[Swift-commit] r6891 - SwiftApps/Swift-MapRed/swift-t-simple/put-get
    wozniak at ci.uchicago.edu
    Mon Aug 19 16:42:07 CDT 2013
Author: wozniak
Date: 2013-08-19 16:42:07 -0500 (Mon, 19 Aug 2013)
New Revision: 6891
Modified:
   SwiftApps/Swift-MapRed/swift-t-simple/put-get/chirp_service.sh
   SwiftApps/Swift-MapRed/swift-t-simple/put-get/test-chirp.swift
Log:
Sketching Swift script...
Modified: SwiftApps/Swift-MapRed/swift-t-simple/put-get/chirp_service.sh
--- SwiftApps/Swift-MapRed/swift-t-simple/put-get/chirp_service.sh	2013-08-19 21:21:32 UTC (rev 6890)
+++ SwiftApps/Swift-MapRed/swift-t-simple/put-get/chirp_service.sh	2013-08-19 21:42:07 UTC (rev 6891)
@@ -1,4 +1,4 @@
-#!/bin/bash -e
+#!/bin/bash
 trap "echo SCRIPT CAUGHT TERM" TERM
@@ -7,12 +7,25 @@
 # This should have been created by setup.sh:
 DEFAULT_ACL=${HOME}/chirp-acl.txt
-[[ -f ${DEFAULT_ACL} ]]
+if [[ ! -f ${DEFAULT_ACL} ]]
+then
+  echo "could not find ${DEFAULT_ACL}"
+  exit 1
+fi
-chirp_server -p 9080 -r ${HOME}/cr_${HOST} -A ${DEFAULT_ACL} &
+CHIRP_ROOT=${HOME}/cr_${HOST}
+chirp_server -d all \
+             -p 9080 \
+             -r ${CHIRP_ROOT} \
+             -A ${DEFAULT_ACL} \
+  >& ${CHIRP_ROOT}/server.log &
 JOB=${!}
-wait
+wait || true
 kill ${JOB}
+echo SERVICE DONE
 exit 0
Modified: SwiftApps/Swift-MapRed/swift-t-simple/put-get/test-chirp.swift
--- SwiftApps/Swift-MapRed/swift-t-simple/put-get/test-chirp.swift	2013-08-19 21:21:32 UTC (rev 6890)
+++ SwiftApps/Swift-MapRed/swift-t-simple/put-get/test-chirp.swift	2013-08-19 21:42:07 UTC (rev 6891)
@@ -4,15 +4,40 @@
 import string;
 import sys;
+app (file t) list_files(string host, int port)
+  "chirp" "-a" "hostname" (sprintf("%s:%i", host, port)) "ls"
+          @stdout=t;
 main
-  string hosts_txt = argv("hosts");
+/*  string hosts_txt = argv("hosts");
+  int port = toint(argv("port"));
   string hosts[] = split(read(input(hosts_txt)), "\n");
-  foreach host in hosts
+  string filenames[][];
+  foreach host,i in hosts
     if (host != "")
       printf("host: %s", host);
+      file t = list_files(host, port);
+      string s = read(t);
+      string files[] = split(s, " ");
+      // foreach f,j in files
+      //   if (f != "")
+      //     filenames[i][j] = f;
+  sleep(2);
More information about the Swift-commit
