[Swift-commit] r6880 - branches/release-0.94/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Aug 19 11:13:53 CDT 2013
Author: davidk
Date: 2013-08-19 11:13:52 -0500 (Mon, 19 Aug 2013)
New Revision: 6880
Modified:
   branches/release-0.94/bin/start-coaster-service
Log:
Run tunneling commands within the same SSH command as worker.pl
Rename hi.swift to jobspernode.swift
Remove jobspernode.swift and logs after running
Create an app file for jobspernode.swift
Fix to run on mac (mktemp differences)
Bugs #1065 and #1058
Modified: branches/release-0.94/bin/start-coaster-service
--- branches/release-0.94/bin/start-coaster-service	2013-08-19 15:37:33 UTC (rev 6879)
+++ branches/release-0.94/bin/start-coaster-service	2013-08-19 16:13:52 UTC (rev 6880)
@@ -1,4 +1,4 @@
-#!/bin/bash
+#!/bin/bash
 # crash: Report a problem and exit
 crash()
@@ -90,7 +90,7 @@
       crash "SWIFTVMBOOT_DIR incorrectly defined in coaster-service.conf"
    fi
-   SEDFILE=`mktemp`
+   SEDFILE=`mktemp XXXXXX`
       echo "s at _CLUSTER-NODES_@$EC2_NODES@"
       echo "s at _INSTANCE-TYPE_@$EC2_INSTANCE_TYPE@"
@@ -218,9 +218,11 @@
    for MACHINE in $WORKER_HOSTS
    do
+      SSH_COMMAND="ssh -A "
       # Enable ssh tunneling if needed
       if [ "$SSH_TUNNELING" == "yes" ]; then
-         ssh -f -n -N $WORKER_USERNAME@$MACHINE -R $PORT:localhost:$PORT
+         SSH_COMMAND="$SSH_COMMAND -n -R $PORT:localhost:$PORT"
          echo $! >> $PID_FILE
       fi
@@ -229,14 +231,14 @@
          ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST ssh $MACHINE mkdir -p $WORKER_LOCATION > /dev/null 2>&1
          ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST "scp /tmp/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION" > /dev/null 2>&1
          echo Starting worker on $MACHINE
-         ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $WORKER_LOG_DIR" &
+         eval "$SSH_COMMAND $WORKER_USERNAME at WORKER_RELAY_HOST WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $WORKER_LOG_DIR" &
       # Connect directly
       else
          ssh $WORKER_USERNAME@$MACHINE mkdir -p $WORKER_LOCATION > /dev/null 2>&1
          scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
-         ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $WORKER_LOG_DIR" &
+         eval "$SSH_COMMAND $WORKER_USERNAME@$MACHINE WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $WORKER_LOG_DIR" &
       fi
    done
@@ -473,11 +475,11 @@
 # Create files for storing port info, if needed
 if [ -z "$LOCAL_PORT" ]; then
-   LOCAL_PORT_FILE=`mktemp`
+   LOCAL_PORT_FILE=`mktemp XXXXXX`
 fi
 if [ -z "$SERVICE_PORT" ]; then
-   SERVICE_PORT_FILE=`mktemp`
+   SERVICE_PORT_FILE=`mktemp XXXXXX`
 fi
 # Check values in configuration file to determine how we should start coaster-service
@@ -527,12 +529,13 @@
    gensites persistent-coasters -p $CONFIG_FILE > $RUN_DIR/sites.xml
 fi
-# For evil bug #467
-echo "app echo (string i) { echo i; }" > hi.swift
-echo "echo(\"hi\");" >> hi.swift
-swift -sites.file sites.xml -tc.file tc.data -config cf hi.swift > /dev/null 2>&1 &
+# Workaround for bug #467. This is needed to property set jobspernode when using persistent coasters.
+echo "app echo (string i) { echo i; }" > jobspernode.swift
+echo "echo(\"hi\");" >> jobspernode.swift
+echo "persistent-coasters echo /bin/echo null null null" >> jobspernode.apps
+swift -sites.file sites.xml -tc.file jobspernode.apps -config cf jobspernode.swift > /dev/null 2>&1 &
 DUMMYPID=$!
-sleep 15
+sleep 15 # This won't run until later when the workers are started
 # Start workers
 case $WORKER_MODE in
@@ -570,6 +573,7 @@
 # Wait for dummy script to finish
 wait $DUMMYPID
+rm -rf jobspernode* swift.log > /dev/null 2>&1
 # Generate config file
 if [ "$SHARED_FILESYSTEM" == "no" ]; then
