[Swift-commit] r6887 - SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Mon Aug 19 15:24:36 CDT 2013
Author: wozniak
Date: 2013-08-19 15:24:36 -0500 (Mon, 19 Aug 2013)
New Revision: 6887
Added:
   SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/About.txt
   SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/chirp_service.sh
   SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/test-chirp.swift
Log:
Initial tests for MCS
Added: SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/About.txt
--- SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/About.txt	                        (rev 0)
+++ SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/About.txt	2013-08-19 20:24:36 UTC (rev 6887)
@@ -0,0 +1,22 @@
+Simple test for chirp_server startup/shutdown as controlled by
+Swift/T TURBINE_WORKER_SERVICE.
+Usage on MCS compute hosts:
+Create your MPICH hosts.txt file
+Create chirp root directories for each host's chirp server in:
+~/cr_${HOST}
+Set permissive ACLs
+Set: export TURBINE_WORKER_SERVICE="chirp_service.sh"
+Run:
+stc test-chirp.swift
+turbine -l -f hosts.txt -n 4 test-chirp.tcl
+The log shows that the servers are brought up and shut down.
Added: SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/chirp_service.sh
--- SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/chirp_service.sh	                        (rev 0)
+++ SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/chirp_service.sh	2013-08-19 20:24:36 UTC (rev 6887)
@@ -0,0 +1,14 @@
+#!/bin/bash
+trap "echo SCRIPT CAUGHT TERM" TERM
+HOST=$( hostname )
+echo HOST: ${HOST}
+chirp_server -p 9080 -r ${HOME}/cr_${HOST} &
+JOB=${!}
+wait
+kill ${JOB}
+exit 0
Property changes on: SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/chirp_service.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/test-chirp.swift
--- SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/test-chirp.swift	                        (rev 0)
+++ SwiftApps/Swift-MapRed/swift-t-simple/startup-shutdown/test-chirp.swift	2013-08-19 20:24:36 UTC (rev 6887)
@@ -0,0 +1,10 @@
+import io;
+import sys;
+main
+  printf("Hello");
+  // Give the chirp server some time to start up
+  sleep(2);
