[Swift-commit] r6902 - in branches/release-0.94/tests/sites: . stampede
davidk at ci.uchicago.edu
Tue Aug 20 15:31:27 CDT 2013
Author: davidk
Date: 2013-08-20 15:31:27 -0500 (Tue, 20 Aug 2013)
New Revision: 6902
Added:
branches/release-0.94/tests/sites/stampede/
branches/release-0.94/tests/sites/stampede/sanity.setup.sh
branches/release-0.94/tests/sites/stampede/sanity.source.sh
branches/release-0.94/tests/sites/stampede/sanity.swift
branches/release-0.94/tests/sites/stampede/sanity.timeout
branches/release-0.94/tests/sites/stampede/sites.template.xml
branches/release-0.94/tests/sites/stampede/swift.properties
branches/release-0.94/tests/sites/stampede/tc.template.data
branches/release-0.94/tests/sites/stampede/title.txt
Log:
Stampede site test
Added: branches/release-0.94/tests/sites/stampede/sanity.setup.sh
--- branches/release-0.94/tests/sites/stampede/sanity.setup.sh (rev 0)
+++ branches/release-0.94/tests/sites/stampede/sanity.setup.sh 2013-08-20 20:31:27 UTC (rev 6902)
@@ -0,0 +1,11 @@
+#!/bin/bash
+USERNAME=$BLUES_USERNAME
+if [[ -z $USERNAME ]]
+then
+ echo "Remote username not provided. Skipping sites configs"
+else
+ ls *xml
+ cat sites.xml | sed "s/{env.USER}/$USERNAME/" > tmp && mv tmp sites.xml
+fi
Property changes on: branches/release-0.94/tests/sites/stampede/sanity.setup.sh
___________________________________________________________________
Added: svn:executable
Added: branches/release-0.94/tests/sites/stampede/sanity.source.sh
--- branches/release-0.94/tests/sites/stampede/sanity.source.sh (rev 0)
+++ branches/release-0.94/tests/sites/stampede/sanity.source.sh 2013-08-20 20:31:27 UTC (rev 6902)
@@ -0,0 +1,6 @@
+#!/bin/bash
+if [ "$HOSTNAME" == "midway001" ]
+then
+ export GLOBUS_HOSTNAME=swift.rcc.uchicago.edu
+ export GLOBUS_TCP_PORT_RANGE=50000,51000
+fi;
Property changes on: branches/release-0.94/tests/sites/stampede/sanity.source.sh
Added: branches/release-0.94/tests/sites/stampede/sanity.swift
--- branches/release-0.94/tests/sites/stampede/sanity.swift (rev 0)
+++ branches/release-0.94/tests/sites/stampede/sanity.swift 2013-08-20 20:31:27 UTC (rev 6902)
@@ -0,0 +1,11 @@
+type file;
+app (file out, file err) remote_driver ()
+ date stdout=@filename(out) stderr=@filename(err);
+file driver_out <simple_mapper; prefix="sanity", suffix=".out">;
+file driver_err <simple_mapper; prefix="sanity", suffix=".err">;
+(driver_out, driver_err) = remote_driver();
\ No newline at end of file
Added: branches/release-0.94/tests/sites/stampede/sanity.timeout
--- branches/release-0.94/tests/sites/stampede/sanity.timeout (rev 0)
+++ branches/release-0.94/tests/sites/stampede/sanity.timeout 2013-08-20 20:31:27 UTC (rev 6902)
@@ -0,0 +1 @@
+300
Added: branches/release-0.94/tests/sites/stampede/sites.template.xml
--- branches/release-0.94/tests/sites/stampede/sites.template.xml (rev 0)
+++ branches/release-0.94/tests/sites/stampede/sites.template.xml 2013-08-20 20:31:27 UTC (rev 6902)
@@ -0,0 +1,17 @@
+<config>
+ <pool handle="stampede">
+ <execution provider="coaster" jobmanager="local:slurm"/>
+ <filesystem provider="local"/>
+ <profile namespace="globus" key="jobsPerNode">16</profile>
+ <profile namespace="globus" key="ppn">16</profile>
+ <profile namespace="globus" key="maxwalltime">00:01:00</profile>
+ <profile namespace="globus" key="queue">development</profile>
+ <profile namespace="globus" key="nodeGranularity">2</profile>
+ <profile namespace="globus" key="maxNodes">2</profile>
+ <profile namespace="globus" key="project">TG-MCA94P017</profile>
+ <profile namespace="karajan" key="jobThrottle">2</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <workdirectory>{env.SCRATCH}</workdirectory>
+ </pool>
+</config>
Added: branches/release-0.94/tests/sites/stampede/swift.properties
--- branches/release-0.94/tests/sites/stampede/swift.properties (rev 0)
+++ branches/release-0.94/tests/sites/stampede/swift.properties 2013-08-20 20:31:27 UTC (rev 6902)
@@ -0,0 +1,8 @@
+use.provider.staging=true
+use.wrapper.staging=false
+wrapperlog.always.transfer=true
+execution.retries=0
+lazy.errors=false
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+tcp.port.range=50000,51000
Added: branches/release-0.94/tests/sites/stampede/tc.template.data
--- branches/release-0.94/tests/sites/stampede/tc.template.data (rev 0)
+++ branches/release-0.94/tests/sites/stampede/tc.template.data 2013-08-20 20:31:27 UTC (rev 6902)
@@ -0,0 +1,8 @@
+local date /bin/date null null null
+beagle date /bin/date null null null
+uc3 date /bin/date null null null
+mcs date /bin/date null null null
+midway date /bin/date null null null
+blues date /bin/date null null null
+fusion date /bin/date null null null
+stampede date /bin/date null null null
Added: branches/release-0.94/tests/sites/stampede/title.txt
--- branches/release-0.94/tests/sites/stampede/title.txt (rev 0)
+++ branches/release-0.94/tests/sites/stampede/title.txt 2013-08-20 20:31:27 UTC (rev 6902)
@@ -0,0 +1 @@
+Stampede remote sanity test
More information about the Swift-commit
