@@ -86,6 +87,9 @@
     -l)
       STRESS=$2
       shift 2;;
+    -z)
+      ENV_FILE=$2
+      shift 2;;
     -v)
       VERBOSE=1
       shift;;
@@ -116,6 +120,13 @@
 fi
 export STRESS="S$STRESS"
+if [ -x "$ENV_FILE" ]
+then
+  source $ENV_FILE
+else
+  echo "Could not load $ENV_FILE"
+fi
 # Iterations per test (may want to run each test multiple times?)
 ITERS_LOCAL=1
@@ -534,7 +545,7 @@
   PROCESS_INTERNAL_PID=$1
   echo "process_trap: killing: $PROCESS_INTERNAL_PID"
   # ps -H
-  kill -TERM $PROCESS_INTERNAL_PID
+  kill -TERM -$PROCESS_INTERNAL_PID
 # Execute process in the background
Added: trunk/tests/user_env.sh
--- trunk/tests/user_env.sh	                        (rev 0)
+++ trunk/tests/user_env.sh	2013-08-21 16:17:47 UTC (rev 6906)
@@ -0,0 +1,21 @@
+export BEAGLE_USERNAME=""
+export MIDWAY_USERNAME=""
+export MCS_USERNAME=""
+export UC3_USERNAME=""
+export FROM_MAIL="test_engine at midway001"
+export TO_MAIL=""
+export KILL_JAVA="true" #Set to true to kill dead java processes
+# FASTSETUP skips svn updates and rebuild to speed up multi_remote.setup.sh | Can be "true" or "false"
+export REMOTE_DRIVER_FASTSETUP="false"
+#export SWIFT_TAR_FILE="path/to/source/tarball/"
+# Determines the groups of tests run on the remote nodes | and future behavior
+# RUN_TYPE can be "daily", "weekly", "manual" (manual is undefined now)
+export RUN_TYPE="daily"
+if [ "$HOSTNAME" == "midway001" ]
+then
+   export GLOBUS_HOSTNAME=swift.rcc.uchicago.edu
+   export GLOBUS_TCP_PORT_RANGE=50000,51000
+fi;
Property changes on: trunk/tests/user_env.sh
___________________________________________________________________
Added: svn:executable
More information about the Swift-commit
