[Swift-commit] r6877 - SwiftApps/Swift-MapRed/TurboChirp
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Fri Aug 16 16:12:12 CDT 2013
Author: wozniak
Date: 2013-08-16 16:12:12 -0500 (Fri, 16 Aug 2013)
New Revision: 6877
Modified:
   SwiftApps/Swift-MapRed/TurboChirp/run.sh
Log:
Minor changes, error check with -e
Modified: SwiftApps/Swift-MapRed/TurboChirp/run.sh
--- SwiftApps/Swift-MapRed/TurboChirp/run.sh	2013-08-16 16:24:36 UTC (rev 6876)
+++ SwiftApps/Swift-MapRed/TurboChirp/run.sh	2013-08-16 21:12:12 UTC (rev 6877)
@@ -1,4 +1,4 @@
-#!/bin/bash
+#!/bin/bash -e
 if [ "$1" == "" ]
 then
@@ -9,10 +9,13 @@
 ./cleanup
 export TURBINE_LOG=1
+export ADLB_EXHAUST_TIME=0.1
 export TURBINE_LAUNCH_OPTS="-f ./hosts.txt"
-stc $PROG > ${PROG%.swift}.tcl
+stc $PROG
 [ "$?" == "0" ] && echo "Compile done"
 #turbine -n 8 ${PROG%.swift}.tcl
 #turbine -l -V -n 10 -f hosts.txt ${PROG%.swift}.tcl -loop=10 -fsize=1 >& ${PROG%.swift}.out
-time turbine -n 10 -f hosts.txt ${PROG%.swift}.tcl -loop=10 -fsize=1
+time turbine -l -n 10 -f hosts.txt ${PROG%.swift}.tcl -loop=10 -fsize=1
 [ "$?" == "0" ] && echo "Execute done"
