[Swift-commit] r6872 - in SwiftTutorials/CIC_2013-08-09: doc part08
    wilde at ci.uchicago.edu
    Thu Aug 15 12:30:06 CDT 2013
Author: wilde
Date: 2013-08-15 12:30:06 -0500 (Thu, 15 Aug 2013)
New Revision: 6872
Added:
   SwiftTutorials/CIC_2013-08-09/part08/app
Removed:
   SwiftTutorials/CIC_2013-08-09/part08/simulate.sh
   SwiftTutorials/CIC_2013-08-09/part08/stats.sh
Modified:
   SwiftTutorials/CIC_2013-08-09/doc/README
   SwiftTutorials/CIC_2013-08-09/part08/p8.swift
Log:
for cic
Modified: SwiftTutorials/CIC_2013-08-09/doc/README
--- SwiftTutorials/CIC_2013-08-09/doc/README	2013-08-15 16:40:46 UTC (rev 6871)
+++ SwiftTutorials/CIC_2013-08-09/doc/README	2013-08-15 17:30:06 UTC (rev 6872)
@@ -10,10 +10,10 @@
 command:
-$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/TUTORIAL-NAME
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/CIC_2013-08-09 tutorial
-This will create a directory called TUTORIAL-NAME which contains all of the
+This will create a directory called "tutorial" which contains all of the
 scripts mentioned in this document.
 Run setup
@@ -22,22 +22,22 @@
 the initial setup.
-$ cd TUTORIAL-NAME       # change to the newly created TUTORIAL-NAME directory
-$ source setup.sh <SITE> # sets swift config files in $HOME/.swift and selects
-                         # a site from the following: ( cloud, uc3, midway )
+$ cd tutorial            # change to the newly created tutorial directory
+$ source setup.sh <SITE> # sets swift config files in $HOME/.swift
+$ java -version          # verify that you have Oracle JAVA (prefered; 1.6 or later)
 $ swift -version         # verify that Swift 0.94 is in your $PATH and functional
-NOTE: If you disconnect from the machine, you will need to re-run source setup.sh.
+NOTE: If you re-login, you will need to re-run source setup.sh.
-Mock "science applications" for the workflow tutorial
+Simple "science applications" for the workflow tutorial
 There are two shell scripts included that serve a very simple stand-ins for science application:
 simulation.sh and stats.sh
 simulation.sh
-The simulation.sh script is a simple substitute for a scientific simulation application. It generates and prints a set of one or more random integers in the range 0-29,999 as controlled by its optional arguments, which are:
+The simulation.sh script serves as a trivial substitute for a complex scientific simulation application. It generates and prints a set of one or more random integers in the range [0-2^32) as controlled by its optional arguments, which are:
 .simulation.sh arguments
 [width="80%",cols="^2,10",options="header"]
@@ -51,7 +51,7 @@
 |5    |count: number of values to generate in the simulation
-With no arguments, simulate.sh prints 1 number in the range of 1-100. Otherwise it generates n numbers of the form R * scale + bias.
+With no arguments, simulate.sh prints 1 number in the range of 1-100. Otherwise it generates n numbers of the form (R*scale)+bias where R is a random integer.
 $ ./simulate.sh
@@ -536,21 +536,21 @@
 .run-dets.sh
-include::part11-swift-py-r/code/run-dets.sh.txt[]
+  include::part11-swift-py-r/code/run-dets.sh.txt[]
 As a reference, an equivalent plain Python code is provided:
 .dets.py
-include::part11-swift-py-r/code/dets.py[]
+  include::part11-swift-py-r/code/dets.py[]
 The Swift script is:
 .dets.swift
-include::part11-swift-py-r/code/dets.swift[]
+  include::part11-swift-py-r/code/dets.swift[]
 ==== Analysis
Added: SwiftTutorials/CIC_2013-08-09/part08/app
--- SwiftTutorials/CIC_2013-08-09/part08/app	                        (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/part08/app	2013-08-15 17:30:06 UTC (rev 6872)
@@ -0,0 +1 @@
+link ../app/
\ No newline at end of file
Property changes on: SwiftTutorials/CIC_2013-08-09/part08/app
___________________________________________________________________
Added: svn:special
Modified: SwiftTutorials/CIC_2013-08-09/part08/p8.swift
--- SwiftTutorials/CIC_2013-08-09/part08/p8.swift	2013-08-15 16:40:46 UTC (rev 6871)
+++ SwiftTutorials/CIC_2013-08-09/part08/p8.swift	2013-08-15 17:30:06 UTC (rev 6872)
@@ -2,19 +2,19 @@
 # Applications to be called by this script
-file simulation_script <"simulate.sh">;
-file analysis_script   <"stats.sh">;
+file simulation_prog <"app/simulate.sh">;
+file analysis_prog   <"app/stats.sh">;
 # app() functions for application programs to be called:
-app (file out) simulation (file script, int timesteps, int sim_range, file bias_file, int scale, int sim_count)
+app (file out) simulation (file prog, int timesteps, int sim_range, file bias_file, int scale, int sim_count)
-  sh @filename(script) timesteps sim_range @filename(bias_file) scale sim_count stdout=@filename(out);
+  sh @filename(prog) timesteps sim_range @filename(bias_file) scale sim_count stdout=@filename(out);
-app (file out) analyze (file script, file s[])
+app (file out) analyze (file prog, file s[])
-  sh @script @filenames(s) stdout=@filename(out);
+  sh @filename(prog) @filenames(s) stdout=@filename(out);
 # Command line params to this script:
@@ -33,9 +33,9 @@
                                            # 1 line: scale offset ( N = n*scale + offset)
 foreach i in [0:nsim-1] {
   file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
-  simout = simulation(simulation_script, steps, range, bias, 100000, count);
+  simout = simulation(simulation_prog, steps, range, bias, 100000, count);
   sims[i] = simout;
 file stats<"output/stats.out">;         # Final output file: average of all "simulations"
-stats = analyze(analysis_script,sims);
+stats = analyze(analysis_prog,sims);
Deleted: SwiftTutorials/CIC_2013-08-09/part08/simulate.sh
--- SwiftTutorials/CIC_2013-08-09/part08/simulate.sh	2013-08-15 16:40:46 UTC (rev 6871)
+++ SwiftTutorials/CIC_2013-08-09/part08/simulate.sh	2013-08-15 17:30:06 UTC (rev 6872)
@@ -1 +0,0 @@
-link ../simulate.sh
Deleted: SwiftTutorials/CIC_2013-08-09/part08/stats.sh
--- SwiftTutorials/CIC_2013-08-09/part08/stats.sh	2013-08-15 16:40:46 UTC (rev 6871)
+++ SwiftTutorials/CIC_2013-08-09/part08/stats.sh	2013-08-15 17:30:06 UTC (rev 6872)
@@ -1 +0,0 @@
-link ../stats.sh
More information about the Swift-commit
