[Swift-commit] r6862 - SwiftTutorials/CIC_2013-08-09
wilde at ci.uchicago.edu
Thu Aug 15 11:17:36 CDT 2013
Author: wilde
Date: 2013-08-15 11:17:36 -0500 (Thu, 15 Aug 2013)
New Revision: 6862
Modified:
SwiftTutorials/CIC_2013-08-09/setup.sh
Log:
for cic
Modified: SwiftTutorials/CIC_2013-08-09/setup.sh
--- SwiftTutorials/CIC_2013-08-09/setup.sh 2013-08-15 16:17:10 UTC (rev 6861)
+++ SwiftTutorials/CIC_2013-08-09/setup.sh 2013-08-15 16:17:36 UTC (rev 6862)
@@ -1,3 +1,51 @@
+# ensure that this script is being sourced
+if [ ${BASH_VERSINFO[0]} -gt 2 -a "${BASH_SOURCE[0]}" = "${0}" ] ; then
+ echo ERROR: script ${BASH_SOURCE[0]} must be executed as: source ${BASH_SOURCE[0]}
+fi
+# Setting scripts folder to the PATH env var.
+DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
+echo Adding $DIR to PATH:
+PATH=$DIR/bin:$DIR/app:$PATH
+# Setting .swift files
+if [ -e $HOME/.swift ]; then
+ savedotswift=$(mktemp -d $HOME/.swift.save.XXXX)
+ echo Saving $HOME/.swift in $savedotswift
+ mv $HOME/.swift/* $savedotswift
+else
+ mkdir -p $HOME/.swift
+fi
+cat >>$HOME/.swift/swift.properties <<END
+# Properties for Swift Tutorial
+sites.file=sites.xml
+tc.file=apps
+wrapperlog.always.transfer=true
+sitedir.keep=true
+file.gc.enabled=false
+status.mode=provider
+execution.retries=0
+lazy.errors=false
+use.wrapper.staging=false
+use.provider.staging=true
+provider.staging.pin.swiftfiles=false
+END
+return
+# OLD, to remove:
#The following line sets the default site
site="uc3"
@@ -34,38 +82,3 @@
echo "Site selected : $site"
site_setup $site
-# Setting scripts folder to the PATH env var.
-DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
-echo Adding $DIR to PATH:
-PATH=$DIR:$PATH
-# Setting .swift files
-if [ -e $HOME/.swift ]; then
- savedotswift=$(mktemp -d $HOME/.swift.save.XXXX)
- echo Saving $HOME/.swift in $savedotswift
- mv $HOME/.swift/* $savedotswift
-else
- mkdir -p $HOME/.swift
-fi
-cat >>$HOME/.swift/swift.properties <<END
-# Properties for Swift Tutorial
-sites.file=sites.xml
-tc.file=apps
-wrapperlog.always.transfer=true
-sitedir.keep=true
-file.gc.enabled=false
-status.mode=provider
-execution.retries=0
-lazy.errors=false
-use.wrapper.staging=false
-use.provider.staging=true
-provider.staging.pin.swiftfiles=true
-END
More information about the Swift-commit
