[Swift-commit] cog r3763
swift at ci.uchicago.edu
Tue Aug 20 02:50:04 CDT 2013
r3763 | hategan | 2013-08-20 02:49:03 -0500 (Tue, 20 Aug 2013) | 1 line
fixed broken variable frame lookup behavior with optional arguments
Index: modules/karajan/src/org/globus/cog/karajan/workflow/nodes/functions/Variable.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/nodes/functions/Variable.java (revision 3762)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/nodes/functions/Variable.java (working copy)
@@ -13,6 +13,9 @@
import org.apache.log4j.Logger;
import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.arguments.ArgUtil;
+import org.globus.cog.karajan.arguments.VariableArguments;
+import org.globus.cog.karajan.stack.StackFrame;
import org.globus.cog.karajan.stack.VariableNotFoundException;
import org.globus.cog.karajan.stack.VariableStack;
import org.globus.cog.karajan.util.Identifier;
@@ -57,7 +60,7 @@
frame = stack.getVarFrameFromTop(name);
switch (frame) {
case VariableStack.NO_FRAME:
throw new VariableNotFoundException(name);
@@ -68,7 +71,37 @@
case VariableStack.DYNAMIC_FRAME:
return stack.getVar(name);
default:
- return stack.getFrameFromTop(frame).getVar(name);
+ StackFrame sf = stack.getFrameFromTop(frame);
+ value = sf.getVar(name);
+ * Must still check if defined since in the case of optional
+ * arguments, an initial invocation of this function may find
+ * a valid value at the relevant frame, while a subsequent
+ * invocation may not.
+ * The converse (initial invocation getting a NO_FRAME) is handled
+ * since the frame is always looked up in that case (see above if)
+ if (value == null) {
+ if (sf.isDefined(name)) {
+ return null;
+ else {
+ throw new VariableNotFoundException(name);
+ else {
+ return value;
+ * Override to allow returning java null values. Even though these are not used much,
+ * it is still possible to manipulate them using the java library.
+ protected void ret(VariableStack stack, final Object value) throws ExecutionException {
+ final VariableArguments vret = ArgUtil.getVariableReturn(stack);
+ vret.append(value);
More information about the Swift-commit
